Re: [U-Boot] Rockchip RK3288 boot trouble
Hi Kever and Simon,
Thanks very much for the help. Really appreciate it.
I didn't see your detail steps for getting u-boot-dtb.bin, does it include SPL here?
I'm using this method:
- with "CONFIG_ROCKCHIP_SPL_BACK_TO_BROM", which is default setting
I'm confusing with this incorrect DRAM size, could you share the console output during you flash the image, there should have correct DRAM size info. I'm not sure if the DRAM on your board is symmetric or not, or any else special.
See below for the output. I noticed that I only have "Channel b" and not "Channel a". On my other board that boots, I have both a and b. I wonder if one bank of DDR3 went bad on this board. What do you think?
Thanks again.
Rick
DDR Version 1.00 20160217 In Channel b: DDR3 200MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=8 Size=1024MB Memory OK OUT usb boot ver:20160218 ChipType = 8 ...FlashInit enter... FtlMallocOffset = 8040 8000 FtlMallocOffset = 10040 8000 FtlMallocOffset = 11040 1000 FtlMallocOffset = 19040 8000 FtlMallocOffset = 1a040 1000 1:0 0 7f7f05 22 ...NandcInit enter... 0:1200 0 7f7f05 22 FtlMallocOffset = 23040 9000 gNandcVer = 6 SDC_BusRequest: CMD=8 SDC_RESP_TIMEOUT 1815 SDC_BusRequest: CMD=8 SDC_RESP_TIMEOUT 1815 SDC_BusRequest: CMD=8 SDC_RESP_TIMEOUT 1815 SDC_BusRequest: CMD=5 SDC_RESP_TIMEOUT 1815 SDC_BusRequest: CMD=5 SDC_RESP_TIMEOUT 1815 SDC_BusRequest: CMD=5 SDC_RESP_TIMEOUT 1815 SDC_BusRequest: CMD=55 SDC_RESP_TIMEOUT 1815 SDC_BusRequest: CMD=55 SDC_RESP_TIMEOUT 1815 SDC_BusRequest: CMD=55 SDC_RESP_TIMEOUT 1815 mmc Ext_csd, ret=0 , Ext[226]=20, bootSize=2000, Ext[215]=1, Ext[214]=d5, Ext[213]=a0, Ext[212]=0,cap =1d5a000 R EL=1f SdmmcInit=2 0 BootCapSize=2000 UserCapSize=1d5a000 FwPartOffset=2000 , 2000 UsbHook 622396 powerOn 623080 DDR Version 1.00 20160217 In SRX Channel b: DDR3 200MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=8 Size=1024MB
Hi Rick,
On 01/20/2017 02:29 AM, Rick Bronson wrote:
Hi Kever and Simon,
Looks like there is something wrong on channel a DDR, and upstream source code does not support this kind of solution, but if you are using rockchip DRAM init code, you board should be still work only with one channel DRAM.
Thanks, - Kever
Thanks again.
Rick
Kever Yang
Rick Bronson
