[PATCH v4 0/2] x86: Minor improvements mostly for image loading
This series provides a few improvements for loading of images. It also provides a way to show more detailed model information as well as an of-platdata fix noticed recently.
Note that this series depends on the GPIO series here:
http://patchwork.ozlabs.org/project/uboot/list/?series=226118
Changes in v4: - Rebase to x86/master (but will not build until GPIO series lands) - Update cover letter
Changes in v3: - Rebase to master - Rebase to master - Drop patches previously applied
Changes in v2: - Fix two missing asterisks in comments
Simon Glass (2): sysinfo: Allow showing model info from sysinfo x86: coral: Show memory config and SKU ID on startup
arch/x86/dts/chromebook_coral.dts | 11 ++ board/google/chromebook_coral/coral.c | 139 +++++++++++++++++- board/google/chromebook_coral/variant_gpio.h | 6 - common/board_info.c | 37 ++++- .../sysinfo/google,coral.txt | 37 +++++ include/sysinfo.h | 4 + 6 files changed, 212 insertions(+), 22 deletions(-) create mode 100644 doc/device-tree-bindings/sysinfo/google,coral.txt
Some boards may want to show the SKU ID or other information obtained at runtime. Allow this to come from sysinfo. The board can then provide a sysinfo driver to provide it.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
(no changes since v3)
common/board_info.c | 37 +++++++++++++++++++++++++++++-------- include/sysinfo.h | 4 ++++ 2 files changed, 33 insertions(+), 8 deletions(-)
diff --git a/common/board_info.c b/common/board_info.c index a6db087f960..20a2dea1f35 100644 --- a/common/board_info.c +++ b/common/board_info.c @@ -1,30 +1,51 @@ // SPDX-License-Identifier: GPL-2.0+
#include <common.h> +#include <dm.h> #include <init.h> +#include <sysinfo.h> #include <linux/libfdt.h> #include <linux/compiler.h>
+DECLARE_GLOBAL_DATA_PTR; + int __weak checkboard(void) { return 0; }
/* - * If the root node of the DTB has a "model" property, show it. + * Check sysinfo for board information. Failing that if the root node of the DTB + * has a "model" property, show it. + * * Then call checkboard(). */ int __weak show_board_info(void) { -#ifdef CONFIG_OF_CONTROL - DECLARE_GLOBAL_DATA_PTR; - const char *model; + if (IS_ENABLED(CONFIG_OF_CONTROL)) { + struct udevice *dev; + const char *model; + char str[80]; + int ret = -ENOSYS; + + if (IS_ENABLED(CONFIG_SYSINFO)) { + /* This might provide more detail */ + ret = uclass_first_device_err(UCLASS_SYSINFO, &dev); + if (!ret) + ret = sysinfo_get_str(dev, + SYSINFO_ID_BOARD_MODEL, + sizeof(str), str); + }
- model = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + /* Fail back to the main 'model' if available */ + if (ret) + model = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + else + model = str;
- if (model) - printf("Model: %s\n", model); -#endif + if (model) + printf("Model: %s\n", model); + }
return checkboard(); } diff --git a/include/sysinfo.h b/include/sysinfo.h index 743f3554659..f4ffb1a3503 100644 --- a/include/sysinfo.h +++ b/include/sysinfo.h @@ -35,9 +35,13 @@ enum sysinfo_id { SYSINFO_ID_NONE,
+ /* For SMBIOS tables */ SYSINFO_ID_SMBIOS_SYSTEM_VERSION, SYSINFO_ID_SMBIOS_BASEBOARD_VERSION,
+ /* For show_board_info() */ + SYSINFO_ID_BOARD_MODEL, + /* First value available for downstream/board used */ SYSINFO_ID_USER = 0x1000, };
Provide the model information through sysinfo so that it shows up on boot. For memconfig 4 pins are provided, for 16 combinations. For SKU ID there are two options:
- two pins provided in a ternary arrangement, for 9 combinations. - reading from the EC
Add a binding doc and drop the unused #defines as well.
Example:
U-Boot 2021.01-rc5
CPU: Intel(R) Celeron(R) CPU N3450 @ 1.10GHz DRAM: 3.9 GiB MMC: sdmmc@1b,0: 1, emmc@1c,0: 2 Video: 1024x768x32 @ b0000000 Model: Google Coral (memconfig 5, SKU 3)
This depends on the GPIO series:
http://patchwork.ozlabs.org/project/uboot/list/?series=228126
Acked-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v3: - Rebase to master - Drop patches previously applied
arch/x86/dts/chromebook_coral.dts | 11 ++ board/google/chromebook_coral/coral.c | 139 +++++++++++++++++- board/google/chromebook_coral/variant_gpio.h | 6 - .../sysinfo/google,coral.txt | 37 +++++ 4 files changed, 179 insertions(+), 14 deletions(-) create mode 100644 doc/device-tree-bindings/sysinfo/google,coral.txt
diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index 2ffe3b423c3..18bbafe5981 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -55,6 +55,17 @@ recovery-gpios = <&gpio_nw (-1) GPIO_ACTIVE_LOW>; write-protect-gpios = <&gpio_nw GPIO_75 GPIO_ACTIVE_HIGH>; phase-enforce-gpios = <&gpio_n GPIO_10 GPIO_ACTIVE_HIGH>; + memconfig-gpios = <&gpio_nw GPIO_101 GPIO_ACTIVE_HIGH + &gpio_nw GPIO_102 GPIO_ACTIVE_HIGH + &gpio_n GPIO_38 GPIO_ACTIVE_HIGH + &gpio_n GPIO_45 GPIO_ACTIVE_HIGH>; + + /* + * This is used for reef only: + * + * skuconfig-gpios = <&gpio_nw GPIO_16 GPIO_ACTIVE_HIGH + * &gpio_nw GPIO_17 GPIO_ACTIVE_HIGH>; + */ smbios { /* Type 1 table */ system { diff --git a/board/google/chromebook_coral/coral.c b/board/google/chromebook_coral/coral.c index f9fb3f163f0..77a6cca4497 100644 --- a/board/google/chromebook_coral/coral.c +++ b/board/google/chromebook_coral/coral.c @@ -3,9 +3,12 @@ * Copyright 2019 Google LLC */
+#define LOG_CATEGORY UCLASS_SYSINFO + #include <common.h> #include <bloblist.h> #include <command.h> +#include <cros_ec.h> #include <dm.h> #include <log.h> #include <sysinfo.h> @@ -15,6 +18,7 @@ #include <asm/intel_gnvs.h> #include <asm/intel_pinctrl.h> #include <dm/acpi.h> +#include <linux/delay.h> #include "variant_gpio.h"
struct cros_gpio_info { @@ -29,10 +33,125 @@ int arch_misc_init(void) return 0; }
-/* This function is needed if CONFIG_CMDLINE is not enabled */ -int board_run_command(const char *cmdline) +static int get_memconfig(struct udevice *dev) { - printf("No command line\n"); + struct gpio_desc gpios[4]; + int cfg; + int ret; + + ret = gpio_request_list_by_name(dev, "memconfig-gpios", gpios, + ARRAY_SIZE(gpios), + GPIOD_IS_IN | GPIOD_PULL_UP); + if (ret < 0) { + log_debug("Cannot get GPIO list '%s' (%d)\n", dev->name, ret); + return ret; + } + + /* Give the lines time to settle */ + udelay(10); + + ret = dm_gpio_get_values_as_int(gpios, ARRAY_SIZE(gpios)); + if (ret < 0) + return log_msg_ret("get", ret); + cfg = ret; + + ret = gpio_free_list(dev, gpios, ARRAY_SIZE(gpios)); + if (ret) + return log_msg_ret("free", ret); + + return cfg; +} + +/** + * get_skuconfig() - Get the SKU number either from pins or the EC + * + * Two options are supported: + * skuconfig-gpios - two pins in the device tree (tried first) + * EC - reading from the EC (backup) + * + * @dev: sysinfo device to use + * @return SKU ID, or -ve error if not found + */ +static int get_skuconfig(struct udevice *dev) +{ + struct gpio_desc gpios[2]; + int cfg; + int ret; + + ret = gpio_request_list_by_name(dev, "skuconfig-gpios", gpios, + ARRAY_SIZE(gpios), + GPIOD_IS_IN); + if (ret != ARRAY_SIZE(gpios)) { + struct udevice *cros_ec; + + log_debug("Cannot get GPIO list '%s' (%d)\n", dev->name, ret); + + /* Try the EC */ + ret = uclass_first_device_err(UCLASS_CROS_EC, &cros_ec); + if (ret < 0) { + log_err("Cannot find EC for SKU details\n"); + return log_msg_ret("sku", ret); + } + ret = cros_ec_get_sku_id(cros_ec); + if (ret < 0) { + log_err("Cannot read SKU details\n"); + return log_msg_ret("sku", ret); + } + + return ret; + } + + ret = dm_gpio_get_values_as_int_base3(gpios, ARRAY_SIZE(gpios)); + if (ret < 0) + return log_msg_ret("get", ret); + cfg = ret; + + ret = gpio_free_list(dev, gpios, ARRAY_SIZE(gpios)); + if (ret) + return log_msg_ret("free", ret); + + return cfg; +} + +static int coral_get_str(struct udevice *dev, int id, size_t size, char *val) +{ + int ret; + + if (IS_ENABLED(CONFIG_SPL_BUILD)) + return -ENOSYS; + + switch (id) { + case SYSINFO_ID_SMBIOS_SYSTEM_VERSION: + case SYSINFO_ID_SMBIOS_BASEBOARD_VERSION: { + ret = get_skuconfig(dev); + + if (ret < 0) + return ret; + if (size < 15) + return -ENOSPC; + sprintf(val, "rev%d", ret); + break; + } + case SYSINFO_ID_BOARD_MODEL: { + int mem_config, sku_config; + const char *model; + + ret = get_memconfig(dev); + if (ret < 0) + log_warning("Unable to read memconfig (err=%d)\n", ret); + mem_config = ret; + ret = get_skuconfig(dev); + if (ret < 0) + log_warning("Unable to read skuconfig (err=%d)\n", ret); + sku_config = ret; + model = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + snprintf(val, size, "%s (memconfig %d, SKU %d)", model, + mem_config, sku_config); + break; + } + default: + return -ENOENT; + }
return 0; } @@ -45,12 +164,15 @@ int chromeos_get_gpio(const struct udevice *dev, const char *prop, int ret;
ret = gpio_request_by_name((struct udevice *)dev, prop, 0, &desc, 0); - if (ret == -ENOTBLK) + if (ret == -ENOTBLK) { info->gpio_num = CROS_GPIO_VIRTUAL; - else if (ret) + log_debug("GPIO '%s' is virtual\n", prop); + } else if (ret) { return log_msg_ret("gpio", ret); - else + } else { info->gpio_num = desc.offset; + dm_gpio_free((struct udevice *)dev, &desc); + } info->linux_name = dev_read_string(desc.dev, "linux-name"); if (!info->linux_name) return log_msg_ret("linux-name", -ENOENT); @@ -81,11 +203,11 @@ static int chromeos_acpi_gpio_generate(const struct udevice *dev, ret = chromeos_get_gpio(dev, "write-protect-gpios", CROS_GPIO_WP, &info[1]); if (ret) - return log_msg_ret("rec", ret); + return log_msg_ret("wp", ret); ret = chromeos_get_gpio(dev, "phase-enforce-gpios", CROS_GPIO_PE, &info[2]); if (ret) - return log_msg_ret("rec", ret); + return log_msg_ret("phase", ret); acpigen_write_scope(ctx, "\"); acpigen_write_name(ctx, "OIPG"); acpigen_write_package(ctx, count); @@ -145,6 +267,7 @@ struct acpi_ops coral_acpi_ops = { };
struct sysinfo_ops coral_sysinfo_ops = { + .get_str = coral_get_str, };
#if !CONFIG_IS_ENABLED(OF_PLATDATA) diff --git a/board/google/chromebook_coral/variant_gpio.h b/board/google/chromebook_coral/variant_gpio.h index f516d88be5c..403e2419a71 100644 --- a/board/google/chromebook_coral/variant_gpio.h +++ b/board/google/chromebook_coral/variant_gpio.h @@ -34,12 +34,6 @@ /* Determine if board is in final shipping mode. */ #define GPIO_SHIP_MODE GPIO_10
-/* Memory SKU GPIOs. */ -#define MEM_CONFIG3 GPIO_45 -#define MEM_CONFIG2 GPIO_38 -#define MEM_CONFIG1 GPIO_102 -#define MEM_CONFIG0 GPIO_101 - /* DMIC_CONFIG_PIN: High for 1-DMIC and low for 4-DMIC's */ #define DMIC_CONFIG_PIN GPIO_17
diff --git a/doc/device-tree-bindings/sysinfo/google,coral.txt b/doc/device-tree-bindings/sysinfo/google,coral.txt new file mode 100644 index 00000000000..d8a1a79687e --- /dev/null +++ b/doc/device-tree-bindings/sysinfo/google,coral.txt @@ -0,0 +1,37 @@ +Google Coral sysinfo information +================================ + +This binding allows information about the board to be described. It includes +the SMBIOS binding as well. + +Required properties: + + - compatible: "google,coral" + - recovery-gpios: GPIO to use for recovery button (-1 if none) + - wite-protect-gpios: GPIO to use for write-protect screw + - phase-enforce-gpios: GPIO to indicate the board is in final ship mode + - memconfig-gpios: 4 GPIOs to use to read memory config (as base2 int) + +Optional properties: + - skuconfig-gpios: 2 GPIOs to use to read SKU ID. If not present, the + Chromium OS EC SKU_ID is used instead + +Example: + +board: board { + compatible = "google,coral"; + recovery-gpios = <&gpio_nw (-1) GPIO_ACTIVE_LOW>; + write-protect-gpios = <&gpio_nw GPIO_75 GPIO_ACTIVE_HIGH>; + phase-enforce-gpios = <&gpio_n GPIO_10 GPIO_ACTIVE_HIGH>; + memconfig-gpios = <&gpio_nw GPIO_101 GPIO_ACTIVE_HIGH + &gpio_nw GPIO_102 GPIO_ACTIVE_HIGH + &gpio_n GPIO_38 GPIO_ACTIVE_HIGH + &gpio_n GPIO_45 GPIO_ACTIVE_HIGH>; + + /* + * This is used for reef only: + * + * skuconfig-gpios = <&gpio_nw GPIO_16 GPIO_ACTIVE_HIGH + * &gpio_nw GPIO_17 GPIO_ACTIVE_HIGH>; + */ + };
Hi Simon,
Example:
U-Boot 2021.01-rc5
It looks this series is applied as patchwork returns nothing?
But the CI still fails https://source.denx.de/u-boot/custodians/u-boot-x86/-/jobs/235619
Changes in v4:
Regards, Bin
Hi Bin,
On Tue, 9 Mar 2021 at 15:34, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Example:
U-Boot 2021.01-rc5
Can you apply it to u-boot-x86/next perhaps? The GPIO series was applied to -next, not -master.
Hi Bin,
On Mon, 15 Mar 2021 at 18:30, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Example:
U-Boot 2021.01-rc5
I've sent a new version, v5, which should apply on the U-Boot -next branch. Are you keeping a -next for x86? If not I am happy to apply it via dm.
Hi Simon,
On Sun, Mar 21, 2021 at 11:51 AM Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Bin,
Hi Simon,
Example:
U-Boot 2021.01-rc5
No, I did not track u-boot/next in the x86 repo. Feel free to apply this series via dm.
Regards, Bin
Bin Meng
