[PATCH v2] sunxi: add fdtoverlay_addr_r environment variable
Commit 69076dff2284 ("cmd: pxe: add support for FDT overlays") added support for loading DT overlay files to PXE boot. However, it needs additional environment variable which points to memory location which can be used to temporary store overlay data.
Add it and in the process unify alignment using spaces and fix comment.
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net ---
Changes from v1: - added r-b tag - fixed comment
include/configs/sunxi-common.h | 49 ++++++++++++++++++---------------- 1 file changed, 26 insertions(+), 23 deletions(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index ded5aea551d3..3e1dc47c9c55 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -62,7 +62,7 @@ #define SDRAM_OFFSET(x) 0x2##x #define CONFIG_SYS_SDRAM_BASE 0x20000000 #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* default load address */ -/* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here +/* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ #define CONFIG_SPL_STACK_R_ADDR 0x2fe00000 @@ -72,7 +72,7 @@ #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_LOAD_ADDR 0x42000000 /* default load address */ /* V3s do not have enough memory to place code at 0x4a000000 */ -/* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here +/* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ #define CONFIG_SPL_STACK_R_ADDR 0x4fe00000 @@ -257,40 +257,42 @@ extern int soft_i2c_gpio_scl; * There is no compression for arm64 kernels (yet), so leave some space * for really big kernels, say 256MB for now. * Scripts, PXE and DTBs should go afterwards, leaving the rest for the initrd. - * Align the initrd to a 2MB page. */ -#define BOOTM_SIZE __stringify(0xa000000) -#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(0080000)) -#define FDT_ADDR_R __stringify(SDRAM_OFFSET(FA00000)) -#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(FC00000)) -#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(FD00000)) -#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(FE00000)) +#define BOOTM_SIZE __stringify(0xa000000) +#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(0080000)) +#define FDT_ADDR_R __stringify(SDRAM_OFFSET(FA00000)) +#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(FC00000)) +#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(FD00000)) +#define FDTOVERLAY_ADDR_R __stringify(SDRAM_OFFSET(FE00000)) +#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(FF00000))
#else /* * 160M RAM (256M minimum minus 64MB heap + 32MB for u-boot, stack, fb, etc. * 32M uncompressed kernel, 16M compressed kernel, 1M fdt, - * 1M script, 1M pxe and the ramdisk at the end. + * 1M script, 1M pxe, 1M dt overlay and the ramdisk at the end. */ #ifndef CONFIG_MACH_SUN8I_V3S -#define BOOTM_SIZE __stringify(0xa000000) -#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(2000000)) -#define FDT_ADDR_R __stringify(SDRAM_OFFSET(3000000)) -#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(3100000)) -#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(3200000)) -#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(3300000)) +#define BOOTM_SIZE __stringify(0xa000000) +#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(2000000)) +#define FDT_ADDR_R __stringify(SDRAM_OFFSET(3000000)) +#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(3100000)) +#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(3200000)) +#define FDTOVERLAY_ADDR_R __stringify(SDRAM_OFFSET(3300000)) +#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(3400000)) #else /* * 64M RAM minus 2MB heap + 16MB for u-boot, stack, fb, etc. * 16M uncompressed kernel, 8M compressed kernel, 1M fdt, - * 1M script, 1M pxe and the ramdisk at the end. + * 1M script, 1M pxe, 1M dt overlay and the ramdisk at the end. */ -#define BOOTM_SIZE __stringify(0x2e00000) -#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(1000000)) -#define FDT_ADDR_R __stringify(SDRAM_OFFSET(1800000)) -#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(1900000)) -#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(1A00000)) -#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(1B00000)) +#define BOOTM_SIZE __stringify(0x2e00000) +#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(1000000)) +#define FDT_ADDR_R __stringify(SDRAM_OFFSET(1800000)) +#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(1900000)) +#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(1A00000)) +#define FDTOVERLAY_ADDR_R __stringify(SDRAM_OFFSET(1B00000)) +#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(1C00000)) #endif #endif
@@ -300,6 +302,7 @@ extern int soft_i2c_gpio_scl; "fdt_addr_r=" FDT_ADDR_R "\0" \ "scriptaddr=" SCRIPT_ADDR_R "\0" \ "pxefile_addr_r=" PXEFILE_ADDR_R "\0" \ + "fdtoverlay_addr_r=" FDTOVERLAY_ADDR_R "\0" \ "ramdisk_addr_r=" RAMDISK_ADDR_R "\0"
#define DFU_ALT_INFO_RAM \
Jernej Skrabec
