[U-Boot] [PATCH] 85xx: remove redudant code with lib_ppc/interrupts.c
For some reason we duplicated the majority of code in lib_ppc/interrupts.c not show how that happened, but there is no good reason for it.
Use the interrupt_init_cpu() and timer_interrupt_cpu() since its why they exist.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc85xx/interrupts.c | 107 ++++----------------------------------------- 1 files changed, 10 insertions(+), 97 deletions(-)
diff --git a/cpu/mpc85xx/interrupts.c b/cpu/mpc85xx/interrupts.c index 4fe1fac..a407c05 100644 --- a/cpu/mpc85xx/interrupts.c +++ b/cpu/mpc85xx/interrupts.c @@ -31,64 +31,18 @@ #include <watchdog.h> #include <command.h> #include <asm/processor.h> -#include <ppc_asm.tmpl>
-unsigned decrementer_count; /* count value for 1e6/HZ microseconds */ - -static __inline__ unsigned long get_msr(void) -{ - unsigned long msr; - - asm volatile("mfmsr %0" : "=r" (msr) :); - return msr; -} - -static __inline__ void set_msr(unsigned long msr) -{ - asm volatile("mtmsr %0" : : "r" (msr)); - asm volatile("isync"); -} - -static __inline__ unsigned long get_dec (void) -{ - unsigned long val; - - asm volatile ("mfdec %0":"=r" (val):); - - return val; -} - - -static __inline__ void set_dec (unsigned long val) -{ - if (val) - asm volatile ("mtdec %0"::"r" (val)); -} - -void enable_interrupts (void) -{ - set_msr (get_msr() | MSR_EE); -} - -/* returns flag if MSR_EE was set before */ -int disable_interrupts (void) -{ - ulong msr = get_msr(); - set_msr (msr & ~MSR_EE); - return ((msr & MSR_EE) != 0); -} - -int interrupt_init (void) +int interrupt_init_cpu(unsigned long *decrementer_count) { volatile ccsr_pic_t *pic = (void *)(CFG_MPC85xx_PIC_ADDR);
pic->gcr = MPC85xx_PICGCR_RST; - while (pic->gcr & MPC85xx_PICGCR_RST); + while (pic->gcr & MPC85xx_PICGCR_RST) + ; pic->gcr = MPC85xx_PICGCR_M; - decrementer_count = get_tbclk() / CFG_HZ; + + /* PIE is same as DIE, dec interrupt enable */ mtspr(SPRN_TCR, TCR_PIE); - set_dec (decrementer_count); - set_msr (get_msr () | MSR_EE);
#ifdef CONFIG_INTERRUPTS pic->iivpr1 = 0x810001; /* 50220 enable ecm interrupts */ @@ -123,9 +77,7 @@ int interrupt_init (void) return (0); }
-/* - * Install and free a interrupt handler. Not implemented yet. - */ +/* Install and free a interrupt handler. Not implemented yet. */
void irq_install_handler(int vec, interrupt_handler_t *handler, void *arg) @@ -139,55 +91,16 @@ irq_free_handler(int vec) return; }
-/****************************************************************************/ - - -volatile ulong timestamp = 0; - -/* - * timer_interrupt - gets called when the decrementer overflows, - * with interrupts disabled. - * Trivial implementation - no need to be really accurate. - */ -void timer_interrupt(struct pt_regs *regs) +void timer_interrupt_cpu(struct pt_regs *regs) { - timestamp++; - set_dec (decrementer_count); + /* PIS is same as DIS, dec interrupt status */ mtspr(SPRN_TSR, TSR_PIS); -#if defined(CONFIG_WATCHDOG) - if ((timestamp % 1000) == 0) - reset_85xx_watchdog(); -#endif /* CONFIG_WATCHDOG */ -} - -void reset_timer (void) -{ - timestamp = 0; -} - -ulong get_timer (ulong base) -{ - return (timestamp - base); -} - -void set_timer (ulong t) -{ - timestamp = t; }
#if defined(CONFIG_CMD_IRQ) - -/******************************************************************************* - * - * irqinfo - print information about PCI devices,not implemented. - * - */ -int -do_irqinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +/* irqinfo - print information about PCI devices,not implemented. */ +int do_irqinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { - printf ("\nInterrupt-unsupported:\n"); - return 0; } - #endif
Kumar Gala
