[PATCH RFC v3 00/11] Integration of tiboot3.bin, sysfw.itb and
Devices that belong to the K3 architecture require SYSFW which is a FIT image consisting of a signed system firmware image and board config binaries.
Board config binaries are needed to bring up SYSFW during U-Boot SPL startup. The board config data is given in YAML as input. These board configs contain board-specific information such as resource management, power management and security.
The following series intends to plumb the system firmware generation into U-Boot using binman for packaging. Thus it will eliminate the need for additional custom repositories for SYSFW generation and also moves towards the community standard build flow. We use binman to package tiboot3.bin and sysfw.itb for J721E.
These images also require x509 certificates which are created using the etype ti-x509-cert.
The series also plumbs the generation of tispl.bin which is required for loading U-Boot in K3 devices. The image is packaged using ATF, OPTEE and DM (Device Manager).
Please note that the implementation is for J721E GP (General Purpose) devices.
Also note the introduction of three new etypes: ti-sysfw, ti-dm and ti-x509-cert.
CI tests on Github have all passed but this is after the inclusion of test/py/requirements.txt installation in Azure pipeline script for World Build tests.
v3: - Reformatted patches to make sure none of the existing board builds and functionalities are broken - x509-cert --> ti-x509-cert - Avoided deletion of k3_fit_atf.sh and k3_gen_x509_cert.sh to make sure no other builds fail - Made change to Azure pipeline script to include installation of test/py/requirements.txt in World Build test
v2: - Added etype x509-cert for creating x509 Texas Instruments certificate binary - Added packaging of tiboot3.bin - Packaging of tiboot3.bin and sysfw.itb using new etype x509 - sysfw --> ti-sysfw - Reformatted and re-arranged patches - Removed k3_fit_atf.sh and k3_gen_x509_cert.sh as their functionality is provided by binman now
Neha Malcom Francis (11): j721e_evm: schema: yaml: Add general schema and J721E board config files ti: tools: config: Add board config class to generate config binaries ti: etype: sysfw: Add entry type for sysfw ti: etype: dm: Add entry type for TI DM ti: etype: x509: Add etype for x509 certificate for K3 devices ti: sysfw: Add support for packaging sysfw.itb ti: j721e: Exclude makefile tiboot3.bin target for J721E ti: j721e: Exclude makefile tispl.bin target for J721E ti: dtsi: j721e: Use binman to package sysfw.itb and tiboot3.bin ti: dtsi: j721e: Use binman to package tispl.bin ci: world_build: test: Add requirements.txt
.azure-pipelines.yml | 1 + Makefile | 2 + arch/arm/dts/k3-j721e-a72-binman.dtsi | 86 + .../k3-j721e-common-proc-board-u-boot.dtsi | 1 + arch/arm/dts/k3-j721e-r5-binman.dtsi | 88 + .../k3-j721e-r5-common-proc-board-u-boot.dtsi | 1 + arch/arm/mach-k3/config.mk | 26 + board/ti/common/schema.yaml | 355 ++ board/ti/j721e/Kconfig | 2 + board/ti/j721e/config.yaml | 3162 +++++++++++++++++ scripts/Makefile.spl | 2 + test/py/requirements.txt | 2 + tools/binman/entries.rst | 36 + tools/binman/etype/ti_dm.py | 23 + tools/binman/etype/ti_sysfw.py | 28 + tools/binman/etype/ti_x509_cert.py | 241 ++ tools/binman/ftest.py | 20 + tools/binman/test/225_ti_dm.dts | 13 + tools/binman/test/232_ti_sysfw.dts | 13 + tools/binman/test/232_x509_cert.dts | 18 + tools/tibcfg_gen.py | 114 + 21 files changed, 4234 insertions(+) create mode 100644 arch/arm/dts/k3-j721e-a72-binman.dtsi create mode 100644 arch/arm/dts/k3-j721e-r5-binman.dtsi create mode 100644 board/ti/common/schema.yaml create mode 100644 board/ti/j721e/config.yaml create mode 100644 tools/binman/etype/ti_dm.py create mode 100644 tools/binman/etype/ti_sysfw.py create mode 100644 tools/binman/etype/ti_x509_cert.py create mode 100644 tools/binman/test/225_ti_dm.dts create mode 100644 tools/binman/test/232_ti_sysfw.dts create mode 100644 tools/binman/test/232_x509_cert.dts create mode 100644 tools/tibcfg_gen.py
Schema file in YAML must be provided in board/ti/common for validating input config files and packaging system firmware. The schema includes entries for rm-cfg, board-cfg, pm-cfg and sec-cfg.
Board config file must be provided in board/ti/<devicename> in YAML. These can then be consumed for generation of binaries to package system firmware. Added YAML config for J721E EVM in particular.
It is to be noted that the bootflow followed by J721E requires tiboot3.bin, TIFS and board config binaries to be packaged into sysfw.itb along with u-boot.img. It also requires DM, ATF, OPTEE packaged into tispl.bin.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: prepared patch for upstreaming] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/common/schema.yaml | 355 ++++ board/ti/j721e/config.yaml | 3162 +++++++++++++++++++++++++++++++++++ 2 files changed, 3517 insertions(+) create mode 100644 board/ti/common/schema.yaml create mode 100644 board/ti/j721e/config.yaml
diff --git a/board/ti/common/schema.yaml b/board/ti/common/schema.yaml new file mode 100644 index 0000000000..070ff797e0 --- /dev/null +++ b/board/ti/common/schema.yaml @@ -0,0 +1,355 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Config schema for TI K3 devices +# + +--- + +definitions: + u8: + type: integer + minimum: 0 + maximum: 0xff + u16: + type: integer + minimum: 0 + maximum: 0xffff + u32: + type: integer + minimum: 0 + maximum: 0xffffffff + + + +type: object +properties: + pm-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + board-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + control: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + main_isolation_enable: + $ref: "#/definitions/u8" + main_isolation_hostid: + $ref: "#/definitions/u16" + + + secproxy: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + scaling_factor: + $ref: "#/definitions/u8" + scaling_profile: + $ref: "#/definitions/u8" + disable_main_nav_secure_proxy: + $ref: "#/definitions/u8" + + msmc: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + msmc_cache_size: + $ref: "#/definitions/u8" + debug_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + trace_dst_enables: + $ref: "#/definitions/u16" + trace_src_enables: + $ref: "#/definitions/u16" + + sec-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + + processor_acl_list: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + proc_acl_entries: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + processor_id: + $ref: "#/definitions/u8" + proc_access_master: + $ref: "#/definitions/u8" + proc_access_secondary: + type: array + minItems: 3 + maxItems: 3 + items: + $ref: "#/definitions/u8" + host_hierarchy: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + host_hierarchy_entries: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + supervisor_host_id: + $ref: "#/definitions/u8" + + otp_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + otp_entry: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + host_perms: + $ref: "#/definitions/u8" + write_host_id: + $ref: "#/definitions/u8" + + dkek_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + allowed_hosts: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + allow_dkek_export_tisci: + $ref: "#/definitions/u8" + rsvd: + type: array + minItems: 3 + maxItems: 3 + items: + $ref: "#/definitions/u8" + + sa2ul_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + rsvd: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + sec_dbg_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + allow_jtag_unlock: + $ref: "#/definitions/u8" + allow_wildcard_unlock: + $ref: "#/definitions/u8" + allowed_debug_level_rsvd: + $ref: "#/definitions/u8" + rsvd: + $ref: "#/definitions/u8" + min_cert_rev: + $ref: "#/definitions/u32" + jtag_unlock_hosts: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + + + sec_handover_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + handover_msg_sender: + $ref: "#/definitions/u8" + handover_to_host_id: + $ref: "#/definitions/u8" + rsvd: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + + rm-cfg: + type: object + properties: + rm_boardcfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + + host_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + host_cfg_entries: + type: array + minItems: 0 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + allowed_atype: + $ref: "#/definitions/u8" + allowed_qos: + $ref: "#/definitions/u16" + allowed_orderid: + $ref: "#/definitions/u32" + allowed_priority: + $ref: "#/definitions/u16" + allowed_sched_priority: + $ref: "#/definitions/u8" + resasg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + resasg_entries_size: + $ref: "#/definitions/u16" + reserved: + $ref: "#/definitions/u16" + + resasg_entries: + type: array + minItems: 0 + maxItems: 418 + items: + type: object + properties: + start_resource: + $ref: "#/definitions/u16" + num_resource: + $ref: "#/definitions/u16" + type: + $ref: "#/definitions/u16" + host_id: + $ref: "#/definitions/u8" + reserved: + $ref: "#/definitions/u8" diff --git a/board/ti/j721e/config.yaml b/board/ti/j721e/config.yaml new file mode 100644 index 0000000000..710517404f --- /dev/null +++ b/board/ti/j721e/config.yaml @@ -0,0 +1,3162 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for J721E EVM +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + +board-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable: 0x5A + main_isolation_hostid: 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor: 0x1 + scaling_profile: 0x1 + disable_main_nav_secure_proxy: 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size: 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables: 0x00 + trace_src_enables: 0x00 + +sec-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + write_host_id: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci: 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size: 0 + rsvd: [0, 0, 0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock: 0x5A + allow_wildcard_unlock: 0x5A + allowed_debug_level_rsvd: 0 + rsvd: 0 + min_cert_rev: 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender: 0 + handover_to_host_id: 0 + rsvd: [0, 0, 0, 0] + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size: 356 + host_cfg_entries: + - #1 + host_id: 3 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #2 + host_id: 5 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #3 + host_id: 12 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #4 + host_id: 13 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #5 + host_id: 21 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #6 + host_id: 26 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #7 + host_id: 28 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #8 + host_id: 35 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #9 + host_id: 37 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #10 + host_id: 40 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #11 + host_id: 42 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #12 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #13 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #14 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #15 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #16 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #17 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #18 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #19 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #20 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #21 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #22 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #23 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #24 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #25 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #26 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #27 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #28 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #29 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #30 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #31 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #32 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + resasg: + subhdr: + magic: 0x7B25 + size: 8 + resasg_entries_size: 3344 + reserved: 0 + resasg_entries: + - + start_resource: 4 + num_resource: 93 + type: 7744 + host_id: 26 + reserved: 0 + - + start_resource: 4 + num_resource: 93 + type: 7808 + host_id: 28 + reserved: 0 + - + start_resource: 0 + num_resource: 32 + type: 7872 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 32 + type: 8192 + host_id: 3 + reserved: 0 + - + start_resource: 32 + num_resource: 32 + type: 8192 + host_id: 5 + reserved: 0 + - + start_resource: 0 + num_resource: 24 + type: 8320 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 24 + type: 8320 + host_id: 5 + reserved: 0 + - + start_resource: 0 + num_resource: 8 + type: 8384 + host_id: 3 + reserved: 0 + - + start_resource: 8 + num_resource: 8 + type: 8384 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 4 + type: 8384 + host_id: 40 + reserved: 0 + - + start_resource: 20 + num_resource: 4 + type: 8384 + host_id: 42 + reserved: 0 + - + start_resource: 24 + num_resource: 4 + type: 8384 + host_id: 35 + reserved: 0 + - + start_resource: 28 + num_resource: 4 + type: 8384 + host_id: 37 + reserved: 0 + - + start_resource: 32 + num_resource: 4 + type: 8384 + host_id: 26 + reserved: 0 + - + start_resource: 36 + num_resource: 4 + type: 8384 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 12 + type: 8384 + host_id: 12 + reserved: 0 + - + start_resource: 52 + num_resource: 12 + type: 8384 + host_id: 13 + reserved: 0 + - + start_resource: 0 + num_resource: 128 + type: 8576 + host_id: 35 + reserved: 0 + - + start_resource: 128 + num_resource: 128 + type: 8576 + host_id: 37 + reserved: 0 + - + start_resource: 0 + num_resource: 128 + type: 8640 + host_id: 40 + reserved: 0 + - + start_resource: 128 + num_resource: 128 + type: 8640 + host_id: 42 + reserved: 0 + - + start_resource: 0 + num_resource: 48 + type: 8704 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 8 + type: 8768 + host_id: 3 + reserved: 0 + - + start_resource: 8 + num_resource: 8 + type: 8768 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 6 + type: 8768 + host_id: 12 + reserved: 0 + - + start_resource: 22 + num_resource: 6 + type: 8768 + host_id: 13 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 8768 + host_id: 35 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 8768 + host_id: 37 + reserved: 0 + - + start_resource: 0 + num_resource: 64 + type: 13258 + host_id: 128 + reserved: 0 + - + start_resource: 20480 + num_resource: 1024 + type: 13261 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 64 + type: 13322 + host_id: 128 + reserved: 0 + - + start_resource: 22528 + num_resource: 1024 + type: 13325 + host_id: 128 + reserved: 0 + - + start_resource: 38 + num_resource: 86 + type: 13386 + host_id: 12 + reserved: 0 + - + start_resource: 124 + num_resource: 32 + type: 13386 + host_id: 13 + reserved: 0 + - + start_resource: 156 + num_resource: 12 + type: 13386 + host_id: 40 + reserved: 0 + - + start_resource: 168 + num_resource: 12 + type: 13386 + host_id: 42 + reserved: 0 + - + start_resource: 180 + num_resource: 12 + type: 13386 + host_id: 21 + reserved: 0 + - + start_resource: 192 + num_resource: 12 + type: 13386 + host_id: 26 + reserved: 0 + - + start_resource: 204 + num_resource: 12 + type: 13386 + host_id: 28 + reserved: 0 + - + start_resource: 216 + num_resource: 28 + type: 13386 + host_id: 35 + reserved: 0 + - + start_resource: 244 + num_resource: 8 + type: 13386 + host_id: 37 + reserved: 0 + - + start_resource: 252 + num_resource: 4 + type: 13386 + host_id: 128 + reserved: 0 + - + start_resource: 38 + num_resource: 1024 + type: 13389 + host_id: 12 + reserved: 0 + - + start_resource: 1062 + num_resource: 512 + type: 13389 + host_id: 13 + reserved: 0 + - + start_resource: 1574 + num_resource: 32 + type: 13389 + host_id: 3 + reserved: 0 + - + start_resource: 1606 + num_resource: 32 + type: 13389 + host_id: 5 + reserved: 0 + - + start_resource: 1638 + num_resource: 256 + type: 13389 + host_id: 40 + reserved: 0 + - + start_resource: 1894 + num_resource: 256 + type: 13389 + host_id: 42 + reserved: 0 + - + start_resource: 2150 + num_resource: 256 + type: 13389 + host_id: 21 + reserved: 0 + - + start_resource: 2406 + num_resource: 256 + type: 13389 + host_id: 26 + reserved: 0 + - + start_resource: 2662 + num_resource: 256 + type: 13389 + host_id: 28 + reserved: 0 + - + start_resource: 2918 + num_resource: 512 + type: 13389 + host_id: 35 + reserved: 0 + - + start_resource: 3430 + num_resource: 256 + type: 13389 + host_id: 37 + reserved: 0 + - + start_resource: 3686 + num_resource: 922 + type: 13389 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 4 + type: 13440 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13440 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 4 + type: 13440 + host_id: 3 + reserved: 0 + - + start_resource: 12 + num_resource: 4 + type: 13440 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 4 + type: 13440 + host_id: 40 + reserved: 0 + - + start_resource: 20 + num_resource: 4 + type: 13440 + host_id: 42 + reserved: 0 + - + start_resource: 24 + num_resource: 4 + type: 13440 + host_id: 21 + reserved: 0 + - + start_resource: 28 + num_resource: 4 + type: 13440 + host_id: 26 + reserved: 0 + - + start_resource: 32 + num_resource: 4 + type: 13440 + host_id: 28 + reserved: 0 + - + start_resource: 36 + num_resource: 12 + type: 13440 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 4 + type: 13440 + host_id: 37 + reserved: 0 + - + start_resource: 52 + num_resource: 12 + type: 13440 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 13504 + host_id: 128 + reserved: 0 + - + start_resource: 440 + num_resource: 150 + type: 13505 + host_id: 12 + reserved: 0 + - + start_resource: 590 + num_resource: 40 + type: 13505 + host_id: 13 + reserved: 0 + - + start_resource: 630 + num_resource: 6 + type: 13505 + host_id: 3 + reserved: 0 + - + start_resource: 636 + num_resource: 6 + type: 13505 + host_id: 5 + reserved: 0 + - + start_resource: 642 + num_resource: 10 + type: 13505 + host_id: 40 + reserved: 0 + - + start_resource: 652 + num_resource: 10 + type: 13505 + host_id: 42 + reserved: 0 + - + start_resource: 662 + num_resource: 32 + type: 13505 + host_id: 21 + reserved: 0 + - + start_resource: 694 + num_resource: 38 + type: 13505 + host_id: 26 + reserved: 0 + - + start_resource: 732 + num_resource: 12 + type: 13505 + host_id: 28 + reserved: 0 + - + start_resource: 744 + num_resource: 182 + type: 13505 + host_id: 35 + reserved: 0 + - + start_resource: 926 + num_resource: 40 + type: 13505 + host_id: 37 + reserved: 0 + - + start_resource: 966 + num_resource: 8 + type: 13505 + host_id: 128 + reserved: 0 + - + start_resource: 316 + num_resource: 8 + type: 13506 + host_id: 12 + reserved: 0 + - + start_resource: 324 + num_resource: 2 + type: 13506 + host_id: 3 + reserved: 0 + - + start_resource: 324 + num_resource: 0 + type: 13506 + host_id: 13 + reserved: 0 + - + start_resource: 326 + num_resource: 2 + type: 13506 + host_id: 5 + reserved: 0 + - + start_resource: 328 + num_resource: 2 + type: 13506 + host_id: 40 + reserved: 0 + - + start_resource: 330 + num_resource: 2 + type: 13506 + host_id: 42 + reserved: 0 + - + start_resource: 332 + num_resource: 2 + type: 13506 + host_id: 21 + reserved: 0 + - + start_resource: 334 + num_resource: 8 + type: 13506 + host_id: 26 + reserved: 0 + - + start_resource: 342 + num_resource: 2 + type: 13506 + host_id: 28 + reserved: 0 + - + start_resource: 344 + num_resource: 4 + type: 13506 + host_id: 35 + reserved: 0 + - + start_resource: 348 + num_resource: 1 + type: 13506 + host_id: 37 + reserved: 0 + - + start_resource: 349 + num_resource: 28 + type: 13506 + host_id: 12 + reserved: 0 + - + start_resource: 377 + num_resource: 20 + type: 13506 + host_id: 13 + reserved: 0 + - + start_resource: 397 + num_resource: 4 + type: 13506 + host_id: 40 + reserved: 0 + - + start_resource: 401 + num_resource: 4 + type: 13506 + host_id: 42 + reserved: 0 + - + start_resource: 405 + num_resource: 4 + type: 13506 + host_id: 21 + reserved: 0 + - + start_resource: 409 + num_resource: 8 + type: 13506 + host_id: 26 + reserved: 0 + - + start_resource: 417 + num_resource: 6 + type: 13506 + host_id: 28 + reserved: 0 + - + start_resource: 423 + num_resource: 16 + type: 13506 + host_id: 35 + reserved: 0 + - + start_resource: 439 + num_resource: 1 + type: 13506 + host_id: 37 + reserved: 0 + - + start_resource: 16 + num_resource: 8 + type: 13507 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 2 + type: 13507 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 0 + type: 13507 + host_id: 13 + reserved: 0 + - + start_resource: 26 + num_resource: 2 + type: 13507 + host_id: 5 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 13507 + host_id: 40 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 13507 + host_id: 42 + reserved: 0 + - + start_resource: 32 + num_resource: 2 + type: 13507 + host_id: 21 + reserved: 0 + - + start_resource: 34 + num_resource: 8 + type: 13507 + host_id: 26 + reserved: 0 + - + start_resource: 42 + num_resource: 2 + type: 13507 + host_id: 28 + reserved: 0 + - + start_resource: 44 + num_resource: 4 + type: 13507 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 1 + type: 13507 + host_id: 37 + reserved: 0 + - + start_resource: 49 + num_resource: 28 + type: 13507 + host_id: 12 + reserved: 0 + - + start_resource: 77 + num_resource: 20 + type: 13507 + host_id: 13 + reserved: 0 + - + start_resource: 97 + num_resource: 4 + type: 13507 + host_id: 40 + reserved: 0 + - + start_resource: 101 + num_resource: 4 + type: 13507 + host_id: 42 + reserved: 0 + - + start_resource: 105 + num_resource: 4 + type: 13507 + host_id: 21 + reserved: 0 + - + start_resource: 109 + num_resource: 8 + type: 13507 + host_id: 26 + reserved: 0 + - + start_resource: 117 + num_resource: 6 + type: 13507 + host_id: 28 + reserved: 0 + - + start_resource: 123 + num_resource: 10 + type: 13507 + host_id: 35 + reserved: 0 + - + start_resource: 133 + num_resource: 6 + type: 13507 + host_id: 37 + reserved: 0 + - + start_resource: 139 + num_resource: 1 + type: 13507 + host_id: 128 + reserved: 0 + - + start_resource: 140 + num_resource: 16 + type: 13508 + host_id: 21 + reserved: 0 + - + start_resource: 156 + num_resource: 6 + type: 13508 + host_id: 26 + reserved: 0 + - + start_resource: 162 + num_resource: 6 + type: 13508 + host_id: 28 + reserved: 0 + - + start_resource: 168 + num_resource: 2 + type: 13508 + host_id: 35 + reserved: 0 + - + start_resource: 170 + num_resource: 2 + type: 13508 + host_id: 37 + reserved: 0 + - + start_resource: 172 + num_resource: 96 + type: 13508 + host_id: 35 + reserved: 0 + - + start_resource: 268 + num_resource: 32 + type: 13508 + host_id: 37 + reserved: 0 + - + start_resource: 304 + num_resource: 0 + type: 13509 + host_id: 12 + reserved: 0 + - + start_resource: 304 + num_resource: 4 + type: 13509 + host_id: 12 + reserved: 0 + - + start_resource: 304 + num_resource: 0 + type: 13509 + host_id: 35 + reserved: 0 + - + start_resource: 308 + num_resource: 6 + type: 13509 + host_id: 35 + reserved: 0 + - + start_resource: 314 + num_resource: 2 + type: 13509 + host_id: 128 + reserved: 0 + - + start_resource: 300 + num_resource: 0 + type: 13510 + host_id: 12 + reserved: 0 + - + start_resource: 300 + num_resource: 2 + type: 13510 + host_id: 12 + reserved: 0 + - + start_resource: 300 + num_resource: 0 + type: 13510 + host_id: 35 + reserved: 0 + - + start_resource: 302 + num_resource: 2 + type: 13510 + host_id: 35 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13511 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13511 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13511 + host_id: 35 + reserved: 0 + - + start_resource: 8 + num_resource: 6 + type: 13511 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 2 + type: 13511 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13512 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 13512 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13512 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 13512 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 5 + type: 13514 + host_id: 12 + reserved: 0 + - + start_resource: 7 + num_resource: 1 + type: 13514 + host_id: 13 + reserved: 0 + - + start_resource: 0 + num_resource: 3 + type: 13515 + host_id: 12 + reserved: 0 + - + start_resource: 3 + num_resource: 2 + type: 13515 + host_id: 13 + reserved: 0 + - + start_resource: 5 + num_resource: 1 + type: 13515 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 1 + type: 13515 + host_id: 5 + reserved: 0 + - + start_resource: 7 + num_resource: 3 + type: 13515 + host_id: 40 + reserved: 0 + - + start_resource: 10 + num_resource: 3 + type: 13515 + host_id: 42 + reserved: 0 + - + start_resource: 13 + num_resource: 3 + type: 13515 + host_id: 21 + reserved: 0 + - + start_resource: 16 + num_resource: 3 + type: 13515 + host_id: 26 + reserved: 0 + - + start_resource: 19 + num_resource: 3 + type: 13515 + host_id: 28 + reserved: 0 + - + start_resource: 22 + num_resource: 6 + type: 13515 + host_id: 35 + reserved: 0 + - + start_resource: 28 + num_resource: 3 + type: 13515 + host_id: 37 + reserved: 0 + - + start_resource: 31 + num_resource: 1 + type: 13515 + host_id: 128 + reserved: 0 + - + start_resource: 140 + num_resource: 16 + type: 13568 + host_id: 12 + reserved: 0 + - + start_resource: 156 + num_resource: 16 + type: 13568 + host_id: 13 + reserved: 0 + - + start_resource: 172 + num_resource: 128 + type: 13568 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 13569 + host_id: 128 + reserved: 0 + - + start_resource: 49152 + num_resource: 1024 + type: 13570 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 13571 + host_id: 128 + reserved: 0 + - + start_resource: 16 + num_resource: 8 + type: 13578 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 2 + type: 13578 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 0 + type: 13578 + host_id: 13 + reserved: 0 + - + start_resource: 26 + num_resource: 2 + type: 13578 + host_id: 5 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 13578 + host_id: 40 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 13578 + host_id: 42 + reserved: 0 + - + start_resource: 32 + num_resource: 2 + type: 13578 + host_id: 21 + reserved: 0 + - + start_resource: 34 + num_resource: 8 + type: 13578 + host_id: 26 + reserved: 0 + - + start_resource: 42 + num_resource: 2 + type: 13578 + host_id: 28 + reserved: 0 + - + start_resource: 44 + num_resource: 4 + type: 13578 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 1 + type: 13578 + host_id: 37 + reserved: 0 + - + start_resource: 49 + num_resource: 28 + type: 13578 + host_id: 12 + reserved: 0 + - + start_resource: 77 + num_resource: 20 + type: 13578 + host_id: 13 + reserved: 0 + - + start_resource: 97 + num_resource: 4 + type: 13578 + host_id: 40 + reserved: 0 + - + start_resource: 101 + num_resource: 4 + type: 13578 + host_id: 42 + reserved: 0 + - + start_resource: 105 + num_resource: 4 + type: 13578 + host_id: 21 + reserved: 0 + - + start_resource: 109 + num_resource: 8 + type: 13578 + host_id: 26 + reserved: 0 + - + start_resource: 117 + num_resource: 6 + type: 13578 + host_id: 28 + reserved: 0 + - + start_resource: 123 + num_resource: 16 + type: 13578 + host_id: 35 + reserved: 0 + - + start_resource: 139 + num_resource: 1 + type: 13578 + host_id: 37 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13579 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13579 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13579 + host_id: 35 + reserved: 0 + - + start_resource: 8 + num_resource: 6 + type: 13579 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 2 + type: 13579 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13580 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 13580 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13580 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 13580 + host_id: 35 + reserved: 0 + - + start_resource: 16 + num_resource: 8 + type: 13581 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 2 + type: 13581 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 0 + type: 13581 + host_id: 13 + reserved: 0 + - + start_resource: 26 + num_resource: 2 + type: 13581 + host_id: 5 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 13581 + host_id: 40 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 13581 + host_id: 42 + reserved: 0 + - + start_resource: 32 + num_resource: 2 + type: 13581 + host_id: 21 + reserved: 0 + - + start_resource: 34 + num_resource: 8 + type: 13581 + host_id: 26 + reserved: 0 + - + start_resource: 42 + num_resource: 2 + type: 13581 + host_id: 28 + reserved: 0 + - + start_resource: 44 + num_resource: 4 + type: 13581 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 1 + type: 13581 + host_id: 37 + reserved: 0 + - + start_resource: 49 + num_resource: 28 + type: 13581 + host_id: 12 + reserved: 0 + - + start_resource: 77 + num_resource: 20 + type: 13581 + host_id: 13 + reserved: 0 + - + start_resource: 97 + num_resource: 4 + type: 13581 + host_id: 40 + reserved: 0 + - + start_resource: 101 + num_resource: 4 + type: 13581 + host_id: 42 + reserved: 0 + - + start_resource: 105 + num_resource: 4 + type: 13581 + host_id: 21 + reserved: 0 + - + start_resource: 109 + num_resource: 8 + type: 13581 + host_id: 26 + reserved: 0 + - + start_resource: 117 + num_resource: 6 + type: 13581 + host_id: 28 + reserved: 0 + - + start_resource: 123 + num_resource: 10 + type: 13581 + host_id: 35 + reserved: 0 + - + start_resource: 133 + num_resource: 6 + type: 13581 + host_id: 37 + reserved: 0 + - + start_resource: 139 + num_resource: 1 + type: 13581 + host_id: 128 + reserved: 0 + - + start_resource: 140 + num_resource: 16 + type: 13582 + host_id: 21 + reserved: 0 + - + start_resource: 156 + num_resource: 6 + type: 13582 + host_id: 26 + reserved: 0 + - + start_resource: 162 + num_resource: 6 + type: 13582 + host_id: 28 + reserved: 0 + - + start_resource: 168 + num_resource: 2 + type: 13582 + host_id: 35 + reserved: 0 + - + start_resource: 170 + num_resource: 2 + type: 13582 + host_id: 37 + reserved: 0 + - + start_resource: 172 + num_resource: 96 + type: 13582 + host_id: 35 + reserved: 0 + - + start_resource: 268 + num_resource: 32 + type: 13582 + host_id: 37 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13583 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13583 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13583 + host_id: 35 + reserved: 0 + - + start_resource: 8 + num_resource: 6 + type: 13583 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 2 + type: 13583 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13584 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 13584 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13584 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 13584 + host_id: 35 + reserved: 0 + - + start_resource: 10 + num_resource: 100 + type: 13632 + host_id: 12 + reserved: 0 + - + start_resource: 110 + num_resource: 32 + type: 13632 + host_id: 13 + reserved: 0 + - + start_resource: 142 + num_resource: 46 + type: 13632 + host_id: 21 + reserved: 0 + - + start_resource: 196 + num_resource: 28 + type: 13632 + host_id: 35 + reserved: 0 + - + start_resource: 228 + num_resource: 28 + type: 13632 + host_id: 37 + reserved: 0 + - + start_resource: 260 + num_resource: 28 + type: 13632 + host_id: 40 + reserved: 0 + - + start_resource: 292 + num_resource: 28 + type: 13632 + host_id: 42 + reserved: 0 + - + start_resource: 320 + num_resource: 24 + type: 13632 + host_id: 26 + reserved: 0 + - + start_resource: 352 + num_resource: 24 + type: 13632 + host_id: 28 + reserved: 0 + - + start_resource: 400 + num_resource: 4 + type: 13632 + host_id: 3 + reserved: 0 + - + start_resource: 404 + num_resource: 4 + type: 13632 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 32 + type: 14922 + host_id: 12 + reserved: 0 + - + start_resource: 48 + num_resource: 16 + type: 14922 + host_id: 13 + reserved: 0 + - + start_resource: 64 + num_resource: 64 + type: 14922 + host_id: 3 + reserved: 0 + - + start_resource: 128 + num_resource: 4 + type: 14922 + host_id: 5 + reserved: 0 + - + start_resource: 132 + num_resource: 16 + type: 14922 + host_id: 40 + reserved: 0 + - + start_resource: 148 + num_resource: 16 + type: 14922 + host_id: 42 + reserved: 0 + - + start_resource: 164 + num_resource: 8 + type: 14922 + host_id: 21 + reserved: 0 + - + start_resource: 172 + num_resource: 8 + type: 14922 + host_id: 26 + reserved: 0 + - + start_resource: 180 + num_resource: 8 + type: 14922 + host_id: 28 + reserved: 0 + - + start_resource: 188 + num_resource: 24 + type: 14922 + host_id: 35 + reserved: 0 + - + start_resource: 212 + num_resource: 8 + type: 14922 + host_id: 37 + reserved: 0 + - + start_resource: 220 + num_resource: 36 + type: 14922 + host_id: 128 + reserved: 0 + - + start_resource: 16400 + num_resource: 128 + type: 14925 + host_id: 12 + reserved: 0 + - + start_resource: 16528 + num_resource: 128 + type: 14925 + host_id: 13 + reserved: 0 + - + start_resource: 16656 + num_resource: 256 + type: 14925 + host_id: 3 + reserved: 0 + - + start_resource: 16912 + num_resource: 64 + type: 14925 + host_id: 5 + reserved: 0 + - + start_resource: 16976 + num_resource: 128 + type: 14925 + host_id: 40 + reserved: 0 + - + start_resource: 17104 + num_resource: 128 + type: 14925 + host_id: 42 + reserved: 0 + - + start_resource: 17232 + num_resource: 64 + type: 14925 + host_id: 21 + reserved: 0 + - + start_resource: 17296 + num_resource: 64 + type: 14925 + host_id: 26 + reserved: 0 + - + start_resource: 17360 + num_resource: 64 + type: 14925 + host_id: 28 + reserved: 0 + - + start_resource: 17424 + num_resource: 128 + type: 14925 + host_id: 35 + reserved: 0 + - + start_resource: 17552 + num_resource: 128 + type: 14925 + host_id: 37 + reserved: 0 + - + start_resource: 17680 + num_resource: 240 + type: 14925 + host_id: 128 + reserved: 0 + - + start_resource: 1 + num_resource: 4 + type: 14976 + host_id: 12 + reserved: 0 + - + start_resource: 5 + num_resource: 4 + type: 14976 + host_id: 13 + reserved: 0 + - + start_resource: 9 + num_resource: 4 + type: 14976 + host_id: 3 + reserved: 0 + - + start_resource: 13 + num_resource: 4 + type: 14976 + host_id: 5 + reserved: 0 + - + start_resource: 17 + num_resource: 4 + type: 14976 + host_id: 40 + reserved: 0 + - + start_resource: 21 + num_resource: 4 + type: 14976 + host_id: 42 + reserved: 0 + - + start_resource: 25 + num_resource: 4 + type: 14976 + host_id: 21 + reserved: 0 + - + start_resource: 29 + num_resource: 4 + type: 14976 + host_id: 26 + reserved: 0 + - + start_resource: 33 + num_resource: 4 + type: 14976 + host_id: 28 + reserved: 0 + - + start_resource: 37 + num_resource: 16 + type: 14976 + host_id: 35 + reserved: 0 + - + start_resource: 53 + num_resource: 4 + type: 14976 + host_id: 37 + reserved: 0 + - + start_resource: 57 + num_resource: 7 + type: 14976 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 15040 + host_id: 128 + reserved: 0 + - + start_resource: 96 + num_resource: 20 + type: 15041 + host_id: 12 + reserved: 0 + - + start_resource: 116 + num_resource: 8 + type: 15041 + host_id: 13 + reserved: 0 + - + start_resource: 124 + num_resource: 32 + type: 15041 + host_id: 3 + reserved: 0 + - + start_resource: 156 + num_resource: 12 + type: 15041 + host_id: 5 + reserved: 0 + - + start_resource: 168 + num_resource: 8 + type: 15041 + host_id: 40 + reserved: 0 + - + start_resource: 176 + num_resource: 8 + type: 15041 + host_id: 42 + reserved: 0 + - + start_resource: 184 + num_resource: 8 + type: 15041 + host_id: 21 + reserved: 0 + - + start_resource: 192 + num_resource: 8 + type: 15041 + host_id: 26 + reserved: 0 + - + start_resource: 200 + num_resource: 8 + type: 15041 + host_id: 28 + reserved: 0 + - + start_resource: 208 + num_resource: 16 + type: 15041 + host_id: 35 + reserved: 0 + - + start_resource: 224 + num_resource: 8 + type: 15041 + host_id: 37 + reserved: 0 + - + start_resource: 232 + num_resource: 20 + type: 15041 + host_id: 128 + reserved: 0 + - + start_resource: 50 + num_resource: 4 + type: 15042 + host_id: 12 + reserved: 0 + - + start_resource: 54 + num_resource: 2 + type: 15042 + host_id: 3 + reserved: 0 + - + start_resource: 54 + num_resource: 0 + type: 15042 + host_id: 13 + reserved: 0 + - + start_resource: 56 + num_resource: 0 + type: 15042 + host_id: 5 + reserved: 0 + - + start_resource: 56 + num_resource: 1 + type: 15042 + host_id: 40 + reserved: 0 + - + start_resource: 57 + num_resource: 1 + type: 15042 + host_id: 42 + reserved: 0 + - + start_resource: 58 + num_resource: 1 + type: 15042 + host_id: 21 + reserved: 0 + - + start_resource: 59 + num_resource: 1 + type: 15042 + host_id: 26 + reserved: 0 + - + start_resource: 60 + num_resource: 1 + type: 15042 + host_id: 28 + reserved: 0 + - + start_resource: 61 + num_resource: 1 + type: 15042 + host_id: 35 + reserved: 0 + - + start_resource: 62 + num_resource: 1 + type: 15042 + host_id: 37 + reserved: 0 + - + start_resource: 63 + num_resource: 9 + type: 15042 + host_id: 12 + reserved: 0 + - + start_resource: 72 + num_resource: 6 + type: 15042 + host_id: 13 + reserved: 0 + - + start_resource: 78 + num_resource: 3 + type: 15042 + host_id: 3 + reserved: 0 + - + start_resource: 81 + num_resource: 2 + type: 15042 + host_id: 5 + reserved: 0 + - + start_resource: 83 + num_resource: 1 + type: 15042 + host_id: 40 + reserved: 0 + - + start_resource: 84 + num_resource: 1 + type: 15042 + host_id: 42 + reserved: 0 + - + start_resource: 85 + num_resource: 1 + type: 15042 + host_id: 21 + reserved: 0 + - + start_resource: 86 + num_resource: 1 + type: 15042 + host_id: 26 + reserved: 0 + - + start_resource: 87 + num_resource: 1 + type: 15042 + host_id: 28 + reserved: 0 + - + start_resource: 88 + num_resource: 2 + type: 15042 + host_id: 35 + reserved: 0 + - + start_resource: 90 + num_resource: 1 + type: 15042 + host_id: 37 + reserved: 0 + - + start_resource: 91 + num_resource: 2 + type: 15042 + host_id: 128 + reserved: 0 + - + start_resource: 2 + num_resource: 4 + type: 15043 + host_id: 12 + reserved: 0 + - + start_resource: 6 + num_resource: 2 + type: 15043 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 0 + type: 15043 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 0 + type: 15043 + host_id: 5 + reserved: 0 + - + start_resource: 8 + num_resource: 1 + type: 15043 + host_id: 40 + reserved: 0 + - + start_resource: 9 + num_resource: 1 + type: 15043 + host_id: 42 + reserved: 0 + - + start_resource: 10 + num_resource: 1 + type: 15043 + host_id: 21 + reserved: 0 + - + start_resource: 11 + num_resource: 1 + type: 15043 + host_id: 26 + reserved: 0 + - + start_resource: 12 + num_resource: 1 + type: 15043 + host_id: 28 + reserved: 0 + - + start_resource: 13 + num_resource: 1 + type: 15043 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 1 + type: 15043 + host_id: 37 + reserved: 0 + - + start_resource: 15 + num_resource: 9 + type: 15043 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 6 + type: 15043 + host_id: 13 + reserved: 0 + - + start_resource: 30 + num_resource: 3 + type: 15043 + host_id: 3 + reserved: 0 + - + start_resource: 33 + num_resource: 2 + type: 15043 + host_id: 5 + reserved: 0 + - + start_resource: 35 + num_resource: 1 + type: 15043 + host_id: 40 + reserved: 0 + - + start_resource: 36 + num_resource: 1 + type: 15043 + host_id: 42 + reserved: 0 + - + start_resource: 37 + num_resource: 1 + type: 15043 + host_id: 21 + reserved: 0 + - + start_resource: 38 + num_resource: 1 + type: 15043 + host_id: 26 + reserved: 0 + - + start_resource: 39 + num_resource: 1 + type: 15043 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 2 + type: 15043 + host_id: 35 + reserved: 0 + - + start_resource: 42 + num_resource: 1 + type: 15043 + host_id: 37 + reserved: 0 + - + start_resource: 43 + num_resource: 3 + type: 15043 + host_id: 128 + reserved: 0 + - + start_resource: 48 + num_resource: 0 + type: 15045 + host_id: 3 + reserved: 0 + - + start_resource: 48 + num_resource: 2 + type: 15045 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 15047 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 15047 + host_id: 3 + reserved: 0 + - + start_resource: 2 + num_resource: 5 + type: 15050 + host_id: 12 + reserved: 0 + - + start_resource: 7 + num_resource: 1 + type: 15050 + host_id: 13 + reserved: 0 + - + start_resource: 0 + num_resource: 3 + type: 15051 + host_id: 12 + reserved: 0 + - + start_resource: 3 + num_resource: 2 + type: 15051 + host_id: 13 + reserved: 0 + - + start_resource: 5 + num_resource: 3 + type: 15051 + host_id: 3 + reserved: 0 + - + start_resource: 8 + num_resource: 3 + type: 15051 + host_id: 5 + reserved: 0 + - + start_resource: 11 + num_resource: 3 + type: 15051 + host_id: 40 + reserved: 0 + - + start_resource: 14 + num_resource: 3 + type: 15051 + host_id: 42 + reserved: 0 + - + start_resource: 17 + num_resource: 3 + type: 15051 + host_id: 21 + reserved: 0 + - + start_resource: 20 + num_resource: 3 + type: 15051 + host_id: 26 + reserved: 0 + - + start_resource: 23 + num_resource: 3 + type: 15051 + host_id: 28 + reserved: 0 + - + start_resource: 26 + num_resource: 3 + type: 15051 + host_id: 35 + reserved: 0 + - + start_resource: 29 + num_resource: 3 + type: 15051 + host_id: 37 + reserved: 0 + - + start_resource: 48 + num_resource: 8 + type: 15104 + host_id: 12 + reserved: 0 + - + start_resource: 56 + num_resource: 4 + type: 15104 + host_id: 13 + reserved: 0 + - + start_resource: 60 + num_resource: 8 + type: 15104 + host_id: 3 + reserved: 0 + - + start_resource: 68 + num_resource: 4 + type: 15104 + host_id: 5 + reserved: 0 + - + start_resource: 72 + num_resource: 4 + type: 15104 + host_id: 40 + reserved: 0 + - + start_resource: 76 + num_resource: 4 + type: 15104 + host_id: 42 + reserved: 0 + - + start_resource: 80 + num_resource: 8 + type: 15104 + host_id: 35 + reserved: 0 + - + start_resource: 88 + num_resource: 4 + type: 15104 + host_id: 37 + reserved: 0 + - + start_resource: 92 + num_resource: 4 + type: 15104 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 15105 + host_id: 128 + reserved: 0 + - + start_resource: 56320 + num_resource: 256 + type: 15106 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 15107 + host_id: 128 + reserved: 0 + - + start_resource: 2 + num_resource: 4 + type: 15114 + host_id: 12 + reserved: 0 + - + start_resource: 6 + num_resource: 2 + type: 15114 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 0 + type: 15114 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 0 + type: 15114 + host_id: 5 + reserved: 0 + - + start_resource: 8 + num_resource: 1 + type: 15114 + host_id: 40 + reserved: 0 + - + start_resource: 9 + num_resource: 1 + type: 15114 + host_id: 42 + reserved: 0 + - + start_resource: 10 + num_resource: 1 + type: 15114 + host_id: 21 + reserved: 0 + - + start_resource: 11 + num_resource: 1 + type: 15114 + host_id: 26 + reserved: 0 + - + start_resource: 12 + num_resource: 1 + type: 15114 + host_id: 28 + reserved: 0 + - + start_resource: 13 + num_resource: 1 + type: 15114 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 1 + type: 15114 + host_id: 37 + reserved: 0 + - + start_resource: 15 + num_resource: 9 + type: 15114 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 6 + type: 15114 + host_id: 13 + reserved: 0 + - + start_resource: 30 + num_resource: 3 + type: 15114 + host_id: 3 + reserved: 0 + - + start_resource: 33 + num_resource: 2 + type: 15114 + host_id: 5 + reserved: 0 + - + start_resource: 35 + num_resource: 1 + type: 15114 + host_id: 40 + reserved: 0 + - + start_resource: 36 + num_resource: 1 + type: 15114 + host_id: 42 + reserved: 0 + - + start_resource: 37 + num_resource: 1 + type: 15114 + host_id: 21 + reserved: 0 + - + start_resource: 38 + num_resource: 1 + type: 15114 + host_id: 26 + reserved: 0 + - + start_resource: 39 + num_resource: 1 + type: 15114 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 2 + type: 15114 + host_id: 35 + reserved: 0 + - + start_resource: 42 + num_resource: 1 + type: 15114 + host_id: 37 + reserved: 0 + - + start_resource: 43 + num_resource: 2 + type: 15114 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 15115 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 15115 + host_id: 3 + reserved: 0 + - + start_resource: 2 + num_resource: 4 + type: 15117 + host_id: 12 + reserved: 0 + - + start_resource: 6 + num_resource: 2 + type: 15117 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 0 + type: 15117 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 0 + type: 15117 + host_id: 5 + reserved: 0 + - + start_resource: 8 + num_resource: 1 + type: 15117 + host_id: 40 + reserved: 0 + - + start_resource: 9 + num_resource: 1 + type: 15117 + host_id: 42 + reserved: 0 + - + start_resource: 10 + num_resource: 1 + type: 15117 + host_id: 21 + reserved: 0 + - + start_resource: 11 + num_resource: 1 + type: 15117 + host_id: 26 + reserved: 0 + - + start_resource: 12 + num_resource: 1 + type: 15117 + host_id: 28 + reserved: 0 + - + start_resource: 13 + num_resource: 1 + type: 15117 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 1 + type: 15117 + host_id: 37 + reserved: 0 + - + start_resource: 15 + num_resource: 9 + type: 15117 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 6 + type: 15117 + host_id: 13 + reserved: 0 + - + start_resource: 30 + num_resource: 3 + type: 15117 + host_id: 3 + reserved: 0 + - + start_resource: 33 + num_resource: 2 + type: 15117 + host_id: 5 + reserved: 0 + - + start_resource: 35 + num_resource: 1 + type: 15117 + host_id: 40 + reserved: 0 + - + start_resource: 36 + num_resource: 1 + type: 15117 + host_id: 42 + reserved: 0 + - + start_resource: 37 + num_resource: 1 + type: 15117 + host_id: 21 + reserved: 0 + - + start_resource: 38 + num_resource: 1 + type: 15117 + host_id: 26 + reserved: 0 + - + start_resource: 39 + num_resource: 1 + type: 15117 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 2 + type: 15117 + host_id: 35 + reserved: 0 + - + start_resource: 42 + num_resource: 1 + type: 15117 + host_id: 37 + reserved: 0 + - + start_resource: 43 + num_resource: 3 + type: 15117 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 15119 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 15119 + host_id: 3 + reserved: 0 + - + start_resource: 12 + num_resource: 20 + type: 15168 + host_id: 3 + reserved: 0 + - + start_resource: 36 + num_resource: 28 + type: 15168 + host_id: 5 + reserved: 0
For validating config files and generating binary config artifacts, here board specific config class is added.
Add function cfgBinaryGen() in tibcfg_gen.py. It uses TIBoardConfig class to load given schema and config files in YAML, validate them and generate binaries.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: prepared patch for upstreaming] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- test/py/requirements.txt | 1 + tools/tibcfg_gen.py | 114 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 115 insertions(+) create mode 100644 tools/tibcfg_gen.py
diff --git a/test/py/requirements.txt b/test/py/requirements.txt index 33c5c0bbc4..a91ba64563 100644 --- a/test/py/requirements.txt +++ b/test/py/requirements.txt @@ -4,6 +4,7 @@ coverage==4.5.4 extras==1.0.0 fixtures==3.0.0 importlib-metadata==0.23 +jsonschema==4.0.0 linecache2==1.0.0 more-itertools==7.2.0 packaging==19.2 diff --git a/tools/tibcfg_gen.py b/tools/tibcfg_gen.py new file mode 100644 index 0000000000..e5fa2690c8 --- /dev/null +++ b/tools/tibcfg_gen.py @@ -0,0 +1,114 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# TI Board Configuration Class for Schema Validation and Binary Generation +# + +import os +import getopt +import sys + +import yaml + +from jsonschema import validate + + +class TIBoardConfig: + + """ Texas Instruments Board Configuration File""" + + def __init__(self, file, schema, data_rules=""): + """Load a YAML configuration file and YAML schema + + Validation of the config file against the schema is also done.""" + with open(file, 'r') as f: + self.file_yaml = yaml.safe_load(f) + with open(schema, 'r') as sch: + self.schema_yaml = yaml.safe_load(sch) + self.data_rules = data_rules + try: + validate(self.file_yaml, self.schema_yaml) + except Exception as e: + print(e) + + def _convert_to_byte_chunk(self, val, data_type): + """Convert value into byte array""" + size = 0 + if(data_type == "#/definitions/u8"): + size = 1 + elif(data_type == "#/definitions/u16"): + size = 2 + elif(data_type == "#/definitions/u32"): + size = 4 + else: + raise Exception("Data type not present in definitions") + if type(val) == int: + br = val.to_bytes(size, byteorder="little") + return br + + def _compile_yaml(self, schema_yaml, file_yaml): + """Convert YAML file into byte array based on YAML schema""" + br = bytearray() + for key in file_yaml.keys(): + node = file_yaml[key] + node_schema = schema_yaml['properties'][key] + node_type = node_schema.get('type') + if not 'type' in node_schema: + br += self._convert_to_byte_chunk(node, + node_schema.get('$ref')) + elif node_type == 'object': + br += self._compile_yaml(node_schema, node) + elif node_type == 'array': + for item in node: + if not isinstance(item, dict): + br += self._convert_to_byte_chunk( + item, schema_yaml['properties'][key]['items']["$ref"]) + else: + br += self._compile_yaml(node_schema.get('items'), item) + return br + + def generate_binaries(self, out_path=""): + """Generate config binary artifacts from the loaded YAML configuration file""" + if not os.path.isdir(out_path): + os.mkdir(out_path) + for key in self.file_yaml.keys(): + node = self.file_yaml[key] + node_schema = self.schema_yaml['properties'][key] + br = self._compile_yaml(node_schema, node) + path = os.path.join(out_path, key + ".bin") + with open(path, 'wb') as cfg: + cfg.write(br) + + def delete_binaries(self, out_path=""): + """Delete generated binaries""" + if os.path.isdir(out_path): + for key in self.file_yaml.keys(): + path = os.path.join(out_path, key + ".bin") + if os.path.isfile(path): + os.remove(path) + + +def cfgBinaryGen(): + """Generate config binaries from YAML config file and YAML schema + Arguments: + - config_yaml: board config file in YAML + - schema_yaml: schema file in YAML to validate config_yaml against + - output_dir: output directory where generated binaries can be populated + Pass the arguments along with the filename in the Makefile. + """ + opts, args = getopt.getopt(sys.argv[1:], "c:s:o") + for opt, val in opts: + if opt == "-c": + config_yaml = val + elif opt == "-s": + schema_yaml = val + elif opt == "-o": + output_dir = os.path.abspath(val) + try: + tibcfg = TIBoardConfig(config_yaml, schema_yaml) + tibcfg.generate_binaries(output_dir) + except: + raise ValueError("Could not find config files!") + + +cfgBinaryGen()
+import yaml
- """ Texas Instruments Board Configuration File"""
- def __init__(self, file, schema, data_rules=""):
try:
print(e)
Don't catch the exception here, so that we never have a non-validated TIBoardConfig object. Instead, catch it in cfgBinaryGen() below to report the validation error.
- def _convert_to_byte_chunk(self, val, data_type):
size = 0
size = 1
size = 2
size = 4
Parentheses are unnecessary for these as well.
else:
return br
- def _compile_yaml(self, schema_yaml, file_yaml):
br = bytearray()
for item in node:
else:
return br
- def generate_binaries(self, out_path=""):
os.mkdir(out_path)
cfg.write(br)
- def delete_binaries(self, out_path=""):
os.remove(path)
- """Generate config binaries from YAML config file and YAML schema
Arguments:
- Pass the arguments along with the filename in the Makefile.
- opts, args = getopt.getopt(sys.argv[1:], "c:s:o")
I'd prefer argparse, with both long/short forms of arguments and proper help messages.
- for opt, val in opts:
if opt == "-c":
config_yaml = val
elif opt == "-s":
schema_yaml = val
elif opt == "-o":
- try:
- except:
+cfgBinaryGen()
This needs to be
if __name__ == "__main__": cfgBinaryGen()
or it will be run when anything uses 'import tibcfg_gen' in Python.
For K3 devices that require a sysfw image, add entry for SYSFW. It can contain system firmware image that can be packaged into sysfw.itb by binman.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: added tests for addition of etype] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- Makefile | 1 + tools/binman/entries.rst | 11 +++++++++++ tools/binman/etype/ti_sysfw.py | 28 ++++++++++++++++++++++++++++ tools/binman/ftest.py | 7 +++++++ tools/binman/test/232_ti_sysfw.dts | 13 +++++++++++++ 5 files changed, 60 insertions(+) create mode 100644 tools/binman/etype/ti_sysfw.py create mode 100644 tools/binman/test/232_ti_sysfw.dts
diff --git a/Makefile b/Makefile index 61927f8918..d20d264c53 100644 --- a/Makefile +++ b/Makefile @@ -1345,6 +1345,7 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ -a opensbi-path=${OPENSBI} \ -a default-dt=$(default_dt) \ -a scp-path=$(SCP) \ + -a ti-sysfw-path=$(SYSFW) \ -a spl-bss-pad=$(if $(CONFIG_SPL_SEPARATE_BSS),,1) \ -a tpl-bss-pad=$(if $(CONFIG_TPL_SEPARATE_BSS),,1) \ -a spl-dtb=$(CONFIG_SPL_OF_REAL) \ diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index ae4305c99e..9fc5c48c35 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1203,6 +1203,17 @@ This entry holds firmware for an external platform-specific coprocessor.
+Entry: ti-sysfw: Texas Instruments System Firmware (SYSFW) blob +------------------------------------------------------------ + +Properties / Entry arguments: + - ti-sysfw-path: Filename of file to read into the entry, typically sysfw.bin + +This entry contains system firmware necessary for booting of K3 architecture +devices. + + + Entry: section: Entry that contains other entries -------------------------------------------------
diff --git a/tools/binman/etype/ti_sysfw.py b/tools/binman/etype/ti_sysfw.py new file mode 100644 index 0000000000..5b5b307030 --- /dev/null +++ b/tools/binman/etype/ti_sysfw.py @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Entry type module for TI SYSFW binary blob +# + +import os +import struct +import sys +import zlib + +from binman.etype.blob_named_by_arg import Entry_blob_named_by_arg +from dtoc import fdt_util +from patman import tools + + +class Entry_ti_sysfw(Entry_blob_named_by_arg): + """Entry containing Texas Instruments System Firmware (SYSFW) blob + + Properties / Entry arguments: + - ti-sysfw-path: Filename of file to read into the entry, typically sysfw.bin + + This entry contains system firmware necessary for booting of K3 architecture devices. + """ + + def __init__(self, section, etype, node): + super().__init__(section, etype, node, 'ti-sysfw') + self.external = True diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index b5cf549703..671d083c54 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -87,6 +87,7 @@ ATF_BL31_DATA = b'bl31' TEE_OS_DATA = b'this is some tee OS data' ATF_BL2U_DATA = b'bl2u' OPENSBI_DATA = b'opensbi' +TI_SYSFW_DATA = b'sysfw' SCP_DATA = b'scp' TEST_FDT1_DATA = b'fdt1' TEST_FDT2_DATA = b'test-fdt2' @@ -195,6 +196,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('tee-pager.bin', TEE_OS_DATA) TestFunctional._MakeInputFile('bl2u.bin', ATF_BL2U_DATA) TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) + TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA)
# Add a few .dtb files for testing @@ -5529,6 +5531,11 @@ fdt fdtmap Extract the devicetree blob from the fdtmap """Test an image with a pre-load header with an invalid key""" with self.assertRaises(ValueError) as e: data = self._DoReadFile('231_pre_load_invalid_key.dts') + + def testPackTiSysfw(self): + """Test that an image with a SYSFW binary can be created""" + data = self._DoReadFile('232_ti_sysfw.dts') + self.assertEqual(TI_SYSFW_DATA, data[:len(TI_SYSFW_DATA)])
def _CheckSafeUniqueNames(self, *images): """Check all entries of given images for unsafe unique names""" diff --git a/tools/binman/test/232_ti_sysfw.dts b/tools/binman/test/232_ti_sysfw.dts new file mode 100644 index 0000000000..9e66cbe77b --- /dev/null +++ b/tools/binman/test/232_ti_sysfw.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + binman { + ti-sysfw { + filename = "sysfw.bin"; + }; + }; +};
HS devices do this very differently, even an RFC without HS support doesn't make much sense, this all has to change when you add HS. Please start with that.
Andrew
-a spl-bss-pad=$(if $(CONFIG_SPL_SEPARATE_BSS),,1) \ -a tpl-bss-pad=$(if $(CONFIG_TPL_SEPARATE_BSS),,1) \ -a spl-dtb=$(CONFIG_SPL_OF_REAL) \-a ti-sysfw-path=$(SYSFW) \
- """Entry containing Texas Instruments System Firmware (SYSFW) blob
- Properties / Entry arguments:
- This entry contains system firmware necessary for booting of K3 architecture devices.
- def __init__(self, section, etype, node):
TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA) # Add a few .dtb files for testing
self.assertEqual(TI_SYSFW_DATA, data[:len(TI_SYSFW_DATA)]) def _CheckSafeUniqueNames(self, *images): """Check all entries of given images for unsafe unique names"""
+/dts-v1/;
- #address-cells = <1>;
- #size-cells = <1>;
- binman {
ti-sysfw {
Hi Andrew,
Andrew
Will incorporate the HS changes and introduce the next patch.
diff --git a/Makefile b/Makefile index 61927f8918..d20d264c53 100644 --- a/Makefile +++ b/Makefile @@ -1345,6 +1345,7 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ Â Â Â Â Â Â Â Â Â -a opensbi-path=${OPENSBI} \ Â Â Â Â Â Â Â Â Â -a default-dt=$(default_dt) \ Â Â Â Â Â Â Â Â Â -a scp-path=$(SCP) \ +Â Â Â Â Â Â Â -a ti-sysfw-path=$(SYSFW) \ Â Â Â Â Â Â Â Â Â -a spl-bss-pad=$(if $(CONFIG_SPL_SEPARATE_BSS),,1) \ Â Â Â Â Â Â Â Â Â -a tpl-bss-pad=$(if $(CONFIG_TPL_SEPARATE_BSS),,1) \ Â Â Â Â Â Â Â Â Â -a spl-dtb=$(CONFIG_SPL_OF_REAL) \ diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index ae4305c99e..9fc5c48c35 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1203,6 +1203,17 @@ This entry holds firmware for an external platform-specific coprocessor. +Entry: ti-sysfw: Texas Instruments System Firmware (SYSFW) blob +------------------------------------------------------------
+Properties / Entry arguments: +Â Â Â - ti-sysfw-path: Filename of file to read into the entry, typically sysfw.bin
Entry: section: Entry that contains other entries  ------------------------------------------------- diff --git a/tools/binman/etype/ti_sysfw.py b/tools/binman/etype/ti_sysfw.py new file mode 100644 index 0000000000..5b5b307030 --- /dev/null +++ b/tools/binman/etype/ti_sysfw.py @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Entry type module for TI SYSFW binary blob +#
+class Entry_ti_sysfw(Entry_blob_named_by_arg): +Â Â Â """Entry containing Texas Instruments System Firmware (SYSFW) blob
+Â Â Â Properties / Entry arguments: +Â Â Â Â Â Â Â - ti-sysfw-path: Filename of file to read into the entry, typically sysfw.bin
+Â Â Â This entry contains system firmware necessary for booting of K3 architecture devices. +Â Â Â """
+   def __init__(self, section, etype, node): +       super().__init__(section, etype, node, 'ti-sysfw') +       self.external = True diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index b5cf549703..671d083c54 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -87,6 +87,7 @@ ATF_BL31_DATA        = b'bl31'  TEE_OS_DATA          = b'this is some tee OS data'  ATF_BL2U_DATA        = b'bl2u'  OPENSBI_DATA         = b'opensbi' +TI_SYSFW_DATA        = b'sysfw'  SCP_DATA             = b'scp'  TEST_FDT1_DATA       = b'fdt1'  TEST_FDT2_DATA       = b'test-fdt2' @@ -195,6 +196,7 @@ class TestFunctional(unittest.TestCase):          TestFunctional._MakeInputFile('tee-pager.bin', TEE_OS_DATA)          TestFunctional._MakeInputFile('bl2u.bin', ATF_BL2U_DATA)          TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) +       TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA)          TestFunctional._MakeInputFile('scp.bin', SCP_DATA)          # Add a few .dtb files for testing @@ -5529,6 +5531,11 @@ fdt        fdtmap               Extract the devicetree blob from the fdtmap          """Test an image with a pre-load header with an invalid key"""          with self.assertRaises(ValueError) as e:              data = self._DoReadFile('231_pre_load_invalid_key.dts')
+Â Â Â def testPackTiSysfw(self): +Â Â Â Â Â Â Â """Test that an image with a SYSFW binary can be created""" +Â Â Â Â Â Â Â data = self._DoReadFile('232_ti_sysfw.dts') +Â Â Â Â Â Â Â self.assertEqual(TI_SYSFW_DATA, data[:len(TI_SYSFW_DATA)]) Â Â Â Â Â def _CheckSafeUniqueNames(self, *images): Â Â Â Â Â Â Â Â Â """Check all entries of given images for unsafe unique names""" diff --git a/tools/binman/test/232_ti_sysfw.dts b/tools/binman/test/232_ti_sysfw.dts new file mode 100644 index 0000000000..9e66cbe77b --- /dev/null +++ b/tools/binman/test/232_ti_sysfw.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+
+/dts-v1/;
+/ { +Â Â Â #address-cells = <1>; +Â Â Â #size-cells = <1>; +Â Â Â binman { +Â Â Â Â Â Â Â ti-sysfw { +Â Â Â Â Â Â Â Â Â Â Â filename = "sysfw.bin"; +Â Â Â Â Â Â Â }; +Â Â Â }; +};
Reviewed-by: Alper Nebi Yasak alpernebiyasak@gmail.com
Minor points below.
Regenerate these with `binman entry-docs >tools/binman/entries.rst` for all your new entry types.
Remove unused imports.
- def testPackTiSysfw(self):
Add new tests to the end of the file, renumber the dts files to be unique.
+/dts-v1/;
- binman {
ti-sysfw {
K3 devices introduces the concept of centralized power, resource and security management to System Firmware. This is to overcome challenges by the traditional approach that implements system control functions on each of the processing units.
The software interface for System Firmware is split into TIFS and DM. DM (Device Manager) is responsible for resource and power management from secure and non-secure hosts. This additional binary is necessary for specific platforms' ROM boot images and is to be packaged into tispl.bin
Add an entry for DM. The entry can be used for the packaging of tispl.bin by binman along with ATF and TEE.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- Makefile | 1 + tools/binman/entries.rst | 10 ++++++++++ tools/binman/etype/ti_dm.py | 23 +++++++++++++++++++++++ tools/binman/ftest.py | 7 +++++++ tools/binman/test/225_ti_dm.dts | 13 +++++++++++++ 5 files changed, 54 insertions(+) create mode 100644 tools/binman/etype/ti_dm.py create mode 100644 tools/binman/test/225_ti_dm.dts
diff --git a/Makefile b/Makefile index d20d264c53..9b29e8e6a2 100644 --- a/Makefile +++ b/Makefile @@ -1342,6 +1342,7 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ $(foreach f,$(BINMAN_INDIRS),-I $(f)) \ -a atf-bl31-path=${BL31} \ -a tee-os-path=${TEE} \ + -a ti-dm-path=${DM} \ -a opensbi-path=${OPENSBI} \ -a default-dt=$(default_dt) \ -a scp-path=$(SCP) \ diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index 9fc5c48c35..b6915ef12e 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1214,6 +1214,16 @@ devices.
+Entry: ti-dm: Texas Instruments Device Manager (DM) blob +----------------------------------------------------------------- + +Properties / Entry arguments: + - ti-dm-path: Filename of file to read into the entry, typically dm.bin + +This entry holds the device manager responsible for resource and power management in K3 devices. + + + Entry: section: Entry that contains other entries -------------------------------------------------
diff --git a/tools/binman/etype/ti_dm.py b/tools/binman/etype/ti_dm.py new file mode 100644 index 0000000000..4203fff36e --- /dev/null +++ b/tools/binman/etype/ti_dm.py @@ -0,0 +1,23 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Entry type for TI Device Manager + +import os + +from binman.etype.blob_named_by_arg import Entry_blob_named_by_arg + + +class Entry_ti_dm(Entry_blob_named_by_arg): + """Entry containing a Texas Instruments Device Manager (DM) + + Properties / Entry arguments: + - ti-dm-path: Filename of file to read into the entry, typically dm.bin + + This entry holds the device manager responsible for resource and power management + in K3 devices. + """ + + def __init__(self, section, etype, node): + super().__init__(section, etype, node, 'ti-dm') + self.external = True diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 671d083c54..3709b68297 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -85,6 +85,7 @@ FSP_S_DATA = b'fsp_s' FSP_T_DATA = b'fsp_t' ATF_BL31_DATA = b'bl31' TEE_OS_DATA = b'this is some tee OS data' +TI_DM_DATA = b'tidmtidm' ATF_BL2U_DATA = b'bl2u' OPENSBI_DATA = b'opensbi' TI_SYSFW_DATA = b'sysfw' @@ -194,6 +195,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('compress_big', COMPRESS_DATA_BIG) TestFunctional._MakeInputFile('bl31.bin', ATF_BL31_DATA) TestFunctional._MakeInputFile('tee-pager.bin', TEE_OS_DATA) + TestFunctional._MakeInputFile('dm.bin', TI_DM_DATA) TestFunctional._MakeInputFile('bl2u.bin', ATF_BL2U_DATA) TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA) @@ -5307,6 +5309,11 @@ fdt fdtmap Extract the devicetree blob from the fdtmap data = self._DoReadFile('222_tee_os.dts') self.assertEqual(TEE_OS_DATA, data[:len(TEE_OS_DATA)])
+ def testPackTiDm(self): + """Test that an image with a TI DM binary can be created""" + data = self._DoReadFile('225_ti_dm.dts') + self.assertEqual(TI_DM_DATA, data[:len(TI_DM_DATA)]) + def testFitFdtOper(self): """Check handling of a specified FIT operation""" entry_args = { diff --git a/tools/binman/test/225_ti_dm.dts b/tools/binman/test/225_ti_dm.dts new file mode 100644 index 0000000000..3ab754131e --- /dev/null +++ b/tools/binman/test/225_ti_dm.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + binman { + ti-dm { + filename = "dm.bin"; + }; + }; +};
TIFS (TI Foundational Security), I assume.
Same minor issues as the previous patch.
-a opensbi-path=${OPENSBI} \ -a default-dt=$(default_dt) \ -a scp-path=$(SCP) \-a ti-dm-path=${DM} \
+import os
- """Entry containing a Texas Instruments Device Manager (DM)
- This entry holds the device manager responsible for resource and power management
- in K3 devices.
- def testPackTiDm(self):
- def testFitFdtOper(self): """Check handling of a specified FIT operation""" entry_args = {
+/dts-v1/;
- binman {
ti-dm {
K3 devices requires x509 certificate to be added as header of bootloader binaries that allows ROM to validate the integrity of the image. Etype that generates a TI x509 certificate is added.
Currently this etype is scaled for J721E. For J721E, tiboot3.bin requires the x509 certificate binary to be prepended to the R5 SPL.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- test/py/requirements.txt | 1 + tools/binman/entries.rst | 15 ++ tools/binman/etype/ti_x509_cert.py | 241 ++++++++++++++++++++++++++++ tools/binman/ftest.py | 6 + tools/binman/test/232_x509_cert.dts | 18 +++ 5 files changed, 281 insertions(+) create mode 100644 tools/binman/etype/ti_x509_cert.py create mode 100644 tools/binman/test/232_x509_cert.dts
diff --git a/test/py/requirements.txt b/test/py/requirements.txt index a91ba64563..add264bdaf 100644 --- a/test/py/requirements.txt +++ b/test/py/requirements.txt @@ -11,6 +11,7 @@ packaging==19.2 pbr==5.4.3 pluggy==0.13.0 py==1.10.0 +pycryptodome==3.14.1 pycryptodomex==3.9.8 pyelftools==0.27 pygit2==0.28.2 diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index b6915ef12e..e7757b3e06 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1890,6 +1890,21 @@ and kernel are genuine.
+Entry: ti-x509-cert: Texas Instruments x509 certificate for K3 devices +------------------------------------------------ + +Properties / Entry arguments: + - content: Phandle of binary to sign + - output: Name of the final output file + - key_file: File with key inside it. If not provided, script generates RSA degenerate key + - core: Target core ID on which image would be running + - load: Target load address of the binary in hex + + Output files: + - certificate.bin: Signed certificate binary + + + Entry: x86-reset16: x86 16-bit reset code for U-Boot ----------------------------------------------------
diff --git a/tools/binman/etype/ti_x509_cert.py b/tools/binman/etype/ti_x509_cert.py new file mode 100644 index 0000000000..b79946c0b9 --- /dev/null +++ b/tools/binman/etype/ti_x509_cert.py @@ -0,0 +1,241 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2018 Google, Inc +# Written by Simon Glass sjg@chromium.org +# + +# Support for a TI x509 certificate for signing K3 devices + +from subprocess import Popen, PIPE +from sys import stderr, stdout +import os +import tempfile + +from Crypto.PublicKey import RSA + +from binman.etype.collection import Entry_collection +from dtoc import fdt_util +from patman import tools + + +class Entry_ti_x509_cert(Entry_collection): + """An entry which contains an x509 certificate binary signed with 1024 bit RSA key + + Properties / Entry arguments: + - content: Phandle of binary to generate signature for + - key_file: File with key inside it. If not provided, script generates RSA degenrate key + - core: Target core ID on which image would be running + - load: Target load address of the binary in hex + + Output files: + - certificate.bin: Signed certificate binary""" + + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.key_file = fdt_util.GetString(self._node, 'key-file', "") + self.core = fdt_util.GetInt(self._node, 'core', 0) + self.load_addr = fdt_util.GetInt(self._node, 'load', 0x41c00000) + self.cert = fdt_util.GetString(self._node, 'cert', 'certificate.bin') + + # temporary directory for intermediate files + self.outdir = tempfile.mkdtemp(prefix='binman.x509.') + + def ReadNode(self): + super().ReadNode() + if self.key_file == "": + self.key_int_file = os.path.join(self.outdir, 'eckey.pem') + self.GenerateDegenKey() + else: + self.key_int_file = self.key_file + + def ObtainContents(self): + self.image = self.GetContents(False) + if self.image is None: + return False + self.image_file = os.path.join(self.outdir, 'x509.image') + with open(self.image_file, 'wb') as f: + f.write(self.image) + self.cert_data = self._TICreateCertificateLegacy() + self.SetContents(self.cert_data) + return True + + def ProcessContents(self): + # The blob may have changed due to WriteSymbols() + return super().ProcessContentsUpdate(self.cert_data) + + def _TICreateCertificateLegacy(self): + """Create certificate for legacy boot flow""" + + sha_val = self.GetShaVal(self.image_file) + bin_size = self.GetFileSize(self.image_file) + addr = "%08x" % self.load_addr + if self.core == 16: + self.cert_type = 1 + else: + self.cert_type = 2 + self.debug_type = 0 + self.bootcore_opts = 0 + + self.GenerateTemplate() + self.GenerateCertificate(bin_size, sha_val, addr) + + return tools.read_file(self.cert_file) + + def GetShaVal(self, binary_file): + process = Popen(['openssl', 'dgst', '-sha512', '-hex', + binary_file], stdout=PIPE, stderr=PIPE) + stdout, stderr = process.communicate() + sha_val = stdout.split()[1] + return sha_val + + def GetFileSize(self, binary_file): + return os.path.getsize(binary_file) + + def ParseKey(self, inp_key, section): + parsed_key = "" + section_true = False + with open(inp_key, 'r') as file: + for line in file: + if section in line: + section_true = True + elif section_true: + if " " not in line: + break + else: + parsed_key += line.replace(":", "").replace(" ", "") + return parsed_key.replace("\n", "") + + def GenerateDegenKey(self): + """Generate a 4096 bit RSA key""" + # generates 1024 bit PEM encoded RSA key in PKCS#1 format + private_key = RSA.generate(1024) + self.key_pem_file = os.path.join(self.outdir, 'key.pem') + with open(self.key_pem_file, 'wb') as f: + f.write(private_key.exportKey('PEM')) + + self.key_text_file = os.path.join(self.outdir, 'key.txt') + process = Popen(['openssl', 'rsa', '-in', self.key_pem_file, + '-text', '-out', self.key_text_file], stdout=PIPE, stderr=PIPE) + stdout, stderr = process.communicate() + + DEGEN_MODULUS = self.ParseKey(self.key_text_file, "modulus") + DEGEN_P = self.ParseKey(self.key_text_file, "prime1") + DEGEN_Q = self.ParseKey(self.key_text_file, "prime2") + DEGEN_COEFF = self.ParseKey(self.key_text_file, "coefficient") + + self.GenerateDegenTemplate() + + self.degen_key = os.path.join(self.outdir, 'x509.degenerateKey.txt') + with open(self.degen_temp_file, 'r') as file_input: + with open(self.degen_key, 'w') as file_output: + for line in file_input: + s = line.replace("DEGEN_MODULUS", DEGEN_MODULUS).replace( + "DEGEN_P", DEGEN_P).replace("DEGEN_Q", DEGEN_Q).replace("DEGEN_COEFF", DEGEN_COEFF) + file_output.write(s) + + self.degen_key_der = os.path.join( + self.outdir, 'x509.degenerateKey.der') + process = Popen(['openssl', 'asn1parse', '-genconf', self.degen_key, + '-out', self.degen_key_der], stdout=PIPE, stderr=PIPE) + stdout, stderr = process.communicate() + + process = Popen(['openssl', 'rsa', '-in', self.degen_key_der, + '-inform', 'DER', '-outform', 'PEM', '-out', self.key_int_file]) + stdout, stderr = process.communicate() + + def GenerateCertificate(self, bin_size, sha_val, addr): + self.temp_x509 = os.path.join(self.outdir, 'x509.temp.cert') + self.cert_file = os.path.join(self.outdir, 'x509.certificate.bin') + + temp_dict = {} + temp_dict['TEST_IMAGE_LENGTH'] = str(bin_size) + temp_dict['TEST_IMAGE_SHA_VAL'] = sha_val.decode("utf-8") + temp_dict['TEST_CERT_TYPE'] = str(self.cert_type) + temp_dict['TEST_BOOT_CORE_OPTS'] = str(self.bootcore_opts) + temp_dict['TEST_BOOT_CORE'] = str(self.core) + temp_dict['TEST_BOOT_ADDR'] = str(addr) + temp_dict['TEST_DEBUG_TYPE'] = str(self.debug_type) + + with open(self.temp_x509, "w") as output_file: + with open(self.temp_file, "r") as input_file: + for line in input_file: + l = line + for key in temp_dict: + if key in line: + l = l.replace(key, temp_dict[key]) + output_file.write(l) + + process = Popen(['openssl', 'req', '-new', '-x509', '-key', self.key_int_file, '-nodes', '-outform', + 'DER', '-out', self.cert_file, '-config', self.temp_x509, '-sha512'], stdout=PIPE, stderr=PIPE) + stdout, stderr = process.communicate() + + def GenerateDegenTemplate(self): + self.degen_temp_file = os.path.join(self.outdir, 'x509.degen-template') + with open(self.degen_temp_file, 'w+', encoding='utf-8') as f: + degen_temp = """ +asn1=SEQUENCE:rsa_key + +[rsa_key] +version=INTEGER:0 +modulus=INTEGER:0xDEGEN_MODULUS +pubExp=INTEGER:1 +privExp=INTEGER:1 +p=INTEGER:0xDEGEN_P +q=INTEGER:0xDEGEN_Q +e1=INTEGER:1 +e2=INTEGER:1 +coeff=INTEGER:0xDEGEN_COEFF""" + f.write(degen_temp) + + def GenerateTemplate(self): + self.temp_file = os.path.join(self.outdir, 'x509.template') + with open(self.temp_file, 'w+', encoding='utf-8') as f: + x509template = """ +[ req ] +distinguished_name = req_distinguished_name +x509_extensions = v3_ca +prompt = no +dirstring_type = nobmp + +[ req_distinguished_name ] +C = US +ST = TX +L = Dallas +O = Texas Instruments Incorporated +OU = Processors +CN = TI support +emailAddress = support@ti.com + +[ v3_ca ] +basicConstraints = CA:true +1.3.6.1.4.1.294.1.1 = ASN1:SEQUENCE:boot_seq +1.3.6.1.4.1.294.1.2 = ASN1:SEQUENCE:image_integrity +1.3.6.1.4.1.294.1.3 = ASN1:SEQUENCE:swrv +# 1.3.6.1.4.1.294.1.4 = ASN1:SEQUENCE:encryption +1.3.6.1.4.1.294.1.8 = ASN1:SEQUENCE:debug + +[ boot_seq ] +certType = INTEGER:TEST_CERT_TYPE +bootCore = INTEGER:TEST_BOOT_CORE +bootCoreOpts = INTEGER:TEST_BOOT_CORE_OPTS +destAddr = FORMAT:HEX,OCT:TEST_BOOT_ADDR +imageSize = INTEGER:TEST_IMAGE_LENGTH + +[ image_integrity ] +shaType = OID:2.16.840.1.101.3.4.2.3 +shaValue = FORMAT:HEX,OCT:TEST_IMAGE_SHA_VAL + +[ swrv ] +swrv = INTEGER:0 + +# [ encryption ] +# initalVector = FORMAT:HEX,OCT:TEST_IMAGE_ENC_IV +# randomString = FORMAT:HEX,OCT:TEST_IMAGE_ENC_RS +# iterationCnt = INTEGER:TEST_IMAGE_KEY_DERIVE_INDEX +# salt = FORMAT:HEX,OCT:TEST_IMAGE_KEY_DERIVE_SALT + +[ debug ] +debugUID = FORMAT:HEX,OCT:0000000000000000000000000000000000000000000000000000000000000000 +debugType = INTEGER:TEST_DEBUG_TYPE +coreDbgEn = INTEGER:0 +coreDbgSecEn = INTEGER:0""" + f.write(x509template) diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 3709b68297..70bda9738c 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -96,6 +96,7 @@ ENV_DATA = b'var1=1\nvar2="2"' PRE_LOAD_MAGIC = b'UBSH' PRE_LOAD_VERSION = 0x11223344.to_bytes(4, 'big') PRE_LOAD_HDR_SIZE = 0x00001000.to_bytes(4, 'big') +X509_DATA = b'filetobesigned'
# Subdirectory of the input dir to use to put test FDTs TEST_FDT_SUBDIR = 'fdts' @@ -200,6 +201,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA) + TestFunctional._MakeInputFile('tosign.bin', X509_DATA)
# Add a few .dtb files for testing TestFunctional._MakeInputFile('%s/test-fdt1.dtb' % TEST_FDT_SUBDIR, @@ -5716,6 +5718,10 @@ fdt fdtmap Extract the devicetree blob from the fdtmap dts='234_replace_section_simple.dts') self.assertEqual(new_data, data)
+ def testX509Cert(self): + """Test an image with the default x509 certificate header""" + data = self._DoReadFile('232_x509_cert.dts') + self.assertGreater(len(data), len(X509_DATA))
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/232_x509_cert.dts b/tools/binman/test/232_x509_cert.dts new file mode 100644 index 0000000000..3e68309de5 --- /dev/null +++ b/tools/binman/test/232_x509_cert.dts @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + ti-x509-cert { + content = <&image>; + }; + + image: blob-ext { + filename = "tosign.bin"; + }; + }; +};
You don't need this if you use Cryptodome instead of Crypto. It's the same thing as pycryptodomex below.
- Output files:
Anything you want to run should normally be a bintool that provides a pythonic wrapper for it, see tools/binman/btool for examples. But if that's too much, openssl calls must at least use the patman.command functions instead.
Don't mess with stderr, stdout. See tools/patman/command for things you can use to run commands and capture their output.
Prefer Cryptodome instead.
- """An entry which contains an x509 certificate binary signed with 1024 bit RSA key
- Output files:
These should actually be in ReadNode(). You should set things to None-like values here to show which attributes will exist, and also do it for attributes set later in other methods.
This looks unused.
For now, omit this and put the outputs in the build directory. See below for an example. (We should eventually reorganize intermediate files, but it should be done by generic helpers that all entries can use).
- def ReadNode(self):
super().ReadNode()
else:
ReadNode() should only copy the device-tree values to the entry object, it shouldn't generate the key here.
- def ObtainContents(self):
return False
f.write(self.image)
Prepare intermediate files like:
uniq = self.GetUniqueName() image_fname = tools.get_output_filename(f'{uniq}.x509-image') tools.write_file(image_fname, data)
Also, better do this in _TICreateCertificateLegacy() because you have to do it in ProcessContents() as well.
return True
- def ProcessContents(self):
You need to read the data again and recreate the certificate here, because the signed data (like u-boot-spl) might have changed, which would make the cert invalid.
- def _TICreateCertificateLegacy(self):
Can be f"{self.load_addr:08x}".
if self.core == 16:
self.cert_type = 1
else:
self.cert_type = 2
self.debug_type = 0
Looks like this doesn't handle the '# Non BOOTCORE, loaded by SYSFW' case in k3_gen_x509_cert.sh.
- def GetShaVal(self, binary_file):
return sha_val
This can be something like `hashlib.sha512(data).hexdigest()`, or something with Cryptodome.Hash.SHA512.
- def GetFileSize(self, binary_file):
No need for an extra function for this, and maybe even for the hash.
- def ParseKey(self, inp_key, section):
parsed_key = ""
for line in file:
if section in line:
section_true = True
elif section_true:
if " " not in line:
break
else:
Better to use Cryptodome for parsing key information. I see there is a Cryptodome.PublicKey.RSA.import_key() if you need to read a provided key, but the values are already there for the degenerate key generated below.
- def GenerateDegenKey(self):
These should be derived from private_key.{n,p,q,u}. I guess f"{private_key.n:x}" and so on should work?
I tried a bit, and looks like pycryptodome and openssl disagree on the coefficient definition, but I can get what openssl gives by switching the p and q like `RSA.construct((n, e, d, q, p)).u`
It would be easier to fill the template in Python with str.format(), something like:
DEGENERATE_KEY_TEMPLATE = """\ asn1=SEQUENCE:rsa_key
[rsa_key] version=INTEGER:0 modulus=INTEGER:0x{modulus:x} pubExp=INTEGER:1 privExp=INTEGER:1 p=INTEGER:0x{p:x} q=INTEGER:0x{q:x} e1=INTEGER:1 e2=INTEGER:1 coeff=INTEGER:0x{coeff:x} """
coeff = RSA.construct(( private_key.n, private_key.e, private_key.d, private_key.q, private_key.p, )).u
degen_conf = DEGENERATE_KEY_TEMPLATE.format( modulus=private_key.n, p=private_key.p, q=private_key.q, coeff=coeff, )
- def GenerateCertificate(self, bin_size, sha_val, addr):
temp_dict = {}
A literal dict looks better here:
temp_dict = { 'TEST_IMAGE_LENGTH': str(bin_size), ... }
l = line
if key in line:
But again, this would be easier with str.format():
X509_TEMPLATE = """\ [...]
[ boot_seq ] certType = INTEGER:{certType} bootCore = INTEGER:{bootCore} bootCoreOpts = INTEGER:{bootCoreOpts} destAddr = FORMAT:HEX,OCT:{destAddr:08x} imageSize = INTEGER:{imageSize}
x509_config = X509_TEMPLATE.format( ... 'certType': self.cert_type, 'bootCoreOpts': self.bootcore_opts, 'bootCore': self.core, 'destAddr': addr, ... )
Read the cert file here and return its bytes, instead of leaving it to _TICreateCertificateLegacy().
In general I think creating fewer files and limiting their scopes to as small as possible is better.
- def GenerateDegenTemplate(self):
degen_temp = """
f.write(degen_temp)
- def GenerateTemplate(self):
x509template = """
I think these templates would be better as top-level constants.
TestFunctional._MakeInputFile('tosign.bin', X509_DATA) # Add a few .dtb files for testing TestFunctional._MakeInputFile('%s/test-fdt1.dtb' % TEST_FDT_SUBDIR,
- def testX509Cert(self):
If you used a bintool, you could do something like _HandleVblockCommand to capture the openssl calls, create a mock file as the output certificate, and check that here.
+/dts-v1/;
- binman {
ti-x509-cert {
content = <&image>;
image: blob-ext {
For devices that require sysfw.itb, board config binary artifacts must be populated in the R5 output directory. These can be used by binman to package sysfw.itb.
config.mk for mach-k3 updated to generate the required binaries using tibcfg_gen.py.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/mach-k3/config.mk | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index da458bcfb2..ed605adf39 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -28,6 +28,24 @@ else KEY=$(patsubst "%",$(srctree)/%,$(CONFIG_SYS_K3_KEY)) endif
+# Board config binary artifacts necessary for packaging of tiboot3.bin +# and sysfw.itb by binman, currently for general purpose devices and +# devices that require sysfw.itb in ROM boot image. Currently set up +# for J721E +ifeq ($(CONFIG_TARGET_J721E_R5_EVM),y) +ifneq ($(CONFIG_TI_SECURE_DEVICE),y) + +CONFIG_YAML = $(srctree)/board/ti/$(BOARD)/config.yaml +SCHEMA_YAML = $(srctree)/board/ti/common/schema.yaml +board-cfg.bin pm-cfg.bin rm-cfg.bin sec-cfg.bin: + $(PYTHON3) $(srctree)/tools/tibcfg_gen.py -c $(CONFIG_YAML) -s $(SCHEMA_YAML) -o $(O) +INPUTS-y += board-cfg.bin +INPUTS-y += pm-cfg.bin +INPUTS-y += rm-cfg.bin +INPUTS-y += sec-cfg.bin +endif +endif + # tiboot3.bin is mandated by ROM and ROM only supports R5 boot. # So restrict tiboot3.bin creation for CPU_V7R. ifdef CONFIG_CPU_V7R
Intention of patch is to move the signing and packaging of tiboot3.bin image for J721E to binman. So patch excludes tiboot3.bin target for J721E.
The functionality of tools/k3_gen_x509_cert.sh has been replicated in binman with the etype x509_cert. This can be used for J721E by binman.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/mach-k3/config.mk | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index ed605adf39..d706d17788 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -46,6 +46,7 @@ INPUTS-y += sec-cfg.bin endif endif
+ifneq ($(CONFIG_TARGET_J721E_R5_EVM), y) # tiboot3.bin is mandated by ROM and ROM only supports R5 boot. # So restrict tiboot3.bin creation for CPU_V7R. ifdef CONFIG_CPU_V7R @@ -65,6 +66,8 @@ tiboot3.bin: image_check FORCE INPUTS-y += tiboot3.bin endif
+endif + ifdef CONFIG_ARM64
ifeq ($(CONFIG_SOC_K3_J721E),)
tispl.bin is to be packaged (with ATF, OPTEE, DM and A72 SPL) using binman. The tispl.bin target from the makefile is no longer needed for J721E.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/mach-k3/config.mk | 5 +++++ scripts/Makefile.spl | 2 ++ 2 files changed, 7 insertions(+)
diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index d706d17788..dd5e42d9df 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -74,6 +74,7 @@ ifeq ($(CONFIG_SOC_K3_J721E),) export DM := /dev/null endif
+ifndef CONFIG_TARGET_J721E_A72_EVM ifeq ($(CONFIG_TI_SECURE_DEVICE),y) SPL_ITS := u-boot-spl-k3_HS.its $(SPL_ITS): export IS_HS=1 @@ -98,9 +99,11 @@ cmd_k3_mkits = \ $(SPL_ITS): FORCE $(call cmd,k3_mkits) endif +endif
else
+ifndef CONFIG_TARGET_J721E_A72_EVM ifeq ($(CONFIG_TI_SECURE_DEVICE),y) INPUTS-y += u-boot.img_HS else @@ -108,4 +111,6 @@ INPUTS-y += u-boot.img endif endif
+endif + include $(srctree)/arch/arm/mach-k3/config_secure.mk diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index f047d4e094..6104cb8587 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -591,6 +591,8 @@ $(obj)/$(SPL_BIN).multidtb.fit.lzo: $(obj)/$(SPL_BIN).multidtb.fit @lzop -f9 $< > $@
ifdef CONFIG_ARCH_K3 +ifndef CONFIG_TARGET_J721E_A72_EVM tispl.bin: $(obj)/u-boot-spl-nodtb.bin $(SHRUNK_ARCH_DTB) $(SPL_ITS) FORCE $(call if_changed,mkfitimage) endif +endif
Hi Neha,
How about using #ifndef CONFIG_BINMAN instead? Any platform enabling that doesn't want to use the old way.
You are still breaking HS functionality with this series correct? That will have to be fixed.
One proposal was discussed here https://lore.kernel.org/all/76474ded-a782-f491-eac6-ece3c5f4a7da@gmail.com/
We should be able to produce tispl.bin_HS and u-boot.img_HS via binman.
You have already covered most of the x509 stuff image in ti-x509-cert etype. Please refer to below script [1] to know what is required to get _HS images.
[1] https://git.ti.com/cgit/security-development-tools/core-secdev-k3/tree/scrip...
else
+endif
You will have to enclose below line in #ifndef CONFIG_BINMAN as well.
Is this still being called in-spite of the changes to config.mk? Please use CONFIG_BINMAN instead of CONFIG_TARGET_J721E_A72_EVM
cheers, -roger
Hi Roger,
On 15/06/22 19:14, Roger Quadros wrote:
Hi Neha,
Yes, this patch was intended for GP only but like Andrew said, will have to do HS as well. I'll build on this patch for HS devices.
else
+endif
Will make the changes.
I will make the changes.
cheers, -roger
By providing entries in the binman node of the device tree, binman will be able to find and package board config binary artifacts generated by TIBoardConfig with sysfw.bin and generate the final image sysfw.itb.
k3-j721e-r5-binman.dtsi has been introduced for R5 specific binman node. It can be then be include by files that require it like k3-j721e-r5-common-proc-board-u-boot.dtsi.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: prepared patch for upstreaming] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-j721e-r5-binman.dtsi | 88 +++++++++++++++++++ .../k3-j721e-r5-common-proc-board-u-boot.dtsi | 1 + board/ti/j721e/Kconfig | 1 + 3 files changed, 90 insertions(+) create mode 100644 arch/arm/dts/k3-j721e-r5-binman.dtsi
diff --git a/arch/arm/dts/k3-j721e-r5-binman.dtsi b/arch/arm/dts/k3-j721e-r5-binman.dtsi new file mode 100644 index 0000000000..e3aeefb08f --- /dev/null +++ b/arch/arm/dts/k3-j721e-r5-binman.dtsi @@ -0,0 +1,88 @@ +// SPDX-License-Identifier: GPL-2.0+ +// Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + +#include <config.h> + +/ { + binman: binman { + multiple-images; + }; +}; + +&binman { + tiboot3 { + filename = "tiboot3.bin"; + ti-x509-cert { + content = <&image1>; + core = <16>; + load = <CONFIG_SPL_TEXT_BASE>; + }; + image1: u-boot-spl { + no-expanded; + }; + }; + binary { + filename = "sysfw.bin"; + ti-x509-cert { + content = <&image2>; + core = <0>; + load = <0x0040000>; + }; + image2: ti-sysfw { + }; + }; + itb { + filename = "sysfw.itb"; + fit { + description = "SYSFW and Config Fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob { + filename = "sysfw.bin"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "board-cfg.bin"; + }; + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "pm-cfg.bin"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "rm-cfg.bin"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sec-cfg.bin"; + }; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi index 48c6ddf672..75ec722e89 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include "k3-j721e-common-proc-board-u-boot.dtsi" +#include "k3-j721e-r5-binman.dtsi"
/ { chosen { diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index c28752a658..a3a9d504ae 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -24,6 +24,7 @@ config TARGET_J721E_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
- binman: binman {
multiple-images;
+&binman {
- tiboot3 {
ti-x509-cert {
core = <16>;
no-expanded;
Please put empty lines between properties and nodes, and between each node. Labels could be u_boot_spl, ti_sysfw instead of image1/2.
- binary {
ti-x509-cert {
core = <0>;
load = <0x0040000>;
image2: ti-sysfw {
- itb {
fit {
images {
sysfw.bin {
type = "firmware";
arch = "arm";
blob {
I dislike having the meaningless 'blob' and 'blob-ext' as node names. Having the extension doesn't make much sense to me for the FIT entry, but I like it for the blob itself:
sysfw { description = "sysfw"; type = "firmware"; arch = "arm"; compression = "none";
sysfw.bin { filename = "sysfw.bin"; type = "blob"; }; };
board-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
pm-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
rm-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
sec-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
- select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
tispl.bin must be packaged (with ATF, OPTEE, DM and A72 SPL) for J721E. Binman picks up and packages entries according to the description given in the device tree.
k3-j721e-a72-binman.dtsi has been introduced for A72 specific binman node. It is included by k3-j721e-common-proc-board-u-boot.dtsi
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-j721e-a72-binman.dtsi | 86 +++++++++++++++++++ .../k3-j721e-common-proc-board-u-boot.dtsi | 1 + board/ti/j721e/Kconfig | 1 + 3 files changed, 88 insertions(+) create mode 100644 arch/arm/dts/k3-j721e-a72-binman.dtsi
diff --git a/arch/arm/dts/k3-j721e-a72-binman.dtsi b/arch/arm/dts/k3-j721e-a72-binman.dtsi new file mode 100644 index 0000000000..beb3424bb9 --- /dev/null +++ b/arch/arm/dts/k3-j721e-a72-binman.dtsi @@ -0,0 +1,86 @@ +// SPDX-License-Identifier: GPL-2.0+ +// Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + +#include <config.h> + +#ifdef CONFIG_ARM64 +/ { + binman: binman { + multiple-images; + }; +}; + +&binman { + tispl { + filename = "tispl.bin"; + fit { + description = "FIT IMAGE"; + #address-cells = <1>; + images { + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + ti-dm { + }; + }; + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + u-boot-spl-nodtb { + }; + }; + k3-j721e-common-proc-board.dtb { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "spl/dts/k3-j721e-common-proc-board.dtb"; + }; + }; + }; + configurations { + default = "conf"; + conf { + description = "k3-j721e-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "k3-j721e-common-proc-board.dtb"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index 677a72d2a2..6490d71f7e 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include <dt-bindings/net/ti-dp83867.h> +#include "k3-j721e-a72-binman.dtsi"
/ { chosen { diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index a3a9d504ae..3cf05f0d3b 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -14,6 +14,7 @@ config TARGET_J721E_A72_EVM select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS + select BINMAN
config TARGET_J721E_R5_EVM bool "TI K3 based J721E EVM running on R5"
Neha,
Will this file be used for all j721e-a72 boards or only common processor board? It should be named accordingly.
You might as well combine the separate r5 and a72 binman files into one file. You can use CONFIG_TARGET_J721E_R5_EVM and CONFIG_TARGET_J721E_A72_EVM to selectively enable the required entries.
So, k3-j721e-common-proc-board-binman.dtsi?
- binman: binman {
multiple-images;
#ifdef CONFIG_TARGET_J721E_A72_EVM
+&binman {
- tispl {
fit {
This used to be "Configuration to load ATF and SPL", let's retain the description.
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
ti-dm {
spl {
os = "U-Boot";
arch = "arm64";
u-boot-spl-nodtb {
type = "flat_dt";
arch = "arm";
blob-ext {
configurations {
default = "conf";
"conf-1"? more confs can be added later
conf {
firmware = "atf";
+}; +#endif
what about u-boot.img?
you need a binman entry for that else it won't be generated right?
- select BINMAN
cheers, -roger
- binman: binman {
multiple-images;
+&binman {
- tispl {
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
ti-dm {
spl {
os = "U-Boot";
arch = "arm64";
u-boot-spl-nodtb {
how about fdt-1 for node name?
type = "flat_dt";
arch = "arm";
blob-ext {
configurations {
default = "conf";
conf {
firmware = "atf";
- select BINMAN
cheers, -roger
- binman: binman {
multiple-images;
+&binman {
- tispl {
Empty lines for this file as well.
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
ti-dm {
spl {
os = "U-Boot";
arch = "arm64";
u-boot-spl-nodtb {
type = "flat_dt";
arch = "arm";
blob-ext {
Indentation here, but it could be a u-boot-spl-dtb entry instead. Or, there's a @fdt-SEQ mechanism to include files based on CONFIG_OF_LIST, which you might want to look at.
configurations {
default = "conf";
conf {
firmware = "atf";
- select BINMAN
To avoid ModuleNotFoundErrors during World Build in CI tests, add installation of test/py/requirements.txt to .azure-pipelines.yml
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- .azure-pipelines.yml | 1 + 1 file changed, 1 insertion(+)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index ad540ea635..0fd57f59f4 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -551,6 +551,7 @@ stages: EOF cat << "EOF" >> build.sh if [[ "${BUILDMAN}" != "" ]]; then + pip install -r test/py/requirements.txt ret=0; tools/buildman/buildman -o /tmp -P -E -W ${BUILDMAN} ${OVERRIDE} || ret=$?; if [[ $ret -ne 0 ]]; then
Neha Malcom Francis (11): j721e_evm: schema: yaml: Add general schema and J721E board config files ti: tools: config: Add board config class to generate config binaries
ti: etype: sysfw: Add entry type for sysfw ti: etype: dm: Add entry type for TI DM ti: etype: x509: Add etype for x509 certificate for K3 devices
These three would be better as 'binman: ...", sorry for not being clear about that.
ti: sysfw: Add support for packaging sysfw.itb ti: j721e: Exclude makefile tiboot3.bin target for J721E ti: j721e: Exclude makefile tispl.bin target for J721E ti: dtsi: j721e: Use binman to package sysfw.itb and tiboot3.bin ti: dtsi: j721e: Use binman to package tispl.bin ci: world_build: test: Add requirements.txt
Alper Nebi Yasak
Andrew Davis
Neha Malcom Francis
Roger Quadros
