[U-Boot] ubi part partation issue (ubi at u-boot)
Hi All,
i am following following issues when using samsung flex-onenand of size 1GB.
1. I am doing following steps,
0) onenand erase force 0x200000 0x6400000
if i erase full onenand my oneboot and uboot also get erased( which are at first block of onenand) i do not know is there different erase command for SLC and MLC. if any body is having idea how to do pls let me know.
onenand_erase: start = 0x06500000, len = 131072 onenand_erase: start = 0x06520000, len = 131072 onenand_erase: start = 0x06540000, len = 131072 onenand_erase: start = 0x06560000, len = 131072 onenand_erase: start = 0x06580000, len = 131072 onenand_erase: start = 0x065a0000, len = 131072 onenand_erase: start = 0x065c0000, len = 131072 onenand_erase: start = 0x065e0000, len = 131072 OK
a) mtdparts
mtdparts
---mtdparts_init--- last_ids : onenand0=onenand env_ids : onenand0=onenand last_parts: mtdparts=onenand:256k@1m(params),8m@2m(kernel),16m(rootfs),32m(fs),- (ubifs) env_parts : mtdparts=onenand:256k@1m(params),8m@2m(kernel),16m(rootfs),32m(fs),- (ubifs)
last_partition : onenand0,0 env_partition : onenand0,0
---list_partitions---
device onenand0 <onenand>, # parts = 5 #: name size offset mask_flags 0: params 0x00040000 0x00100000 0 1: kernel 0x00800000 0x00200000 0 2: rootfs 0x01000000 0x00a00000 0 3: fs 0x02000000 0x01a00000 0 4: ubifs 0x2c600000 0x03a00000 0
--- mtd_part_info: partition number 0 for device onenand0 (onenand)
active partition: onenand0,0 - (params) 0x00040000 @ 0x00100000
defaults: mtdids : onenand0=onenand mtdparts: mtdparts=onenand:256k@1m(params),8m@2m(kernel),16m(rootfs),32m(fs),-(u bifs)
******* Reboot the target ***************** b) ubi part kernel
LEONID # ubi part kernel
last_partition : onenand0,0 env_partition : onenand0=onenand --- getting current partition: onenand0=onenand --- find_dev_and_part --- id = onenand0=onenand no partition number specified 448 do_ubi -1454 do_ubi -2466 do_ubi -5UBI: mtd1 is detached from ubi0 --- find_dev_and_part --- id = kernel --- find_dev_and_part --- id = kernel Creating 1 MTD partitions on "onenand0": 0x%lx-0x%lx : "" UBI: attaching mtd1 to ubi0 ubi_attach_mtd_dev UBI: min_io_size 2048 UBI: hdrs_min_io_size 512 UBI: ec_hdr_alsize 512 UBI: vid_hdr_alsize 512 UBI: vid_hdr_offset 512 UBI: vid_hdr_aloffset 512 UBI: vid_hdr_shift 0 UBI: leb_start 2048 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 129024 bytes UBI: logical eraseblock size: 129024 bytes UBI: sub-page size: 512 UBI: VID header offset: 512 (aligned 512) UBI: data offset: 2048 $$$$$$$$$$$$$abcd 0x20000,0x67821140e1attach_by_scanning-1 attach_by_scanning-2 attach_by_scanning-3 attach_by_scanning-4 attach_by_scanning-5 attach_by_scanning-6 attach_by_scanning-7 23ubi_attach_mtd_dev error code =0UBI: attached mtd1 to ubi0 UBI: MTD device name: "mtd=1" UBI: MTD device size: %lu MiB UBI: number of good PEBs: 51 UBI: number of bad PEBs: 13 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 0 UBI: available PEBs: 45 UBI: total number of reserved PEBs: 6 UBI: number of PEBs reserved for bad PEB handling: 2 UBI: max/mean erase counter: 1/1
# ubi part kernel
c1) ubi create kernel 0x600000 s
i face below error
# ubi create kernel 0x600000 s
last_partition : onenand0,0 env_partition : onenand0=onenand --- getting current partition: onenand0=onenand --- find_dev_and_part --- id = onenand0=onenand no partition number specified 448 do_ubi -1512 do_ubi -3Creating static volume kernel of size 6291456 UBI error: ubi_create_volume: cannot create volume 0, error -28
c2) ubi create kernel is sucessfull
last_partition : onenand0,0 env_partition : onenand0=onenand --- getting current partition: onenand0=onenand --- find_dev_and_part --- id = onenand0=onenand no partition number specified 448 do_ubi -1512 do_ubi -3Creating static volume kernel of size 6291456 UBI error: ubi_create_volume: cannot create volume 0, error -28 LEONID # ubi create kernel
last_partition : onenand0,0 env_partition : onenand0=onenand --- getting current partition: onenand0=onenand --- find_dev_and_part --- id = onenand0=onenand no partition number specified 448 do_ubi -1512 do_ubi -3Creating dynamic volume kernel of size 5806080 onenand_erase: start = 0x00240000, len = 131072 onenand_erase: start = 0x00260000, len = 131072 onenand_erase: start = 0x00280000, len = 131072 onenand_erase: start = 0x002a0000, len = 131072 onenand_erase: start = 0x002c0000, len = 131072 onenand_erase: start = 0x002e0000, len = 131072 onenand_erase: start = 0x00300000, len = 131072 onenand_erase: start = 0x00320000, len = 131072 onenand_erase: start = 0x00340000, len = 131072 onenand_erase: start = 0x00360000, len = 131072 onenand_erase: start = 0x00380000, len = 131072 onenand_erase: start = 0x003a0000, len = 131072 onenand_erase: start = 0x003c0000, len = 131072 onenand_erase: start = 0x003e0000, len = 131072 onenand_erase: start = 0x00400000, len = 131072 onenand_erase: start = 0x00420000, len = 131072 onenand_erase: start = 0x00440000, len = 131072 onenand_erase: start = 0x00460000, len = 131072 onenand_erase: start = 0x00480000, len = 131072 onenand_erase: start = 0x004a0000, len = 131072 onenand_erase: start = 0x004c0000, len = 131072 onenand_erase: start = 0x004e0000, len = 131072 onenand_erase: start = 0x00500000, len = 131072 onenand_erase: start = 0x00520000, len = 131072 onenand_erase: start = 0x00540000, len = 131072 onenand_erase: start = 0x00560000, len = 131072 onenand_erase: start = 0x00580000, len = 131072 onenand_erase: start = 0x005a0000, len = 131072 onenand_erase: start = 0x005c0000, len = 131072 onenand_erase: start = 0x005e0000, len = 131072 onenand_erase: start = 0x00620000, len = 131072 onenand_erase: start = 0x00660000, len = 131072 onenand_erase: start = 0x00680000, len = 131072 onenand_erase: start = 0x006a0000, len = 131072 onenand_erase: start = 0x006c0000, len = 131072 onenand_erase: start = 0x006e0000, len = 131072 onenand_erase: start = 0x00700000, len = 131072 onenand_erase: start = 0x00720000, len = 131072 onenand_erase: start = 0x00740000, len = 131072 onenand_erase: start = 0x00760000, len = 131072 onenand_erase: start = 0x00780000, len = 131072 onenand_erase: start = 0x007a0000, len = 131072 onenand_erase: start = 0x007c0000, len = 131072 onenand_erase: start = 0x007e0000, len = 131072 onenand_erase: start = 0x00800000, len = 131072 onenand_erase: start = 0x00840000, len = 131072 onenand_erase: start = 0x008c0000, len = 131072 onenand_erase: start = 0x008e0000, len = 131072 onenand_erase: start = 0x00940000, len = 131072
# ubi info l
last_partition : onenand0,0 env_partition : onenand0=onenand --- getting current partition: onenand0=onenand --- find_dev_and_part --- id = onenand0=onenand no partition number specified 448 do_ubi -1512 do_ubi -3UBI: volume information dump: UBI: vol_id 0 UBI: reserved_pebs 45 UBI: alignment 1 UBI: data_pad 0 UBI: vol_type 3 UBI: name_len 6 UBI: usable_leb_size 129024 UBI: used_ebs 45 UBI: used_bytes %ld UBI: last_eb_bytes 129024 UBI: corrupted 0 UBI: upd_marker 0 UBI: name kernel
UBI: volume information dump: UBI: vol_id 2147479551 UBI: reserved_pebs 2 UBI: alignment 1 UBI: data_pad 0 UBI: vol_type 3 UBI: name_len 13 UBI: usable_leb_size 129024 UBI: used_ebs 2 UBI: used_bytes %ld UBI: last_eb_bytes 2 UBI: corrupted 0 UBI: upd_marker 0 UBI: name layout volume
d)ubi write 0x62000000 zImage 0x490000
after reset the target
a) ubi part kernel command fails with below error UBI error: ubi_io_read: error -5 while reading 64 bytes from PEB 50:0, read %zd
# ubi part kernel
last_partition : onenand0,0 env_partition : onenand0,0 448 do_ubi -1454 do_ubi -2466 do_ubi -5--- find_dev_and_part --- id = kernel --- find_dev_and_part --- id = kernel Creating 1 MTD partitions on "onenand0": 0x%lx-0x%lx : "" UBI: attaching mtd1 to ubi0 ubi_attach_mtd_dev UBI: min_io_size 2048 UBI: hdrs_min_io_size 512 UBI: ec_hdr_alsize 512 UBI: vid_hdr_alsize 512 UBI: vid_hdr_offset 512 UBI: vid_hdr_aloffset 512 UBI: vid_hdr_shift 0 UBI: leb_start 2048 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 129024 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 512 (aligned 512) UBI: data offset: 2048 $$$$$$$$$$$$$abcd 0x20000,0x67821140e1attach_by_scanning-1 onenand_wait: controller error = 0x0400 onenand_wait: controller error = 0x0400 onenand_wait: controller error = 0x0400 onenand_wait: controller error = 0x0400 UBI error: ubi_io_read: error -5 while reading 64 bytes from PEB 50:0, read %zd bytes attach_by_scanning-2 2UBI error: ubi_init: cannot attach mtd1 UBI error: ubi_init: UBI error: cannot initialize UBI, error -5 UBI init error -5 LEONID #
naveen yadav
