[U-Boot] [PATCH] Fix compiler warning in mpc8xxx ddr code
ctrl_regs.c: In function 'compute_fsl_memctl_config_regs': ctrl_regs.c:523: warning: 'caslat' may be used uninitialized in this function ctrl_regs.c:523: note: 'caslat' was declared here
Add a warning in DDR1 case if cas_latency isn't a value we know about.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc8xxx/ddr/ctrl_regs.c | 6 ++++-- 1 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/cpu/mpc8xxx/ddr/ctrl_regs.c b/cpu/mpc8xxx/ddr/ctrl_regs.c index ca67551..e6c2a5c 100644 --- a/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -520,7 +520,7 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, unsigned int wr; /* Write Recovery */ unsigned int dll_res; /* DLL Reset */ unsigned int mode; /* Normal=0 or Test=1 */ - unsigned int caslat; /* CAS# latency */ + unsigned int caslat = 0;/* CAS# latency */ /* BT: Burst Type (0=Sequential, 1=Interleaved) */ unsigned int bt; unsigned int bl; /* BL: Burst Length */ @@ -572,7 +572,9 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, 0x6, /* 2.5 clocks */ 0x3 /* 3.0 clocks */ }; - caslat = mode_caslat_table[cas_latency - 1]; + caslat = mode_caslat_table[cas_latency - 1]; + } else { + printf("Warning: unknown cas_latency %d\n", cas_latency); } #elif defined(CONFIG_FSL_DDR2) caslat = cas_latency;
Thanks it's fix my warnings
Ack-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
Best Regards, J.
Dear Kumar Gala,
In message 1220643629-1653-1-git-send-email-galak@kernel.crashing.org you wrote:
Applied, thanks.
Kumar Gala
