[U-Boot] [PATCH] test/py: only check for SPL signature if SPL uses serial output
check for U-Boot SPL signature only if SPL really has a serial output. So check if CONFIG_SPL_SERIAL_SUPPORT is active in board config.
Signed-off-by: Heiko Schocher hs@denx.de --- found this while trying test/py on the smartweb board, which has SPL but no SPL serial output.
test/py/u_boot_console_base.py | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index bc2bd76..f888d5c 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -304,10 +304,13 @@ class ConsoleBase(object): self.p.timeout = 30000 self.p.logfile_read = self.logstream if self.config.buildconfig.get('config_spl', False) == 'y': - m = self.p.expect([pattern_u_boot_spl_signon] + self.bad_patterns) - if m != 0: - raise Exception('Bad pattern found on console: ' + - self.bad_pattern_ids[m - 1]) + if self.config.buildconfig.get('config_spl_serial_support', + False) == 'y': + m = self.p.expect([pattern_u_boot_spl_signon] + + self.bad_patterns) + if m != 0: + raise Exception('Bad pattern found on console: ' + + self.bad_pattern_ids[m - 1]) m = self.p.expect([pattern_u_boot_main_signon] + self.bad_patterns) if m != 0: raise Exception('Bad pattern found on console: ' +
Nit: That's wrapped really narrow. Any chance of wrapping to more like 72-74 characters?
if m != 0:
False) == 'y':
self.bad_patterns)
if m != 0:
Conceptually this change looks fine. Rather than using nested ifs, why not write "if a and b:" and so avoid adding an extra indent level? I'd also introduce some variables to shorten the text a bit:
bcfg = u_boot_console.config.buildconfig if bcfg.get('config_spl', 'n') == 'y' and bcfg.get('config_spl_serial_support', 'n') == 'y': ...
or:
bcfg = u_boot_console.config.buildconfig config_spl = bcfg.get('config_spl', 'n') == 'y' config_spl_serial_support = bcfg.get('config_spl_serial_support', 'n') == 'y' if config_spl and config_spl_serial_support: ...
Heiko Schocher
Stephen Warren
