[U-Boot] [PATCH 3/4] qe: add qe support to ls1021aqds
Signed-off-by: Zhao Qiang B45475@freescale.com --- board/freescale/ls1021aqds/ls1021aqds.c | 8 ++++++++ include/configs/ls1021aqds.h | 5 +++++ 2 files changed, 13 insertions(+)
diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 12e83f7..3bc4a68 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -16,6 +16,9 @@
#include "../common/qixis.h" #include "ls1021aqds_qixis.h" +#ifdef CONFIG_U_QE +#include "../../../drivers/qe/qe.h" +#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -227,6 +230,11 @@ int board_init(void) fsl_serdes_init(); config_serdes_mux(); #endif + +#ifdef CONFIG_U_QE + u_qe_init(); +#endif + return 0; }
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 657e3b6..e19b81e 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -67,6 +67,9 @@ unsigned long get_board_ddr_clk(void);
#define CONFIG_SYS_HAS_SERDES
+#if !defined(CONFIG_SDCARD) && !defined(CONFIG_NAND) && !defined(CONFIG_SPI) +#define CONFIG_U_QE +#endif /* * IFC Definitions */ @@ -329,6 +332,8 @@ unsigned long get_board_ddr_clk(void);
#define CONFIG_BOOTDELAY 3
+#define CONFIG_SYS_QE_FW_ADDR 0x67f40000 + #define CONFIG_EXTRA_ENV_SETTINGS \ "bootargs=root=/dev/ram0 rw console=ttyS0,115200\0" \ "fdt_high=0xcfffffff\0" \
Signed-off-by: Zhao Qiang B45475@freescale.com --- board/freescale/ls1021atwr/ls1021atwr.c | 7 +++++++ include/configs/ls1021atwr.h | 6 ++++++ 2 files changed, 13 insertions(+)
diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index b522ff2..da09d6e 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -16,6 +16,9 @@ #include <netdev.h> #include <fsl_mdio.h> #include <tsec.h> +#ifdef CONFIG_U_QE +#include "../../../drivers/qe/qe.h" +#endif
@@ -277,6 +280,10 @@ int board_init(void) config_serdes_mux(); #endif
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 45b2272..b09c2c7 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -48,6 +48,10 @@
+#if !defined(CONFIG_SDCARD) && !defined(CONFIG_NAND) && !defined(CONFIG_SPI) +#define CONFIG_U_QE +#endif + /* * IFC Definitions */ @@ -274,6 +278,8 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */
+#define CONFIG_SYS_QE_FW_ADDR 0x67f40000 + /* * Environment */
Applied to u-boot-fsl-qoriq master. Awaiting upstream. Thanks.
York
York
York Sun
Zhao Qiang
