[U-Boot] [PATCH 0/2] Introduction of new board Peach-Pit
This board is based on Exynos5420 and is similar to SMDK5420 board. Adding new and refactoring existing DT and config files to support both SMDK5420 and Peach-Pit.
Akshay Saraswat (2): Exynos5420: Introduce support for the Peach-Pit board Exynos5420: Let macros be used for exynos5420
arch/arm/cpu/armv7/exynos/exynos5_setup.h | 6 +- arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos5420-peach-pit.dts | 127 +++++++++++++++++++++++++ arch/arm/dts/exynos5420-smdk5420.dts | 23 +---- arch/arm/dts/exynos5420.dtsi | 70 -------------- arch/arm/dts/exynos54xx.dtsi | 151 ++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/exynos5420.h | 46 +++++++++ include/configs/peach-pit.h | 27 ++++++ include/configs/smdk5420.h | 49 ++-------- 10 files changed, 367 insertions(+), 136 deletions(-) create mode 100644 arch/arm/dts/exynos5420-peach-pit.dts delete mode 100644 arch/arm/dts/exynos5420.dtsi create mode 100644 arch/arm/dts/exynos54xx.dtsi create mode 100644 include/configs/exynos5420.h create mode 100644 include/configs/peach-pit.h
While the Exynos5420 chip is used in both Smdk5420 and in the Peach-Pit line of devices, there could be other boards using the same chip, so a common configuration file is being added (exynos5420.h) as well as two common device tree files (exynos54xx.dtsi & exynos5420.dtsi).
The peach board as declared in boards.cfg is a copy of smdk5420 declaration. The configuration files are similar, but define different default device trees, console serial ports and prompts.
The device tree files for smdk5420 and peach-pit inherit from the same common file.
Signed-off-by: Vadim Bendebury vbendeb@chromium.org Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos5420-peach-pit.dts | 127 ++++++++++++++++++++++++++++ arch/arm/dts/exynos5420-smdk5420.dts | 23 +----- arch/arm/dts/exynos5420.dtsi | 70 ---------------- arch/arm/dts/exynos54xx.dtsi | 151 ++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/exynos5420.h | 46 +++++++++++ include/configs/peach-pit.h | 27 ++++++ include/configs/smdk5420.h | 49 ++--------- 9 files changed, 364 insertions(+), 133 deletions(-) create mode 100644 arch/arm/dts/exynos5420-peach-pit.dts delete mode 100644 arch/arm/dts/exynos5420.dtsi create mode 100644 arch/arm/dts/exynos54xx.dtsi create mode 100644 include/configs/exynos5420.h create mode 100644 include/configs/peach-pit.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5554615..933a464 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -6,7 +6,8 @@ dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ exynos5250-smdk5250.dtb \ - exynos5420-smdk5420.dtb + exynos5420-smdk5420.dtb \ + exynos5420-peach-pit.dtb dtb-$(CONFIG_MX6) += imx6q-sabreauto.dtb dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra20-medcom-wide.dtb \ diff --git a/arch/arm/dts/exynos5420-peach-pit.dts b/arch/arm/dts/exynos5420-peach-pit.dts new file mode 100644 index 0000000..8d148af --- /dev/null +++ b/arch/arm/dts/exynos5420-peach-pit.dts @@ -0,0 +1,127 @@ +/* + * SAMSUNG/GOOGLE Peach-Pit board device tree source + * + * Copyright (c) 2013 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos54xx.dtsi" + +/ { + model = "Samsung/Google Peach Pit board based on Exynos5420"; + + compatible = "google,pit-rev#", "google,pit", + "google,peach", "samsung,exynos5420", "samsung,exynos5"; + + config { + google,bad-wake-gpios = <&gpio 0x56 0>; /* gpx0-6 */ + hwid = "PIT TEST A-A 7848"; + lazy-init = <1>; + }; + + aliases { + serial0 = "/serial@12C30000"; + console = "/serial@12C30000"; + pmic = "/i2c@12ca0000"; + }; + + dmc { + mem-manuf = "samsung"; + mem-type = "ddr3"; + clock-frequency = <800000000>; + arm-frequency = <1700000000>; + }; + + tmu@10060000 { + samsung,min-temp = <25>; + samsung,max-temp = <125>; + samsung,start-warning = <95>; + samsung,start-tripping = <105>; + samsung,hw-tripping = <110>; + samsung,efuse-min-value = <40>; + samsung,efuse-value = <55>; + samsung,efuse-max-value = <100>; + samsung,slope = <274761730>; + samsung,dc-value = <25>; + }; + + /* MAX77802 is on i2c bus 4 */ + i2c@12ca0000 { + clock-frequency = <400000>; + power-regulator@9 { + compatible = "maxim,max77802-pmic"; + reg = <0x9>; + }; + }; + + i2c@12cd0000 { /* i2c7 */ + clock-frequency = <100000>; + soundcodec@20 { + reg = <0x20>; + compatible = "maxim,max98090-codec"; + }; + }; + + sound@3830000 { + samsung,codec-type = "max98090"; + }; + + i2c@12e10000 { /* i2c9 */ + clock-frequency = <400000>; + tpm@20 { + compatible = "infineon,slb9645-tpm"; + reg = <0x20>; + }; + }; + + spi@12d30000 { /* spi1 */ + spi-max-frequency = <50000000>; + firmware_storage_spi: flash@0 { + reg = <0>; + + /* + * A region for the kernel to store a panic event + * which the firmware will add to the log. + */ + elog-panic-event-offset = <0x01e00000 0x100000>; + + elog-shrink-size = <0x400>; + elog-full-threshold = <0xc00>; + }; + }; + + spi@12d40000 { /* spi2 */ + spi-max-frequency = <4000000>; + spi-deactivate-delay = <200>; + cros-ec@0 { + reg = <0>; + compatible = "google,cros-ec"; + spi-half-duplex; + spi-max-timeout-ms = <1100>; + spi-frame-header = <0xec>; + ec-interrupt = <&gpio 93 1>; /* GPX1_5 */ + + /* + * This describes the flash memory within the EC. Note + * that the STM32L flash erases to 0, not 0xff. + */ + #address-cells = <1>; + #size-cells = <1>; + flash@8000000 { + reg = <0x08000000 0x20000>; + erase-value = <0>; + }; + }; + }; + + xhci@12000000 { + samsung,vbus-gpio = <&gpio 0x40 0>; /* H00 */ + }; + + xhci@12400000 { + samsung,vbus-gpio = <&gpio 0x41 0>; /* H01 */ + }; +}; diff --git a/arch/arm/dts/exynos5420-smdk5420.dts b/arch/arm/dts/exynos5420-smdk5420.dts index d739763..1bc6256 100644 --- a/arch/arm/dts/exynos5420-smdk5420.dts +++ b/arch/arm/dts/exynos5420-smdk5420.dts @@ -8,7 +8,7 @@ */
/dts-v1/; -/include/ "exynos5420.dtsi" +/include/ "exynos54xx.dtsi"
/ { model = "SAMSUNG SMDK5420 board based on EXYNOS5420"; @@ -19,27 +19,6 @@ };
aliases { - i2c0 = "/i2c@12c60000"; - i2c1 = "/i2c@12c70000"; - i2c2 = "/i2c@12c80000"; - i2c3 = "/i2c@12c90000"; - i2c4 = "/i2c@12ca0000"; - i2c5 = "/i2c@12cb0000"; - i2c6 = "/i2c@12cc0000"; - i2c7 = "/i2c@12cd0000"; - i2c8 = "/i2c@12e00000"; - i2c9 = "/i2c@12e10000"; - i2c10 = "/i2c@12e20000"; - spi0 = "/spi@12d20000"; - spi1 = "/spi@12d30000"; - spi2 = "/spi@12d40000"; - spi3 = "/spi@131a0000"; - spi4 = "/spi@131b0000"; - mmc0 = "/mmc@12200000"; - mmc1 = "/mmc@12210000"; - mmc2 = "/mmc@12220000"; - xhci0 = "/xhci@12000000"; - xhci1 = "/xhci@12400000"; serial0 = "/serial@12C30000"; console = "/serial@12C30000"; }; diff --git a/arch/arm/dts/exynos5420.dtsi b/arch/arm/dts/exynos5420.dtsi deleted file mode 100644 index 02ead61..0000000 --- a/arch/arm/dts/exynos5420.dtsi +++ /dev/null @@ -1,70 +0,0 @@ -/* - * (C) Copyright 2013 SAMSUNG Electronics - * SAMSUNG EXYNOS5420 SoC device tree source - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/include/ "exynos5.dtsi" - -/ { - config { - machine-arch-id = <4151>; - }; - - i2c@12ca0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5-hsi2c"; - reg = <0x12CA0000 0x100>; - interrupts = <0 60 0>; - }; - - i2c@12cb0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5-hsi2c"; - reg = <0x12CB0000 0x100>; - interrupts = <0 61 0>; - }; - - i2c@12cc0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5-hsi2c"; - reg = <0x12CC0000 0x100>; - interrupts = <0 62 0>; - }; - - i2c@12cd0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5-hsi2c"; - reg = <0x12CD0000 0x100>; - interrupts = <0 63 0>; - }; - - i2c@12e00000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5-hsi2c"; - reg = <0x12E00000 0x100>; - interrupts = <0 87 0>; - }; - - i2c@12e10000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5-hsi2c"; - reg = <0x12E10000 0x100>; - interrupts = <0 88 0>; - }; - - i2c@12e20000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5-hsi2c"; - reg = <0x12E20000 0x100>; - interrupts = <0 203 0>; - }; -}; diff --git a/arch/arm/dts/exynos54xx.dtsi b/arch/arm/dts/exynos54xx.dtsi new file mode 100644 index 0000000..b9f8e0b --- /dev/null +++ b/arch/arm/dts/exynos54xx.dtsi @@ -0,0 +1,151 @@ +/* + * (C) Copyright 2013 SAMSUNG Electronics + * SAMSUNG EXYNOS5420 SoC device tree source + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "exynos5.dtsi" + +/ { + config { + machine-arch-id = <4151>; + }; + + aliases { + i2c0 = "/i2c@12c60000"; + i2c1 = "/i2c@12c70000"; + i2c2 = "/i2c@12c80000"; + i2c3 = "/i2c@12c90000"; + i2c4 = "/i2c@12ca0000"; + i2c5 = "/i2c@12cb0000"; + i2c6 = "/i2c@12cc0000"; + i2c7 = "/i2c@12cd0000"; + i2c8 = "/i2c@12e00000"; + i2c9 = "/i2c@12e10000"; + i2c10 = "/i2c@12e20000"; + spi0 = "/spi@12d20000"; + spi1 = "/spi@12d30000"; + spi2 = "/spi@12d40000"; + spi3 = "/spi@131a0000"; + spi4 = "/spi@131b0000"; + mmc0 = "/mmc@12200000"; + mmc1 = "/mmc@12210000"; + mmc2 = "/mmc@12220000"; + xhci0 = "/xhci@12000000"; + xhci1 = "/xhci@12400000"; + }; + + i2c@12ca0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12CA0000 0x100>; + interrupts = <0 60 0>; + }; + + i2c@12cb0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12CB0000 0x100>; + interrupts = <0 61 0>; + }; + + i2c@12cc0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12CC0000 0x100>; + interrupts = <0 62 0>; + }; + + i2c@12cd0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12CD0000 0x100>; + interrupts = <0 63 0>; + }; + + i2c@12e00000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12E00000 0x100>; + interrupts = <0 87 0>; + }; + + i2c@12e10000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12E10000 0x100>; + interrupts = <0 88 0>; + }; + + i2c@12e20000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12E20000 0x100>; + interrupts = <0 203 0>; + }; + + mmc@12200000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + samsung,removable = <0>; + samsung,pre-init; + }; + + mmc@12210000 { + status = "disabled"; + }; + + mmc@12220000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + samsung,removable = <1>; + }; + + mmc@12230000 { + status = "disabled"; + }; + + fimd@14400000 { + /* sysmmu is not used in U-Boot */ + samsung,disable-sysmmu; + }; + + dp@145b0000 { + samsung,lt-status = <0>; + + samsung,master-mode = <0>; + samsung,bist-mode = <0>; + samsung,bist-pattern = <0>; + samsung,h-sync-polarity = <0>; + samsung,v-sync-polarity = <0>; + samsung,interlaced = <0>; + samsung,color-space = <0>; + samsung,dynamic-range = <0>; + samsung,ycbcr-coeff = <0>; + samsung,color-depth = <1>; + }; + + dmc { + mem-type = "ddr3"; + }; + + xhci1: xhci@12400000 { + compatible = "samsung,exynos5250-xhci"; + reg = <0x12400000 0x10000>; + #address-cells = <1>; + #size-cells = <1>; + + phy { + compatible = "samsung,exynos5250-usb3-phy"; + reg = <0x12500000 0x100>; + }; + }; +}; diff --git a/boards.cfg b/boards.cfg index 880d972..4423231 100644 --- a/boards.cfg +++ b/boards.cfg @@ -289,6 +289,7 @@ Active arm armv7 exynos samsung origen Active arm armv7 exynos samsung smdk5250 smdk5250 - Chander Kashyap k.chander@samsung.com Active arm armv7 exynos samsung smdk5250 snow - Rajeshwari Shinde rajeshwari.s@samsung.com Active arm armv7 exynos samsung smdk5420 smdk5420 - Rajeshwari Shinde rajeshwari.s@samsung.com +Active arm armv7 exynos samsung smdk5420 peach-pit - Akshay Saraswat akshay.s@samsung.com Active arm armv7 exynos samsung smdkv310 smdkv310 - Chander Kashyap k.chander@samsung.com Active arm armv7 exynos samsung trats trats - Lukasz Majewski l.majewski@samsung.com Active arm armv7 exynos samsung trats2 trats2 - Piotr Wilczek p.wilczek@samsung.com diff --git a/include/configs/exynos5420.h b/include/configs/exynos5420.h new file mode 100644 index 0000000..3a28bbc --- /dev/null +++ b/include/configs/exynos5420.h @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2013 Samsung Electronics + * + * Configuration settings for the SAMSUNG EXYNOS5420 SoC + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_EXYNOS5420_H +#define __CONFIG_EXYNOS5420_H + +#define CONFIG_EXYNOS5420 /* which is in a Exynos5 Family */ + +#define MACH_TYPE_SMDK5420 8002 +#define CONFIG_MACH_TYPE MACH_TYPE_SMDK5420 + +#define CONFIG_VAR_SIZE_SPL + +#define CONFIG_SYS_SDRAM_BASE 0x20000000 +#define CONFIG_SYS_TEXT_BASE 0x23E00000 +#ifdef CONFIG_VAR_SIZE_SPL +#define CONFIG_SPL_TEXT_BASE 0x02024410 +#else +#define CONFIG_SPL_TEXT_BASE 0x02024400 +#endif +#define CONFIG_IRAM_TOP 0x02074000 + +#define CONFIG_DEVICE_TREE_LIST "exynos5420-peach-pit exynos5420-smdk5420" + +#define CONFIG_MAX_I2C_NUM 11 + +/* Enable FIT support and comparison */ +#define CONFIG_FIT +#define CONFIG_FIT_BEST_MATCH + +#define CONFIG_BOARD_REV_GPIO_COUNT 2 + +#define CONFIG_BOOTCOMMAND "mmc read 20007000 451 2000; bootm 20007000" + +/* + * Put the initial stack pointer 1KB below this to allow room for the + * SPL marker. This value is arbitrary, but gd_t is placed starting here. + */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_IRAM_TOP - 0x800) + +#endif /* __CONFIG_EXYNOS5420_H */ diff --git a/include/configs/peach-pit.h b/include/configs/peach-pit.h new file mode 100644 index 0000000..638b68b --- /dev/null +++ b/include/configs/peach-pit.h @@ -0,0 +1,27 @@ +/* + * Copyright (C) 2013 Samsung Electronics + * + * Configuration settings for the SAMSUNG/GOOGLE PEACH-PIT board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_PEACH_PIT_H +#define __CONFIG_PEACH_PIT_H + +#include <configs/exynos5-dt.h> + +#include <configs/exynos5420.h> + +#define CONFIG_CHROMEOS_PEACH + +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos5420-peach-pit + +/* select serial console configuration */ +#define CONFIG_SERIAL3 /* use SERIAL 3 */ + +#define CONFIG_SYS_PROMPT "Peach # " +#define CONFIG_IDENT_STRING " for Peach" + +#endif /* __CONFIG_PEACH_PIT_H */ diff --git a/include/configs/smdk5420.h b/include/configs/smdk5420.h index 58f706a..606739b 100644 --- a/include/configs/smdk5420.h +++ b/include/configs/smdk5420.h @@ -1,58 +1,27 @@ /* * Copyright (C) 2013 Samsung Electronics * - * Configuration settings for the SAMSUNG EXYNOS5420 board. + * Configuration settings for the SAMSUNG SMDK5420 board. * * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_5420_H -#define __CONFIG_5420_H +#ifndef __CONFIG_SMDK5420_H +#define __CONFIG_SMDK5420_H
-#define CONFIG_EXYNOS5420 /* which is in a Exynos5 Family */ +#include <configs/exynos5420.h> + #define CONFIG_SMDK5420 /* which is in a SMDK5420 */
#undef CONFIG_DEFAULT_DEVICE_TREE #define CONFIG_DEFAULT_DEVICE_TREE exynos5420-smdk5420
-#define CONFIG_VAR_SIZE_SPL - -#define CONFIG_SYS_SDRAM_BASE 0x20000000 -#define CONFIG_SYS_TEXT_BASE 0x23E00000 - -#define CONFIG_BOARD_REV_GPIO_COUNT 2 - -/* MACH_TYPE_SMDK5420 macro will be removed once added to mach-types */ -#define MACH_TYPE_SMDK5420 8002 /* Temporary number */ -#define CONFIG_MACH_TYPE MACH_TYPE_SMDK5420 - /* select serial console configuration */ -#define CONFIG_SERIAL3 /* use SERIAL 3 */ - -#ifdef CONFIG_VAR_SIZE_SPL -#define CONFIG_SPL_TEXT_BASE 0x02024410 -#else -#define CONFIG_SPL_TEXT_BASE 0x02024400 -#endif - -#define CONFIG_BOOTCOMMAND "mmc read 20007000 451 2000; bootm 20007000" - -#define CONFIG_SYS_PROMPT "SMDK5420 # " -#define CONFIG_IDENT_STRING " for SMDK5420" - -#define CONFIG_IRAM_TOP 0x02074000 -/* - * Put the initial stack pointer 1KB below this to allow room for the - * SPL marker. This value is arbitrary, but gd_t is placed starting here. - */ -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_IRAM_TOP - 0x800) - -#define CONFIG_MAX_I2C_NUM 11 +#define CONFIG_SERIAL3 /* use SERIAL 3 */
-/* Enable FIT support and comparison */ -#define CONFIG_FIT -#define CONFIG_FIT_BEST_MATCH +#define CONFIG_SYS_PROMPT "SMDK5420 # " +#define CONFIG_IDENT_STRING " for SMDK5420"
-#endif /* __CONFIG_5420_H */ +#endif /* __CONFIG_SMDK5420_H */
Macros defined in exynos5_setup.h specific to SMDK5420 are required for Peach-Pit too. Hence, replacing CONFIG_SMDK5420 with CONFIG_EXYNOS5420 to enable these macros for all the boards based on Exynos5420.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/exynos5_setup.h b/arch/arm/cpu/armv7/exynos/exynos5_setup.h index 53b0ace..db8ea86 100644 --- a/arch/arm/cpu/armv7/exynos/exynos5_setup.h +++ b/arch/arm/cpu/armv7/exynos/exynos5_setup.h @@ -431,10 +431,10 @@
/* * Definitions that differ with SoC's. - * Below is the part defining macros for smdk5250. - * Else part introduces macros for smdk5420. + * Below is the part defining macros for Exynos5250. + * Else part introduces macros for Exynos5420. */ -#ifndef CONFIG_SMDK5420 +#ifndef CONFIG_EXYNOS5420
/* APLL_CON1 */ #define APLL_CON1_VAL (0x00203800)
- Definitions that differ with SoC's.
- Below is the part defining macros for smdk5250.
- Else part introduces macros for smdk5420.
- Below is the part defining macros for Exynos5250.
- Else part introduces macros for Exynos5420.
/* APLL_CON1 */
1.8.3.2
Akshay Saraswat
