[U-Boot] [PATCH v3 1/4] Add run_command_list() to run a list of commands
This new function runs a list of commands separated by semicolon or newline. We move this out of cmd_source so that it can be used by other code. The PXE code also uses the new function.
Suggested-by: Michael Walle michael@walle.cc Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Added a few more comments on the need for malloc() - Change PXE's printf() to a debug() - Fix bug in built-in run_command() - Fix commit message to mention ; and \n - Move run_command_list() comment to header file
common/cmd_pxe.c | 20 ++---------- common/cmd_source.c | 49 +---------------------------- common/main.c | 85 +++++++++++++++++++++++++++++++++++++++++++++++++++ include/common.h | 13 ++++++++ 4 files changed, 102 insertions(+), 65 deletions(-)
diff --git a/common/cmd_pxe.c b/common/cmd_pxe.c index b3c1f67..6032a0f 100644 --- a/common/cmd_pxe.c +++ b/common/cmd_pxe.c @@ -515,33 +515,19 @@ static void label_print(void *data) */ static int label_localboot(struct pxe_label *label) { - char *localcmd, *dupcmd; - int ret; + char *localcmd;
localcmd = from_env("localcmd");
if (!localcmd) return -ENOENT;
- /* - * dup the command to avoid any issues with the version of it existing - * in the environment changing during the execution of the command. - */ - dupcmd = strdup(localcmd); - - if (!dupcmd) - return -ENOMEM; - if (label->append) setenv("bootargs", label->append);
- printf("running: %s\n", dupcmd); - - ret = run_command(dupcmd, 0); + debug("running: %s\n", localcmd);
- free(dupcmd); - - return ret; + return run_command_list(localcmd, strlen(localcmd), 0); }
/* diff --git a/common/cmd_source.c b/common/cmd_source.c index 32fff5c..c4cde98 100644 --- a/common/cmd_source.c +++ b/common/cmd_source.c @@ -39,9 +39,6 @@ #if defined(CONFIG_8xx) #include <mpc8xx.h> #endif -#ifdef CONFIG_SYS_HUSH_PARSER -#include <hush.h> -#endif
int source (ulong addr, const char *fit_uname) @@ -49,8 +46,6 @@ source (ulong addr, const char *fit_uname) ulong len; image_header_t *hdr; ulong *data; - char *cmd; - int rcode = 0; int verify; #if defined(CONFIG_FIT) const void* fit_hdr; @@ -151,49 +146,7 @@ source (ulong addr, const char *fit_uname) }
debug ("** Script length: %ld\n", len); - - if ((cmd = malloc (len + 1)) == NULL) { - return 1; - } - - /* make sure cmd is null terminated */ - memmove (cmd, (char *)data, len); - *(cmd + len) = 0; - -#ifdef CONFIG_SYS_HUSH_PARSER /*?? */ - rcode = parse_string_outer (cmd, FLAG_PARSE_SEMICOLON); -#else - { - char *line = cmd; - char *next = cmd; - - /* - * break into individual lines, - * and execute each line; - * terminate on error. - */ - while (*next) { - if (*next == '\n') { - *next = '\0'; - /* run only non-empty commands */ - if (*line) { - debug ("** exec: "%s"\n", - line); - if (run_command(line, 0) < 0) { - rcode = 1; - break; - } - } - line = next + 1; - } - ++next; - } - if (rcode == 0 && *line) - rcode = (run_command(line, 0) >= 0); - } -#endif - free (cmd); - return rcode; + return run_command_list((char *)data, len, 0); }
/**************************************************/ diff --git a/common/main.c b/common/main.c index db181d3..8c5115d 100644 --- a/common/main.c +++ b/common/main.c @@ -30,6 +30,7 @@ #include <common.h> #include <watchdog.h> #include <command.h> +#include <malloc.h> #include <version.h> #ifdef CONFIG_MODEM_SUPPORT #include <malloc.h> /* for free() prototype */ @@ -1373,6 +1374,90 @@ int run_command(const char *cmd, int flag) #endif }
+#ifndef CONFIG_SYS_HUSH_PARSER +/** + * Execute a list of command separated by ; or \n using the built-in parser. + * + * This function cannot take a const char * for the command, since if it + * finds newlines in the string, it replaces them with \0. + * + * @param cmd String containing list of commands + * @param flag Execution flags (CMD_FLAG_...) + * @return 0 on success, or != 0 on error. + */ +static int builtin_run_command_list(char *cmd, int flag) +{ + char *line, *next; + int rcode = 0; + + /* + * Break into individual lines, and execute each line; terminate on + * error. + */ + line = next = cmd; + while (*next) { + if (*next == '\n') { + *next = '\0'; + /* run only non-empty commands */ + if (*line) { + debug("** exec: "%s"\n", line); + if (builtin_run_command(line, 0) < 0) { + rcode = 1; + break; + } + } + line = next + 1; + } + ++next; + } + if (rcode == 0 && *line) + rcode = (builtin_run_command(line, 0) >= 0); + + return rcode; +} +#endif + +int run_command_list(const char *cmd, int len, int flag) +{ + int need_buff = 1; + char *buff = (char *)cmd; /* cast away const */ + int rcode = 0; + + if (len == -1) { + len = strlen(cmd); +#ifdef CONFIG_SYS_HUSH_PARSER + /* hush will never change our string */ + need_buff = 0; +#else + /* the built-in parser will change our string if it sees \n */ + need_buff = strchr(cmd, '\n') != NULL; +#endif + } + if (need_buff) { + buff = malloc(len + 1); + if (!buff) + return 1; + memcpy(buff, cmd, len); + buff[len] = '\0'; + } +#ifdef CONFIG_SYS_HUSH_PARSER + rcode = parse_string_outer(buff, FLAG_PARSE_SEMICOLON); +#else + /* + * This function will overwrite any \n it sees with a \0, which + * is why it can't work with a const char *. Here we are making + * using of internal knowledge of this function, to avoid always + * doing a malloc() which is actually required only in a case that + * is pretty rare. + */ + rcode = builtin_run_command_list(buff, flag); + if (need_buff) + free(buff); +#endif + + return rcode; +} + /****************************************************************************/
#if defined(CONFIG_CMD_RUN) diff --git a/include/common.h b/include/common.h index 74d9704..c4ae451 100644 --- a/include/common.h +++ b/include/common.h @@ -268,6 +268,19 @@ int print_buffer (ulong addr, void* data, uint width, uint count, uint linelen); /* common/main.c */ void main_loop (void); int run_command(const char *cmd, int flag); + +/** + * Run a list of commands separated by ; or even \0 + * + * Note that if 'len' is not -1, then the command does not need to be nul + * terminated, Memory will be allocated for the command in that case. + * + * @param cmd List of commands to run, each separated bu semicolon + * @param len Length of commands excluding terminator if known (-1 if not) + * @param flag Execution flags (CMD_FLAG_...) + * @return 0 on success, or != 0 on error. + */ +int run_command_list(const char *cmd, int len, int flag); int readline (const char *const prompt); int readline_into_buffer(const char *const prompt, char *buffer, int timeout);
Any environment variable can hold commands to be executed by the 'run' command. The environment variables preboot, bootcmd and menucmd have special code for triggering execution in certain circumstances.
We adjust these calls to use run_command_list() instead of run_command(). This change permits these variables to have embedded newlines so that they work the same as the 'source' command.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Update commit message to be less confusing
Changes in v3: - Remove unneeded len parameter in calls to run_command_list
common/main.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/main.c b/common/main.c index 8c5115d..578977b 100644 --- a/common/main.c +++ b/common/main.c @@ -334,7 +334,7 @@ void main_loop (void) int prev = disable_ctrlc(1); /* disable Control C checking */ # endif
- run_command(p, 0); + run_command_list(p, -1, 0);
# ifdef CONFIG_AUTOBOOT_KEYED disable_ctrlc(prev); /* restore Control C checking */ @@ -382,7 +382,7 @@ void main_loop (void) int prev = disable_ctrlc(1); /* disable Control C checking */ # endif
- run_command(s, 0); + run_command_list(s, -1, 0);
# ifdef CONFIG_AUTOBOOT_KEYED disable_ctrlc(prev); /* restore Control C checking */ @@ -393,7 +393,7 @@ void main_loop (void) if (menukey == CONFIG_MENUKEY) { s = getenv("menucmd"); if (s) - run_command(s, 0); + run_command_list(s, -1, 0); } #endif /* CONFIG_MENUKEY */ #endif /* CONFIG_BOOTDELAY */
Dear Simon Glass,
Changes in v2:
Changes in v3:
Applied, thanks.
Now that run_command() handles both parsers, clean up sandbox to use it. This fixes a build error.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Add new patch to clean up sandbox's run_command() usage
arch/sandbox/cpu/start.c | 6 ------ 1 files changed, 0 insertions(+), 6 deletions(-)
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 6c3e8eb..7603bf9 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -90,13 +90,7 @@ int sandbox_main_loop_init(void)
/* Execute command if required */ if (state->cmd) { - /* TODO: redo this when cmd tidy-up series lands */ -#ifdef CONFIG_SYS_HUSH_PARSER run_command(state->cmd, 0); -#else - parse_string_outer(state->cmd, FLAG_PARSE_SEMICOLON | - FLAG_EXIT_FROM_LOOP); -#endif os_exit(state->exit_type); }
Acked-by: Mike Frysinger vapier@gentoo.org -mike
Dear Simon Glass,
Changes in v3:
Applied, thanks.
Since run_command() and run_command_list() are important and a little confusing, add some basic tests to check that the behaviour is correct.
Note: I am not sure that this should be committed, nor where it should go in the source tree. Comments welcome.
To run the unit tests use the ut_cmd command available in sandbox:
make sandbox_config make ./u-boot -c ut_cmd
(To test both hush and built-in parsers, you need to manually change CONFIG_SYS_HUSH_PARSER in include/configs/sandbox.h and build/run again)
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Add some unit tests for run_command() and run_command_list()
Makefile | 1 + test/Makefile | 45 ++++++++++++++++++++++++++++ test/command_ut.c | 85 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 131 insertions(+), 0 deletions(-) create mode 100644 test/Makefile create mode 100644 test/command_ut.c
diff --git a/Makefile b/Makefile index 4ddf8d6..21a0f69 100644 --- a/Makefile +++ b/Makefile @@ -301,6 +301,7 @@ LIBS += common/libcommon.o LIBS += lib/libfdt/libfdt.o LIBS += api/libapi.o LIBS += post/libpost.o +LIBS += test/libtest.o
ifneq ($(CONFIG_AM33XX)$(CONFIG_OMAP34XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX),) LIBS += $(CPUDIR)/omap-common/libomap-common.o diff --git a/test/Makefile b/test/Makefile new file mode 100644 index 0000000..83594f3 --- /dev/null +++ b/test/Makefile @@ -0,0 +1,45 @@ +# +# (C) Copyright 2012 The Chromium Authors +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libtest.o + +COBJS-$(CONFIG_SANDBOX) += command_ut.o + +COBJS := $(sort $(COBJS-y)) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) $(XOBJS) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/test/command_ut.c b/test/command_ut.c new file mode 100644 index 0000000..dfddc22 --- /dev/null +++ b/test/command_ut.c @@ -0,0 +1,85 @@ +/* + * Copyright (c) 2012, The Chromium Authors + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define DEBUG + +#include <common.h> + +static const char test_cmd[] = "setenv list 1\n setenv list ${list}2; " + "setenv list ${list}3\0" + "setenv list ${list}4"; + +static int do_ut_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + printf("%s: Testing commands\n", __func__); + run_command("env default -f", 0); + + /* run a single command */ + run_command("setenv single 1", 0); + assert(!strcmp("1", getenv("single"))); + + /* make sure that compound statements work */ +#ifdef CONFIG_SYS_HUSH_PARSER + run_command("if test -n ${single} ; then setenv check 1; fi", 0); + assert(!strcmp("1", getenv("check"))); + run_command("setenv check", 0); +#endif + + /* commands separated by ; */ + run_command_list("setenv list 1; setenv list ${list}1", -1, 0); + assert(!strcmp("11", getenv("list"))); + + /* commands separated by \n */ + run_command_list("setenv list 1\n setenv list ${list}1", -1, 0); + assert(!strcmp("11", getenv("list"))); + + /* command followed by \n and nothing else */ + run_command_list("setenv list 1${list}\n", -1, 0); + assert(!strcmp("111", getenv("list"))); + + /* three commands in a row */ + run_command_list("setenv list 1\n setenv list ${list}2; " + "setenv list ${list}3", -1, 0); + assert(!strcmp("123", getenv("list"))); + + /* a command string with \0 in it. Stuff after \0 should be ignored */ + run_command("setenv list", 0); + run_command_list(test_cmd, sizeof(test_cmd), 0); + assert(!strcmp("123", getenv("list"))); + + /* + * a command list where we limit execution to only the first command + * using the length parameter. + */ + run_command_list("setenv list 1\n setenv list ${list}2; " + "setenv list ${list}3", strlen("setenv list 1"), 0); + assert(!strcmp("1", getenv("list"))); + + printf("%s: Everything went swimmingly\n", __func__); + return 0; +} + +U_BOOT_CMD( + ut_cmd, 5, 1, do_ut_cmd, + "Very basic test of command parsers", + "" +);
that sort actually needed ?
$(XOBJS) is dead code
+#define DEBUG
should comment why you've always defined this
i'd put the first string on a new line too to make it easier to read
what is "ut" supposed to stand for ? -mike
Hi Mike,
Not yet :-) I like what it does to object files, but it is pointless at least for now. Will drop it.
Removed
+#define DEBUG
done
- "setenv list ${list}3\0"
- "setenv list ${list}4";
Done
Unit test, as normally needed by code that is utterly tortuous.
-mike
i'd use "unit test" in the cmd help string then -mike
Dear Simon Glass,
Changes in v3:
Applied, thanks.
- return run_command_list(localcmd, strlen(localcmd), 0);
should be -1 instead of strlen()
- int need_buff = 1;
- char *buff = (char *)cmd; /* cast away const */
- int rcode = 0;
- if (len == -1) {
len = strlen(cmd);
need_buff = 0;
+#else
we have memchr(), so you should be able to split the len==-1 and the need_buff logic into two sep steps
also, should you handle the case where '\n' is the very last char ? or not bother ? -mike
Hi Mike,
done
- int rcode = 0;
- if (len == -1) {
- len = strlen(cmd);
- /* hush will never change our string */
- need_buff = 0;
+#else
- /* the built-in parser will change our string if it sees \n */
- need_buff = strchr(cmd, '\n') != NULL;
Are you saying that we should do this check if len is not -1 also?
I am only doing it when len is not specified, since if a length is provided we must allocate. This is used by the source command, which does not necessary have a nul-terminated string.
* Note that if 'len' is not -1, then the command does not need to be nul * terminated, Memory will be allocated for the command in that case.
Sorry if I am missing your point.
Do you mean not allocate in that case? I don't think it is a common situation is it?
-mike
int need_buff = 1;
int rcode = 0;
if (len == -1) {
len = strlen(cmd);
need_buff = 0;
+#else
looks to me like it should be: int need_buff;
if (len == -1) len = strlen(cmd); #ifdef CONFIG_SYS_HUSH_PARSER need_buff = 0; #else need_buff = memchr(cmd, '\n', len) != NULL; #endif if (need_buff) { ... }
i don't know how commands get passed down (as i've never poked that area before) which is why i'm asking -mike
Hi Mike,
- int rcode = 0;
- if (len == -1) {
- need_buff = 0;
+#else
This logic is different. For example it won't nul terminate a terminate a command string that is passed in with no terminator. I think this is required by the 'source' command.
Well within the normal command parses run_command() is called. They split up the commands for us. We only need run_command_list() when we think we might have a raw list of commands, on which no processing has been done.
-mike
Dear Simon Glass,
Changes in v3:
Applied, thanks.
Mike Frysinger
