[U-Boot] [PATCH v3] ftwdt010_wdt: support faraday ftwdt010 watchdog
Faraday ftwdt010 watchdog is an architecture independant watchdog. It is usaually used in SoC chip design.
Signed-off-by: Macpaul Lin macpaul@andestech.com --- Change v2: Fix the wrong title of ftwdt010_wdt patch. Change v3: Patch v2 was encoded in utf-8. Fixed to ASCII.
drivers/watchdog/Makefile | 1 + drivers/watchdog/ftwdt010_wdt.c | 95 ++++++++++++++++++++++++++++++++++++++ drivers/watchdog/ftwdt010_wdt.h | 96 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 192 insertions(+), 0 deletions(-) create mode 100644 drivers/watchdog/ftwdt010_wdt.c create mode 100644 drivers/watchdog/ftwdt010_wdt.h
diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 6ab4d52..5579bf2 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk LIB := $(obj)libwatchdog.o
COBJS-$(CONFIG_AT91SAM9_WATCHDOG) += at91sam9_wdt.o +COBJS-$(CONFIG_FTWDT010_WATCHDOG) += ftwdt010_wdt.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/watchdog/ftwdt010_wdt.c b/drivers/watchdog/ftwdt010_wdt.c new file mode 100644 index 0000000..8571f15 --- /dev/null +++ b/drivers/watchdog/ftwdt010_wdt.c @@ -0,0 +1,95 @@ +/* + * [origin: Linux kernel drivers/watchdog/ftwdt010_wdt.c] + * + * Watchdog driver for the FTWDT010 Watch Dog Driver + * + * (c) Copyright 2004 Faraday Technology Corp. (www.faraday-tech.com) + * Based on sa1100_wdt.c by Oleg Drokin green@crimea.edu + * Based on SoftDog driver by Alan Cox alan@redhat.com + * + * Copyright (C) 2011 Andes Technology Corporation + * Macpaul Lin, Andes Technology Corporation macpaul@andestech.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version + * 2 of the License, or (at your option) any later version. + * + * 27/11/2004 Initial release, Faraday. + * 12/01/2011 Port to u-boot, Macpaul Lin. + */ + +#include <common.h> +#include <watchdog.h> +#include <asm/io.h> +#include "ftwdt010_wdt.h" + +/* + * Set the watchdog time interval. + * Counter is 32 bit. + */ +static int ftwdt010_wdt_settimeout(unsigned int timeout) +{ + unsigned int reg; + + struct ftwdt010_wdt *wd = (struct ftwdt010_wdt *)CONFIG_FTWDT010_BASE; + + debug("Activating WDT..\n"); + + /* Check if disabled */ + if (readl(&wd->wdcr) & ~FTWDT010_WDCR_ENABLE) { + printf("sorry, watchdog is disabled\n"); + return -1; + } + + /* + * In a 66MHz system, + * if you set WDLOAD as 0x03EF1480 (66000000) + * the reset timer is 1 second. + */ + reg = FTWDT010_WDLOAD(timeout * FTWDT010_TIMEOUT_FACTOR); + + writel(reg, &wd->wdload); + + return 0; +} + +void ftwdt010_wdt_reset() +{ + struct ftwdt010_wdt *wd = (struct ftwdt010_wdt *)CONFIG_FTWDT010_BASE; + + /* clear control register */ + writel(0, &wd->wdcr); + + /* Write Magic number */ + writel(FTWDT010_WDRESTART_MAGIC, &wd->wdrestart); + + /* Enable WDT */ + writel((FTWDT010_WDCR_RST | FTWDT010_WDCR_ENABLE), &wd->wdcr); +} + +void ftwdt010_wdt_disable() +{ + struct ftwdt010_wdt *wd = (struct ftwdt010_wdt *)CONFIG_FTWDT010_BASE; + + debug("Deactivating WDT..\n"); + + /* + * It was defined with CONFIG_WATCHDOG_NOWAYOUT in Linux + * + * Shut off the timer. + * Lock it in if it's a module and we defined ...NOWAYOUT + */ + writel(0, &wd->wdcr); +} + +void hw_watchdog_reset() +{ + ftwdt010_wdt_reset(); +} + +void hw_watchdog_init(void) +{ + /* set timer in ms */ + ftwdt010_wdt_settimeout(CONFIG_FTWDT010_HW_TIMEOUT * 1000); +} diff --git a/drivers/watchdog/ftwdt010_wdt.h b/drivers/watchdog/ftwdt010_wdt.h new file mode 100644 index 0000000..00daec5 --- /dev/null +++ b/drivers/watchdog/ftwdt010_wdt.h @@ -0,0 +1,96 @@ +/* + * [origin: Linux kernel drivers/watchdog/ftwdt010_wdt.c] + * + * Watchdog driver for the FTWDT010 Watch Dog Driver + * + * (c) Copyright 2004 Faraday Technology Corp. (www.faraday-tech.com) + * Based on sa1100_wdt.c by Oleg Drokin green@crimea.edu + * Based on SoftDog driver by Alan Cox alan@redhat.com + * + * Copyright (C) 2011 Andes Technology Corporation + * Macpaul Lin, Andes Technology Corporation macpaul@andestech.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version + * 2 of the License, or (at your option) any later version. + * + * 27/11/2004 Initial release, Faraday. + * 12/01/2011 Port to u-boot, Macpaul Lin. + */ + +#ifndef __FTWDT010_H +#define __FTWDT010_H + +struct ftwdt010_wdt { + unsigned int wdcounter; /* Counter Reg - 0x00 */ + unsigned int wdload; /* Counter Auto Reload Reg - 0x04 */ + unsigned int wdrestart; /* Counter Restart Reg - 0x08 */ + unsigned int wdcr; /* Control Reg - 0x0c */ + unsigned int wdstatus; /* Status Reg - 0x10 */ + unsigned int wdclear; /* Timer Clear - 0x14 */ + unsigned int wdintrlen; /* Interrupt Length - 0x18 */ +}; + +/* + * WDLOAD - Counter Auto Reload Register + * The Auto Reload Register is set to 0x03EF1480 (66Mhz) by default. + * Which means in a 66MHz system, the period of Watch Dog timer reset is + * one second. + */ +#define FTWDT010_WDLOAD(x) ((x) & 0xffffffff) + +/* + * WDRESTART - Watch Dog Timer Counter Restart Register + * If writing 0x5AB9 to WDRESTART register, Watch Dog timer will + * automatically reload WDLOAD to WDCOUNTER and restart counting. + */ +#define FTWDT010_WDRESTART_MAGIC 0x5AB9 + +/* WDCR - Watch Dog Timer Control Register */ +#define FTWDT010_WDCR_ENABLE (1 << 0) +#define FTWDT010_WDCR_RST (1 << 1) +#define FTWDT010_WDCR_INTR (1 << 2) +/* FTWDT010_WDCR_EXT bit: Watch Dog Timer External Signal Enable */ +#define FTWDT010_WDCR_EXT (1 << 3) +/* FTWDT010_WDCR_CLOCK bit: Clock Source: 0: PCLK, 1: EXTCLK. + * The clock source PCLK cannot be gated when system sleeps, even if + * WDCLOCK bit is turned on. + * + * Faraday's Watch Dog timer can be driven by an external clock. The + * programmer just needs to write one to WdCR[WdClock] bit. + * + * Note: There is a limitation between EXTCLK and PCLK: + * EXTCLK cycle time / PCLK cycle time > 2. + * If the system does not need an external clock, + * just keep WdCR[WdClock] bit in its default value. + */ +#define FTWDT010_WDCR_CLOCK (1 << 4) + +/* + * WDSTATUS - Watch Dog Timer Status Register + * This bit is set when the counter reaches Zero + */ +#define FTWDT010_WDSTATUS(x) ((x) & 0x1) + +/* + * WDCLEAR - Watch Dog Timer Clear Register + * Writing one to this register will clear WDSTATUS. + */ +#define FTWDT010_WDCLEAR (1 << 0) + +/* + * WDINTRLEN - Watch Dog Timer Interrupt Length + * This register controls the duration length of wd_rst, wd_intr and wd_ext. + * The default value is 0xFF. + */ +#define FTWDT010_WDINTRLEN(x) ((x) & 0xff) + +/* + * Variable timeout should be set in ms. + * (CONFIG_SYS_CLK_FREQ/1000) equals 1 ms. + * WDLOAD = timeout * TIMEOUT_FACTOR. + */ +#define FTWDT010_TIMEOUT_FACTOR (CONFIG_SYS_CLK_FREQ / 1000) /* 1 ms */ + +#endif /* __FTWDT010_H */
Dear Macpaul Lin,
In message 1294195930-11548-1-git-send-email-macpaul@andestech.com you wrote:
- [origin: Linux kernel drivers/watchdog/ftwdt010_wdt.c]
Sorry, but I see only now that this file was derived from Linux. Please note this accordingly in the commit message - see http://www.denx.de/wiki/view/U-Boot/Patches#Attributing_Code_Copyrights_Sign
Hi Wolfgang,
2011/1/26 Wolfgang Denk wd@denx.de
Dear Macpaul Lin,
Ah, there is a problem here.
The upstream Linux Kernel source tree has not accept this commit. If the reference driver source (GPL) haven't released to Linux Kernel yet, or the reference source code is just send to Linux Kernel. How do we deal with it?
If the driver source haven't be accepted by Linux kernel, I think I can modify the copyright statement hence this driver is independent with current Linux Kernel.
Dear Macpaul Lin,
In message AANLkTin+Fd7edXc4VY1ifGNpgOA5ZbAx83ciQJVA+PL8@mail.gmail.com you wrote:
Maybe you can add a link to the mailing list entry which shows your submission? I think it is in any case interesting to the reader to be able to refer to the Linux driver source as well.
Indeed.
Dear Wolfgang
Dear Macpaul Lin,
[deleted]
Indeed.
Since the Linux Driver still under clean up, I will modify the copyright statement of this driver for u-boot and send patch v3.
Po-Yu: If you were doing the code clean up works for watchdog timer for Linux Kernel, please keep on doing this work. Since I have no time to deal with Linux Kernel recently. If you have clean patch of this watchdog driver please commit it, too.
Best regards, Macpaul Lin
Dear Wolfgang,
I have modified copyright statement for this patch ftwdt010_wdt v3 http://patchwork.ozlabs.org/patch/77564/ and send patch v4 http://patchwork.ozlabs.org/patch/80490/ about 2 weeks ago.
Just remind you if this method is capable, please apply the new patch. Thanks a lot.
Macpaul Lin
Macpaul Lin
