[U-Boot] [PATCH][v3] powerpc: mmc: Add corenet devices support in esdhc spl
Existing eSDHC SPL framework assumes booting from sd-image with boot_format header which contains final u-boot Image offset and size. No such header is present in case of corenet devices like T1040 as corenet deivces use PBI-RCW based intialization.
So, for corenet deives, SPL bootloader use values provided at compilation time. These values can be defined in board specific config file.
Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- Changes for v3: Send as independent patch (not as part of patch set)
Changes for v2: Updated description based on Sun York's inputs
drivers/mmc/fsl_esdhc_spl.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_spl.c b/drivers/mmc/fsl_esdhc_spl.c index 65c52a2..8fc263f 100644 --- a/drivers/mmc/fsl_esdhc_spl.c +++ b/drivers/mmc/fsl_esdhc_spl.c @@ -42,6 +42,10 @@ void __noreturn mmc_boot(void) hang(); }
+#ifdef CONFIG_FSL_CORENET + offset = CONFIG_SYS_MMC_U_BOOT_OFFS; + code_len = CONFIG_SYS_MMC_U_BOOT_SIZE; +#else blklen = mmc->read_bl_len; tmp_buf = malloc(blklen); if (!tmp_buf) { @@ -91,6 +95,7 @@ void __noreturn mmc_boot(void) /* * Load U-Boot image from mmc into RAM */ +#endif blk_start = ALIGN(offset, mmc->read_bl_len) / mmc->read_bl_len; blk_cnt = ALIGN(code_len, mmc->read_bl_len) / mmc->read_bl_len; err = mmc->block_dev.block_read(0, blk_start, blk_cnt,
Hi Priyanka,
- offset = CONFIG_SYS_MMC_U_BOOT_OFFS;
- code_len = CONFIG_SYS_MMC_U_BOOT_SIZE;
- Load U-Boot image from mmc into RAM
*/ +#endif blk_start = ALIGN(offset, mmc->read_bl_len) / mmc->read_bl_len; blk_cnt = ALIGN(code_len, mmc->read_bl_len) / mmc->read_bl_len; err = mmc->block_dev.block_read(0, blk_start, blk_cnt, -- 1.7.4.1
Acked-by: Pantelis Antoniou panto@antoniou-consulting.com
Thanks.
-- Pantelis
Pantelis Antoniou
Priyanka Jain
