Re: [U-Boot-Users] u-boot compilation
Robert Schwebel robert@schwebel.de schrieb am 06.11.02 10:03:44:
On Wed, Nov 06, 2002 at 09:23:52AM +0100, Marius Gröger wrote:
What do you mean here - what else than stage 1 can a cross compiler be?!
Normally when you build a toolchain you first have to build a compiler which is able to work without glibc headers (needs only to have C support). Then you use it to build glibc and afterwards you recompile your compiler with glibc support and whatever languages you need.
Gotcha... I thought you were referring to gcc's terminology of "stages". There, anything higher thant stage 1 is compiled by itself which obviously won't work cross.
What you call stage1 is sometimes (and in Elinos, too) called a "bootstrap gcc".
However: u-boot should be compilable with such a bootstrap gcc, as it should not be dependent on glibc. (It is bad enogh for it to be so dependent on several Linux headers, but that is a compromise to be able to reuse code from Linux - we had that before).
Regards, Marius.
________________________________________________________________ Keine verlorenen Lotto-Quittungen, keine vergessenen Gewinne mehr! Beim WEB.DE Lottoservice: http://tippen2.web.de/?x=13
Marius Gröger
