[PATCH 2/2] mach-snapdragon/mach-ipq40xx: fix, merge and refactoring
ipq40xx/snapdragon: Merge two, more than 90% overlapping Qualcomm's Snapdrgon based arches, into one: "mach-snapdragon".
Signed-off-by: Andrey VOLKOV andrey@volkov.fr --- arch/arm/Kconfig | 19 --- arch/arm/Makefile | 1 arch/arm/mach-ipq40xx/Kconfig | 15 -- arch/arm/mach-ipq40xx/Makefile | 9 - arch/arm/mach-ipq40xx/clock-ipq4019.c | 88 ------------- arch/arm/mach-ipq40xx/include/mach/gpio.h | 10 -- arch/arm/mach-ipq40xx/pinctrl-ipq4019.c | 54 -------- arch/arm/mach-ipq40xx/pinctrl-snapdragon.c | 166 ------------------------- arch/arm/mach-ipq40xx/pinctrl-snapdragon.h | 30 ----- arch/arm/mach-snapdragon/Kconfig | 47 ++++++- arch/arm/mach-snapdragon/Makefile | 5 + arch/arm/mach-snapdragon/clock-ipq4019.c | 88 +++++++++++++ arch/arm/mach-snapdragon/pinctrl-ipq4019.c | 54 ++++++++ arch/arm/mach-snapdragon/pinctrl-snapdragon.c | 36 +++-- arch/arm/mach-snapdragon/pinctrl-snapdragon.h | 1 drivers/phy/qcom/Kconfig | 2 drivers/reset/Kconfig | 2 drivers/reset/reset-qcom.c | 2 drivers/smem/Kconfig | 2 drivers/spi/Kconfig | 2 20 files changed, 220 insertions(+), 413 deletions(-) delete mode 100644 arch/arm/mach-ipq40xx/Kconfig delete mode 100644 arch/arm/mach-ipq40xx/Makefile delete mode 100644 arch/arm/mach-ipq40xx/clock-ipq4019.c delete mode 100644 arch/arm/mach-ipq40xx/include/mach/gpio.h delete mode 100644 arch/arm/mach-ipq40xx/pinctrl-ipq4019.c delete mode 100644 arch/arm/mach-ipq40xx/pinctrl-snapdragon.c delete mode 100644 arch/arm/mach-ipq40xx/pinctrl-snapdragon.h create mode 100644 arch/arm/mach-snapdragon/clock-ipq4019.c create mode 100644 arch/arm/mach-snapdragon/pinctrl-ipq4019.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index a25b7f6d99..a495dfe813 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -803,21 +803,6 @@ config ARCH_INTEGRATOR select PL01X_SERIAL imply CMD_DM -config ARCH_IPQ40XX - bool "Qualcomm IPQ40xx SoCs" - select CPU_V7A - select DM - select DM_GPIO - select DM_SERIAL - select DM_RESET - select GPIO_EXTRA_HEADER - select MSM_SMEM - select PINCTRL - select CLK - select SMEM - select OF_CONTROL - imply CMD_DM - config ARCH_KEYSTONE bool "TI Keystone" select CMD_POWEROFF @@ -1098,6 +1083,7 @@ config ARCH_RMOBILE config ARCH_SNAPDRAGON bool "Qualcomm Snapdragon SoCs" + select CLK select DM select DM_GPIO select DM_SERIAL @@ -1105,6 +1091,7 @@ config ARCH_SNAPDRAGON select MSM_SMEM select OF_CONTROL select OF_SEPARATE + select PINCTRL select SMEM select SPMI imply CMD_DM @@ -2225,8 +2212,6 @@ source "arch/arm/mach-highbank/Kconfig" source "arch/arm/mach-integrator/Kconfig" -source "arch/arm/mach-ipq40xx/Kconfig" - source "arch/arm/mach-k3/Kconfig" source "arch/arm/mach-keystone/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index ac602aed9c..ceee6a02d0 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -61,7 +61,6 @@ machine-$(CONFIG_ARCH_DAVINCI) += davinci machine-$(CONFIG_ARCH_EXYNOS) += exynos machine-$(CONFIG_ARCH_GXP) += hpe machine-$(CONFIG_ARCH_HIGHBANK) += highbank -machine-$(CONFIG_ARCH_IPQ40XX) += ipq40xx machine-$(CONFIG_ARCH_K3) += k3 machine-$(CONFIG_ARCH_KEYSTONE) += keystone machine-$(CONFIG_ARCH_KIRKWOOD) += kirkwood diff --git a/arch/arm/mach-ipq40xx/Kconfig b/arch/arm/mach-ipq40xx/Kconfig deleted file mode 100644 index 4eef80e935..0000000000 --- a/arch/arm/mach-ipq40xx/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if ARCH_IPQ40XX - -config SYS_SOC - default "ipq40xx" - -config SYS_MALLOC_F_LEN - default 0x2000 - -config SYS_TEXT_BASE - default 0x87300000 - -config NR_DRAM_BANKS - default 1 - -endif diff --git a/arch/arm/mach-ipq40xx/Makefile b/arch/arm/mach-ipq40xx/Makefile deleted file mode 100644 index 08a65b8854..0000000000 --- a/arch/arm/mach-ipq40xx/Makefile +++ /dev/null @@ -1,9 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (c) 2019 Sartura Ltd. -# -# Author: Robert Marko robert.marko@sartura.hr - -obj-y += clock-ipq4019.o -obj-y += pinctrl-snapdragon.o -obj-y += pinctrl-ipq4019.o diff --git a/arch/arm/mach-ipq40xx/clock-ipq4019.c b/arch/arm/mach-ipq40xx/clock-ipq4019.c deleted file mode 100644 index c1d5c4ecdd..0000000000 --- a/arch/arm/mach-ipq40xx/clock-ipq4019.c +++ /dev/null @@ -1,88 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Clock drivers for Qualcomm IPQ40xx - * - * Copyright (c) 2020 Sartura Ltd. - * - * Author: Robert Marko robert.marko@sartura.hr - * - */ - -#include <clk-uclass.h> -#include <common.h> -#include <dm.h> -#include <errno.h> - -#include <dt-bindings/clock/qcom,ipq4019-gcc.h> - -struct msm_clk_priv { - phys_addr_t base; -}; - -ulong msm_set_rate(struct clk *clk, ulong rate) -{ - switch (clk->id) { - case GCC_BLSP1_UART1_APPS_CLK: /*UART1*/ - /* This clock is already initialized by SBL1 */ - return 0; - default: - return -EINVAL; - } -} - -static int msm_clk_probe(struct udevice *dev) -{ - struct msm_clk_priv *priv = dev_get_priv(dev); - - priv->base = dev_read_addr(dev); - if (priv->base == FDT_ADDR_T_NONE) - return -EINVAL; - - return 0; -} - -static ulong msm_clk_set_rate(struct clk *clk, ulong rate) -{ - return msm_set_rate(clk, rate); -} - -static int msm_enable(struct clk *clk) -{ - switch (clk->id) { - case GCC_BLSP1_QUP1_SPI_APPS_CLK: /*SPI1*/ - /* This clock is already initialized by SBL1 */ - return 0; - case GCC_PRNG_AHB_CLK: /*PRNG*/ - /* This clock is already initialized by SBL1 */ - return 0; - case GCC_USB3_MASTER_CLK: - case GCC_USB3_SLEEP_CLK: - case GCC_USB3_MOCK_UTMI_CLK: - case GCC_USB2_MASTER_CLK: - case GCC_USB2_SLEEP_CLK: - case GCC_USB2_MOCK_UTMI_CLK: - /* These clocks is already initialized by SBL1 */ - return 0; - default: - return -EINVAL; - } -} - -static struct clk_ops msm_clk_ops = { - .set_rate = msm_clk_set_rate, - .enable = msm_enable, -}; - -static const struct udevice_id msm_clk_ids[] = { - { .compatible = "qcom,gcc-ipq4019" }, - { } -}; - -U_BOOT_DRIVER(clk_msm) = { - .name = "clk_msm", - .id = UCLASS_CLK, - .of_match = msm_clk_ids, - .ops = &msm_clk_ops, - .priv_auto = sizeof(struct msm_clk_priv), - .probe = msm_clk_probe, -}; diff --git a/arch/arm/mach-ipq40xx/include/mach/gpio.h b/arch/arm/mach-ipq40xx/include/mach/gpio.h deleted file mode 100644 index a45747c0fe..0000000000 --- a/arch/arm/mach-ipq40xx/include/mach/gpio.h +++ /dev/null @@ -1,10 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Empty gpio.h - * - * This file must stay as arch/arm/include/asm/gpio.h requires it. - * - * Copyright (c) 2019 Sartura Ltd. - * - * Author: Robert Marko robert.marko@sartura.hr - */ diff --git a/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c b/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c deleted file mode 100644 index 3e365f8cc8..0000000000 --- a/arch/arm/mach-ipq40xx/pinctrl-ipq4019.c +++ /dev/null @@ -1,54 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Qualcomm IPQ40xx pinctrl - * - * Copyright (c) 2019 Sartura Ltd. - * - * Author: Robert Marko robert.marko@sartura.hr - */ - -#include "pinctrl-snapdragon.h" -#include <common.h> - -#define MAX_PIN_NAME_LEN 32 -static char pin_name[MAX_PIN_NAME_LEN]; - -static const struct pinctrl_function msm_pinctrl_functions[] = { - {"gpio", 0}, - {"blsp_uart0_0", 1}, /* Only for GPIO:16,17 */ - {"blsp_uart0_1", 2}, /* Only for GPIO:60,61 */ - {"blsp_uart1", 1}, - {"blsp_spi0_0", 1}, /* Only for GPIO:12,13,14,15 */ - {"blsp_spi0_1", 2}, /* Only for GPIO:54,55,56,57 */ - {"blsp_spi1", 2}, - {"mdio_0", 1}, /* Only for GPIO6 */ - {"mdio_1", 2}, /* Only for GPIO53 */ - {"mdc_0", 1}, /* Only for GPIO7 */ - {"mdc_1", 2}, /* Only for GPIO52 */ -}; - -static const char *ipq4019_get_function_name(struct udevice *dev, - unsigned int selector) -{ - return msm_pinctrl_functions[selector].name; -} - -static const char *ipq4019_get_pin_name(struct udevice *dev, - unsigned int selector) -{ - snprintf(pin_name, MAX_PIN_NAME_LEN, "GPIO_%u", selector); - return pin_name; -} - -static unsigned int ipq4019_get_function_mux(unsigned int selector) -{ - return msm_pinctrl_functions[selector].val; -} - -struct msm_pinctrl_data ipq4019_data = { - .pin_count = 100, - .functions_count = ARRAY_SIZE(msm_pinctrl_functions), - .get_function_name = ipq4019_get_function_name, - .get_function_mux = ipq4019_get_function_mux, - .get_pin_name = ipq4019_get_pin_name, -}; diff --git a/arch/arm/mach-ipq40xx/pinctrl-snapdragon.c b/arch/arm/mach-ipq40xx/pinctrl-snapdragon.c deleted file mode 100644 index 036fec93d7..0000000000 --- a/arch/arm/mach-ipq40xx/pinctrl-snapdragon.c +++ /dev/null @@ -1,166 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * TLMM driver for Qualcomm IPQ40xx - * - * (C) Copyright 2018 Ramon Fried ramon.fried@gmail.com - * - * Copyright (c) 2020 Sartura Ltd. - * - * Author: Robert Marko robert.marko@sartura.hr - * - */ - -#include <common.h> -#include <dm.h> -#include <errno.h> -#include <asm/io.h> -#include <dm/device_compat.h> -#include <dm/lists.h> -#include <dm/pinctrl.h> -#include <linux/bitops.h> -#include "pinctrl-snapdragon.h" - -struct msm_pinctrl_priv { - phys_addr_t base; - struct msm_pinctrl_data *data; -}; - -#define GPIO_CONFIG_OFFSET(x) ((x) * 0x1000) -#define TLMM_GPIO_PULL_MASK GENMASK(1, 0) -#define TLMM_FUNC_SEL_MASK GENMASK(5, 2) -#define TLMM_DRV_STRENGTH_MASK GENMASK(8, 6) -#define TLMM_GPIO_DISABLE BIT(9) - -static const struct pinconf_param msm_conf_params[] = { - { "drive-strength", PIN_CONFIG_DRIVE_STRENGTH, 2 }, - { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, - { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 2 }, -}; - -static int msm_get_functions_count(struct udevice *dev) -{ - struct msm_pinctrl_priv *priv = dev_get_priv(dev); - - return priv->data->functions_count; -} - -static int msm_get_pins_count(struct udevice *dev) -{ - struct msm_pinctrl_priv *priv = dev_get_priv(dev); - - return priv->data->pin_count; -} - -static const char *msm_get_function_name(struct udevice *dev, - unsigned int selector) -{ - struct msm_pinctrl_priv *priv = dev_get_priv(dev); - - return priv->data->get_function_name(dev, selector); -} - -static int msm_pinctrl_probe(struct udevice *dev) -{ - struct msm_pinctrl_priv *priv = dev_get_priv(dev); - - priv->base = devfdt_get_addr(dev); - priv->data = (struct msm_pinctrl_data *)dev->driver_data; - - return priv->base == FDT_ADDR_T_NONE ? -EINVAL : 0; -} - -static const char *msm_get_pin_name(struct udevice *dev, unsigned int selector) -{ - struct msm_pinctrl_priv *priv = dev_get_priv(dev); - - return priv->data->get_pin_name(dev, selector); -} - -static int msm_pinmux_set(struct udevice *dev, unsigned int pin_selector, - unsigned int func_selector) -{ - struct msm_pinctrl_priv *priv = dev_get_priv(dev); - - clrsetbits_le32(priv->base + GPIO_CONFIG_OFFSET(pin_selector), - TLMM_FUNC_SEL_MASK | TLMM_GPIO_DISABLE, - priv->data->get_function_mux(func_selector) << 2); - return 0; -} - -static int msm_pinconf_set(struct udevice *dev, unsigned int pin_selector, - unsigned int param, unsigned int argument) -{ - struct msm_pinctrl_priv *priv = dev_get_priv(dev); - - switch (param) { - case PIN_CONFIG_DRIVE_STRENGTH: - clrsetbits_le32(priv->base + GPIO_CONFIG_OFFSET(pin_selector), - TLMM_DRV_STRENGTH_MASK, argument << 6); - break; - case PIN_CONFIG_BIAS_DISABLE: - clrbits_le32(priv->base + GPIO_CONFIG_OFFSET(pin_selector), - TLMM_GPIO_PULL_MASK); - break; - case PIN_CONFIG_BIAS_PULL_UP: - clrsetbits_le32(priv->base + GPIO_CONFIG_OFFSET(pin_selector), - TLMM_GPIO_PULL_MASK, argument); - break; - default: - return 0; - } - - return 0; -} - -static int msm_pinctrl_bind(struct udevice *dev) -{ - ofnode node = dev_ofnode(dev); - const char *name; - int ret; - - ofnode_get_property(node, "gpio-controller", &ret); - if (ret < 0) - return 0; - - /* Get the name of gpio node */ - name = ofnode_get_name(node); - if (!name) - return -EINVAL; - - /* Bind gpio node */ - ret = device_bind_driver_to_node(dev, "gpio_msm", - name, node, NULL); - if (ret) - return ret; - - dev_dbg(dev, "bind %s\n", name); - - return 0; -} - -static struct pinctrl_ops msm_pinctrl_ops = { - .get_pins_count = msm_get_pins_count, - .get_pin_name = msm_get_pin_name, - .set_state = pinctrl_generic_set_state, - .pinmux_set = msm_pinmux_set, - .pinconf_num_params = ARRAY_SIZE(msm_conf_params), - .pinconf_params = msm_conf_params, - .pinconf_set = msm_pinconf_set, - .get_functions_count = msm_get_functions_count, - .get_function_name = msm_get_function_name, -}; - -static const struct udevice_id msm_pinctrl_ids[] = { - { .compatible = "qcom,ipq4019-pinctrl", .data = (ulong)&ipq4019_data }, - { } -}; - -U_BOOT_DRIVER(pinctrl_snapdraon) = { - .name = "pinctrl_msm", - .id = UCLASS_PINCTRL, - .of_match = msm_pinctrl_ids, - .priv_auto = sizeof(struct msm_pinctrl_priv), - .ops = &msm_pinctrl_ops, - .probe = msm_pinctrl_probe, - .bind = msm_pinctrl_bind, -}; diff --git a/arch/arm/mach-ipq40xx/pinctrl-snapdragon.h b/arch/arm/mach-ipq40xx/pinctrl-snapdragon.h deleted file mode 100644 index 2341a71349..0000000000 --- a/arch/arm/mach-ipq40xx/pinctrl-snapdragon.h +++ /dev/null @@ -1,30 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Qualcomm Pin control - * - * (C) Copyright 2018 Ramon Fried ramon.fried@gmail.com - * - */ -#ifndef _PINCTRL_SNAPDRAGON_H -#define _PINCTRL_SNAPDRAGON_H - -#include <common.h> - -struct msm_pinctrl_data { - int pin_count; - int functions_count; - const char *(*get_function_name)(struct udevice *dev, - unsigned int selector); - unsigned int (*get_function_mux)(unsigned int selector); - const char *(*get_pin_name)(struct udevice *dev, - unsigned int selector); -}; - -struct pinctrl_function { - const char *name; - int val; -}; - -extern struct msm_pinctrl_data ipq4019_data; - -#endif diff --git a/arch/arm/mach-snapdragon/Kconfig b/arch/arm/mach-snapdragon/Kconfig index 83dd2c07a1..6600120248 100644 --- a/arch/arm/mach-snapdragon/Kconfig +++ b/arch/arm/mach-snapdragon/Kconfig @@ -9,28 +9,61 @@ config SYS_MALLOC_F_LEN config SPL_SYS_MALLOC_F_LEN default 0x2000 -config APQ8016 +config COMMON_SNAPDRAGON + bool + default n + +config SNAPDRAGON_ARMV8 bool select ARM64 + select COMMON_SNAPDRAGON + default n + +config SNAPDRAGON_ARMV7A + bool + select CPU_V7A + default n + +config APQ8016 + bool + select SNAPDRAGON_ARMV8 default n config APQ8096 bool - select ARM64 + select SNAPDRAGON_ARMV8 default n config SDM845 bool - select ARM64 + select SNAPDRAGON_ARMV8 select LINUX_KERNEL_IMAGE_HEADER default n config QCS40X bool - select ARM64 + select SNAPDRAGON_ARMV8 select LINUX_KERNEL_IMAGE_HEADER default n +config IPQ40XX + bool + select SNAPDRAGON_ARMV7A + select DM_RESET + default n + +config SYS_LOAD_ADDR + default 0x80000000 if (IPQ40XX || SDM845 || QCS40X) + default 0x80080000 if (APQ8096 || APQ8016) + +config SYS_TEXT_BASE + default 0x8f600000 if APQ8016 + default 0x87300000 if IPQ40XX + +config NR_DRAM_BANKS + default 1 if (IPQ40XX || APQ8016) + default 2 if APQ8096 + config LNX_KRNL_IMG_TEXT_OFFSET_BASE default 0x80000000 @@ -98,6 +131,12 @@ config TARGET_QCS404EVB - 1GiB RAM - 8GiB eMMC, uSD slot +config TARGET_IPQ4019 + bool "Generic IPQ4019 based board" + select IPQ40XX + help + Support for the generic Qualcomm IPQ4019 based board + endchoice source "board/qualcomm/dragonboard410c/Kconfig" diff --git a/arch/arm/mach-snapdragon/Makefile b/arch/arm/mach-snapdragon/Makefile index 00997196ab..89e5a49780 100644 --- a/arch/arm/mach-snapdragon/Makefile +++ b/arch/arm/mach-snapdragon/Makefile @@ -2,7 +2,7 @@ # # (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com -obj-y += clock-snapdragon.o +obj-$(CONFIG_COMMON_SNAPDRAGON) += clock-snapdragon.o obj-y += pinctrl-snapdragon.o obj-$(CONFIG_SDM845) += clock-sdm845.o @@ -22,3 +22,6 @@ obj-$(CONFIG_APQ8016) += misc.o dram.o obj-$(CONFIG_QCS40X) += clock-qcs404.o obj-$(CONFIG_QCS40X) += sysmap-qcs404.o obj-$(CONFIG_QCS40X) += pinctrl-qcs404.o + +obj-$(CONFIG_IPQ40XX) += clock-ipq4019.o +obj-$(CONFIG_IPQ40XX) += pinctrl-ipq4019.o diff --git a/arch/arm/mach-snapdragon/clock-ipq4019.c b/arch/arm/mach-snapdragon/clock-ipq4019.c new file mode 100644 index 0000000000..c1d5c4ecdd --- /dev/null +++ b/arch/arm/mach-snapdragon/clock-ipq4019.c @@ -0,0 +1,88 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Clock drivers for Qualcomm IPQ40xx + * + * Copyright (c) 2020 Sartura Ltd. + * + * Author: Robert Marko robert.marko@sartura.hr + * + */ + +#include <clk-uclass.h> +#include <common.h> +#include <dm.h> +#include <errno.h> + +#include <dt-bindings/clock/qcom,ipq4019-gcc.h> + +struct msm_clk_priv { + phys_addr_t base; +}; + +ulong msm_set_rate(struct clk *clk, ulong rate) +{ + switch (clk->id) { + case GCC_BLSP1_UART1_APPS_CLK: /*UART1*/ + /* This clock is already initialized by SBL1 */ + return 0; + default: + return -EINVAL; + } +} + +static int msm_clk_probe(struct udevice *dev) +{ + struct msm_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) + return -EINVAL; + + return 0; +} + +static ulong msm_clk_set_rate(struct clk *clk, ulong rate) +{ + return msm_set_rate(clk, rate); +} + +static int msm_enable(struct clk *clk) +{ + switch (clk->id) { + case GCC_BLSP1_QUP1_SPI_APPS_CLK: /*SPI1*/ + /* This clock is already initialized by SBL1 */ + return 0; + case GCC_PRNG_AHB_CLK: /*PRNG*/ + /* This clock is already initialized by SBL1 */ + return 0; + case GCC_USB3_MASTER_CLK: + case GCC_USB3_SLEEP_CLK: + case GCC_USB3_MOCK_UTMI_CLK: + case GCC_USB2_MASTER_CLK: + case GCC_USB2_SLEEP_CLK: + case GCC_USB2_MOCK_UTMI_CLK: + /* These clocks is already initialized by SBL1 */ + return 0; + default: + return -EINVAL; + } +} + +static struct clk_ops msm_clk_ops = { + .set_rate = msm_clk_set_rate, + .enable = msm_enable, +}; + +static const struct udevice_id msm_clk_ids[] = { + { .compatible = "qcom,gcc-ipq4019" }, + { } +}; + +U_BOOT_DRIVER(clk_msm) = { + .name = "clk_msm", + .id = UCLASS_CLK, + .of_match = msm_clk_ids, + .ops = &msm_clk_ops, + .priv_auto = sizeof(struct msm_clk_priv), + .probe = msm_clk_probe, +}; diff --git a/arch/arm/mach-snapdragon/pinctrl-ipq4019.c b/arch/arm/mach-snapdragon/pinctrl-ipq4019.c new file mode 100644 index 0000000000..3e365f8cc8 --- /dev/null +++ b/arch/arm/mach-snapdragon/pinctrl-ipq4019.c @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Qualcomm IPQ40xx pinctrl + * + * Copyright (c) 2019 Sartura Ltd. + * + * Author: Robert Marko robert.marko@sartura.hr + */ + +#include "pinctrl-snapdragon.h" +#include <common.h> + +#define MAX_PIN_NAME_LEN 32 +static char pin_name[MAX_PIN_NAME_LEN]; + +static const struct pinctrl_function msm_pinctrl_functions[] = { + {"gpio", 0}, + {"blsp_uart0_0", 1}, /* Only for GPIO:16,17 */ + {"blsp_uart0_1", 2}, /* Only for GPIO:60,61 */ + {"blsp_uart1", 1}, + {"blsp_spi0_0", 1}, /* Only for GPIO:12,13,14,15 */ + {"blsp_spi0_1", 2}, /* Only for GPIO:54,55,56,57 */ + {"blsp_spi1", 2}, + {"mdio_0", 1}, /* Only for GPIO6 */ + {"mdio_1", 2}, /* Only for GPIO53 */ + {"mdc_0", 1}, /* Only for GPIO7 */ + {"mdc_1", 2}, /* Only for GPIO52 */ +}; + +static const char *ipq4019_get_function_name(struct udevice *dev, + unsigned int selector) +{ + return msm_pinctrl_functions[selector].name; +} + +static const char *ipq4019_get_pin_name(struct udevice *dev, + unsigned int selector) +{ + snprintf(pin_name, MAX_PIN_NAME_LEN, "GPIO_%u", selector); + return pin_name; +} + +static unsigned int ipq4019_get_function_mux(unsigned int selector) +{ + return msm_pinctrl_functions[selector].val; +} + +struct msm_pinctrl_data ipq4019_data = { + .pin_count = 100, + .functions_count = ARRAY_SIZE(msm_pinctrl_functions), + .get_function_name = ipq4019_get_function_name, + .get_function_mux = ipq4019_get_function_mux, + .get_pin_name = ipq4019_get_pin_name, +}; diff --git a/arch/arm/mach-snapdragon/pinctrl-snapdragon.c b/arch/arm/mach-snapdragon/pinctrl-snapdragon.c index 4ed4ab4d4c..fc72f6ad92 100644 --- a/arch/arm/mach-snapdragon/pinctrl-snapdragon.c +++ b/arch/arm/mach-snapdragon/pinctrl-snapdragon.c @@ -1,9 +1,13 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * TLMM driver for Qualcomm APQ8016, APQ8096 + * TLMM driver for Qualcomm Snapdragon SOCs * * (C) Copyright 2018 Ramon Fried ramon.fried@gmail.com * + * Copyright (c) 2020 Sartura Ltd. + * + * Author: Robert Marko robert.marko@sartura.hr + * */ #include <common.h> @@ -30,6 +34,7 @@ struct msm_pinctrl_priv { static const struct pinconf_param msm_conf_params[] = { { "drive-strength", PIN_CONFIG_DRIVE_STRENGTH, 3 }, { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, + { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 2 }, }; static int msm_get_functions_count(struct udevice *dev) @@ -96,6 +101,10 @@ static int msm_pinconf_set(struct udevice *dev, unsigned int pin_selector, clrbits_le32(priv->base + GPIO_CONFIG_OFFSET(pin_selector), TLMM_GPIO_PULL_MASK); break; + case PIN_CONFIG_BIAS_PULL_UP: + clrsetbits_le32(priv->base + GPIO_CONFIG_OFFSET(pin_selector), + TLMM_GPIO_PULL_MASK, argument); + break; default: return 0; } @@ -103,18 +112,6 @@ static int msm_pinconf_set(struct udevice *dev, unsigned int pin_selector, return 0; } -static struct pinctrl_ops msm_pinctrl_ops = { - .get_pins_count = msm_get_pins_count, - .get_pin_name = msm_get_pin_name, - .set_state = pinctrl_generic_set_state, - .pinmux_set = msm_pinmux_set, - .pinconf_num_params = ARRAY_SIZE(msm_conf_params), - .pinconf_params = msm_conf_params, - .pinconf_set = msm_pinconf_set, - .get_functions_count = msm_get_functions_count, - .get_function_name = msm_get_function_name, -}; - static int msm_pinctrl_bind(struct udevice *dev) { ofnode node = dev_ofnode(dev); @@ -141,11 +138,24 @@ static int msm_pinctrl_bind(struct udevice *dev) return 0; } +static struct pinctrl_ops msm_pinctrl_ops = { + .get_pins_count = msm_get_pins_count, + .get_pin_name = msm_get_pin_name, + .set_state = pinctrl_generic_set_state, + .pinmux_set = msm_pinmux_set, + .pinconf_num_params = ARRAY_SIZE(msm_conf_params), + .pinconf_params = msm_conf_params, + .pinconf_set = msm_pinconf_set, + .get_functions_count = msm_get_functions_count, + .get_function_name = msm_get_function_name, +}; + static const struct udevice_id msm_pinctrl_ids[] = { { .compatible = "qcom,msm8916-pinctrl", .data = (ulong)&apq8016_data }, { .compatible = "qcom,msm8996-pinctrl", .data = (ulong)&apq8096_data }, { .compatible = "qcom,sdm845-pinctrl", .data = (ulong)&sdm845_data }, { .compatible = "qcom,qcs404-pinctrl", .data = (ulong)&qcs404_data }, + { .compatible = "qcom,ipq4019-pinctrl", .data = (ulong)&ipq4019_data }, { } }; diff --git a/arch/arm/mach-snapdragon/pinctrl-snapdragon.h b/arch/arm/mach-snapdragon/pinctrl-snapdragon.h index 178ee01a41..2ba61a45b3 100644 --- a/arch/arm/mach-snapdragon/pinctrl-snapdragon.h +++ b/arch/arm/mach-snapdragon/pinctrl-snapdragon.h @@ -29,5 +29,6 @@ extern struct msm_pinctrl_data apq8016_data; extern struct msm_pinctrl_data apq8096_data; extern struct msm_pinctrl_data sdm845_data; extern struct msm_pinctrl_data qcs404_data; +extern struct msm_pinctrl_data ipq4019_data; #endif diff --git a/drivers/phy/qcom/Kconfig b/drivers/phy/qcom/Kconfig index f4ca174805..cdc73d46b4 100644 --- a/drivers/phy/qcom/Kconfig +++ b/drivers/phy/qcom/Kconfig @@ -8,7 +8,7 @@ config MSM8916_USB_PHY config PHY_QCOM_IPQ4019_USB tristate "Qualcomm IPQ4019 USB PHY driver" - depends on PHY && ARCH_IPQ40XX + depends on PHY && IPQ40XX help Support for the USB PHY-s on Qualcomm IPQ40xx SoC-s. diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 4cb0ba0850..a3d5fe8872 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -158,7 +158,7 @@ config RESET_IMX7 config RESET_QCOM bool "Reset driver for Qualcomm SoCs" - depends on DM_RESET && (ARCH_SNAPDRAGON || ARCH_IPQ40XX) + depends on DM_RESET && ARCH_SNAPDRAGON default y help Support for reset controller on Qualcomm SoCs. diff --git a/drivers/reset/reset-qcom.c b/drivers/reset/reset-qcom.c index 2c61d6a6dc..7e5eae190d 100644 --- a/drivers/reset/reset-qcom.c +++ b/drivers/reset/reset-qcom.c @@ -25,7 +25,7 @@ struct qcom_reset_map { u8 bit; }; -#ifdef CONFIG_ARCH_IPQ40XX +#ifdef CONFIG_IPQ40XX #include <dt-bindings/reset/qcom,ipq4019-reset.h> static const struct qcom_reset_map gcc_qcom_resets[] = { [WIFI0_CPU_INIT_RESET] = { 0x1f008, 5 }, diff --git a/drivers/smem/Kconfig b/drivers/smem/Kconfig index 73d51b3a7a..7169d0f205 100644 --- a/drivers/smem/Kconfig +++ b/drivers/smem/Kconfig @@ -15,7 +15,7 @@ config SANDBOX_SMEM config MSM_SMEM bool "Qualcomm Shared Memory Manager (SMEM)" depends on DM - depends on ARCH_SNAPDRAGON || ARCH_IPQ40XX + depends on ARCH_SNAPDRAGON help Enable support for the Qualcomm Shared Memory Manager. The driver provides an interface to items in a heap shared among all diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 2f12081f88..a2d5c689ff 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -361,7 +361,7 @@ config PL022_SPI config SPI_QUP bool "Qualcomm SPI controller with QUP interface" - depends on ARCH_IPQ40XX + depends on ARCH_SNAPDRAGON help Qualcomm Universal Peripheral (QUP) core is an AHB slave that
provides a common data path (an output FIFO and an input FIFO)
Andrey Volkov
