[PATCH 0/4] White Space cleanup
The following is an attempt of a minimal-invasive white space cleaup. It performs the following actions:
- Remove empty lines at the end of a file - Remove white space at the end of lines - Remove excessive empty lines: there is almost never a good reason to have more than 2 consecutive empty lines in a file - Remove SPACE characters that are followed by TAB characters.
Care has been taken not to: - change any actual code - change the formatting of the files (assuming you use a monospace font); no attempts were made to clean up broken formatting. - change any files that were imported from other projects, where we might want to re-import more recent versions; for imports from the Linux kernel, current Linux versions were taken as reference, so for example some files in scripts/kconfig were fixed to fix differences from the Linux versions.
This is all purely cosmetic. No code changes result from this.
I am aware that such a global cosmetic cleanup is always kind of disruptive, but we are at -rc5, so the code should be pretty stable for now, and I've done a few rebases before, with little and easy to fix conflicts.
Wolfgang Denk (4): WS cleanup: remove trailing empty lines WS cleanup: remove excessive empty lines WS cleanup: remove trailing white space WS cleanup: remove SPACE(s) followed by TAB
Licenses/lgpl-2.0.txt | 2 +- Makefile | 6 +- README | 1 - arch/arc/lib/libgcc2.h | 2 +- arch/arm/cpu/arm926ejs/armada100/timer.c | 2 +- arch/arm/cpu/arm926ejs/cache.c | 1 - arch/arm/cpu/armv7/psci-common.c | 1 - arch/arm/cpu/armv8/fel_utils.S | 20 +- .../cpu/armv8/fsl-layerscape/doc/README.lsch3 | 36 +- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 4 +- arch/arm/cpu/armv8/hisilicon/pinmux.c | 2 - arch/arm/cpu/armv8/xen/hypercall.S | 1 - arch/arm/dts/sama7g5-pinfunc.h | 1 - arch/arm/dts/vf610-pinfunc.h | 2 +- arch/arm/include/asm/arch-am33xx/cpu.h | 2 +- arch/arm/include/asm/arch-armada100/mfp.h | 2 +- arch/arm/include/asm/arch-imxrt/imxrt.h | 1 - arch/arm/include/asm/arch-mx25/imx-regs.h | 22 +- arch/arm/include/asm/arch-mx5/imx-regs.h | 4 +- arch/arm/include/asm/arch-mx6/mx6_plugin.S | 4 +- arch/arm/include/asm/arch-mx7/mx7_plugin.S | 2 +- .../include/asm/arch-mx7ulp/mx7ulp_plugin.S | 2 +- .../include/asm/arch-rockchip/cru_rk3368.h | 16 +- .../arm/include/asm/arch-rockchip/f_rockusb.h | 1 - arch/arm/include/asm/arch-stm32/stm32f.h | 1 - .../include/asm/arch-stv0991/stv0991_defs.h | 1 - arch/arm/include/asm/arch-vf610/iomux-vf610.h | 8 +- arch/arm/include/asm/macro.h | 2 +- arch/arm/include/asm/ti-common/davinci_nand.h | 6 +- arch/arm/include/asm/xen.h | 1 - arch/arm/lib/ccn504.S | 3 +- arch/arm/lib/div64.S | 10 +- arch/arm/lib/lib1funcs.S | 6 +- arch/arm/mach-at91/armv7/sama7g5_devices.c | 1 - arch/arm/mach-at91/atmel_sfr.c | 1 - arch/arm/mach-at91/include/mach/at91_mc.h | 24 +- arch/arm/mach-at91/include/mach/at91_st.h | 2 +- arch/arm/mach-bcm283x/msg.c | 1 - .../arm/mach-davinci/include/mach/da8xx-usb.h | 36 +- .../mach-davinci/include/mach/davinci_misc.h | 2 +- arch/arm/mach-imx/Makefile | 4 +- arch/arm/mach-imx/mx7/soc.c | 1 - .../arm/mach-keystone/include/mach/hardware.h | 6 +- arch/arm/mach-kirkwood/cpu.c | 1 - .../serdes/a38x/high_speed_env_spec.c | 2 - arch/arm/mach-octeontx/Makefile | 1 - arch/arm/mach-octeontx2/Makefile | 1 - arch/arm/mach-omap2/clocks-common.c | 2 +- arch/arm/mach-omap2/omap5/prcm-regs.c | 2 +- arch/arm/mach-omap2/pipe3-phy.c | 1 - arch/arm/mach-orion5x/timer.c | 2 +- arch/arm/mach-rmobile/pfc-r8a7790.h | 2 +- arch/arm/mach-rockchip/rk3368/Makefile | 2 +- arch/arm/mach-s5pc1xx/include/mach/sromc.h | 4 +- arch/arm/mach-snapdragon/dram.c | 1 - .../include/mach/fpga_manager_arria10.h | 16 +- arch/arm/mach-sunxi/dram_sun4i.c | 2 +- arch/arm/mach-sunxi/dram_sun8i_a33.c | 4 +- .../mach-sunxi/dram_timings/h6_ddr3_1333.c | 2 +- arch/arm/mach-tegra/tegra20/display.c | 1 - arch/arm/mach-versatile/timer.c | 1 - arch/m68k/cpu/mcf5227x/start.S | 4 +- arch/m68k/cpu/mcf523x/cpu.c | 2 +- arch/m68k/cpu/mcf52x2/cpu.c | 2 +- arch/m68k/cpu/mcf530x/Makefile | 1 - arch/m68k/cpu/mcf532x/cpu.c | 2 +- arch/m68k/cpu/mcf5445x/cpu.c | 2 +- arch/m68k/cpu/mcf5445x/start.S | 6 +- arch/m68k/include/asm/immap_5307.h | 1 - arch/m68k/include/asm/m5271.h | 2 +- arch/m68k/include/asm/m5307.h | 1 - arch/m68k/lib/muldi3.c | 2 +- arch/mips/include/asm/mipsregs.h | 32 +- .../mach-jz47xx/include/mach/jz4780_dram.h | 1 - arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S | 6 +- arch/nds32/cpu/n1213/ag101/lowlevel_init.S | 6 +- arch/nds32/cpu/n1213/ag101/watchdog.S | 2 +- arch/nds32/cpu/n1213/start.S | 8 +- arch/powerpc/cpu/mpc83xx/pcie.c | 4 +- .../powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c | 1 - arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 1 - arch/powerpc/cpu/mpc85xx/start.S | 8 +- arch/powerpc/include/asm/fsl_lbc.h | 4 +- arch/powerpc/include/asm/immap_85xx.h | 4 +- arch/powerpc/include/asm/processor.h | 2 +- arch/powerpc/lib/ppccache.S | 1 - arch/sandbox/include/asm/gpio.h | 2 +- arch/sh/lib/time.c | 1 - arch/x86/cpu/intel_common/car2.S | 2 +- arch/x86/lib/bios_asm.S | 4 +- arch/xtensa/include/asm/arch-dc232b/core.h | 3 - arch/xtensa/include/asm/arch-dc232b/tie-asm.h | 5 - arch/xtensa/include/asm/arch-dc232b/tie.h | 1 - arch/xtensa/include/asm/arch-dc233c/core.h | 48 +- arch/xtensa/include/asm/arch-dc233c/tie-asm.h | 5 - arch/xtensa/include/asm/arch-dc233c/tie.h | 1 - arch/xtensa/include/asm/arch-de212/core.h | 58 +- arch/xtensa/include/asm/arch-de212/tie-asm.h | 1 - arch/xtensa/include/asm/arch-de212/tie.h | 1 - arch/xtensa/include/asm/cacheasm.h | 2 - arch/xtensa/include/asm/regs.h | 1 - arch/xtensa/lib/Makefile | 2 +- arch/xtensa/lib/bootm.c | 1 - arch/xtensa/lib/relocate.c | 1 - board/Marvell/guruplug/guruplug.c | 2 +- board/Marvell/octeontx/smc.c | 1 - board/Marvell/octeontx2/soc-utils.c | 1 - board/atmark-techno/armadillo-800eva/Makefile | 1 - board/atmel/sama7g5ek/sama7g5ek.c | 1 - board/beacon/imx8mn/README | 1 - board/beacon/imx8mn/lpddr4_timing.c | 1 - board/boundary/nitrogen6x/README | 2 +- .../boundary/nitrogen6x/README.mx6qsabrelite | 1 - board/cadence/xtfpga/README | 1 - board/compulab/cm_t43/spl.c | 1 - .../ddr/lpddr4_timing_01061010.1_2.c | 1 - board/freescale/common/sys_eeprom.c | 2 +- board/freescale/common/zm7300.c | 1 - board/freescale/imx8mn_evk/ddr4_timing.c | 1 - board/freescale/imx8mn_evk/ddr4_timing_ld.c | 1 - board/freescale/ls1012afrdm/README | 4 +- board/freescale/ls1012aqds/README | 4 +- board/freescale/ls1012ardb/README | 8 +- board/freescale/ls1046afrwy/README | 4 +- board/freescale/ls1046aqds/README | 4 +- board/freescale/ls1046ardb/README | 6 +- board/freescale/ls1088a/ddr.c | 2 - board/freescale/ls2080aqds/README | 1 - board/freescale/ls2080ardb/README | 1 - board/freescale/m53017evb/README | 2 +- board/freescale/mx6memcal/mx6memcal.c | 1 - board/freescale/t208xqds/README | 1 - board/freescale/t4rdb/cpld.h | 1 - board/gateworks/gw_ventana/Makefile | 1 - board/gateworks/gw_ventana/gsc.h | 1 - board/gdsys/a38x/dt_helpers.c | 1 - board/ge/common/ge_rtc.c | 1 - board/ge/mx53ppd/mx53ppd_video.c | 1 - board/hisilicon/poplar/poplar.c | 1 - board/keymile/common/qrio.c | 1 - board/logicpd/am3517evm/am3517evm.h | 2 +- board/logicpd/imx6/Makefile | 1 - board/logicpd/imx6/README | 1 - board/logicpd/omap3som/omap3logic.h | 2 +- board/mediatek/mt7622/Makefile | 1 - board/mqmaker/miqi_rk3288/miqi-rk3288.c | 1 - board/mscc/jr2/Makefile | 1 - board/mscc/ocelot/Makefile | 1 - .../zynq/zynq-syzygy-hub/ps7_init_gpl.c | 1 - board/phytium/durian/Makefile | 1 - board/phytium/durian/cpu.h | 1 - board/phytium/durian/durian.c | 1 - .../dragonboard820c/dragonboard820c.c | 6 +- board/rockchip/evb_rk3229/evb_rk3229.c | 1 - board/rockchip/evb_rk3288/evb-rk3288.c | 1 - board/rockchip/evb_rk3328/evb-rk3328.c | 1 - board/synopsys/axs10x/axs10x.h | 1 - board/sysam/stmark2/sbf_dram_init.S | 2 +- board/technexion/pico-imx7d/pico-imx7d.c | 1 - .../pico-imx8mq/lpddr4_timing_1gb.c | 1 - .../pico-imx8mq/lpddr4_timing_2gb.c | 1 - .../pico-imx8mq/lpddr4_timing_3gb.c | 1 - .../pico-imx8mq/lpddr4_timing_4gb.c | 1 - board/terasic/de0-nano-soc/qts/pll_config.h | 1 - board/ti/am57xx/board.c | 24 +- board/ti/am57xx/mux_data.h | 4 +- board/warp7/README | 2 +- board/xen/xenguest_arm64/xenguest_arm64.c | 1 - board/xilinx/versal/cmds.c | 1 - .../xilinx/zynq/zynq-microzed/ps7_init_gpl.c | 8 - board/xilinx/zynq/zynq-zc702/ps7_init_gpl.c | 4 - board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c | 8 - board/xilinx/zynq/zynq-zed/ps7_init_gpl.c | 8 - board/xilinx/zynq/zynq-zybo/ps7_init_gpl.c | 1 - cmd/bedbug.c | 4 - cmd/cramfs.c | 2 +- cmd/pvblock.c | 1 - cmd/scp03.c | 1 - cmd/smccc.c | 1 - cmd/spi.c | 6 +- common/hash.c | 2 +- common/hwconfig.c | 2 +- common/lcd_console.c | 1 - common/spl/spl_mmc.c | 2 +- common/spl/spl_ram.c | 2 - common/usb_storage.c | 2 +- disk/Makefile | 2 +- doc/README.commands.spl | 6 +- doc/README.dfutftp | 2 - doc/README.distro | 2 +- doc/README.falcon | 4 +- doc/README.odroid | 4 +- doc/README.pcap | 1 - .../firmware/linaro,optee-tz.txt | 1 - .../mailbox/k3-secure-proxy.txt | 2 +- .../memory-controller/k3-j721e-ddrss.txt | 2 +- .../memory-controllers/k3-am654-ddrss.txt | 2 +- doc/device-tree-bindings/mmc/snps,dw-mmc.txt | 1 - doc/device-tree-bindings/net/altera_tse.txt | 2 +- .../net/fsl,mcf-dma-fec.txt | 2 +- doc/device-tree-bindings/net/fsl,mcf-fec.txt | 2 +- doc/device-tree-bindings/net/mdio.txt | 1 - .../pinctrl/bcm6838-pinctrl.txt | 2 +- .../pinctrl/marvell,armada-apn806-pinctrl.txt | 14 +- .../pinctrl/marvell,mvebu-pinctrl.txt | 2 +- .../regulator/fsl,anatop-regulator.txt | 14 +- doc/device-tree-bindings/spi/spi-bus.txt | 14 +- doc/device-tree-bindings/spi/spi-qup.txt | 2 +- doc/device-tree-bindings/tpm2/sandbox.txt | 2 +- .../w1-eeprom/ds24xxx.txt | 1 - doc/device-tree-bindings/w1-eeprom/ds2502.txt | 1 - .../w1-eeprom/eep_sandbox.txt | 1 - doc/device-tree-bindings/w1/w1-gpio.txt | 1 - doc/imx/common/imx6.txt | 2 +- doc/mvebu/armada-8k-memory.txt | 1 - doc/mvebu/cmd/bubt.txt | 1 - drivers/axi/axi-uclass.c | 1 - drivers/cache/cache-v5l2.c | 4 +- drivers/cache/sandbox_cache.c | 2 +- drivers/clk/at91/clk-sam9x60-pll.c | 1 - drivers/clk/imx/clk-pllv3.c | 2 +- drivers/clk/meson/Makefile | 1 - drivers/clk/rockchip/clk_pll.c | 1 - drivers/crypto/Makefile | 2 +- drivers/ddr/altera/sdram_s10.c | 1 - drivers/ddr/fsl/ddr3_dimm_params.c | 18 +- drivers/ddr/marvell/a38x/ddr3_training.c | 1 - drivers/ddr/marvell/axp/ddr3_spd.c | 2 +- drivers/firmware/scmi/Makefile | 2 +- drivers/fpga/socfpga.c | 1 - drivers/gpio/hi6220_gpio.c | 4 - drivers/i2c/designware_i2c.h | 2 +- drivers/i2c/mxc_i2c.c | 2 - drivers/misc/atsha204a-i2c.c | 32 +- drivers/misc/cros_ec.c | 2 +- drivers/misc/fsl_devdis.c | 1 - drivers/mmc/Makefile | 2 +- drivers/mmc/mmc.c | 2 +- drivers/mtd/mtdcore.c | 8 +- drivers/mtd/nand/raw/davinci_nand.c | 2 +- drivers/mtd/nand/raw/fsl_elbc_nand.c | 2 +- drivers/mtd/nand/raw/mxs_nand_spl.c | 1 - drivers/mtd/nand/raw/nand_base.c | 12 +- drivers/mtd/nand/raw/nand_ids.c | 2 +- drivers/mtd/nand/raw/nand_util.c | 4 +- drivers/mtd/onenand/onenand_base.c | 4 +- drivers/mtd/spi/spi-nor-ids.c | 2 +- drivers/mtd/ubi/build.c | 2 +- drivers/mtd/ubi/crc32.c | 32 +- drivers/net/at91_emac.c | 2 +- drivers/net/calxedaxgmac.c | 2 +- drivers/net/dm9000x.c | 4 +- drivers/net/e1000.c | 4 - drivers/net/e1000.h | 2 +- drivers/net/fsl-mc/dpni.c | 1 - drivers/net/mvmdio.c | 1 - drivers/net/octeontx/nic_main.c | 1 - drivers/net/octeontx2/Makefile | 1 - drivers/net/octeontx2/nix.c | 1 - drivers/net/octeontx2/npc.h | 1 - drivers/net/octeontx2/rvu.h | 1 - drivers/net/phy/meson-gxl.c | 2 +- drivers/net/smc911x.h | 4 +- drivers/net/sun8i_emac.c | 2 +- drivers/pci/fsl_pci_init.c | 2 +- drivers/phy/marvell/comphy_core.h | 1 - drivers/phy/marvell/utmi_phy.h | 1 - drivers/pinctrl/mediatek/pinctrl-mt7622.c | 2 - drivers/pinctrl/meson/pinctrl-meson-axg.c | 2 +- drivers/pinctrl/meson/pinctrl-meson-g12a.c | 2 +- drivers/pinctrl/renesas/pfc-r8a77970.c | 2 +- drivers/pinctrl/renesas/pfc-r8a77980.c | 6 +- drivers/power/pmic/pmic_tps65910.c | 2 +- drivers/pwm/pwm-meson.c | 2 +- drivers/ram/k3-ddrss/k3-ddrss.c | 4 +- drivers/ram/rockchip/sdram_rk322x.c | 1 - drivers/ram/stm32_sdram.c | 2 +- drivers/reset/reset-meson.c | 10 +- drivers/reset/reset-raspberrypi.c | 1 - drivers/serial/serial_msm.c | 2 +- drivers/serial/serial_sti_asc.c | 1 - drivers/serial/serial_xen.c | 1 - drivers/spi/atcspi200_spi.c | 2 +- drivers/thermal/imx_tmu.c | 4 +- drivers/timer/atmel_pit_timer.c | 2 +- drivers/timer/stm32_timer.c | 1 - drivers/usb/dwc3/core.h | 12 +- drivers/usb/dwc3/dwc3-meson-gxl.c | 2 +- drivers/usb/dwc3/gadget.c | 2 +- drivers/usb/eth/r8152.c | 1 - drivers/usb/gadget/at91_udc.h | 3 +- drivers/usb/gadget/pxa27x_udc.c | 2 +- drivers/usb/host/xhci-rcar-r8a779x_usb3_v3.h | 2 +- drivers/usb/musb-new/musb_gadget.c | 4 +- drivers/usb/musb-new/musb_regs.h | 2 +- drivers/usb/musb-new/musb_uboot.c | 2 +- drivers/usb/musb/musb_core.h | 10 +- drivers/usb/musb/musb_hcd.c | 4 +- drivers/video/anx9804.c | 10 +- drivers/video/bus_vcxk.c | 10 +- drivers/video/mxsfb.c | 2 +- drivers/video/rockchip/rk_mipi.c | 1 - drivers/video/stb_truetype.h | 1 - drivers/video/tdo-tl070wsh30.c | 2 +- drivers/watchdog/orion_wdt.c | 4 +- drivers/xen/events.c | 1 - drivers/xen/gnttab.c | 1 - fs/btrfs/btrfs.c | 2 +- fs/btrfs/kernel-shared/btrfs_tree.h | 1 - fs/jffs2/summary.h | 10 +- fs/ubifs/ubifs.h | 10 +- include/atsha204a-i2c.h | 4 +- include/configs/amcore.h | 1 - include/configs/at91sam9263ek.h | 4 +- include/configs/broadcom_bcm963158.h | 1 - include/configs/broadcom_bcm968580xref.h | 1 - include/configs/cm_t335.h | 1 - include/configs/comtrend_ar5315u.h | 1 - include/configs/comtrend_ar5387un.h | 1 - include/configs/comtrend_ct5361.h | 1 - include/configs/comtrend_wap5813n.h | 1 - include/configs/controlcenterdc.h | 2 +- include/configs/corenet_ds.h | 2 +- include/configs/emsdp.h | 1 - include/configs/etamin.h | 1 - include/configs/huawei_hg556a.h | 1 - include/configs/imx6-engicam.h | 2 +- include/configs/imx7-cm.h | 6 +- include/configs/km/km-mpc832x.h | 1 - include/configs/ls1043a_common.h | 2 +- include/configs/nas220.h | 1 - include/configs/netgear_cg3100d.h | 1 - include/configs/netgear_dgnd3700v2.h | 1 - include/configs/novena.h | 2 +- include/configs/omap3_beagle.h | 2 +- include/configs/opos6uldev.h | 2 +- include/configs/sagem_f@st1704.h | 1 - include/configs/sfr_nb4_ser.h | 1 - include/configs/socrates.h | 10 +- include/configs/verdin-imx8mm.h | 1 - include/div64.h | 2 +- include/dm/platform_data/spi_coldfire.h | 1 - include/dt-bindings/clock/mt7622-clk.h | 1 - include/dt-bindings/comphy/comphy_data.h | 1 - include/dt-bindings/mfd/dbx500-prcmu.h | 104 ++-- include/dt-bindings/pinctrl/dra.h | 1 - include/dt-bindings/pinctrl/omap.h | 1 - include/dt-bindings/pinctrl/stm32-pinfunc.h | 1 - include/dt-bindings/thermal/thermal.h | 1 - include/environment/distro/sf.h | 14 +- include/environment/ti/nand.h | 1 - include/faraday/ftpmu010.h | 2 +- include/fsl-mc/fsl_dpni.h | 2 - include/fsl_qe.h | 2 +- include/fsl_wdog.h | 2 +- include/generic-phy.h | 2 +- include/imximage.h | 2 +- include/linux/apm_bios.h | 2 +- include/linux/compiler.h | 2 +- include/linux/ioport.h | 2 +- include/linux/list.h | 4 +- include/linux/mtd/doc2000.h | 6 +- include/linux/mtd/flashchip.h | 1 - include/linux/mtd/partitions.h | 10 +- include/linux/mtd/rawnand.h | 2 +- include/linux/screen_info.h | 4 +- include/linux/serial_reg.h | 8 +- include/linux/usb/gadget.h | 6 +- include/mc13783.h | 2 +- include/mpc85xx.h | 6 +- include/mtd/mtd-abi.h | 2 +- include/mvmfp.h | 2 +- include/part.h | 2 +- include/phy.h | 4 +- include/smem.h | 1 - include/st_logo_data.h | 1 - include/tsec.h | 2 +- include/video_font_4x6.h | 512 +++++++++--------- net/tftp.c | 1 - scripts/basic/Makefile | 2 +- scripts/dtc/treesource.c | 1 - scripts/kconfig/Makefile | 2 +- scripts/kconfig/expr.c | 2 +- scripts/kconfig/gconf.c | 2 +- scripts/kconfig/list.h | 2 +- test/dm/pci_ep.c | 1 - test/dm/smem.c | 1 - tools/asn1_compiler.c | 2 +- tools/kwbimage.h | 4 +- tools/patman/test/test01.txt | 20 +- 390 files changed, 867 insertions(+), 1112 deletions(-)
Signed-off-by: Wolfgang Denk wd@denx.de --- arch/arm/cpu/arm926ejs/cache.c | 1 - arch/arm/cpu/armv7/psci-common.c | 1 - arch/arm/cpu/armv8/hisilicon/pinmux.c | 2 -- arch/arm/cpu/armv8/xen/hypercall.S | 1 - arch/arm/dts/sama7g5-pinfunc.h | 1 - arch/arm/include/asm/arch-imxrt/imxrt.h | 1 - arch/arm/include/asm/arch-rockchip/f_rockusb.h | 1 - arch/arm/include/asm/arch-stm32/stm32f.h | 1 - arch/arm/include/asm/arch-stv0991/stv0991_defs.h | 1 - arch/arm/include/asm/xen.h | 1 - arch/arm/lib/ccn504.S | 1 - arch/arm/mach-at91/armv7/sama7g5_devices.c | 1 - arch/arm/mach-at91/atmel_sfr.c | 1 - arch/arm/mach-bcm283x/msg.c | 1 - arch/arm/mach-imx/mx7/soc.c | 1 - arch/arm/mach-kirkwood/cpu.c | 1 - arch/arm/mach-octeontx/Makefile | 1 - arch/arm/mach-octeontx2/Makefile | 1 - arch/arm/mach-omap2/pipe3-phy.c | 1 - arch/arm/mach-snapdragon/dram.c | 1 - arch/arm/mach-tegra/tegra20/display.c | 1 - arch/arm/mach-versatile/timer.c | 1 - arch/m68k/cpu/mcf530x/Makefile | 1 - arch/m68k/include/asm/immap_5307.h | 1 - arch/m68k/include/asm/m5307.h | 1 - arch/mips/mach-jz47xx/include/mach/jz4780_dram.h | 1 - arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c | 1 - arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 1 - arch/powerpc/lib/ppccache.S | 1 - arch/sh/lib/time.c | 1 - arch/xtensa/include/asm/arch-dc232b/core.h | 1 - arch/xtensa/include/asm/arch-dc232b/tie-asm.h | 1 - arch/xtensa/include/asm/arch-dc232b/tie.h | 1 - arch/xtensa/include/asm/arch-dc233c/core.h | 1 - arch/xtensa/include/asm/arch-dc233c/tie-asm.h | 1 - arch/xtensa/include/asm/arch-dc233c/tie.h | 1 - arch/xtensa/include/asm/arch-de212/core.h | 1 - arch/xtensa/include/asm/arch-de212/tie-asm.h | 1 - arch/xtensa/include/asm/arch-de212/tie.h | 1 - arch/xtensa/include/asm/regs.h | 1 - arch/xtensa/lib/bootm.c | 1 - arch/xtensa/lib/relocate.c | 1 - board/Marvell/octeontx/smc.c | 1 - board/Marvell/octeontx2/soc-utils.c | 1 - board/atmark-techno/armadillo-800eva/Makefile | 1 - board/atmel/sama7g5ek/sama7g5ek.c | 1 - board/beacon/imx8mn/README | 1 - board/beacon/imx8mn/lpddr4_timing.c | 1 - board/boundary/nitrogen6x/README.mx6qsabrelite | 1 - board/cadence/xtfpga/README | 1 - board/compulab/cm_t43/spl.c | 1 - .../imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.1_2.c | 1 - board/freescale/common/zm7300.c | 1 - board/freescale/imx8mn_evk/ddr4_timing.c | 1 - board/freescale/imx8mn_evk/ddr4_timing_ld.c | 1 - board/freescale/ls2080aqds/README | 1 - board/freescale/ls2080ardb/README | 1 - board/freescale/mx6memcal/mx6memcal.c | 1 - board/freescale/t4rdb/cpld.h | 1 - board/gateworks/gw_ventana/Makefile | 1 - board/gateworks/gw_ventana/gsc.h | 1 - board/gdsys/a38x/dt_helpers.c | 1 - board/ge/common/ge_rtc.c | 1 - board/ge/mx53ppd/mx53ppd_video.c | 1 - board/hisilicon/poplar/poplar.c | 1 - board/keymile/common/qrio.c | 1 - board/logicpd/imx6/Makefile | 1 - board/logicpd/imx6/README | 1 - board/mediatek/mt7622/Makefile | 1 - board/mqmaker/miqi_rk3288/miqi-rk3288.c | 1 - board/mscc/jr2/Makefile | 1 - board/mscc/ocelot/Makefile | 1 - board/opalkelly/zynq/zynq-syzygy-hub/ps7_init_gpl.c | 1 - board/phytium/durian/Makefile | 1 - board/phytium/durian/cpu.h | 1 - board/phytium/durian/durian.c | 1 - board/rockchip/evb_rk3229/evb_rk3229.c | 1 - board/rockchip/evb_rk3288/evb-rk3288.c | 1 - board/rockchip/evb_rk3328/evb-rk3328.c | 1 - board/synopsys/axs10x/axs10x.h | 1 - board/technexion/pico-imx7d/pico-imx7d.c | 1 - board/technexion/pico-imx8mq/lpddr4_timing_1gb.c | 1 - board/technexion/pico-imx8mq/lpddr4_timing_2gb.c | 1 - board/technexion/pico-imx8mq/lpddr4_timing_3gb.c | 1 - board/technexion/pico-imx8mq/lpddr4_timing_4gb.c | 1 - board/terasic/de0-nano-soc/qts/pll_config.h | 1 - board/xen/xenguest_arm64/xenguest_arm64.c | 1 - board/xilinx/versal/cmds.c | 1 - board/xilinx/zynq/zynq-microzed/ps7_init_gpl.c | 4 ---- board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c | 4 ---- board/xilinx/zynq/zynq-zed/ps7_init_gpl.c | 4 ---- board/xilinx/zynq/zynq-zybo/ps7_init_gpl.c | 1 - cmd/pvblock.c | 1 - cmd/scp03.c | 1 - cmd/smccc.c | 1 - common/lcd_console.c | 1 - common/spl/spl_ram.c | 2 -- doc/README.pcap | 1 - doc/device-tree-bindings/mmc/snps,dw-mmc.txt | 1 - doc/device-tree-bindings/net/mdio.txt | 1 - doc/device-tree-bindings/w1-eeprom/ds24xxx.txt | 1 - doc/device-tree-bindings/w1-eeprom/ds2502.txt | 1 - doc/device-tree-bindings/w1-eeprom/eep_sandbox.txt | 1 - doc/device-tree-bindings/w1/w1-gpio.txt | 1 - doc/mvebu/armada-8k-memory.txt | 1 - doc/mvebu/cmd/bubt.txt | 1 - drivers/axi/axi-uclass.c | 1 - drivers/clk/at91/clk-sam9x60-pll.c | 1 - drivers/clk/meson/Makefile | 1 - drivers/clk/rockchip/clk_pll.c | 1 - drivers/ddr/altera/sdram_s10.c | 1 - drivers/ddr/marvell/a38x/ddr3_training.c | 1 - drivers/fpga/socfpga.c | 1 - drivers/gpio/hi6220_gpio.c | 2 -- drivers/misc/fsl_devdis.c | 1 - drivers/mtd/nand/raw/mxs_nand_spl.c | 1 - drivers/net/fsl-mc/dpni.c | 1 - drivers/net/mvmdio.c | 1 - drivers/net/octeontx/nic_main.c | 1 - drivers/net/octeontx2/Makefile | 1 - drivers/net/octeontx2/nix.c | 1 - drivers/net/octeontx2/npc.h | 1 - drivers/net/octeontx2/rvu.h | 1 - drivers/phy/marvell/comphy_core.h | 1 - drivers/phy/marvell/utmi_phy.h | 1 - drivers/pinctrl/mediatek/pinctrl-mt7622.c | 2 -- drivers/ram/rockchip/sdram_rk322x.c | 1 - drivers/reset/reset-raspberrypi.c | 1 - drivers/serial/serial_sti_asc.c | 1 - drivers/serial/serial_xen.c | 1 - drivers/timer/stm32_timer.c | 1 - drivers/usb/eth/r8152.c | 1 - drivers/usb/gadget/at91_udc.h | 1 - drivers/video/rockchip/rk_mipi.c | 1 - drivers/xen/events.c | 1 - drivers/xen/gnttab.c | 1 - include/configs/amcore.h | 1 - include/configs/broadcom_bcm963158.h | 1 - include/configs/broadcom_bcm968580xref.h | 1 - include/configs/cm_t335.h | 1 - include/configs/comtrend_ar5315u.h | 1 - include/configs/comtrend_ar5387un.h | 1 - include/configs/comtrend_ct5361.h | 1 - include/configs/comtrend_wap5813n.h | 1 - include/configs/emsdp.h | 1 - include/configs/huawei_hg556a.h | 1 - include/configs/km/km-mpc832x.h | 1 - include/configs/nas220.h | 1 - include/configs/netgear_cg3100d.h | 1 - include/configs/netgear_dgnd3700v2.h | 1 - include/configs/sagem_f@st1704.h | 1 - include/configs/sfr_nb4_ser.h | 1 - include/configs/verdin-imx8mm.h | 1 - include/dm/platform_data/spi_coldfire.h | 1 - include/dt-bindings/clock/mt7622-clk.h | 1 - include/dt-bindings/comphy/comphy_data.h | 1 - include/dt-bindings/pinctrl/dra.h | 1 - include/dt-bindings/pinctrl/omap.h | 1 - include/dt-bindings/pinctrl/stm32-pinfunc.h | 1 - include/dt-bindings/thermal/thermal.h | 1 - include/environment/ti/nand.h | 1 - include/linux/serial_reg.h | 1 - include/smem.h | 1 - include/st_logo_data.h | 1 - net/tftp.c | 1 - scripts/dtc/treesource.c | 1 - test/dm/pci_ep.c | 1 - test/dm/smem.c | 1 - 168 files changed, 181 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index acab9bccc0..95963d2665 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -89,4 +89,3 @@ void enable_caches(void) dcache_enable(); #endif } - diff --git a/arch/arm/cpu/armv7/psci-common.c b/arch/arm/cpu/armv7/psci-common.c index a328b2bc0e..f313fe4b84 100644 --- a/arch/arm/cpu/armv7/psci-common.c +++ b/arch/arm/cpu/armv7/psci-common.c @@ -43,4 +43,3 @@ u32 __secure psci_get_context_id(int cpu) { return psci_context_id[cpu]; } - diff --git a/arch/arm/cpu/armv8/hisilicon/pinmux.c b/arch/arm/cpu/armv8/hisilicon/pinmux.c index 5183e00a44..e14057c0a4 100644 --- a/arch/arm/cpu/armv8/hisilicon/pinmux.c +++ b/arch/arm/cpu/armv8/hisilicon/pinmux.c @@ -181,5 +181,3 @@ int hi6220_pinmux_config(int peripheral)
return 0; } - - diff --git a/arch/arm/cpu/armv8/xen/hypercall.S b/arch/arm/cpu/armv8/xen/hypercall.S index 731256b34e..e69ed408dc 100644 --- a/arch/arm/cpu/armv8/xen/hypercall.S +++ b/arch/arm/cpu/armv8/xen/hypercall.S @@ -76,4 +76,3 @@ HYPERCALL2(sched_op); HYPERCALL2(event_channel_op); HYPERCALL2(hvm_op); HYPERCALL2(memory_op); - diff --git a/arch/arm/dts/sama7g5-pinfunc.h b/arch/arm/dts/sama7g5-pinfunc.h index 89293e5470..b5472fa4c9 100644 --- a/arch/arm/dts/sama7g5-pinfunc.h +++ b/arch/arm/dts/sama7g5-pinfunc.h @@ -921,4 +921,3 @@ #define PIN_PE7__TIOA4 PINMUX_PIN(PIN_PE7, 3, 3) #define PIN_PE7__ISC_D11 PINMUX_PIN(PIN_PE7, 5, 2) #define PIN_PE7__G1_TSUCOMP PINMUX_PIN(PIN_PE7, 7, 1) - diff --git a/arch/arm/include/asm/arch-imxrt/imxrt.h b/arch/arm/include/asm/arch-imxrt/imxrt.h index 1cb2c57d31..14f7c769b0 100644 --- a/arch/arm/include/asm/arch-imxrt/imxrt.h +++ b/arch/arm/include/asm/arch-imxrt/imxrt.h @@ -8,4 +8,3 @@ #define _ASM_ARCH_IMXRT_H
#endif /* _ASM_ARCH_IMXRT_H */ - diff --git a/arch/arm/include/asm/arch-rockchip/f_rockusb.h b/arch/arm/include/asm/arch-rockchip/f_rockusb.h index 9772321023..e9c7f79339 100644 --- a/arch/arm/include/asm/arch-rockchip/f_rockusb.h +++ b/arch/arm/include/asm/arch-rockchip/f_rockusb.h @@ -133,4 +133,3 @@ struct f_rockusb { /* init rockusb device, tell rockusb which device you want to read/write*/ void rockusb_dev_init(char *dev_type, int dev_index); #endif /* _F_ROCKUSB_H_ */ - diff --git a/arch/arm/include/asm/arch-stm32/stm32f.h b/arch/arm/include/asm/arch-stm32/stm32f.h index a1ce81ecad..e795d81169 100644 --- a/arch/arm/include/asm/arch-stm32/stm32f.h +++ b/arch/arm/include/asm/arch-stm32/stm32f.h @@ -18,4 +18,3 @@ void stm32_flash_latency_cfg(int latency);
#endif /* _ASM_ARCH_STM32F_H */ - diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_defs.h b/arch/arm/include/asm/arch-stv0991/stv0991_defs.h index 97d28b26f1..98d7cde85b 100644 --- a/arch/arm/include/asm/arch-stv0991/stv0991_defs.h +++ b/arch/arm/include/asm/arch-stv0991/stv0991_defs.h @@ -12,4 +12,3 @@ extern int stv0991_pinmux_config(enum periph_id); extern int clock_setup(enum periph_clock);
#endif - diff --git a/arch/arm/include/asm/xen.h b/arch/arm/include/asm/xen.h index 8e2ee3d64e..670d5ad4a5 100644 --- a/arch/arm/include/asm/xen.h +++ b/arch/arm/include/asm/xen.h @@ -4,4 +4,3 @@ */
extern unsigned long rom_pointer[]; - diff --git a/arch/arm/lib/ccn504.S b/arch/arm/lib/ccn504.S index 2c584095c3..f2245872fc 100644 --- a/arch/arm/lib/ccn504.S +++ b/arch/arm/lib/ccn504.S @@ -78,4 +78,3 @@ ENTRY(ccn504_set_aux)
ret ENDPROC(ccn504_set_aux) - diff --git a/arch/arm/mach-at91/armv7/sama7g5_devices.c b/arch/arm/mach-at91/armv7/sama7g5_devices.c index a58f671f72..0b702c7fb7 100644 --- a/arch/arm/mach-at91/armv7/sama7g5_devices.c +++ b/arch/arm/mach-at91/armv7/sama7g5_devices.c @@ -8,4 +8,3 @@ char *get_cpu_name(void) { return "SAMA7G5"; } - diff --git a/arch/arm/mach-at91/atmel_sfr.c b/arch/arm/mach-at91/atmel_sfr.c index b14222460f..62108d2bd0 100644 --- a/arch/arm/mach-at91/atmel_sfr.c +++ b/arch/arm/mach-at91/atmel_sfr.c @@ -39,4 +39,3 @@ void configure_ddrcfg_input_buffers(bool open) else writel(0, &sfr->ddrcfg); } - diff --git a/arch/arm/mach-bcm283x/msg.c b/arch/arm/mach-bcm283x/msg.c index 347aece3cd..e43d7d9b67 100644 --- a/arch/arm/mach-bcm283x/msg.c +++ b/arch/arm/mach-bcm283x/msg.c @@ -196,4 +196,3 @@ int bcm2711_notify_vl805_reset(void)
return 0; } - diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index fda25ba66a..9f649e4888 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -435,4 +435,3 @@ void reset_misc(void) #endif #endif } - diff --git a/arch/arm/mach-kirkwood/cpu.c b/arch/arm/mach-kirkwood/cpu.c index 3953aa9b9b..e9571298a8 100644 --- a/arch/arm/mach-kirkwood/cpu.c +++ b/arch/arm/mach-kirkwood/cpu.c @@ -278,4 +278,3 @@ int cpu_eth_init(struct bd_info *bis) return 0; } #endif - diff --git a/arch/arm/mach-octeontx/Makefile b/arch/arm/mach-octeontx/Makefile index 20cb48ad92..8706becd0f 100644 --- a/arch/arm/mach-octeontx/Makefile +++ b/arch/arm/mach-octeontx/Makefile @@ -6,4 +6,3 @@ # */
obj-y += lowlevel_init.o clock.o cpu.o - diff --git a/arch/arm/mach-octeontx2/Makefile b/arch/arm/mach-octeontx2/Makefile index c3192343dd..b3073a84b1 100644 --- a/arch/arm/mach-octeontx2/Makefile +++ b/arch/arm/mach-octeontx2/Makefile @@ -6,4 +6,3 @@ # */
obj-y += lowlevel_init.o clock.o cpu.o - diff --git a/arch/arm/mach-omap2/pipe3-phy.c b/arch/arm/mach-omap2/pipe3-phy.c index 35ec81d314..3dfb184c43 100644 --- a/arch/arm/mach-omap2/pipe3-phy.c +++ b/arch/arm/mach-omap2/pipe3-phy.c @@ -229,4 +229,3 @@ int phy_pipe3_power_off(struct omap_pipe3 *phy)
return 0; } - diff --git a/arch/arm/mach-snapdragon/dram.c b/arch/arm/mach-snapdragon/dram.c index 2a161be137..499dfdf0da 100644 --- a/arch/arm/mach-snapdragon/dram.c +++ b/arch/arm/mach-snapdragon/dram.c @@ -97,4 +97,3 @@ int msm_fixup_memory(void *blob)
return 0; } - diff --git a/arch/arm/mach-tegra/tegra20/display.c b/arch/arm/mach-tegra/tegra20/display.c index 869db285a4..4ba3fb23fd 100644 --- a/arch/arm/mach-tegra/tegra20/display.c +++ b/arch/arm/mach-tegra/tegra20/display.c @@ -12,4 +12,3 @@ #include <asm/arch-tegra/dc.h> #include <asm/arch-tegra/clk_rst.h> #include <asm/arch-tegra/timer.h> - diff --git a/arch/arm/mach-versatile/timer.c b/arch/arm/mach-versatile/timer.c index a0babce7ba..739cb2997a 100644 --- a/arch/arm/mach-versatile/timer.c +++ b/arch/arm/mach-versatile/timer.c @@ -60,4 +60,3 @@ int timer_init (void)
return 0; } - diff --git a/arch/m68k/cpu/mcf530x/Makefile b/arch/m68k/cpu/mcf530x/Makefile index b34cb3c78c..6bd7cd3591 100644 --- a/arch/m68k/cpu/mcf530x/Makefile +++ b/arch/m68k/cpu/mcf530x/Makefile @@ -4,4 +4,3 @@
extra-y = start.o obj-y = interrupts.o cpu.o speed.o cpu_init.o - diff --git a/arch/m68k/include/asm/immap_5307.h b/arch/m68k/include/asm/immap_5307.h index e041e7e0af..930e0899e8 100644 --- a/arch/m68k/include/asm/immap_5307.h +++ b/arch/m68k/include/asm/immap_5307.h @@ -114,4 +114,3 @@ typedef struct gpio { } gpio_t;
#endif /* __IMMAP_5307__ */ - diff --git a/arch/m68k/include/asm/m5307.h b/arch/m68k/include/asm/m5307.h index f96e6ca29d..67547d2dd9 100644 --- a/arch/m68k/include/asm/m5307.h +++ b/arch/m68k/include/asm/m5307.h @@ -66,4 +66,3 @@ #define MCFSIM_ICR_PRI3 0x03 /* Priority 3 intr */
#endif /* mcf5307_h */ - diff --git a/arch/mips/mach-jz47xx/include/mach/jz4780_dram.h b/arch/mips/mach-jz47xx/include/mach/jz4780_dram.h index 61cc148988..2c0d30a80e 100644 --- a/arch/mips/mach-jz47xx/include/mach/jz4780_dram.h +++ b/arch/mips/mach-jz47xx/include/mach/jz4780_dram.h @@ -454,4 +454,3 @@ void pll_init(void); void sdram_init(void);
#endif /* __JZ4780_DRAM_H__ */ - diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c b/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c index 5bf0047930..da8e0b6555 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c @@ -399,4 +399,3 @@ const char *serdes_clock_to_string(u32 clock) #endif } } - diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c index f5126e2c8a..2b4912bea0 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c @@ -885,4 +885,3 @@ const char *serdes_clock_to_string(u32 clock) return "150"; } } - diff --git a/arch/powerpc/lib/ppccache.S b/arch/powerpc/lib/ppccache.S index dcef1ffcaf..e55025181f 100644 --- a/arch/powerpc/lib/ppccache.S +++ b/arch/powerpc/lib/ppccache.S @@ -104,4 +104,3 @@ _GLOBAL(invalidate_dcache_range) sync /* wait for dcbi's to get to ram */ #endif blr - diff --git a/arch/sh/lib/time.c b/arch/sh/lib/time.c index f951544728..366500d90b 100644 --- a/arch/sh/lib/time.c +++ b/arch/sh/lib/time.c @@ -32,4 +32,3 @@ int timer_init(void)
return 0; } - diff --git a/arch/xtensa/include/asm/arch-dc232b/core.h b/arch/xtensa/include/asm/arch-dc232b/core.h index c50a358c52..92ea0dfe35 100644 --- a/arch/xtensa/include/asm/arch-dc232b/core.h +++ b/arch/xtensa/include/asm/arch-dc232b/core.h @@ -419,4 +419,3 @@
#endif /* _XTENSA_CORE_CONFIGURATION_H */ - diff --git a/arch/xtensa/include/asm/arch-dc232b/tie-asm.h b/arch/xtensa/include/asm/arch-dc232b/tie-asm.h index 05ce1107f5..7003cad40d 100644 --- a/arch/xtensa/include/asm/arch-dc232b/tie-asm.h +++ b/arch/xtensa/include/asm/arch-dc232b/tie-asm.h @@ -117,4 +117,3 @@ #define XCHAL_SA_NUM_ATMPS 2
#endif /*_XTENSA_CORE_TIE_ASM_H*/ - diff --git a/arch/xtensa/include/asm/arch-dc232b/tie.h b/arch/xtensa/include/asm/arch-dc232b/tie.h index 2e70311d3e..4f8b50cd6c 100644 --- a/arch/xtensa/include/asm/arch-dc232b/tie.h +++ b/arch/xtensa/include/asm/arch-dc232b/tie.h @@ -126,4 +126,3 @@ #define XCHAL_OP0_FORMAT_LENGTHS 3,3,3,3,3,3,3,3,2,2,2,2,2,2,3,3
#endif /*_XTENSA_CORE_TIE_H*/ - diff --git a/arch/xtensa/include/asm/arch-dc233c/core.h b/arch/xtensa/include/asm/arch-dc233c/core.h index 8a7345559c..ca07d8ee21 100644 --- a/arch/xtensa/include/asm/arch-dc233c/core.h +++ b/arch/xtensa/include/asm/arch-dc233c/core.h @@ -450,4 +450,3 @@
#endif /* _XTENSA_CORE_CONFIGURATION_H */ - diff --git a/arch/xtensa/include/asm/arch-dc233c/tie-asm.h b/arch/xtensa/include/asm/arch-dc233c/tie-asm.h index 53a1e42a74..317d4e1312 100644 --- a/arch/xtensa/include/asm/arch-dc233c/tie-asm.h +++ b/arch/xtensa/include/asm/arch-dc233c/tie-asm.h @@ -169,4 +169,3 @@ #define XCHAL_SA_NUM_ATMPS 1
#endif /*_XTENSA_CORE_TIE_ASM_H*/ - diff --git a/arch/xtensa/include/asm/arch-dc233c/tie.h b/arch/xtensa/include/asm/arch-dc233c/tie.h index ddee4ad3f6..2c2a8493cd 100644 --- a/arch/xtensa/include/asm/arch-dc233c/tie.h +++ b/arch/xtensa/include/asm/arch-dc233c/tie.h @@ -126,4 +126,3 @@ #define XCHAL_OP0_FORMAT_LENGTHS 3,3,3,3,3,3,3,3,2,2,2,2,2,2,3,3
#endif /*_XTENSA_CORE_TIE_H*/ - diff --git a/arch/xtensa/include/asm/arch-de212/core.h b/arch/xtensa/include/asm/arch-de212/core.h index 7e94339e6d..7268692d0e 100644 --- a/arch/xtensa/include/asm/arch-de212/core.h +++ b/arch/xtensa/include/asm/arch-de212/core.h @@ -569,4 +569,3 @@
#endif /* _XTENSA_CORE_CONFIGURATION_H */ - diff --git a/arch/xtensa/include/asm/arch-de212/tie-asm.h b/arch/xtensa/include/asm/arch-de212/tie-asm.h index 988aa2ba57..3192ac82ad 100644 --- a/arch/xtensa/include/asm/arch-de212/tie-asm.h +++ b/arch/xtensa/include/asm/arch-de212/tie-asm.h @@ -146,4 +146,3 @@ #define XCHAL_SA_NUM_ATMPS 1
#endif /*_XTENSA_CORE_TIE_ASM_H*/ - diff --git a/arch/xtensa/include/asm/arch-de212/tie.h b/arch/xtensa/include/asm/arch-de212/tie.h index 2f36493d88..865c41c128 100644 --- a/arch/xtensa/include/asm/arch-de212/tie.h +++ b/arch/xtensa/include/asm/arch-de212/tie.h @@ -112,4 +112,3 @@ 3,3,3,3,3,3,3,3,2,2,2,2,2,2,3,3, 3,3,3,3,3,3,3,3,2,2,2,2,2,2,3,3
#endif /*_XTENSA_CORE_TIE_H*/ - diff --git a/arch/xtensa/include/asm/regs.h b/arch/xtensa/include/asm/regs.h index 32b50f9511..52d6e8cc01 100644 --- a/arch/xtensa/include/asm/regs.h +++ b/arch/xtensa/include/asm/regs.h @@ -91,4 +91,3 @@ #define DEBUGCAUSE_ICOUNT_BIT 0 /* ICOUNT would incr. to zero */
#endif /* _XTENSA_SPECREG_H */ - diff --git a/arch/xtensa/lib/bootm.c b/arch/xtensa/lib/bootm.c index bb1e2886ab..49ec0c218e 100644 --- a/arch/xtensa/lib/bootm.c +++ b/arch/xtensa/lib/bootm.c @@ -196,4 +196,3 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images)
return 1; } - diff --git a/arch/xtensa/lib/relocate.c b/arch/xtensa/lib/relocate.c index 91141f581e..3dc8edc801 100644 --- a/arch/xtensa/lib/relocate.c +++ b/arch/xtensa/lib/relocate.c @@ -14,4 +14,3 @@ int clear_bss(void) memset((void *)&__bss_start, 0x00, len); return 0; } - diff --git a/board/Marvell/octeontx/smc.c b/board/Marvell/octeontx/smc.c index 5eeba2358b..8df32049bd 100644 --- a/board/Marvell/octeontx/smc.c +++ b/board/Marvell/octeontx/smc.c @@ -22,4 +22,3 @@ ssize_t smc_dram_size(unsigned int node)
return regs.regs[0]; } - diff --git a/board/Marvell/octeontx2/soc-utils.c b/board/Marvell/octeontx2/soc-utils.c index 1cba7fb596..43a19a9071 100644 --- a/board/Marvell/octeontx2/soc-utils.c +++ b/board/Marvell/octeontx2/soc-utils.c @@ -46,4 +46,3 @@ const char *read_board_name(void) { return fdt_get_board_model(); } - diff --git a/board/atmark-techno/armadillo-800eva/Makefile b/board/atmark-techno/armadillo-800eva/Makefile index 87e8ca5e6a..7e01cb6794 100644 --- a/board/atmark-techno/armadillo-800eva/Makefile +++ b/board/atmark-techno/armadillo-800eva/Makefile @@ -3,4 +3,3 @@ # Copyright (C) 2012 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com
obj-y += armadillo-800eva.o - diff --git a/board/atmel/sama7g5ek/sama7g5ek.c b/board/atmel/sama7g5ek/sama7g5ek.c index 4df43d81f8..411b31160b 100644 --- a/board/atmel/sama7g5ek/sama7g5ek.c +++ b/board/atmel/sama7g5ek/sama7g5ek.c @@ -74,4 +74,3 @@ int dram_init(void) CONFIG_SYS_SDRAM_SIZE); return 0; } - diff --git a/board/beacon/imx8mn/README b/board/beacon/imx8mn/README index d3c90d31dd..a9eddd4e64 100644 --- a/board/beacon/imx8mn/README +++ b/board/beacon/imx8mn/README @@ -36,4 +36,3 @@ Boot ==== Set baseboard DIP switch: S17: 1100XXXX - diff --git a/board/beacon/imx8mn/lpddr4_timing.c b/board/beacon/imx8mn/lpddr4_timing.c index 3c1ad392f1..112e892f51 100644 --- a/board/beacon/imx8mn/lpddr4_timing.c +++ b/board/beacon/imx8mn/lpddr4_timing.c @@ -1431,4 +1431,3 @@ struct dram_timing_info dram_timing = { .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), .fsp_table = { 3200, 400, 100, }, }; - diff --git a/board/boundary/nitrogen6x/README.mx6qsabrelite b/board/boundary/nitrogen6x/README.mx6qsabrelite index 6283c9575e..828eea216e 100644 --- a/board/boundary/nitrogen6x/README.mx6qsabrelite +++ b/board/boundary/nitrogen6x/README.mx6qsabrelite @@ -116,4 +116,3 @@ Note: This will upload and run the U-Boot image in memory, the SPI will not be 5. Use one of previous descriptions to re-flash the SPI-NOR as required.
6. Ensure SW1 is returned to "00" to boot from the fuses once done. - diff --git a/board/cadence/xtfpga/README b/board/cadence/xtfpga/README index 5f29e2592f..889da9e77d 100644 --- a/board/cadence/xtfpga/README +++ b/board/cadence/xtfpga/README @@ -122,4 +122,3 @@ variable to make. Because this problem is easy to fall into and difficult to debug if one doesn't expect it, the linker script provides a link-time check and fatal error message if the image size exceeds 128 KB. - diff --git a/board/compulab/cm_t43/spl.c b/board/compulab/cm_t43/spl.c index 016c63a509..f277840f99 100644 --- a/board/compulab/cm_t43/spl.c +++ b/board/compulab/cm_t43/spl.c @@ -133,4 +133,3 @@ void sdram_init(void)
hang(); } - diff --git a/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.1_2.c b/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.1_2.c index 870a94aecc..9019a1f203 100644 --- a/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.1_2.c +++ b/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.1_2.c @@ -1845,4 +1845,3 @@ struct dram_timing_info ucm_dram_timing_01061010 = { .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), .fsp_table = { 2400, 400, 100, }, }; - diff --git a/board/freescale/common/zm7300.c b/board/freescale/common/zm7300.c index 03679e723f..e8c2fc85c8 100644 --- a/board/freescale/common/zm7300.c +++ b/board/freescale/common/zm7300.c @@ -230,4 +230,3 @@ int zm_enable_wp() } return 0; } - diff --git a/board/freescale/imx8mn_evk/ddr4_timing.c b/board/freescale/imx8mn_evk/ddr4_timing.c index f1509e2159..77611ea026 100644 --- a/board/freescale/imx8mn_evk/ddr4_timing.c +++ b/board/freescale/imx8mn_evk/ddr4_timing.c @@ -1052,4 +1052,3 @@ struct dram_timing_info dram_timing = { .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), .fsp_table = { 2400, 1066, }, }; - diff --git a/board/freescale/imx8mn_evk/ddr4_timing_ld.c b/board/freescale/imx8mn_evk/ddr4_timing_ld.c index 983fc7d99f..a3577efd0b 100644 --- a/board/freescale/imx8mn_evk/ddr4_timing_ld.c +++ b/board/freescale/imx8mn_evk/ddr4_timing_ld.c @@ -1054,4 +1054,3 @@ struct dram_timing_info dram_timing = { .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), .fsp_table = { 1600, 1066, }, }; - diff --git a/board/freescale/ls2080aqds/README b/board/freescale/ls2080aqds/README index 8e31e9e41e..cc0907607f 100644 --- a/board/freescale/ls2080aqds/README +++ b/board/freescale/ls2080aqds/README @@ -213,4 +213,3 @@ DPMAC13 -> PHY4-P0 DPMAC14 -> PHY4-P1 DPMAC15 -> PHY4-P2 DPMAC16 -> PHY4-P3 - diff --git a/board/freescale/ls2080ardb/README b/board/freescale/ls2080ardb/README index 205c45cb2a..afb84116ff 100644 --- a/board/freescale/ls2080ardb/README +++ b/board/freescale/ls2080ardb/README @@ -132,4 +132,3 @@ below: => setenv bootargs 'console=ttyS1,115200 root=/dev/ram earlycon=uart8250,mmio,0x21c0600,115200 default_hugepagesz=2m hugepagesz=2m hugepages=16 mem=2048M' - diff --git a/board/freescale/mx6memcal/mx6memcal.c b/board/freescale/mx6memcal/mx6memcal.c index 1cc744fa9b..0dfd7dec9e 100644 --- a/board/freescale/mx6memcal/mx6memcal.c +++ b/board/freescale/mx6memcal/mx6memcal.c @@ -30,4 +30,3 @@ int dram_init(void) gd->ram_size = imx_ddr_size(); return 0; } - diff --git a/board/freescale/t4rdb/cpld.h b/board/freescale/t4rdb/cpld.h index dc3f9f3c26..fcac9244c8 100644 --- a/board/freescale/t4rdb/cpld.h +++ b/board/freescale/t4rdb/cpld.h @@ -45,4 +45,3 @@ void cpld_write(unsigned int reg, u8 value); #define CPLD_READ(reg) cpld_read(offsetof(struct cpld_data, reg)) #define CPLD_WRITE(reg, value) \ cpld_write(offsetof(struct cpld_data, reg), value) - diff --git a/board/gateworks/gw_ventana/Makefile b/board/gateworks/gw_ventana/Makefile index 8fa691aefc..360d1d4c12 100644 --- a/board/gateworks/gw_ventana/Makefile +++ b/board/gateworks/gw_ventana/Makefile @@ -8,4 +8,3 @@
obj-y := gw_ventana.o gsc.o eeprom.o common.o obj-$(CONFIG_SPL_BUILD) += gw_ventana_spl.o - diff --git a/board/gateworks/gw_ventana/gsc.h b/board/gateworks/gw_ventana/gsc.h index 29d375b3a7..5c34988828 100644 --- a/board/gateworks/gw_ventana/gsc.h +++ b/board/gateworks/gw_ventana/gsc.h @@ -69,4 +69,3 @@ int gsc_info(int verbose); int gsc_boot_wd_disable(void); const char *gsc_get_dtb_name(int level, char *buf, int sz); #endif - diff --git a/board/gdsys/a38x/dt_helpers.c b/board/gdsys/a38x/dt_helpers.c index c859024a28..61d30c2e63 100644 --- a/board/gdsys/a38x/dt_helpers.c +++ b/board/gdsys/a38x/dt_helpers.c @@ -39,4 +39,3 @@ int request_gpio_by_name(struct gpio_desc *gpio, const char *gpio_dev_name,
return dm_gpio_request(gpio, gpio_name); } - diff --git a/board/ge/common/ge_rtc.c b/board/ge/common/ge_rtc.c index 48c3778046..6437afc7bd 100644 --- a/board/ge/common/ge_rtc.c +++ b/board/ge/common/ge_rtc.c @@ -53,4 +53,3 @@ void check_time(void) else env_set("rtc_status", "OK"); } - diff --git a/board/ge/mx53ppd/mx53ppd_video.c b/board/ge/mx53ppd/mx53ppd_video.c index 3240ed62ae..4e2c6ebde7 100644 --- a/board/ge/mx53ppd/mx53ppd_video.c +++ b/board/ge/mx53ppd/mx53ppd_video.c @@ -92,4 +92,3 @@ struct display_info_t const displays[] = { };
size_t display_count = ARRAY_SIZE(displays); - diff --git a/board/hisilicon/poplar/poplar.c b/board/hisilicon/poplar/poplar.c index 6cc79d96a1..b89e7e8697 100644 --- a/board/hisilicon/poplar/poplar.c +++ b/board/hisilicon/poplar/poplar.c @@ -195,4 +195,3 @@ int board_init(void)
return 0; } - diff --git a/board/keymile/common/qrio.c b/board/keymile/common/qrio.c index 25937ee362..da516918af 100644 --- a/board/keymile/common/qrio.c +++ b/board/keymile/common/qrio.c @@ -290,4 +290,3 @@ int get_scl(void) return qrio_get_gpio(KM_I2C_DEBLOCK_PORT, KM_I2C_DEBLOCK_SCL); } - diff --git a/board/logicpd/imx6/Makefile b/board/logicpd/imx6/Makefile index 337df9247d..dbaf18d3e0 100644 --- a/board/logicpd/imx6/Makefile +++ b/board/logicpd/imx6/Makefile @@ -7,4 +7,3 @@ #
obj-y := imx6logic.o - diff --git a/board/logicpd/imx6/README b/board/logicpd/imx6/README index 19f79c5734..9d7b9128c4 100644 --- a/board/logicpd/imx6/README +++ b/board/logicpd/imx6/README @@ -80,4 +80,3 @@ while starting.
Additional Support Documentation can be found at: https://support.logicpd.com/ - diff --git a/board/mediatek/mt7622/Makefile b/board/mediatek/mt7622/Makefile index 2c54d86fff..64f101337b 100644 --- a/board/mediatek/mt7622/Makefile +++ b/board/mediatek/mt7622/Makefile @@ -1,4 +1,3 @@ # SPDX-License-Identifier: GPL-2.0
obj-y += mt7622_rfb.o - diff --git a/board/mqmaker/miqi_rk3288/miqi-rk3288.c b/board/mqmaker/miqi_rk3288/miqi-rk3288.c index 779bc646b2..1649bee063 100644 --- a/board/mqmaker/miqi_rk3288/miqi-rk3288.c +++ b/board/mqmaker/miqi_rk3288/miqi-rk3288.c @@ -2,4 +2,3 @@ /* * (C) Copyright 2016 Rockchip Electronics Co., Ltd */ - diff --git a/board/mscc/jr2/Makefile b/board/mscc/jr2/Makefile index c1db2a9045..56fd8d913e 100644 --- a/board/mscc/jr2/Makefile +++ b/board/mscc/jr2/Makefile @@ -1,4 +1,3 @@ # SPDX-License-Identifier: (GPL-2.0+ OR MIT)
obj-$(CONFIG_SOC_JR2) := jr2.o - diff --git a/board/mscc/ocelot/Makefile b/board/mscc/ocelot/Makefile index 9f28c81268..39ce9601b9 100644 --- a/board/mscc/ocelot/Makefile +++ b/board/mscc/ocelot/Makefile @@ -1,4 +1,3 @@ # SPDX-License-Identifier: (GPL-2.0+ OR MIT)
obj-$(CONFIG_SOC_OCELOT) := ocelot.o - diff --git a/board/opalkelly/zynq/zynq-syzygy-hub/ps7_init_gpl.c b/board/opalkelly/zynq/zynq-syzygy-hub/ps7_init_gpl.c index 80f2b83b58..0cbfc08183 100644 --- a/board/opalkelly/zynq/zynq-syzygy-hub/ps7_init_gpl.c +++ b/board/opalkelly/zynq/zynq-syzygy-hub/ps7_init_gpl.c @@ -289,4 +289,3 @@ int ps7_init(void) return ret; return PS7_INIT_SUCCESS; } - diff --git a/board/phytium/durian/Makefile b/board/phytium/durian/Makefile index c2fbf19838..8637ba4afc 100644 --- a/board/phytium/durian/Makefile +++ b/board/phytium/durian/Makefile @@ -6,4 +6,3 @@ #
obj-y += durian.o - diff --git a/board/phytium/durian/cpu.h b/board/phytium/durian/cpu.h index a5a213d30c..696731ede1 100644 --- a/board/phytium/durian/cpu.h +++ b/board/phytium/durian/cpu.h @@ -20,4 +20,3 @@ #define HNF_BASE (unsigned long)(0x3A200000)
#endif /* _FT_DURIAN_H */ - diff --git a/board/phytium/durian/durian.c b/board/phytium/durian/durian.c index ef13f7cff4..ee484749bc 100644 --- a/board/phytium/durian/durian.c +++ b/board/phytium/durian/durian.c @@ -113,4 +113,3 @@ int last_stage_init(void) } return ret; } - diff --git a/board/rockchip/evb_rk3229/evb_rk3229.c b/board/rockchip/evb_rk3229/evb_rk3229.c index c64c62f7b0..0b14b241b3 100644 --- a/board/rockchip/evb_rk3229/evb_rk3229.c +++ b/board/rockchip/evb_rk3229/evb_rk3229.c @@ -7,4 +7,3 @@ #include <dm.h> #include <asm/io.h> #include <asm/arch-rockchip/uart.h> - diff --git a/board/rockchip/evb_rk3288/evb-rk3288.c b/board/rockchip/evb_rk3288/evb-rk3288.c index 779bc646b2..1649bee063 100644 --- a/board/rockchip/evb_rk3288/evb-rk3288.c +++ b/board/rockchip/evb_rk3288/evb-rk3288.c @@ -2,4 +2,3 @@ /* * (C) Copyright 2016 Rockchip Electronics Co., Ltd */ - diff --git a/board/rockchip/evb_rk3328/evb-rk3328.c b/board/rockchip/evb_rk3328/evb-rk3328.c index 779bc646b2..1649bee063 100644 --- a/board/rockchip/evb_rk3328/evb-rk3328.c +++ b/board/rockchip/evb_rk3328/evb-rk3328.c @@ -2,4 +2,3 @@ /* * (C) Copyright 2016 Rockchip Electronics Co., Ltd */ - diff --git a/board/synopsys/axs10x/axs10x.h b/board/synopsys/axs10x/axs10x.h index 69541cc578..db5f062874 100644 --- a/board/synopsys/axs10x/axs10x.h +++ b/board/synopsys/axs10x/axs10x.h @@ -12,4 +12,3 @@ enum { };
#endif /* _BOARD_SYNOPSYS_AXS10X_H */ - diff --git a/board/technexion/pico-imx7d/pico-imx7d.c b/board/technexion/pico-imx7d/pico-imx7d.c index 2d749dac19..5c9470309a 100644 --- a/board/technexion/pico-imx7d/pico-imx7d.c +++ b/board/technexion/pico-imx7d/pico-imx7d.c @@ -244,4 +244,3 @@ int board_ehci_hcd_init(int port) } return 0; } - diff --git a/board/technexion/pico-imx8mq/lpddr4_timing_1gb.c b/board/technexion/pico-imx8mq/lpddr4_timing_1gb.c index bcb852668c..97b9ee2752 100644 --- a/board/technexion/pico-imx8mq/lpddr4_timing_1gb.c +++ b/board/technexion/pico-imx8mq/lpddr4_timing_1gb.c @@ -1731,4 +1731,3 @@ struct dram_timing_info dram_timing_1gb = { .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), .fsp_table = { 3200, 667, }, }; - diff --git a/board/technexion/pico-imx8mq/lpddr4_timing_2gb.c b/board/technexion/pico-imx8mq/lpddr4_timing_2gb.c index 9a8a323d63..1572a50a05 100644 --- a/board/technexion/pico-imx8mq/lpddr4_timing_2gb.c +++ b/board/technexion/pico-imx8mq/lpddr4_timing_2gb.c @@ -1731,4 +1731,3 @@ struct dram_timing_info dram_timing_2gb = { .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), .fsp_table = { 3200, 667, }, }; - diff --git a/board/technexion/pico-imx8mq/lpddr4_timing_3gb.c b/board/technexion/pico-imx8mq/lpddr4_timing_3gb.c index 0f74ce581c..3fc60a3eeb 100644 --- a/board/technexion/pico-imx8mq/lpddr4_timing_3gb.c +++ b/board/technexion/pico-imx8mq/lpddr4_timing_3gb.c @@ -1731,4 +1731,3 @@ struct dram_timing_info dram_timing_3gb = { .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), .fsp_table = { 3200, 667, }, }; - diff --git a/board/technexion/pico-imx8mq/lpddr4_timing_4gb.c b/board/technexion/pico-imx8mq/lpddr4_timing_4gb.c index b1d1c5223e..93b3423516 100644 --- a/board/technexion/pico-imx8mq/lpddr4_timing_4gb.c +++ b/board/technexion/pico-imx8mq/lpddr4_timing_4gb.c @@ -1731,4 +1731,3 @@ struct dram_timing_info dram_timing_4gb = { .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), .fsp_table = { 3200, 667, }, }; - diff --git a/board/terasic/de0-nano-soc/qts/pll_config.h b/board/terasic/de0-nano-soc/qts/pll_config.h index 68dc3bc279..e439336d45 100644 --- a/board/terasic/de0-nano-soc/qts/pll_config.h +++ b/board/terasic/de0-nano-soc/qts/pll_config.h @@ -81,4 +81,3 @@ #define CONFIG_HPS_ALTERAGRP_DBGATCLK 4
#endif /* _PRELOADER_PLL_CONFIG_H_ */ - diff --git a/board/xen/xenguest_arm64/xenguest_arm64.c b/board/xen/xenguest_arm64/xenguest_arm64.c index 21363d878f..da0ddeefff 100644 --- a/board/xen/xenguest_arm64/xenguest_arm64.c +++ b/board/xen/xenguest_arm64/xenguest_arm64.c @@ -195,4 +195,3 @@ void board_cleanup_before_linux(void) { xen_fini(); } - diff --git a/board/xilinx/versal/cmds.c b/board/xilinx/versal/cmds.c index 04d4cdb141..797c1a5d68 100644 --- a/board/xilinx/versal/cmds.c +++ b/board/xilinx/versal/cmds.c @@ -102,4 +102,3 @@ U_BOOT_CMD(versal, 4, 1, do_versal, "versal sub-system", versal_help_text ) - diff --git a/board/xilinx/zynq/zynq-microzed/ps7_init_gpl.c b/board/xilinx/zynq/zynq-microzed/ps7_init_gpl.c index 337af2d964..323835ab1b 100644 --- a/board/xilinx/zynq/zynq-microzed/ps7_init_gpl.c +++ b/board/xilinx/zynq/zynq-microzed/ps7_init_gpl.c @@ -12485,7 +12485,3 @@ ps7_init() //xil_printf ("\n PCW Silicon Version : %d.0", pcw_ver); return PS7_INIT_SUCCESS; } - - - - diff --git a/board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c b/board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c index c84ee6b1f2..cc90a4c94b 100644 --- a/board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c +++ b/board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c @@ -12725,7 +12725,3 @@ ps7_init() //xil_printf ("\n PCW Silicon Version : %d.0", pcw_ver); return PS7_INIT_SUCCESS; } - - - - diff --git a/board/xilinx/zynq/zynq-zed/ps7_init_gpl.c b/board/xilinx/zynq/zynq-zed/ps7_init_gpl.c index 7a15ea5729..8fb3908e02 100644 --- a/board/xilinx/zynq/zynq-zed/ps7_init_gpl.c +++ b/board/xilinx/zynq/zynq-zed/ps7_init_gpl.c @@ -12383,7 +12383,3 @@ ps7_init() //xil_printf ("\n PCW Silicon Version : %d.0", pcw_ver); return PS7_INIT_SUCCESS; } - - - - diff --git a/board/xilinx/zynq/zynq-zybo/ps7_init_gpl.c b/board/xilinx/zynq/zynq-zybo/ps7_init_gpl.c index fda6d18dd9..04d2e5f137 100644 --- a/board/xilinx/zynq/zynq-zybo/ps7_init_gpl.c +++ b/board/xilinx/zynq/zynq-zybo/ps7_init_gpl.c @@ -12565,4 +12565,3 @@ int ps7_init(void) return ret; return PS7_INIT_SUCCESS; } - diff --git a/cmd/pvblock.c b/cmd/pvblock.c index 4e99b06122..56ce8b18d5 100644 --- a/cmd/pvblock.c +++ b/cmd/pvblock.c @@ -27,4 +27,3 @@ U_BOOT_CMD(pvblock, 5, 1, do_pvblock, "pvblock write addr blk# cnt - read/write `cnt'" " blocks starting at block `blk#'\n" " to/from memory address `addr'"); - diff --git a/cmd/scp03.c b/cmd/scp03.c index 655e0bba08..216c942dd4 100644 --- a/cmd/scp03.c +++ b/cmd/scp03.c @@ -49,4 +49,3 @@ static char text[] = U_BOOT_CMD_WITH_SUBCMDS(scp03, "Secure Channel Protocol 03 control", text, U_BOOT_SUBCMD_MKENT(enable, 1, 1, do_scp03_enable), U_BOOT_SUBCMD_MKENT(provision, 1, 1, do_scp03_provision)); - diff --git a/cmd/smccc.c b/cmd/smccc.c index f527181772..0539a42587 100644 --- a/cmd/smccc.c +++ b/cmd/smccc.c @@ -69,4 +69,3 @@ U_BOOT_CMD( " - id Session ID, passed to W7 (defaults to zero)\n" ); #endif - diff --git a/common/lcd_console.c b/common/lcd_console.c index 9c0ff4480e..ed36c78440 100644 --- a/common/lcd_console.c +++ b/common/lcd_console.c @@ -258,4 +258,3 @@ U_BOOT_CMD( "print string on lcd-framebuffer", " <string>" ); - diff --git a/common/spl/spl_ram.c b/common/spl/spl_ram.c index df1d5b43d8..df9f3a4d00 100644 --- a/common/spl/spl_ram.c +++ b/common/spl/spl_ram.c @@ -81,5 +81,3 @@ SPL_LOAD_IMAGE_METHOD("RAM", 0, BOOT_DEVICE_RAM, spl_ram_load_image); #if CONFIG_IS_ENABLED(DFU) SPL_LOAD_IMAGE_METHOD("DFU", 0, BOOT_DEVICE_DFU, spl_ram_load_image); #endif - - diff --git a/doc/README.pcap b/doc/README.pcap index 97b3e55fd8..8e30b93c66 100644 --- a/doc/README.pcap +++ b/doc/README.pcap @@ -59,4 +59,3 @@ PCAP status:
# pcap stop # tftpput 0xffffffff80100000 $pcapsize 10.0.2.2:capture.pcap - diff --git a/doc/device-tree-bindings/mmc/snps,dw-mmc.txt b/doc/device-tree-bindings/mmc/snps,dw-mmc.txt index 69faefa95e..0c9e3ada5a 100644 --- a/doc/device-tree-bindings/mmc/snps,dw-mmc.txt +++ b/doc/device-tree-bindings/mmc/snps,dw-mmc.txt @@ -30,4 +30,3 @@ mmc0@f000a000 { clock-names = "biu", "ciu"; max-frequency = <25000000>; }; - diff --git a/doc/device-tree-bindings/net/mdio.txt b/doc/device-tree-bindings/net/mdio.txt index 1595325050..a7d8ac5b15 100644 --- a/doc/device-tree-bindings/net/mdio.txt +++ b/doc/device-tree-bindings/net/mdio.txt @@ -33,4 +33,3 @@ requires no compatible property for probing. reg = <2>; }; }; - diff --git a/doc/device-tree-bindings/w1-eeprom/ds24xxx.txt b/doc/device-tree-bindings/w1-eeprom/ds24xxx.txt index 2e91be93b7..3ad8d460f2 100644 --- a/doc/device-tree-bindings/w1-eeprom/ds24xxx.txt +++ b/doc/device-tree-bindings/w1-eeprom/ds24xxx.txt @@ -34,4 +34,3 @@ onewire_tm: onewire { compatible = "maxim,ds24xxx"; } }; - diff --git a/doc/device-tree-bindings/w1-eeprom/ds2502.txt b/doc/device-tree-bindings/w1-eeprom/ds2502.txt index 7f05fc432e..8788e57058 100644 --- a/doc/device-tree-bindings/w1-eeprom/ds2502.txt +++ b/doc/device-tree-bindings/w1-eeprom/ds2502.txt @@ -30,4 +30,3 @@ Example with parent bus: compatible = "maxim,ds2502"; }; }; - diff --git a/doc/device-tree-bindings/w1-eeprom/eep_sandbox.txt b/doc/device-tree-bindings/w1-eeprom/eep_sandbox.txt index 82bb5899af..ebf718c743 100644 --- a/doc/device-tree-bindings/w1-eeprom/eep_sandbox.txt +++ b/doc/device-tree-bindings/w1-eeprom/eep_sandbox.txt @@ -31,4 +31,3 @@ onewire_tm: onewire { compatible = "sandbox,w1-eeprom"; } }; - diff --git a/doc/device-tree-bindings/w1/w1-gpio.txt b/doc/device-tree-bindings/w1/w1-gpio.txt index 5a582448e4..2ba86d7d91 100644 --- a/doc/device-tree-bindings/w1/w1-gpio.txt +++ b/doc/device-tree-bindings/w1/w1-gpio.txt @@ -37,4 +37,3 @@ onewire_tm: onewire { compatible = "maxim,ds24xxx"; } }; - diff --git a/doc/mvebu/armada-8k-memory.txt b/doc/mvebu/armada-8k-memory.txt index 064518eb51..f554d71e99 100644 --- a/doc/mvebu/armada-8k-memory.txt +++ b/doc/mvebu/armada-8k-memory.txt @@ -53,4 +53,3 @@ Start End Use 0xFFF00000 0xFFFFFFFF Bootrom
0x100000000 <DRAM Size>-1 DRAM - diff --git a/doc/mvebu/cmd/bubt.txt b/doc/mvebu/cmd/bubt.txt index a539c15bcd..6051243f11 100644 --- a/doc/mvebu/cmd/bubt.txt +++ b/doc/mvebu/cmd/bubt.txt @@ -52,4 +52,3 @@ Notes: - NAND: # nand write <load_address> 0 <ATF Size> - SPI: # sf write <load_address> 0 <ATF Size> - SD/eMMC: # mmc write <load_address> [0|1] <ATF Size>/<block_size> - diff --git a/drivers/axi/axi-uclass.c b/drivers/axi/axi-uclass.c index afb4844ecb..41551ae85c 100644 --- a/drivers/axi/axi-uclass.c +++ b/drivers/axi/axi-uclass.c @@ -38,4 +38,3 @@ UCLASS_DRIVER(axi) = { .post_bind = dm_scan_fdt_dev, .flags = DM_UC_FLAG_SEQ_ALIAS, }; - diff --git a/drivers/clk/at91/clk-sam9x60-pll.c b/drivers/clk/at91/clk-sam9x60-pll.c index 1bfae5fd01..383f79cfba 100644 --- a/drivers/clk/at91/clk-sam9x60-pll.c +++ b/drivers/clk/at91/clk-sam9x60-pll.c @@ -439,4 +439,3 @@ U_BOOT_DRIVER(at91_sam9x60_frac_pll_clk) = { .ops = &sam9x60_frac_pll_ops, .flags = DM_FLAG_PRE_RELOC, }; - diff --git a/drivers/clk/meson/Makefile b/drivers/clk/meson/Makefile index 7204383e17..b9c6bd66cf 100644 --- a/drivers/clk/meson/Makefile +++ b/drivers/clk/meson/Makefile @@ -7,4 +7,3 @@ obj-$(CONFIG_CLK_MESON_GX) += gxbb.o obj-$(CONFIG_CLK_MESON_AXG) += axg.o obj-$(CONFIG_CLK_MESON_G12A) += g12a.o obj-$(CONFIG_CLK_MESON_G12A) += g12a-ao.o - diff --git a/drivers/clk/rockchip/clk_pll.c b/drivers/clk/rockchip/clk_pll.c index 83d45c75ee..8d2aaf5b84 100644 --- a/drivers/clk/rockchip/clk_pll.c +++ b/drivers/clk/rockchip/clk_pll.c @@ -359,4 +359,3 @@ rockchip_get_cpu_settings(struct rockchip_cpu_rate_table *cpu_table, else return ps; } - diff --git a/drivers/ddr/altera/sdram_s10.c b/drivers/ddr/altera/sdram_s10.c index 3caa2e14f9..d3a6d21860 100644 --- a/drivers/ddr/altera/sdram_s10.c +++ b/drivers/ddr/altera/sdram_s10.c @@ -335,4 +335,3 @@ int sdram_mmr_init_full(struct udevice *dev) debug("DDR: HMC init success\n"); return 0; } - diff --git a/drivers/ddr/marvell/a38x/ddr3_training.c b/drivers/ddr/marvell/a38x/ddr3_training.c index 2512b58cb7..0ddd5aea75 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training.c +++ b/drivers/ddr/marvell/a38x/ddr3_training.c @@ -2895,4 +2895,3 @@ unsigned int mv_ddr_misl_phy_odt_n_get(void)
return odt_n; } - diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index 685957626b..d73414d5ac 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -69,4 +69,3 @@ void fpgamgr_program_write(const void *rbf_data, size_t rbf_size) : "+r"(src), "+r"(dst), "+r"(loops32), "+r"(loops4) : : "r0", "r1", "r2", "r3", "r4", "r5", "r6", "r7", "cc"); } - diff --git a/drivers/gpio/hi6220_gpio.c b/drivers/gpio/hi6220_gpio.c index 04f8d904a2..608ad64f65 100644 --- a/drivers/gpio/hi6220_gpio.c +++ b/drivers/gpio/hi6220_gpio.c @@ -91,5 +91,3 @@ U_BOOT_DRIVER(gpio_hi6220) = { .probe = hi6220_gpio_probe, .priv_auto = sizeof(struct gpio_bank), }; - - diff --git a/drivers/misc/fsl_devdis.c b/drivers/misc/fsl_devdis.c index abd20b4d61..cfe03b40cd 100644 --- a/drivers/misc/fsl_devdis.c +++ b/drivers/misc/fsl_devdis.c @@ -25,4 +25,3 @@ void device_disable(const struct devdis_table *tbl, uint32_t num) tbl[i].mask); } } - diff --git a/drivers/mtd/nand/raw/mxs_nand_spl.c b/drivers/mtd/nand/raw/mxs_nand_spl.c index 17f46ae5e9..d16224a2e0 100644 --- a/drivers/mtd/nand/raw/mxs_nand_spl.c +++ b/drivers/mtd/nand/raw/mxs_nand_spl.c @@ -295,4 +295,3 @@ int nand_default_bbt(struct mtd_info *mtd) void nand_deselect(void) { } - diff --git a/drivers/net/fsl-mc/dpni.c b/drivers/net/fsl-mc/dpni.c index 443e430695..5290be20c8 100644 --- a/drivers/net/fsl-mc/dpni.c +++ b/drivers/net/fsl-mc/dpni.c @@ -525,4 +525,3 @@ int dpni_reset_statistics(struct fsl_mc_io *mc_io, /* send command to mc*/ return mc_send_command(mc_io, &cmd); } - diff --git a/drivers/net/mvmdio.c b/drivers/net/mvmdio.c index 96f8dc62b5..6fb8a985d0 100644 --- a/drivers/net/mvmdio.c +++ b/drivers/net/mvmdio.c @@ -234,4 +234,3 @@ U_BOOT_DRIVER(mvmdio) = { .ops = &mvmdio_ops, .priv_auto = sizeof(struct mvmdio_priv), }; - diff --git a/drivers/net/octeontx/nic_main.c b/drivers/net/octeontx/nic_main.c index 8f05d4e720..0f36f2586e 100644 --- a/drivers/net/octeontx/nic_main.c +++ b/drivers/net/octeontx/nic_main.c @@ -775,4 +775,3 @@ static struct pci_device_id octeontx_nic_supported[] = { };
U_BOOT_PCI_DEVICE(octeontx_nic, octeontx_nic_supported); - diff --git a/drivers/net/octeontx2/Makefile b/drivers/net/octeontx2/Makefile index c9300727ae..dc14efd132 100644 --- a/drivers/net/octeontx2/Makefile +++ b/drivers/net/octeontx2/Makefile @@ -5,4 +5,3 @@
obj-$(CONFIG_NET_OCTEONTX2) += cgx.o nix_af.o nix.o rvu_pf.o \ rvu_af.o rvu_common.o - diff --git a/drivers/net/octeontx2/nix.c b/drivers/net/octeontx2/nix.c index 039c44b654..5954737b5c 100644 --- a/drivers/net/octeontx2/nix.c +++ b/drivers/net/octeontx2/nix.c @@ -828,4 +828,3 @@ void nix_print_mac_info(struct udevice *dev) printf(" CGX%d LMAC%d [%s]", lmac->cgx->cgx_id, lmac->lmac_id, lmac_type_to_str[lmac->lmac_type]); } - diff --git a/drivers/net/octeontx2/npc.h b/drivers/net/octeontx2/npc.h index 6e645cd32e..a20a1ba067 100644 --- a/drivers/net/octeontx2/npc.h +++ b/drivers/net/octeontx2/npc.h @@ -87,4 +87,3 @@ struct npc { }
#endif /* __NPC_H__ */ - diff --git a/drivers/net/octeontx2/rvu.h b/drivers/net/octeontx2/rvu.h index f455260a6f..c0a834b89a 100644 --- a/drivers/net/octeontx2/rvu.h +++ b/drivers/net/octeontx2/rvu.h @@ -116,4 +116,3 @@ void rvu_aq_free(struct admin_queue *aq); void rvu_get_lfid_for_pf(int pf, int *nixid, int *npaid);
#endif /* __RVU_H__ */ - diff --git a/drivers/phy/marvell/comphy_core.h b/drivers/phy/marvell/comphy_core.h index ba64491dfe..9bbd7f8f35 100644 --- a/drivers/phy/marvell/comphy_core.h +++ b/drivers/phy/marvell/comphy_core.h @@ -141,4 +141,3 @@ void comphy_pcie_config_detect(u32 comphy_max_count, void comphy_pcie_unit_general_config(u32 pex_index);
#endif /* _COMPHY_CORE_H_ */ - diff --git a/drivers/phy/marvell/utmi_phy.h b/drivers/phy/marvell/utmi_phy.h index 8a570bae73..264d14b604 100644 --- a/drivers/phy/marvell/utmi_phy.h +++ b/drivers/phy/marvell/utmi_phy.h @@ -98,4 +98,3 @@ (0x3 << UTMI_CHGDTC_CTRL_VSRC_OFFSET)
#endif /* _UTMI_PHY_H_ */ - diff --git a/drivers/pinctrl/mediatek/pinctrl-mt7622.c b/drivers/pinctrl/mediatek/pinctrl-mt7622.c index b413a4c7e4..bf4e9a28e9 100644 --- a/drivers/pinctrl/mediatek/pinctrl-mt7622.c +++ b/drivers/pinctrl/mediatek/pinctrl-mt7622.c @@ -750,5 +750,3 @@ U_BOOT_DRIVER(mt7622_pinctrl) = { .probe = mtk_pinctrl_mt7622_probe, .priv_auto = sizeof(struct mtk_pinctrl_priv), }; - - diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index 9057ccacd9..d7492be6ec 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -852,4 +852,3 @@ U_BOOT_DRIVER(dmc_rk322x) = { .plat_auto = sizeof(struct rk322x_sdram_params), #endif }; - diff --git a/drivers/reset/reset-raspberrypi.c b/drivers/reset/reset-raspberrypi.c index e2d284e5ac..6a80179b82 100644 --- a/drivers/reset/reset-raspberrypi.c +++ b/drivers/reset/reset-raspberrypi.c @@ -57,4 +57,3 @@ U_BOOT_DRIVER(raspberrypi_reset) = { .of_match = raspberrypi_reset_ids, .ops = &raspberrypi_reset_ops, }; - diff --git a/drivers/serial/serial_sti_asc.c b/drivers/serial/serial_sti_asc.c index 2cada4efbf..40381b57b0 100644 --- a/drivers/serial/serial_sti_asc.c +++ b/drivers/serial/serial_sti_asc.c @@ -209,4 +209,3 @@ U_BOOT_DRIVER(serial_sti_asc) = { .probe = sti_asc_serial_probe, .priv_auto = sizeof(struct sti_asc_serial), }; - diff --git a/drivers/serial/serial_xen.c b/drivers/serial/serial_xen.c index e1d5b229bd..ab318b0646 100644 --- a/drivers/serial/serial_xen.c +++ b/drivers/serial/serial_xen.c @@ -180,4 +180,3 @@ U_BOOT_DRIVER(serial_xen) = { .flags = DM_FLAG_PRE_RELOC, #endif }; - diff --git a/drivers/timer/stm32_timer.c b/drivers/timer/stm32_timer.c index e34f5202fc..f07251e54c 100644 --- a/drivers/timer/stm32_timer.c +++ b/drivers/timer/stm32_timer.c @@ -135,4 +135,3 @@ U_BOOT_DRIVER(stm32_timer) = { .probe = stm32_timer_probe, .ops = &stm32_timer_ops, }; - diff --git a/drivers/usb/eth/r8152.c b/drivers/usb/eth/r8152.c index 4677da9f29..d21fc682b0 100644 --- a/drivers/usb/eth/r8152.c +++ b/drivers/usb/eth/r8152.c @@ -1894,4 +1894,3 @@ static const struct usb_device_id r8152_eth_id_table[] = {
U_BOOT_USB_DEVICE(r8152_eth, r8152_eth_id_table); #endif /* CONFIG_DM_ETH */ - diff --git a/drivers/usb/gadget/at91_udc.h b/drivers/usb/gadget/at91_udc.h index 668b8c4a7c..96a521ee08 100644 --- a/drivers/usb/gadget/at91_udc.h +++ b/drivers/usb/gadget/at91_udc.h @@ -164,4 +164,3 @@ struct at91_request { #define DBG(stuff...) debug("udc: " stuff)
#endif - diff --git a/drivers/video/rockchip/rk_mipi.c b/drivers/video/rockchip/rk_mipi.c index 8813220671..f14cbc6dbf 100644 --- a/drivers/video/rockchip/rk_mipi.c +++ b/drivers/video/rockchip/rk_mipi.c @@ -328,4 +328,3 @@ int rk_mipi_phy_enable(struct udevice *dev)
return 0; } - diff --git a/drivers/xen/events.c b/drivers/xen/events.c index c490f87b2f..5e90a65846 100644 --- a/drivers/xen/events.c +++ b/drivers/xen/events.c @@ -196,4 +196,3 @@ void fini_events(void) /* Dealloc all events */ unbind_all_ports(); } - diff --git a/drivers/xen/gnttab.c b/drivers/xen/gnttab.c index 778729d646..31e96e2939 100644 --- a/drivers/xen/gnttab.c +++ b/drivers/xen/gnttab.c @@ -215,4 +215,3 @@ void fini_gnttab(void) setup.dom = DOMID_SELF; setup.nr_frames = 0; } - diff --git a/include/configs/amcore.h b/include/configs/amcore.h index 641d8fdbd5..e73160579f 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -99,4 +99,3 @@ #define CONFIG_SYS_CS1_CTRL 0x0100
#endif /* __AMCORE_CONFIG_H */ - diff --git a/include/configs/broadcom_bcm963158.h b/include/configs/broadcom_bcm963158.h index 238ae9c010..6a49ed0d46 100644 --- a/include/configs/broadcom_bcm963158.h +++ b/include/configs/broadcom_bcm963158.h @@ -39,4 +39,3 @@ /* * bcm963158 */ - diff --git a/include/configs/broadcom_bcm968580xref.h b/include/configs/broadcom_bcm968580xref.h index febe6c0a04..5e7ba252e5 100644 --- a/include/configs/broadcom_bcm968580xref.h +++ b/include/configs/broadcom_bcm968580xref.h @@ -38,4 +38,3 @@ /* * 968580xref */ - diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 342cc7fddc..c3b40d4854 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -145,4 +145,3 @@ #endif /* CONFIG_SPL_BUILD */
#endif /* __CONFIG_CM_T335_H */ - diff --git a/include/configs/comtrend_ar5315u.h b/include/configs/comtrend_ar5315u.h index 71a1af1cdd..9f4b4e2804 100644 --- a/include/configs/comtrend_ar5315u.h +++ b/include/configs/comtrend_ar5315u.h @@ -7,4 +7,3 @@ #include <configs/bmips_bcm6318.h>
#define CONFIG_REMAKE_ELF - diff --git a/include/configs/comtrend_ar5387un.h b/include/configs/comtrend_ar5387un.h index 7b195749ac..888a6d8985 100644 --- a/include/configs/comtrend_ar5387un.h +++ b/include/configs/comtrend_ar5387un.h @@ -7,4 +7,3 @@ #include <configs/bmips_bcm6328.h>
#define CONFIG_REMAKE_ELF - diff --git a/include/configs/comtrend_ct5361.h b/include/configs/comtrend_ct5361.h index 2a28e6c624..10e2969948 100644 --- a/include/configs/comtrend_ct5361.h +++ b/include/configs/comtrend_ct5361.h @@ -7,4 +7,3 @@ #include <configs/bmips_bcm6348.h>
#define CONFIG_REMAKE_ELF - diff --git a/include/configs/comtrend_wap5813n.h b/include/configs/comtrend_wap5813n.h index c8cddaf126..f786c465ba 100644 --- a/include/configs/comtrend_wap5813n.h +++ b/include/configs/comtrend_wap5813n.h @@ -7,4 +7,3 @@ #include <configs/bmips_bcm6368.h>
#define CONFIG_REMAKE_ELF - diff --git a/include/configs/emsdp.h b/include/configs/emsdp.h index a872d48154..8df08337c0 100644 --- a/include/configs/emsdp.h +++ b/include/configs/emsdp.h @@ -33,4 +33,3 @@ "emsdp rom lock\0"
#endif /* _CONFIG_EMSDP_H_ */ - diff --git a/include/configs/huawei_hg556a.h b/include/configs/huawei_hg556a.h index 529fc9495e..7c88af0532 100644 --- a/include/configs/huawei_hg556a.h +++ b/include/configs/huawei_hg556a.h @@ -7,4 +7,3 @@ #include <configs/bmips_bcm6358.h>
#define CONFIG_REMAKE_ELF - diff --git a/include/configs/km/km-mpc832x.h b/include/configs/km/km-mpc832x.h index 22dfb5da67..fa213e4a8b 100644 --- a/include/configs/km/km-mpc832x.h +++ b/include/configs/km/km-mpc832x.h @@ -73,4 +73,3 @@
/* EEprom support */ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 - diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 1fd5471ac5..dea63f04cd 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -87,4 +87,3 @@ #define CONFIG_KIRKWOOD_GPIO
#endif /* _CONFIG_NAS220_H */ - diff --git a/include/configs/netgear_cg3100d.h b/include/configs/netgear_cg3100d.h index 8d2b3e73a0..59468a4c55 100644 --- a/include/configs/netgear_cg3100d.h +++ b/include/configs/netgear_cg3100d.h @@ -5,4 +5,3 @@
#include <configs/bmips_common.h> #include <configs/bmips_bcm3380.h> - diff --git a/include/configs/netgear_dgnd3700v2.h b/include/configs/netgear_dgnd3700v2.h index 779c20700a..f14316c845 100644 --- a/include/configs/netgear_dgnd3700v2.h +++ b/include/configs/netgear_dgnd3700v2.h @@ -7,4 +7,3 @@ #include <configs/bmips_bcm6362.h>
#define CONFIG_REMAKE_ELF - diff --git a/include/configs/sagem_f@st1704.h b/include/configs/sagem_f@st1704.h index e5bb4e50d1..d6d2014ef5 100644 --- a/include/configs/sagem_f@st1704.h +++ b/include/configs/sagem_f@st1704.h @@ -5,4 +5,3 @@
#include <configs/bmips_common.h> #include <configs/bmips_bcm6338.h> - diff --git a/include/configs/sfr_nb4_ser.h b/include/configs/sfr_nb4_ser.h index 529fc9495e..7c88af0532 100644 --- a/include/configs/sfr_nb4_ser.h +++ b/include/configs/sfr_nb4_ser.h @@ -7,4 +7,3 @@ #include <configs/bmips_bcm6358.h>
#define CONFIG_REMAKE_ELF - diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 7be5e5ddf1..8b574e1ceb 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -125,4 +125,3 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
#endif /*_VERDIN_IMX8MM_H */ - diff --git a/include/dm/platform_data/spi_coldfire.h b/include/dm/platform_data/spi_coldfire.h index da514bad0d..0d534b1d66 100644 --- a/include/dm/platform_data/spi_coldfire.h +++ b/include/dm/platform_data/spi_coldfire.h @@ -26,4 +26,3 @@ struct coldfire_spi_plat { };
#endif /* __spi_coldfire_h */ - diff --git a/include/dt-bindings/clock/mt7622-clk.h b/include/dt-bindings/clock/mt7622-clk.h index 22b8d08b60..76fcaff0e4 100644 --- a/include/dt-bindings/clock/mt7622-clk.h +++ b/include/dt-bindings/clock/mt7622-clk.h @@ -268,4 +268,3 @@ #define CLK_SGMII_CDR_FB 3
#endif /* _DT_BINDINGS_CLK_MT7622_H */ - diff --git a/include/dt-bindings/comphy/comphy_data.h b/include/dt-bindings/comphy/comphy_data.h index 8353a78740..8a49241238 100644 --- a/include/dt-bindings/comphy/comphy_data.h +++ b/include/dt-bindings/comphy/comphy_data.h @@ -51,4 +51,3 @@ #define UTMI_PHY_INVALID 0xff
#endif /* _COMPHY_DATA_H_ */ - diff --git a/include/dt-bindings/pinctrl/dra.h b/include/dt-bindings/pinctrl/dra.h index 18ec5df5a5..b543eebd2f 100644 --- a/include/dt-bindings/pinctrl/dra.h +++ b/include/dt-bindings/pinctrl/dra.h @@ -77,4 +77,3 @@ #define A_DELAY_PS(val) ((val) & 0xffff) #define G_DELAY_PS(val) ((val) & 0xffff) #endif - diff --git a/include/dt-bindings/pinctrl/omap.h b/include/dt-bindings/pinctrl/omap.h index f48245ff87..4c060ee0e0 100644 --- a/include/dt-bindings/pinctrl/omap.h +++ b/include/dt-bindings/pinctrl/omap.h @@ -89,4 +89,3 @@ #define OMAP4_UART4_RX 0x11c
#endif - diff --git a/include/dt-bindings/pinctrl/stm32-pinfunc.h b/include/dt-bindings/pinctrl/stm32-pinfunc.h index e6fb8ada3f..e6e0780789 100644 --- a/include/dt-bindings/pinctrl/stm32-pinfunc.h +++ b/include/dt-bindings/pinctrl/stm32-pinfunc.h @@ -39,4 +39,3 @@ #define STM32MP_PKG_AD 0x8
#endif /* _DT_BINDINGS_STM32_PINFUNC_H */ - diff --git a/include/dt-bindings/thermal/thermal.h b/include/dt-bindings/thermal/thermal.h index bc7babb1a6..7871e5f52b 100644 --- a/include/dt-bindings/thermal/thermal.h +++ b/include/dt-bindings/thermal/thermal.h @@ -13,4 +13,3 @@ #define THERMAL_NO_LIMIT (~0)
#endif - diff --git a/include/environment/ti/nand.h b/include/environment/ti/nand.h index f2482e8c35..11dcefcc41 100644 --- a/include/environment/ti/nand.h +++ b/include/environment/ti/nand.h @@ -23,4 +23,3 @@ #else #define NANDARGS "" #endif - diff --git a/include/linux/serial_reg.h b/include/linux/serial_reg.h index 29c3b5b9a5..ef020ad162 100644 --- a/include/linux/serial_reg.h +++ b/include/linux/serial_reg.h @@ -384,4 +384,3 @@ #define UART_EXAR_RXTRG 0x0b /* Rx FIFO trigger level write-only */
#endif /* _LINUX_SERIAL_REG_H */ - diff --git a/include/smem.h b/include/smem.h index 598799d3a0..83da9e177e 100644 --- a/include/smem.h +++ b/include/smem.h @@ -88,4 +88,3 @@ void *smem_get(struct udevice *dev, unsigned int host, unsigned int item, size_t int smem_get_free_space(struct udevice *dev, unsigned int host);
#endif /* _smem_h_ */ - diff --git a/include/st_logo_data.h b/include/st_logo_data.h index d8d1fd3b03..b53fa1c38b 100644 --- a/include/st_logo_data.h +++ b/include/st_logo_data.h @@ -3263,4 +3263,3 @@ unsigned char stmicroelectronics_uboot_logo_8bit_rle[] = { 0xe1, 0x00, 0x00, 0x00, 0xff, 0x00, 0xe1, 0x00, 0x00, 0x00, 0xff, 0x00, 0xe1, 0x00, 0x00, 0x01 }; - diff --git a/net/tftp.c b/net/tftp.c index 5baf528f4e..87392014d5 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -925,4 +925,3 @@ void tftp_start_server(void) memset(net_server_ethaddr, 0, 6); } #endif /* CONFIG_CMD_TFTPSRV */ - diff --git a/scripts/dtc/treesource.c b/scripts/dtc/treesource.c index 2461a3d068..b36cb41902 100644 --- a/scripts/dtc/treesource.c +++ b/scripts/dtc/treesource.c @@ -281,4 +281,3 @@ void dt_to_source(FILE *f, struct dt_info *dti)
write_tree_source_node(f, dti->dt, 0); } - diff --git a/test/dm/pci_ep.c b/test/dm/pci_ep.c index 9b03b8bae3..9941abd4ce 100644 --- a/test/dm/pci_ep.c +++ b/test/dm/pci_ep.c @@ -62,4 +62,3 @@ static int dm_test_pci_ep_base(struct unit_test_state *uts) }
DM_TEST(dm_test_pci_ep_base, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); - diff --git a/test/dm/smem.c b/test/dm/smem.c index a797026cb5..289fb59ba1 100644 --- a/test/dm/smem.c +++ b/test/dm/smem.c @@ -25,4 +25,3 @@ static int dm_test_smem_base(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_smem_base, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); -
Signed-off-by: Wolfgang Denk wd@denx.de --- README | 1 - arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c | 2 -- arch/xtensa/include/asm/arch-dc232b/core.h | 2 -- arch/xtensa/include/asm/arch-dc232b/tie-asm.h | 4 ---- arch/xtensa/include/asm/arch-dc233c/core.h | 3 --- arch/xtensa/include/asm/arch-dc233c/tie-asm.h | 4 ---- arch/xtensa/include/asm/arch-de212/core.h | 3 --- arch/xtensa/include/asm/cacheasm.h | 2 -- board/freescale/ls1088a/ddr.c | 2 -- board/freescale/t208xqds/README | 1 - board/xilinx/zynq/zynq-microzed/ps7_init_gpl.c | 4 ---- board/xilinx/zynq/zynq-zc702/ps7_init_gpl.c | 4 ---- board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c | 4 ---- board/xilinx/zynq/zynq-zed/ps7_init_gpl.c | 4 ---- cmd/bedbug.c | 4 ---- doc/README.dfutftp | 2 -- doc/device-tree-bindings/firmware/linaro,optee-tz.txt | 1 - drivers/gpio/hi6220_gpio.c | 2 -- drivers/i2c/mxc_i2c.c | 2 -- drivers/mtd/nand/raw/nand_util.c | 2 -- drivers/net/e1000.c | 4 ---- drivers/video/stb_truetype.h | 1 - fs/btrfs/kernel-shared/btrfs_tree.h | 1 - include/configs/etamin.h | 1 - include/fsl-mc/fsl_dpni.h | 2 -- include/linux/mtd/flashchip.h | 1 - include/linux/serial_reg.h | 1 - 27 files changed, 64 deletions(-)
diff --git a/README b/README index a3f81e4aed..91bf2a4e30 100644 --- a/README +++ b/README @@ -300,7 +300,6 @@ board_init_r(): - loads U-Boot or (in falcon mode) Linux
- Configuration Options: ----------------------
diff --git a/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c b/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c index 3b41c7d49b..bb7d24b4b7 100644 --- a/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c +++ b/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c @@ -14,8 +14,6 @@ #include "sys_env_lib.h" #include "ctrl_pex.h"
- - /* * serdes_seq_db - holds all serdes sequences, their size and the * relevant index in the data array initialized in serdes_seq_init diff --git a/arch/xtensa/include/asm/arch-dc232b/core.h b/arch/xtensa/include/asm/arch-dc232b/core.h index 92ea0dfe35..c1453f719e 100644 --- a/arch/xtensa/include/asm/arch-dc232b/core.h +++ b/arch/xtensa/include/asm/arch-dc232b/core.h @@ -127,8 +127,6 @@ #define XCHAL_DCACHE_IS_WRITEBACK 1 /* writeback feature */
- - /**************************************************************************** Parameters Useful for PRIVILEGED (Supervisory or Non-Virtualized) Code ****************************************************************************/ diff --git a/arch/xtensa/include/asm/arch-dc232b/tie-asm.h b/arch/xtensa/include/asm/arch-dc232b/tie-asm.h index 7003cad40d..35a26dca7c 100644 --- a/arch/xtensa/include/asm/arch-dc232b/tie-asm.h +++ b/arch/xtensa/include/asm/arch-dc232b/tie-asm.h @@ -26,7 +26,6 @@ #define XTHAL_SAS_ALL 0xFFFF /* include all default NCP contents */
- /* Macro to save all non-coprocessor (extra) custom TIE and optional state * (not including zero-overhead loop registers). * Save area ptr (clobbered): ptr (1 byte aligned) @@ -109,11 +108,8 @@ .endif .endm // xchal_ncp_load
- - #define XCHAL_NCP_NUM_ATMPS 2
- #define XCHAL_SA_NUM_ATMPS 2
#endif /*_XTENSA_CORE_TIE_ASM_H*/ diff --git a/arch/xtensa/include/asm/arch-dc233c/core.h b/arch/xtensa/include/asm/arch-dc233c/core.h index ca07d8ee21..4646cdbfb4 100644 --- a/arch/xtensa/include/asm/arch-dc233c/core.h +++ b/arch/xtensa/include/asm/arch-dc233c/core.h @@ -149,13 +149,10 @@ #define XCHAL_HAVE_PREFETCH 0 /* PREFCTL register */
- #ifndef XTENSA_HAL_NON_PRIVILEGED_ONLY
/*---------------------------------------------------------------------- diff --git a/arch/xtensa/include/asm/arch-dc233c/tie-asm.h b/arch/xtensa/include/asm/arch-dc233c/tie-asm.h index 317d4e1312..7b3d1f3c57 100644 --- a/arch/xtensa/include/asm/arch-dc233c/tie-asm.h +++ b/arch/xtensa/include/asm/arch-dc233c/tie-asm.h @@ -31,8 +31,6 @@ | ((ccuse) & XTHAL_SAS_ANYCC) \ | ((abi) & XTHAL_SAS_ANYABI) )
- - /* * Macro to save all non-coprocessor (extra) custom TIE and optional state * (not including zero-overhead loop registers). @@ -164,8 +162,6 @@
#define XCHAL_NCP_NUM_ATMPS 1
- - #define XCHAL_SA_NUM_ATMPS 1
#endif /*_XTENSA_CORE_TIE_ASM_H*/ diff --git a/arch/xtensa/include/asm/arch-de212/core.h b/arch/xtensa/include/asm/arch-de212/core.h index 7268692d0e..443fd459ca 100644 --- a/arch/xtensa/include/asm/arch-de212/core.h +++ b/arch/xtensa/include/asm/arch-de212/core.h @@ -206,13 +206,10 @@ #define XCHAL_HAVE_DCACHE_DYN_WAYS 0 /* Dcache dynamic way support */
/*---------------------------------------------------------------------- diff --git a/arch/xtensa/include/asm/cacheasm.h b/arch/xtensa/include/asm/cacheasm.h index 6d321f8866..69448cfff7 100644 --- a/arch/xtensa/include/asm/cacheasm.h +++ b/arch/xtensa/include/asm/cacheasm.h @@ -134,7 +134,6 @@ .endm
- .macro ___flush_invalidate_dcache_range ar as at
#if XCHAL_DCACHE_SIZE @@ -171,7 +170,6 @@ .endm
- .macro ___flush_invalidate_dcache_page ar as
#if XCHAL_DCACHE_SIZE diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c index 995c429601..9e0941cc9d 100644 --- a/board/freescale/ls1088a/ddr.c +++ b/board/freescale/ls1088a/ddr.c @@ -88,8 +88,6 @@ found: pbsp->clk_adjust, pbsp->wrlvl_start, pbsp->wrlvl_ctl_2, pbsp->wrlvl_ctl_3);
- - popts->half_strength_driver_enable = 0; /* * Write leveling override diff --git a/board/freescale/t208xqds/README b/board/freescale/t208xqds/README index d690857f2e..9678c39e34 100755 --- a/board/freescale/t208xqds/README +++ b/board/freescale/t208xqds/README @@ -158,7 +158,6 @@ Start Address End Address Definition Max size 0xE8000000 0xE801FFFF RCW (current bank) 128KB
- Software configurations and board settings ------------------------------------------ 1. NOR boot: diff --git a/board/xilinx/zynq/zynq-microzed/ps7_init_gpl.c b/board/xilinx/zynq/zynq-microzed/ps7_init_gpl.c index 323835ab1b..c2a6f9199a 100644 --- a/board/xilinx/zynq/zynq-microzed/ps7_init_gpl.c +++ b/board/xilinx/zynq/zynq-microzed/ps7_init_gpl.c @@ -12399,8 +12399,6 @@ unsigned long ps7_post_config_1_0[] = { // };
- - #include "xil_io.h"
unsigned long *ps7_mio_init_data = ps7_mio_init_data_3_0; @@ -12477,8 +12475,6 @@ ps7_init() ret = ps7_config (ps7_ddr_init_data); if (ret != PS7_INIT_SUCCESS) return ret;
- - // Peripherals init ret = ps7_config (ps7_peripherals_init_data); if (ret != PS7_INIT_SUCCESS) return ret; diff --git a/board/xilinx/zynq/zynq-zc702/ps7_init_gpl.c b/board/xilinx/zynq/zynq-zc702/ps7_init_gpl.c index 248c72861c..fd102a3ce4 100644 --- a/board/xilinx/zynq/zynq-zc702/ps7_init_gpl.c +++ b/board/xilinx/zynq/zynq-zc702/ps7_init_gpl.c @@ -12732,8 +12732,6 @@ unsigned long ps7_post_config_1_0[] = { // };
unsigned long *ps7_mio_init_data = ps7_mio_init_data_3_0; @@ -12810,8 +12808,6 @@ ps7_init() ret = ps7_config (ps7_ddr_init_data); if (ret != PS7_INIT_SUCCESS) return ret;
- - // Peripherals init ret = ps7_config (ps7_peripherals_init_data); if (ret != PS7_INIT_SUCCESS) return ret; diff --git a/board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c b/board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c index cc90a4c94b..796e5b0c5f 100644 --- a/board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c +++ b/board/xilinx/zynq/zynq-zc706/ps7_init_gpl.c @@ -12639,8 +12639,6 @@ unsigned long ps7_post_config_1_0[] = { // };
unsigned long *ps7_mio_init_data = ps7_mio_init_data_3_0; @@ -12717,8 +12715,6 @@ ps7_init() ret = ps7_config (ps7_ddr_init_data); if (ret != PS7_INIT_SUCCESS) return ret;
- - // Peripherals init ret = ps7_config (ps7_peripherals_init_data); if (ret != PS7_INIT_SUCCESS) return ret; diff --git a/board/xilinx/zynq/zynq-zed/ps7_init_gpl.c b/board/xilinx/zynq/zynq-zed/ps7_init_gpl.c index 8fb3908e02..baf89a5800 100644 --- a/board/xilinx/zynq/zynq-zed/ps7_init_gpl.c +++ b/board/xilinx/zynq/zynq-zed/ps7_init_gpl.c @@ -12297,8 +12297,6 @@ unsigned long ps7_post_config_1_0[] = { // };
unsigned long *ps7_mio_init_data = ps7_mio_init_data_3_0; @@ -12375,8 +12373,6 @@ ps7_init() ret = ps7_config (ps7_ddr_init_data); if (ret != PS7_INIT_SUCCESS) return ret;
- - // Peripherals init ret = ps7_config (ps7_peripherals_init_data); if (ret != PS7_INIT_SUCCESS) return ret; diff --git a/cmd/bedbug.c b/cmd/bedbug.c index 549c9056dd..0bd67fcf47 100644 --- a/cmd/bedbug.c +++ b/cmd/bedbug.c @@ -39,7 +39,6 @@ int bedbug_puts (const char *str) } /* bedbug_puts */
- /* ====================================================================== * Initialize the bug_ctx structure used by the bedbug debugger. This is * specific to the CPU since each has different debug registers and @@ -53,7 +52,6 @@ int bedbug_init(void) } /* bedbug_init */
- /* ====================================================================== * Entry point from the interpreter to the disassembler. Repeated calls * will resume from the last disassembled address. @@ -183,7 +181,6 @@ void do_bedbug_breakpoint (struct pt_regs *regs) } /* do_bedbug_breakpoint */
- /* ====================================================================== * Called from the CPU-specific breakpoint handling routine. Enter a * mini main loop until the stopped flag is cleared from the breakpoint @@ -241,7 +238,6 @@ void bedbug_main_loop (unsigned long addr, struct pt_regs *regs) } /* bedbug_main_loop */
- /* ====================================================================== * Interpreter command to continue from a breakpoint. Just clears the * stopped flag in the context so that the breakpoint routine will diff --git a/doc/README.dfutftp b/doc/README.dfutftp index a3341bbb61..1206507911 100644 --- a/doc/README.dfutftp +++ b/doc/README.dfutftp @@ -88,7 +88,6 @@ for pure DFU USB transfer. possible to set large enough default buffer (8 MiB @ BBB)
- FIT image format for download -----------------------------
@@ -110,7 +109,6 @@ should look like where "u-boot.bin" is the DFU entity name to be stored.
- To do -----
diff --git a/doc/device-tree-bindings/firmware/linaro,optee-tz.txt b/doc/device-tree-bindings/firmware/linaro,optee-tz.txt index d38834c67d..2d75c2b1b5 100644 --- a/doc/device-tree-bindings/firmware/linaro,optee-tz.txt +++ b/doc/device-tree-bindings/firmware/linaro,optee-tz.txt @@ -21,7 +21,6 @@ the reference implementation maintained by Linaro. in drivers/tee/optee/optee_smc.h
- Example: firmware { optee { diff --git a/drivers/gpio/hi6220_gpio.c b/drivers/gpio/hi6220_gpio.c index 608ad64f65..e287c31b93 100644 --- a/drivers/gpio/hi6220_gpio.c +++ b/drivers/gpio/hi6220_gpio.c @@ -54,8 +54,6 @@ static int hi6220_gpio_get_value(struct udevice *dev, unsigned gpio) return !!readb(bank->base + (BIT(gpio + 2))); }
- - static const struct dm_gpio_ops gpio_hi6220_ops = { .direction_input = hi6220_gpio_direction_input, .direction_output = hi6220_gpio_direction_output, diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 003aa33f6e..bf56ffa5ad 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -798,8 +798,6 @@ void bus_i2c_init(int index, int speed, int unused, bus_i2c_set_bus_speed(&mxc_i2c_buses[index], speed); }
- - /* * Init I2C Bus */ diff --git a/drivers/mtd/nand/raw/nand_util.c b/drivers/mtd/nand/raw/nand_util.c index 00c3c6c412..5cc256bf20 100644 --- a/drivers/mtd/nand/raw/nand_util.c +++ b/drivers/mtd/nand/raw/nand_util.c @@ -545,8 +545,6 @@ int nand_verify(struct mtd_info *mtd, loff_t ofs, size_t len, u_char *buf) return rval ? -EIO : 0; }
- - /** * nand_write_skip_bad: * diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index 5bdcede8f1..4e34248ff6 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -5251,11 +5251,7 @@ e1000_configure_tx(struct e1000_hw *hw) mdelay(20); }
- - E1000_WRITE_REG(hw, TCTL, tctl); - - }
/** diff --git a/drivers/video/stb_truetype.h b/drivers/video/stb_truetype.h index 5d00bff9fd..26f4ac2ca8 100644 --- a/drivers/video/stb_truetype.h +++ b/drivers/video/stb_truetype.h @@ -497,7 +497,6 @@ STBTT_DEF void stbtt_GetBakedQuad(stbtt_bakedchar *chardata, int pw, int ph, // // It's inefficient; you might want to c&p it and optimize it.
- ////////////////////////////////////////////////////////////////////////////// // // NEW TEXTURE BAKING API diff --git a/fs/btrfs/kernel-shared/btrfs_tree.h b/fs/btrfs/kernel-shared/btrfs_tree.h index 6a76d1e456..d8eff0b912 100644 --- a/fs/btrfs/kernel-shared/btrfs_tree.h +++ b/fs/btrfs/kernel-shared/btrfs_tree.h @@ -334,7 +334,6 @@ #define BTRFS_STRING_ITEM_KEY 253
- /* 32 bytes in various csum fields */ #define BTRFS_CSUM_SIZE 32
diff --git a/include/configs/etamin.h b/include/configs/etamin.h index 880149fb89..a823aff6b5 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -110,7 +110,6 @@ #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
- #undef COMMON_ENV_DFU_ARGS #define COMMON_ENV_DFU_ARGS "dfu_args=run bootargs_defaults;" \ "setenv bootargs ${bootargs};" \ diff --git a/include/fsl-mc/fsl_dpni.h b/include/fsl-mc/fsl_dpni.h index 96d81d9934..e5e7338192 100644 --- a/include/fsl-mc/fsl_dpni.h +++ b/include/fsl-mc/fsl_dpni.h @@ -173,8 +173,6 @@ do { \ MC_RSP_OP(cmd, 2, 0, 64, uint64_t, state->options);\ } while (0)
- - /* cmd, param, offset, width, type, arg_name */ #define DPNI_CMD_SET_PRIMARY_MAC_ADDR(cmd, mac_addr) \ do { \ diff --git a/include/linux/mtd/flashchip.h b/include/linux/mtd/flashchip.h index 666480db93..265e89f02b 100644 --- a/include/linux/mtd/flashchip.h +++ b/include/linux/mtd/flashchip.h @@ -52,7 +52,6 @@ typedef enum { } flstate_t;
- /* NOTE: confusingly, this can be used to refer to more than one chip at a time, if they're interleaved. This can even refer to individual partitions on the same physical chip when present. */ diff --git a/include/linux/serial_reg.h b/include/linux/serial_reg.h index ef020ad162..dca7efa142 100644 --- a/include/linux/serial_reg.h +++ b/include/linux/serial_reg.h @@ -288,7 +288,6 @@ #define UART_ACR_ASREN 0x80 /* Additional status enable */
- /* * These definitions are for the RSA-DV II/S card, from *
Signed-off-by: Wolfgang Denk wd@denx.de --- Licenses/lgpl-2.0.txt | 2 +- Makefile | 4 ++-- arch/arm/include/asm/arch-am33xx/cpu.h | 2 +- arch/arm/lib/lib1funcs.S | 6 +++--- arch/xtensa/include/asm/arch-de212/core.h | 2 +- board/freescale/common/sys_eeprom.c | 2 +- .../dragonboard820c/dragonboard820c.c | 6 +++--- board/warp7/README | 2 +- common/spl/spl_mmc.c | 2 +- doc/README.distro | 2 +- doc/imx/common/imx6.txt | 2 +- drivers/misc/atsha204a-i2c.c | 2 +- drivers/mtd/mtdcore.c | 4 ++-- drivers/mtd/nand/raw/nand_base.c | 2 +- drivers/mtd/nand/raw/nand_util.c | 2 +- drivers/mtd/ubi/build.c | 2 +- drivers/net/phy/meson-gxl.c | 2 +- drivers/ram/stm32_sdram.c | 2 +- drivers/reset/reset-meson.c | 10 +++++----- drivers/serial/serial_msm.c | 2 +- drivers/usb/dwc3/dwc3-meson-gxl.c | 2 +- drivers/usb/musb-new/musb_regs.h | 2 +- drivers/usb/musb-new/musb_uboot.c | 2 +- drivers/usb/musb/musb_hcd.c | 2 +- drivers/video/anx9804.c | 10 +++++----- drivers/video/tdo-tl070wsh30.c | 2 +- include/configs/imx6-engicam.h | 2 +- include/linux/mtd/rawnand.h | 2 +- include/linux/serial_reg.h | 4 ++-- scripts/kconfig/gconf.c | 2 +- tools/asn1_compiler.c | 2 +- tools/patman/test/test01.txt | 20 +++++++++---------- 32 files changed, 56 insertions(+), 56 deletions(-)
diff --git a/Licenses/lgpl-2.0.txt b/Licenses/lgpl-2.0.txt index 5bc8fb2c8f..12735e6c21 100644 --- a/Licenses/lgpl-2.0.txt +++ b/Licenses/lgpl-2.0.txt @@ -133,7 +133,7 @@ such a program is covered only if its contents constitute a work based on the Library (independent of the use of the Library in a tool for writing it). Whether that is true depends on what the Library does and what the program that uses the Library does. - + 1. You may copy and distribute verbatim copies of the Library's complete source code as you receive it, in any medium, provided that you conspicuously and appropriately publish on each copy an diff --git a/Makefile b/Makefile index 732d702947..e2f5d47d1f 100644 --- a/Makefile +++ b/Makefile @@ -327,14 +327,14 @@ os_x_before = $(shell if [ $(DARWIN_MAJOR_VERSION) -le $(1) -a \ $(DARWIN_MINOR_VERSION) -le $(2) ] ; then echo "$(3)"; else echo "$(4)"; fi ;)
os_x_after = $(shell if [ $(DARWIN_MAJOR_VERSION) -ge $(1) -a \ - $(DARWIN_MINOR_VERSION) -ge $(2) ] ; then echo "$(3)"; else echo "$(4)"; fi ;) + $(DARWIN_MINOR_VERSION) -ge $(2) ] ; then echo "$(3)"; else echo "$(4)"; fi ;)
# Snow Leopards build environment has no longer restrictions as described above HOSTCC = $(call os_x_before, 10, 5, "cc", "gcc") KBUILD_HOSTCFLAGS += $(call os_x_before, 10, 4, "-traditional-cpp") KBUILD_HOSTLDFLAGS += $(call os_x_before, 10, 5, "-multiply_defined suppress")
-# macOS Mojave (10.14.X) +# macOS Mojave (10.14.X) # Undefined symbols for architecture x86_64: "_PyArg_ParseTuple" KBUILD_HOSTLDFLAGS += $(call os_x_after, 10, 14, "-lpython -dynamclib", "") endif diff --git a/arch/arm/include/asm/arch-am33xx/cpu.h b/arch/arm/include/asm/arch-am33xx/cpu.h index 79081de700..b33e6f7fd1 100644 --- a/arch/arm/include/asm/arch-am33xx/cpu.h +++ b/arch/arm/include/asm/arch-am33xx/cpu.h @@ -408,7 +408,7 @@ struct cm_dpll { unsigned int resv1; unsigned int clktimer2clk; /* offset 0x04 */ unsigned int resv2[11]; - unsigned int clkselmacclk; /* offset 0x34 */ + unsigned int clkselmacclk; /* offset 0x34 */ }; #endif /* CONFIG_AM43XX */
diff --git a/arch/arm/lib/lib1funcs.S b/arch/arm/lib/lib1funcs.S index 0798d098af..700eee5fbb 100644 --- a/arch/arm/lib/lib1funcs.S +++ b/arch/arm/lib/lib1funcs.S @@ -34,7 +34,7 @@ mov \divisor, \divisor, lsl \result mov \curbit, \curbit, lsl \result mov \result, #0 - + #else
@ Initially shift the divisor left 3 bits if possible, @@ -48,7 +48,7 @@
@ Unless the divisor is very big, shift it up in multiples of @ four bits, since this is the amount of unwinding in the main - @ division loop. Continue shifting until the divisor is + @ division loop. Continue shifting until the divisor is @ larger than the dividend. 1: cmp \divisor, #0x10000000 cmplo \divisor, \dividend @@ -135,7 +135,7 @@
@ Unless the divisor is very big, shift it up in multiples of @ four bits, since this is the amount of unwinding in the main - @ division loop. Continue shifting until the divisor is + @ division loop. Continue shifting until the divisor is @ larger than the dividend. 1: cmp \divisor, #0x10000000 cmplo \divisor, \dividend diff --git a/arch/xtensa/include/asm/arch-de212/core.h b/arch/xtensa/include/asm/arch-de212/core.h index 443fd459ca..3271406291 100644 --- a/arch/xtensa/include/asm/arch-de212/core.h +++ b/arch/xtensa/include/asm/arch-de212/core.h @@ -89,7 +89,7 @@ #define XCHAL_HAVE_HIFI3_VFPU 0 /* HiFi3 Audio Engine VFPU option */ #define XCHAL_HAVE_HIFI2 0 /* HiFi2 Audio Engine pkg */ #define XCHAL_HAVE_HIFI2EP 0 /* HiFi2EP */ -#define XCHAL_HAVE_HIFI_MINI 0 +#define XCHAL_HAVE_HIFI_MINI 0
#define XCHAL_HAVE_VECTORFPU2005 0 /* vector or user floating-point pkg */ diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index 35df8ba389..431f8caeb0 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -62,7 +62,7 @@ static struct __attribute__ ((__packed__)) eeprom { u8 mac_count; /* 0x40 Number of MAC addresses */ u8 mac_flag; /* 0x41 MAC table flags */ u8 mac[MAX_NUM_PORTS][6]; /* 0x42 - 0xa1 MAC addresses */ - u8 res_2[90]; /* 0xa2 - 0xfb Reserved */ + u8 res_2[90]; /* 0xa2 - 0xfb Reserved */ u32 crc; /* 0xfc - 0xff CRC32 checksum */ #endif } e; diff --git a/board/qualcomm/dragonboard820c/dragonboard820c.c b/board/qualcomm/dragonboard820c/dragonboard820c.c index 4ccb1a0750..f9cc762a25 100644 --- a/board/qualcomm/dragonboard820c/dragonboard820c.c +++ b/board/qualcomm/dragonboard820c/dragonboard820c.c @@ -73,7 +73,7 @@ static void sdhci_power_init(void)
/* drive strength configs for sdhc pins */ const struct tlmm_cfg hdrv[] = { - + { SDC1_CLK_HDRV, TLMM_CUR_VAL_16MA, TLMM_HDRV_MASK, }, { SDC1_CMD_HDRV, TLMM_CUR_VAL_10MA, TLMM_HDRV_MASK, }, { SDC1_DATA_HDRV, TLMM_CUR_VAL_10MA, TLMM_HDRV_MASK, }, @@ -81,14 +81,14 @@ static void sdhci_power_init(void)
/* pull configs for sdhc pins */ const struct tlmm_cfg pull[] = { - + { SDC1_CLK_PULL, TLMM_NO_PULL, TLMM_PULL_MASK, }, { SDC1_CMD_PULL, TLMM_PULL_UP, TLMM_PULL_MASK, }, { SDC1_DATA_PULL, TLMM_PULL_UP, TLMM_PULL_MASK, }, };
const struct tlmm_cfg rclk[] = { - + { SDC1_RCLK_PULL, TLMM_PULL_DOWN, TLMM_PULL_MASK,}, };
diff --git a/board/warp7/README b/board/warp7/README index 579bb2de38..05cdfd0027 100644 --- a/board/warp7/README +++ b/board/warp7/README @@ -19,7 +19,7 @@ $ make
This will generate the U-Boot binary called u-boot-dtb.imx.
-Put warp7 board in USB download mode: +Put warp7 board in USB download mode:
Remove the CPU board from the base board then put switch 2 in the upper position diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 212a2b0992..d52f8a3eef 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -194,7 +194,7 @@ static int mmc_load_image_raw_partition(struct spl_image_info *spl_image, err = part_get_info(mmc_get_blk_desc(mmc), type_part, &info); if (err) continue; - if (info.sys_ind == + if (info.sys_ind == CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE) { partition = type_part; break; diff --git a/doc/README.distro b/doc/README.distro index c4f041ca71..fa8cec1102 100644 --- a/doc/README.distro +++ b/doc/README.distro @@ -233,7 +233,7 @@ fdtfile: the DTB with a different DTB. fdtfile will automatically be set for you if it matches the format ${soc}-${board}.dtb which covers most 32 bit use cases. AArch64 generally does not match as the Linux kernel put the dtb files under - SoC vendor directories. + SoC vendor directories.
ramdisk_addr_r:
diff --git a/doc/imx/common/imx6.txt b/doc/imx/common/imx6.txt index 0b5061128c..9007cfbf58 100644 --- a/doc/imx/common/imx6.txt +++ b/doc/imx/common/imx6.txt @@ -9,7 +9,7 @@ SoC. 1.1 MAC Address: It is stored in fuse bank 4, with the 32 lsbs in word 2 and the 16 msbs in word 3[15:0]. For i.MX6SX and i.MX6UL, they have two MAC addresses. The second MAC address - is stored in fuse bank 4, with the 16 lsb in word 3[31:16] and the 32 msbs in + is stored in fuse bank 4, with the 16 lsb in word 3[31:16] and the 32 msbs in word 4.
Example: diff --git a/drivers/misc/atsha204a-i2c.c b/drivers/misc/atsha204a-i2c.c index af65c559dc..52d9eadf49 100644 --- a/drivers/misc/atsha204a-i2c.c +++ b/drivers/misc/atsha204a-i2c.c @@ -339,7 +339,7 @@ int atsha204a_read(struct udevice *dev, enum atsha204a_zone zone, bool read32, retry--; atsha204a_wakeup(dev); } while (retry >= 0); - + if (res) { debug("ATSHA204A read failed\n"); return res; diff --git a/drivers/mtd/mtdcore.c b/drivers/mtd/mtdcore.c index 582129d0df..d0351b2c6a 100644 --- a/drivers/mtd/mtdcore.c +++ b/drivers/mtd/mtdcore.c @@ -4,7 +4,7 @@ * drivers and users. * * Copyright © 1999-2010 David Woodhouse dwmw2@infradead.org - * Copyright © 2006 Red Hat UK Limited + * Copyright © 2006 Red Hat UK Limited * */
@@ -123,7 +123,7 @@ void *idr_get_next(struct idr *idp, int *next) } else { *next = 0; } - + return ret; }
diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index 3679ee727e..0caaf7b32c 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -910,7 +910,7 @@ static int nand_wait(struct mtd_info *mtd, struct nand_chip *chip)
u32 timer = (CONFIG_SYS_HZ * timeo) / 1000; u32 time_start; - + time_start = get_timer(0); while (get_timer(time_start) < timer) { if (chip->dev_ready) { diff --git a/drivers/mtd/nand/raw/nand_util.c b/drivers/mtd/nand/raw/nand_util.c index 5cc256bf20..d03b8645c4 100644 --- a/drivers/mtd/nand/raw/nand_util.c +++ b/drivers/mtd/nand/raw/nand_util.c @@ -189,7 +189,7 @@ int nand_erase_opts(struct mtd_info *mtd,
#define NAND_CMD_LOCK_TIGHT 0x2c #define NAND_CMD_LOCK_STATUS 0x7a - + /****************************************************************************** * Support for locking / unlocking operations of some NAND devices *****************************************************************************/ diff --git a/drivers/mtd/ubi/build.c b/drivers/mtd/ubi/build.c index 61e38ba1ab..e2bd32697e 100644 --- a/drivers/mtd/ubi/build.c +++ b/drivers/mtd/ubi/build.c @@ -115,7 +115,7 @@ static struct ubi_device *ubi_devices[UBI_MAX_DEVICES]; #else struct ubi_device *ubi_devices[UBI_MAX_DEVICES]; #endif - + #ifndef __UBOOT__ /* Serializes UBI devices creations and removals */ DEFINE_MUTEX(ubi_devices_mutex); diff --git a/drivers/net/phy/meson-gxl.c b/drivers/net/phy/meson-gxl.c index ffb1a61402..753ca72768 100644 --- a/drivers/net/phy/meson-gxl.c +++ b/drivers/net/phy/meson-gxl.c @@ -73,7 +73,7 @@ restart_aneg:
if (!(wol & BIT(12)) || ((exp & EXPANSION_NWAY) && !(lpa & LPA_LPACK))) { - + /* Looks like aneg failed after all */ if (!retries) { printf("%s LPA corruption max attempts\n", diff --git a/drivers/ram/stm32_sdram.c b/drivers/ram/stm32_sdram.c index 3e25cc7a01..47a930ee95 100644 --- a/drivers/ram/stm32_sdram.c +++ b/drivers/ram/stm32_sdram.c @@ -286,7 +286,7 @@ static int stm32_fmc_of_to_plat(struct udevice *dev) } else { dev_dbg(dev, "cannot find st,mem_remap property\n"); } - + swp_fmc = dev_read_u32_default(dev, "st,swp_fmc", NOT_FOUND); if (swp_fmc != NOT_FOUND) { /* set fmc swapping selection */ diff --git a/drivers/reset/reset-meson.c b/drivers/reset/reset-meson.c index d4e0745d0e..5896bcb421 100644 --- a/drivers/reset/reset-meson.c +++ b/drivers/reset/reset-meson.c @@ -70,16 +70,16 @@ struct reset_ops meson_reset_ops = { .rst_deassert = meson_reset_deassert, };
-static const struct udevice_id meson_reset_ids[] = { - { .compatible = "amlogic,meson-gxbb-reset" }, +static const struct udevice_id meson_reset_ids[] = { + { .compatible = "amlogic,meson-gxbb-reset" }, { .compatible = "amlogic,meson-axg-reset" }, - { } -}; + { } +};
static int meson_reset_probe(struct udevice *dev) { struct meson_reset_priv *priv = dev_get_priv(dev); - + return regmap_init_mem(dev_ofnode(dev), &priv->regmap); }
diff --git a/drivers/serial/serial_msm.c b/drivers/serial/serial_msm.c index ac4d0824b9..a22623c316 100644 --- a/drivers/serial/serial_msm.c +++ b/drivers/serial/serial_msm.c @@ -233,7 +233,7 @@ static int msm_serial_of_to_plat(struct udevice *dev) if (priv->base == FDT_ADDR_T_NONE) return -EINVAL;
- priv->clk_bit_rate = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), + priv->clk_bit_rate = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), "bit-rate", UART_DM_CLK_RX_TX_BIT_RATE);
return 0; diff --git a/drivers/usb/dwc3/dwc3-meson-gxl.c b/drivers/usb/dwc3/dwc3-meson-gxl.c index 08467d6210..7c26290c15 100644 --- a/drivers/usb/dwc3/dwc3-meson-gxl.c +++ b/drivers/usb/dwc3/dwc3-meson-gxl.c @@ -170,7 +170,7 @@ static int dwc3_meson_gxl_usb2_init(struct dwc3_meson_gxl *priv) static int dwc3_meson_gxl_usb_init(struct dwc3_meson_gxl *priv) { int ret; - + ret = dwc3_meson_gxl_usb2_init(priv); if (ret) return ret; diff --git a/drivers/usb/musb-new/musb_regs.h b/drivers/usb/musb-new/musb_regs.h index e9362f6def..9fd01fafdf 100644 --- a/drivers/usb/musb-new/musb_regs.h +++ b/drivers/usb/musb-new/musb_regs.h @@ -190,7 +190,7 @@
/* SUNXI has different reg addresses, but identical r/w functions */ -#ifndef CONFIG_ARCH_SUNXI +#ifndef CONFIG_ARCH_SUNXI
/* * Common USB registers diff --git a/drivers/usb/musb-new/musb_uboot.c b/drivers/usb/musb-new/musb_uboot.c index 8ac2f0a78a..61ff68def2 100644 --- a/drivers/usb/musb-new/musb_uboot.c +++ b/drivers/usb/musb-new/musb_uboot.c @@ -159,7 +159,7 @@ static struct int_queue *_musb_create_int_queue(struct musb_host_data *host, static int _musb_destroy_int_queue(struct musb_host_data *host, struct usb_device *dev, struct int_queue *queue) { - int index = usb_pipein(queue->urb.pipe) * 16 + + int index = usb_pipein(queue->urb.pipe) * 16 + usb_pipeendpoint(queue->urb.pipe);
if (queue->urb.status == -EINPROGRESS) diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index afbc648883..ffed3b82be 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -327,7 +327,7 @@ static int ctrlreq_out_data_phase(struct usb_device *dev, u32 len, void *buffer)
/* Set TXPKTRDY bit */ csr = readw(&musbr->txcsr); - + csr |= MUSB_CSR0_TXPKTRDY; csr |= MUSB_CSR0_H_DIS_PING; writew(csr, &musbr->txcsr); diff --git a/drivers/video/anx9804.c b/drivers/video/anx9804.c index b050c4292f..3037ff39b4 100644 --- a/drivers/video/anx9804.c +++ b/drivers/video/anx9804.c @@ -67,11 +67,11 @@ void anx9804_init(unsigned int i2c_bus, u8 lanes, u8 data_rate, int bpp) printf("Error anx9804 clock is not stable\n");
i2c_reg_write(0x39, ANX9804_VID_CTRL2_REG, colordepth); - + /* Set a bunch of analog related register values */ - i2c_reg_write(0x38, ANX9804_PLL_CTRL_REG, 0x07); - i2c_reg_write(0x39, ANX9804_PLL_FILTER_CTRL3, 0x19); - i2c_reg_write(0x39, ANX9804_PLL_CTRL3, 0xd9); + i2c_reg_write(0x38, ANX9804_PLL_CTRL_REG, 0x07); + i2c_reg_write(0x39, ANX9804_PLL_FILTER_CTRL3, 0x19); + i2c_reg_write(0x39, ANX9804_PLL_CTRL3, 0xd9); i2c_reg_write(0x39, ANX9804_RST_CTRL2_REG, ANX9804_RST_CTRL2_AC_MODE); i2c_reg_write(0x39, ANX9804_ANALOG_DEBUG_REG1, 0xf0); i2c_reg_write(0x39, ANX9804_ANALOG_DEBUG_REG3, 0x99); @@ -105,7 +105,7 @@ void anx9804_init(unsigned int i2c_bus, u8 lanes, u8 data_rate, int bpp) i2c_reg_write(0x38, ANX9804_LINK_BW_SET_REG, data_rate); i2c_reg_write(0x38, ANX9804_LANE_COUNT_SET_REG, lanes);
- /* Link training */ + /* Link training */ i2c_reg_write(0x38, ANX9804_LINK_TRAINING_CTRL_REG, ANX9804_LINK_TRAINING_CTRL_EN); mdelay(5); diff --git a/drivers/video/tdo-tl070wsh30.c b/drivers/video/tdo-tl070wsh30.c index 813b87a681..7ad0af73f0 100644 --- a/drivers/video/tdo-tl070wsh30.c +++ b/drivers/video/tdo-tl070wsh30.c @@ -118,7 +118,7 @@ static int tl070wsh30_panel_probe(struct udevice *dev)
/* reset panel */ dm_gpio_set_value(&priv->reset, true); - + mdelay(10);
dm_gpio_set_value(&priv->reset, false); diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index bfe83b8cba..835a760e3d 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -109,7 +109,7 @@ #ifdef CONFIG_MX6UL # define DRAM_OFFSET(x) 0x87##x # define FDT_ADDR __stringify(DRAM_OFFSET(800000)) -#else +#else # define DRAM_OFFSET(x) 0x1##x # define FDT_ADDR __stringify(DRAM_OFFSET(8000000)) #endif diff --git a/include/linux/mtd/rawnand.h b/include/linux/mtd/rawnand.h index 66febc6b72..b1417f4d05 100644 --- a/include/linux/mtd/rawnand.h +++ b/include/linux/mtd/rawnand.h @@ -945,7 +945,7 @@ struct nand_chip { int jedec_version; struct nand_onfi_params onfi_params; struct nand_jedec_params jedec_params; - + struct nand_data_interface *data_interface;
int read_retries; diff --git a/include/linux/serial_reg.h b/include/linux/serial_reg.h index dca7efa142..20ea54397f 100644 --- a/include/linux/serial_reg.h +++ b/include/linux/serial_reg.h @@ -3,7 +3,7 @@ * include/linux/serial_reg.h * * Copyright (C) 1992, 1994 by Theodore Ts'o. - * + * * These are the UART port assignments, expressed as offsets from the base * register. These assignments should hold for any serial port based on * a 8250, 16450, or 16550(A). @@ -88,7 +88,7 @@
#define UART_LCR 3 /* Out: Line Control Register */ /* - * Note: if the word length is 5 bits (UART_LCR_WLEN5), then setting + * Note: if the word length is 5 bits (UART_LCR_WLEN5), then setting * UART_LCR_STOP will select 1.5 stop bits, not 2 stop bits. */ #define UART_LCR_DLAB 0x80 /* Divisor latch access bit */ diff --git a/scripts/kconfig/gconf.c b/scripts/kconfig/gconf.c index a9e48cc7b5..2ec7419301 100644 --- a/scripts/kconfig/gconf.c +++ b/scripts/kconfig/gconf.c @@ -639,7 +639,7 @@ on_set_option_mode3_activate(GtkMenuItem *menuitem, gpointer user_data) void on_introduction1_activate(GtkMenuItem * menuitem, gpointer user_data) { GtkWidget *dialog; - const gchar *intro_text = + const gchar *intro_text = "Welcome to gkc, the GTK+ graphical configuration tool\n" "For each option, a blank box indicates the feature is disabled, a\n" "check indicates it is enabled, and a dot indicates that it is to\n" diff --git a/tools/asn1_compiler.c b/tools/asn1_compiler.c index adabd41452..03fb7e0375 100644 --- a/tools/asn1_compiler.c +++ b/tools/asn1_compiler.c @@ -427,7 +427,7 @@ static void tokenise(char *buffer, char *end) } memcpy(tokens[tix].content, start, tokens[tix].size); tokens[tix].content[tokens[tix].size] = 0; - + /* If it begins with a lowercase letter then * it's an element name */ diff --git a/tools/patman/test/test01.txt b/tools/patman/test/test01.txt index b238a8b4ba..de2d9e4d28 100644 --- a/tools/patman/test/test01.txt +++ b/tools/patman/test/test01.txt @@ -3,15 +3,15 @@ Author: Simon Glass sjg@chromium.org Date: Sat Apr 15 15:39:08 2017 -0600
pci: Correct cast for sandbox - + This gives a warning with some native compilers: - + cmd/pci.c:152:11: warning: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘u64 {aka long unsigned int}’ [-Wformat=] - + Fix it with a cast. - + Signed-off-by: Simon Glass sjg@chromium.org Commit-changes: 2 - second revision change @@ -21,7 +21,7 @@ Date: Sat Apr 15 15:39:08 2017 -0600 about some things from the first commit END - + Commit-notes: Some notes about the first commit @@ -32,15 +32,15 @@ Author: Simon Glass sjg@chromium.org Date: Sat Apr 15 15:39:08 2017 -0600
fdt: Correct cast for sandbox in fdtdec_setup_mem_size_base() - + This gives a warning with some native compilers: - + lib/fdtdec.c:1203:8: warning: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘long unsigned int’ [-Wformat=] - + Fix it with a cast. - + Signed-off-by: Simon Glass sjg@chromium.org Series-to: u-boot Series-prefix: RFC @@ -60,7 +60,7 @@ Date: Sat Apr 15 15:39:08 2017 -0600
Cover-changes: 4 - Some notes for the cover letter - + Cover-letter: test: A test patch series This is a test of how the cover
On Mon, 27 Sept 2021 at 09:43, Wolfgang Denk wd@denx.de wrote:
nit: commit message
The spaces in test01.txt were generated by 'git log' and don't seem to be needed to run the test.
On Mon, Sep 27, 2021 at 05:42:38PM +0200, Wolfgang Denk wrote:
Signed-off-by: Wolfgang Denk wd@denx.de Reviewed-by: Simon Glass sjg@chromium.org
Signed-off-by: Wolfgang Denk wd@denx.de --- Makefile | 2 +- arch/arc/lib/libgcc2.h | 2 +- arch/arm/cpu/arm926ejs/armada100/timer.c | 2 +- arch/arm/cpu/armv8/fel_utils.S | 20 +- .../cpu/armv8/fsl-layerscape/doc/README.lsch3 | 36 +- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 4 +- arch/arm/dts/vf610-pinfunc.h | 2 +- arch/arm/include/asm/arch-armada100/mfp.h | 2 +- arch/arm/include/asm/arch-mx25/imx-regs.h | 22 +- arch/arm/include/asm/arch-mx5/imx-regs.h | 4 +- arch/arm/include/asm/arch-mx6/mx6_plugin.S | 4 +- arch/arm/include/asm/arch-mx7/mx7_plugin.S | 2 +- .../include/asm/arch-mx7ulp/mx7ulp_plugin.S | 2 +- .../include/asm/arch-rockchip/cru_rk3368.h | 16 +- arch/arm/include/asm/arch-vf610/iomux-vf610.h | 8 +- arch/arm/include/asm/macro.h | 2 +- arch/arm/include/asm/ti-common/davinci_nand.h | 6 +- arch/arm/lib/ccn504.S | 2 +- arch/arm/lib/div64.S | 10 +- arch/arm/mach-at91/include/mach/at91_mc.h | 24 +- arch/arm/mach-at91/include/mach/at91_st.h | 2 +- .../arm/mach-davinci/include/mach/da8xx-usb.h | 36 +- .../mach-davinci/include/mach/davinci_misc.h | 2 +- arch/arm/mach-imx/Makefile | 4 +- .../arm/mach-keystone/include/mach/hardware.h | 6 +- arch/arm/mach-omap2/clocks-common.c | 2 +- arch/arm/mach-omap2/omap5/prcm-regs.c | 2 +- arch/arm/mach-orion5x/timer.c | 2 +- arch/arm/mach-rmobile/pfc-r8a7790.h | 2 +- arch/arm/mach-rockchip/rk3368/Makefile | 2 +- arch/arm/mach-s5pc1xx/include/mach/sromc.h | 4 +- .../include/mach/fpga_manager_arria10.h | 16 +- arch/arm/mach-sunxi/dram_sun4i.c | 2 +- arch/arm/mach-sunxi/dram_sun8i_a33.c | 4 +- .../mach-sunxi/dram_timings/h6_ddr3_1333.c | 2 +- arch/m68k/cpu/mcf5227x/start.S | 4 +- arch/m68k/cpu/mcf523x/cpu.c | 2 +- arch/m68k/cpu/mcf52x2/cpu.c | 2 +- arch/m68k/cpu/mcf532x/cpu.c | 2 +- arch/m68k/cpu/mcf5445x/cpu.c | 2 +- arch/m68k/cpu/mcf5445x/start.S | 6 +- arch/m68k/include/asm/m5271.h | 2 +- arch/m68k/lib/muldi3.c | 2 +- arch/mips/include/asm/mipsregs.h | 32 +- arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S | 6 +- arch/nds32/cpu/n1213/ag101/lowlevel_init.S | 6 +- arch/nds32/cpu/n1213/ag101/watchdog.S | 2 +- arch/nds32/cpu/n1213/start.S | 8 +- arch/powerpc/cpu/mpc83xx/pcie.c | 4 +- arch/powerpc/cpu/mpc85xx/start.S | 8 +- arch/powerpc/include/asm/fsl_lbc.h | 4 +- arch/powerpc/include/asm/immap_85xx.h | 4 +- arch/powerpc/include/asm/processor.h | 2 +- arch/sandbox/include/asm/gpio.h | 2 +- arch/x86/cpu/intel_common/car2.S | 2 +- arch/x86/lib/bios_asm.S | 4 +- arch/xtensa/include/asm/arch-dc233c/core.h | 44 +- arch/xtensa/include/asm/arch-de212/core.h | 52 +- arch/xtensa/lib/Makefile | 2 +- board/Marvell/guruplug/guruplug.c | 2 +- board/boundary/nitrogen6x/README | 2 +- board/freescale/ls1012afrdm/README | 4 +- board/freescale/ls1012aqds/README | 4 +- board/freescale/ls1012ardb/README | 8 +- board/freescale/ls1046afrwy/README | 4 +- board/freescale/ls1046aqds/README | 4 +- board/freescale/ls1046ardb/README | 6 +- board/freescale/m53017evb/README | 2 +- board/logicpd/am3517evm/am3517evm.h | 2 +- board/logicpd/omap3som/omap3logic.h | 2 +- board/sysam/stmark2/sbf_dram_init.S | 2 +- board/ti/am57xx/board.c | 24 +- board/ti/am57xx/mux_data.h | 4 +- cmd/cramfs.c | 2 +- cmd/spi.c | 6 +- common/hash.c | 2 +- common/hwconfig.c | 2 +- common/usb_storage.c | 2 +- disk/Makefile | 2 +- doc/README.commands.spl | 6 +- doc/README.falcon | 4 +- doc/README.odroid | 4 +- .../mailbox/k3-secure-proxy.txt | 2 +- .../memory-controller/k3-j721e-ddrss.txt | 2 +- .../memory-controllers/k3-am654-ddrss.txt | 2 +- doc/device-tree-bindings/net/altera_tse.txt | 2 +- .../net/fsl,mcf-dma-fec.txt | 2 +- doc/device-tree-bindings/net/fsl,mcf-fec.txt | 2 +- .../pinctrl/bcm6838-pinctrl.txt | 2 +- .../pinctrl/marvell,armada-apn806-pinctrl.txt | 14 +- .../pinctrl/marvell,mvebu-pinctrl.txt | 2 +- .../regulator/fsl,anatop-regulator.txt | 14 +- doc/device-tree-bindings/spi/spi-bus.txt | 14 +- doc/device-tree-bindings/spi/spi-qup.txt | 2 +- doc/device-tree-bindings/tpm2/sandbox.txt | 2 +- drivers/cache/cache-v5l2.c | 4 +- drivers/cache/sandbox_cache.c | 2 +- drivers/clk/imx/clk-pllv3.c | 2 +- drivers/crypto/Makefile | 2 +- drivers/ddr/fsl/ddr3_dimm_params.c | 18 +- drivers/ddr/marvell/axp/ddr3_spd.c | 2 +- drivers/firmware/scmi/Makefile | 2 +- drivers/i2c/designware_i2c.h | 2 +- drivers/misc/atsha204a-i2c.c | 30 +- drivers/misc/cros_ec.c | 2 +- drivers/mmc/Makefile | 2 +- drivers/mmc/mmc.c | 2 +- drivers/mtd/mtdcore.c | 4 +- drivers/mtd/nand/raw/davinci_nand.c | 2 +- drivers/mtd/nand/raw/fsl_elbc_nand.c | 2 +- drivers/mtd/nand/raw/nand_base.c | 10 +- drivers/mtd/nand/raw/nand_ids.c | 2 +- drivers/mtd/onenand/onenand_base.c | 4 +- drivers/mtd/spi/spi-nor-ids.c | 2 +- drivers/mtd/ubi/crc32.c | 32 +- drivers/net/at91_emac.c | 2 +- drivers/net/calxedaxgmac.c | 2 +- drivers/net/dm9000x.c | 4 +- drivers/net/e1000.h | 2 +- drivers/net/smc911x.h | 4 +- drivers/net/sun8i_emac.c | 2 +- drivers/pci/fsl_pci_init.c | 2 +- drivers/pinctrl/meson/pinctrl-meson-axg.c | 2 +- drivers/pinctrl/meson/pinctrl-meson-g12a.c | 2 +- drivers/pinctrl/renesas/pfc-r8a77970.c | 2 +- drivers/pinctrl/renesas/pfc-r8a77980.c | 6 +- drivers/power/pmic/pmic_tps65910.c | 2 +- drivers/pwm/pwm-meson.c | 2 +- drivers/ram/k3-ddrss/k3-ddrss.c | 4 +- drivers/spi/atcspi200_spi.c | 2 +- drivers/thermal/imx_tmu.c | 4 +- drivers/timer/atmel_pit_timer.c | 2 +- drivers/usb/dwc3/core.h | 12 +- drivers/usb/dwc3/gadget.c | 2 +- drivers/usb/gadget/at91_udc.h | 2 +- drivers/usb/gadget/pxa27x_udc.c | 2 +- drivers/usb/host/xhci-rcar-r8a779x_usb3_v3.h | 2 +- drivers/usb/musb-new/musb_gadget.c | 4 +- drivers/usb/musb/musb_core.h | 10 +- drivers/usb/musb/musb_hcd.c | 2 +- drivers/video/bus_vcxk.c | 10 +- drivers/video/mxsfb.c | 2 +- drivers/watchdog/orion_wdt.c | 4 +- fs/btrfs/btrfs.c | 2 +- fs/jffs2/summary.h | 10 +- fs/ubifs/ubifs.h | 10 +- include/atsha204a-i2c.h | 4 +- include/configs/at91sam9263ek.h | 4 +- include/configs/controlcenterdc.h | 2 +- include/configs/corenet_ds.h | 2 +- include/configs/imx7-cm.h | 6 +- include/configs/ls1043a_common.h | 2 +- include/configs/novena.h | 2 +- include/configs/omap3_beagle.h | 2 +- include/configs/opos6uldev.h | 2 +- include/configs/socrates.h | 10 +- include/div64.h | 2 +- include/dt-bindings/mfd/dbx500-prcmu.h | 104 ++-- include/environment/distro/sf.h | 14 +- include/faraday/ftpmu010.h | 2 +- include/fsl_qe.h | 2 +- include/fsl_wdog.h | 2 +- include/generic-phy.h | 2 +- include/imximage.h | 2 +- include/linux/apm_bios.h | 2 +- include/linux/compiler.h | 2 +- include/linux/ioport.h | 2 +- include/linux/list.h | 4 +- include/linux/mtd/doc2000.h | 6 +- include/linux/mtd/partitions.h | 10 +- include/linux/screen_info.h | 4 +- include/linux/serial_reg.h | 2 +- include/linux/usb/gadget.h | 6 +- include/mc13783.h | 2 +- include/mpc85xx.h | 6 +- include/mtd/mtd-abi.h | 2 +- include/mvmfp.h | 2 +- include/part.h | 2 +- include/phy.h | 4 +- include/tsec.h | 2 +- include/video_font_4x6.h | 512 +++++++++--------- scripts/basic/Makefile | 2 +- scripts/kconfig/Makefile | 2 +- scripts/kconfig/expr.c | 2 +- scripts/kconfig/list.h | 2 +- tools/kwbimage.h | 4 +- 186 files changed, 811 insertions(+), 811 deletions(-)
diff --git a/Makefile b/Makefile index e2f5d47d1f..4b5f53f951 100644 --- a/Makefile +++ b/Makefile @@ -1756,7 +1756,7 @@ endif # May be overridden by arch/$(ARCH)/config.mk ifdef CONFIG_LTO quiet_cmd_u-boot__ ?= LTO $@ - cmd_u-boot__ ?= \ + cmd_u-boot__ ?= \ $(CC) -nostdlib -nostartfiles \ $(LTO_FINAL_LDFLAGS) $(c_flags) \ $(KBUILD_LDFLAGS:%=-Wl,%) $(LDFLAGS_u-boot:%=-Wl,%) -o $@ \ diff --git a/arch/arc/lib/libgcc2.h b/arch/arc/lib/libgcc2.h index 9c3ce99892..95eb9b0524 100644 --- a/arch/arc/lib/libgcc2.h +++ b/arch/arc/lib/libgcc2.h @@ -35,7 +35,7 @@ typedef int HItype __attribute__ ((mode (HI))); typedef unsigned int UHItype __attribute__ ((mode (HI))); #if MIN_UNITS_PER_WORD > 1 /* These typedefs are usually forbidden on dsp's with UNITS_PER_WORD 1. */ -typedef int SItype __attribute__ ((mode (SI))); +typedef int SItype __attribute__ ((mode (SI))); typedef unsigned int USItype __attribute__ ((mode (SI))); #if __SIZEOF_LONG_LONG__ > 4 /* These typedefs are usually forbidden on archs with UNITS_PER_WORD 2. */ diff --git a/arch/arm/cpu/arm926ejs/armada100/timer.c b/arch/arm/cpu/arm926ejs/armada100/timer.c index 6d77ad3b6d..4b96d4aa91 100644 --- a/arch/arm/cpu/arm926ejs/armada100/timer.c +++ b/arch/arm/cpu/arm926ejs/armada100/timer.c @@ -45,7 +45,7 @@ struct armd1tmr_registers { #define TIMER 0 /* Use TIMER 0 */ /* Each timer has 3 match registers */ #define MATCH_CMP(x) ((3 * TIMER) + x) -#define TIMER_LOAD_VAL 0xffffffff +#define TIMER_LOAD_VAL 0xffffffff #define COUNT_RD_REQ 0x1
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/cpu/armv8/fel_utils.S b/arch/arm/cpu/armv8/fel_utils.S index 7def44ad1d..5266515f14 100644 --- a/arch/arm/cpu/armv8/fel_utils.S +++ b/arch/arm/cpu/armv8/fel_utils.S @@ -64,18 +64,18 @@ ENTRY(return_to_fel)
/* AArch32 code to restore the state from fel_stash and return back to FEL. */ back_in_32: - .word 0xe59f0028 // ldr r0, [pc, #40] ; load fel_stash address - .word 0xe5901008 // ldr r1, [r0, #8] - .word 0xe129f001 // msr CPSR_fc, r1 + .word 0xe59f0028 // ldr r0, [pc, #40] ; load fel_stash address + .word 0xe5901008 // ldr r1, [r0, #8] + .word 0xe129f001 // msr CPSR_fc, r1 .word 0xf57ff06f // isb - .word 0xe590d000 // ldr sp, [r0] - .word 0xe590e004 // ldr lr, [r0, #4] - .word 0xe5901010 // ldr r1, [r0, #16] - .word 0xee0c1f10 // mcr 15, 0, r1, cr12, cr0, {0} ; VBAR - .word 0xe590100c // ldr r1, [r0, #12] - .word 0xee011f10 // mcr 15, 0, r1, cr1, cr0, {0} ; SCTLR + .word 0xe590d000 // ldr sp, [r0] + .word 0xe590e004 // ldr lr, [r0, #4] + .word 0xe5901010 // ldr r1, [r0, #16] + .word 0xee0c1f10 // mcr 15, 0, r1, cr12, cr0, {0} ; VBAR + .word 0xe590100c // ldr r1, [r0, #12] + .word 0xee011f10 // mcr 15, 0, r1, cr1, cr0, {0} ; SCTLR .word 0xf57ff06f // isb - .word 0xe12fff1e // bx lr ; return to FEL + .word 0xe12fff1e // bx lr ; return to FEL fel_stash_addr: .word 0x00000000 // receives fel_stash addr, by AA64 code above ENDPROC(return_to_fel) diff --git a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch3 b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch3 index 6c98d99d0c..9119d60ffb 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch3 +++ b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch3 @@ -42,22 +42,22 @@ Flash Layout pre-silicon platforms (simulator and emulator):
------------------------- - | FIT Image | + | FIT Image | | (linux + DTB + RFS) | ------------------------- ----> 0x0120_0000 - | Debug Server FW | + | Debug Server FW | ------------------------- ----> 0x00C0_0000 - | AIOP FW | + | AIOP FW | ------------------------- ----> 0x0070_0000 - | MC FW | + | MC FW | ------------------------- ----> 0x006C_0000 - | MC DPL Blob | + | MC DPL Blob | ------------------------- ----> 0x0020_0000 - | BootLoader + Env| + | BootLoader + Env| ------------------------- ----> 0x0000_1000 - | PBI | + | PBI | ------------------------- ----> 0x0000_0080 - | RCW | + | RCW | ------------------------- ----> 0x0000_0000
32-MB NOR flash layout for pre-silicon platforms (simulator and emulator) @@ -70,45 +70,45 @@ Flash Layout ----------------------------------------- ----> 0x5_8790_0000 | | FIT Image (linux + DTB + RFS) (40M) | | ----------------------------------------- ----> 0x5_8510_0000 | - | PHY firmware (2M) | | + | PHY firmware (2M) | | ----------------------------------------- ----> 0x5_84F0_0000 | 64K | Debug Server FW (2M) | | Alt ----------------------------------------- ----> 0x5_84D0_0000 | Bank | AIOP FW (4M) | | ----------------------------------------- ----> 0x5_8490_0000 (vbank4) - | MC DPC Blob (1M) | | + | MC DPC Blob (1M) | | ----------------------------------------- ----> 0x5_8480_0000 | | MC DPL Blob (1M) | | ----------------------------------------- ----> 0x5_8470_0000 | - | MC FW (4M) | | + | MC FW (4M) | | ----------------------------------------- ----> 0x5_8430_0000 | - | BootLoader Environment (1M) | | + | BootLoader Environment (1M) | | ----------------------------------------- ----> 0x5_8420_0000 | | BootLoader (1M) | | ----------------------------------------- ----> 0x5_8410_0000 | - | RCW and PBI (1M) | | + | RCW and PBI (1M) | | ----------------------------------------- ----> 0x5_8400_0000 --- | .. Unused .. (7M) | | ----------------------------------------- ----> 0x5_8390_0000 | | FIT Image (linux + DTB + RFS) (40M) | | ----------------------------------------- ----> 0x5_8110_0000 | - | PHY firmware (2M) | | + | PHY firmware (2M) | | ----------------------------------------- ----> 0x5_80F0_0000 | 64K | Debug Server FW (2M) | | Bank ----------------------------------------- ----> 0x5_80D0_0000 | | AIOP FW (4M) | | ----------------------------------------- ----> 0x5_8090_0000 (vbank0) - | MC DPC Blob (1M) | | + | MC DPC Blob (1M) | | ----------------------------------------- ----> 0x5_8080_0000 | | MC DPL Blob (1M) | | ----------------------------------------- ----> 0x5_8070_0000 | - | MC FW (4M) | | + | MC FW (4M) | | ----------------------------------------- ----> 0x5_8030_0000 | - | BootLoader Environment (1M) | | + | BootLoader Environment (1M) | | ----------------------------------------- ----> 0x5_8020_0000 | | BootLoader (1M) | | ----------------------------------------- ----> 0x5_8010_0000 | - | RCW and PBI (1M) | | + | RCW and PBI (1M) | | ----------------------------------------- ----> 0x5_8000_0000 ---
128-MB NOR flash layout for QDS and RDB boards diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index d8803738f1..3aa1a9c3e5 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -250,7 +250,7 @@ ENTRY(lowlevel_init) * b. We use only Region0 whose NSAID write/read is EN * * NOTE: As per the CCSR map doc, TZASC 3 and TZASC 4 are just - * placeholders. + * placeholders. */
.macro tzasc_prog, xreg @@ -259,7 +259,7 @@ ENTRY(lowlevel_init) mov x16, #0x10000 mul x14, \xreg, x16 add x14, x14,x12 - mov x1, #0x8 + mov x1, #0x8 add x1, x1, x14
ldr w0, [x1] /* Filter 0 Gate Keeper Register */ diff --git a/arch/arm/dts/vf610-pinfunc.h b/arch/arm/dts/vf610-pinfunc.h index 9456719074..e079edf306 100644 --- a/arch/arm/dts/vf610-pinfunc.h +++ b/arch/arm/dts/vf610-pinfunc.h @@ -424,7 +424,7 @@ #define VF610_PAD_PTD29__FTM3_CH2 0x104 0x000 ALT4 0x0 #define VF610_PAD_PTD29__DSPI2_SIN 0x104 0x000 ALT5 0x0 #define VF610_PAD_PTD29__DEBUG_OUT11 0x104 0x000 ALT7 0x0 -#define VF610_PAD_PTD28__GPIO_66 0x108 0x000 ALT0 0x0 +#define VF610_PAD_PTD28__GPIO_66 0x108 0x000 ALT0 0x0 #define VF610_PAD_PTD28__FB_AD28 0x108 0x000 ALT1 0x0 #define VF610_PAD_PTD28__NF_IO12 0x108 0x000 ALT2 0x0 #define VF610_PAD_PTD28__I2C2_SCL 0x108 0x34C ALT3 0x1 diff --git a/arch/arm/include/asm/arch-armada100/mfp.h b/arch/arm/include/asm/arch-armada100/mfp.h index a808ee8574..cd837eaef4 100644 --- a/arch/arm/include/asm/arch-armada100/mfp.h +++ b/arch/arm/include/asm/arch-armada100/mfp.h @@ -17,7 +17,7 @@ /* * Frequently used MFP Configuration macros for all ARMADA100 family of SoCs * - * offset, pull,pF, drv,dF, edge,eF ,afn,aF + * offset, pull,pF, drv,dF, edge,eF ,afn,aF */ /* UART1 */ #define MFP107_UART1_TXD (MFP_REG(0x01ac) | MFP_AF1 | MFP_DRIVE_FAST) diff --git a/arch/arm/include/asm/arch-mx25/imx-regs.h b/arch/arm/include/asm/arch-mx25/imx-regs.h index 57809697c1..d5ea868c45 100644 --- a/arch/arm/include/asm/arch-mx25/imx-regs.h +++ b/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -50,11 +50,11 @@ struct ccm_regs {
/* Enhanced SDRAM Controller (ESDRAMC) registers */ struct esdramc_regs { - u32 ctl0; /* control 0 */ - u32 cfg0; /* configuration 0 */ - u32 ctl1; /* control 1 */ - u32 cfg1; /* configuration 1 */ - u32 misc; /* miscellaneous */ + u32 ctl0; /* control 0 */ + u32 cfg0; /* configuration 0 */ + u32 ctl1; /* control 1 */ + u32 cfg1; /* configuration 1 */ + u32 misc; /* miscellaneous */ u32 pad[3]; u32 cdly1; /* Delay Line 1 configuration debug */ u32 cdly2; /* delay line 2 configuration debug */ @@ -66,11 +66,11 @@ struct esdramc_regs {
/* General Purpose Timer (GPT) registers */ struct gpt_regs { - u32 ctrl; /* control */ - u32 pre; /* prescaler */ - u32 stat; /* status */ - u32 intr; /* interrupt */ - u32 cmp[3]; /* output compare 1-3 */ + u32 ctrl; /* control */ + u32 pre; /* prescaler */ + u32 stat; /* status */ + u32 intr; /* interrupt */ + u32 cmp[3]; /* output compare 1-3 */ u32 capt[2]; /* input capture 1-2 */ u32 counter; /* counter */ }; @@ -456,7 +456,7 @@ struct epit_regs { #define GPT_CTRL_TEN 1 /* Timer enable */
/* WDOG enable */ -#define WCR_WDE 0x04 +#define WCR_WDE 0x04 #define WSR_UNLOCK1 0x5555 #define WSR_UNLOCK2 0xAAAA
diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 2731b7fb59..f763749b03 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -43,7 +43,7 @@ #define MMC_SDHC1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00004000) #define MMC_SDHC2_BASE_ADDR (SPBA0_BASE_ADDR + 0x00008000) #define UART3_BASE (SPBA0_BASE_ADDR + 0x0000C000) -#define CSPI1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00010000) +#define CSPI1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00010000) #define SSI2_BASE_ADDR (SPBA0_BASE_ADDR + 0x00014000) #define MMC_SDHC3_BASE_ADDR (SPBA0_BASE_ADDR + 0x00020000) #define MMC_SDHC4_BASE_ADDR (SPBA0_BASE_ADDR + 0x00024000) @@ -97,7 +97,7 @@ #define IIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x00098000) #define CSU_BASE_ADDR (AIPS2_BASE_ADDR + 0x0009C000) #define ARM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A0000) -#define OWIRE_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A4000) +#define OWIRE_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A4000) #define FIRI_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A8000) #define CSPI2_BASE_ADDR (AIPS2_BASE_ADDR + 0x000AC000) #define SDMA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B0000) diff --git a/arch/arm/include/asm/arch-mx6/mx6_plugin.S b/arch/arm/include/asm/arch-mx6/mx6_plugin.S index 7e61d22ca7..4d12c6873b 100644 --- a/arch/arm/include/asm/arch-mx6/mx6_plugin.S +++ b/arch/arm/include/asm/arch-mx6/mx6_plugin.S @@ -7,10 +7,10 @@
#ifdef CONFIG_ROM_UNIFIED_SECTIONS #define ROM_API_TABLE_BASE_ADDR_LEGACY 0x180 -#define ROM_VERSION_OFFSET 0x80 +#define ROM_VERSION_OFFSET 0x80 #else #define ROM_API_TABLE_BASE_ADDR_LEGACY 0xC0 -#define ROM_VERSION_OFFSET 0x48 +#define ROM_VERSION_OFFSET 0x48 #endif #define ROM_API_TABLE_BASE_ADDR_MX6DQ_TO15 0xC4 #define ROM_API_TABLE_BASE_ADDR_MX6DL_TO12 0xC4 diff --git a/arch/arm/include/asm/arch-mx7/mx7_plugin.S b/arch/arm/include/asm/arch-mx7/mx7_plugin.S index c7a84e8caa..b552542e28 100644 --- a/arch/arm/include/asm/arch-mx7/mx7_plugin.S +++ b/arch/arm/include/asm/arch-mx7/mx7_plugin.S @@ -6,7 +6,7 @@ #include <config.h>
#define ROM_API_TABLE_BASE_ADDR_LEGACY 0x180 -#define ROM_VERSION_OFFSET 0x80 +#define ROM_VERSION_OFFSET 0x80 #define ROM_API_HWCNFG_SETUP_OFFSET 0x08
plugin_start: diff --git a/arch/arm/include/asm/arch-mx7ulp/mx7ulp_plugin.S b/arch/arm/include/asm/arch-mx7ulp/mx7ulp_plugin.S index bcc804b58f..5089b1d517 100644 --- a/arch/arm/include/asm/arch-mx7ulp/mx7ulp_plugin.S +++ b/arch/arm/include/asm/arch-mx7ulp/mx7ulp_plugin.S @@ -6,7 +6,7 @@ #include <config.h>
plugin_start: diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h index 316c67c62f..ed2a612185 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h @@ -126,17 +126,17 @@ enum { /* GLB_RST_CON */ PMU_GLB_SRST_CTRL_SHIFT = 2, PMU_GLB_SRST_CTRL_MASK = GENMASK(3, 2), - PMU_RST_BY_FST_GLB_SRST = 0, - PMU_RST_BY_SND_GLB_SRST = 1, + PMU_RST_BY_FST_GLB_SRST = 0, + PMU_RST_BY_SND_GLB_SRST = 1, PMU_RST_DISABLE = 2, WDT_GLB_SRST_CTRL_SHIFT = 1, WDT_GLB_SRST_CTRL_MASK = BIT(1), - WDT_TRIGGER_SND_GLB_SRST = 0, - WDT_TRIGGER_FST_GLB_SRST = 1, - TSADC_GLB_SRST_CTRL_SHIFT = 0, - TSADC_GLB_SRST_CTRL_MASK = BIT(0), - TSADC_TRIGGER_SND_GLB_SRST = 0, - TSADC_TRIGGER_FST_GLB_SRST = 1, + WDT_TRIGGER_SND_GLB_SRST = 0, + WDT_TRIGGER_FST_GLB_SRST = 1, + TSADC_GLB_SRST_CTRL_SHIFT = 0, + TSADC_GLB_SRST_CTRL_MASK = BIT(0), + TSADC_TRIGGER_SND_GLB_SRST = 0, + TSADC_TRIGGER_FST_GLB_SRST = 1,
}; #endif diff --git a/arch/arm/include/asm/arch-vf610/iomux-vf610.h b/arch/arm/include/asm/arch-vf610/iomux-vf610.h index 8ba03e5a17..94ab059745 100644 --- a/arch/arm/include/asm/arch-vf610/iomux-vf610.h +++ b/arch/arm/include/asm/arch-vf610/iomux-vf610.h @@ -163,13 +163,13 @@ enum { VF610_PAD_PTB24__NF_WE_B = IOMUX_PAD(0x0178, 0x0178, 5, __NA_, 0, VF610_NFC_CN_PAD_CTRL), VF610_PAD_PTB25__NF_CE0_B = IOMUX_PAD(0x017c, 0x017c, 5, __NA_, 0, VF610_NFC_CN_PAD_CTRL),
- VF610_PAD_PTB27__NF_RE_B = IOMUX_PAD(0x0184, 0x0184, 6, __NA_, 0, VF610_NFC_CN_PAD_CTRL), + VF610_PAD_PTB27__NF_RE_B = IOMUX_PAD(0x0184, 0x0184, 6, __NA_, 0, VF610_NFC_CN_PAD_CTRL),
- VF610_PAD_PTC26__NF_RB_B = IOMUX_PAD(0x018C, 0x018C, 5, __NA_, 0, VF610_NFC_RB_PAD_CTRL), + VF610_PAD_PTC26__NF_RB_B = IOMUX_PAD(0x018C, 0x018C, 5, __NA_, 0, VF610_NFC_RB_PAD_CTRL),
- VF610_PAD_PTC27__NF_ALE = IOMUX_PAD(0x0190, 0x0190, 6, __NA_, 0, VF610_NFC_CN_PAD_CTRL), + VF610_PAD_PTC27__NF_ALE = IOMUX_PAD(0x0190, 0x0190, 6, __NA_, 0, VF610_NFC_CN_PAD_CTRL),
- VF610_PAD_PTC28__NF_CLE = IOMUX_PAD(0x0194, 0x0194, 6, __NA_, 0, VF610_NFC_CN_PAD_CTRL), + VF610_PAD_PTC28__NF_CLE = IOMUX_PAD(0x0194, 0x0194, 6, __NA_, 0, VF610_NFC_CN_PAD_CTRL),
VF610_PAD_PTE0__DCU0_HSYNC = IOMUX_PAD(0x01a4, 0x01a4, 1, __NA_, 0, VF610_DCU_PAD_CTRL), VF610_PAD_PTE1__DCU0_VSYNC = IOMUX_PAD(0x01a8, 0x01a8, 1, __NA_, 0, VF610_DCU_PAD_CTRL), diff --git a/arch/arm/include/asm/macro.h b/arch/arm/include/asm/macro.h index 485310d660..590ac80a19 100644 --- a/arch/arm/include/asm/macro.h +++ b/arch/arm/include/asm/macro.h @@ -154,7 +154,7 @@ lr .req x30 orr \xreg1, \xreg1, \xreg2 cbz \xreg1, \master_label #else - b \master_label + b \master_label #endif .endm
diff --git a/arch/arm/include/asm/ti-common/davinci_nand.h b/arch/arm/include/asm/ti-common/davinci_nand.h index 28842c3b15..ffaac6840b 100644 --- a/arch/arm/include/asm/ti-common/davinci_nand.h +++ b/arch/arm/include/asm/ti-common/davinci_nand.h @@ -12,9 +12,9 @@ #include <linux/mtd/rawnand.h> #include <asm/arch/hardware.h>
-#define NAND_READ_START 0x00 -#define NAND_READ_END 0x30 -#define NAND_STATUS 0x70 +#define NAND_READ_START 0x00 +#define NAND_READ_END 0x30 +#define NAND_STATUS 0x70
#define MASK_CLE 0x10 #define MASK_ALE 0x08 diff --git a/arch/arm/lib/ccn504.S b/arch/arm/lib/ccn504.S index f2245872fc..c6ea3e3afc 100644 --- a/arch/arm/lib/ccn504.S +++ b/arch/arm/lib/ccn504.S @@ -12,7 +12,7 @@ /************************************************************************* * * void ccn504_add_masters_to_dvm(CCI_MN_BASE, CCI_MN_RNF_NODEID_LIST, - * CCI_MN_DVM_DOMAIN_CTL_SET); + * CCI_MN_DVM_DOMAIN_CTL_SET); * * Add fully-coherent masters to DVM domain * diff --git a/arch/arm/lib/div64.S b/arch/arm/lib/div64.S index 3ef1ce1fff..a83e337214 100644 --- a/arch/arm/lib/div64.S +++ b/arch/arm/lib/div64.S @@ -34,12 +34,12 @@ * This is meant to be used by do_div() from include/asm/div64.h only. * * Input parameters: - * xh-xl = dividend (clobbered) - * r4 = divisor (preserved) + * xh-xl = dividend (clobbered) + * r4 = divisor (preserved) * * Output values: - * yh-yl = result - * xh = remainder + * yh-yl = result + * xh = remainder * * Clobbered regs: xl, ip */ @@ -85,7 +85,7 @@ UNWIND(.fnstart) #endif
@ The division loop for needed upper bit positions. - @ Break out early if dividend reaches 0. + @ Break out early if dividend reaches 0. 2: cmp xh, yl orrcs yh, yh, ip subscs xh, xh, yl diff --git a/arch/arm/mach-at91/include/mach/at91_mc.h b/arch/arm/mach-at91/include/mach/at91_mc.h index 18b0e163c0..7cf6cdf310 100644 --- a/arch/arm/mach-at91/include/mach/at91_mc.h +++ b/arch/arm/mach-at91/include/mach/at91_mc.h @@ -16,7 +16,7 @@ #ifndef __ASSEMBLY__
typedef struct at91_ebi { - u32 csa; /* 0x00 Chip Select Assignment Register */ + u32 csa; /* 0x00 Chip Select Assignment Register */ u32 cfgr; /* 0x04 Configuration Register */ u32 reserved[2]; } at91_ebi_t; @@ -28,20 +28,20 @@ typedef struct at91_ebi { #define AT91_EBI_CSA_CS4A 0x0010
typedef struct at91_sdramc { - u32 mr; /* 0x00 SDRAMC Mode Register */ - u32 tr; /* 0x04 SDRAMC Refresh Timer Register */ - u32 cr; /* 0x08 SDRAMC Configuration Register */ - u32 ssr; /* 0x0C SDRAMC Self Refresh Register */ - u32 lpr; /* 0x10 SDRAMC Low Power Register */ - u32 ier; /* 0x14 SDRAMC Interrupt Enable Register */ - u32 idr; /* 0x18 SDRAMC Interrupt Disable Register */ - u32 imr; /* 0x1C SDRAMC Interrupt Mask Register */ - u32 icr; /* 0x20 SDRAMC Interrupt Status Register */ + u32 mr; /* 0x00 SDRAMC Mode Register */ + u32 tr; /* 0x04 SDRAMC Refresh Timer Register */ + u32 cr; /* 0x08 SDRAMC Configuration Register */ + u32 ssr; /* 0x0C SDRAMC Self Refresh Register */ + u32 lpr; /* 0x10 SDRAMC Low Power Register */ + u32 ier; /* 0x14 SDRAMC Interrupt Enable Register */ + u32 idr; /* 0x18 SDRAMC Interrupt Disable Register */ + u32 imr; /* 0x1C SDRAMC Interrupt Mask Register */ + u32 icr; /* 0x20 SDRAMC Interrupt Status Register */ u32 reserved[3]; } at91_sdramc_t;
typedef struct at91_smc { - u32 csr[8]; /* 0x00 SDRAMC Mode Register */ + u32 csr[8]; /* 0x00 SDRAMC Mode Register */ } at91_smc_t;
#define AT91_SMC_CSR_RWHOLD(x) ((x & 0x7) << 28) @@ -60,7 +60,7 @@ typedef struct at91_smc { #define AT91_SMC_CSR_NWS(x) (x & 0x7F)
typedef struct at91_bfc { - u32 mr; /* 0x00 SDRAMC Mode Register */ + u32 mr; /* 0x00 SDRAMC Mode Register */ } at91_bfc_t;
typedef struct at91_mc { diff --git a/arch/arm/mach-at91/include/mach/at91_st.h b/arch/arm/mach-at91/include/mach/at91_st.h index ec4658a391..f91cec98c9 100644 --- a/arch/arm/mach-at91/include/mach/at91_st.h +++ b/arch/arm/mach-at91/include/mach/at91_st.h @@ -24,6 +24,6 @@ typedef struct at91_st {
#define AT91_ST_WDMR_WDV(x) (x & 0xFFFF) #define AT91_ST_WDMR_RSTEN 0x00010000 -#define AT91_ST_WDMR_EXTEN 0x00020000 +#define AT91_ST_WDMR_EXTEN 0x00020000
#endif diff --git a/arch/arm/mach-davinci/include/mach/da8xx-usb.h b/arch/arm/mach-davinci/include/mach/da8xx-usb.h index 215706e172..99d403cef7 100644 --- a/arch/arm/mach-davinci/include/mach/da8xx-usb.h +++ b/arch/arm/mach-davinci/include/mach/da8xx-usb.h @@ -29,22 +29,22 @@ struct da8xx_usb_regs { dv_reg revision; dv_reg control; - dv_reg status; - dv_reg emulation; - dv_reg mode; - dv_reg autoreq; - dv_reg srpfixtime; - dv_reg teardown; - dv_reg intsrc; - dv_reg intsrc_set; - dv_reg intsrc_clr; - dv_reg intmsk; - dv_reg intmsk_set; - dv_reg intmsk_clr; - dv_reg intsrcmsk; - dv_reg eoi; - dv_reg intvector; - dv_reg grndis_size[4]; + dv_reg status; + dv_reg emulation; + dv_reg mode; + dv_reg autoreq; + dv_reg srpfixtime; + dv_reg teardown; + dv_reg intsrc; + dv_reg intsrc_set; + dv_reg intsrc_clr; + dv_reg intmsk; + dv_reg intmsk_set; + dv_reg intmsk_clr; + dv_reg intsrcmsk; + dv_reg eoi; + dv_reg intvector; + dv_reg grndis_size[4]; };
#define da8xx_usb_regs ((struct da8xx_usb_regs *)DA8XX_USB_OTG_BASE) @@ -68,13 +68,13 @@ struct da8xx_usb_regs { #define CFGCHIP2_OTGMODE (3 << 13) #define CFGCHIP2_NO_OVERRIDE (0 << 13) #define CFGCHIP2_FORCE_HOST (1 << 13) -#define CFGCHIP2_FORCE_DEVICE (2 << 13) +#define CFGCHIP2_FORCE_DEVICE (2 << 13) #define CFGCHIP2_FORCE_HOST_VBUS_LOW (3 << 13) #define CFGCHIP2_USB1PHYCLKMUX (1 << 12) #define CFGCHIP2_USB2PHYCLKMUX (1 << 11) #define CFGCHIP2_PHYPWRDN (1 << 10) #define CFGCHIP2_OTGPWRDN (1 << 9) -#define CFGCHIP2_DATPOL (1 << 8) +#define CFGCHIP2_DATPOL (1 << 8) #define CFGCHIP2_USB1SUSPENDM (1 << 7) #define CFGCHIP2_PHY_PLLON (1 << 6) /* override PLL suspend */ #define CFGCHIP2_SESENDEN (1 << 5) /* Vsess_end comparator */ diff --git a/arch/arm/mach-davinci/include/mach/davinci_misc.h b/arch/arm/mach-davinci/include/mach/davinci_misc.h index 48b11f7a5c..54098a227e 100644 --- a/arch/arm/mach-davinci/include/mach/davinci_misc.h +++ b/arch/arm/mach-davinci/include/mach/davinci_misc.h @@ -23,7 +23,7 @@ struct pinmux_config { /* pin table definition */ struct pinmux_resource { const struct pinmux_config *pins; - const int n_pins; + const int n_pins; };
#define PINMUX_ITEM(item) { \ diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 0ef269563d..63e28c635e 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -34,7 +34,7 @@ obj-$(CONFIG_CMD_PRIBLOB) += priblob.o obj-$(CONFIG_SPL_BUILD) += spl.o endif ifeq ($(SOC),$(filter $(SOC),mx7)) -obj-y += cpu.o +obj-y += cpu.o obj-$(CONFIG_SYS_I2C_MXC) += i2c-mxv7.o obj-$(CONFIG_ENV_IS_IN_MMC) += mmc_env.o obj-$(CONFIG_FSL_MFGPROT) += cmd_mfgprot.o @@ -43,7 +43,7 @@ ifeq ($(SOC),$(filter $(SOC),mx5 mx6 mx7)) obj-$(CONFIG_IMX_VIDEO_SKIP) += video.o endif ifeq ($(SOC),$(filter $(SOC),mx6 mx7)) -obj-y += cache.o init.o +obj-y += cache.o init.o obj-$(CONFIG_FEC_MXC) += mac.o obj-$(CONFIG_IMX_RDC) += rdc-sema.o ifneq ($(CONFIG_SPL_BUILD),y) diff --git a/arch/arm/mach-keystone/include/mach/hardware.h b/arch/arm/mach-keystone/include/mach/hardware.h index 0c5dc6a739..98a8f058df 100644 --- a/arch/arm/mach-keystone/include/mach/hardware.h +++ b/arch/arm/mach-keystone/include/mach/hardware.h @@ -148,8 +148,8 @@ typedef volatile unsigned int *dv_reg_p; #define KS2_CIC_HOST_ENABLE_IDX_SET 0x34 #define KS2_CIC_CHAN_MAP(n) (0x0400 + (n << 2))
-#define KS2_UART0_BASE 0x02530c00 -#define KS2_UART1_BASE 0x02531000 +#define KS2_UART0_BASE 0x02530c00 +#define KS2_UART1_BASE 0x02531000
/* Boot Config */ #define KS2_DEVICE_STATE_CTRL_BASE 0x02620000 @@ -210,7 +210,7 @@ typedef volatile unsigned int *dv_reg_p; #endif
/* AEMIF */ -#define KS2_AEMIF_CNTRL_BASE 0x21000a00 +#define KS2_AEMIF_CNTRL_BASE 0x21000a00 #define DAVINCI_ASYNC_EMIF_CNTRL_BASE KS2_AEMIF_CNTRL_BASE
/* Flag from ks2_debug options to check if DSPs need to stay ON */ diff --git a/arch/arm/mach-omap2/clocks-common.c b/arch/arm/mach-omap2/clocks-common.c index 14b638a651..9120634f06 100644 --- a/arch/arm/mach-omap2/clocks-common.c +++ b/arch/arm/mach-omap2/clocks-common.c @@ -552,7 +552,7 @@ void scale_vcores(struct vcores_data const *vcores) if (pv->value[opp]) { /* Handle non-empty members only */ pv->value[opp] = optimize_vcore_voltage(pv, opp); - px = (struct volts *)vcores; + px = (struct volts *)vcores; j = 0; while (px < pv) { /* diff --git a/arch/arm/mach-omap2/omap5/prcm-regs.c b/arch/arm/mach-omap2/omap5/prcm-regs.c index b5baebc069..28c4f4f737 100644 --- a/arch/arm/mach-omap2/omap5/prcm-regs.c +++ b/arch/arm/mach-omap2/omap5/prcm-regs.c @@ -300,7 +300,7 @@ struct omap_sys_ctrl_regs const omap5_ctrl = { .control_std_fuse_die_id_1 = 0x4A002208, .control_std_fuse_die_id_2 = 0x4A00220C, .control_std_fuse_die_id_3 = 0x4A002210, - .control_phy_power_usb = 0x4A002370, + .control_phy_power_usb = 0x4A002370, .control_phy_power_sata = 0x4A002374, .control_padconf_core_base = 0x4A002800, .control_paconf_global = 0x4A002DA0, diff --git a/arch/arm/mach-orion5x/timer.c b/arch/arm/mach-orion5x/timer.c index 0adf3dcc64..d7ea2e3943 100644 --- a/arch/arm/mach-orion5x/timer.c +++ b/arch/arm/mach-orion5x/timer.c @@ -69,7 +69,7 @@ struct orion5x_tmr_registers *orion5x_tmr_regs = #define TVR_ARM_TIMER_OFFS 0 #define TVR_ARM_TIMER_MASK 0xffffffff #define TVR_ARM_TIMER_MAX 0xffffffff -#define TIMER_LOAD_VAL 0xffffffff +#define TIMER_LOAD_VAL 0xffffffff
static inline ulong read_timer(void) { diff --git a/arch/arm/mach-rmobile/pfc-r8a7790.h b/arch/arm/mach-rmobile/pfc-r8a7790.h index e911be4039..3b36548aec 100644 --- a/arch/arm/mach-rmobile/pfc-r8a7790.h +++ b/arch/arm/mach-rmobile/pfc-r8a7790.h @@ -82,7 +82,7 @@ PORT_1(fn, pfx##26, sfx), PORT_1(fn, pfx##27, sfx)
#define CPU_32_PORT0_16(fn, pfx, sfx) \ - PORT_10(fn, pfx, sfx), \ + PORT_10(fn, pfx, sfx), \ PORT_1(fn, pfx##10, sfx),PORT_1(fn, pfx##11, sfx), \ PORT_1(fn, pfx##12, sfx), PORT_1(fn, pfx##13, sfx), \ PORT_1(fn, pfx##14, sfx), PORT_1(fn, pfx##15, sfx), \ diff --git a/arch/arm/mach-rockchip/rk3368/Makefile b/arch/arm/mach-rockchip/rk3368/Makefile index 3bddc104a7..5910f20bff 100644 --- a/arch/arm/mach-rockchip/rk3368/Makefile +++ b/arch/arm/mach-rockchip/rk3368/Makefile @@ -3,4 +3,4 @@ # Copyright (c) 2016 Andreas Färber obj-y += clk_rk3368.o obj-y += rk3368.o -obj-y += syscon_rk3368.o +obj-y += syscon_rk3368.o diff --git a/arch/arm/mach-s5pc1xx/include/mach/sromc.h b/arch/arm/mach-s5pc1xx/include/mach/sromc.h index 45de4a799d..a8eb2a38b0 100644 --- a/arch/arm/mach-s5pc1xx/include/mach/sromc.h +++ b/arch/arm/mach-s5pc1xx/include/mach/sromc.h @@ -4,9 +4,9 @@ * Naveen Krishna Ch ch.naveen@samsung.com * * Note: This file contains the register description for Memory subsystem - * (SROM, NAND Flash, OneNand, DDR, OneDRAM) on S5PC1XX. + * (SROM, NAND Flash, OneNand, DDR, OneDRAM) on S5PC1XX. * - * Only SROMC is defined as of now + * Only SROMC is defined as of now */
#ifndef __ASM_ARCH_SROMC_H_ diff --git a/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h index 048708202c..7ab9517007 100644 --- a/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h @@ -14,8 +14,8 @@
#define ALT_FPGAMGR_IMGCFG_STAT_F2S_CRC_ERROR_SET_MSK BIT(0) #define ALT_FPGAMGR_IMGCFG_STAT_F2S_EARLY_USERMODE_SET_MSK BIT(1) -#define ALT_FPGAMGR_IMGCFG_STAT_F2S_USERMODE_SET_MSK BIT(2) -#define ALT_FPGAMGR_IMGCFG_STAT_F2S_INITDONE_OE_SET_MSK BIT(3) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_USERMODE_SET_MSK BIT(2) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_INITDONE_OE_SET_MSK BIT(3) #define ALT_FPGAMGR_IMGCFG_STAT_F2S_NSTATUS_PIN_SET_MSK BIT(4) #define ALT_FPGAMGR_IMGCFG_STAT_F2S_NSTATUS_OE_SET_MSK BIT(5) #define ALT_FPGAMGR_IMGCFG_STAT_F2S_CONDONE_PIN_SET_MSK BIT(6) @@ -26,9 +26,9 @@ #define ALT_FPGAMGR_IMGCFG_STAT_F2S_PR_ERROR_SET_MSK BIT(11) #define ALT_FPGAMGR_IMGCFG_STAT_F2S_NCONFIG_PIN_SET_MSK BIT(12) #define ALT_FPGAMGR_IMGCFG_STAT_F2S_NCEO_OE_SET_MSK BIT(13) -#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL0_SET_MSK BIT(16) -#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL1_SET_MSK BIT(17) -#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL2_SET_MSK BIT(18) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL0_SET_MSK BIT(16) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL1_SET_MSK BIT(17) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL2_SET_MSK BIT(18) #define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL_SET_MSD (\ ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL0_SET_MSK |\ ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL1_SET_MSK |\ @@ -50,9 +50,9 @@ #define ALT_FPGAMGR_IMGCFG_CTL_01_S2F_PR_REQUEST_SET_MSK BIT(16) #define ALT_FPGAMGR_IMGCFG_CTL_01_S2F_NCE_SET_MSK BIT(24)
-#define ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_CTRL_SET_MSK BIT(0) -#define ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_DATA_SET_MSK BIT(8) -#define ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_SET_MSK 0x00030000 +#define ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_CTRL_SET_MSK BIT(0) +#define ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_DATA_SET_MSK BIT(8) +#define ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_SET_MSK 0x00030000 #define ALT_FPGAMGR_IMGCFG_CTL_02_CFGWIDTH_SET_MSK BIT(24) #define ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_LSB 16
diff --git a/arch/arm/mach-sunxi/dram_sun4i.c b/arch/arm/mach-sunxi/dram_sun4i.c index 76d698214d..80a6c4bc0f 100644 --- a/arch/arm/mach-sunxi/dram_sun4i.c +++ b/arch/arm/mach-sunxi/dram_sun4i.c @@ -279,7 +279,7 @@ static void mctl_setup_dram_clock(u32 clk, u32 mbus_clk) reg_val |= CCM_PLL5_CTRL_M(CCM_PLL5_CTRL_M_X(2)); reg_val |= CCM_PLL5_CTRL_K(CCM_PLL5_CTRL_K_X(3)); reg_val |= CCM_PLL5_CTRL_N(CCM_PLL5_CTRL_N_X(11)); - } else { + } else { /* any other frequency that is a multiple of 24 */ reg_val |= CCM_PLL5_CTRL_M(CCM_PLL5_CTRL_M_X(2)); reg_val |= CCM_PLL5_CTRL_K(CCM_PLL5_CTRL_K_X(2)); diff --git a/arch/arm/mach-sunxi/dram_sun8i_a33.c b/arch/arm/mach-sunxi/dram_sun8i_a33.c index d99a38b10a..367b74061e 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a33.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a33.c @@ -126,8 +126,8 @@ static void auto_set_timing_para(struct dram_para *para) u32 tdinit3 = (1 * CONFIG_DRAM_CLK) + 1; /* 1us */
u8 twtp = tcwl + 2 + twr; /* WL + BL / 2 + tWR */ - u8 twr2rd = tcwl + 2 + twtr; /* WL + BL / 2 + tWTR */ - u8 trd2wr = tcl + 2 + 1 - tcwl; /* RL + BL / 2 + 2 - WL */ + u8 twr2rd = tcwl + 2 + twtr; /* WL + BL / 2 + tWTR */ + u8 trd2wr = tcl + 2 + 1 - tcwl; /* RL + BL / 2 + 2 - WL */
/* Set work mode register */ mctl_set_cr(para); diff --git a/arch/arm/mach-sunxi/dram_timings/h6_ddr3_1333.c b/arch/arm/mach-sunxi/dram_timings/h6_ddr3_1333.c index 611eaa3024..2136ca3a4c 100644 --- a/arch/arm/mach-sunxi/dram_timings/h6_ddr3_1333.c +++ b/arch/arm/mach-sunxi/dram_timings/h6_ddr3_1333.c @@ -30,7 +30,7 @@ * MR1: DLL enabled, output strength RZQ/6, Rtt_norm RZQ/2, * write levelling disabled, TDQS disabled, output buffer enabled * MR2: manual full array self refresh, dynamic ODT off, - * CAS write latency (CWL): 8 + * CAS write latency (CWL): 8 */ static u32 mr_ddr3[7] = { 0x00001c70, 0x00000040, 0x00000018, 0x00000000, diff --git a/arch/m68k/cpu/mcf5227x/start.S b/arch/m68k/cpu/mcf5227x/start.S index 86c93ba3fa..8ad9e65d9e 100644 --- a/arch/m68k/cpu/mcf5227x/start.S +++ b/arch/m68k/cpu/mcf5227x/start.S @@ -38,10 +38,10 @@ _vectors: #if defined(CONFIG_CF_SBF) INITSP: .long 0 /* Initial SP */ -INITPC: .long ASM_DRAMINIT /* Initial PC */ +INITPC: .long ASM_DRAMINIT /* Initial PC */ #else INITSP: .long 0 /* Initial SP */ -INITPC: .long _START /* Initial PC */ +INITPC: .long _START /* Initial PC */ #endif
vector02_0F: diff --git a/arch/m68k/cpu/mcf523x/cpu.c b/arch/m68k/cpu/mcf523x/cpu.c index 8d3ab6f3fb..e44656db5f 100644 --- a/arch/m68k/cpu/mcf523x/cpu.c +++ b/arch/m68k/cpu/mcf523x/cpu.c @@ -106,7 +106,7 @@ int watchdog_init(void) #if defined(CONFIG_MCFFEC) /* Default initializations for MCFFEC controllers. To override, * create a board-specific function called: - * int board_eth_init(struct bd_info *bis) + * int board_eth_init(struct bd_info *bis) */
int cpu_eth_init(struct bd_info *bis) diff --git a/arch/m68k/cpu/mcf52x2/cpu.c b/arch/m68k/cpu/mcf52x2/cpu.c index 0676e39141..8f72ef567f 100644 --- a/arch/m68k/cpu/mcf52x2/cpu.c +++ b/arch/m68k/cpu/mcf52x2/cpu.c @@ -421,7 +421,7 @@ int do_reset(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) #if defined(CONFIG_MCFFEC) /* Default initializations for MCFFEC controllers. To override, * create a board-specific function called: - * int board_eth_init(struct bd_info *bis) + * int board_eth_init(struct bd_info *bis) */
int cpu_eth_init(struct bd_info *bis) diff --git a/arch/m68k/cpu/mcf532x/cpu.c b/arch/m68k/cpu/mcf532x/cpu.c index d37dd3defb..1dadffd4ca 100644 --- a/arch/m68k/cpu/mcf532x/cpu.c +++ b/arch/m68k/cpu/mcf532x/cpu.c @@ -148,7 +148,7 @@ int watchdog_init(void) #if defined(CONFIG_MCFFEC) /* Default initializations for MCFFEC controllers. To override, * create a board-specific function called: - * int board_eth_init(struct bd_info *bis) + * int board_eth_init(struct bd_info *bis) */ int cpu_eth_init(struct bd_info *bis) { diff --git a/arch/m68k/cpu/mcf5445x/cpu.c b/arch/m68k/cpu/mcf5445x/cpu.c index ac1e591681..d9a71c6b92 100644 --- a/arch/m68k/cpu/mcf5445x/cpu.c +++ b/arch/m68k/cpu/mcf5445x/cpu.c @@ -110,7 +110,7 @@ int print_cpuinfo(void) #if defined(CONFIG_MCFFEC) /* Default initializations for MCFFEC controllers. To override, * create a board-specific function called: - * int board_eth_init(struct bd_info *bis) + * int board_eth_init(struct bd_info *bis) */
int cpu_eth_init(struct bd_info *bis) diff --git a/arch/m68k/cpu/mcf5445x/start.S b/arch/m68k/cpu/mcf5445x/start.S index 7007d78c83..c9f4145932 100644 --- a/arch/m68k/cpu/mcf5445x/start.S +++ b/arch/m68k/cpu/mcf5445x/start.S @@ -46,16 +46,16 @@ _vectors:
INITSP: .long 0 /* Initial SP */ #ifdef CONFIG_CF_SBF -INITPC: .long ASM_DRAMINIT /* Initial PC */ +INITPC: .long ASM_DRAMINIT /* Initial PC */ #endif #ifdef CONFIG_SYS_NAND_BOOT -INITPC: .long ASM_DRAMINIT_N /* Initial PC */ +INITPC: .long ASM_DRAMINIT_N /* Initial PC */ #endif
#else
#endif
diff --git a/arch/m68k/include/asm/m5271.h b/arch/m68k/include/asm/m5271.h index dce0d26a0f..7ebeddbb68 100644 --- a/arch/m68k/include/asm/m5271.h +++ b/arch/m68k/include/asm/m5271.h @@ -115,7 +115,7 @@ #define MCF_GPIO_PAR_TIMER 0x10004C
#define MCF_DSCR_EIM 0x100050 -#define MCF_DCSR_FEC12C 0x100052 +#define MCF_DCSR_FEC12C 0x100052 #define MCF_DCSR_UART 0x100053 #define MCF_DCSR_QSPI 0x100054 #define MCF_DCSR_TIMER 0x100055 diff --git a/arch/m68k/lib/muldi3.c b/arch/m68k/lib/muldi3.c index 23ef4b732a..c42ca1d753 100644 --- a/arch/m68k/lib/muldi3.c +++ b/arch/m68k/lib/muldi3.c @@ -41,7 +41,7 @@ umul_ppmm (__w.s.high, __w.s.low, u, v); \ __w.ll; })
-typedef int SItype __attribute__ ((mode (SI))); +typedef int SItype __attribute__ ((mode (SI))); typedef unsigned int USItype __attribute__ ((mode (SI))); typedef int DItype __attribute__ ((mode (DI))); typedef int word_type __attribute__ ((mode (__word__))); diff --git a/arch/mips/include/asm/mipsregs.h b/arch/mips/include/asm/mipsregs.h index e65485b4ff..3db3965fcf 100644 --- a/arch/mips/include/asm/mipsregs.h +++ b/arch/mips/include/asm/mipsregs.h @@ -2307,8 +2307,8 @@ do { \ " .set " MIPS_ISA_LEVEL " \n" \ " .set dsp \n" \ " mflo %0, $ac0 \n" \ - " .set pop \n" \ - : "=r" (mflo0)); \ + " .set pop \n" \ + : "=r" (mflo0)); \ mflo0; \ })
@@ -2320,8 +2320,8 @@ do { \ " .set " MIPS_ISA_LEVEL " \n" \ " .set dsp \n" \ " mflo %0, $ac1 \n" \ - " .set pop \n" \ - : "=r" (mflo1)); \ + " .set pop \n" \ + : "=r" (mflo1)); \ mflo1; \ })
@@ -2333,8 +2333,8 @@ do { \ " .set " MIPS_ISA_LEVEL " \n" \ " .set dsp \n" \ " mflo %0, $ac2 \n" \ - " .set pop \n" \ - : "=r" (mflo2)); \ + " .set pop \n" \ + : "=r" (mflo2)); \ mflo2; \ })
@@ -2346,8 +2346,8 @@ do { \ " .set " MIPS_ISA_LEVEL " \n" \ " .set dsp \n" \ " mflo %0, $ac3 \n" \ - " .set pop \n" \ - : "=r" (mflo3)); \ + " .set pop \n" \ + : "=r" (mflo3)); \ mflo3; \ })
@@ -2359,8 +2359,8 @@ do { \ " .set " MIPS_ISA_LEVEL " \n" \ " .set dsp \n" \ " mfhi %0, $ac0 \n" \ - " .set pop \n" \ - : "=r" (mfhi0)); \ + " .set pop \n" \ + : "=r" (mfhi0)); \ mfhi0; \ })
@@ -2372,8 +2372,8 @@ do { \ " .set " MIPS_ISA_LEVEL " \n" \ " .set dsp \n" \ " mfhi %0, $ac1 \n" \ - " .set pop \n" \ - : "=r" (mfhi1)); \ + " .set pop \n" \ + : "=r" (mfhi1)); \ mfhi1; \ })
@@ -2385,8 +2385,8 @@ do { \ " .set " MIPS_ISA_LEVEL " \n" \ " .set dsp \n" \ " mfhi %0, $ac2 \n" \ - " .set pop \n" \ - : "=r" (mfhi2)); \ + " .set pop \n" \ + : "=r" (mfhi2)); \ mfhi2; \ })
@@ -2398,8 +2398,8 @@ do { \ " .set " MIPS_ISA_LEVEL " \n" \ " .set dsp \n" \ " mfhi %0, $ac3 \n" \ - " .set pop \n" \ - : "=r" (mfhi3)); \ + " .set pop \n" \ + : "=r" (mfhi3)); \ mfhi3; \ })
diff --git a/arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S b/arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S index 507d79e77b..161d0a3f97 100644 --- a/arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S +++ b/arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S @@ -38,9 +38,9 @@ * for Orca and Emerald */ #define BOARD_ID_REG 0x104 -#define BOARD_ID_FAMILY_MASK 0xfff000 -#define BOARD_ID_FAMILY_V5 0x556000 -#define BOARD_ID_FAMILY_K7 0x74b000 +#define BOARD_ID_FAMILY_MASK 0xfff000 +#define BOARD_ID_FAMILY_V5 0x556000 +#define BOARD_ID_FAMILY_K7 0x74b000
/* * parameters for the static memory controller diff --git a/arch/nds32/cpu/n1213/ag101/lowlevel_init.S b/arch/nds32/cpu/n1213/ag101/lowlevel_init.S index 73f1f52056..ddd2363479 100644 --- a/arch/nds32/cpu/n1213/ag101/lowlevel_init.S +++ b/arch/nds32/cpu/n1213/ag101/lowlevel_init.S @@ -38,9 +38,9 @@ * for Orca and Emerald */ #define BOARD_ID_REG 0x104 -#define BOARD_ID_FAMILY_MASK 0xfff000 -#define BOARD_ID_FAMILY_V5 0x556000 -#define BOARD_ID_FAMILY_K7 0x74b000 +#define BOARD_ID_FAMILY_MASK 0xfff000 +#define BOARD_ID_FAMILY_V5 0x556000 +#define BOARD_ID_FAMILY_K7 0x74b000
/* * parameters for the static memory controller diff --git a/arch/nds32/cpu/n1213/ag101/watchdog.S b/arch/nds32/cpu/n1213/ag101/watchdog.S index 243096a663..8e7399d0df 100644 --- a/arch/nds32/cpu/n1213/ag101/watchdog.S +++ b/arch/nds32/cpu/n1213/ag101/watchdog.S @@ -16,7 +16,7 @@ ENTRY(turnoff_watchdog) #define WD_ENABLE 0x1
! Turn off the watchdog, according to Faraday FTWDT010 spec - li $p0, (CONFIG_FTWDT010_BASE+WD_CR) ! Get the addr of WD CR + li $p0, (CONFIG_FTWDT010_BASE+WD_CR) ! Get the addr of WD CR lwi $p1, [$p0] ! Get the config of WD andi $p1, $p1, 0x1f ! Wipe out useless bits li $r0, ~WD_ENABLE diff --git a/arch/nds32/cpu/n1213/start.S b/arch/nds32/cpu/n1213/start.S index 3395721552..e2bff037a9 100644 --- a/arch/nds32/cpu/n1213/start.S +++ b/arch/nds32/cpu/n1213/start.S @@ -20,7 +20,7 @@ */ #define ENA_DCAC 2UL #define DIS_DCAC ~ENA_DCAC -#define ICAC_MEM_KBF_ISET (0x07) ! I Cache sets per way +#define ICAC_MEM_KBF_ISET (0x07) ! I Cache sets per way #define ICAC_MEM_KBF_IWAY (0x07<<3) ! I cache ways #define ICAC_MEM_KBF_ISZ (0x07<<6) ! I cache line size #define DCAC_MEM_KBF_DSET (0x07) ! D Cache sets per way @@ -434,21 +434,21 @@ tlb_fill: SAVE_ALL move $r0, $sp ! To get the kernel stack li $r1, 1 ! Determine interruption type - bal do_interruption + bal do_interruption
.align 5 tlb_not_present: SAVE_ALL move $r0, $sp ! To get the kernel stack li $r1, 2 ! Determine interruption type - bal do_interruption + bal do_interruption
.align 5 tlb_misc: SAVE_ALL move $r0, $sp ! To get the kernel stack li $r1, 3 ! Determine interruption type - bal do_interruption + bal do_interruption
.align 5 tlb_vlpt_miss: diff --git a/arch/powerpc/cpu/mpc83xx/pcie.c b/arch/powerpc/cpu/mpc83xx/pcie.c index 84797c871c..6c9a6add09 100644 --- a/arch/powerpc/cpu/mpc83xx/pcie.c +++ b/arch/powerpc/cpu/mpc83xx/pcie.c @@ -91,8 +91,8 @@ static int pcie_##rw##_config_##size(struct pci_controller *hose, \ \ ret = mpc83xx_pcie_remap_cfg(hose, dev); \ if (ret) { \ - cfg_##rw##_err(val); \ - return ret; \ + cfg_##rw##_err(val); \ + return ret; \ } \ cfg_##rw(val, (void *)hose->cfg_addr + offset, type, op); \ return 0; \ diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index f41e82ad18..fa8d2e4cd5 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -77,7 +77,7 @@ _start_e500: /* Enable debug exception */ li r1,MSR_DE - mtmsr r1 + mtmsr r1
/* * If we got an ePAPR device tree pointer passed in as r3, we need that @@ -1164,9 +1164,9 @@ _start_cont:
li r0,0
-1: subi r4,r4,4 - stw r0,0(r4) - cmplw r4,r3 +1: subi r4,r4,4 + stw r0,0(r4) + cmplw r4,r3 bne 1b
#if CONFIG_VAL(SYS_MALLOC_F_LEN) diff --git a/arch/powerpc/include/asm/fsl_lbc.h b/arch/powerpc/include/asm/fsl_lbc.h index 3b26451928..5038cb9f59 100644 --- a/arch/powerpc/include/asm/fsl_lbc.h +++ b/arch/powerpc/include/asm/fsl_lbc.h @@ -294,8 +294,8 @@ void lbc_sdram_init(void); #define LBCR_EPAR_SHIFT 16 #define LBCR_BMT 0x0000FF00 #define LBCR_BMT_SHIFT 8 -#define LBCR_BMTPS 0x0000000F -#define LBCR_BMTPS_SHIFT 0 +#define LBCR_BMTPS 0x0000000F +#define LBCR_BMTPS_SHIFT 0
/* LCRR - Clock Ratio Register */ diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index f539c0be71..770705a879 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1510,7 +1510,7 @@ typedef struct par_io { */
typedef struct cpc_corenet { - u32 cpccsr0; /* Config/status reg */ + u32 cpccsr0; /* Config/status reg */ u32 res1; u32 cpccfg0; /* Configuration register */ u32 res2; @@ -1573,7 +1573,7 @@ typedef struct cpc_corenet { #define CPC_SRCR0_SRAMSZ_16_WAY 0x00000008 #define CPC_SRCR0_SRAMSZ_32_WAY 0x0000000a #define CPC_SRCR0_SRAMEN 0x00000001 -#define CPC_ERRDIS_TMHITDIS 0x00000080 /* multi-way hit disable */ +#define CPC_ERRDIS_TMHITDIS 0x00000080 /* multi-way hit disable */ #define CPC_HDBCR0_CDQ_SPEC_DIS 0x08000000 #define CPC_HDBCR0_TAG_ECC_SCRUB_DIS 0x01000000 #define CPC_HDBCR0_DATA_ECC_SCRUB_DIS 0x00400000 diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index e03ab21f59..2005c7389d 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -752,7 +752,7 @@ #define MAS5 SPRN_MAS5 #define MAS6 SPRN_MAS6 #define MAS7 SPRN_MAS7 -#define MAS8 SPRN_MAS8 +#define MAS8 SPRN_MAS8
#if defined(CONFIG_MPC85xx) #define DAR_DEAR DEAR diff --git a/arch/sandbox/include/asm/gpio.h b/arch/sandbox/include/asm/gpio.h index 9e10052667..9542fdee67 100644 --- a/arch/sandbox/include/asm/gpio.h +++ b/arch/sandbox/include/asm/gpio.h @@ -65,7 +65,7 @@ int sandbox_gpio_get_direction(struct udevice *dev, unsigned int offset); * * @param dev device to use * @param offset GPIO offset within bank - * @param output 0 to set as input, 1 to set as output + * @param output 0 to set as input, 1 to set as output * @return -1 on error, 0 if ok */ int sandbox_gpio_set_direction(struct udevice *dev, unsigned int offset, diff --git a/arch/x86/cpu/intel_common/car2.S b/arch/x86/cpu/intel_common/car2.S index 086f987477..f8cf78586d 100644 --- a/arch/x86/cpu/intel_common/car2.S +++ b/arch/x86/cpu/intel_common/car2.S @@ -88,7 +88,7 @@ clear_var_mtrr: * MTRR_PHYS_MASK_HIGH = 0000000FFh For 40 bit addressing */
- movl $0x80000008, %eax /* Address sizes leaf */ + movl $0x80000008, %eax /* Address sizes leaf */ cpuid sub $32, %al movzx %al, %eax diff --git a/arch/x86/lib/bios_asm.S b/arch/x86/lib/bios_asm.S index 62dc5652db..9e2a02658b 100644 --- a/arch/x86/lib/bios_asm.S +++ b/arch/x86/lib/bios_asm.S @@ -22,8 +22,8 @@ .globl __idt_handler __idt_handler: pushal - movb $0, %al /* This instruction gets modified */ - ljmp $0, $__interrupt_handler_16bit + movb $0, %al /* This instruction gets modified */ + ljmp $0, $__interrupt_handler_16bit .globl __idt_handler_size __idt_handler_size: .long . - __idt_handler diff --git a/arch/xtensa/include/asm/arch-dc233c/core.h b/arch/xtensa/include/asm/arch-dc233c/core.h index 4646cdbfb4..cd3c8c115f 100644 --- a/arch/xtensa/include/asm/arch-dc233c/core.h +++ b/arch/xtensa/include/asm/arch-dc233c/core.h @@ -263,28 +263,28 @@ EXCSAVE/EPS/EPC_n, RFI n) */
/* Type of each interrupt: */ -#define XCHAL_INT0_TYPE XTHAL_INTTYPE_EXTERN_LEVEL -#define XCHAL_INT1_TYPE XTHAL_INTTYPE_EXTERN_LEVEL -#define XCHAL_INT2_TYPE XTHAL_INTTYPE_EXTERN_LEVEL -#define XCHAL_INT3_TYPE XTHAL_INTTYPE_EXTERN_LEVEL -#define XCHAL_INT4_TYPE XTHAL_INTTYPE_EXTERN_LEVEL -#define XCHAL_INT5_TYPE XTHAL_INTTYPE_EXTERN_LEVEL -#define XCHAL_INT6_TYPE XTHAL_INTTYPE_TIMER -#define XCHAL_INT7_TYPE XTHAL_INTTYPE_SOFTWARE -#define XCHAL_INT8_TYPE XTHAL_INTTYPE_EXTERN_LEVEL -#define XCHAL_INT9_TYPE XTHAL_INTTYPE_EXTERN_LEVEL -#define XCHAL_INT10_TYPE XTHAL_INTTYPE_TIMER -#define XCHAL_INT11_TYPE XTHAL_INTTYPE_SOFTWARE -#define XCHAL_INT12_TYPE XTHAL_INTTYPE_EXTERN_LEVEL -#define XCHAL_INT13_TYPE XTHAL_INTTYPE_TIMER -#define XCHAL_INT14_TYPE XTHAL_INTTYPE_NMI -#define XCHAL_INT15_TYPE XTHAL_INTTYPE_EXTERN_EDGE -#define XCHAL_INT16_TYPE XTHAL_INTTYPE_EXTERN_EDGE -#define XCHAL_INT17_TYPE XTHAL_INTTYPE_EXTERN_EDGE -#define XCHAL_INT18_TYPE XTHAL_INTTYPE_EXTERN_EDGE -#define XCHAL_INT19_TYPE XTHAL_INTTYPE_EXTERN_EDGE -#define XCHAL_INT20_TYPE XTHAL_INTTYPE_EXTERN_EDGE -#define XCHAL_INT21_TYPE XTHAL_INTTYPE_EXTERN_EDGE +#define XCHAL_INT0_TYPE XTHAL_INTTYPE_EXTERN_LEVEL +#define XCHAL_INT1_TYPE XTHAL_INTTYPE_EXTERN_LEVEL +#define XCHAL_INT2_TYPE XTHAL_INTTYPE_EXTERN_LEVEL +#define XCHAL_INT3_TYPE XTHAL_INTTYPE_EXTERN_LEVEL +#define XCHAL_INT4_TYPE XTHAL_INTTYPE_EXTERN_LEVEL +#define XCHAL_INT5_TYPE XTHAL_INTTYPE_EXTERN_LEVEL +#define XCHAL_INT6_TYPE XTHAL_INTTYPE_TIMER +#define XCHAL_INT7_TYPE XTHAL_INTTYPE_SOFTWARE +#define XCHAL_INT8_TYPE XTHAL_INTTYPE_EXTERN_LEVEL +#define XCHAL_INT9_TYPE XTHAL_INTTYPE_EXTERN_LEVEL +#define XCHAL_INT10_TYPE XTHAL_INTTYPE_TIMER +#define XCHAL_INT11_TYPE XTHAL_INTTYPE_SOFTWARE +#define XCHAL_INT12_TYPE XTHAL_INTTYPE_EXTERN_LEVEL +#define XCHAL_INT13_TYPE XTHAL_INTTYPE_TIMER +#define XCHAL_INT14_TYPE XTHAL_INTTYPE_NMI +#define XCHAL_INT15_TYPE XTHAL_INTTYPE_EXTERN_EDGE +#define XCHAL_INT16_TYPE XTHAL_INTTYPE_EXTERN_EDGE +#define XCHAL_INT17_TYPE XTHAL_INTTYPE_EXTERN_EDGE +#define XCHAL_INT18_TYPE XTHAL_INTTYPE_EXTERN_EDGE +#define XCHAL_INT19_TYPE XTHAL_INTTYPE_EXTERN_EDGE +#define XCHAL_INT20_TYPE XTHAL_INTTYPE_EXTERN_EDGE +#define XCHAL_INT21_TYPE XTHAL_INTTYPE_EXTERN_EDGE
/* Masks of interrupts for each type of interrupt: */ #define XCHAL_INTTYPE_MASK_UNCONFIGURED 0xFFC00000 diff --git a/arch/xtensa/include/asm/arch-de212/core.h b/arch/xtensa/include/asm/arch-de212/core.h index 3271406291..60c6efba7d 100644 --- a/arch/xtensa/include/asm/arch-de212/core.h +++ b/arch/xtensa/include/asm/arch-de212/core.h @@ -108,8 +108,8 @@ #define XCHAL_HAVE_DFP_ACCEL 0 /* double precision FP acceleration pkg */ #define XCHAL_HAVE_DFP_accel XCHAL_HAVE_DFP_ACCEL /* for backward compatibility */
-#define XCHAL_HAVE_DFPU_SINGLE_ONLY 0 /* DFPU Coprocessor, single precision only */ -#define XCHAL_HAVE_DFPU_SINGLE_DOUBLE 0 /* DFPU Coprocessor, single and double precision */ +#define XCHAL_HAVE_DFPU_SINGLE_ONLY 0 /* DFPU Coprocessor, single precision only */ +#define XCHAL_HAVE_DFPU_SINGLE_DOUBLE 0 /* DFPU Coprocessor, single and double precision */ #define XCHAL_HAVE_VECTRA1 0 /* Vectra I pkg */ #define XCHAL_HAVE_VECTRALX 0 /* Vectra LX pkg */ #define XCHAL_HAVE_PDX4 0 /* PDX4 */ @@ -127,8 +127,8 @@ #define XCHAL_HAVE_TURBO16 0 /* ConnX Turbo16 pkg */ #define XCHAL_HAVE_BBP16 0 /* ConnX BBP16 pkg */ #define XCHAL_HAVE_FLIX3 0 /* basic 3-way FLIX option */ -#define XCHAL_HAVE_GRIVPEP 0 /* GRIVPEP is General Release of IVPEP */ -#define XCHAL_HAVE_GRIVPEP_HISTOGRAM 0 /* Histogram option on GRIVPEP */ +#define XCHAL_HAVE_GRIVPEP 0 /* GRIVPEP is General Release of IVPEP */ +#define XCHAL_HAVE_GRIVPEP_HISTOGRAM 0 /* Histogram option on GRIVPEP */
/*---------------------------------------------------------------------- @@ -348,28 +348,28 @@ EXCSAVE/EPS/EPC_n, RFI n) */
/* Masks of interrupts for each type of interrupt: */ #define XCHAL_INTTYPE_MASK_UNCONFIGURED 0xFFC00000 diff --git a/arch/xtensa/lib/Makefile b/arch/xtensa/lib/Makefile index c59df7d372..ad4fe32cb6 100644 --- a/arch/xtensa/lib/Makefile +++ b/arch/xtensa/lib/Makefile @@ -5,4 +5,4 @@
obj-$(CONFIG_CMD_BOOTM) += bootm.o
-obj-y += cache.o misc.o relocate.o time.o +obj-y += cache.o misc.o relocate.o time.o diff --git a/board/Marvell/guruplug/guruplug.c b/board/Marvell/guruplug/guruplug.c index 8e7dbb3f3f..ea87ded222 100644 --- a/board/Marvell/guruplug/guruplug.c +++ b/board/Marvell/guruplug/guruplug.c @@ -77,7 +77,7 @@ int board_early_init_f(void) MPP43_GPIO, MPP44_GPIO, MPP45_GPIO, - MPP46_GPIO, /* M_RLED */ + MPP46_GPIO, /* M_RLED */ MPP47_GPIO, /* M_GLED */ MPP48_GPIO, /* B_RLED */ MPP49_GPIO, /* B_GLED */ diff --git a/board/boundary/nitrogen6x/README b/board/boundary/nitrogen6x/README index 9d84265029..973b18fa93 100644 --- a/board/boundary/nitrogen6x/README +++ b/board/boundary/nitrogen6x/README @@ -74,7 +74,7 @@ board configurations is shown in the boards.cfg file: nitrogen6q i.MX6Q/6D 1GB nitrogen6dl i.MX6DL 1GB nitrogen6s i.MX6S 512MB - nitrogen6q2g i.MX6Q/6D 2GB + nitrogen6q2g i.MX6Q/6D 2GB nitrogen6dl2g i.MX6DL 2GB nitrogen6s1g i.MX6S 1GB
diff --git a/board/freescale/ls1012afrdm/README b/board/freescale/ls1012afrdm/README index 181c4615a8..382b668fbe 100644 --- a/board/freescale/ls1012afrdm/README +++ b/board/freescale/ls1012afrdm/README @@ -52,7 +52,7 @@ QSPI flash map Images | Size |QSPI Flash Address ------------------------------------------ RCW + PBI | 1MB | 0x4000_0000 -U-boot | 1MB | 0x4010_0000 -U-boot Env | 1MB | 0x4020_0000 +U-boot | 1MB | 0x4010_0000 +U-boot Env | 1MB | 0x4020_0000 PPA FIT image | 2MB | 0x4050_0000 Linux ITB | ~53MB | 0x40A0_0000 diff --git a/board/freescale/ls1012aqds/README b/board/freescale/ls1012aqds/README index dee4b302c1..c1956f9fd7 100644 --- a/board/freescale/ls1012aqds/README +++ b/board/freescale/ls1012aqds/README @@ -53,7 +53,7 @@ QSPI flash map Images | Size |QSPI Flash Address ------------------------------------------ RCW + PBI | 1MB | 0x4000_0000 -U-boot | 1MB | 0x4010_0000 -U-boot Env | 1MB | 0x4020_0000 +U-boot | 1MB | 0x4010_0000 +U-boot Env | 1MB | 0x4020_0000 PPA FIT image | 2MB | 0x4050_0000 Linux ITB | ~53MB | 0x40A0_0000 diff --git a/board/freescale/ls1012ardb/README b/board/freescale/ls1012ardb/README index 572fd8c7d0..5b6f306a1d 100644 --- a/board/freescale/ls1012ardb/README +++ b/board/freescale/ls1012ardb/README @@ -48,8 +48,8 @@ QSPI flash map Images | Size |QSPI Flash Address ------------------------------------------ RCW + PBI | 1MB | 0x4000_0000 -U-boot | 1MB | 0x4010_0000 -U-boot Env | 1MB | 0x4020_0000 +U-boot | 1MB | 0x4010_0000 +U-boot Env | 1MB | 0x4020_0000 PPA FIT image | 2MB | 0x4050_0000 Linux ITB | ~53MB | 0x40A0_0000
@@ -90,8 +90,8 @@ QSPI flash map Images | Size |QSPI Flash Address ------------------------------------------ RCW + PBI | 1MB | 0x4000_0000 -U-boot | 1MB | 0x4010_0000 -U-boot Env | 1MB | 0x4030_0000 +U-boot | 1MB | 0x4010_0000 +U-boot Env | 1MB | 0x4030_0000 PPA FIT image | 2MB | 0x4040_0000 PFE firmware | 20K | 0x00a0_0000 Linux ITB | ~53MB | 0x4100_0000 diff --git a/board/freescale/ls1046afrwy/README b/board/freescale/ls1046afrwy/README index d7b5a7794f..2c7c797a87 100644 --- a/board/freescale/ls1046afrwy/README +++ b/board/freescale/ls1046afrwy/README @@ -42,8 +42,8 @@ Memory map from core's view Start Address End Address Description Size 0x00_0000_0000 - 0x00_000F_FFFF Secure Boot ROM 1MB 0x00_0100_0000 - 0x00_0FFF_FFFF CCSRBAR 240MB -0x00_1000_0000 - 0x00_1000_FFFF OCRAM0 64KB -0x00_1001_0000 - 0x00_1001_FFFF OCRAM1 64KB +0x00_1000_0000 - 0x00_1000_FFFF OCRAM0 64KB +0x00_1001_0000 - 0x00_1001_FFFF OCRAM1 64KB 0x00_2000_0000 - 0x00_20FF_FFFF DCSR 16MB 0x00_7E80_0000 - 0x00_7E80_FFFF IFC - NAND Flash 64KB 0x00_7FB0_0000 - 0x00_7FB0_0FFF IFC - CPLD 4KB diff --git a/board/freescale/ls1046aqds/README b/board/freescale/ls1046aqds/README index b8fa32652b..4c227e8876 100644 --- a/board/freescale/ls1046aqds/README +++ b/board/freescale/ls1046aqds/README @@ -47,8 +47,8 @@ Memory map from core's view Start Address End Address Description Size 0x00_0000_0000 - 0x00_000F_FFFF Secure Boot ROM 1MB 0x00_0100_0000 - 0x00_0FFF_FFFF CCSRBAR 240MB -0x00_1000_0000 - 0x00_1000_FFFF OCRAM0 64KB -0x00_1001_0000 - 0x00_1001_FFFF OCRAM1 64KB +0x00_1000_0000 - 0x00_1000_FFFF OCRAM0 64KB +0x00_1001_0000 - 0x00_1001_FFFF OCRAM1 64KB 0x00_2000_0000 - 0x00_20FF_FFFF DCSR 16MB 0x00_6000_0000 - 0x00_67FF_FFFF IFC - NOR Flash 128MB 0x00_7E80_0000 - 0x00_7E80_FFFF IFC - NAND Flash 64KB diff --git a/board/freescale/ls1046ardb/README b/board/freescale/ls1046ardb/README index a38c9d4830..bef49df091 100644 --- a/board/freescale/ls1046ardb/README +++ b/board/freescale/ls1046ardb/README @@ -43,8 +43,8 @@ Memory map from core's view Start Address End Address Description Size 0x00_0000_0000 - 0x00_000F_FFFF Secure Boot ROM 1MB 0x00_0100_0000 - 0x00_0FFF_FFFF CCSRBAR 240MB -0x00_1000_0000 - 0x00_1000_FFFF OCRAM0 64KB -0x00_1001_0000 - 0x00_1001_FFFF OCRAM1 64KB +0x00_1000_0000 - 0x00_1000_FFFF OCRAM0 64KB +0x00_1001_0000 - 0x00_1001_FFFF OCRAM1 64KB 0x00_2000_0000 - 0x00_20FF_FFFF DCSR 16MB 0x00_7E80_0000 - 0x00_7E80_FFFF IFC - NAND Flash 64KB 0x00_7FB0_0000 - 0x00_7FB0_0FFF IFC - CPLD 4KB @@ -59,7 +59,7 @@ Start Address End Address Description Size QSPI flash map: Start Address End Address Description Size 0x00_4000_0000 - 0x00_400F_FFFF RCW + PBI 1MB -0x00_4010_0000 - 0x00_402F_FFFF U-Boot 2MB +0x00_4010_0000 - 0x00_402F_FFFF U-Boot 2MB 0x00_4030_0000 - 0x00_403F_FFFF U-Boot Env 1MB 0x00_4040_0000 - 0x00_405F_FFFF PPA 2MB 0x00_4060_0000 - 0x00_408F_FFFF Secure boot header diff --git a/board/freescale/m53017evb/README b/board/freescale/m53017evb/README index c4b019e2a9..8a7d8cadf0 100644 --- a/board/freescale/m53017evb/README +++ b/board/freescale/m53017evb/README @@ -98,7 +98,7 @@ CONFIG_SYS_IMMR -- define for MBAR offset
CONFIG_SYS_MBAR -- define MBAR offset
-CONFIG_MONITOR_IS_IN_RAM -- Not support +CONFIG_MONITOR_IS_IN_RAM -- Not support
CONFIG_SYS_INIT_RAM_ADDR -- defines the base address of the MCF5301x internal SRAM
diff --git a/board/logicpd/am3517evm/am3517evm.h b/board/logicpd/am3517evm/am3517evm.h index 0e5b8326ba..db2134bb9d 100644 --- a/board/logicpd/am3517evm/am3517evm.h +++ b/board/logicpd/am3517evm/am3517evm.h @@ -314,7 +314,7 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) \ /*SYS_nRESWARM */\ - MUX_VAL(CP(SYS_NRESWARM), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(SYS_NRESWARM), (IDIS | PTU | EN | M4)) \ /* - GPIO30 */\ MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\ /* - PEN_IRQ */\ diff --git a/board/logicpd/omap3som/omap3logic.h b/board/logicpd/omap3som/omap3logic.h index 63c2141783..0de1f2a54e 100644 --- a/board/logicpd/omap3som/omap3logic.h +++ b/board/logicpd/omap3som/omap3logic.h @@ -243,7 +243,7 @@ void set_muxconf_regs(void) MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M0)); /*HSUSB2_DATA5*/ MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | EN | M0)); /*HSUSB2_DATA6*/ MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M0)); /*HSUSB2_DATA7*/ - MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /* GPIO_4 */ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /* GPIO_4 */ MUX_VAL(CP(ETK_D10_ES2), (IDIS | PTU | DIS | M3)); /*HSUSB2_CLK*/ MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTU | DIS | M3)); /*HSUSB2_STP*/ MUX_VAL(CP(ETK_D12_ES2), (IEN | PTU | DIS | M3)); /*HSUSB2_DIR*/ diff --git a/board/sysam/stmark2/sbf_dram_init.S b/board/sysam/stmark2/sbf_dram_init.S index 984b31b9d0..b6f38731f1 100644 --- a/board/sysam/stmark2/sbf_dram_init.S +++ b/board/sysam/stmark2/sbf_dram_init.S @@ -5,7 +5,7 @@ * (C) Copyright 2017 Angelo Dureghello angelo@sysam.it */
-.equ PPMCR0, 0xfc04002d +.equ PPMCR0, 0xfc04002d .equ MSCR_SDRAMC, 0xec094060 .equ MISCCR2, 0xec09001a .equ DDR_RCR, 0xfc0b8180 diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 399a2e5d91..cfc825e52a 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -144,13 +144,13 @@ static const struct emif_regs beagle_x15_emif1_ddr3_532mhz_emif_regs = { .read_idle_ctrl = 0x00050000, .zq_config = 0x5007190b, .temp_alert_config = 0x00000000, - .emif_ddr_phy_ctlr_1_init = 0x0024400b, + .emif_ddr_phy_ctlr_1_init = 0x0024400b, .emif_ddr_phy_ctlr_1 = 0x0e24400b, - .emif_ddr_ext_phy_ctrl_1 = 0x10040100, - .emif_ddr_ext_phy_ctrl_2 = 0x00910091, - .emif_ddr_ext_phy_ctrl_3 = 0x00950095, - .emif_ddr_ext_phy_ctrl_4 = 0x009b009b, - .emif_ddr_ext_phy_ctrl_5 = 0x009e009e, + .emif_ddr_ext_phy_ctrl_1 = 0x10040100, + .emif_ddr_ext_phy_ctrl_2 = 0x00910091, + .emif_ddr_ext_phy_ctrl_3 = 0x00950095, + .emif_ddr_ext_phy_ctrl_4 = 0x009b009b, + .emif_ddr_ext_phy_ctrl_5 = 0x009e009e, .emif_rd_wr_lvl_rmp_win = 0x00000000, .emif_rd_wr_lvl_rmp_ctl = 0x80000000, .emif_rd_wr_lvl_ctl = 0x00000000, @@ -208,13 +208,13 @@ static const struct emif_regs beagle_x15_emif2_ddr3_532mhz_emif_regs = { .read_idle_ctrl = 0x00050000, .zq_config = 0x5007190b, .temp_alert_config = 0x00000000, - .emif_ddr_phy_ctlr_1_init = 0x0024400b, + .emif_ddr_phy_ctlr_1_init = 0x0024400b, .emif_ddr_phy_ctlr_1 = 0x0e24400b, - .emif_ddr_ext_phy_ctrl_1 = 0x10040100, - .emif_ddr_ext_phy_ctrl_2 = 0x00910091, - .emif_ddr_ext_phy_ctrl_3 = 0x00950095, - .emif_ddr_ext_phy_ctrl_4 = 0x009b009b, - .emif_ddr_ext_phy_ctrl_5 = 0x009e009e, + .emif_ddr_ext_phy_ctrl_1 = 0x10040100, + .emif_ddr_ext_phy_ctrl_2 = 0x00910091, + .emif_ddr_ext_phy_ctrl_3 = 0x00950095, + .emif_ddr_ext_phy_ctrl_4 = 0x009b009b, + .emif_ddr_ext_phy_ctrl_5 = 0x009e009e, .emif_rd_wr_lvl_rmp_win = 0x00000000, .emif_rd_wr_lvl_rmp_ctl = 0x80000000, .emif_rd_wr_lvl_ctl = 0x00000000, diff --git a/board/ti/am57xx/mux_data.h b/board/ti/am57xx/mux_data.h index 212799c93d..54b7050a45 100644 --- a/board/ti/am57xx/mux_data.h +++ b/board/ti/am57xx/mux_data.h @@ -539,7 +539,7 @@ const struct iodelay_cfg_entry iodelay_cfg_array_bbai[] = { {0x0884, 0, 0}, /* CFG_UART2_RTSN_OUT */ {0x0888, 683, 0}, /* CFG_UART2_RXD_IN */ {0x088C, 0, 0}, /* CFG_UART2_RXD_OEN */ - {0x0890, 0, 0}, /* CFG_UART2_RXD_OUT */ + {0x0890, 0, 0}, /* CFG_UART2_RXD_OUT */ {0x0894, 835, 0}, /* CFG_UART2_TXD_IN */ {0x0898, 0, 0}, /* CFG_UART2_TXD_OEN */ {0x089C, 0, 0}, /* CFG_UART2_TXD_OUT */ @@ -553,7 +553,7 @@ const struct iodelay_cfg_entry iodelay_cfg_array_bbai[] = { {0x0C48, 0, 404}, /* CFG_VOUT1_D22_IN */ {0x0C78, 0, 0}, /* CFG_VOUT1_D4_IN */ {0x0C84, 0, 365}, /* CFG_VOUT1_D5_IN */ - {0x0C90, 0, 0}, /* CFG_VOUT1_D6_IN */ + {0x0C90, 0, 0}, /* CFG_VOUT1_D6_IN */ {0x0C9C, 0, 218}, /* CFG_VOUT1_D7_IN */ };
diff --git a/cmd/cramfs.c b/cmd/cramfs.c index 44c0818d5d..d79292bad5 100644 --- a/cmd/cramfs.c +++ b/cmd/cramfs.c @@ -3,7 +3,7 @@ * * based on: cmd_jffs2.c * - * Add support for a CRAMFS located in RAM + * Add support for a CRAMFS located in RAM */
diff --git a/cmd/spi.c b/cmd/spi.c index bdbdbacecd..6dc32678da 100644 --- a/cmd/spi.c +++ b/cmd/spi.c @@ -29,9 +29,9 @@ static unsigned int bus; static unsigned int cs; static unsigned int mode; static unsigned int freq; -static int bitlen; -static uchar dout[MAX_SPI_BYTES]; -static uchar din[MAX_SPI_BYTES]; +static int bitlen; +static uchar dout[MAX_SPI_BYTES]; +static uchar din[MAX_SPI_BYTES];
static int do_spi_xfer(int bus, int cs) { diff --git a/common/hash.c b/common/hash.c index 6277fe65b3..3884298edf 100644 --- a/common/hash.c +++ b/common/hash.c @@ -228,7 +228,7 @@ static struct hash_algo hash_algo[] = { #endif #ifdef CONFIG_SHA1 { - .name = "sha1", + .name = "sha1", .digest_size = SHA1_SUM_LEN, .chunk_size = CHUNKSZ_SHA1, #ifdef CONFIG_SHA_HW_ACCEL diff --git a/common/hwconfig.c b/common/hwconfig.c index 26a561c365..63b3ccaf84 100644 --- a/common/hwconfig.c +++ b/common/hwconfig.c @@ -179,7 +179,7 @@ int hwconfig_arg_cmp_f(const char *opt, const char *arg, char *buf) * * This call is similar to hwconfig_f(), except that it takes additional * argument @subopt. In this example: - * "dr_usb:mode=peripheral" + * "dr_usb:mode=peripheral" * "dr_usb" is an option, "mode" is a sub-option, and "peripheral" is its * argument. */ diff --git a/common/usb_storage.c b/common/usb_storage.c index 946c6b2b32..c9e2d7343c 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -94,7 +94,7 @@ struct us_data { int action; /* what to do */ int ip_wanted; /* needed */ int *irq_handle; /* for USB int requests */ - unsigned int irqpipe; /* pipe for release_irq */ + unsigned int irqpipe; /* pipe for release_irq */ unsigned char irqmaxp; /* max packed for irq Pipe */ unsigned char irqinterval; /* Intervall for IRQ Pipe */ struct scsi_cmd *srb; /* current srb */ diff --git a/disk/Makefile b/disk/Makefile index ccd0335959..6ce5a687b3 100644 --- a/disk/Makefile +++ b/disk/Makefile @@ -5,7 +5,7 @@
#ccflags-y += -DET_DEBUG -DDEBUG
-obj-$(CONFIG_PARTITIONS) += part.o +obj-$(CONFIG_PARTITIONS) += part.o obj-$(CONFIG_$(SPL_)MAC_PARTITION) += part_mac.o obj-$(CONFIG_$(SPL_)DOS_PARTITION) += part_dos.o obj-$(CONFIG_$(SPL_)ISO_PARTITION) += part_iso.o diff --git a/doc/README.commands.spl b/doc/README.commands.spl index cb3e0c8e0a..ecfd3ca9ee 100644 --- a/doc/README.commands.spl +++ b/doc/README.commands.spl @@ -17,14 +17,14 @@ TYPICAL CALL
on OMAP3: nandecc hw -nand read 0x82000000 0x280000 0x400000 /* Read kernel image from NAND*/ -spl export atags /* export ATAGS */ +nand read 0x82000000 0x280000 0x400000 /* Read kernel image from NAND*/ +spl export atags /* export ATAGS */ nand erase 0x680000 0x20000 /* erase - one page */ nand write 0x80000100 0x680000 0x20000 /* write the image - one page */
call with FDT: nandecc hw -nand read 0x82000000 0x280000 0x400000 /* Read kernel image from NAND*/ +nand read 0x82000000 0x280000 0x400000 /* Read kernel image from NAND*/ tftpboot 0x80000100 devkit8000.dtb /* Read fdt */ spl export fdt 0x82000000 - 0x80000100 /* export FDT */ nand erase 0x680000 0x20000 /* erase - one page */ diff --git a/doc/README.falcon b/doc/README.falcon index 713d7063a1..88218d35b9 100644 --- a/doc/README.falcon +++ b/doc/README.falcon @@ -69,7 +69,7 @@ CONFIG_CMD_SPL_NAND_OFS Offset in NAND where the parameters area was saved.
CONFIG_CMD_SPL_NOR_OFS Offset in NOR where the parameters area was saved.
-CONFIG_CMD_SPL_WRITE_SIZE Size of the parameters area to be copied +CONFIG_CMD_SPL_WRITE_SIZE Size of the parameters area to be copied
CONFIG_SPL_OS_BOOT Activate Falcon Mode.
@@ -89,7 +89,7 @@ Environment variables A board may chose to look at the environment for decisions about falcon mode. In this case the following variables may be supported:
-boot_os : Set to yes/Yes/true/True/1 to enable booting to OS, +boot_os : Set to yes/Yes/true/True/1 to enable booting to OS, any other value to fall back to U-Boot (including unset) falcon_args_file : Filename to load as the 'args' portion of falcon mode diff --git a/doc/README.odroid b/doc/README.odroid index bc77ae3175..1090a0ea14 100644 --- a/doc/README.odroid +++ b/doc/README.odroid @@ -296,8 +296,8 @@ Odroid # usb part 0 Partition Map for USB device 0 -- Partition Type: DOS
Part Start Sector Num Sectors UUID Type - 1 3072 263168 000c4046-01 06 - 2 266240 13457408 000c4046-02 83 + 1 3072 263168 000c4046-01 06 + 2 266240 13457408 000c4046-02 83
Odroid # ls usb 0:2 /boot <DIR> 4096 . diff --git a/doc/device-tree-bindings/mailbox/k3-secure-proxy.txt b/doc/device-tree-bindings/mailbox/k3-secure-proxy.txt index f3add0d4e7..c25d7091bf 100644 --- a/doc/device-tree-bindings/mailbox/k3-secure-proxy.txt +++ b/doc/device-tree-bindings/mailbox/k3-secure-proxy.txt @@ -10,7 +10,7 @@ Secure Proxy Device Node: Required properties: -------------------- - compatible: Shall be: "ti,am654-secure-proxy" -- reg-names data - Map the data region +- reg-names data - Map the data region scfg - Map the secure configuration region rt - Map the Realtime region. - reg: Contains the register map per reg-names. diff --git a/doc/device-tree-bindings/memory-controller/k3-j721e-ddrss.txt b/doc/device-tree-bindings/memory-controller/k3-j721e-ddrss.txt index c4cf26eaa4..dd0260b394 100644 --- a/doc/device-tree-bindings/memory-controller/k3-j721e-ddrss.txt +++ b/doc/device-tree-bindings/memory-controller/k3-j721e-ddrss.txt @@ -11,7 +11,7 @@ Required properties: -------------------- - compatible: Shall be: "ti,j721e-ddrss" for j721e, j7200 "ti,am64-ddrss" for am642 -- reg-names cfg - Map the controller configuration region +- reg-names cfg - Map the controller configuration region ctrl_mmr_lp4 - Map LP4 register region in ctrl mmr - reg: Contains the register map per reg-names. - power-domains: Should contain two entries: diff --git a/doc/device-tree-bindings/memory-controllers/k3-am654-ddrss.txt b/doc/device-tree-bindings/memory-controllers/k3-am654-ddrss.txt index 4ed731c524..1e11edf7b1 100644 --- a/doc/device-tree-bindings/memory-controllers/k3-am654-ddrss.txt +++ b/doc/device-tree-bindings/memory-controllers/k3-am654-ddrss.txt @@ -14,7 +14,7 @@ DDRSS device node: Required properties: -------------------- - compatible: Shall be: "ti,am654-ddrss" -- reg-names ss - Map the sub system wrapper logic region +- reg-names ss - Map the sub system wrapper logic region ctl - Map the controller region phy - Map the PHY region - reg: Contains the register map per reg-names. diff --git a/doc/device-tree-bindings/net/altera_tse.txt b/doc/device-tree-bindings/net/altera_tse.txt index cb190df65f..96ab1d6ebc 100644 --- a/doc/device-tree-bindings/net/altera_tse.txt +++ b/doc/device-tree-bindings/net/altera_tse.txt @@ -90,7 +90,7 @@ Example:
tse_sub_1_eth_tse_0: ethernet@0x1,00001000 { compatible = "altr,tse-msgdma-1.0"; - reg = <0x00000001 0x00001000 0x00000400>, + reg = <0x00000001 0x00001000 0x00000400>, <0x00000001 0x00001460 0x00000020>, <0x00000001 0x00001480 0x00000020>, <0x00000001 0x000014A0 0x00000008>, diff --git a/doc/device-tree-bindings/net/fsl,mcf-dma-fec.txt b/doc/device-tree-bindings/net/fsl,mcf-dma-fec.txt index e237825bac..5c6d548cae 100644 --- a/doc/device-tree-bindings/net/fsl,mcf-dma-fec.txt +++ b/doc/device-tree-bindings/net/fsl,mcf-dma-fec.txt @@ -21,7 +21,7 @@ Example:
fec0: ethernet@9000 { compatible = "fsl,mcf-dma-fec"; - reg = <0x9000 0x800>; + reg = <0x9000 0x800>; mii-base = <0>; phy-addr = <0>; timeout-loop = <5000>; diff --git a/doc/device-tree-bindings/net/fsl,mcf-fec.txt b/doc/device-tree-bindings/net/fsl,mcf-fec.txt index 39bbaa52f3..2699b5ac07 100644 --- a/doc/device-tree-bindings/net/fsl,mcf-fec.txt +++ b/doc/device-tree-bindings/net/fsl,mcf-fec.txt @@ -15,7 +15,7 @@ Example:
fec0: ethernet@fc030000 { compatible = "fsl,mcf-fec"; - reg = <0xfc030000 0x400>; + reg = <0xfc030000 0x400>; mii-base = <0>; phy-addr = <0>; timeout-loop = <5000>; diff --git a/doc/device-tree-bindings/pinctrl/bcm6838-pinctrl.txt b/doc/device-tree-bindings/pinctrl/bcm6838-pinctrl.txt index 2034f05993..ace66ead5c 100644 --- a/doc/device-tree-bindings/pinctrl/bcm6838-pinctrl.txt +++ b/doc/device-tree-bindings/pinctrl/bcm6838-pinctrl.txt @@ -2,7 +2,7 @@
Required properties for the pinctrl driver: - compatible: "brcm,bcm6838-pinctrl" -- regmap: specify the gpio test port syscon +- regmap: specify the gpio test port syscon - brcm,pins-count: the number of pin - brcm,functions-count: the number of function
diff --git a/doc/device-tree-bindings/pinctrl/marvell,armada-apn806-pinctrl.txt b/doc/device-tree-bindings/pinctrl/marvell,armada-apn806-pinctrl.txt index 51f2f2c79c..0d6f861445 100644 --- a/doc/device-tree-bindings/pinctrl/marvell,armada-apn806-pinctrl.txt +++ b/doc/device-tree-bindings/pinctrl/marvell,armada-apn806-pinctrl.txt @@ -3,19 +3,19 @@ ---------------------------------------------------------------------- MPP# 0x1 0x2 0x3 0x4 ---------------------------------------------------------------------- -0 SDIO_CLK - SPI0_CLK - +0 SDIO_CLK - SPI0_CLK - 1 SDIO_CMD - SPI0_MISO - -2 SDIO_D[0] - SPI0_MOSI - -3 SDIO_D[1] - SPI0_CS0n - +2 SDIO_D[0] - SPI0_MOSI - +3 SDIO_D[1] - SPI0_CS0n - 4 SDIO_D[2] - I2C0_SDA SPI0_CS1n 5 SDIO_D[3] - I2C0_SCK - 6 SDIO_DS - - - 7 SDIO_D[4] - UART1_RXD - -8 SDIO_D[5] - UART1_TXD - -9 SDIO_D[6] - SPI0_CS1n - +8 SDIO_D[5] - UART1_TXD - +9 SDIO_D[6] - SPI0_CS1n - 10 SDIO_D[7] - - - -11 - - UART0_TXD - -12 SDIO_CARD_PW_OFF SDIO_HW_RST - - +11 - - UART0_TXD - +12 SDIO_CARD_PW_OFF SDIO_HW_RST - - 13 - - - - 14 - - - - 15 - - - - diff --git a/doc/device-tree-bindings/pinctrl/marvell,mvebu-pinctrl.txt b/doc/device-tree-bindings/pinctrl/marvell,mvebu-pinctrl.txt index 1fc1bc6645..c6984ddd60 100644 --- a/doc/device-tree-bindings/pinctrl/marvell,mvebu-pinctrl.txt +++ b/doc/device-tree-bindings/pinctrl/marvell,mvebu-pinctrl.txt @@ -11,7 +11,7 @@ Required properties for the pinctrl driver: "marvell,armada-8k-cpm-pinctrl", "marvell,armada-8k-cps-pinctrl" - bank-name: A string defining the pinc controller bank name -- reg: A pair of values defining the pin controller base address +- reg: A pair of values defining the pin controller base address and the address space - pin-count: Numeric value defining the amount of multi purpose pins included in this bank diff --git a/doc/device-tree-bindings/regulator/fsl,anatop-regulator.txt b/doc/device-tree-bindings/regulator/fsl,anatop-regulator.txt index 2a60e4941b..bd272384af 100644 --- a/doc/device-tree-bindings/regulator/fsl,anatop-regulator.txt +++ b/doc/device-tree-bindings/regulator/fsl,anatop-regulator.txt @@ -8,21 +8,21 @@ Required properties: - anatop-reg-offset: u32 value representing the anatop MFD register offset. - anatop-vol-bit-shift: u32 value representing the bit shift for the register. - anatop-vol-bit-width: u32 value representing the number of bits used in the - register. + register. - anatop-min-bit-val: u32 value representing the minimum value of this - register. + register. - anatop-min-voltage: u32 value representing the minimum voltage of this - regulator. + regulator. - anatop-max-voltage: u32 value representing the maximum voltage of this - regulator. + regulator.
Optional properties: - anatop-delay-reg-offset: u32 value representing the anatop MFD step time - register offset. + register offset. - anatop-delay-bit-shift: u32 value representing the bit shift for the step - time register. + time register. - anatop-delay-bit-width: u32 value representing the number of bits used in - the step time register. + the step time register. - anatop-enable-bit: u32 value representing regulator enable bit offset. - vin-supply: input supply phandle.
diff --git a/doc/device-tree-bindings/spi/spi-bus.txt b/doc/device-tree-bindings/spi/spi-bus.txt index 420ec9529f..e57897ac0c 100644 --- a/doc/device-tree-bindings/spi/spi-bus.txt +++ b/doc/device-tree-bindings/spi/spi-bus.txt @@ -8,10 +8,10 @@ in slave mode.
The SPI master node requires the following properties: - #address-cells - number of cells required to define a chip select - address on the SPI bus. + address on the SPI bus. - #size-cells - should be zero. - compatible - name of SPI bus controller following generic names - recommended practice. + recommended practice. - cs-gpios - (optional) gpios chip select. No other properties are required in the SPI bus node. It is assumed that a driver for an SPI bus device will understand that it is an SPI bus. @@ -45,16 +45,16 @@ SPI slave nodes must be children of the SPI master node and can contain the following properties. - reg - (required) chip select address of device. - compatible - (required) name of SPI device following generic names - recommended practice + recommended practice - spi-max-frequency - (required) Maximum SPI clocking speed of device in Hz - spi-cpol - (optional) Empty property indicating device requires - inverse clock polarity (CPOL) mode + inverse clock polarity (CPOL) mode - spi-cpha - (optional) Empty property indicating device requires - shifted clock phase (CPHA) mode + shifted clock phase (CPHA) mode - spi-cs-high - (optional) Empty property indicating device requires - chip select active high + chip select active high - spi-3wire - (optional) Empty property indicating device requires - 3-wire mode. + 3-wire mode. - spi-tx-bus-width - (optional) The bus width(number of data wires) that used for MOSI. Defaults to 1 if not present. - spi-rx-bus-width - (optional) The bus width(number of data wires) that diff --git a/doc/device-tree-bindings/spi/spi-qup.txt b/doc/device-tree-bindings/spi/spi-qup.txt index 3697df2631..2f2f070c5a 100644 --- a/doc/device-tree-bindings/spi/spi-qup.txt +++ b/doc/device-tree-bindings/spi/spi-qup.txt @@ -7,7 +7,7 @@ Required properties: - reg : Physical base address and size of SPI registers map. - clock : Clock phandle (see clock bindings for details). - #address-cells : Number of cells required to define a chip select - address on the SPI bus. Should be set to 1. + address on the SPI bus. Should be set to 1. - #size-cells : Should be zero. - pinctrl-names : Must be "default" - pinctrl-n : At least one pinctrl phandle diff --git a/doc/device-tree-bindings/tpm2/sandbox.txt b/doc/device-tree-bindings/tpm2/sandbox.txt index 3d0f727cc4..05a310e057 100644 --- a/doc/device-tree-bindings/tpm2/sandbox.txt +++ b/doc/device-tree-bindings/tpm2/sandbox.txt @@ -7,5 +7,5 @@ Required properties: Example:
tpm { - compatible = "sandbox,tpm2"; + compatible = "sandbox,tpm2"; }; diff --git a/drivers/cache/cache-v5l2.c b/drivers/cache/cache-v5l2.c index 2c7983d0ce..bbdb76bd57 100644 --- a/drivers/cache/cache-v5l2.c +++ b/drivers/cache/cache-v5l2.c @@ -68,8 +68,8 @@ struct v5l2_plat { struct l2cache *regs; u32 iprefetch; u32 dprefetch; - u32 tram_ctl[2]; - u32 dram_ctl[2]; + u32 tram_ctl[2]; + u32 dram_ctl[2]; };
static int v5l2_enable(struct udevice *dev) diff --git a/drivers/cache/sandbox_cache.c b/drivers/cache/sandbox_cache.c index 0fb767e433..955dfc8a0f 100644 --- a/drivers/cache/sandbox_cache.c +++ b/drivers/cache/sandbox_cache.c @@ -31,7 +31,7 @@ static int snadbox_disable(struct udevice *dev)
static const struct cache_ops sandbox_cache_ops = { .get_info = sandbox_get_info, - .enable = sandbox_enable, + .enable = sandbox_enable, .disable = snadbox_disable, };
diff --git a/drivers/clk/imx/clk-pllv3.c b/drivers/clk/imx/clk-pllv3.c index b5cbf80054..077757efcb 100644 --- a/drivers/clk/imx/clk-pllv3.c +++ b/drivers/clk/imx/clk-pllv3.c @@ -160,7 +160,7 @@ static ulong clk_pllv3_sys_set_rate(struct clk *clk, ulong rate) }
static const struct clk_ops clk_pllv3_sys_ops = { - .enable = clk_pllv3_generic_enable, + .enable = clk_pllv3_generic_enable, .disable = clk_pllv3_generic_disable, .get_rate = clk_pllv3_sys_get_rate, .set_rate = clk_pllv3_sys_set_rate, diff --git a/drivers/crypto/Makefile b/drivers/crypto/Makefile index efbd1d3fca..82688e8359 100644 --- a/drivers/crypto/Makefile +++ b/drivers/crypto/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (c) 2013 Samsung Electronics Co., Ltd. -# http://www.samsung.com +# http://www.samsung.com
obj-$(CONFIG_EXYNOS_ACE_SHA) += ace_sha.o obj-y += rsa_mod_exp/ diff --git a/drivers/ddr/fsl/ddr3_dimm_params.c b/drivers/ddr/fsl/ddr3_dimm_params.c index 8464438c54..1f8db90c45 100644 --- a/drivers/ddr/fsl/ddr3_dimm_params.c +++ b/drivers/ddr/fsl/ddr3_dimm_params.c @@ -36,18 +36,18 @@ * 0110 16Gb 2GB * * SPD byte8 - module memory bus width - * bit[2:0] primary bus width + * bit[2:0] primary bus width * 000 8bits - * 001 16bits - * 010 32bits - * 011 64bits + * 001 16bits + * 010 32bits + * 011 64bits * * SPD byte7 - module organiztion - * bit[2:0] sdram device width - * 000 4bits - * 001 8bits - * 010 16bits - * 011 32bits + * bit[2:0] sdram device width + * 000 4bits + * 001 8bits + * 010 16bits + * 011 32bits * */ static unsigned long long diff --git a/drivers/ddr/marvell/axp/ddr3_spd.c b/drivers/ddr/marvell/axp/ddr3_spd.c index e2305d8814..dd772e63ab 100644 --- a/drivers/ddr/marvell/axp/ddr3_spd.c +++ b/drivers/ddr/marvell/axp/ddr3_spd.c @@ -46,7 +46,7 @@ #define SPD_COL_NUM_MASK (7 << SPD_COL_NUM_OFF)
#define SPD_MODULE_ORG_BYTE 7 -#define SPD_MODULE_SDRAM_DEV_WIDTH_OFF 0 +#define SPD_MODULE_SDRAM_DEV_WIDTH_OFF 0 #define SPD_MODULE_SDRAM_DEV_WIDTH_MASK (7 << SPD_MODULE_SDRAM_DEV_WIDTH_OFF) #define SPD_MODULE_BANK_NUM_MIN 1 #define SPD_MODULE_BANK_NUM_OFF 3 diff --git a/drivers/firmware/scmi/Makefile b/drivers/firmware/scmi/Makefile index e1e0224066..966475ec10 100644 --- a/drivers/firmware/scmi/Makefile +++ b/drivers/firmware/scmi/Makefile @@ -1,5 +1,5 @@ obj-y += scmi_agent-uclass.o obj-y += smt.o -obj-$(CONFIG_ARM_SMCCC) += smccc_agent.o +obj-$(CONFIG_ARM_SMCCC) += smccc_agent.o obj-$(CONFIG_DM_MAILBOX) += mailbox_agent.o obj-$(CONFIG_SANDBOX) += sandbox-scmi_agent.o sandbox-scmi_devices.o diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index 9b2349a0a2..b56d7dd22f 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -112,7 +112,7 @@ struct i2c_regs { #define IC_TX_EMPTY 0x0010 #define IC_TX_OVER 0x0008 #define IC_RX_FULL 0x0004 -#define IC_RX_OVER 0x0002 +#define IC_RX_OVER 0x0002 #define IC_RX_UNDER 0x0001
/* fifo threshold register definitions */ diff --git a/drivers/misc/atsha204a-i2c.c b/drivers/misc/atsha204a-i2c.c index 52d9eadf49..715dabb279 100644 --- a/drivers/misc/atsha204a-i2c.c +++ b/drivers/misc/atsha204a-i2c.c @@ -2,8 +2,8 @@ * I2C Driver for Atmel ATSHA204 over I2C * * Copyright (C) 2014 Josh Datko, Cryptotronix, jbd@cryptotronix.com - * 2016 Tomas Hlavacek, CZ.NIC, tmshlvck@gmail.com - * 2017 Marek Behun, CZ.NIC, marek.behun@nic.cz + * 2016 Tomas Hlavacek, CZ.NIC, tmshlvck@gmail.com + * 2017 Marek Behun, CZ.NIC, marek.behun@nic.cz * * This program is free software; you can redistribute it and/or modify it * under the terms of the GNU General Public License version 2 as @@ -40,11 +40,11 @@ DECLARE_GLOBAL_DATA_PTR; * * int i, j; * for (i = 0; i < 256; ++i) { - * u8 c = 0; - * for (j = 0; j < 8; ++j) { - * c = (c << 1) | ((i >> j) & 1); - * } - * bitreverse_table[i] = c; + * u8 c = 0; + * for (j = 0; j < 8; ++j) { + * c = (c << 1) | ((i >> j) & 1); + * } + * bitreverse_table[i] = c; * } */
@@ -88,14 +88,14 @@ static u8 const bitreverse_table[256] = { * * int i, j; * for (i = 0; i < 256; ++i) { - * u16 c = i << 8; - * for (j = 0; j < 8; ++j) { - * int b = c >> 15; - * c <<= 1; - * if (b) - * c ^= 0x8005; - * } - * crc16_table[i] = c; + * u16 c = i << 8; + * for (j = 0; j < 8; ++j) { + * int b = c >> 15; + * c <<= 1; + * if (b) + * c ^= 0x8005; + * } + * crc16_table[i] = c; * } */ static u16 const crc16_table[256] = { diff --git a/drivers/misc/cros_ec.c b/drivers/misc/cros_ec.c index 2a15094d20..1da4c038c3 100644 --- a/drivers/misc/cros_ec.c +++ b/drivers/misc/cros_ec.c @@ -414,7 +414,7 @@ static int ec_command(struct udevice *dev, uint cmd, int cmd_version,
int cros_ec_scan_keyboard(struct udevice *dev, struct mbkp_keyscan *scan) { - if (ec_command(dev, EC_CMD_MKBP_STATE, 0, NULL, 0, scan, + if (ec_command(dev, EC_CMD_MKBP_STATE, 0, NULL, 0, scan, sizeof(scan->data)) != sizeof(scan->data)) return -1;
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index dde6cd563f..7e819d2b3a 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -65,7 +65,7 @@ obj-$(CONFIG_MMC_SDHCI_PIC32) += pic32_sdhci.o obj-$(CONFIG_MMC_SDHCI_ROCKCHIP) += rockchip_sdhci.o obj-$(CONFIG_MMC_SDHCI_S5P) += s5p_sdhci.o obj-$(CONFIG_MMC_SDHCI_SPEAR) += spear_sdhci.o -obj-$(CONFIG_MMC_SDHCI_STI) += sti_sdhci.o +obj-$(CONFIG_MMC_SDHCI_STI) += sti_sdhci.o obj-$(CONFIG_MMC_SDHCI_TANGIER) += tangier_sdhci.o obj-$(CONFIG_MMC_SDHCI_TEGRA) += tegra_mmc.o obj-$(CONFIG_MMC_SDHCI_XENON) += xenon_sdhci.o diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index d3babbfeb1..ba54b19c14 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -699,7 +699,7 @@ static int mmc_send_op_cond(struct mmc *mmc) mmc_go_idle(mmc);
start = get_timer(0); - /* Asking to the card its capabilities */ + /* Asking to the card its capabilities */ for (i = 0; ; i++) { err = mmc_send_op_cond_iter(mmc, i != 0); if (err) diff --git a/drivers/mtd/mtdcore.c b/drivers/mtd/mtdcore.c index d0351b2c6a..9496903e86 100644 --- a/drivers/mtd/mtdcore.c +++ b/drivers/mtd/mtdcore.c @@ -799,8 +799,8 @@ static bool mtd_device_matches_name(struct mtd_info *mtd, const char *name) * device name * @name: MTD device name to open * - * This function returns MTD device description structure in case of - * success and an error code in case of failure. + * This function returns MTD device description structure in case of + * success and an error code in case of failure. */ struct mtd_info *get_mtd_device_nm(const char *name) { diff --git a/drivers/mtd/nand/raw/davinci_nand.c b/drivers/mtd/nand/raw/davinci_nand.c index 9ad3a57690..b876052cdd 100644 --- a/drivers/mtd/nand/raw/davinci_nand.c +++ b/drivers/mtd/nand/raw/davinci_nand.c @@ -39,7 +39,7 @@ #define NAND_TIMEOUT 10240 #define NAND_ECC_BUSY 0xC #define NAND_4BITECC_MASK 0x03FF03FF -#define EMIF_NANDFSR_ECC_STATE_MASK 0x00000F00 +#define EMIF_NANDFSR_ECC_STATE_MASK 0x00000F00 #define ECC_STATE_NO_ERR 0x0 #define ECC_STATE_TOO_MANY_ERRS 0x1 #define ECC_STATE_ERR_CORR_COMP_P 0x2 diff --git a/drivers/mtd/nand/raw/fsl_elbc_nand.c b/drivers/mtd/nand/raw/fsl_elbc_nand.c index 0c1bd7b474..ddfd75d32d 100644 --- a/drivers/mtd/nand/raw/fsl_elbc_nand.c +++ b/drivers/mtd/nand/raw/fsl_elbc_nand.c @@ -716,7 +716,7 @@ static int fsl_elbc_chip_init(int devnum, u8 *addr) nand->bbt_td = &bbt_main_descr; nand->bbt_md = &bbt_mirror_descr;
- /* set up nand options */ + /* set up nand options */ nand->options = NAND_NO_SUBPAGE_WRITE; nand->bbt_options = NAND_BBT_USE_FLASH;
diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index 0caaf7b32c..80dd419389 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -266,7 +266,7 @@ static void ioread8_rep(void *addr, uint8_t *buf, int len) static void ioread16_rep(void *addr, void *buf, int len) { int i; - u16 *p = (u16 *) buf; + u16 *p = (u16 *) buf;
for (i = 0; i < len; i++) p[i] = readw(addr); @@ -908,11 +908,11 @@ static int nand_wait(struct mtd_info *mtd, struct nand_chip *chip) if (ret) return ret;
- u32 timer = (CONFIG_SYS_HZ * timeo) / 1000; - u32 time_start; + u32 timer = (CONFIG_SYS_HZ * timeo) / 1000; + u32 time_start;
- time_start = get_timer(0); - while (get_timer(time_start) < timer) { + time_start = get_timer(0); + while (get_timer(time_start) < timer) { if (chip->dev_ready) { if (chip->dev_ready(mtd)) break; diff --git a/drivers/mtd/nand/raw/nand_ids.c b/drivers/mtd/nand/raw/nand_ids.c index 3104f879f6..2a50f0b214 100644 --- a/drivers/mtd/nand/raw/nand_ids.c +++ b/drivers/mtd/nand/raw/nand_ids.c @@ -30,7 +30,7 @@ struct nand_flash_dev nand_flash_ids[] = { LEGACY_ID_NAND("NAND 1MiB 3,3V 8-bit", 0xe8, 1, SZ_4K, SP_OPTIONS), LEGACY_ID_NAND("NAND 1MiB 3,3V 8-bit", 0xec, 1, SZ_4K, SP_OPTIONS), LEGACY_ID_NAND("NAND 2MiB 3,3V 8-bit", 0xea, 2, SZ_4K, SP_OPTIONS), - LEGACY_ID_NAND("NAND 4MiB 3,3V 8-bit", 0xd5, 4, SZ_8K, SP_OPTIONS), + LEGACY_ID_NAND("NAND 4MiB 3,3V 8-bit", 0xd5, 4, SZ_8K, SP_OPTIONS),
LEGACY_ID_NAND("NAND 8MiB 3,3V 8-bit", 0xe6, 8, SZ_8K, SP_OPTIONS), #endif diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 09daa0dd36..46aeef258d 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -2306,8 +2306,8 @@ static int flexonenand_get_boundary(struct mtd_info *mtd)
/** * flexonenand_get_size - Fill up fields in onenand_chip and mtd_info - * boundary[], diesize[], mtd->size, mtd->erasesize, - * mtd->eraseregions + * boundary[], diesize[], mtd->size, mtd->erasesize, + * mtd->eraseregions * @param mtd - MTD device structure */ static void flexonenand_get_size(struct mtd_info *mtd) diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 4aef1ddd6e..0bff52d5f2 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -76,7 +76,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("at45db321d", 0x1f2700, 0, 64 * 1024, 64, SECT_4K) }, { INFO("at45db641d", 0x1f2800, 0, 64 * 1024, 128, SECT_4K) }, { INFO("at25sl321", 0x1f4216, 0, 64 * 1024, 64, SECT_4K) }, - { INFO("at26df081a", 0x1f4501, 0, 64 * 1024, 16, SECT_4K) }, + { INFO("at26df081a", 0x1f4501, 0, 64 * 1024, 16, SECT_4K) }, #endif #ifdef CONFIG_SPI_FLASH_EON /* EON */ /* EON -- en25xxx */ diff --git a/drivers/mtd/ubi/crc32.c b/drivers/mtd/ubi/crc32.c index 9ce061c861..35820c753e 100644 --- a/drivers/mtd/ubi/crc32.c +++ b/drivers/mtd/ubi/crc32.c @@ -293,8 +293,8 @@ EXPORT_SYMBOL(crc32_be); * * A big-endian CRC written this way would be coded like: * for (i = 0; i < input_bits; i++) { - * multiple = remainder & 0x80000000 ? CRCPOLY : 0; - * remainder = (remainder << 1 | next_input_bit()) ^ multiple; + * multiple = remainder & 0x80000000 ? CRCPOLY : 0; + * remainder = (remainder << 1 | next_input_bit()) ^ multiple; * } * Notice how, to get at bit 32 of the shifted remainder, we look * at bit 31 of the remainder *before* shifting it. @@ -313,14 +313,14 @@ EXPORT_SYMBOL(crc32_be); * This changes the code to: * for (i = 0; i < input_bits; i++) { * remainder ^= next_input_bit() << 31; - * multiple = (remainder & 0x80000000) ? CRCPOLY : 0; - * remainder = (remainder << 1) ^ multiple; + * multiple = (remainder & 0x80000000) ? CRCPOLY : 0; + * remainder = (remainder << 1) ^ multiple; * } * With this optimization, the little-endian code is simpler: * for (i = 0; i < input_bits; i++) { * remainder ^= next_input_bit(); - * multiple = (remainder & 1) ? CRCPOLY : 0; - * remainder = (remainder >> 1) ^ multiple; + * multiple = (remainder & 1) ? CRCPOLY : 0; + * remainder = (remainder >> 1) ^ multiple; * } * * Note that the other details of endianness have been hidden in CRCPOLY @@ -330,19 +330,19 @@ EXPORT_SYMBOL(crc32_be); * order, we can actually do the merging 8 or more bits at a time rather * than one bit at a time: * for (i = 0; i < input_bytes; i++) { - * remainder ^= next_input_byte() << 24; - * for (j = 0; j < 8; j++) { - * multiple = (remainder & 0x80000000) ? CRCPOLY : 0; - * remainder = (remainder << 1) ^ multiple; - * } + * remainder ^= next_input_byte() << 24; + * for (j = 0; j < 8; j++) { + * multiple = (remainder & 0x80000000) ? CRCPOLY : 0; + * remainder = (remainder << 1) ^ multiple; + * } * } * Or in little-endian: * for (i = 0; i < input_bytes; i++) { - * remainder ^= next_input_byte(); - * for (j = 0; j < 8; j++) { - * multiple = (remainder & 1) ? CRCPOLY : 0; - * remainder = (remainder << 1) ^ multiple; - * } + * remainder ^= next_input_byte(); + * for (j = 0; j < 8; j++) { + * multiple = (remainder & 1) ? CRCPOLY : 0; + * remainder = (remainder << 1) ^ multiple; + * } * } * If the input is a multiple of 32 bits, you can even XOR in a 32-bit * word at a time and increase the inner loop count to 32. diff --git a/drivers/net/at91_emac.c b/drivers/net/at91_emac.c index e40b94ad89..9846961163 100644 --- a/drivers/net/at91_emac.c +++ b/drivers/net/at91_emac.c @@ -84,7 +84,7 @@ typedef struct { } rbf_t;
typedef struct { - rbf_t rbfdt[RBF_FRAMEMAX]; + rbf_t rbfdt[RBF_FRAMEMAX]; unsigned long rbindex; } emac_device;
diff --git a/drivers/net/calxedaxgmac.c b/drivers/net/calxedaxgmac.c index b98d709117..eb1e2a756c 100644 --- a/drivers/net/calxedaxgmac.c +++ b/drivers/net/calxedaxgmac.c @@ -587,7 +587,7 @@ static const struct eth_ops xgmac_eth_ops = { .start = xgmac_eth_start, .send = xgmac_tx, .recv = xgmac_rx, - .free_pkt = xgmac_free_pkt, + .free_pkt = xgmac_free_pkt, .stop = xgmac_eth_stop, .write_hwaddr = xgmac_eth_write_hwaddr, .read_rom_hwaddr = xgmac_eth_read_rom_hwaddr, diff --git a/drivers/net/dm9000x.c b/drivers/net/dm9000x.c index e46a269af9..4f062e99d9 100644 --- a/drivers/net/dm9000x.c +++ b/drivers/net/dm9000x.c @@ -28,7 +28,7 @@ v1.2 03/18/2003 Weilun Huang weilun_huang@davicom.com.tw: --------------------------------------
12/15/2003 Initial port to u-boot by - Sascha Hauer saschahauer@web.de + Sascha Hauer saschahauer@web.de
06/03/2008 Remy Bohmer linux@bohmer.net - Fixed the driver to work with DM9000A. @@ -66,7 +66,7 @@ TODO: external MII is not functional, only internal at the moment. #define DM9000_DBG(fmt,args...) printf(fmt, ##args) #define DM9000_DMP_PACKET(func,packet,length) \ do { \ - int i; \ + int i; \ printf("%s: length: %d\n", func, length); \ for (i = 0; i < length; i++) { \ if (i % 8 == 0) \ diff --git a/drivers/net/e1000.h b/drivers/net/e1000.h index 082154a997..f96f12c8f4 100644 --- a/drivers/net/e1000.h +++ b/drivers/net/e1000.h @@ -249,7 +249,7 @@ struct e1000_phy_stats { #define E1000_ERR_MASTER_REQUESTS_PENDING 10 #define E1000_ERR_HOST_INTERFACE_COMMAND 11 #define E1000_BLK_PHY_RESET 12 -#define E1000_ERR_SWFW_SYNC 13 +#define E1000_ERR_SWFW_SYNC 13
/* PCI Device IDs */ #define E1000_DEV_ID_82542 0x1000 diff --git a/drivers/net/smc911x.h b/drivers/net/smc911x.h index 0a27f3c43e..59018f00b2 100644 --- a/drivers/net/smc911x.h +++ b/drivers/net/smc911x.h @@ -13,9 +13,9 @@ /* Below are the register offsets and bit definitions * of the Lan911x memory space */ -#define RX_DATA_FIFO 0x00 +#define RX_DATA_FIFO 0x00
-#define TX_DATA_FIFO 0x20 +#define TX_DATA_FIFO 0x20 #define TX_CMD_A_INT_ON_COMP 0x80000000 #define TX_CMD_A_INT_BUF_END_ALGN 0x03000000 #define TX_CMD_A_INT_4_BYTE_ALGN 0x00000000 diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index d7553fe163..a6eb82bd16 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -403,7 +403,7 @@ static int sun8i_phy_init(struct emac_eth_dev *priv, void *dev) }
#define cache_clean_descriptor(desc) \ - flush_dcache_range((uintptr_t)(desc), \ + flush_dcache_range((uintptr_t)(desc), \ (uintptr_t)(desc) + sizeof(struct emac_dma_desc))
#define cache_inv_descriptor(desc) \ diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index fc3327ec53..c544af2a0b 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -885,7 +885,7 @@ int fsl_pcie_init_board(int busno) setbits_be32(addr, _DEVDISR_PCIE4); /* disable */ #endif
- return busno; + return busno; } #else int fsl_pcie_init_ctrl(int busno, u32 devdisr, enum srds_prtcl dev, diff --git a/drivers/pinctrl/meson/pinctrl-meson-axg.c b/drivers/pinctrl/meson/pinctrl-meson-axg.c index 5d234bca3d..820a6c9bb1 100644 --- a/drivers/pinctrl/meson/pinctrl-meson-axg.c +++ b/drivers/pinctrl/meson/pinctrl-meson-axg.c @@ -908,7 +908,7 @@ static struct meson_bank meson_axg_aobus_banks[] = { };
static struct meson_pmx_bank meson_axg_periphs_pmx_banks[] = { - /* name first last reg offset */ + /* name first last reg offset */ BANK_PMX("Z", PIN(GPIOZ_0, EE_OFF), PIN(GPIOZ_10, EE_OFF), 0x2, 0), BANK_PMX("BOOT", PIN(BOOT_0, EE_OFF), PIN(BOOT_14, EE_OFF), 0x0, 0), BANK_PMX("A", PIN(GPIOA_0, EE_OFF), PIN(GPIOA_20, EE_OFF), 0xb, 0), diff --git a/drivers/pinctrl/meson/pinctrl-meson-g12a.c b/drivers/pinctrl/meson/pinctrl-meson-g12a.c index 8bd265ad95..90a4f8056c 100644 --- a/drivers/pinctrl/meson/pinctrl-meson-g12a.c +++ b/drivers/pinctrl/meson/pinctrl-meson-g12a.c @@ -1220,7 +1220,7 @@ static struct meson_bank meson_g12a_aobus_banks[] = { };
static struct meson_pmx_bank meson_g12a_periphs_pmx_banks[] = { - /* name first last reg offset */ + /* name first last reg offset */ BANK_PMX("Z", PIN(GPIOZ_0, EE_OFF), PIN(GPIOZ_15, EE_OFF), 0x6, 0), BANK_PMX("H", PIN(GPIOH_0, EE_OFF), PIN(GPIOH_8, EE_OFF), 0xb, 0), BANK_PMX("BOOT", PIN(BOOT_0, EE_OFF), PIN(BOOT_15, EE_OFF), 0x0, 0), diff --git a/drivers/pinctrl/renesas/pfc-r8a77970.c b/drivers/pinctrl/renesas/pfc-r8a77970.c index 4e6f406214..8cf133a2ba 100644 --- a/drivers/pinctrl/renesas/pfc-r8a77970.c +++ b/drivers/pinctrl/renesas/pfc-r8a77970.c @@ -161,7 +161,7 @@ #define IP0_31_28 FM(DU_DG3) FM(MSIOF3_SS2) F_(0, 0) FM(A7) FM(PWMFSW0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP1_3_0 FM(DU_DG4) F_(0, 0) F_(0, 0) FM(A8) FM(FSO_CFE_0_N_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP1_7_4 FM(DU_DG5) F_(0, 0) F_(0, 0) FM(A9) FM(FSO_CFE_1_N_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) -#define IP1_11_8 FM(DU_DG6) F_(0, 0) F_(0, 0) FM(A10) FM(FSO_TOE_N_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP1_11_8 FM(DU_DG6) F_(0, 0) F_(0, 0) FM(A10) FM(FSO_TOE_N_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP1_15_12 FM(DU_DG7) F_(0, 0) F_(0, 0) FM(A11) FM(IRQ1) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP1_19_16 FM(DU_DB2) F_(0, 0) F_(0, 0) FM(A12) FM(IRQ2) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP1_23_20 FM(DU_DB3) F_(0, 0) F_(0, 0) FM(A13) FM(FXR_CLKOUT1) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) diff --git a/drivers/pinctrl/renesas/pfc-r8a77980.c b/drivers/pinctrl/renesas/pfc-r8a77980.c index 2d15500f0f..7cd4ef9830 100644 --- a/drivers/pinctrl/renesas/pfc-r8a77980.c +++ b/drivers/pinctrl/renesas/pfc-r8a77980.c @@ -88,7 +88,7 @@ #define GPSR1_0 F_(IRQ0, IP2_27_24)
/* GPSR2 */ -#define GPSR2_29 F_(FSO_TOE_N, IP10_19_16) +#define GPSR2_29 F_(FSO_TOE_N, IP10_19_16) #define GPSR2_28 F_(FSO_CFE_1_N, IP10_15_12) #define GPSR2_27 F_(FSO_CFE_0_N, IP10_11_8) #define GPSR2_26 F_(SDA3, IP10_7_4) @@ -253,11 +253,11 @@ #define IP8_11_8 FM(CANFD0_RX_A) FM(RXDA_EXTFXR) FM(PWM1_B) FM(DU_CDE) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP8_15_12 FM(CANFD1_TX) FM(FXR_TXDB) FM(PWM2_B) FM(TCLK1_B) FM(TX1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP8_19_16 FM(CANFD1_RX) FM(RXDB_EXTFXR) FM(PWM3_B) FM(TCLK2_B) FM(RX1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) -#define IP8_23_20 FM(CANFD_CLK_A) FM(CLK_EXTFXR) FM(PWM4_B) FM(SPEEDIN_B) FM(SCIF_CLK_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP8_23_20 FM(CANFD_CLK_A) FM(CLK_EXTFXR) FM(PWM4_B) FM(SPEEDIN_B) FM(SCIF_CLK_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP8_27_24 FM(DIGRF_CLKIN) FM(DIGRF_CLKEN_IN) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP8_31_28 FM(DIGRF_CLKOUT) FM(DIGRF_CLKEN_OUT) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP9_3_0 FM(IRQ4) F_(0, 0) F_(0, 0) FM(VI0_DATA12) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) -#define IP9_7_4 FM(IRQ5) F_(0, 0) F_(0, 0) FM(VI0_DATA13) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP9_7_4 FM(IRQ5) F_(0, 0) F_(0, 0) FM(VI0_DATA13) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP9_11_8 FM(MSIOF0_RXD) FM(DU_DR0) F_(0, 0) FM(VI0_DATA14) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP9_15_12 FM(MSIOF0_TXD) FM(DU_DR1) F_(0, 0) FM(VI0_DATA15) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) #define IP9_19_16 FM(MSIOF0_SCK) FM(DU_DG0) F_(0, 0) FM(VI0_DATA16) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) diff --git a/drivers/power/pmic/pmic_tps65910.c b/drivers/power/pmic/pmic_tps65910.c index fcd0a654a8..e3de730821 100644 --- a/drivers/power/pmic/pmic_tps65910.c +++ b/drivers/power/pmic/pmic_tps65910.c @@ -51,7 +51,7 @@ int power_tps65910_init(unsigned char bus)
/* * tps65910_set_i2c_control() - Set the TPS65910 to be controlled via the I2C - * interface. + * interface. * @return: 0 on success, not 0 on failure */ int tps65910_set_i2c_control(void) diff --git a/drivers/pwm/pwm-meson.c b/drivers/pwm/pwm-meson.c index 03eeacc286..2311910a63 100644 --- a/drivers/pwm/pwm-meson.c +++ b/drivers/pwm/pwm-meson.c @@ -401,7 +401,7 @@ static const struct pwm_ops meson_pwm_ops = { .set_invert = meson_pwm_set_invert, };
-#define XTAL -1 +#define XTAL -1
/* Local clock ids aliases to avoid define conflicts */ #define GXBB_CLKID_HDMI_PLL 2 diff --git a/drivers/ram/k3-ddrss/k3-ddrss.c b/drivers/ram/k3-ddrss/k3-ddrss.c index cb8edcbc15..95b5cf9128 100644 --- a/drivers/ram/k3-ddrss/k3-ddrss.c +++ b/drivers/ram/k3-ddrss/k3-ddrss.c @@ -27,8 +27,8 @@ #define CTRLMMR_DDR4_FSP_CLKCHNG_REQ_OFFS 0x80 #define CTRLMMR_DDR4_FSP_CLKCHNG_ACK_OFFS 0xc0
-#define DDRSS_V2A_R1_MAT_REG 0x0020 -#define DDRSS_ECC_CTRL_REG 0x0120 +#define DDRSS_V2A_R1_MAT_REG 0x0020 +#define DDRSS_ECC_CTRL_REG 0x0120
struct k3_ddrss_desc { struct udevice *dev; diff --git a/drivers/spi/atcspi200_spi.c b/drivers/spi/atcspi200_spi.c index 775b9ffc25..de9c14837c 100644 --- a/drivers/spi/atcspi200_spi.c +++ b/drivers/spi/atcspi200_spi.c @@ -81,7 +81,7 @@ struct nds_spi_slave { unsigned int freq; ulong clock; unsigned int mode; - u8 num_cs; + u8 num_cs; unsigned int mtiming; size_t cmd_len; u8 cmd_buf[16]; diff --git a/drivers/thermal/imx_tmu.c b/drivers/thermal/imx_tmu.c index 07766baf45..ca45abbb8e 100644 --- a/drivers/thermal/imx_tmu.c +++ b/drivers/thermal/imx_tmu.c @@ -22,8 +22,8 @@ DECLARE_GLOBAL_DATA_PTR;
#define SITES_MAX 16 -#define FLAGS_VER2 0x1 -#define FLAGS_VER3 0x2 +#define FLAGS_VER2 0x1 +#define FLAGS_VER3 0x2
#define TMR_DISABLE 0x0 #define TMR_ME 0x80000000 diff --git a/drivers/timer/atmel_pit_timer.c b/drivers/timer/atmel_pit_timer.c index 3178e58884..5cf46f224a 100644 --- a/drivers/timer/atmel_pit_timer.c +++ b/drivers/timer/atmel_pit_timer.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright (C) 2017 Microchip Corporation - * Wenyou.Yang wenyou.yang@microchip.com + * Wenyou.Yang wenyou.yang@microchip.com */
#include <common.h> diff --git a/drivers/usb/dwc3/core.h b/drivers/usb/dwc3/core.h index 44533fd7fe..1502cb859a 100644 --- a/drivers/usb/dwc3/core.h +++ b/drivers/usb/dwc3/core.h @@ -691,8 +691,8 @@ struct dwc3_scratchpad_array { * @has_lpm_erratum: true when core was configured with LPM Erratum. Note that * there's now way for software to detect this in runtime. * @is_utmi_l1_suspend: the core asserts output signal - * 0 - utmi_sleep_n - * 1 - utmi_l1_suspend_n + * 0 - utmi_sleep_n + * 1 - utmi_l1_suspend_n * @is_selfpowered: true when we are selfpowered * @is_fpga: true when we are using the FPGA board * @needs_fifo_resize: not all users might want fifo resizing, flag it @@ -713,10 +713,10 @@ struct dwc3_scratchpad_array { * @dis_u2_susphy_quirk: set if we disable usb2 suspend phy * @tx_de_emphasis_quirk: set if we enable Tx de-emphasis quirk * @tx_de_emphasis: Tx de-emphasis value - * 0 - -6dB de-emphasis - * 1 - -3.5dB de-emphasis - * 2 - No de-emphasis - * 3 - Reserved + * 0 - -6dB de-emphasis + * 1 - -3.5dB de-emphasis + * 2 - No de-emphasis + * 3 - Reserved * @index: index of _this_ controller * @list: to maintain the list of dwc3 controllers */ diff --git a/drivers/usb/dwc3/gadget.c b/drivers/usb/dwc3/gadget.c index 4e68fb0a82..eb416b832a 100644 --- a/drivers/usb/dwc3/gadget.c +++ b/drivers/usb/dwc3/gadget.c @@ -2209,7 +2209,7 @@ static void dwc3_gadget_conndone_interrupt(struct dwc3 *dwc) * BESL value in the LPM token is less than or equal to LPM * NYET threshold. */ - if (dwc->revision < DWC3_REVISION_240A && dwc->has_lpm_erratum) + if (dwc->revision < DWC3_REVISION_240A && dwc->has_lpm_erratum) WARN(true, "LPM Erratum not available on dwc3 revisisions < 2.40a\n");
if (dwc->has_lpm_erratum && dwc->revision >= DWC3_REVISION_240A) diff --git a/drivers/usb/gadget/at91_udc.h b/drivers/usb/gadget/at91_udc.h index 96a521ee08..e18de0e2f0 100644 --- a/drivers/usb/gadget/at91_udc.h +++ b/drivers/usb/gadget/at91_udc.h @@ -35,7 +35,7 @@
#define AT91_UDP_ISR 0x1c /* Interrupt Status Register */ #define AT91_UDP_EP(n) (1 << (n)) /* Endpoint Interrupt Status */ -#define AT91_UDP_RXSUSP (1 << 8) /* USB Suspend Interrupt Status */ +#define AT91_UDP_RXSUSP (1 << 8) /* USB Suspend Interrupt Status */ #define AT91_UDP_RXRSM (1 << 9) /* USB Resume Interrupt Status */ #define AT91_UDP_EXTRSM (1 << 10) /* External Resume Interrupt Status [AT91RM9200 only] */ #define AT91_UDP_SOFINT (1 << 11) /* Start of Frame Interrupt Status */ diff --git a/drivers/usb/gadget/pxa27x_udc.c b/drivers/usb/gadget/pxa27x_udc.c index ba362b8f25..583ceb4d55 100644 --- a/drivers/usb/gadget/pxa27x_udc.c +++ b/drivers/usb/gadget/pxa27x_udc.c @@ -472,7 +472,7 @@ void udc_irq(void) * so using '|=' isn't safe as it may ack an interrupt. */ #define UDCCR_OEN (1 << 31) /* On-the-Go Enable */ -#define UDCCR_MASK_BITS (UDCCR_OEN | UDCCR_UDE) +#define UDCCR_MASK_BITS (UDCCR_OEN | UDCCR_UDE)
static inline void udc_set_mask_UDCCR(int mask) { diff --git a/drivers/usb/host/xhci-rcar-r8a779x_usb3_v3.h b/drivers/usb/host/xhci-rcar-r8a779x_usb3_v3.h index f0f48a3354..8db88f0dcf 100644 --- a/drivers/usb/host/xhci-rcar-r8a779x_usb3_v3.h +++ b/drivers/usb/host/xhci-rcar-r8a779x_usb3_v3.h @@ -40,7 +40,7 @@ * * To generate the content of the array below, use ie. the following command: * $ hexdump -v -e '/4 "0x%08x, "' r8a779x_usb3_v3.dlmem | \ - * sed "s@(.{47}) @\1\n@g" + * sed "s@(.{47}) @\1\n@g" * * [1] git://git.kernel.org/pub/scm/linux/kernel/git/dwmw2/linux-firmware.git */ diff --git a/drivers/usb/musb-new/musb_gadget.c b/drivers/usb/musb-new/musb_gadget.c index 5b149dac6d..1fef00b292 100644 --- a/drivers/usb/musb-new/musb_gadget.c +++ b/drivers/usb/musb-new/musb_gadget.c @@ -995,8 +995,8 @@ void musb_g_rx(struct musb *musb, u8 epnum) && (musb_ep->dma->actual_len == musb_ep->packet_sz)) { /* In double buffer case, continue to unload fifo if - * there is Rx packet in FIFO. - **/ + * there is Rx packet in FIFO. + **/ csr = musb_readw(epio, MUSB_RXCSR); if ((csr & MUSB_RXCSR_RXPKTRDY) && hw_ep->rx_double_buffered) diff --git a/drivers/usb/musb/musb_core.h b/drivers/usb/musb/musb_core.h index e5d8ac7028..47b839c083 100644 --- a/drivers/usb/musb/musb_core.h +++ b/drivers/usb/musb/musb_core.h @@ -207,14 +207,14 @@ struct musb_regs { /* TxType/RxType */ #define MUSB_TYPE_SPEED 0xc0 #define MUSB_TYPE_SPEED_SHIFT 6 -#define MUSB_TYPE_SPEED_HIGH 1 -#define MUSB_TYPE_SPEED_FULL 2 +#define MUSB_TYPE_SPEED_HIGH 1 +#define MUSB_TYPE_SPEED_FULL 2 #define MUSB_TYPE_SPEED_LOW 3 #define MUSB_TYPE_PROTO 0x30 /* Implicitly zero for ep0 */ #define MUSB_TYPE_PROTO_SHIFT 4 #define MUSB_TYPE_REMOTE_END 0xf /* Implicitly zero for ep0 */ -#define MUSB_TYPE_PROTO_BULK 2 -#define MUSB_TYPE_PROTO_INTR 3 +#define MUSB_TYPE_PROTO_BULK 2 +#define MUSB_TYPE_PROTO_INTR 3
/* CONFIGDATA */ #define MUSB_CONFIGDATA_MPRXE 0x80 /* Auto bulk pkt combining */ @@ -304,7 +304,7 @@ struct musb_regs { * values are not supported */ struct musb_epinfo { - u8 epnum; /* endpoint number */ + u8 epnum; /* endpoint number */ u8 epdir; /* endpoint direction */ u16 epsize; /* endpoint FIFO size */ }; diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index ffed3b82be..17901704f5 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -14,7 +14,7 @@ #include "musb_hcd.h"
/* MSC control transfers */ -#define USB_MSC_BBB_RESET 0xFF +#define USB_MSC_BBB_RESET 0xFF #define USB_MSC_BBB_GET_MAX_LUN 0xFE
/* Endpoint configuration information */ diff --git a/drivers/video/bus_vcxk.c b/drivers/video/bus_vcxk.c index 2a72d23eb8..3863662d9f 100644 --- a/drivers/video/bus_vcxk.c +++ b/drivers/video/bus_vcxk.c @@ -63,8 +63,8 @@ at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE;
#ifndef CONFIG_SYS_VCXK_DOUBLEBUFFERED #define VCXK_BWS(x, data) vcxk_bws[x] = data; - #define VCXK_BWS_WORD_SET(x, mask) vcxk_bws_word[x] |= mask; - #define VCXK_BWS_WORD_CLEAR(x, mask) vcxk_bws_word[x] &= ~mask; + #define VCXK_BWS_WORD_SET(x, mask) vcxk_bws_word[x] |= mask; + #define VCXK_BWS_WORD_CLEAR(x, mask) vcxk_bws_word[x] &= ~mask; #define VCXK_BWS_LONG(x, data) vcxk_bws_long[x] = data; #else u_char double_bws[16384]; @@ -83,7 +83,7 @@ at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; #endif
#define VC4K16_Bright1 vcxk_bws_word[0x20004 / 2] -#define VC4K16_Bright2 vcxk_bws_word[0x20006 / 2] +#define VC4K16_Bright2 vcxk_bws_word[0x20006 / 2] #define VC2K_Bright vcxk_bws[0x8000] #define VC8K_BrightH vcxk_bws[0xC000] #define VC8K_BrightL vcxk_bws[0xC001] @@ -263,7 +263,7 @@ void vcxk_clear(void) * set the display brightness * PARAMETER * side 1 set front side brightness - * 2 set back side brightness + * 2 set back side brightness * 3 set brightness for both sides * brightness 0..1000 *** @@ -276,7 +276,7 @@ void vcxk_setbrightness(unsigned int side, short brightness) VC4K16_Bright1 = brightness + 23; if ((side == 0) || (side & 0x2)) VC4K16_Bright2 = brightness + 23; - } else { + } else { VC2K_Bright = (brightness >> 4) + 2; VC8K_BrightH = (brightness + 23) >> 8; VC8K_BrightL = (brightness + 23) & 0xFF; diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 523d8a8d98..98d2965711 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -54,7 +54,7 @@ __weak void mxsfb_system_setup(void) * Freescale mx23evk/mx28evk with a Seiko 4.3'' WVGA panel: * setenv videomode * video=ctfb:x:800,y:480,depth:24,mode:0,pclk:29851, - * le:89,ri:164,up:23,lo:10,hs:10,vs:10,sync:0,vmode:0 + * le:89,ri:164,up:23,lo:10,hs:10,vs:10,sync:0,vmode:0 */
static void mxs_lcd_init(struct udevice *dev, u32 fb_addr, diff --git a/drivers/watchdog/orion_wdt.c b/drivers/watchdog/orion_wdt.c index cebea426fb..c30ed82217 100644 --- a/drivers/watchdog/orion_wdt.c +++ b/drivers/watchdog/orion_wdt.c @@ -4,8 +4,8 @@ * Watchdog driver for Orion/Kirkwood processors * * Authors: Tomas Hlavacek tmshlvck@gmail.com - * Sylver Bruneau sylver.bruneau@googlemail.com - * Marek Behun marek.behun@nic.cz + * Sylver Bruneau sylver.bruneau@googlemail.com + * Marek Behun marek.behun@nic.cz * * This file is licensed under the terms of the GNU General Public * License version 2. This program is licensed "as is" without any diff --git a/fs/btrfs/btrfs.c b/fs/btrfs/btrfs.c index 52a243a659..741c6e20f5 100644 --- a/fs/btrfs/btrfs.c +++ b/fs/btrfs/btrfs.c @@ -23,7 +23,7 @@ static int show_dir(struct btrfs_root *root, struct extent_buffer *eb, struct btrfs_key key; static const char* dir_item_str[] = { [BTRFS_FT_REG_FILE] = " ", - [BTRFS_FT_DIR] = "DIR", + [BTRFS_FT_DIR] = "DIR", [BTRFS_FT_CHRDEV] = "CHR", [BTRFS_FT_BLKDEV] = "BLK", [BTRFS_FT_FIFO] = "FIF", diff --git a/fs/jffs2/summary.h b/fs/jffs2/summary.h index 834933cd15..c8cba88529 100644 --- a/fs/jffs2/summary.h +++ b/fs/jffs2/summary.h @@ -39,7 +39,7 @@ struct jffs2_sum_inode_flash __u32 inode; /* inode number */ __u32 version; /* inode version */ __u32 offset; /* offset on jeb */ - __u32 totlen; /* record length */ + __u32 totlen; /* record length */ } __attribute__((packed));
struct jffs2_sum_dirent_flash @@ -49,7 +49,7 @@ struct jffs2_sum_dirent_flash __u32 offset; /* offset on jeb */ __u32 pino; /* parent inode */ __u32 version; /* dirent version */ - __u32 ino; /* == zero for unlink */ + __u32 ino; /* == zero for unlink */ uint8_t nsize; /* dirent name size */ uint8_t type; /* dirent type */ uint8_t name[0]; /* dirent name */ @@ -94,7 +94,7 @@ struct jffs2_sum_inode_mem __u32 inode; /* inode number */ __u32 version; /* inode version */ __u32 offset; /* offset on jeb */ - __u32 totlen; /* record length */ + __u32 totlen; /* record length */ } __attribute__((packed));
struct jffs2_sum_dirent_mem @@ -105,7 +105,7 @@ struct jffs2_sum_dirent_mem __u32 offset; /* ofset on jeb */ __u32 pino; /* parent inode */ __u32 version; /* dirent version */ - __u32 ino; /* == zero for unlink */ + __u32 ino; /* == zero for unlink */ uint8_t nsize; /* dirent name size */ uint8_t type; /* dirent type */ uint8_t name[0]; /* dirent name */ @@ -155,7 +155,7 @@ struct jffs2_summary struct jffs2_sum_marker { __u32 offset; /* offset of the summary node in the jeb */ - __u32 magic; /* == JFFS2_SUM_MAGIC */ + __u32 magic; /* == JFFS2_SUM_MAGIC */ };
#define JFFS2_SUMMARY_FRAME_SIZE (sizeof(struct jffs2_raw_summary) + sizeof(struct jffs2_sum_marker)) diff --git a/fs/ubifs/ubifs.h b/fs/ubifs/ubifs.h index 512fdaa144..46dfbd0b5a 100644 --- a/fs/ubifs/ubifs.h +++ b/fs/ubifs/ubifs.h @@ -252,10 +252,10 @@ struct inode { };
struct super_operations { - struct inode *(*alloc_inode)(struct super_block *sb); + struct inode *(*alloc_inode)(struct super_block *sb); void (*destroy_inode)(struct inode *);
- void (*dirty_inode) (struct inode *, int flags); + void (*dirty_inode) (struct inode *, int flags); int (*write_inode) (struct inode *, struct writeback_control *wbc); int (*drop_inode) (struct inode *); void (*evict_inode) (struct inode *); @@ -326,7 +326,7 @@ struct super_block { char s_id[32]; /* Informational name */ u8 s_uuid[16]; /* UUID */
- void *s_fs_info; /* Filesystem private info */ + void *s_fs_info; /* Filesystem private info */ unsigned int s_max_links; #ifndef __UBOOT__ fmode_t s_mode; @@ -431,7 +431,7 @@ struct file { #define f_dentry f_path.dentry #define f_vfsmnt f_path.mnt const struct file_operations *f_op; - unsigned int f_flags; + unsigned int f_flags; loff_t f_pos; unsigned int f_uid, f_gid;
@@ -466,7 +466,7 @@ struct file { #if BITS_PER_LONG==32 #define MAX_LFS_FILESIZE (((u64)PAGE_CACHE_SIZE << (BITS_PER_LONG-1))-1) #elif BITS_PER_LONG==64 -#define MAX_LFS_FILESIZE 0x7fffffffffffffffUL +#define MAX_LFS_FILESIZE 0x7fffffffffffffffUL #endif
/* diff --git a/include/atsha204a-i2c.h b/include/atsha204a-i2c.h index 344fd8ace7..39fc0e9ca7 100644 --- a/include/atsha204a-i2c.h +++ b/include/atsha204a-i2c.h @@ -2,8 +2,8 @@ * I2C Driver for Atmel ATSHA204 over I2C * * Copyright (C) 2014 Josh Datko, Cryptotronix, jbd@cryptotronix.com - * 2016 Tomas Hlavacek, CZ.NIC, tmshlvck@gmail.com - * 2017 Marek Behun, CZ.NIC, marek.behun@nic.cz + * 2016 Tomas Hlavacek, CZ.NIC, tmshlvck@gmail.com + * 2017 Marek Behun, CZ.NIC, marek.behun@nic.cz * * This program is free software; you can redistribute it and/or modify it * under the terms of the GNU General Public License version 2 as diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 51ecf4173b..f0cee49525 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -91,7 +91,7 @@ (AT91_PMC_PLLAR_29 | \ AT91_PMC_PLLXR_OUT(MASTER_PLL_OUT) | \ AT91_PMC_PLLXR_PLLCOUNT(63) | \ - AT91_PMC_PLLXR_MUL(MASTER_PLL_MUL - 1) | \ + AT91_PMC_PLLXR_MUL(MASTER_PLL_MUL - 1) | \ AT91_PMC_PLLXR_DIV(MASTER_PLL_DIV))
/* PCK/2 = MCK Master Clock from PLLA */ @@ -101,7 +101,7 @@
/* PCK/2 = MCK Master Clock from PLLA */ #define CONFIG_SYS_MCKR2_VAL \ - (AT91_PMC_MCKR_CSS_PLLA | AT91_PMC_MCKR_PRES_1 | \ + (AT91_PMC_MCKR_CSS_PLLA | AT91_PMC_MCKR_PRES_1 | \ AT91_PMC_MCKR_MDIV_2)
/* define PDC[31:16] as DATA[31:16] */ diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index 3b17f75d20..266084d04d 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -20,7 +20,7 @@ * U-Boot into it. */
-#define CONFIG_LOADADDR 1000000 +#define CONFIG_LOADADDR 1000000
/* * SATA/SCSI/AHCI configuration diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index c877f3c725..9152e8e3f7 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -165,7 +165,7 @@ #define PIXIS_LBMAP_ALTBANK 0x40
#define CONFIG_SYS_FLASH_QUIET_TEST -#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ diff --git a/include/configs/imx7-cm.h b/include/configs/imx7-cm.h index 4a3706d996..6e529f3186 100644 --- a/include/configs/imx7-cm.h +++ b/include/configs/imx7-cm.h @@ -23,9 +23,9 @@
/* * Use: - * boot-mode=mix - * boot-mode=sd - * boot-mode=net + * boot-mode=mix + * boot-mode=sd + * boot-mode=net */ #define MY_CONFIG_BOOT_MODE "boot-mode=sd\0"
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 834c3e6780..dce8c55c8a 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -236,7 +236,7 @@ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ "fdt_high=0xffffffffffffffff\0" \ "initrd_high=0xffffffffffffffff\0" \ - "fdt_addr=0x64f00000\0" \ + "fdt_addr=0x64f00000\0" \ "kernel_addr=0x61000000\0" \ "scriptaddr=0x80000000\0" \ "scripthdraddr=0x80080000\0" \ diff --git a/include/configs/novena.h b/include/configs/novena.h index 3876412ee6..d0cb703248 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -118,7 +118,7 @@ "kernel_addr_r="__stringify(CONFIG_LOADADDR)"\0" \ "pxefile_addr_r="__stringify(CONFIG_LOADADDR)"\0" \ "scriptaddr="__stringify(CONFIG_LOADADDR)"\0" \ - "ramdisk_addr_r=0x28000000\0" \ + "ramdisk_addr_r=0x28000000\0" \ "fdt_addr_r=0x18000000\0" \ "fdtfile=imx6q-novena.dtb\0" \ "stdout=serial,vidconsole\0" \ diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 6563335f91..e6b4b2f032 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -211,7 +211,7 @@ "${defargs} " \ "${optargs} " \ "root=${ramroot} ramdisk_size=${ramdisk_size} " \ - "rootfstype=${ramrootfstype}\0" \ + "rootfstype=${ramrootfstype}\0" \ "ramboot=run mmcbootenv; " \ "if run loadimage && run loaddtb && run loadramdisk; then " \ "echo Booting ${bootdir}/${bootfile} from mmc ${bootpart} w/ramdisk ...; " \ diff --git a/include/configs/opos6uldev.h b/include/configs/opos6uldev.h index 2fb1634a7d..a6f38fe101 100644 --- a/include/configs/opos6uldev.h +++ b/include/configs/opos6uldev.h @@ -78,7 +78,7 @@ "mmcrootfstype=ext4 rootwait\0" \ "kernelimg=" __stringify(CONFIG_BOARD_NAME) "-linux.bin\0" \ "splashpos=0,0\0" \ - "splashimage=" __stringify(CONFIG_LOADADDR) "\0" \ + "splashimage=" __stringify(CONFIG_LOADADDR) "\0" \ "videomode=video=ctfb:x:800,y:480,depth:18,pclk:33033,le:96,ri:96,up:20,lo:21,hs:64,vs:4,sync:0,vmode:0\0" \ "check_env=if test -n ${flash_env_version}; " \ "then env default env_version; " \ diff --git a/include/configs/socrates.h b/include/configs/socrates.h index da60546966..ecc8886d1d 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -133,7 +133,7 @@ #define CONFIG_SYS_FPGA_SIZE 0x00100000 /* 1 MB */ #define CONFIG_SYS_HMI_BASE 0xc0010000 #define CONFIG_SYS_BR3_PRELIM 0xc0001881 /* UPMA, 32-bit */ -#define CONFIG_SYS_OR3_PRELIM 0xfff00000 /* 1 MB */ +#define CONFIG_SYS_OR3_PRELIM 0xfff00000 /* 1 MB */
#define CONFIG_SYS_NAND_BASE (CONFIG_SYS_FPGA_BASE + 0x70) #define CONFIG_SYS_MAX_NAND_DEVICE 1 @@ -254,17 +254,17 @@ "era fe000000 fe1dffff;" \ "cp.b 100000 fe000000 ${filesize};" \ "setenv filesize;saveenv\0" \ - "update_fdt=tftp 100000 ${fdt_file};" \ + "update_fdt=tftp 100000 ${fdt_file};" \ "era fe1e0000 fe1fffff;" \ "cp.b 100000 fe1e0000 ${filesize};" \ "setenv filesize;saveenv\0" \ - "update_initrd=tftp 100000 ${initrd_file};" \ + "update_initrd=tftp 100000 ${initrd_file};" \ "era fe200000 fe9fffff;" \ "cp.b 100000 fe200000 ${filesize};" \ "setenv filesize;saveenv\0" \ "clean_data=era fea00000 fff5ffff\0" \ - "usbargs=setenv bootargs root=/dev/sda1 rw\0" \ - "load_usb=usb start;" \ + "usbargs=setenv bootargs root=/dev/sda1 rw\0" \ + "load_usb=usb start;" \ "ext2load usb 0:1 ${kernel_addr_r} /boot/uImage\0" \ "boot_usb=run load_usb usbargs addcons;" \ "bootm ${kernel_addr_r} - ${fdt_addr};" \ diff --git a/include/div64.h b/include/div64.h index 8b92d2b183..66a2af4df0 100644 --- a/include/div64.h +++ b/include/div64.h @@ -220,7 +220,7 @@ extern u32 __div64_32(u64 *dividend, u32 divisor); } else if (likely(((n) >> 32) == 0)) { \ __rem = (u32)(n) % __base; \ (n) = (u32)(n) / __base; \ - } else \ + } else \ __rem = __div64_32(&(n), __base); \ __rem; \ }) diff --git a/include/dt-bindings/mfd/dbx500-prcmu.h b/include/dt-bindings/mfd/dbx500-prcmu.h index 0404bcc47d..7266ae67b0 100644 --- a/include/dt-bindings/mfd/dbx500-prcmu.h +++ b/include/dt-bindings/mfd/dbx500-prcmu.h @@ -12,64 +12,64 @@ */ #define ARMCLK 0 #define PRCMU_ACLK 1 -#define PRCMU_SVAMMCSPCLK 2 -#define PRCMU_SDMMCHCLK 2 /* DBx540 only. */ -#define PRCMU_SIACLK 3 -#define PRCMU_SIAMMDSPCLK 3 /* DBx540 only. */ -#define PRCMU_SGACLK 4 -#define PRCMU_UARTCLK 5 -#define PRCMU_MSP02CLK 6 -#define PRCMU_MSP1CLK 7 -#define PRCMU_I2CCLK 8 -#define PRCMU_SDMMCCLK 9 -#define PRCMU_SLIMCLK 10 -#define PRCMU_CAMCLK 10 /* DBx540 only. */ -#define PRCMU_PER1CLK 11 -#define PRCMU_PER2CLK 12 -#define PRCMU_PER3CLK 13 -#define PRCMU_PER5CLK 14 -#define PRCMU_PER6CLK 15 -#define PRCMU_PER7CLK 16 -#define PRCMU_LCDCLK 17 -#define PRCMU_BMLCLK 18 -#define PRCMU_HSITXCLK 19 -#define PRCMU_HSIRXCLK 20 +#define PRCMU_SVAMMCSPCLK 2 +#define PRCMU_SDMMCHCLK 2 /* DBx540 only. */ +#define PRCMU_SIACLK 3 +#define PRCMU_SIAMMDSPCLK 3 /* DBx540 only. */ +#define PRCMU_SGACLK 4 +#define PRCMU_UARTCLK 5 +#define PRCMU_MSP02CLK 6 +#define PRCMU_MSP1CLK 7 +#define PRCMU_I2CCLK 8 +#define PRCMU_SDMMCCLK 9 +#define PRCMU_SLIMCLK 10 +#define PRCMU_CAMCLK 10 /* DBx540 only. */ +#define PRCMU_PER1CLK 11 +#define PRCMU_PER2CLK 12 +#define PRCMU_PER3CLK 13 +#define PRCMU_PER5CLK 14 +#define PRCMU_PER6CLK 15 +#define PRCMU_PER7CLK 16 +#define PRCMU_LCDCLK 17 +#define PRCMU_BMLCLK 18 +#define PRCMU_HSITXCLK 19 +#define PRCMU_HSIRXCLK 20 #define PRCMU_HDMICLK 21 -#define PRCMU_APEATCLK 22 -#define PRCMU_APETRACECLK 23 -#define PRCMU_MCDECLK 24 -#define PRCMU_IPI2CCLK 25 -#define PRCMU_DSIALTCLK 26 -#define PRCMU_DMACLK 27 -#define PRCMU_B2R2CLK 28 -#define PRCMU_TVCLK 29 -#define SPARE_UNIPROCLK 30 -#define PRCMU_SSPCLK 31 -#define PRCMU_RNGCLK 32 -#define PRCMU_UICCCLK 33 +#define PRCMU_APEATCLK 22 +#define PRCMU_APETRACECLK 23 +#define PRCMU_MCDECLK 24 +#define PRCMU_IPI2CCLK 25 +#define PRCMU_DSIALTCLK 26 +#define PRCMU_DMACLK 27 +#define PRCMU_B2R2CLK 28 +#define PRCMU_TVCLK 29 +#define SPARE_UNIPROCLK 30 +#define PRCMU_SSPCLK 31 +#define PRCMU_RNGCLK 32 +#define PRCMU_UICCCLK 33 #define PRCMU_G1CLK 34 /* DBx540 only. */ #define PRCMU_HVACLK 35 /* DBx540 only. */ -#define PRCMU_SPARE1CLK 36 -#define PRCMU_SPARE2CLK 37 +#define PRCMU_SPARE1CLK 36 +#define PRCMU_SPARE2CLK 37
-#define PRCMU_NUM_REG_CLOCKS 38 +#define PRCMU_NUM_REG_CLOCKS 38
-#define PRCMU_RTCCLK PRCMU_NUM_REG_CLOCKS -#define PRCMU_SYSCLK 39 -#define PRCMU_CDCLK 40 -#define PRCMU_TIMCLK 41 -#define PRCMU_PLLSOC0 42 -#define PRCMU_PLLSOC1 43 -#define PRCMU_ARMSS 44 -#define PRCMU_PLLDDR 45 +#define PRCMU_RTCCLK PRCMU_NUM_REG_CLOCKS +#define PRCMU_SYSCLK 39 +#define PRCMU_CDCLK 40 +#define PRCMU_TIMCLK 41 +#define PRCMU_PLLSOC0 42 +#define PRCMU_PLLSOC1 43 +#define PRCMU_ARMSS 44 +#define PRCMU_PLLDDR 45
/* DSI Clocks */ -#define PRCMU_PLLDSI 46 -#define PRCMU_DSI0CLK 47 -#define PRCMU_DSI1CLK 48 -#define PRCMU_DSI0ESCCLK 49 -#define PRCMU_DSI1ESCCLK 50 -#define PRCMU_DSI2ESCCLK 51 +#define PRCMU_PLLDSI 46 +#define PRCMU_DSI0CLK 47 +#define PRCMU_DSI1CLK 48 +#define PRCMU_DSI0ESCCLK 49 +#define PRCMU_DSI1ESCCLK 50 +#define PRCMU_DSI2ESCCLK 51
/* LCD DSI PLL - Ux540 only */ #define PRCMU_PLLDSI_LCD 52 @@ -79,6 +79,6 @@ #define PRCMU_DSI1ESCCLK_LCD 56 #define PRCMU_DSI2ESCCLK_LCD 57
-#define PRCMU_NUM_CLKS 58 +#define PRCMU_NUM_CLKS 58
#endif diff --git a/include/environment/distro/sf.h b/include/environment/distro/sf.h index e793be06c6..62624d553c 100644 --- a/include/environment/distro/sf.h +++ b/include/environment/distro/sf.h @@ -10,16 +10,16 @@
#if CONFIG_IS_ENABLED(CMD_SF) #define BOOTENV_SHARED_SF(devtypel) \ - #devtypel "_boot=" \ + #devtypel "_boot=" \ "if " #devtypel " probe ${busnum}; then " \ - "devtype=" #devtypel "; " \ - "run scan_sf_for_scripts; " \ + "devtype=" #devtypel "; " \ + "run scan_sf_for_scripts; " \ "fi\0" -#define BOOTENV_DEV_SF(devtypeu, devtypel, instance) \ - "bootcmd_" #devtypel #instance "=" \ - "busnum=" #instance "; " \ +#define BOOTENV_DEV_SF(devtypeu, devtypel, instance) \ + "bootcmd_" #devtypel #instance "=" \ + "busnum=" #instance "; " \ "run " #devtypel "_boot\0" -#define BOOTENV_DEV_NAME_SF(devtypeu, devtypel, instance) \ +#define BOOTENV_DEV_NAME_SF(devtypeu, devtypel, instance) \ #devtypel #instance " " #else #define BOOTENV_SHARED_SF(devtypel) diff --git a/include/faraday/ftpmu010.h b/include/faraday/ftpmu010.h index 8fc81f902d..ccb7805375 100644 --- a/include/faraday/ftpmu010.h +++ b/include/faraday/ftpmu010.h @@ -137,7 +137,7 @@ struct ftpmu010 { * 1. FTPMU010_PDLLCR0_HCLKOUTDIS: * Datasheet indicated it starts at bit #21 which was wrong. * 2. FTPMU010_PDLLCR0_DLLFRAG: - * Datasheet indicated it has 2 bit which was wrong. + * Datasheet indicated it has 2 bit which was wrong. */ #define FTPMU010_PDLLCR0_HCLKOUTDIS(cr0) (((cr0) & 0xf) << 20) #define FTPMU010_PDLLCR0_DLLFRAG(cr0) (1 << 19) diff --git a/include/fsl_qe.h b/include/fsl_qe.h index cd8fca95b4..48accb8d89 100644 --- a/include/fsl_qe.h +++ b/include/fsl_qe.h @@ -40,7 +40,7 @@ typedef struct qe_snum { #define QE_RISC_ALLOCATION_RISC2 0x2 /* RISC 2 */ #define QE_RISC_ALLOCATION_RISC3 0x4 /* RISC 3 */ #define QE_RISC_ALLOCATION_RISC4 0x8 /* RISC 4 */ -#define QE_RISC_ALLOCATION_RISC1_AND_RISC2 (QE_RISC_ALLOCATION_RISC1 | \ +#define QE_RISC_ALLOCATION_RISC1_AND_RISC2 (QE_RISC_ALLOCATION_RISC1 | \ QE_RISC_ALLOCATION_RISC2) #define QE_RISC_ALLOCATION_FOUR_RISCS (QE_RISC_ALLOCATION_RISC1 | \ QE_RISC_ALLOCATION_RISC2 | \ diff --git a/include/fsl_wdog.h b/include/fsl_wdog.h index 655f22ed9a..29f00d3b9f 100644 --- a/include/fsl_wdog.h +++ b/include/fsl_wdog.h @@ -14,6 +14,6 @@ struct watchdog_regs { #define WCR_WDE 0x04 #define WCR_WDT 0x08 #define WCR_SRS 0x10 -#define WCR_WDA 0x20 +#define WCR_WDA 0x20 #define SET_WCR_WT(x) (x << 8) #define WCR_WT_MSK SET_WCR_WT(0xFF) diff --git a/include/generic-phy.h b/include/generic-phy.h index a17d900e4b..9a11659640 100644 --- a/include/generic-phy.h +++ b/include/generic-phy.h @@ -201,7 +201,7 @@ int generic_phy_power_off(struct phy *phy); * generic_phy_configure() - configure a PHY device * * @phy: PHY port to be configured - * @params: PHY Parameters, underlying data is specific to the PHY function + * @params: PHY Parameters, underlying data is specific to the PHY function * @return 0 if OK, or a negative error code */ int generic_phy_configure(struct phy *phy, void *params); diff --git a/include/imximage.h b/include/imximage.h index 1ed3284f15..5a812f5a10 100644 --- a/include/imximage.h +++ b/include/imximage.h @@ -124,7 +124,7 @@ typedef struct { } flash_header_v1_t;
typedef struct { - uint32_t length; /* Length of data to be read from flash */ + uint32_t length; /* Length of data to be read from flash */ } flash_cfg_parms_t;
typedef struct { diff --git a/include/linux/apm_bios.h b/include/linux/apm_bios.h index 3dabc3f770..32d1401770 100644 --- a/include/linux/apm_bios.h +++ b/include/linux/apm_bios.h @@ -34,7 +34,7 @@ struct apm_bios_info { #define APM_16_BIT_SUPPORT 0x0001 #define APM_32_BIT_SUPPORT 0x0002 #define APM_IDLE_SLOWS_CLOCK 0x0004 -#define APM_BIOS_DISABLED 0x0008 +#define APM_BIOS_DISABLED 0x0008 #define APM_BIOS_DISENGAGED 0x0010
/* diff --git a/include/linux/compiler.h b/include/linux/compiler.h index 98dd3fc4cc..09cea0e95e 100644 --- a/include/linux/compiler.h +++ b/include/linux/compiler.h @@ -203,7 +203,7 @@ void __read_once_size(const volatile void *p, void *res, int size) /* * We can't declare function 'inline' because __no_sanitize_address confilcts * with inlining. Attempt to inline it may cause a build failure. - * https://gcc.gnu.org/bugzilla/show_bug.cgi?id=67368 + * https://gcc.gnu.org/bugzilla/show_bug.cgi?id=67368 * '__maybe_unused' allows us to avoid defined-but-not-used warnings. */ # define __no_kasan_or_inline __no_sanitize_address notrace __maybe_unused diff --git a/include/linux/ioport.h b/include/linux/ioport.h index 7129504e05..85288c3729 100644 --- a/include/linux/ioport.h +++ b/include/linux/ioport.h @@ -63,7 +63,7 @@ struct resource_list { #define IORESOURCE_IRQ_HIGHLEVEL (1<<2) #define IORESOURCE_IRQ_LOWLEVEL (1<<3) #define IORESOURCE_IRQ_SHAREABLE (1<<4) -#define IORESOURCE_IRQ_OPTIONAL (1<<5) +#define IORESOURCE_IRQ_OPTIONAL (1<<5)
/* PnP DMA specific bits (IORESOURCE_BITS) */ #define IORESOURCE_DMA_TYPE_MASK (3<<0) diff --git a/include/linux/list.h b/include/linux/list.h index f62afa092c..3eacf68e3a 100644 --- a/include/linux/list.h +++ b/include/linux/list.h @@ -456,7 +456,7 @@ static inline void list_splice_tail_init(struct list_head *list, * Continue to iterate over list of given type, continuing after * the current position. */ -#define list_for_each_entry_continue(pos, head, member) \ +#define list_for_each_entry_continue(pos, head, member) \ for (pos = list_entry(pos->member.next, typeof(*pos), member); \ prefetch(pos->member.next), &pos->member != (head); \ pos = list_entry(pos->member.next, typeof(*pos), member)) @@ -510,7 +510,7 @@ static inline void list_splice_tail_init(struct list_head *list, * Iterate over list of given type, continuing after current point, * safe against removal of list entry. */ -#define list_for_each_entry_safe_continue(pos, n, head, member) \ +#define list_for_each_entry_safe_continue(pos, n, head, member) \ for (pos = list_entry(pos->member.next, typeof(*pos), member), \ n = list_entry(pos->member.next, typeof(*pos), member); \ &pos->member != (head); \ diff --git a/include/linux/mtd/doc2000.h b/include/linux/mtd/doc2000.h index d57f8da810..a72cb7d20b 100644 --- a/include/linux/mtd/doc2000.h +++ b/include/linux/mtd/doc2000.h @@ -54,7 +54,7 @@ #define DoC_Mplus_Configuration 0x100a #define DoC_Mplus_OutputControl 0x100c #define DoC_Mplus_FlashControl 0x1020 -#define DoC_Mplus_FlashSelect 0x1022 +#define DoC_Mplus_FlashSelect 0x1022 #define DoC_Mplus_FlashCmd 0x1024 #define DoC_Mplus_FlashAddress 0x1026 #define DoC_Mplus_FlashData0 0x1028 @@ -62,14 +62,14 @@ #define DoC_Mplus_ReadPipeInit 0x102a #define DoC_Mplus_LastDataRead 0x102c #define DoC_Mplus_LastDataRead1 0x102d -#define DoC_Mplus_WritePipeTerm 0x102e +#define DoC_Mplus_WritePipeTerm 0x102e #define DoC_Mplus_ECCSyndrome0 0x1040 #define DoC_Mplus_ECCSyndrome1 0x1041 #define DoC_Mplus_ECCSyndrome2 0x1042 #define DoC_Mplus_ECCSyndrome3 0x1043 #define DoC_Mplus_ECCSyndrome4 0x1044 #define DoC_Mplus_ECCSyndrome5 0x1045 -#define DoC_Mplus_ECCConf 0x1046 +#define DoC_Mplus_ECCConf 0x1046 #define DoC_Mplus_Toggle 0x1046 #define DoC_Mplus_DownloadStatus 0x1074 #define DoC_Mplus_CtrlConfirm 0x1076 diff --git a/include/linux/mtd/partitions.h b/include/linux/mtd/partitions.h index 3822237f2a..0f5a233266 100644 --- a/include/linux/mtd/partitions.h +++ b/include/linux/mtd/partitions.h @@ -21,16 +21,16 @@ * For each partition, these fields are available: * name: string that will be used to label the partition's MTD device. * size: the partition size; if defined as MTDPART_SIZ_FULL, the partition - * will extend to the end of the master MTD device. + * will extend to the end of the master MTD device. * offset: absolute starting position within the master MTD device; if - * defined as MTDPART_OFS_APPEND, the partition will start where the + * defined as MTDPART_OFS_APPEND, the partition will start where the * previous one ended; if MTDPART_OFS_NXTBLK, at the next erase block; * if MTDPART_OFS_RETAIN, consume as much as possible, leaving size * after the end of partition. * mask_flags: contains flags that have to be masked (removed) from the - * master MTD flag set for the corresponding MTD partition. - * For example, to force a read-only partition, simply adding - * MTD_WRITEABLE to the mask_flags will do the trick. + * master MTD flag set for the corresponding MTD partition. + * For example, to force a read-only partition, simply adding + * MTD_WRITEABLE to the mask_flags will do the trick. * * Note: writeable partitions require their size and offset be * erasesize aligned (e.g. use MTDPART_OFS_NEXTBLK). diff --git a/include/linux/screen_info.h b/include/linux/screen_info.h index 899fbb487c..46e7fff899 100644 --- a/include/linux/screen_info.h +++ b/include/linux/screen_info.h @@ -47,7 +47,7 @@ struct screen_info { } __attribute__((packed));
#define VIDEO_TYPE_MDA 0x10 /* Monochrome Text Display */ -#define VIDEO_TYPE_CGA 0x11 /* CGA Display */ +#define VIDEO_TYPE_CGA 0x11 /* CGA Display */ #define VIDEO_TYPE_EGAM 0x20 /* EGA/VGA in Monochrome Mode */ #define VIDEO_TYPE_EGAC 0x21 /* EGA in Color Mode */ #define VIDEO_TYPE_VGAC 0x22 /* VGA+ in Color Mode */ @@ -74,7 +74,7 @@ extern struct screen_info screen_info; #define ORIG_X (screen_info.orig_x) #define ORIG_Y (screen_info.orig_y) #define ORIG_VIDEO_MODE (screen_info.orig_video_mode) -#define ORIG_VIDEO_COLS (screen_info.orig_video_cols) +#define ORIG_VIDEO_COLS (screen_info.orig_video_cols) #define ORIG_VIDEO_EGA_BX (screen_info.orig_video_ega_bx) #define ORIG_VIDEO_LINES (screen_info.orig_video_lines) #define ORIG_VIDEO_ISVGA (screen_info.orig_video_isVGA) diff --git a/include/linux/serial_reg.h b/include/linux/serial_reg.h index 20ea54397f..061371773c 100644 --- a/include/linux/serial_reg.h +++ b/include/linux/serial_reg.h @@ -257,7 +257,7 @@ */ #define UART_ASR 0x01 /* Additional Status Register */ #define UART_RFL 0x03 /* Receiver FIFO level */ -#define UART_TFL 0x04 /* Transmitter FIFO level */ +#define UART_TFL 0x04 /* Transmitter FIFO level */ #define UART_ICR 0x05 /* Index Control Register */
/* The 16950 ICR registers */ diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 7e6d329e54..b3f4b8d134 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -160,14 +160,14 @@ struct usb_ep_caps { * endpoint. It's set once by UDC driver when endpoint is initialized, and * should not be changed. Should not be confused with maxpacket. * @max_streams: The maximum number of streams supported - * by this EP (0 - 16, actual number is 2^n) + * by this EP (0 - 16, actual number is 2^n) * @maxburst: the maximum number of bursts supported by this EP (for usb3) * @driver_data:for use by the gadget driver. all other fields are * read-only to gadget drivers. * @desc: endpoint descriptor. This pointer is set before the endpoint is - * enabled and remains valid until the endpoint is disabled. + * enabled and remains valid until the endpoint is disabled. * @comp_desc: In case of SuperSpeed support, this is the endpoint companion - * descriptor that is used to configure the endpoint + * descriptor that is used to configure the endpoint * * the bus controller driver lists all the general purpose endpoints in * gadget->ep_list. the control endpoint (gadget->ep0) is not in that list, diff --git a/include/mc13783.h b/include/mc13783.h index 47345f006f..c7ee03b0f9 100644 --- a/include/mc13783.h +++ b/include/mc13783.h @@ -18,7 +18,7 @@ #define VIOLOEN (1 << 6) #define VIOLOSTBY (1 << 7) #define VIOLOMODE (1 << 8) -#define VDIGEN (1 << 9) +#define VDIGEN (1 << 9) #define VDIGSTBY (1 << 10) #define VDIGMODE (1 << 11) #define VGENEN (1 << 12) diff --git a/include/mpc85xx.h b/include/mpc85xx.h index 3753e47edf..ce6d083eff 100644 --- a/include/mpc85xx.h +++ b/include/mpc85xx.h @@ -42,7 +42,7 @@ CONFIG_SYS_CCSRBAR_PHYS_LOW and/or CONFIG_SYS_CCSRBAR_PHYS_HIGH instead." #endif
#ifndef CONFIG_SYS_CCSRBAR -#define CONFIG_SYS_CCSRBAR CONFIG_SYS_CCSRBAR_DEFAULT +#define CONFIG_SYS_CCSRBAR CONFIG_SYS_CCSRBAR_DEFAULT #endif
#ifndef CONFIG_SYS_CCSRBAR_PHYS_HIGH @@ -54,14 +54,14 @@ CONFIG_SYS_CCSRBAR_PHYS_LOW and/or CONFIG_SYS_CCSRBAR_PHYS_HIGH instead." #endif
#ifndef CONFIG_SYS_CCSRBAR_PHYS_LOW -#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR_DEFAULT +#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR_DEFAULT #endif
#define CONFIG_SYS_CCSRBAR_PHYS ((CONFIG_SYS_CCSRBAR_PHYS_HIGH * 1ull) << 32 | \ CONFIG_SYS_CCSRBAR_PHYS_LOW)
#ifndef CONFIG_SYS_IMMR -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR #endif
#endif /* __MPC85xx_H__ */ diff --git a/include/mtd/mtd-abi.h b/include/mtd/mtd-abi.h index 8d9761050f..ea244fbaeb 100644 --- a/include/mtd/mtd-abi.h +++ b/include/mtd/mtd-abi.h @@ -106,7 +106,7 @@ struct mtd_write_req { #define MTD_NANDECC_PLACE 1 // Use the given placement in the structure (YAFFS1 legacy mode) #define MTD_NANDECC_AUTOPLACE 2 // Use the default placement scheme #define MTD_NANDECC_PLACEONLY 3 // Use the given placement in the structure (Do not store ecc result on read) -#define MTD_NANDECC_AUTOPL_USR 4 // Use the given autoplacement scheme rather than using the default +#define MTD_NANDECC_AUTOPL_USR 4 // Use the given autoplacement scheme rather than using the default
/* OTP mode selection */ #define MTD_OTP_OFF 0 diff --git a/include/mvmfp.h b/include/mvmfp.h index 16f26841e2..de86ffd5e2 100644 --- a/include/mvmfp.h +++ b/include/mvmfp.h @@ -45,7 +45,7 @@ /* * to facilitate the definition, the following macros are provided * - * offset, pull,pF, drv,dF, edge,eF ,afn,aF + * offset, pull,pF, drv,dF, edge,eF ,afn,aF */ #define MFP_OFFSET_MASK MFP(0xffff, 0, 0, 0, 0, 0, 0) #define MFP_REG(x) MFP(x, 0, 0, 0, 0, 0, 0) diff --git a/include/part.h b/include/part.h index 419c859708..b66b07a1f0 100644 --- a/include/part.h +++ b/include/part.h @@ -75,7 +75,7 @@ struct disk_partition { char type_guid[UUID_STR_LEN + 1]; /* type GUID as string, if exists */ #endif #ifdef CONFIG_DOS_PARTITION - uchar sys_ind; /* partition type */ + uchar sys_ind; /* partition type */ #endif };
diff --git a/include/phy.h b/include/phy.h index 6b928636b6..8e949a7bb9 100644 --- a/include/phy.h +++ b/include/phy.h @@ -575,8 +575,8 @@ static inline bool phy_interface_is_sgmii(struct phy_device *phydev) }
/* PHY UIDs for various PHYs that are referenced in external code */ -#define PHY_UID_CS4340 0x13e51002 -#define PHY_UID_CS4223 0x03e57003 +#define PHY_UID_CS4340 0x13e51002 +#define PHY_UID_CS4223 0x03e57003 #define PHY_UID_TN2020 0x00a19410 #define PHY_UID_IN112525_S03 0x02107440
diff --git a/include/tsec.h b/include/tsec.h index 5433cfd966..c301c28d3d 100644 --- a/include/tsec.h +++ b/include/tsec.h @@ -25,7 +25,7 @@ #define TSEC_SIZE 0x40000 #define TSEC_MDIO_OFFSET 0x40000 #else -#define TSEC_SIZE 0x01000 +#define TSEC_SIZE 0x01000 #define TSEC_MDIO_OFFSET 0x01000 #endif
diff --git a/include/video_font_4x6.h b/include/video_font_4x6.h index 64c5ed2eda..c7e6351b64 100644 --- a/include/video_font_4x6.h +++ b/include/video_font_4x6.h @@ -49,7 +49,7 @@ __END__; static unsigned char video_fontdata[VIDEO_FONT_SIZE] = {
/*{*/ - /* Char 0: ' ' */ + /* Char 0: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -58,7 +58,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 1: ' ' */ + /* Char 1: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -67,7 +67,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 2: ' ' */ + /* Char 2: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -76,7 +76,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 3: ' ' */ + /* Char 3: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -85,7 +85,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 4: ' ' */ + /* Char 4: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -94,7 +94,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 5: ' ' */ + /* Char 5: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -103,7 +103,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 6: ' ' */ + /* Char 6: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -112,7 +112,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 7: ' ' */ + /* Char 7: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -121,7 +121,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 8: ' ' */ + /* Char 8: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -130,7 +130,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 9: ' ' */ + /* Char 9: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -139,7 +139,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 10: '' */ + /* Char 10: '' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -148,7 +148,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 11: ' ' */ + /* Char 11: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -157,7 +157,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 12: ' ' */ + /* Char 12: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -166,7 +166,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 13: ' ' */ + /* Char 13: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -175,7 +175,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 14: ' ' */ + /* Char 14: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -184,7 +184,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 15: ' ' */ + /* Char 15: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -193,7 +193,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 16: ' ' */ + /* Char 16: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -202,7 +202,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 17: ' ' */ + /* Char 17: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -211,7 +211,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 18: ' ' */ + /* Char 18: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -220,7 +220,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 19: ' ' */ + /* Char 19: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -229,7 +229,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 20: ' ' */ + /* Char 20: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -238,7 +238,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 21: ' ' */ + /* Char 21: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -247,7 +247,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 22: ' ' */ + /* Char 22: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -256,7 +256,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 23: ' ' */ + /* Char 23: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -265,7 +265,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 24: ' ' */ + /* Char 24: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -274,7 +274,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 25: ' ' */ + /* Char 25: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -283,7 +283,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 26: ' ' */ + /* Char 26: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -292,7 +292,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 27: ' ' */ + /* Char 27: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -301,7 +301,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 28: ' ' */ + /* Char 28: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -310,7 +310,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 29: ' ' */ + /* Char 29: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -319,7 +319,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 30: ' ' */ + /* Char 30: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -328,7 +328,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 31: ' ' */ + /* Char 31: ' ' */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -337,7 +337,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 32: ' ' */ + /* Char 32: ' ' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ @@ -346,7 +346,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 33: '!' */ + /* Char 33: '!' */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -355,7 +355,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 34: '"' */ + /* Char 34: '"' */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ @@ -364,7 +364,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 35: '#' */ + /* Char 35: '#' */ 0xaa, /*= [* * ] */ 0xff, /*= [****] */ 0xff, /*= [****] */ @@ -373,7 +373,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 36: '$' */ + /* Char 36: '$' */ 0x44, /*= [ * ] */ 0x66, /*= [ ** ] */ 0xee, /*= [*** ] */ @@ -382,7 +382,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 37: '%' */ + /* Char 37: '%' */ 0xaa, /*= [* * ] */ 0x22, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -391,7 +391,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 38: '&' */ + /* Char 38: '&' */ 0x66, /*= [ ** ] */ 0x99, /*= [* *] */ 0x66, /*= [ ** ] */ @@ -400,7 +400,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 39: ''' */ + /* Char 39: ''' */ 0x22, /*= [ * ] */ 0x44, /*= [ * ] */ 0x00, /*= [ ] */ @@ -409,7 +409,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 40: '(' */ + /* Char 40: '(' */ 0x22, /*= [ * ] */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -418,7 +418,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 41: ')' */ + /* Char 41: ')' */ 0x44, /*= [ * ] */ 0x22, /*= [ * ] */ 0x22, /*= [ * ] */ @@ -427,7 +427,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 42: '*' */ + /* Char 42: '*' */ 0x00, /*= [ ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -436,7 +436,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 43: '+' */ + /* Char 43: '+' */ 0x00, /*= [ ] */ 0x44, /*= [ * ] */ 0xee, /*= [*** ] */ @@ -445,7 +445,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 44: ',' */ + /* Char 44: ',' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ @@ -454,7 +454,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 45: '-' */ + /* Char 45: '-' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xee, /*= [*** ] */ @@ -463,7 +463,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 46: '.' */ + /* Char 46: '.' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ @@ -472,7 +472,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 47: '/' */ + /* Char 47: '/' */ 0x00, /*= [ ] */ 0x22, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -481,7 +481,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 48: '0' */ + /* Char 48: '0' */ 0x44, /*= [ * ] */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ @@ -490,7 +490,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 49: '1' */ + /* Char 49: '1' */ 0x44, /*= [ * ] */ 0xcc, /*= [** ] */ 0x44, /*= [ * ] */ @@ -499,7 +499,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 50: '2' */ + /* Char 50: '2' */ 0xcc, /*= [** ] */ 0x22, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -508,7 +508,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ /*}*/ /*{*/ - /* Char 51: '3' */ + /* Char 51: '3' */ 0xee, /*= [*** ] */ 0x22, /*= [ * ] */ 0x66, /*= [ ** ] */ @@ -516,7 +516,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 52: '4' */ + /*{*/ /* Char 52: '4' */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ 0xee, /*= [*** ] */ @@ -524,7 +524,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x22, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 53: '5' */ + /*{*/ /* Char 53: '5' */ 0xee, /*= [*** ] */ 0x88, /*= [* ] */ 0xee, /*= [*** ] */ @@ -532,7 +532,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 54: '6' */ + /*{*/ /* Char 54: '6' */ 0xee, /*= [*** ] */ 0x88, /*= [* ] */ 0xee, /*= [*** ] */ @@ -540,7 +540,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 55: '7' */ + /*{*/ /* Char 55: '7' */ 0xee, /*= [*** ] */ 0x22, /*= [ * ] */ 0x22, /*= [ * ] */ @@ -548,7 +548,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x22, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 56: '8' */ + /*{*/ /* Char 56: '8' */ 0xee, /*= [*** ] */ 0xaa, /*= [* * ] */ 0xee, /*= [*** ] */ @@ -556,7 +556,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 57: '9' */ + /*{*/ /* Char 57: '9' */ 0xee, /*= [*** ] */ 0xaa, /*= [* * ] */ 0xee, /*= [*** ] */ @@ -564,7 +564,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x22, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 58: ':' */ + /*{*/ /* Char 58: ':' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x44, /*= [ * ] */ @@ -572,7 +572,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 59: ';' */ + /*{*/ /* Char 59: ';' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x44, /*= [ * ] */ @@ -580,7 +580,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x88, /*= [* ] */ /*}*/ - /*{*/ /* Char 60: '<' */ + /*{*/ /* Char 60: '<' */ 0x22, /*= [ * ] */ 0x44, /*= [ * ] */ 0x88, /*= [* ] */ @@ -588,7 +588,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x22, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 61: '=' */ + /*{*/ /* Char 61: '=' */ 0x00, /*= [ ] */ 0xee, /*= [*** ] */ 0x00, /*= [ ] */ @@ -596,7 +596,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 62: '>' */ + /*{*/ /* Char 62: '>' */ 0x88, /*= [* ] */ 0x44, /*= [ * ] */ 0x22, /*= [ * ] */ @@ -604,7 +604,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x88, /*= [* ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 63: '?' */ + /*{*/ /* Char 63: '?' */ 0xee, /*= [*** ] */ 0x22, /*= [ * ] */ 0x66, /*= [ ** ] */ @@ -612,7 +612,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 64: '@' */ + /*{*/ /* Char 64: '@' */ 0x44, /*= [ * ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -620,7 +620,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 65: 'A' */ + /*{*/ /* Char 65: 'A' */ 0x44, /*= [ * ] */ 0xaa, /*= [* * ] */ 0xee, /*= [*** ] */ @@ -628,7 +628,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 66: 'B' */ + /*{*/ /* Char 66: 'B' */ 0xcc, /*= [** ] */ 0xaa, /*= [* * ] */ 0xcc, /*= [** ] */ @@ -636,7 +636,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xcc, /*= [** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 67: 'C' */ + /*{*/ /* Char 67: 'C' */ 0x66, /*= [ ** ] */ 0x88, /*= [* ] */ 0x88, /*= [* ] */ @@ -644,7 +644,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 68: 'D' */ + /*{*/ /* Char 68: 'D' */ 0xcc, /*= [** ] */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ @@ -652,7 +652,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xcc, /*= [** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 69: 'E' */ + /*{*/ /* Char 69: 'E' */ 0xee, /*= [*** ] */ 0x88, /*= [* ] */ 0xee, /*= [*** ] */ @@ -660,7 +660,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 70: 'F' */ + /*{*/ /* Char 70: 'F' */ 0xee, /*= [*** ] */ 0x88, /*= [* ] */ 0xee, /*= [*** ] */ @@ -668,7 +668,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x88, /*= [* ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 71: 'G' */ + /*{*/ /* Char 71: 'G' */ 0x66, /*= [ ** ] */ 0x88, /*= [* ] */ 0xee, /*= [*** ] */ @@ -676,7 +676,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 72: 'H' */ + /*{*/ /* Char 72: 'H' */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ 0xee, /*= [*** ] */ @@ -684,7 +684,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 73: 'I' */ + /*{*/ /* Char 73: 'I' */ 0xee, /*= [*** ] */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -692,7 +692,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 74: 'J' */ + /*{*/ /* Char 74: 'J' */ 0x22, /*= [ * ] */ 0x22, /*= [ * ] */ 0x22, /*= [ * ] */ @@ -700,7 +700,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 75: 'K' */ + /*{*/ /* Char 75: 'K' */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ 0xcc, /*= [** ] */ @@ -708,7 +708,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 76: 'L' */ + /*{*/ /* Char 76: 'L' */ 0x88, /*= [* ] */ 0x88, /*= [* ] */ 0x88, /*= [* ] */ @@ -716,7 +716,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 77: 'M' */ + /*{*/ /* Char 77: 'M' */ 0xaa, /*= [* * ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -724,7 +724,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 78: 'N' */ + /*{*/ /* Char 78: 'N' */ 0xaa, /*= [* * ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -732,7 +732,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 79: 'O' */ + /*{*/ /* Char 79: 'O' */ 0x44, /*= [ * ] */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ @@ -740,7 +740,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 80: 'P' */ + /*{*/ /* Char 80: 'P' */ 0xcc, /*= [** ] */ 0xaa, /*= [* * ] */ 0xcc, /*= [** ] */ @@ -748,7 +748,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x88, /*= [* ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 81: 'Q' */ + /*{*/ /* Char 81: 'Q' */ 0x44, /*= [ * ] */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ @@ -756,7 +756,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 82: 'R' */ + /*{*/ /* Char 82: 'R' */ 0xcc, /*= [** ] */ 0xaa, /*= [* * ] */ 0xee, /*= [*** ] */ @@ -764,7 +764,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 83: 'S' */ + /*{*/ /* Char 83: 'S' */ 0x66, /*= [ ** ] */ 0x88, /*= [* ] */ 0x44, /*= [ * ] */ @@ -772,7 +772,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xcc, /*= [** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 84: 'T' */ + /*{*/ /* Char 84: 'T' */ 0xee, /*= [*** ] */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -780,7 +780,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 85: 'U' */ + /*{*/ /* Char 85: 'U' */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ @@ -788,7 +788,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 86: 'V' */ + /*{*/ /* Char 86: 'V' */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ @@ -796,7 +796,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 87: 'W' */ + /*{*/ /* Char 87: 'W' */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ 0xee, /*= [*** ] */ @@ -804,7 +804,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 88: 'X' */ + /*{*/ /* Char 88: 'X' */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ 0x44, /*= [ * ] */ @@ -812,7 +812,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 89: 'Y' */ + /*{*/ /* Char 89: 'Y' */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ 0x44, /*= [ * ] */ @@ -820,7 +820,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 90: 'Z' */ + /*{*/ /* Char 90: 'Z' */ 0xee, /*= [*** ] */ 0x22, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -828,7 +828,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 91: '[' */ + /*{*/ /* Char 91: '[' */ 0x66, /*= [ ** ] */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -836,7 +836,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 92: '' */ + /*{*/ /* Char 92: '' */ 0x00, /*= [ ] */ 0x88, /*= [* ] */ 0x44, /*= [ * ] */ @@ -844,7 +844,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 93: ']' */ + /*{*/ /* Char 93: ']' */ 0x66, /*= [ ** ] */ 0x22, /*= [ * ] */ 0x22, /*= [ * ] */ @@ -852,7 +852,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 94: '^' */ + /*{*/ /* Char 94: '^' */ 0x44, /*= [ * ] */ 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ @@ -860,7 +860,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 95: '_' */ + /*{*/ /* Char 95: '_' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ @@ -868,7 +868,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0xff, /*= [****] */ /*}*/ - /*{*/ /* Char 96: '`' */ + /*{*/ /* Char 96: '`' */ 0x88, /*= [* ] */ 0x44, /*= [ * ] */ 0x00, /*= [ ] */ @@ -876,7 +876,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 97: 'a' */ + /*{*/ /* Char 97: 'a' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x66, /*= [ ** ] */ @@ -884,7 +884,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 98: 'b' */ + /*{*/ /* Char 98: 'b' */ 0x88, /*= [* ] */ 0x88, /*= [* ] */ 0xcc, /*= [** ] */ @@ -892,7 +892,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xcc, /*= [** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 99: 'c' */ + /*{*/ /* Char 99: 'c' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x66, /*= [ ** ] */ @@ -900,7 +900,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 100: 'd' */ + /*{*/ /* Char 100: 'd' */ 0x22, /*= [ * ] */ 0x22, /*= [ * ] */ 0x66, /*= [ ** ] */ @@ -908,7 +908,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 101: 'e' */ + /*{*/ /* Char 101: 'e' */ 0x00, /*= [ ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -916,7 +916,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 102: 'f' */ + /*{*/ /* Char 102: 'f' */ 0x22, /*= [ * ] */ 0x44, /*= [ * ] */ 0xee, /*= [*** ] */ @@ -924,7 +924,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 103: 'g' */ + /*{*/ /* Char 103: 'g' */ 0x00, /*= [ ] */ 0x66, /*= [ ** ] */ 0xaa, /*= [* * ] */ @@ -932,7 +932,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 104: 'h' */ + /*{*/ /* Char 104: 'h' */ 0x88, /*= [* ] */ 0x88, /*= [* ] */ 0xcc, /*= [** ] */ @@ -940,7 +940,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 105: 'i' */ + /*{*/ /* Char 105: 'i' */ 0x44, /*= [ * ] */ 0x00, /*= [ ] */ 0x44, /*= [ * ] */ @@ -948,7 +948,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 106: 'j' */ + /*{*/ /* Char 106: 'j' */ 0x44, /*= [ * ] */ 0x00, /*= [ ] */ 0x44, /*= [ * ] */ @@ -956,7 +956,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x88, /*= [* ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 107: 'k' */ + /*{*/ /* Char 107: 'k' */ 0x00, /*= [ ] */ 0x88, /*= [* ] */ 0xaa, /*= [* * ] */ @@ -964,7 +964,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 108: 'l' */ + /*{*/ /* Char 108: 'l' */ 0x00, /*= [ ] */ 0xcc, /*= [** ] */ 0x44, /*= [ * ] */ @@ -972,7 +972,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 109: 'm' */ + /*{*/ /* Char 109: 'm' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xee, /*= [*** ] */ @@ -980,7 +980,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 110: 'n' */ + /*{*/ /* Char 110: 'n' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xcc, /*= [** ] */ @@ -988,7 +988,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 111: 'o' */ + /*{*/ /* Char 111: 'o' */ 0x00, /*= [ ] */ 0x44, /*= [ * ] */ 0xaa, /*= [* * ] */ @@ -996,7 +996,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 112: 'p' */ + /*{*/ /* Char 112: 'p' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xcc, /*= [** ] */ @@ -1004,7 +1004,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xcc, /*= [** ] */ 0x88, /*= [* ] */ /*}*/ - /*{*/ /* Char 113: 'q' */ + /*{*/ /* Char 113: 'q' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x66, /*= [ ** ] */ @@ -1012,7 +1012,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x22, /*= [ * ] */ /*}*/ - /*{*/ /* Char 114: 'r' */ + /*{*/ /* Char 114: 'r' */ 0x00, /*= [ ] */ 0xcc, /*= [** ] */ 0xaa, /*= [* * ] */ @@ -1020,7 +1020,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x88, /*= [* ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 115: 's' */ + /*{*/ /* Char 115: 's' */ 0x00, /*= [ ] */ 0x66, /*= [ ** ] */ 0xcc, /*= [** ] */ @@ -1028,7 +1028,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xcc, /*= [** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 116: 't' */ + /*{*/ /* Char 116: 't' */ 0x00, /*= [ ] */ 0x44, /*= [ * ] */ 0xee, /*= [*** ] */ @@ -1036,7 +1036,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 117: 'u' */ + /*{*/ /* Char 117: 'u' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xaa, /*= [* * ] */ @@ -1044,7 +1044,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 118: 'v' */ + /*{*/ /* Char 118: 'v' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xaa, /*= [* * ] */ @@ -1052,7 +1052,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 119: 'w' */ + /*{*/ /* Char 119: 'w' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xaa, /*= [* * ] */ @@ -1060,7 +1060,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 120: 'x' */ + /*{*/ /* Char 120: 'x' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xaa, /*= [* * ] */ @@ -1068,7 +1068,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 121: 'y' */ + /*{*/ /* Char 121: 'y' */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xaa, /*= [* * ] */ @@ -1076,7 +1076,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x22, /*= [ * ] */ 0xcc, /*= [** ] */ /*}*/ - /*{*/ /* Char 122: 'z' */ + /*{*/ /* Char 122: 'z' */ 0x00, /*= [ ] */ 0xee, /*= [*** ] */ 0x66, /*= [ ** ] */ @@ -1084,7 +1084,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 123: '{' */ + /*{*/ /* Char 123: '{' */ 0x22, /*= [ * ] */ 0x44, /*= [ * ] */ 0xcc, /*= [** ] */ @@ -1092,7 +1092,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x22, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 124: '|' */ + /*{*/ /* Char 124: '|' */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -1100,7 +1100,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 125: '}' */ + /*{*/ /* Char 125: '}' */ 0x88, /*= [* ] */ 0x44, /*= [ * ] */ 0x66, /*= [ ** ] */ @@ -1108,7 +1108,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x88, /*= [* ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 126: '~' */ + /*{*/ /* Char 126: '~' */ 0x55, /*= [ * *] */ 0xaa, /*= [* * ] */ 0x00, /*= [ ] */ @@ -1116,7 +1116,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 127: '' */ + /*{*/ /* Char 127: '' */ 0x44, /*= [ * ] */ 0xaa, /*= [* * ] */ 0xaa, /*= [* * ] */ @@ -1124,7 +1124,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 128: */ + /*{*/ /* Char 128: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1132,7 +1132,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 129: */ + /*{*/ /* Char 129: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1140,7 +1140,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 130: */ + /*{*/ /* Char 130: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1148,7 +1148,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 131: */ + /*{*/ /* Char 131: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1156,7 +1156,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 132: */ + /*{*/ /* Char 132: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1164,7 +1164,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 133: */ + /*{*/ /* Char 133: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1172,7 +1172,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 134: */ + /*{*/ /* Char 134: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1180,7 +1180,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 135: */ + /*{*/ /* Char 135: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1188,7 +1188,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 136: */ + /*{*/ /* Char 136: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1196,7 +1196,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 137: */ + /*{*/ /* Char 137: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1204,7 +1204,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 138: */ + /*{*/ /* Char 138: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1212,7 +1212,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 139: */ + /*{*/ /* Char 139: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1220,7 +1220,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 140: */ + /*{*/ /* Char 140: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1228,7 +1228,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 141: */ + /*{*/ /* Char 141: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1236,7 +1236,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 142: */ + /*{*/ /* Char 142: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1244,7 +1244,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 143: */ + /*{*/ /* Char 143: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1252,7 +1252,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 144: */ + /*{*/ /* Char 144: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1260,7 +1260,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 145: */ + /*{*/ /* Char 145: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1268,7 +1268,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 146: */ + /*{*/ /* Char 146: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1276,7 +1276,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 147: */ + /*{*/ /* Char 147: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1284,7 +1284,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 148: */ + /*{*/ /* Char 148: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1292,7 +1292,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 149: */ + /*{*/ /* Char 149: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1300,7 +1300,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 150: */ + /*{*/ /* Char 150: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1308,7 +1308,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 151: */ + /*{*/ /* Char 151: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1316,7 +1316,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 152: */ + /*{*/ /* Char 152: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1324,7 +1324,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 153: */ + /*{*/ /* Char 153: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1332,7 +1332,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 154: */ + /*{*/ /* Char 154: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1340,7 +1340,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 155: */ + /*{*/ /* Char 155: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1348,7 +1348,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 156: */ + /*{*/ /* Char 156: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1356,7 +1356,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 157: */ + /*{*/ /* Char 157: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1364,7 +1364,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 158: */ + /*{*/ /* Char 158: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1372,7 +1372,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 159: */ + /*{*/ /* Char 159: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1380,7 +1380,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 160: */ + /*{*/ /* Char 160: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1388,7 +1388,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 161: */ + /*{*/ /* Char 161: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1396,7 +1396,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 162: */ + /*{*/ /* Char 162: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1404,7 +1404,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 163: */ + /*{*/ /* Char 163: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1412,7 +1412,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 164: */ + /*{*/ /* Char 164: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1420,7 +1420,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 165: */ + /*{*/ /* Char 165: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1428,7 +1428,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 166: */ + /*{*/ /* Char 166: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1436,7 +1436,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 167: */ + /*{*/ /* Char 167: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1444,7 +1444,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 168: */ + /*{*/ /* Char 168: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1452,7 +1452,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 169: */ + /*{*/ /* Char 169: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1460,7 +1460,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 170: */ + /*{*/ /* Char 170: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1468,7 +1468,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 171: */ + /*{*/ /* Char 171: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1476,7 +1476,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 172: */ + /*{*/ /* Char 172: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1484,7 +1484,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 173: */ + /*{*/ /* Char 173: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1492,7 +1492,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 174: */ + /*{*/ /* Char 174: */ 0x00, /*= [ ] */ 0x66, /*= [ ** ] */ 0xcc, /*= [** ] */ @@ -1500,7 +1500,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 175: */ + /*{*/ /* Char 175: */ 0x00, /*= [ ] */ 0xcc, /*= [** ] */ 0x66, /*= [ ** ] */ @@ -1508,7 +1508,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 176: */ + /*{*/ /* Char 176: */ 0x88, /*= [* ] */ 0x22, /*= [ * ] */ 0x88, /*= [* ] */ @@ -1516,7 +1516,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x88, /*= [* ] */ 0x22, /*= [ * ] */ /*}*/ - /*{*/ /* Char 177: */ + /*{*/ /* Char 177: */ 0xaa, /*= [* * ] */ 0x55, /*= [ * *] */ 0xaa, /*= [* * ] */ @@ -1524,7 +1524,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xaa, /*= [* * ] */ 0x55, /*= [ * *] */ /*}*/ - /*{*/ /* Char 178: */ + /*{*/ /* Char 178: */ 0xdd, /*= [** *] */ 0xbb, /*= [* **] */ 0xdd, /*= [** *] */ @@ -1532,7 +1532,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xdd, /*= [** *] */ 0xbb, /*= [* **] */ /*}*/ - /*{*/ /* Char 179: */ + /*{*/ /* Char 179: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ @@ -1540,7 +1540,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 180: */ + /*{*/ /* Char 180: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0xcc, /*= [** ] */ @@ -1548,7 +1548,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 181: */ + /*{*/ /* Char 181: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0xcc, /*= [** ] */ @@ -1556,7 +1556,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 182: */ + /*{*/ /* Char 182: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0xee, /*= [*** ] */ @@ -1564,7 +1564,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 183: */ + /*{*/ /* Char 183: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xee, /*= [*** ] */ @@ -1572,7 +1572,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 184: */ + /*{*/ /* Char 184: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xcc, /*= [** ] */ @@ -1580,7 +1580,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 185: */ + /*{*/ /* Char 185: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0xee, /*= [*** ] */ @@ -1588,7 +1588,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 186: */ + /*{*/ /* Char 186: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ @@ -1596,7 +1596,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 187: */ + /*{*/ /* Char 187: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xee, /*= [*** ] */ @@ -1604,7 +1604,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 188: */ + /*{*/ /* Char 188: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0xee, /*= [*** ] */ @@ -1612,7 +1612,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 189: */ + /*{*/ /* Char 189: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0xee, /*= [*** ] */ @@ -1620,7 +1620,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 190: */ + /*{*/ /* Char 190: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0xcc, /*= [** ] */ @@ -1628,7 +1628,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 191: */ + /*{*/ /* Char 191: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xcc, /*= [** ] */ @@ -1636,7 +1636,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 192: */ + /*{*/ /* Char 192: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0x77, /*= [ ***] */ @@ -1644,7 +1644,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 193: */ + /*{*/ /* Char 193: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0xff, /*= [****] */ @@ -1652,7 +1652,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 194: */ + /*{*/ /* Char 194: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xff, /*= [****] */ @@ -1660,7 +1660,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 195: */ + /*{*/ /* Char 195: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0x77, /*= [ ***] */ @@ -1668,7 +1668,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 196: */ + /*{*/ /* Char 196: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xff, /*= [****] */ @@ -1676,7 +1676,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 197: */ + /*{*/ /* Char 197: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0xff, /*= [****] */ @@ -1684,7 +1684,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 198: */ + /*{*/ /* Char 198: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0x77, /*= [ ***] */ @@ -1692,7 +1692,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 199: */ + /*{*/ /* Char 199: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0x77, /*= [ ***] */ @@ -1700,7 +1700,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 200: */ + /*{*/ /* Char 200: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0x77, /*= [ ***] */ @@ -1708,7 +1708,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 201: */ + /*{*/ /* Char 201: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x77, /*= [ ***] */ @@ -1716,7 +1716,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 202: */ + /*{*/ /* Char 202: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0xff, /*= [****] */ @@ -1724,7 +1724,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 203: */ + /*{*/ /* Char 203: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xff, /*= [****] */ @@ -1732,7 +1732,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 204: */ + /*{*/ /* Char 204: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0x77, /*= [ ***] */ @@ -1740,7 +1740,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 205: */ + /*{*/ /* Char 205: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xff, /*= [****] */ @@ -1748,7 +1748,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 206: */ + /*{*/ /* Char 206: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0xff, /*= [****] */ @@ -1756,7 +1756,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 207: */ + /*{*/ /* Char 207: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0xff, /*= [****] */ @@ -1764,7 +1764,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 208: */ + /*{*/ /* Char 208: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0xff, /*= [****] */ @@ -1772,7 +1772,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 209: */ + /*{*/ /* Char 209: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xff, /*= [****] */ @@ -1780,7 +1780,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 210: */ + /*{*/ /* Char 210: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0xff, /*= [****] */ @@ -1788,7 +1788,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 211: */ + /*{*/ /* Char 211: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0x77, /*= [ ***] */ @@ -1796,7 +1796,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 212: */ + /*{*/ /* Char 212: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0x77, /*= [ ***] */ @@ -1804,7 +1804,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 213: */ + /*{*/ /* Char 213: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x77, /*= [ ***] */ @@ -1812,7 +1812,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 214: */ + /*{*/ /* Char 214: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x77, /*= [ ***] */ @@ -1820,7 +1820,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 215: */ + /*{*/ /* Char 215: */ 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ 0xff, /*= [****] */ @@ -1828,7 +1828,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x66, /*= [ ** ] */ 0x66, /*= [ ** ] */ /*}*/ - /*{*/ /* Char 216: */ + /*{*/ /* Char 216: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0xff, /*= [****] */ @@ -1836,7 +1836,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 217: */ + /*{*/ /* Char 217: */ 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ 0xcc, /*= [** ] */ @@ -1844,7 +1844,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 218: */ + /*{*/ /* Char 218: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x77, /*= [ ***] */ @@ -1852,7 +1852,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x44, /*= [ * ] */ 0x44, /*= [ * ] */ /*}*/ - /*{*/ /* Char 219: */ + /*{*/ /* Char 219: */ 0xff, /*= [****] */ 0xff, /*= [****] */ 0xff, /*= [****] */ @@ -1860,7 +1860,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xff, /*= [****] */ 0xff, /*= [****] */ /*}*/ - /*{*/ /* Char 220: */ + /*{*/ /* Char 220: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ @@ -1868,7 +1868,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xff, /*= [****] */ 0xff, /*= [****] */ /*}*/ - /*{*/ /* Char 221: */ + /*{*/ /* Char 221: */ 0xcc, /*= [** ] */ 0xcc, /*= [** ] */ 0xcc, /*= [** ] */ @@ -1876,7 +1876,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xcc, /*= [** ] */ 0xcc, /*= [** ] */ /*}*/ - /*{*/ /* Char 222: */ + /*{*/ /* Char 222: */ 0x33, /*= [ **] */ 0x33, /*= [ **] */ 0x33, /*= [ **] */ @@ -1884,7 +1884,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x33, /*= [ **] */ 0x33, /*= [ **] */ /*}*/ - /*{*/ /* Char 223: */ + /*{*/ /* Char 223: */ 0xff, /*= [****] */ 0xff, /*= [****] */ 0xff, /*= [****] */ @@ -1892,7 +1892,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 224: */ + /*{*/ /* Char 224: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1900,7 +1900,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 225: */ + /*{*/ /* Char 225: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1908,7 +1908,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 226: */ + /*{*/ /* Char 226: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1916,7 +1916,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 227: */ + /*{*/ /* Char 227: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1924,7 +1924,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 228: */ + /*{*/ /* Char 228: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1932,7 +1932,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 229: */ + /*{*/ /* Char 229: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1940,7 +1940,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 230: */ + /*{*/ /* Char 230: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1948,7 +1948,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 231: */ + /*{*/ /* Char 231: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1956,7 +1956,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 232: */ + /*{*/ /* Char 232: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1964,7 +1964,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 233: */ + /*{*/ /* Char 233: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1972,7 +1972,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 234: */ + /*{*/ /* Char 234: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1980,7 +1980,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 235: */ + /*{*/ /* Char 235: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1988,7 +1988,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 236: */ + /*{*/ /* Char 236: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -1996,7 +1996,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 237: */ + /*{*/ /* Char 237: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2004,7 +2004,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 238: */ + /*{*/ /* Char 238: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2012,7 +2012,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 239: */ + /*{*/ /* Char 239: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2020,7 +2020,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 240: */ + /*{*/ /* Char 240: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2028,7 +2028,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 241: */ + /*{*/ /* Char 241: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2036,7 +2036,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 242: */ + /*{*/ /* Char 242: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2044,7 +2044,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 243: */ + /*{*/ /* Char 243: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2052,7 +2052,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 244: */ + /*{*/ /* Char 244: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2060,7 +2060,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 245: */ + /*{*/ /* Char 245: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2068,7 +2068,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 246: */ + /*{*/ /* Char 246: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2076,7 +2076,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 247: */ + /*{*/ /* Char 247: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2084,7 +2084,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 248: */ + /*{*/ /* Char 248: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2092,7 +2092,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 249: */ + /*{*/ /* Char 249: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2100,7 +2100,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 250: */ + /*{*/ /* Char 250: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2108,7 +2108,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 251: */ + /*{*/ /* Char 251: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2116,7 +2116,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 252: */ + /*{*/ /* Char 252: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2124,7 +2124,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 253: */ + /*{*/ /* Char 253: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ @@ -2132,7 +2132,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0xee, /*= [*** ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 254: */ + /*{*/ /* Char 254: */ 0x00, /*= [ ] */ 0x00, /*= [ ] */ 0x66, /*= [ ** ] */ @@ -2140,7 +2140,7 @@ static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /*= [ ] */ 0x00, /*= [ ] */ /*}*/ - /*{*/ /* Char 255: */ + /*{*/ /* Char 255: */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ 0xee, /*= [*** ] */ diff --git a/scripts/basic/Makefile b/scripts/basic/Makefile index 092a8876d6..848f16d3c4 100644 --- a/scripts/basic/Makefile +++ b/scripts/basic/Makefile @@ -7,7 +7,7 @@ # when kernel configuration changes (which is what happens when # .config is included by main Makefile. # --------------------------------------------------------------------------- -# fixdep: Used to generate dependency information during build process +# fixdep: Used to generate dependency information during build process
hostprogs-y := fixdep always := $(hostprogs-y) diff --git a/scripts/kconfig/Makefile b/scripts/kconfig/Makefile index d52128425c..12e525ee31 100644 --- a/scripts/kconfig/Makefile +++ b/scripts/kconfig/Makefile @@ -50,7 +50,7 @@ build_xconfig: $(obj)/qconf
localyesconfig localmodconfig: $(obj)/conf $(Q)perl $(srctree)/$(src)/streamline_config.pl --$@ $(srctree) $(Kconfig) > .tmp.config - $(Q)if [ -f .config ]; then \ + $(Q)if [ -f .config ]; then \ cmp -s .tmp.config .config || \ (mv -f .config .config.old.1; \ mv -f .tmp.config .config; \ diff --git a/scripts/kconfig/expr.c b/scripts/kconfig/expr.c index e1a39e9084..9f79bdfaaa 100644 --- a/scripts/kconfig/expr.c +++ b/scripts/kconfig/expr.c @@ -894,7 +894,7 @@ bool expr_depends_symbol(struct expr *dep, struct symbol *sym) default: ; } - return false; + return false; }
/* diff --git a/scripts/kconfig/list.h b/scripts/kconfig/list.h index 45cb237ab7..06e8d555d8 100644 --- a/scripts/kconfig/list.h +++ b/scripts/kconfig/list.h @@ -48,7 +48,7 @@ struct list_head { */ #define list_for_each_entry(pos, head, member) \ for (pos = list_entry((head)->next, typeof(*pos), member); \ - &pos->member != (head); \ + &pos->member != (head); \ pos = list_entry(pos->member.next, typeof(*pos), member))
/** diff --git a/tools/kwbimage.h b/tools/kwbimage.h index e063e3e41e..10e3254a58 100644 --- a/tools/kwbimage.h +++ b/tools/kwbimage.h @@ -23,8 +23,8 @@ /* NAND ECC Mode */ #define IBR_HDR_ECC_DEFAULT 0x00 #define IBR_HDR_ECC_FORCED_HAMMING 0x01 -#define IBR_HDR_ECC_FORCED_RS 0x02 -#define IBR_HDR_ECC_DISABLED 0x03 +#define IBR_HDR_ECC_FORCED_RS 0x02 +#define IBR_HDR_ECC_DISABLED 0x03
/* Boot Type - block ID */ #define IBR_HDR_I2C_ID 0x4D
On Mon, Sep 27, 2021 at 05:42:39PM +0200, Wolfgang Denk wrote:
Signed-off-by: Wolfgang Denk wd@denx.de
