[U-Boot] [PATCH] bootz: fix silent console
fixup was lost during split between command code and logic.
Signed-off-by: Markus Niebel Markus.Niebel@tq-group.com --- common/bootm.c | 2 +- common/cmd_bootm.c | 6 ++++++ include/bootm.h | 2 ++ 3 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/common/bootm.c b/common/bootm.c index 6b3ea8c..94b9503 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -467,7 +467,7 @@ ulong bootm_disable_interrupts(void) #define CONSOLE_ARG "console=" #define CONSOLE_ARG_LEN (sizeof(CONSOLE_ARG) - 1)
-static void fixup_silent_linux(void) +void fixup_silent_linux(void) { char *buf; const char *env_val; diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 6723360..d3e410a 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -596,6 +596,12 @@ int do_bootz(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) * disable interrupts ourselves */ bootm_disable_interrupts(); +#if defined(CONFIG_SILENT_CONSOLE) && !defined(CONFIG_SILENT_U_BOOT_ONLY) + /* + * same goes for fixup_silent_linux + */ + fixup_silent_linux(); +#endif
images.os.os = IH_OS_LINUX; ret = do_bootm_states(cmdtp, flag, argc, argv, diff --git a/include/bootm.h b/include/bootm.h index b3d1a62..8e094b3 100644 --- a/include/bootm.h +++ b/include/bootm.h @@ -50,6 +50,8 @@ ulong bootm_disable_interrupts(void);
/* This is a special function used by booti/bootz */ int bootm_find_ramdisk_fdt(int flag, int argc, char * const argv[]); +/* This function is used also used by bootz */ +void fixup_silent_linux(void);
int do_bootm_states(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], int states, bootm_headers_t *images, int boot_progress);
Hi Markus,
Quite a bit of effort was expended trying to join this code back together rather than having two separate code paths for bootm and bootz.
Since this is cmdline-related, I suggest something like this:
- Enable BOOTM_STATE_OS_CMDLINE for all archs in do_bootm() - Call fixup_silent_linux() in do_bootm_states() when processing BOOTM_STATE_OS_CMDLINE - Add BOOTM_STATE_OS_CMDLINE to the do_bootm_states() call in do_bootz()
Or similar...that way we keep bootm and bootz in sync. The separate call to bootm_disable_interrupts() is unfortunate but is a problem for another day.
Hello Simon,
Am 20.11.2014 um 20:15 schrieb Simon Glass:
Hi Markus,
I Understand
I read through the code to find out, what the implications of your suggestions were. Since I'm not very familiar with this piece of code, please correct me, If i'm wrong:
- rename the arch specific do_bootm_linux to arch_bootm_linux - implement a generic version of do_bootm_linux inside bootm_os.c - call arch_bootm_linux from generic do_bootm_linux - move the call to fixup_silent_linux to new do_bootm_linux for the BOOTM_STATE_OS_CMDLINE case - mask BOOTM_STATE_OS_CMDLINE before calling arch_bootm_linux for all but MIPS and PPC
because this seems a bit intrusive I'm not sure. But if this is the wy to go, I will prepare a patch.
Regards, Markus
Hi Markus,
On 25 November 2014 at 01:31, Markus Niebel list-09_u-boot@tqsc.de wrote:
Hello Simon,
Hi Markus,
I Understand
Yes that sounds complicated. But copying code in multiple places is how the image/bootm support got so ugly, and it was a big effort to fix it up. So I'd really like to avoid copying code.
But it should be a lot easier than that.
In do_boot() there is:
return do_bootm_states(cmdtp, flag, argc, argv, BOOTM_STATE_START | BOOTM_STATE_FINDOS | BOOTM_STATE_FINDOTHER | BOOTM_STATE_LOADOS | #if defined(CONFIG_PPC) || defined(CONFIG_MIPS) BOOTM_STATE_OS_CMDLINE | #endif BOOTM_STATE_OS_PREP | BOOTM_STATE_OS_FAKE_GO | BOOTM_STATE_OS_GO, &images, 1); }
You should be able to remove the #ifdef.
Then in do_bootm_states() there is:
/* Load the OS */ if (!ret && (states & BOOTM_STATE_LOADOS)) { ... #if defined(CONFIG_SILENT_CONSOLE) && !defined(CONFIG_SILENT_U_BOOT_ONLY) if (images->os.os == IH_OS_LINUX) fixup_silent_linux(); #endif }
And later:
if (!ret && (states & BOOTM_STATE_OS_CMDLINE)) ret = boot_fn(BOOTM_STATE_OS_CMDLINE, argc, argv, images);
You should be able to move the '#if defined' code to inside this if () - so that fixup_silent_linux() happens in the CMDLINE stage instead of the LOADOS stage.
Then in do_bootz(), add BOOTM_STATE_OS_CMDLINE to the call to do_bootm_states().
Then bootm and bootz will still go along exactly the same code path.
The tricky bit is that of course this does affect each arch - you need to make sure that each do_bootm_linux() function in arch/xxx/lib/bootm.c will handle BOOTM_STATE_OS_CMDLINE (and return 0, not -1). At a glance I can see that ARM returns -1 - it will need to return 0.
Also each function in boot_os[] needs to do the same. I looked at most of them and they check for BOOTM_STATE_OS_GO and return 0 for anything else, so should be OK. Maybe do_bootm_standalone() will need to do so too.
Regards, Markus
Markus Niebel
