[U-Boot-Users] u-boot Tulip DECchip support
I'm using a Sandpoint board with X3 (MPC8245) unity CPU card. Sandpoint does not have an ethernet controller.And since I have a PCI DECchip 21x4x Ethernet controller I want to use it with sandpoint board. I'm able to use this ethernet card with my linux image, it works fine, but I couldn't add this to u-boot image. So I'm dowloading the linux image by using "loadb" or "loads" commands via serial channel and it tooks to much time. You can see my previous tryings below.
Is there anybody who has used this ethernet controller with Sandpoint? Or do you have any suggestion for my problem.
Regards yio
P.S: Below, there are previous messages between I and Wolfgang. Since I was not aware of using this list I have sent e-mails directly to Wolfgang. Thanks to him for his recommendations about the problem and warnings about using this list.
Hello,
in message 000b01c44ebe$9f0193d0$aa06010a@aselsan.com.tr you wrote:
First of all, Thank you very much for your help. I'm sorry I couldn't
see the Tulip support of u-boor at the first time.
You are welcome.
Yes you are right I should have used the mailing list. Thank you for
your warning.
Ummm... so why aren't you using it in this case?
For future messages please use the mailing list.
Enable CFG_CMD_NET and CONFIG_TULIP and CONFIG_NET_MULTI in your board configuration.
I have tried you recommendations about how to add Tulip driver. But I
couldn't succedded. Here what I have done exactly and, what results I have reached.
I think, by the "board configuration", you mean u-boot-1.1.1\include\configs\Sandpoint8245.h file. In that file, CONFIG_NET_MULTI had already been defined. Then I have defined the first two ( CFG_CMD_NET, CONFIG_TULIP). Then firstly, I have run the command "make clean", secondly run "make Sandpoint8245_config", And finally, when I have run the command "make CROSS_COMPILE=ppc_82xx-" I have received an error, saying that definition of CFG_CMD_NET was dublicated. OK, since it seems to
Maybe I was not clear enough. "CFG_CMD_NET" is not a #define you should set yourself; you should make sure that "CFG_CMD_NET" is included (i. e. used) in your definition of the CONFIG_COMMANDS definition.
So as a result, my DECchip Ethernet card is still not working with
u-boot. (Or I couldn't make it work somehow!) Would you please help me about where am I wrong. I can enter this subject in mailing list, so some other people can use this help.
sorry, I'm afraid I cannot help. I don;t have any Tulip based network card here, so I cannot test this myself. Please ask on the mailing list.
anyone get this working on an 8245 based board. I am having the same problem...
Regards yio
Hello,
sorry I couldn't
You are welcome.
Thank you for
your warning.
in your
driver. But I
results I have
reached.
file,
defined the first
the command "make
received an error,
since it seems to
working with
so some other
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de Brain off-line, please wait.
Hello,
in message E1BTbK0-0005YM-00@sc8-sf-web2.sourceforge.net you wrote:
I need help about u-boot. I'm using u-boot in a
Sandpoint
X3 board. This board does not have an ethernet controller.
So
I'm using DECchip 21x4X PCI ethernet card. But I think
u-boot
does not suppot that card.(Or I couldn't find!). Can you
help
You are wrong. The Tulip chip is supported. See drivers/dc2114x.*
about how can I add this ethernet card into u-boot image. I
card. But For now I only can download the linux image via serial channel with loads command and this takes too much time. (about 30 minutes).
You could also use loadb which is much faster. But of course not as fast as Ethernet :-)
P.S: I have entered this subject into "Forums" in u-boot
page.
But since I need an urgent help I'm also posting it to you.
The U-Boot page should have told you that the preferred communication channel is through the u-0boot-users mailing list.
Dikkat:
Bu elektronik posta mesaji kisisel ve ozeldir. Eger size gonderilmediyse lutfen gondericiyi bilgilendirip mesaji siliniz. Firmamiza gelen ve giden mesajlar virus taramasindan gecirilmekte, guvenlik nedeni ile kontrol edilerek saklanmaktadir. Mesajdaki gorusler ve bakis acisi gondericiye ait olup Aselsan A.S. resmi gorusu olmak zorunda degildir.
Attention:
This e-mail message is privileged and confidential. If you are not the intended recipient please delete the message and notify the sender. E-mails to and from the company are monitored for operational reasons and in accordance with lawful business practices. Any views or opinions presented are solely those of the author and do not necessarily represent the views of the company.
__________________________________ Do you Yahoo!? Yahoo! Mail - Helps protect you from nasty viruses. http://promotions.yahoo.com/new_mail
Frank
Yusuf Ibrahim Özkök
