[PATCH 1/1] fru: ops: avoid out of bounds access
Building xilinx_zynq_virt_defconfig fails on origin/next as reported by GCC 10.2 (as provided by Debian Bullseye):
CC board/xilinx/common/fru_ops.o board/xilinx/common/fru_ops.c: In function ‘fru_capture’: board/xilinx/common/fru_ops.c:173:8: error: array subscript 284 is outside array bounds of ‘struct fru_table[1]’ [-Werror=array-bounds] 173 | limit = data + sizeof(struct fru_board_data); | ~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ board/xilinx/common/fru_ops.c:17:18: note: while referencing ‘fru_data’ 17 | struct fru_table fru_data __section(.data); | ^~~~~~~~
When using sizeof(struct fru_board_data) to find the end of the structure you should add it to the start of the structure.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- board/xilinx/common/fru_ops.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/xilinx/common/fru_ops.c b/board/xilinx/common/fru_ops.c index b4cd3d4998..44f0913f2e 100644 --- a/board/xilinx/common/fru_ops.c +++ b/board/xilinx/common/fru_ops.c @@ -170,7 +170,7 @@ static int fru_parse_board(unsigned long addr) data = (u8 *)&fru_data.brd.manufacturer_type_len;
/* Record max structure limit not to write data over allocated space */ - limit = data + sizeof(struct fru_board_data); + limit = (u8 *)&fru_data.brd + sizeof(struct fru_board_data);
for (i = 0; ; i++, data += FRU_BOARD_MAX_LEN) { len = fru_check_type_len(*(u8 *)addr, fru_data.brd.lang_code, -- 2.29.2
-- 2.29.2
Applied. M
Michal Simek
