[PATCH v2] global: Use proper project name U-Boot (next2)
Use proper project name in README, rst and comment. Done in connection to commit bb922ca3eb4b ("global: Use proper project name U-Boot (next)").
Signed-off-by: Michal Simek michal.simek@amd.com ---
Changes in v2: - Revert change in tools/binman/entries.rst reported by Simon
board/cobra5272/README | 18 +++++++++--------- board/emulation/qemu-ppce500/qemu-ppce500.c | 2 +- doc/board/xilinx/zynq.rst | 2 +- doc/board/xilinx/zynqmp-r5.rst | 4 ++-- doc/imx/mkimage/imximage.txt | 2 +- doc/usage/environment.rst | 2 +- doc/usage/semihosting.rst | 2 +- 7 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/board/cobra5272/README b/board/cobra5272/README index 11abcfacdb6e..0b07148b73a3 100644 --- a/board/cobra5272/README +++ b/board/cobra5272/README @@ -1,6 +1,6 @@ File: README.COBRA5272 Author: Florian Schlote for Sentec elektronik (linux@sentec-elektronik.de) -Contents: This is the README of u-boot (Universal bootloader) for our +Contents: This is the README of U-Boot (Universal bootloader) for our COBRA5272 board. Version: v01.00 Date: Tue Mar 30 00:28:33 CEST 2004 @@ -31,7 +31,7 @@ Please refer to u-boot README (general info, u-boot-x-x-x/README), to u-boot-x-x-x/board/cobra5272/README and to the comments in u-boot-x-x-x/include/configs/cobra5272.h
-Configuring u-boot is done by commenting/uncommenting preprocessor defines. +Configuring U-Boot is done by commenting/uncommenting preprocessor defines.
Default configuration is
@@ -48,10 +48,10 @@ Default configuration is
#----------------------------------- -# u-boot FLASH version & RAM version +# U-Boot FLASH version & RAM version #-----------------------------------
-The u-boot bootloader for Coldfire processors can be configured +The U-Boot bootloader for Coldfire processors can be configured
1. as a standalone bootloader residing in flash & relocating itself to RAM on startup automatically => "FLASH version" @@ -60,7 +60,7 @@ The u-boot bootloader for Coldfire processors can be configured prestage bootloader ("chainloading") & is running only from the RAM address it is linked to => "RAM version"
- This version may be very helpful when installing u-boot for the first time + This version may be very helpful when installing U-Boot for the first time since it can be used to make available s. th. like a "bootstrap mechanism".
@@ -71,7 +71,7 @@ How to build the different images: Flash version ------------------------------
-Compile u-boot +Compile U-Boot
in dir ./u-boot-x-x-x/
@@ -81,14 +81,14 @@ please first check:
CONFIG_MONITOR_IS_IN_RAM has to be not present in the file
- => u-boot as single bootloader starting from flash + => U-Boot as single bootloader starting from flash
in configs/cobra5272_defconfig CONFIG_TEXT_BASE should be
CONFIG_TEXT_BASE=0xffe00000
- => linking address for u-boot as single bootloader stored in flash + => linking address for U-Boot as single bootloader stored in flash
then:
@@ -116,7 +116,7 @@ please modify the settings:
CONFIG_MONITOR_IS_IN_RAM=y
- => u-boot as RAM version, chainloaded by another bootloader or using bdm cable + => U-Boot as RAM version, chainloaded by another bootloader or using bdm cable
in configs/cobra5272_defconfig CONFIG_TEXT_BASE should be diff --git a/board/emulation/qemu-ppce500/qemu-ppce500.c b/board/emulation/qemu-ppce500/qemu-ppce500.c index a39bcb4fa0c7..40fd9e5e02b1 100644 --- a/board/emulation/qemu-ppce500/qemu-ppce500.c +++ b/board/emulation/qemu-ppce500/qemu-ppce500.c @@ -318,7 +318,7 @@ ulong get_bus_freq(ulong dummy) int cpu_numcores(void) { /* - * The QEMU u-boot target only needs to drive the first core, + * The QEMU U-Boot target only needs to drive the first core, * spinning and device tree nodes get driven by QEMU itself */ return 1; diff --git a/doc/board/xilinx/zynq.rst b/doc/board/xilinx/zynq.rst index 438912fe42c2..76d67bd62ee9 100644 --- a/doc/board/xilinx/zynq.rst +++ b/doc/board/xilinx/zynq.rst @@ -83,7 +83,7 @@ Mainline status ---------------
- Added basic board configurations support. -- Added zynq u-boot bsp code - arch/arm/mach-zynq +- Added zynq U-Boot bsp code - arch/arm/mach-zynq - Added zynq boards named - zc70x, zed, microzed, zc770_xm010/xm011/xm012/xm013 - Added zynq drivers:
diff --git a/doc/board/xilinx/zynqmp-r5.rst b/doc/board/xilinx/zynqmp-r5.rst index 2cd368b0308e..266d07d1193f 100644 --- a/doc/board/xilinx/zynqmp-r5.rst +++ b/doc/board/xilinx/zynqmp-r5.rst @@ -26,7 +26,7 @@ configure and build armv7 toolchain:: Notes ^^^^^
-Output fragment is u-boot. +Output fragment is U-Boot.
Loading ------- @@ -38,7 +38,7 @@ Bootgen ^^^^^^^
The first way is to use Xilinx FSBL (First stage -bootloader) to load u-boot and start it. The following bif can be used for boot +bootloader) to load U-Boot and start it. The following bif can be used for boot image generation via Xilinx bootgen utility::
diff --git a/doc/imx/mkimage/imximage.txt b/doc/imx/mkimage/imximage.txt index f2cf23c5dab8..fa4e486661c2 100644 --- a/doc/imx/mkimage/imximage.txt +++ b/doc/imx/mkimage/imximage.txt @@ -213,7 +213,7 @@ Disk identifier: 0xb712a870 Device Boot Start End Blocks Id System /dev/mmcblk0p1 3 16 112455 83 Linux
-I have set 100MB, leaving the first 2 sectors free. I will copy u-boot +I have set 100MB, leaving the first 2 sectors free. I will copy U-Boot there.
8. Write the partition table and exit. diff --git a/doc/usage/environment.rst b/doc/usage/environment.rst index c6439dde6689..c57b717caaf3 100644 --- a/doc/usage/environment.rst +++ b/doc/usage/environment.rst @@ -216,7 +216,7 @@ fdt_high 0xffffffffffffffff (64-bit machines) then the fdt will not be copied at all on boot. For this to work it must reside in writable memory, have - sufficient padding on the end of it for u-boot to + sufficient padding on the end of it for U-Boot to add the information it needs into it, and the memory must be accessible by the kernel. This usage is strongly discouraged however as it also stops U-Boot from ensuring the device tree starting diff --git a/doc/usage/semihosting.rst b/doc/usage/semihosting.rst index 6a280b455e0c..9303a6364d5d 100644 --- a/doc/usage/semihosting.rst +++ b/doc/usage/semihosting.rst @@ -23,7 +23,7 @@ eMMC or other NV media are available. There are two main ARM virtual Fixed Virtual Platform (FVP) models, `Versatile Express (VE) FVP and BASE FVP http://www.arm.com/products/tools/models/fast-models/foundation-model.php`_. -The initial vexpress64 u-boot board created here runs on the VE virtual +The initial vexpress64 U-Boot board created here runs on the VE virtual platform using the license-free Foundation_v8 simulator. Fortunately, the Foundation_v8 simulator also supports the BASE_FVP model which companies can purchase licenses for and contain much more functionality.
Changes in v2:
Changes in v2:
- as a standalone bootloader residing in flash & relocating itself to RAM on
- This version may be very helpful when installing U-Boot for the first time since it can be used to make available s. th. like a "bootstrap mechanism".
then:
*/ return 1;
- spinning and device tree nodes get driven by QEMU itself
Loading
- Write the partition table and exit.
- sufficient padding on the end of it for U-Boot to add the information it needs into it, and the memory must be accessible by the kernel. This usage is strongly discouraged however as it also stops U-Boot from ensuring the device tree starting
Applied. M
Michal Simek
