[PATCH v1] imx: support i.MX8QM DMSSE20 a1 board
Add i.MX8QM DMSSE20 a1 board support
U-Boot 2020.10-rc3-00177-g316f823505 (Aug 31 2020 - 16:08:37 +0200)
Model: Advantech iMX8QM DMSSE20 Board: DMS-SE20A1 8GB Build: SCFW 494c97f3, SECO-FW d7523fe8, ATF 09c5cc9 Boot: USB DRAM: 8 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... Card did not respond to voltage select! *** Warning - No block device, using default environment
In: serial@5a060000 Out: serial@5a060000 Err: serial@5a060000 Net: Warning: ethernet@5b040000 (eth0) using random MAC address - 0e:db:c9:1a:a4:a7 eth0: ethernet@5b040000 [PRIME] Warning: ethernet@5b050000 (eth1) using random MAC address - d2:38:f7:68:ce:91 , eth1: ethernet@5b050000 Hit any key to stop autoboot: 0
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Ye Li ye.li@nxp.com Cc: uboot-imx uboot-imx@nxp.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8qm-dmsse20-a1.dts | 345 ++++++++++++++++++ arch/arm/mach-imx/imx8/Kconfig | 7 + board/advantech/imx8qm_dmsse20_a1/Kconfig | 14 + board/advantech/imx8qm_dmsse20_a1/MAINTAINERS | 6 + board/advantech/imx8qm_dmsse20_a1/Makefile | 8 + board/advantech/imx8qm_dmsse20_a1/README | 61 ++++ .../imx8qm_dmsse20_a1/imx8qm_dmsse20_a1.c | 188 ++++++++++ .../advantech/imx8qm_dmsse20_a1/imximage.cfg | 21 ++ board/advantech/imx8qm_dmsse20_a1/spl.c | 217 +++++++++++ common/Kconfig | 2 +- configs/imx8qm_dmsse20a1_defconfig | 86 +++++ include/configs/imx8qm_dmsse20.h | 219 +++++++++++ 13 files changed, 1174 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8qm-dmsse20-a1.dts create mode 100644 board/advantech/imx8qm_dmsse20_a1/Kconfig create mode 100644 board/advantech/imx8qm_dmsse20_a1/MAINTAINERS create mode 100644 board/advantech/imx8qm_dmsse20_a1/Makefile create mode 100644 board/advantech/imx8qm_dmsse20_a1/README create mode 100644 board/advantech/imx8qm_dmsse20_a1/imx8qm_dmsse20_a1.c create mode 100644 board/advantech/imx8qm_dmsse20_a1/imximage.cfg create mode 100644 board/advantech/imx8qm_dmsse20_a1/spl.c create mode 100644 configs/imx8qm_dmsse20a1_defconfig create mode 100644 include/configs/imx8qm_dmsse20.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f8f529435b..986d1969da 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -752,6 +752,7 @@ dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-com.dtb \ dtb-$(CONFIG_ARCH_IMX8) += \ fsl-imx8qm-apalis.dtb \ fsl-imx8qm-mek.dtb \ + imx8qm-dmsse20-a1.dtb \ imx8qm-rom7720-a1.dtb \ fsl-imx8qxp-ai_ml.dtb \ fsl-imx8qxp-colibri.dtb \ diff --git a/arch/arm/dts/imx8qm-dmsse20-a1.dts b/arch/arm/dts/imx8qm-dmsse20-a1.dts new file mode 100644 index 0000000000..6f4f795e99 --- /dev/null +++ b/arch/arm/dts/imx8qm-dmsse20-a1.dts @@ -0,0 +1,345 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017 NXP + */ + +/dts-v1/; + +/* First 128KB is for PSCI ATF. */ +/memreserve/ 0x80000000 0x00020000; + +#include "fsl-imx8qm.dtsi" + +/ { + model = "Advantech iMX8QM DMSSE20"; + compatible = "fsl,imx8qm-mek", "fsl,imx8qm"; + + aliases { + mmc0 = &usdhc1; + mmc2 = &usdhc3; + }; + + chosen { + bootargs = "console=ttyLP0,115200 earlycon=lpuart32,0x5a060000,115200"; + stdout-path = &lpuart0; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_usb_otg1_vbus: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "usb_otg1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 3 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_usdhc2_vmmc: usdhc2_vmmc { + compatible = "regulator-fixed"; + regulator-name = "sw-3p3-sd1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio4 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + busfreq { + status = "disabled"; + }; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog_1>; + + imx8qm-mek { + pinctrl_hog_1: hoggrp-1 { + fsl,pins = < + SC_P_USB_SS3_TC0_LSIO_GPIO4_IO03 0x06000048 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETB_PAD 0x000014a0 + SC_P_ENET0_MDC_CONN_ENET0_MDC 0x06000020 + SC_P_ENET0_MDIO_CONN_ENET0_MDIO 0x06000020 + SC_P_ENET0_RGMII_TX_CTL_CONN_ENET0_RGMII_TX_CTL 0x00000060 + SC_P_ENET0_RGMII_TXC_CONN_ENET0_RGMII_TXC 0x00000060 + SC_P_ENET0_RGMII_TXD0_CONN_ENET0_RGMII_TXD0 0x00000060 + SC_P_ENET0_RGMII_TXD1_CONN_ENET0_RGMII_TXD1 0x00000060 + SC_P_ENET0_RGMII_TXD2_CONN_ENET0_RGMII_TXD2 0x00000060 + SC_P_ENET0_RGMII_TXD3_CONN_ENET0_RGMII_TXD3 0x00000060 + SC_P_ENET0_RGMII_RXC_CONN_ENET0_RGMII_RXC 0x00000060 + SC_P_ENET0_RGMII_RX_CTL_CONN_ENET0_RGMII_RX_CTL 0x00000060 + SC_P_ENET0_RGMII_RXD0_CONN_ENET0_RGMII_RXD0 0x00000060 + SC_P_ENET0_RGMII_RXD1_CONN_ENET0_RGMII_RXD1 0x00000060 + SC_P_ENET0_RGMII_RXD2_CONN_ENET0_RGMII_RXD2 0x00000060 + SC_P_ENET0_RGMII_RXD3_CONN_ENET0_RGMII_RXD3 0x00000060 + >; + }; + + pinctrl_fec2: fec2grp { + fsl,pins = < + SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETA_PAD 0x000014a0 + SC_P_ENET1_MDC_CONN_ENET1_MDC 0x06000020 + SC_P_ENET1_MDIO_CONN_ENET1_MDIO 0x06000020 + SC_P_ENET1_RGMII_TX_CTL_CONN_ENET1_RGMII_TX_CTL 0x00000060 + SC_P_ENET1_RGMII_TXC_CONN_ENET1_RGMII_TXC 0x00000060 + SC_P_ENET1_RGMII_TXD0_CONN_ENET1_RGMII_TXD0 0x00000060 + SC_P_ENET1_RGMII_TXD1_CONN_ENET1_RGMII_TXD1 0x00000060 + SC_P_ENET1_RGMII_TXD2_CONN_ENET1_RGMII_TXD2 0x00000060 + SC_P_ENET1_RGMII_TXD3_CONN_ENET1_RGMII_TXD3 0x00000060 + SC_P_ENET1_RGMII_RXC_CONN_ENET1_RGMII_RXC 0x00000060 + SC_P_ENET1_RGMII_RX_CTL_CONN_ENET1_RGMII_RX_CTL 0x00000060 + SC_P_ENET1_RGMII_RXD0_CONN_ENET1_RGMII_RXD0 0x00000060 + SC_P_ENET1_RGMII_RXD1_CONN_ENET1_RGMII_RXD1 0x00000060 + SC_P_ENET1_RGMII_RXD2_CONN_ENET1_RGMII_RXD2 0x00000060 + SC_P_ENET1_RGMII_RXD3_CONN_ENET1_RGMII_RXD3 0x00000060 + >; + }; + + pinctrl_lpuart0: lpuart0grp { + fsl,pins = < + SC_P_UART0_RX_DMA_UART0_RX 0x06000020 + SC_P_UART0_TX_DMA_UART0_TX 0x06000020 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000021 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000021 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000021 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000021 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000021 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000021 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000021 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000021 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000021 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x06000041 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000021 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000040 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000020 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000020 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000020 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000020 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000020 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000020 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000020 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000020 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000020 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x06000040 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000020 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000040 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000020 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000020 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000020 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000020 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000020 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000020 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000020 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000020 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000020 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x06000040 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000020 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2grpgpio { + fsl,pins = < + SC_P_USDHC1_RESET_B_LSIO_GPIO4_IO07 0x00000020 + SC_P_USDHC1_VSELECT_LSIO_GPIO4_IO08 0x00000020 + >; + }; + + pinctrl_usdhc3_gpio: usdhc3grpgpio { + fsl,pins = < + SC_P_USDHC2_WP_LSIO_GPIO4_IO11 0x00000021 + SC_P_USDHC2_CD_B_LSIO_GPIO4_IO12 0x00000021 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000021 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000021 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000021 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000021 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000021 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000021 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000040 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000020 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000020 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000020 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000020 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000020 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000040 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000020 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000020 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000020 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000020 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000020 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + SC_P_USDHC2_CLK_CONN_USDHC2_CLK 0x06000041 + SC_P_USDHC2_CMD_CONN_USDHC2_CMD 0x00000021 + SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0 0x00000021 + SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1 0x00000021 + SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2 0x00000021 + SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3 0x00000021 + SC_P_USDHC2_VSELECT_CONN_USDHC2_VSELECT 0x00000021 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp100mhz { + fsl,pins = < + SC_P_USDHC2_CLK_CONN_USDHC2_CLK 0x06000040 + SC_P_USDHC2_CMD_CONN_USDHC2_CMD 0x00000020 + SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0 0x00000020 + SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1 0x00000020 + SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2 0x00000020 + SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3 0x00000020 + SC_P_USDHC2_VSELECT_CONN_USDHC2_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp200mhz { + fsl,pins = < + SC_P_USDHC2_CLK_CONN_USDHC2_CLK 0x06000040 + SC_P_USDHC2_CMD_CONN_USDHC2_CMD 0x00000020 + SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0 0x00000020 + SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1 0x00000020 + SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2 0x00000020 + SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3 0x00000020 + SC_P_USDHC2_VSELECT_CONN_USDHC2_VSELECT 0x00000020 + >; + }; + }; +}; + +&gpio2 { + status = "okay"; +}; + +&gpio4 { + status = "okay"; +}; + +&gpio5 { + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + bus-width = <4>; + cd-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio5 21 GPIO_ACTIVE_HIGH>; + vmmc-supply = <®_usdhc2_vmmc>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default","state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>, <&pinctrl_usdhc3_gpio>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>, <&pinctrl_usdhc3_gpio>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>, <&pinctrl_usdhc3_gpio>; + bus-width = <4>; + cd-gpios = <&gpio4 12 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio4 11 GPIO_ACTIVE_HIGH>; + no-1-8-v; + status = "okay"; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,ar8031-phy-fixup; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@4 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <4>; + }; + }; +}; + +&fec2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec2>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy1>; + fsl,ar8031-phy-fixup; + fsl,magic-packet; + status = "okay"; + fsl,mii-exclusive; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy1: ethernet-phy@4 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <4>; + }; + }; +}; + +&lpuart0 { /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart0>; + status = "okay"; +}; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index 9d1f73dfc7..ee6781c6f7 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -86,6 +86,12 @@ config TARGET_IMX8QM_ROM7720_A1 select SUPPORT_SPL select IMX8QM
+config TARGET_IMX8QM_DMSSE20_A1 + bool "Support i.MX8QM DMS-SE20-A1 board" + select BOARD_LATE_INIT + select SUPPORT_SPL + select IMX8QM + config TARGET_IMX8QXP_MEK bool "Support i.MX8QXP MEK board" select BOARD_LATE_INIT @@ -95,6 +101,7 @@ endchoice
source "board/freescale/imx8qm_mek/Kconfig" source "board/freescale/imx8qxp_mek/Kconfig" +source "board/advantech/imx8qm_dmsse20_a1/Kconfig" source "board/advantech/imx8qm_rom7720_a1/Kconfig" source "board/toradex/apalis-imx8/Kconfig" source "board/toradex/colibri-imx8x/Kconfig" diff --git a/board/advantech/imx8qm_dmsse20_a1/Kconfig b/board/advantech/imx8qm_dmsse20_a1/Kconfig new file mode 100644 index 0000000000..1d5e68a96f --- /dev/null +++ b/board/advantech/imx8qm_dmsse20_a1/Kconfig @@ -0,0 +1,14 @@ +if TARGET_IMX8QM_DMSSE20_A1 + +config SYS_BOARD + default "imx8qm_dmsse20_a1" + +config SYS_VENDOR + default "advantech" + +config SYS_CONFIG_NAME + default "imx8qm_dmsse20" + +source "board/freescale/common/Kconfig" + +endif diff --git a/board/advantech/imx8qm_dmsse20_a1/MAINTAINERS b/board/advantech/imx8qm_dmsse20_a1/MAINTAINERS new file mode 100644 index 0000000000..c1e8048bbb --- /dev/null +++ b/board/advantech/imx8qm_dmsse20_a1/MAINTAINERS @@ -0,0 +1,6 @@ +i.MX8QM ROM DMSSE20 a1 BOARD +M: Oliver Graute oliver.graute@kococonnector.com +S: Maintained +F: board/advantech/imx8qm_dmsse20_a1/ +F: include/configs/imx8qm_dmsse20.h +F: configs/imx8qm_dmsse20a1_defconfig diff --git a/board/advantech/imx8qm_dmsse20_a1/Makefile b/board/advantech/imx8qm_dmsse20_a1/Makefile new file mode 100644 index 0000000000..262ffcd683 --- /dev/null +++ b/board/advantech/imx8qm_dmsse20_a1/Makefile @@ -0,0 +1,8 @@ +# +# Copyright 2017 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += imx8qm_dmsse20_a1.o +obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/board/advantech/imx8qm_dmsse20_a1/README b/board/advantech/imx8qm_dmsse20_a1/README new file mode 100644 index 0000000000..2105e9c425 --- /dev/null +++ b/board/advantech/imx8qm_dmsse20_a1/README @@ -0,0 +1,61 @@ +U-Boot for the NXP i.MX8QM DMSSE20-a1 board + +Quick Start +=========== + +- Build the ARM Trusted firmware binary +- Get scfw_tcm.bin and ahab-container.img +- Get imx-mkimage +- Build U-Boot +- Build imx-mkimage +- Flash the binary into the SD card +- Boot + +Get and Build the ARM Trusted firmware +====================================== + +$ git clone https://source.codeaurora.org/external/imx/imx-atf +$ cd imx-atf/ +$ git checkout origin/imx_4.14.78_1.0.0_ga -b imx_4.14.78_1.0.0_ga +$ make PLAT=imx8qm bl31 + +Get scfw_tcm.bin and ahab-container.img +============================== + +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-sc-firmware-1.1.bin +$ chmod +x imx-sc-firmware-1.1.bin +$ ./imx-sc-firmware-1.1.bin +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin +$ chmod +x firmware-imx-8.0.bin +$ ./firmware-imx-8.0.bin + +Or use this to avoid running random scripts from the internet, +but note that you must agree to the license the script displays: + +$ dd if=imx-sc-firmware-1.1.bin of=imx-sc-firmware-1.1.tar.bz2 bs=37185 skip=1 +$ tar -xf imx-sc-firmware-1.1.tar.bz2 +$ cp imx-sc-firmware-1.1/mx8qm-val-scfw-tcm.bin $(builddir) + +$ dd if=firmware-imx-8.0.bin of=firmware-imx-8.0.tar.bz2 bs=37180 skip=1 +$ tar -xf firmware-imx-8.0.tar.bz2 +$ cp firmware-imx-8.0/firmware/seco/mx8qm-ahab-container.img $(builddir) + +Build U-Boot +============ + +$ export ATF_LOAD_ADDR=0x80000000 +$ export BL33_LOAD_ADDR=0x80020000 +$ make imx8qm_dmsse20a1_defconfig +$ make u-boot.bin +$ make flash.bin + +Flash the binary into the SD card +================================= + +Burn the flash.bin binary to SD card offset 32KB: + +$ sudo dd if=flash.bin of=/dev/sd[x] bs=1k seek=32 conv=fsync + +Boot +==== +Set Boot switch SW1: 011100. diff --git a/board/advantech/imx8qm_dmsse20_a1/imx8qm_dmsse20_a1.c b/board/advantech/imx8qm_dmsse20_a1/imx8qm_dmsse20_a1.c new file mode 100644 index 0000000000..b93d2046f5 --- /dev/null +++ b/board/advantech/imx8qm_dmsse20_a1/imx8qm_dmsse20_a1.c @@ -0,0 +1,188 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017-2018 NXP + * Copyright (C) 2020 Oliver Graute oliver.graute@kococonnector.com + */ + +#include <common.h> +#include <errno.h> +#include <linux/libfdt.h> +#include <asm/io.h> +#include <asm/gpio.h> +#include <asm/arch/clock.h> +#include <asm/arch/sci/sci.h> +#include <asm/arch/imx8-pins.h> +#include <asm/arch/iomux.h> +#include <asm/arch/sys_proto.h> +/* #include <power-domain.h> */ + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +static iomux_cfg_t uart0_pads[] = { + SC_P_UART0_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + SC_P_UART0_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx8_iomux_setup_multiple_pads(uart0_pads, ARRAY_SIZE(uart0_pads)); +} + +int board_early_init_f(void) +{ + sc_pm_clock_rate_t rate = SC_80MHZ; + int ret; + + /* Set UART0 clock root to 80 MHz */ + ret = sc_pm_setup_uart(SC_R_UART_0, rate); + if (ret) + return ret; + + setup_iomux_uart(); + + /* This is needed to because Kernel do not Power Up DC_0 */ + sc_pm_set_resource_power_mode(-1, SC_R_DC_0, SC_PM_PW_MODE_ON); + sc_pm_set_resource_power_mode(-1, SC_R_GPIO_5, SC_PM_PW_MODE_ON); + + return 0; +} + +#if IS_ENABLED(CONFIG_FEC_MXC) +#include <miiphy.h> + +int board_phy_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} +#endif + +#ifdef CONFIG_MXC_GPIO + +#define LVDS_ENABLE IMX_GPIO_NR(1, 6) +#define MIPI_ENABLE IMX_GPIO_NR(1, 7) + +#define BB_GPIO_3V3_1 IMX_GPIO_NR(4, 20) +#define BB_GPIO_3V3_2 IMX_GPIO_NR(4, 24) +#define BB_GPIO_3V3_3 IMX_GPIO_NR(4, 23) + +static void board_gpio_init(void) +{ + /* Enable BB 3V3 */ + gpio_request(BB_GPIO_3V3_1, "bb_3v3_1"); + gpio_direction_output(BB_GPIO_3V3_1, 1); + gpio_request(BB_GPIO_3V3_2, "bb_3v3_2"); + gpio_direction_output(BB_GPIO_3V3_2, 1); + gpio_request(BB_GPIO_3V3_3, "bb_3v3_3"); + gpio_direction_output(BB_GPIO_3V3_3, 1); + + /* enable LVDS SAS boards */ + gpio_request(LVDS_ENABLE, "lvds_enable"); + gpio_direction_output(LVDS_ENABLE, 1); + + /* enable MIPI SAS boards */ + gpio_request(MIPI_ENABLE, "mipi_enable"); + gpio_direction_output(MIPI_ENABLE, 1); +} +#endif + +int checkboard(void) +{ + puts("Board: DMS-SE20A1 8GB\n"); + build_info(); + print_bootinfo(); + + return 0; +} + +int board_init(void) +{ + if (IS_ENABLED(CONFIG_XEN)) + return 0; + +#ifdef CONFIG_MXC_GPIO + board_gpio_init(); +#endif + + return 0; +} + +void board_quiesce_devices(void) +{ + if (IS_ENABLED(CONFIG_XEN)) { + /* Clear magic number to let xen know uboot is over */ + writel(0x0, (void __iomem *)0x80000000); + return; + } +} + +void detail_board_ddr_info(void) +{ + puts("\nDDR "); +} + +/* + * Board specific reset that is system reset. + */ +void reset_cpu(ulong addr) +{ + puts("SCI reboot request"); + + while (1) + putc('.'); +} + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, struct bd_info *bd) +{ + return 0; +} +#endif + +int board_mmc_get_env_dev(int devno) +{ + /* Use EMMC */ + if (IS_ENABLED(CONFIG_XEN)) + return 0; + + return devno; +} + +int mmc_map_to_kernel_blk(int dev_no) +{ + /* Use EMMC */ + if (IS_ENABLED(CONFIG_XEN)) + return 0; + + return dev_no; +} + +int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + env_set("board_name", "DMS-SE20A1"); + env_set("board_rev", "iMX8QM"); +#endif + + env_set("sec_boot", "no"); +#ifdef CONFIG_AHAB_BOOT + env_set("sec_boot", "yes"); +#endif + + return 0; +} diff --git a/board/advantech/imx8qm_dmsse20_a1/imximage.cfg b/board/advantech/imx8qm_dmsse20_a1/imximage.cfg new file mode 100644 index 0000000000..e324c7ca37 --- /dev/null +++ b/board/advantech/imx8qm_dmsse20_a1/imximage.cfg @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#define __ASSEMBLY__ + +/* Boot from SD, sector size 0x400 */ +BOOT_FROM SD 0x400 +/* SoC type IMX8QM */ +SOC_TYPE IMX8QM +/* Append seco container image */ +APPEND mx8qm-ahab-container.img +/* Create the 2nd container */ +CONTAINER +/* Add scfw image with exec attribute */ +IMAGE SCU mx8qm-val-scfw-tcm.bin +/* Add ATF image with exec attribute */ +IMAGE A35 bl31.bin 0x80000000 +/* Add U-Boot image with load attribute */ +DATA A35 u-boot-dtb.bin 0x80020000 diff --git a/board/advantech/imx8qm_dmsse20_a1/spl.c b/board/advantech/imx8qm_dmsse20_a1/spl.c new file mode 100644 index 0000000000..8eb3d53c91 --- /dev/null +++ b/board/advantech/imx8qm_dmsse20_a1/spl.c @@ -0,0 +1,217 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017-2018 NXP + */ +#include <common.h> +#include <dm.h> +#include <spl.h> +#include <fsl_esdhc.h> + +#include <asm/io.h> +#include <asm/gpio.h> +#include <asm/arch/clock.h> +#include <asm/arch/sci/sci.h> +#include <asm/arch/imx8-pins.h> +#include <asm/arch/iomux.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define ESDHC_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ESDHC_CLK_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ENET_INPUT_PAD_CTRL ((SC_PAD_CONFIG_OD_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_18V_10MA << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ENET_NORMAL_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_18V_10MA << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define FSPI_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define GPIO_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define I2C_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_LOW << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define UART_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) +#ifdef CONFIG_FSL_ESDHC_IMX + +#define USDHC1_CD_GPIO IMX_GPIO_NR(5, 22) +#define USDHC2_CD_GPIO IMX_GPIO_NR(4, 12) + +static struct fsl_esdhc_cfg usdhc_cfg[CONFIG_SYS_FSL_USDHC_NUM] = { + {USDHC1_BASE_ADDR, 0, 8}, + {USDHC3_BASE_ADDR, 0, 4}, +}; + +static iomux_cfg_t emmc0[] = { + SC_P_EMMC0_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL), + SC_P_EMMC0_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA4 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA5 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA6 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA7 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_STROBE | MUX_PAD_CTRL(ESDHC_PAD_CTRL), +}; + +static iomux_cfg_t usdhc2_sd[] = { + SC_P_USDHC2_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL), + SC_P_USDHC2_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_WP | MUX_MODE_ALT(3) | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_CD_B | MUX_MODE_ALT(3) | MUX_PAD_CTRL(ESDHC_PAD_CTRL), +}; + +int board_mmc_init(struct bd_info *bis) +{ + int i, ret; + + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + * mmc2 USDHC3 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + ret = sc_pm_set_resource_power_mode(-1, SC_R_SDHC_0, SC_PM_PW_MODE_ON); + if (ret != SC_ERR_NONE) + return ret; + + imx8_iomux_setup_multiple_pads(emmc0, ARRAY_SIZE(emmc0)); + init_clk_usdhc(0); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + break; + case 1: + ret = sc_pm_set_resource_power_mode(-1, SC_R_SDHC_2, SC_PM_PW_MODE_ON); + if (ret != SC_ERR_NONE) + return ret; + ret = sc_pm_set_resource_power_mode(-1, SC_R_GPIO_4, SC_PM_PW_MODE_ON); + if (ret != SC_ERR_NONE) + return ret; + + imx8_iomux_setup_multiple_pads(usdhc2_sd, ARRAY_SIZE(usdhc2_sd)); + init_clk_usdhc(2); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + gpio_request(USDHC2_CD_GPIO, "sd2_cd"); + gpio_direction_input(USDHC2_CD_GPIO); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return 0; + } + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + + return 0; +} + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = 1; + break; + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + case USDHC3_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + break; + } + + return ret; +} + +#endif /* CONFIG_FSL_ESDHC_IMX */ + +void spl_board_init(void) +{ +#if defined(CONFIG_SPL_SPI_SUPPORT) + if (sc_rm_is_resource_owned(-1, SC_R_FSPI_0)) { + if (sc_pm_set_resource_power_mode(-1, SC_R_FSPI_0, SC_PM_PW_MODE_ON)) + puts("Warning: failed to initialize FSPI0\n"); + } +#endif + + puts("Normal Boot\n"); +} + +void spl_board_prepare_for_boot(void) +{ +#if defined(CONFIG_SPL_SPI_SUPPORT) + if (sc_rm_is_resource_owned(-1, SC_R_FSPI_0)) { + if (sc_pm_set_resource_power_mode(-1, SC_R_FSPI_0, SC_PM_PW_MODE_OFF)) + puts("Warning: failed to turn off FSPI0\n"); + } +#endif +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + arch_cpu_init(); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + board_init_r(NULL, 0); +} diff --git a/common/Kconfig b/common/Kconfig index c58f08ba91..538dda1c10 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -896,7 +896,7 @@ config BOARD_LATE_INIT
config DISPLAY_CPUINFO bool "Display information about the CPU during start up" - default y if ARC|| ARM || NIOS2 || X86 || XTENSA || M68K + default y if ARC || ARM || NIOS2 || X86 || XTENSA || M68K help Display information about the CPU that U-Boot is running on when U-Boot starts up. The function print_cpuinfo() is called diff --git a/configs/imx8qm_dmsse20a1_defconfig b/configs/imx8qm_dmsse20a1_defconfig new file mode 100644 index 0000000000..242b817733 --- /dev/null +++ b/configs/imx8qm_dmsse20a1_defconfig @@ -0,0 +1,86 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8=y +CONFIG_SYS_TEXT_BASE=0x80020000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_TARGET_IMX8QM_DMSSE20_A1=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_OFFSET=0x400000 +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/advantech/imx8qm_dmsse20_a1/imximage.cfg" +CONFIG_OF_CONTROL=y +CONFIG_CI_UDC=y +CONFIG_DM_PCA953X=y +CONFIG_BOOTDELAY=3 +CONFIG_LOG=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_IMX_BOOTAUX=y +CONFIG_FS_FAT=y +CONFIG_FS_EXT4=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_BROKEN_CD=y +CONFIG_CMD_SF=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_EXT4=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8qm-dmsse20-a1" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK=y +CONFIG_CLK_IMX8=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +# CONFIG_EFI_LOADER is not set +CONFIG_FEC_MXC_SHARE_MDIO=y +CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_MISC=y +CONFIG_SMC_FUSE=y +CONFIG_BOOTAUX_RESERVED_MEM_BASE=0x88000000 +CONFIG_BOOTAUX_RESERVED_MEM_SIZE=0x08000000 +# CONFIG_DISPLAY_CPUINFO is not set diff --git a/include/configs/imx8qm_dmsse20.h b/include/configs/imx8qm_dmsse20.h new file mode 100644 index 0000000000..e1e0bc6e38 --- /dev/null +++ b/include/configs/imx8qm_dmsse20.h @@ -0,0 +1,219 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017-2019 NXP + */ + +#ifndef __IMX8QM_DMSSE20_H +#define __IMX8QM_DMSSE20_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> +#define CONFIG_REMAKE_ELF + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_MAX_SIZE (124 * 1024) +#define CONFIG_SPL_BSS_START_ADDR 0x00128000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x1000 /* 4 KB */ +#endif + +#define CONFIG_NR_DRAM_BANKS 4 + +/* #define CONFIG_ARCH_MISC_INIT */ + +/* #define CONFIG_CMD_READ */ + +/* Flat Device Tree Definitions */ +#define CONFIG_OF_BOARD_SETUP + +/* #undef CONFIG_CMD_EXPORTENV */ +/* #undef CONFIG_CMD_IMPORTENV */ +/* #undef CONFIG_CMD_IMLS */ + +/* #undef CONFIG_CMD_CRC32 */ +#undef CONFIG_BOOTM_NETBSD + +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define USDHC1_BASE_ADDR 0x5B010000 +#define USDHC2_BASE_ADDR 0x5B020000 +#define USDHC3_BASE_ADDR 0x5B030000 + +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +/* FUSE command */ +#define CONFIG_CMD_FUSE + +#define CONFIG_FEC_XCV_TYPE RGMII +#define FEC_QUIRK_ENET_MAC + +#define CONFIG_PHY_GIGE /* Support for 1000BASE-X */ + +/* ENET0 connects AR8031 on CPU board */ +#define CONFIG_FEC1_ENET_DEV 0 + +/* ENET1 connects AR8031 on CPU board */ +#define CONFIG_FEC2_ENET_DEV 1 +#define CONFIG_FEC_MXC_PHYADDR 0x4 +#define IMX_FEC_BASE 0x5B040000 +/* FEC1 */ +#define IMX_FEC1_BASE 0x5B040000 +#define CONFIG_FEC1_MXC_PHYADDR 0x4 +#define CONFIG_ETHPRIME "eth0" +/* FEC2 */ +#define IMX_FEC2_BASE 0x5B050000 +#define CONFIG_FEC2_MXC_PHYADDR 0x4 +#define CONFIG_ETHPRIME1 "eth1" + +/* Boot M4 */ +#define M4_BOOT_ENV \ + "m4_0_image=m4_0.bin\0" \ + "m4_1_image=m4_1.bin\0" \ + "loadm4image_0=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${m4_0_image}\0" \ + "loadm4image_1=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${m4_1_image}\0" \ + "m4boot_0=run loadm4image_0; dcache flush; bootaux ${loadaddr} 0\0" \ + "m4boot_1=run loadm4image_1; dcache flush; bootaux ${loadaddr} 1\0" \ + +#ifdef CONFIG_NAND_BOOT +#define MFG_NAND_PARTITION "mtdparts=gpmi-nand:128m(boot),32m(kernel),16m(dtb),8m(misc),-(rootfs) " +#else +#define MFG_NAND_PARTITION "" +#endif + +#define CONFIG_MFG_ENV_SETTINGS \ + "mfgtool_args=setenv bootargs console=${console},${baudrate} " \ + "initrd_addr=0x83100000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "emmc_dev=0\0" \ + "sd_dev=1\0" \ + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_MFG_ENV_SETTINGS \ + M4_BOOT_ENV \ + "script=boot.scr\0" \ + "image=Image\0" \ + "panel=NULL\0" \ + "console=ttyLP0\0" \ + "earlycon=lpuart32,0x5a060000\0" \ + "fdt_addr=0x83000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "boot_fdt=try\0" \ + "fdt_file=imx8qm-dmsse20-a1.dtb\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} earlycon=${earlycon},${baudrate} root=${mmcroot}\0 " \ + "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "echo wait for boot; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} earlycon=${earlycon},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp mac=${ethaddr} nfsroot=${serverip}:${nfsroot},v3,tcp rw\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "booti; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else booti ${loadaddr} - ${fdt_addr}; fi" + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x80280000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_SP_ADDR 0x80200000 + +/* Default environment is in SD */ + +#ifdef CONFIG_QSPI_BOOT +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#else +#define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ +#endif + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 0 + +#define CONFIG_SYS_MMC_ENV_DEV 2 /* USDHC3 */ +#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC3 */ +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN ((CONFIG_ENV_SIZE + (32 * 1024)) * 1024) + +#define CONFIG_SYS_SDRAM_BASE 0x080000000 +#define PHYS_SDRAM_1 0x080000000 +#define PHYS_SDRAM_2 0x880000000 +#define PHYS_SDRAM_1_SIZE 0x080000000 /* 2 GB */ +#define PHYS_SDRAM_2_SIZE 0x180000000 /* 6 GB */ + +#define CONFIG_SYS_MEMTEST_START 0xA0000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (PHYS_SDRAM_1_SIZE >> 2)) + +/* Serial */ +#define CONFIG_BAUDRATE 115200 + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 8000000 /* 8MHz */ + +#define CONFIG_IMX_SMMU + +/* MT35XU512ABA1G12 has only one Die, so QSPI0 B won't work */ +#ifdef CONFIG_FSL_FSPI +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS 0 +#define CONFIG_SF_DEFAULT_SPEED 40000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define FSL_FSPI_FLASH_SIZE SZ_64M +#define FSL_FSPI_FLASH_NUM 1 +#define FSPI0_BASE_ADDR 0x5d120000 +#define FSPI0_AMBA_BASE 0 +#define CONFIG_SYS_FSL_FSPI_AHB +#endif + +/* #define CONFIG_OF_SYSTEM_SETUP */ + +#endif /* __IMX8QM_DMSSE20_H */
[snip]
You should also list the dts files.
[snip]
This should be rST and in doc/board/
[snip]
- Copyright 2017-2019 NXP
Do we really need these includes here?
These guards are unnecessary.
Don't include commented out defines please.
You cannot enable/disable commands in the header file, that's an error to checkpatch as they've all been in Kconfig for some time. CONFIG_BOOTM_xxx has been for a bit as well. Please audit the whole file for things which are already in Kconfig, thanks.
- "mfgtool_args=setenv bootargs console=${console},${baudrate} " \
- "initrd_addr=0x83100000\0" \
- "initrd_high=0xffffffffffffffff\0" \
It's not a good idea, but not fatal to disable initrd relocation.
- "emmc_dev=0\0" \
- "sd_dev=1\0" \
- CONFIG_MFG_ENV_SETTINGS \
- M4_BOOT_ENV \
- "script=boot.scr\0" \
- "image=Image\0" \
- "panel=NULL\0" \
- "console=ttyLP0\0" \
- "earlycon=lpuart32,0x5a060000\0" \
- "fdt_addr=0x83000000\0" \
- "fdt_high=0xffffffffffffffff\0" \
It is however fatal to disable fdt relocation. It's far too easy for real life examples to generated non-8-byte-aligned addresses for the dtb and the Linux blows up. Please also see include/configs/ti_armv7_common.h and the big block comment about where to place and how much space to have between the kernel, initrd and device tree. While that's for a 32bit platform, it's all applicable to aarch64 (perhaps with the caveat that dtb can be up to 2MiB? off the top of my head).
[snip]
ok will do that
[snip]
ok will do that
[snip]
I got some errors if I remove these two lines. So I keep them.
ok will remove that
ok will remove that
ok will remove that
- "emmc_dev=0\0" \
- "sd_dev=1\0" \
- M4_BOOT_ENV \
- "image=Image\0" \
- "panel=NULL\0" \
not sure If I full understood that. I will remove the fdt_high line.
thx for your feedback.
Oliver
Hi Oliver,
On Mon, Aug 31, 2020 at 11:54 AM Oliver Graute oliver.graute@kococonnector.com wrote:
The imx-mkimage is only needed for building the NXP U-Boot, right?
On 31/08/20, Fabio Estevam wrote:
Hi Oliver,
ok I'll remove that line
Best Regards,
Oliver
Fabio Estevam
Oliver Graute
Oliver Graute
