[U-Boot] [PATCH v4 0/3] Amlogic Meson GXBaby and ODROID-C2 support
this series adds a very basic support for Amlogic S905 SoC (GXBaby) and for the ODROID-C2 board [1], and is based on u-boot sources available from the board vendor [2]. At the moment the only supported devices are the integrated UART and Ethernet adapter.
Changes since v3: - designware eth: added check that buffer addresses are in first 4GiB as suggested by Marek (and thus removed the ack tags) - consolidated pinmux and gpio macros - used get_unaligned_be64() to avoid alignment faults in dram_init() - uint32_t -> u32 in serial_meson.c - implemented reboot and read from e-fuse through secure monitor
Changes since v2: - squashed all platform patches into a single one - got rid of additional non-upstream DTS node for ethernet - improved board README - added macros for SoC registers fields
Changes since v1: - updated DTS files from Linux kernel - added Ethernet support - first 16MiB of RAM are now marked as unavailable; this seems to be required to successfully boot Linux - fixed typo in config file
[1] http://www.hardkernel.com/main/products/prdt_info.php?g_code=G145457216438 [2] https://github.com/hardkernel/u-boot/tree/odroidc2-v2015.01
Beniamino Galvani (3): net: designware: fix descriptor layout and warnings on 64-bit archs arm: add initial support for Amlogic Meson and ODROID-C2 arm: meson: implement calls to secure monitor
arch/arm/Kconfig | 5 + arch/arm/Makefile | 1 + arch/arm/dts/Makefile | 2 + arch/arm/dts/meson-gxbb-odroidc2.dts | 69 +++++++++++++ arch/arm/dts/meson-gxbb.dtsi | 178 +++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-meson/gxbb.h | 52 ++++++++++ arch/arm/include/asm/arch-meson/sm.h | 13 +++ arch/arm/mach-meson/Kconfig | 31 ++++++ arch/arm/mach-meson/Makefile | 7 ++ arch/arm/mach-meson/board.c | 67 +++++++++++++ arch/arm/mach-meson/sm.c | 71 +++++++++++++ board/hardkernel/odroid-c2/Kconfig | 12 +++ board/hardkernel/odroid-c2/MAINTAINERS | 6 ++ board/hardkernel/odroid-c2/Makefile | 7 ++ board/hardkernel/odroid-c2/README | 60 +++++++++++ board/hardkernel/odroid-c2/odroid-c2.c | 67 +++++++++++++ configs/odroid-c2_defconfig | 23 +++++ drivers/net/designware.c | 59 ++++++----- drivers/net/designware.h | 4 +- drivers/serial/Kconfig | 15 +++ drivers/serial/Makefile | 1 + drivers/serial/serial_meson.c | 162 ++++++++++++++++++++++++++++++ include/configs/odroid-c2.h | 55 ++++++++++ 23 files changed, 938 insertions(+), 29 deletions(-) create mode 100644 arch/arm/dts/meson-gxbb-odroidc2.dts create mode 100644 arch/arm/dts/meson-gxbb.dtsi create mode 100644 arch/arm/include/asm/arch-meson/gxbb.h create mode 100644 arch/arm/include/asm/arch-meson/sm.h create mode 100644 arch/arm/mach-meson/Kconfig create mode 100644 arch/arm/mach-meson/Makefile create mode 100644 arch/arm/mach-meson/board.c create mode 100644 arch/arm/mach-meson/sm.c create mode 100644 board/hardkernel/odroid-c2/Kconfig create mode 100644 board/hardkernel/odroid-c2/MAINTAINERS create mode 100644 board/hardkernel/odroid-c2/Makefile create mode 100644 board/hardkernel/odroid-c2/README create mode 100644 board/hardkernel/odroid-c2/odroid-c2.c create mode 100644 configs/odroid-c2_defconfig create mode 100644 drivers/serial/serial_meson.c create mode 100644 include/configs/odroid-c2.h
All members of the DMA descriptor must be 32-bit, even on 64-bit architectures: change the type to u32 to ensure this. Also, fix other warnings.
Signed-off-by: Beniamino Galvani b.galvani@gmail.com --- drivers/net/designware.c | 59 ++++++++++++++++++++++++++---------------------- drivers/net/designware.h | 4 ++-- 2 files changed, 34 insertions(+), 29 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index ca58f34..2eda461 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -98,8 +98,8 @@ static void tx_descs_init(struct dw_eth_dev *priv)
for (idx = 0; idx < CONFIG_TX_DESCR_NUM; idx++) { desc_p = &desc_table_p[idx]; - desc_p->dmamac_addr = &txbuffs[idx * CONFIG_ETH_BUFSIZE]; - desc_p->dmamac_next = &desc_table_p[idx + 1]; + desc_p->dmamac_addr = (ulong)&txbuffs[idx * CONFIG_ETH_BUFSIZE]; + desc_p->dmamac_next = (ulong)&desc_table_p[idx + 1];
#if defined(CONFIG_DW_ALTDESCRIPTOR) desc_p->txrx_status &= ~(DESC_TXSTS_TXINT | DESC_TXSTS_TXLAST | @@ -117,11 +117,11 @@ static void tx_descs_init(struct dw_eth_dev *priv) }
/* Correcting the last pointer of the chain */ - desc_p->dmamac_next = &desc_table_p[0]; + desc_p->dmamac_next = (ulong)&desc_table_p[0];
/* Flush all Tx buffer descriptors at once */ - flush_dcache_range((unsigned int)priv->tx_mac_descrtable, - (unsigned int)priv->tx_mac_descrtable + + flush_dcache_range((ulong)priv->tx_mac_descrtable, + (ulong)priv->tx_mac_descrtable + sizeof(priv->tx_mac_descrtable));
writel((ulong)&desc_table_p[0], &dma_p->txdesclistaddr); @@ -142,13 +142,12 @@ static void rx_descs_init(struct dw_eth_dev *priv) * Otherwise there's a chance to get some of them flushed in RAM when * GMAC is already pushing data to RAM via DMA. This way incoming from * GMAC data will be corrupted. */ - flush_dcache_range((unsigned int)rxbuffs, (unsigned int)rxbuffs + - RX_TOTAL_BUFSIZE); + flush_dcache_range((ulong)rxbuffs, (ulong)rxbuffs + RX_TOTAL_BUFSIZE);
for (idx = 0; idx < CONFIG_RX_DESCR_NUM; idx++) { desc_p = &desc_table_p[idx]; - desc_p->dmamac_addr = &rxbuffs[idx * CONFIG_ETH_BUFSIZE]; - desc_p->dmamac_next = &desc_table_p[idx + 1]; + desc_p->dmamac_addr = (ulong)&rxbuffs[idx * CONFIG_ETH_BUFSIZE]; + desc_p->dmamac_next = (ulong)&desc_table_p[idx + 1];
desc_p->dmamac_cntl = (MAC_MAX_FRAME_SZ & DESC_RXCTRL_SIZE1MASK) | @@ -158,11 +157,11 @@ static void rx_descs_init(struct dw_eth_dev *priv) }
/* Flush all Rx buffer descriptors at once */ - flush_dcache_range((unsigned int)priv->rx_mac_descrtable, - (unsigned int)priv->rx_mac_descrtable + + flush_dcache_range((ulong)priv->rx_mac_descrtable, + (ulong)priv->rx_mac_descrtable + sizeof(priv->rx_mac_descrtable));
writel((ulong)&desc_table_p[0], &dma_p->rxdesclistaddr); @@ -290,12 +289,11 @@ static int _dw_eth_send(struct dw_eth_dev *priv, void *packet, int length) struct eth_dma_regs *dma_p = priv->dma_regs_p; u32 desc_num = priv->tx_currdescnum; struct dmamacdescr *desc_p = &priv->tx_mac_descrtable[desc_num]; - uint32_t desc_start = (uint32_t)desc_p; - uint32_t desc_end = desc_start + + ulong desc_start = (ulong)desc_p; + ulong desc_end = desc_start + roundup(sizeof(*desc_p), ARCH_DMA_MINALIGN); - uint32_t data_start = (uint32_t)desc_p->dmamac_addr; - uint32_t data_end = data_start + - roundup(length, ARCH_DMA_MINALIGN); + ulong data_start = desc_p->dmamac_addr; + ulong data_end = data_start + roundup(length, ARCH_DMA_MINALIGN); /* * Strictly we only need to invalidate the "txrx_status" field * for the following check, but on some platforms we cannot @@ -312,7 +310,7 @@ static int _dw_eth_send(struct dw_eth_dev *priv, void *packet, int length) return -EPERM; }
- memcpy(desc_p->dmamac_addr, packet, length); + memcpy((void *)data_start, packet, length);
/* Flush data to be sent */ flush_dcache_range(data_start, data_end); @@ -352,11 +350,11 @@ static int _dw_eth_recv(struct dw_eth_dev *priv, uchar **packetp) u32 status, desc_num = priv->rx_currdescnum; struct dmamacdescr *desc_p = &priv->rx_mac_descrtable[desc_num]; int length = -EAGAIN; - uint32_t desc_start = (uint32_t)desc_p; - uint32_t desc_end = desc_start + + ulong desc_start = (ulong)desc_p; + ulong desc_end = desc_start + roundup(sizeof(*desc_p), ARCH_DMA_MINALIGN); - uint32_t data_start = (uint32_t)desc_p->dmamac_addr; - uint32_t data_end; + ulong data_start = desc_p->dmamac_addr; + ulong data_end;
/* Invalidate entire buffer descriptor */ invalidate_dcache_range(desc_start, desc_end); @@ -372,7 +370,7 @@ static int _dw_eth_recv(struct dw_eth_dev *priv, uchar **packetp) /* Invalidate received data */ data_end = data_start + roundup(length, ARCH_DMA_MINALIGN); invalidate_dcache_range(data_start, data_end); - *packetp = desc_p->dmamac_addr; + *packetp = (uchar *)(ulong)desc_p->dmamac_addr; }
return length; @@ -382,8 +380,8 @@ static int _dw_free_pkt(struct dw_eth_dev *priv) { u32 desc_num = priv->rx_currdescnum; struct dmamacdescr *desc_p = &priv->rx_mac_descrtable[desc_num]; - uint32_t desc_start = (uint32_t)desc_p; - uint32_t desc_end = desc_start + + ulong desc_start = (ulong)desc_p; + ulong desc_end = desc_start + roundup(sizeof(*desc_p), ARCH_DMA_MINALIGN);
/* @@ -488,6 +486,11 @@ int designware_initialize(ulong base_addr, u32 interface) return -ENOMEM; }
+ if ((unsigned long long)priv + sizeof(*priv) > (1ULL << 32)) { + printf("designware: buffers are outside DMA memory\n"); + return -EINVAL; + } + memset(dev, 0, sizeof(struct eth_device)); memset(priv, 0, sizeof(struct dw_eth_dev));
@@ -583,6 +586,7 @@ static int designware_eth_probe(struct udevice *dev) struct eth_pdata *pdata = dev_get_platdata(dev); struct dw_eth_dev *priv = dev_get_priv(dev); u32 iobase = pdata->iobase; + ulong ioaddr; int ret;
#ifdef CONFIG_DM_PCI @@ -601,8 +605,9 @@ static int designware_eth_probe(struct udevice *dev) #endif
debug("%s, iobase=%x, priv=%p\n", __func__, iobase, priv); - priv->mac_regs_p = (struct eth_mac_regs *)iobase; - priv->dma_regs_p = (struct eth_dma_regs *)(iobase + DW_DMA_BASE_OFFSET); + ioaddr = iobase; + priv->mac_regs_p = (struct eth_mac_regs *)ioaddr; + priv->dma_regs_p = (struct eth_dma_regs *)(ioaddr + DW_DMA_BASE_OFFSET); priv->interface = pdata->phy_interface; priv->max_speed = pdata->max_speed;
diff --git a/drivers/net/designware.h b/drivers/net/designware.h index ed6344c..d48df7b 100644 --- a/drivers/net/designware.h +++ b/drivers/net/designware.h @@ -110,8 +110,8 @@ struct eth_dma_regs { struct dmamacdescr { u32 txrx_status; u32 dmamac_cntl; - void *dmamac_addr; - struct dmamacdescr *dmamac_next; + u32 dmamac_addr; + u32 dmamac_next; } __aligned(ARCH_DMA_MINALIGN);
Why don't you use u32 instead of ulong ? The u32 is well defined. DTTO all over the place.
btw just curious, but what will happen if the descriptors get allocated in area above 4GiB ? Will the code silently corrupt memory by discarding the top bits in the descriptor pointer?
- u32 dmamac_addr;
- u32 dmamac_next;
&txbuffs[idx * CONFIG_ETH_BUFSIZE] is a pointer (and hence has the size of a ulong) and casting it to u32 would give a warning on 64 bit archs ("cast from pointer to integer of different size").
No, if the driver private structure (which contains buffers and descriptors) is above 4GiB, designware_initialize() will complain and return an error.
Beniamino
Will cast to uintptr_t and then to u32 help ?
It's just a feeling, but casting to ulong just to circumvent compiler warning does not sound right.
Which code checks that ?
Beniamino
Note that uintptr_t is defined as ulong and the second cast to u32 is not needed because C does not require casts between arithmetic types. So I don't see much difference.
It seems fine to me, the (ulong) is needed to cast the pointer to an arithmetic type of equivalent size which then can be assigned to an u32 variable.
Beniamino
return -EINVAL;
Hmm, this is going to get very interesting with efi_loader support. By default we allocate memory at the highest possible free address, so payloads will probably (unless they specify limits) have their buffers above 32bit on this platform. If we now deny any DMA to them, we basically break I/O access.
Could you by any chance just use a bounce buffer?
Alex
I'm not familiar with efi_loader, but on this platform the physical RAM is within the 32bit memory range, so I don't think a workaround is needed. And I guess probably it's the same for the other 64bit ARM SoC using this driver.
BTW, I see that another driver (sunxi_mmc) also truncates the upper 32 bits of addresses on 64bit platforms. Maybe this issue should be addresses in a generic way?
Do you have any suggestions on how to do it? Are there any primitives in u-boot to request memory from low addresses?
Beniamino
So if RAM is always within the lower 32bits, then we don't have a problem.
The only 64bit sunxi platform (A64) also only has 32bit physical RAM addresses.
Thinking about this I don't think we have the memory reservation logistics to maintain a good bounce buffer. You could create a global array in bss that you read to / write from, but I'm not sure it's really worth it.
At the end of the day, if you know that your platform can only ever do 32bit DMA to a physical address range that's only 32bits, it's perfectly ok IMHO.
We only have a problem if you have a platform that has RAM above 4G and can only do DMA to 32bit addresses.
Alex
On Mon, Apr 18, 2016 at 5:57 AM, Beniamino Galvani b.galvani@gmail.com wrote:
Sorry, didn't notice that you already had this conversation in a previous version.
return -EINVAL;
Beniamino _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Am 17.04.2016 um 09:48 schrieb Beniamino Galvani:
- if ((unsigned long long)priv + sizeof(*priv) > (1ULL << 32)) {
Regards, Andreas
return -EINVAL;
- memset(dev, 0, sizeof(struct eth_device)); memset(priv, 0, sizeof(struct dw_eth_dev));
[snip]
I think ">" is correct, the (unfortunate) case
priv + size == (1 << 32)
is still acceptable because the last byte used by the structure would be (priv + size - 1).
Beniamino
This adds platform code for the Amlogic Meson GXBaby (S905) SoC and a board definition for ODROID-C2. This initial submission only supports UART and Ethernet (through the existing Designware driver). DTS files are the ones submitted to Linux arm-soc for 4.7 [1].
[1] https://patchwork.ozlabs.org/patch/603583/
Signed-off-by: Beniamino Galvani b.galvani@gmail.com --- arch/arm/Kconfig | 5 + arch/arm/Makefile | 1 + arch/arm/dts/Makefile | 2 + arch/arm/dts/meson-gxbb-odroidc2.dts | 69 +++++++++++++ arch/arm/dts/meson-gxbb.dtsi | 178 +++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-meson/gxbb.h | 52 ++++++++++ arch/arm/mach-meson/Kconfig | 31 ++++++ arch/arm/mach-meson/Makefile | 7 ++ arch/arm/mach-meson/board.c | 66 ++++++++++++ board/hardkernel/odroid-c2/Kconfig | 12 +++ board/hardkernel/odroid-c2/MAINTAINERS | 6 ++ board/hardkernel/odroid-c2/Makefile | 7 ++ board/hardkernel/odroid-c2/README | 60 +++++++++++ board/hardkernel/odroid-c2/odroid-c2.c | 51 ++++++++++ configs/odroid-c2_defconfig | 23 +++++ drivers/serial/Kconfig | 15 +++ drivers/serial/Makefile | 1 + drivers/serial/serial_meson.c | 162 ++++++++++++++++++++++++++++++ include/configs/odroid-c2.h | 55 ++++++++++ 19 files changed, 803 insertions(+) create mode 100644 arch/arm/dts/meson-gxbb-odroidc2.dts create mode 100644 arch/arm/dts/meson-gxbb.dtsi create mode 100644 arch/arm/include/asm/arch-meson/gxbb.h create mode 100644 arch/arm/mach-meson/Kconfig create mode 100644 arch/arm/mach-meson/Makefile create mode 100644 arch/arm/mach-meson/board.c create mode 100644 board/hardkernel/odroid-c2/Kconfig create mode 100644 board/hardkernel/odroid-c2/MAINTAINERS create mode 100644 board/hardkernel/odroid-c2/Makefile create mode 100644 board/hardkernel/odroid-c2/README create mode 100644 board/hardkernel/odroid-c2/odroid-c2.c create mode 100644 configs/odroid-c2_defconfig create mode 100644 drivers/serial/serial_meson.c create mode 100644 include/configs/odroid-c2.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d1c3157..95a0838 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -456,6 +456,9 @@ config ARCH_KEYSTONE select SUPPORT_SPL select CMD_POWEROFF
+config ARCH_MESON + bool "Amlogic Meson" + config ARCH_MX7 bool "Freescale MX7" select CPU_V7 @@ -780,6 +783,8 @@ source "arch/arm/mach-orion5x/Kconfig"
source "arch/arm/cpu/armv7/rmobile/Kconfig"
+source "arch/arm/mach-meson/Kconfig" + source "arch/arm/mach-rockchip/Kconfig"
source "arch/arm/mach-s5pc1xx/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index d516345..ecd1887 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -50,6 +50,7 @@ machine-$(CONFIG_ARCH_HIGHBANK) += highbank machine-$(CONFIG_ARCH_KEYSTONE) += keystone # TODO: rename CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOOD machine-$(CONFIG_KIRKWOOD) += kirkwood +machine-$(CONFIG_ARCH_MESON) += meson machine-$(CONFIG_ARCH_MVEBU) += mvebu # TODO: rename CONFIG_TEGRA -> CONFIG_ARCH_TEGRA # TODO: rename CONFIG_ORION5X -> CONFIG_ARCH_ORION5X diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index aa31fd9..be28d21 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -24,6 +24,8 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-jerry.dtb \ rk3288-rock2-square.dtb \ rk3036-sdk.dtb +dtb-$(CONFIG_ARCH_MESON) += \ + meson-gxbb-odroidc2.dtb dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra20-medcom-wide.dtb \ tegra20-paz00.dtb \ diff --git a/arch/arm/dts/meson-gxbb-odroidc2.dts b/arch/arm/dts/meson-gxbb-odroidc2.dts new file mode 100644 index 0000000..653c2fa --- /dev/null +++ b/arch/arm/dts/meson-gxbb-odroidc2.dts @@ -0,0 +1,69 @@ +/* + * Copyright (c) 2016 Andreas Färber + * Copyright (c) 2016 BayLibre, Inc. + * Author: Kevin Hilman khilman@kernel.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "meson-gxbb.dtsi" + +/ { + compatible = "hardkernel,odroid-c2", "amlogic,meson-gxbb"; + model = "Hardkernel ODROID-C2"; + + aliases { + serial0 = &uart_AO; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; +}; + +&uart_AO { + status = "okay"; +}; diff --git a/arch/arm/dts/meson-gxbb.dtsi b/arch/arm/dts/meson-gxbb.dtsi new file mode 100644 index 0000000..832815d --- /dev/null +++ b/arch/arm/dts/meson-gxbb.dtsi @@ -0,0 +1,178 @@ +/* + * Copyright (c) 2016 Andreas Färber + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + compatible = "amlogic,meson-gxbb"; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <0x2>; + #size-cells = <0x0>; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x0>; + enable-method = "psci"; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x1>; + enable-method = "psci"; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x2>; + enable-method = "psci"; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x3>; + enable-method = "psci"; + }; + }; + + arm-pmu { + compatible = "arm,cortex-a53-pmu"; + interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_EDGE_RISING)>, + <GIC_PPI 14 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_EDGE_RISING)>, + <GIC_PPI 11 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_EDGE_RISING)>, + <GIC_PPI 10 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_EDGE_RISING)>; + }; + + xtal: xtal-clk { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "xtal"; + #clock-cells = <0>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + cbus: cbus@c1100000 { + compatible = "simple-bus"; + reg = <0x0 0xc1100000 0x0 0x100000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xc1100000 0x0 0x100000>; + + uart_A: serial@84c0 { + compatible = "amlogic,meson-uart"; + reg = <0x0 0x084c0 0x0 0x14>; + interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>; + status = "disabled"; + }; + }; + + gic: interrupt-controller@c4301000 { + compatible = "arm,gic-400"; + reg = <0x0 0xc4301000 0 0x1000>, + <0x0 0xc4302000 0 0x2000>, + <0x0 0xc4304000 0 0x2000>, + <0x0 0xc4306000 0 0x2000>; + interrupt-controller; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; + #interrupt-cells = <3>; + #address-cells = <0>; + }; + + aobus: aobus@c8100000 { + compatible = "simple-bus"; + reg = <0x0 0xc8100000 0x0 0x100000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xc8100000 0x0 0x100000>; + + uart_AO: serial@4c0 { + compatible = "amlogic,meson-uart"; + reg = <0x0 0x004c0 0x0 0x14>; + interrupts = <GIC_SPI 193 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>; + status = "disabled"; + }; + }; + + apb: apb@d0000000 { + compatible = "simple-bus"; + reg = <0x0 0xd0000000 0x0 0x200000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xd0000000 0x0 0x200000>; + }; + }; +}; diff --git a/arch/arm/include/asm/arch-meson/gxbb.h b/arch/arm/include/asm/arch-meson/gxbb.h new file mode 100644 index 0000000..f90f632 --- /dev/null +++ b/arch/arm/include/asm/arch-meson/gxbb.h @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2016 - Beniamino Galvani b.galvani@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __GXBB_H__ +#define __GXBB_H__ + +#define GXBB_PERIPHS_BASE 0xc8834400 +#define GXBB_HIU_BASE 0xc883c000 +#define GXBB_ETH_BASE 0xc9410000 + +/* Peripherals registers */ +#define GXBB_PERIPHS_ADDR(off) (GXBB_PERIPHS_BASE + ((off) << 2)) + +/* GPIO registers 0 to 6 */ +#define _GXBB_GPIO_OFF(n) ((n) == 6 ? 0x08 : 0x0c + 3 * (n)) +#define GXBB_GPIO_EN(n) GXBB_PERIPHS_ADDR(_GXBB_GPIO_OFF(n) + 0) +#define GXBB_GPIO_IN(n) GXBB_PERIPHS_ADDR(_GXBB_GPIO_OFF(n) + 1) +#define GXBB_GPIO_OUT(n) GXBB_PERIPHS_ADDR(_GXBB_GPIO_OFF(n) + 2) + +/* Pinmux registers 0 to 12 */ +#define GXBB_PINMUX(n) GXBB_PERIPHS_ADDR(0x2c + (n)) + +#define GXBB_ETH_REG_0 GXBB_PERIPHS_ADDR(0x50) +#define GXBB_ETH_REG_1 GXBB_PERIPHS_ADDR(0x51) + +#define GXBB_ETH_REG_0_PHY_INTF BIT(0) +#define GXBB_ETH_REG_0_TX_PHASE(x) (((x) & 3) << 5) +#define GXBB_ETH_REG_0_TX_RATIO(x) (((x) & 7) << 7) +#define GXBB_ETH_REG_0_PHY_CLK_EN BIT(10) +#define GXBB_ETH_REG_0_CLK_EN BIT(12) + +/* HIU registers */ +#define GXBB_HIU_ADDR(off) (GXBB_HIU_BASE + ((off) << 2)) + +#define GXBB_MEM_PD_REG_0 GXBB_HIU_ADDR(0x40) + +/* Ethernet memory power domain */ +#define GXBB_MEM_PD_REG_0_ETH_MASK (BIT(2) | BIT(3)) + +/* Clock gates */ +#define GXBB_GCLK_MPEG_0 GXBB_HIU_ADDR(0x50) +#define GXBB_GCLK_MPEG_1 GXBB_HIU_ADDR(0x51) +#define GXBB_GCLK_MPEG_2 GXBB_HIU_ADDR(0x52) +#define GXBB_GCLK_MPEG_OTHER GXBB_HIU_ADDR(0x53) +#define GXBB_GCLK_MPEG_AO GXBB_HIU_ADDR(0x54) + +#define GXBB_GCLK_MPEG_1_ETH BIT(3) + +#endif /* __GXBB_H__ */ diff --git a/arch/arm/mach-meson/Kconfig b/arch/arm/mach-meson/Kconfig new file mode 100644 index 0000000..77d3cfe --- /dev/null +++ b/arch/arm/mach-meson/Kconfig @@ -0,0 +1,31 @@ +if ARCH_MESON + +config MESON_GXBB + bool "Support Meson GXBaby" + select ARM64 + select DM + select DM_SERIAL + help + The Amlogic Meson GXBaby (S905) is an ARM SoC with a + quad-core Cortex-A53 CPU and a Mali-450 GPU. + +if MESON_GXBB + +config TARGET_ODROID_C2 + bool "ODROID-C2" + help + ODROID-C2 is a single board computer based on Meson GXBaby + with 2 GiB of RAM, Gigabit Ethernet, HDMI, 4 USB, micro-SD + slot, eMMC, IR receiver and a 40-pin GPIO header. + +endif + +config SYS_SOC + default "meson" + +config SYS_MALLOC_F_LEN + default 0x1000 + +source "board/hardkernel/odroid-c2/Kconfig" + +endif diff --git a/arch/arm/mach-meson/Makefile b/arch/arm/mach-meson/Makefile new file mode 100644 index 0000000..44e3d63 --- /dev/null +++ b/arch/arm/mach-meson/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (c) 2016 Beniamino Galvani b.galvani@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += board.o diff --git a/arch/arm/mach-meson/board.c b/arch/arm/mach-meson/board.c new file mode 100644 index 0000000..05f4c79 --- /dev/null +++ b/arch/arm/mach-meson/board.c @@ -0,0 +1,66 @@ +/* + * (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <libfdt.h> +#include <linux/err.h> +#include <asm/arch/gxbb.h> +#include <asm/armv8/mmu.h> +#include <asm/unaligned.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + const fdt64_t *val; + int offset; + int len; + + offset = fdt_path_offset(gd->fdt_blob, "/memory"); + if (offset < 0) + return -EINVAL; + + val = fdt_getprop(gd->fdt_blob, offset, "reg", &len); + if (len < sizeof(*val) * 2) + return -EINVAL; + + /* Use unaligned access since cache is still disabled */ + gd->ram_size = get_unaligned_be64(&val[1]); + + return 0; +} + +void dram_init_banksize(void) +{ + /* Reserve first 16 MiB of RAM for firmware */ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE + (16 * 1024 * 1024); + gd->bd->bi_dram[0].size = gd->ram_size - (16 * 1024 * 1024); +} + +void reset_cpu(ulong addr) +{ + /* Not implemented yet */ +} + +static struct mm_region gxbb_mem_map[] = { + { + .base = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .base = 0x80000000UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = gxbb_mem_map; diff --git a/board/hardkernel/odroid-c2/Kconfig b/board/hardkernel/odroid-c2/Kconfig new file mode 100644 index 0000000..687d9c6 --- /dev/null +++ b/board/hardkernel/odroid-c2/Kconfig @@ -0,0 +1,12 @@ +if TARGET_ODROID_C2 + +config SYS_BOARD + default "odroid-c2" + +config SYS_VENDOR + default "hardkernel" + +config SYS_CONFIG_NAME + default "odroid-c2" + +endif diff --git a/board/hardkernel/odroid-c2/MAINTAINERS b/board/hardkernel/odroid-c2/MAINTAINERS new file mode 100644 index 0000000..23ae1e7 --- /dev/null +++ b/board/hardkernel/odroid-c2/MAINTAINERS @@ -0,0 +1,6 @@ +ODROID-C2 +M: Beniamino Galvani b.galvani@gmail.com +S: Maintained +F: board/hardkernel/odroid-c2/ +F: include/configs/odroid-c2.h +F: configs/odroid-c2_defconfig diff --git a/board/hardkernel/odroid-c2/Makefile b/board/hardkernel/odroid-c2/Makefile new file mode 100644 index 0000000..571044b --- /dev/null +++ b/board/hardkernel/odroid-c2/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := odroid-c2.o diff --git a/board/hardkernel/odroid-c2/README b/board/hardkernel/odroid-c2/README new file mode 100644 index 0000000..d6d266a --- /dev/null +++ b/board/hardkernel/odroid-c2/README @@ -0,0 +1,60 @@ +U-Boot for ODROID-C2 +==================== + +ODROID-C2 is a single board computer manufactured by Hardkernel +Co. Ltd with the following specifications: + + - Amlogic S905 ARM Cortex-A53 quad-core SoC @ 2GHz + - ARM Mali 450 GPU + - 2GB DDR3 SDRAM + - Gigabit Ethernet + - HDMI 2.0 4K/60Hz display + - 40-pin GPIO header + - 4 x USB 2.0 Host, 1 x USB OTG + - eMMC, microSD + - Infrared receiver + +Schematics are available on the manufacturer website. + +Currently the u-boot port supports the following devices: + - serial + - Ethernet + +u-boot compilation +================== + + > export ARCH=arm + > export CROSS_COMPILE=aarch64-none-elf- + > make odroid-c2_defconfig + > make + +Image creation +============== + +Amlogic doesn't provide sources for the firmware and for tools needed +to create the bootloader image, so it is necessary to obtain them from +the git tree published by the board vendor: + + > DIR=odroid-c2 + > git clone --depth 1 \ + https://github.com/hardkernel/u-boot.git -b odroidc2-v2015.01 \ + $DIR + > $DIR/fip/fip_create --bl30 $DIR/fip/gxb/bl30.bin \ + --bl301 $DIR/fip/gxb/bl301.bin \ + --bl31 $DIR/fip/gxb/bl31.bin \ + --bl33 u-boot.bin \ + $DIR/fip.bin + > $DIR/fip/fip_create --dump $DIR/fip.bin + > cat $DIR/fip/gxb/bl2.package $DIR/fip.bin > $DIR/boot_new.bin + > $DIR/fip/gxb/aml_encrypt_gxb --bootsig \ + --input $DIR/boot_new.bin \ + --output $DIR/u-boot.img + > dd if=$DIR/u-boot.img of=$DIR/u-boot.gxbb bs=512 skip=96 + +and then write the image to SD with: + + > DEV=/dev/your_sd_device + > BL1=$DIR/sd_fuse/bl1.bin.hardkernel + > dd if=$BL1 of=$DEV conv=fsync bs=1 count=442 + > dd if=$BL1 of=$DEV conv=fsync bs=512 skip=1 seek=1 + > dd if=$DIR/u-boot.gxbb of=$DEV conv=fsync bs=512 seek=97 diff --git a/board/hardkernel/odroid-c2/odroid-c2.c b/board/hardkernel/odroid-c2/odroid-c2.c new file mode 100644 index 0000000..c258d4f --- /dev/null +++ b/board/hardkernel/odroid-c2/odroid-c2.c @@ -0,0 +1,51 @@ +/* + * (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/gxbb.h> +#include <dm/platdata.h> +#include <phy.h> + +int board_init(void) +{ + return 0; +} + +static const struct eth_pdata gxbb_eth_pdata = { + .iobase = GXBB_ETH_BASE, + .phy_interface = PHY_INTERFACE_MODE_RGMII, +}; + +U_BOOT_DEVICE(meson_eth) = { + .name = "eth_designware", + .platdata = &gxbb_eth_pdata, +}; + +int misc_init_r(void) +{ + /* Select Ethernet function */ + setbits_le32(GXBB_PINMUX(6), 0x3fff); + + /* Set RGMII mode */ + setbits_le32(GXBB_ETH_REG_0, GXBB_ETH_REG_0_PHY_INTF | + GXBB_ETH_REG_0_TX_PHASE(1) | + GXBB_ETH_REG_0_TX_RATIO(4) | + GXBB_ETH_REG_0_PHY_CLK_EN | + GXBB_ETH_REG_0_CLK_EN); + + /* Enable power and clock gate */ + setbits_le32(GXBB_GCLK_MPEG_1, GXBB_GCLK_MPEG_1_ETH); + clrbits_le32(GXBB_MEM_PD_REG_0, GXBB_MEM_PD_REG_0_ETH_MASK); + + /* Reset PHY on GPIOZ_14 */ + clrbits_le32(GXBB_GPIO_EN(3), BIT(14)); + clrbits_le32(GXBB_GPIO_OUT(3), BIT(14)); + mdelay(10); + setbits_le32(GXBB_GPIO_OUT(3), BIT(14)); + + return 0; +} diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig new file mode 100644 index 0000000..a771b20 --- /dev/null +++ b/configs/odroid-c2_defconfig @@ -0,0 +1,23 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_MESON_GXBB=y +CONFIG_TARGET_ODROID_C2=y +CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-odroidc2" +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_BASE=0xc81004c0 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index a9a5d47..7720b3e 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -112,6 +112,14 @@ config DEBUG_UART_S5P will need to provide parameters to make this work. The driver will be available until the real driver-model serial is running.
+config DEBUG_UART_MESON + bool "Amlogic Meson" + depends on MESON_SERIAL + help + Select this to enable a debug UART using the serial_meson driver. You + will need to provide parameters to make this work. The driver will + be available until the real driver-model serial is running. + config DEBUG_UART_UARTLITE bool "Xilinx Uartlite" help @@ -320,6 +328,13 @@ config XILINX_UARTLITE If you have a Xilinx based board and want to use the uartlite serial ports, say Y to this option. If unsure, say N.
+config MESON_SERIAL + bool "Support for Amlogic Meson UART" + depends on DM_SERIAL && ARCH_MESON + help + If you have an Amlogic Meson based board and want to use the on-chip + serial ports, say Y to this option. If unsure, say N. + config MSM_SERIAL bool "Qualcomm on-chip UART" depends on DM_SERIAL diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index b0ac9d8..35c143d 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -26,6 +26,7 @@ obj-$(CONFIG_SYS_NS16550) += ns16550.o obj-$(CONFIG_S5P) += serial_s5p.o obj-$(CONFIG_MXC_UART) += serial_mxc.o obj-$(CONFIG_PXA_SERIAL) += serial_pxa.o +obj-$(CONFIG_MESON_SERIAL) += serial_meson.o obj-$(CONFIG_S3C24X0_SERIAL) += serial_s3c24x0.o obj-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o obj-$(CONFIG_SANDBOX_SERIAL) += sandbox.o diff --git a/drivers/serial/serial_meson.c b/drivers/serial/serial_meson.c new file mode 100644 index 0000000..1b49426 --- /dev/null +++ b/drivers/serial/serial_meson.c @@ -0,0 +1,162 @@ +/* + * (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <linux/compiler.h> +#include <serial.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct meson_uart { + u32 wfifo; + u32 rfifo; + u32 control; + u32 status; + u32 misc; +}; + +struct meson_serial_platdata { + struct meson_uart *reg; +}; + +/* AML_UART_STATUS bits */ +#define AML_UART_PARITY_ERR BIT(16) +#define AML_UART_FRAME_ERR BIT(17) +#define AML_UART_TX_FIFO_WERR BIT(18) +#define AML_UART_RX_EMPTY BIT(20) +#define AML_UART_TX_FULL BIT(21) +#define AML_UART_TX_EMPTY BIT(22) +#define AML_UART_XMIT_BUSY BIT(25) +#define AML_UART_ERR (AML_UART_PARITY_ERR | \ + AML_UART_FRAME_ERR | \ + AML_UART_TX_FIFO_WERR) + +/* AML_UART_CONTROL bits */ +#define AML_UART_TX_EN BIT(12) +#define AML_UART_RX_EN BIT(13) +#define AML_UART_TX_RST BIT(22) +#define AML_UART_RX_RST BIT(23) +#define AML_UART_CLR_ERR BIT(24) + +static void meson_serial_init(struct meson_uart *uart) +{ + u32 val; + + val = readl(&uart->control); + val |= (AML_UART_RX_RST | AML_UART_TX_RST | AML_UART_CLR_ERR); + writel(val, &uart->control); + val &= ~(AML_UART_RX_RST | AML_UART_TX_RST | AML_UART_CLR_ERR); + writel(val, &uart->control); + val |= (AML_UART_RX_EN | AML_UART_TX_EN); + writel(val, &uart->control); +} + +static int meson_serial_probe(struct udevice *dev) +{ + struct meson_serial_platdata *plat = dev->platdata; + struct meson_uart *const uart = plat->reg; + + meson_serial_init(uart); + + return 0; +} + +static int meson_serial_getc(struct udevice *dev) +{ + struct meson_serial_platdata *plat = dev->platdata; + struct meson_uart *const uart = plat->reg; + + if (readl(&uart->status) & AML_UART_RX_EMPTY) + return -EAGAIN; + + return readl(&uart->rfifo) & 0xff; +} + +static int meson_serial_putc(struct udevice *dev, const char ch) +{ + struct meson_serial_platdata *plat = dev->platdata; + struct meson_uart *const uart = plat->reg; + + if (readl(&uart->status) & AML_UART_TX_FULL) + return -EAGAIN; + + writel(ch, &uart->wfifo); + + return 0; +} + +static int meson_serial_pending(struct udevice *dev, bool input) +{ + struct meson_serial_platdata *plat = dev->platdata; + struct meson_uart *const uart = plat->reg; + uint32_t status = readl(&uart->status); + + if (input) + return !(status & AML_UART_RX_EMPTY); + else + return !(status & AML_UART_TX_FULL); +} + +static int meson_serial_ofdata_to_platdata(struct udevice *dev) +{ + struct meson_serial_platdata *plat = dev->platdata; + fdt_addr_t addr; + + addr = dev_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->reg = (struct meson_uart *)addr; + + return 0; +} + +static const struct dm_serial_ops meson_serial_ops = { + .putc = meson_serial_putc, + .pending = meson_serial_pending, + .getc = meson_serial_getc, +}; + +static const struct udevice_id meson_serial_ids[] = { + { .compatible = "amlogic,meson-uart" }, + { } +}; + +U_BOOT_DRIVER(serial_meson) = { + .name = "serial_meson", + .id = UCLASS_SERIAL, + .of_match = meson_serial_ids, + .probe = meson_serial_probe, + .ops = &meson_serial_ops, + .flags = DM_FLAG_PRE_RELOC, + .ofdata_to_platdata = meson_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct meson_serial_platdata), +}; + +#ifdef CONFIG_DEBUG_UART_MESON + +#include <debug_uart.h> + +static inline void _debug_uart_init(void) +{ +} + +static inline void _debug_uart_putc(int ch) +{ + struct meson_uart *regs = (struct meson_uart *)CONFIG_DEBUG_UART_BASE; + + while (readl(®s->status) & AML_UART_TX_FULL) + ; + + writel(ch, ®s->wfifo); +} + +DEBUG_UART_FUNCS + +#endif diff --git a/include/configs/odroid-c2.h b/include/configs/odroid-c2.h new file mode 100644 index 0000000..5dbc0ce --- /dev/null +++ b/include/configs/odroid-c2.h @@ -0,0 +1,55 @@ +/* + * Configuration for ODROID-C2 + * (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_CPU_ARMV8 +#define CONFIG_REMAKE_ELF +#define CONFIG_SYS_CACHELINE_SIZE 64 +#define CONFIG_SYS_NO_FLASH +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_ENV_IS_NOWHERE 1 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MAXARGS 32 +#define CONFIG_SYS_MALLOC_LEN (32 << 20) +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_MISC_INIT_R + +#define CONFIG_SYS_SDRAM_BASE 0 +#define CONFIG_SYS_TEXT_BASE 0x01000000 +#define CONFIG_SYS_INIT_SP_ADDR 0x20000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE + +/* Generic Interrupt Controller Definitions */ +#define GICD_BASE 0xc4301000 +#define GICC_BASE 0xc4302000 + +#if !defined(CONFIG_IDENT_STRING) +# define CONFIG_IDENT_STRING " odroid-c2" +#endif + +/* Serial setup */ +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE \ + { 4800, 9600, 19200, 38400, 57600, 115200 } + +#define CONFIG_CMD_ENV + +/* Monitor Command Prompt */ +/* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING + +#include <config_distro_defaults.h> + +#endif /* __CONFIG_H */
Implement calls to the secure monitor to reset the board and read the MAC address from e-fuse.
Signed-off-by: Beniamino Galvani b.galvani@gmail.com --- arch/arm/include/asm/arch-meson/sm.h | 13 +++++++ arch/arm/mach-meson/Makefile | 2 +- arch/arm/mach-meson/board.c | 3 +- arch/arm/mach-meson/sm.c | 71 ++++++++++++++++++++++++++++++++++ board/hardkernel/odroid-c2/odroid-c2.c | 16 ++++++++ 5 files changed, 103 insertions(+), 2 deletions(-) create mode 100644 arch/arm/include/asm/arch-meson/sm.h create mode 100644 arch/arm/mach-meson/sm.c
diff --git a/arch/arm/include/asm/arch-meson/sm.h b/arch/arm/include/asm/arch-meson/sm.h new file mode 100644 index 0000000..87134c6 --- /dev/null +++ b/arch/arm/include/asm/arch-meson/sm.h @@ -0,0 +1,13 @@ +/* + * (C) Copyright 2016 - Beniamino Galvani b.galvani@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __MESON_SM_H__ +#define __MESON_SM_H__ + +void meson_sm_reboot(void); +ssize_t meson_sm_read_efuse(uintptr_t offset, void *buffer, size_t size); + +#endif /* __MESON_SM_H__ */ diff --git a/arch/arm/mach-meson/Makefile b/arch/arm/mach-meson/Makefile index 44e3d63..bf49b8b 100644 --- a/arch/arm/mach-meson/Makefile +++ b/arch/arm/mach-meson/Makefile @@ -4,4 +4,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += board.o +obj-y += board.o sm.o diff --git a/arch/arm/mach-meson/board.c b/arch/arm/mach-meson/board.c index 05f4c79..6272f2f 100644 --- a/arch/arm/mach-meson/board.c +++ b/arch/arm/mach-meson/board.c @@ -8,6 +8,7 @@ #include <libfdt.h> #include <linux/err.h> #include <asm/arch/gxbb.h> +#include <asm/arch/sm.h> #include <asm/armv8/mmu.h> #include <asm/unaligned.h>
@@ -42,7 +43,7 @@ void dram_init_banksize(void)
void reset_cpu(ulong addr) { - /* Not implemented yet */ + meson_sm_reboot(); }
static struct mm_region gxbb_mem_map[] = { diff --git a/arch/arm/mach-meson/sm.c b/arch/arm/mach-meson/sm.c new file mode 100644 index 0000000..3065bd2 --- /dev/null +++ b/arch/arm/mach-meson/sm.c @@ -0,0 +1,71 @@ +/* + * (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Secure monitor calls. + */ + +#include <common.h> +#include <asm/arch/gxbb.h> + +#define MIN(a, b) ((a) < (b) ? (a) : (b)) + +#define FN_GET_SHARE_MEM_INPUT_BASE 0x82000020 +#define FN_GET_SHARE_MEM_OUTPUT_BASE 0x82000021 +#define FN_EFUSE_READ 0x82000030 +#define FN_EFUSE_WRITE 0x82000031 +#define FN_REBOOT 0x84000009 + +static void *shmem_input; +static void *shmem_output; + +static void meson_init_shmem(void) +{ + struct pt_regs regs; + + if (shmem_input && shmem_output) + return; + + regs.regs[0] = FN_GET_SHARE_MEM_INPUT_BASE; + smc_call(®s); + shmem_input = (void *)regs.regs[0]; + + regs.regs[0] = FN_GET_SHARE_MEM_OUTPUT_BASE; + smc_call(®s); + shmem_output = (void *)regs.regs[0]; + + debug("Secure Monitor shmem: 0x%p 0x%p\n", shmem_input, shmem_output); +} + +void meson_sm_reboot(void) +{ + struct pt_regs regs; + + regs.regs[0] = FN_REBOOT; + regs.regs[1] = 1; /* normal reboot */ + regs.regs[2] = 0; + regs.regs[3] = 0; + + smc_call(®s); +} + +ssize_t meson_sm_read_efuse(uintptr_t offset, void *buffer, size_t size) +{ + struct pt_regs regs; + + meson_init_shmem(); + + regs.regs[0] = FN_EFUSE_READ; + regs.regs[1] = offset; + regs.regs[2] = size; + + smc_call(®s); + + if (regs.regs[0] == 0) + return -1; + + memcpy(buffer, shmem_output, MIN(size, regs.regs[0])); + + return regs.regs[0]; +} diff --git a/board/hardkernel/odroid-c2/odroid-c2.c b/board/hardkernel/odroid-c2/odroid-c2.c index c258d4f..bd72100 100644 --- a/board/hardkernel/odroid-c2/odroid-c2.c +++ b/board/hardkernel/odroid-c2/odroid-c2.c @@ -7,9 +7,15 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/gxbb.h> +#include <asm/arch/sm.h> #include <dm/platdata.h> #include <phy.h>
+#define EFUSE_SN_OFFSET 20 +#define EFUSE_SN_SIZE 16 +#define EFUSE_MAC_OFFSET 52 +#define EFUSE_MAC_SIZE 6 + int board_init(void) { return 0; @@ -27,6 +33,9 @@ U_BOOT_DEVICE(meson_eth) = {
int misc_init_r(void) { + u8 mac_addr[EFUSE_MAC_SIZE]; + ssize_t len; + /* Select Ethernet function */ setbits_le32(GXBB_PINMUX(6), 0x3fff);
@@ -47,5 +56,12 @@ int misc_init_r(void) mdelay(10); setbits_le32(GXBB_GPIO_OUT(3), BIT(14));
+ if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, + mac_addr, EFUSE_MAC_SIZE); + if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac_addr)) + eth_setenv_enetaddr("ethaddr", mac_addr); + } + return 0; }
Am 17.04.2016 um 09:48 schrieb Beniamino Galvani b.galvani@gmail.com:
- (C) Copyright 2016 - Beniamino Galvani b.galvani@gmail.com
- meson_sm_reboot();
Shouldn't reboot be available as psci call? We could then have a generic reset function for systems with working psci in atf.
Alex
Yes, the 0x84000009 function ID used to reset the board seems to be actually a PSCI call, so probably a generic function could be implemented and used. I will change this in the next version.
Thanks, Beniamino
- (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com
- Secure monitor calls.
See include/linux/kernel.h for min macro
participants (5)
Alexander Graf
Andreas Färber
Beniamino Galvani
Joe Hershberger
