[U-Boot] [PATCH 0/2] Two bug fixes of Denali NAND controller driver
Masahiro Yamada (2): mtd: denali: fix NAND_CMD_PARAM command mtd: denali: support NAND_CMD_RNDOUT command
drivers/mtd/nand/denali.c | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
NAND_CMD_PARAM (0xEC) command is not working on the Denali NAND controller driver.
Unlike NAND_CMD_READID (0x90), when the NAND_CMD_PARAM command is followed by an address cycle, the target device goes busy. (R/B# is deasserted) Wait until the parameter data are ready.
In addition, unnecessary clear_interrupts() should be removed.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
drivers/mtd/nand/denali.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/denali.c b/drivers/mtd/nand/denali.c index ba3de1a..d9abc7e 100644 --- a/drivers/mtd/nand/denali.c +++ b/drivers/mtd/nand/denali.c @@ -1059,9 +1059,8 @@ static void denali_cmdfunc(struct mtd_info *mtd, unsigned int cmd, int col, addr = MODE_11 | BANK(denali->flash_bank); index_addr(denali, addr | 0, cmd); break; - case NAND_CMD_PARAM: - clear_interrupts(denali); case NAND_CMD_READID: + case NAND_CMD_PARAM: reset_buf(denali); /* sometimes ManufactureId read from register is not right * e.g. some of Micron MT29F32G08QAA MLC NAND chips @@ -1070,6 +1069,8 @@ static void denali_cmdfunc(struct mtd_info *mtd, unsigned int cmd, int col, addr = MODE_11 | BANK(denali->flash_bank); index_addr(denali, addr | 0, cmd); index_addr(denali, addr | 1, col & 0xFF); + if (cmd == NAND_CMD_PARAM) + udelay(50); break; case NAND_CMD_READ0: case NAND_CMD_SEQIN:
case NAND_CMD_READID:clear_interrupts(denali);
- case NAND_CMD_PARAM: reset_buf(denali); /* sometimes ManufactureId read from register is not right
- e.g. some of Micron MT29F32G08QAA MLC NAND chips
break; case NAND_CMD_READ0: case NAND_CMD_SEQIN:udelay(50);
Acked-by: Chin Liang See clsee@altera.com
The function nand_flash_detect_ext_param_page() requires NAND_CMD_RNDOUT command supported. It is necessary to detect some types of ONFi-compliant devices. Without it, the error message "unsupported command received 0x5" is shown.
Let's support this command on the Denali NAND controller driver.
drivers/mtd/nand/denali.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/mtd/nand/denali.c b/drivers/mtd/nand/denali.c index d9abc7e..308b784 100644 --- a/drivers/mtd/nand/denali.c +++ b/drivers/mtd/nand/denali.c @@ -1072,6 +1072,13 @@ static void denali_cmdfunc(struct mtd_info *mtd, unsigned int cmd, int col, if (cmd == NAND_CMD_PARAM) udelay(50); break; + case NAND_CMD_RNDOUT: + addr = MODE_11 | BANK(denali->flash_bank); + index_addr(denali, addr | 0, cmd); + index_addr(denali, addr | 1, col & 0xFF); + index_addr(denali, addr | 1, col >> 8); + index_addr(denali, addr | 0, NAND_CMD_RNDOUTSTART); + break; case NAND_CMD_READ0: case NAND_CMD_SEQIN: denali->page = page;
- case NAND_CMD_RNDOUT:
case NAND_CMD_READ0: case NAND_CMD_SEQIN: denali->page = page;break;
break;
This usage of RNDOUT is a regression for other drivers as well, such as fsl_ifc_nand... I really wish emulating a simple controller weren't the API used to talk to higher level drivers. :-(
-Scott
Chin Liang See
Masahiro Yamada
Scott Wood
