[PATCH] serial: pl011: Resend the character if FIFO is full in debug uart
pl01x_putc() might return -EAGAIN if there was no space in FIFO. In that case, high-level caller should wait until there is space and resend the character.
Signed-off-by: Chen Baozi chenbaozi@phytium.com.cn --- drivers/serial/serial_pl01x.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index 76b96ad414..17b26aed81 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -417,7 +417,7 @@ static inline void _debug_uart_putc(int ch) { struct pl01x_regs *regs = (struct pl01x_regs *)CONFIG_DEBUG_UART_BASE;
- pl01x_putc(regs, ch); + while (pl01x_putc(regs, ch) == -EAGAIN); }
DEBUG_UART_FUNCS
- while (pl01x_putc(regs, ch) == -EAGAIN);
I just recently also stumbled over this problem, that this serial driver did "swallow" many char's in the early debug stage.
Coding style is a bit non-optimal though IMHO. Please move the ";" into the next newline instead.
Other than that:
Thanks, Stefan
Chen Baozi
Stefan Roese
