[U-Boot] [PATCH v2] Small refactor to remove duplicate serial code
This tidies up duplicate code, and checks that default_serial_console() does in fact produce a device.
Acked-by: Mike Frysinger vapier@gentoo.org
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Rebase to master
common/serial.c | 61 +++++++++++++++++------------------------------------- 1 files changed, 19 insertions(+), 42 deletions(-)
diff --git a/common/serial.c b/common/serial.c index 995d268..2bd8976 100644 --- a/common/serial.c +++ b/common/serial.c @@ -158,73 +158,50 @@ void serial_reinit_all (void) } }
-int serial_init (void) +static struct serial_device *get_current(void) { + struct serial_device *dev; + if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); + dev = default_serial_console();
- return dev->init (); + /* We must have a console device */ + if (!dev) + panic("Cannot find console"); + } else { + dev = serial_current; } + return dev; +}
- return serial_current->init (); +int serial_init(void) +{ + return get_current()->init(); }
void serial_setbrg (void) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); - - dev->setbrg (); - return; - } - - serial_current->setbrg (); + get_current()->setbrg(); }
int serial_getc (void) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); - - return dev->getc (); - } - - return serial_current->getc (); + return get_current()->getc(); }
int serial_tstc (void) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); - - return dev->tstc (); - } - - return serial_current->tstc (); + return get_current()->tstc(); }
void serial_putc (const char c) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); - - dev->putc (c); - return; - } - - serial_current->putc (c); + get_current()->putc(c); }
void serial_puts (const char *s) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); - - dev->puts (s); - return; - } - - serial_current->puts (s); + get_current()->puts(s); }
#if CONFIG_POST & CONFIG_SYS_POST_UART
generally speaking there's no newlines in between any of the tags -mike
Dear Simon Glass,
Changes in v2:
- Rebase to master
Doesn't apply - please rebase and resubmit.
Hi Wolfgang,
On Fri, Oct 21, 2011 at 3:27 PM, Wolfgang Denk wd@denx.de wrote:
Dear Simon Glass,
Changes in v2:
- Rebase to master
It is ok - it is already applied.
I really should update some patches in patchwork, as that might be causing you some difficulty. But I have lost my password. Do you know of any way to recover it?
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "Don't think; let the machine do it for you!" - E. C. Berkeley
There is none, but ask on the patchwork mailing list for it to be changed (state that you're on the ozlabs server), and the server maintainer will send you a new one.
Personally, I have .pwclientrc filled in with my login and pwd... after my first loss of patchwork passwd. :)
Amicalement,
Dear Simon Glass,
In message CAPnjgZ1QQMrp88B_iX-YewsqG6B+v2t3KGkyWg3X4sfFcw592w@mail.gmail.com you wrote:
Send email to JK and ask him to change / reset it.
Albert ARIBAUD
Mike Frysinger
