[PATCH 0/3] Add SAMA5D2 PWM Support
Add support for the PWM found on SAMA5D2 SoCs.
Dan Sneddon (3): pwm: Add PWM driver for SAMA5D2 dt-bindings: pwm: pwm-at91: Add PWM bindings for A5D2 ARM:dts: sama5d2: Add pwm definition
arch/arm/dts/sama5d2.dtsi | 8 + doc/device-tree-bindings/pwm/pwm-at91.txt | 16 ++ drivers/pwm/Kconfig | 6 + drivers/pwm/Makefile | 1 + drivers/pwm/pwm-at91.c | 207 ++++++++++++++++++++++ 5 files changed, 238 insertions(+) create mode 100644 doc/device-tree-bindings/pwm/pwm-at91.txt create mode 100644 drivers/pwm/pwm-at91.c
Add support for the PWM found on the SAMA5D2 family of devices.
Signed-off-by: Dan Sneddon dan.sneddon@microchip.com --- drivers/pwm/Kconfig | 6 ++ drivers/pwm/Makefile | 1 + drivers/pwm/pwm-at91.c | 207 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 214 insertions(+) create mode 100644 drivers/pwm/pwm-at91.c
diff --git a/drivers/pwm/Kconfig b/drivers/pwm/Kconfig index cf7f4c6840..691bbcd469 100644 --- a/drivers/pwm/Kconfig +++ b/drivers/pwm/Kconfig @@ -91,3 +91,9 @@ config PWM_TI_EHRPWM default y help PWM driver support for the EHRPWM controller found on TI SOCs. + +config PWM_AT91 + bool "Enable support for PWM found on AT91 SoC's" + depends on DM_PWM && ARCH_AT91 + help + Support for PWM hardware on AT91 based SoC. diff --git a/drivers/pwm/Makefile b/drivers/pwm/Makefile index 10d244bfb7..6cdcbdb996 100644 --- a/drivers/pwm/Makefile +++ b/drivers/pwm/Makefile @@ -21,3 +21,4 @@ obj-$(CONFIG_PWM_SIFIVE) += pwm-sifive.o obj-$(CONFIG_PWM_TEGRA) += tegra_pwm.o obj-$(CONFIG_PWM_SUNXI) += sunxi_pwm.o obj-$(CONFIG_PWM_TI_EHRPWM) += pwm-ti-ehrpwm.o +obj-$(CONFIG_PWM_AT91) += pwm-at91.o diff --git a/drivers/pwm/pwm-at91.c b/drivers/pwm/pwm-at91.c new file mode 100644 index 0000000000..95597aee55 --- /dev/null +++ b/drivers/pwm/pwm-at91.c @@ -0,0 +1,207 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * PWM support for Microchip AT91 architectures. + * + * Copyright (C) 2021 Microchip Technology Inc. and its subsidiaries + * + * Author: Dan Sneddon daniel.sneddon@microchip.com + * + * Based on drivers/pwm/pwm-atmel.c from Linux. + */ +#include <clk.h> +#include <common.h> +#include <div64.h> +#include <dm.h> +#include <linux/bitops.h> +#include <linux/io.h> +#include <pwm.h> + +#define PERIOD_BITS 16 +#define PWM_MAX_PRES 10 +#define NSEC_PER_SEC 1000000000L + +#define PWM_ENA 0x04 +#define PWM_CHANNEL_OFFSET 0x20 +#define PWM_CMR 0x200 +#define PWM_CMR_CPRE_MSK GENMASK(3, 0) +#define PWM_CMR_CPOL BIT(9) +#define PWM_CDTY 0x204 +#define PWM_CPRD 0x20C + +struct at91_pwm_priv { + void __iomem *base; + struct clk pclk; + u32 clkrate; +}; + +static int at91_pwm_calculate_cprd_and_pres(struct udevice *dev, + unsigned long clkrate, + uint period_ns, uint duty_ns, + unsigned long *cprd, u32 *pres) +{ + u64 cycles = period_ns; + int shift; + + /* Calculate the period cycles and prescale value */ + cycles *= clkrate; + do_div(cycles, NSEC_PER_SEC); + + /* + * The register for the period length is period_bits bits wide. + * So for each bit the number of clock cycles is wider divide the input + * clock frequency by two using pres and shift cprd accordingly. + */ + shift = fls(cycles) - PERIOD_BITS; + + if (shift > PWM_MAX_PRES) { + return -EINVAL; + } else if (shift > 0) { + *pres = shift; + cycles >>= *pres; + } else { + *pres = 0; + } + + *cprd = cycles; + + return 0; +} + +static void at91_pwm_calculate_cdty(uint period_ns, uint duty_ns, + unsigned long clkrate, unsigned long cprd, + u32 pres, unsigned long *cdty) +{ + u64 cycles = duty_ns; + + cycles *= clkrate; + do_div(cycles, NSEC_PER_SEC); + cycles >>= pres; + *cdty = cprd - cycles; +} + +/** + * Returns: channel status after set operation + */ +static bool at91_pwm_set(void __iomem *base, uint channel, bool enable) +{ + u32 val, cur_status; + + val = ioread32(base + PWM_ENA); + cur_status = !!(val & BIT(channel)); + + /* if channel is already in that state, do nothing */ + if (!(enable ^ cur_status)) + return cur_status; + + if (enable) + val |= BIT(channel); + else + val &= ~(BIT(channel)); + + iowrite32(val, base + PWM_ENA); + + return cur_status; +} + +static int at91_pwm_set_enable(struct udevice *dev, uint channel, bool enable) +{ + struct at91_pwm_priv *priv = dev_get_priv(dev); + + at91_pwm_set(priv->base, channel, enable); + + return 0; +} + +static int at91_pwm_set_config(struct udevice *dev, uint channel, + uint period_ns, uint duty_ns) +{ + struct at91_pwm_priv *priv = dev_get_priv(dev); + unsigned long cprd, cdty; + u32 pres, val; + int channel_enabled; + int ret; + + ret = at91_pwm_calculate_cprd_and_pres(dev, priv->clkrate, period_ns, + duty_ns, &cprd, &pres); + if (ret) + return ret; + + at91_pwm_calculate_cdty(period_ns, duty_ns, priv->clkrate, cprd, pres, &cdty); + + /* disable the channel */ + channel_enabled = at91_pwm_set(priv->base, channel, false); + + /* It is necessary to preserve CPOL, inside CMR */ + val = ioread32(priv->base + (channel * PWM_CHANNEL_OFFSET) + PWM_CMR); + val = (val & ~PWM_CMR_CPRE_MSK) | (pres & PWM_CMR_CPRE_MSK); + iowrite32(val, priv->base + (channel * PWM_CHANNEL_OFFSET) + PWM_CMR); + + iowrite32(cprd, priv->base + (channel * PWM_CHANNEL_OFFSET) + PWM_CPRD); + + iowrite32(cdty, priv->base + (channel * PWM_CHANNEL_OFFSET) + PWM_CDTY); + + /* renable the channel if needed */ + if (channel_enabled) + at91_pwm_set(priv->base, channel, true); + + return 0; +} + +static int at91_pwm_set_invert(struct udevice *dev, uint channel, + bool polarity) +{ + struct at91_pwm_priv *priv = dev_get_priv(dev); + u32 val; + + val = ioread32(priv->base + (channel * PWM_CHANNEL_OFFSET) + PWM_CMR); + if (polarity) + val |= PWM_CMR_CPOL; + else + val &= ~PWM_CMR_CPOL; + iowrite32(val, priv->base + (channel * PWM_CHANNEL_OFFSET) + PWM_CMR); + + return 0; +} + +static int at91_pwm_probe(struct udevice *dev) +{ + struct at91_pwm_priv *priv = dev_get_priv(dev); + int ret; + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -EINVAL; + + ret = clk_get_by_index(dev, 0, &priv->pclk); + if (ret) + return ret; + + /* clocks aren't ref-counted so just enabled them once here */ + ret = clk_enable(&priv->pclk); + if (ret) + return ret; + + priv->clkrate = clk_get_rate(&priv->pclk); + + return ret; +} + +static const struct pwm_ops at91_pwm_ops = { + .set_config = at91_pwm_set_config, + .set_enable = at91_pwm_set_enable, + .set_invert = at91_pwm_set_invert, +}; + +static const struct udevice_id at91_pwm_of_match[] = { + { .compatible = "atmel,sama5d2-pwm" }, + { } +}; + +U_BOOT_DRIVER(at91_pwm) = { + .name = "at91_pwm", + .id = UCLASS_PWM, + .of_match = at91_pwm_of_match, + .probe = at91_pwm_probe, + .priv_auto = sizeof(struct at91_pwm_priv), + .ops = &at91_pwm_ops, +};
Document the bindings needed for the PWM device on the SAMA5D2.
Signed-off-by: Dan Sneddon dan.sneddon@microchip.com --- doc/device-tree-bindings/pwm/pwm-at91.txt | 16 ++++++++++++++++ 1 file changed, 16 insertions(+) create mode 100644 doc/device-tree-bindings/pwm/pwm-at91.txt
diff --git a/doc/device-tree-bindings/pwm/pwm-at91.txt b/doc/device-tree-bindings/pwm/pwm-at91.txt new file mode 100644 index 0000000000..a03da404f5 --- /dev/null +++ b/doc/device-tree-bindings/pwm/pwm-at91.txt @@ -0,0 +1,16 @@ +Microchip AT91 PWM controller for SAMA5D2 + +Required properties: + - compatible: Should be "atmel,sama5d2-pwm" + - reg: Physical base address and length of the controller's registers. + - clocks: Should contain a clock identifier for the PWM's parent clock. + - #pwm-cells: Should be 3. + +Example: + +pwm0: pwm@f802c000 { + compatible = "atmel,sama5d2-pwm"; + reg = <0xf802c000 0x4000>; + clocks = <&pwm_clk>; + #pwm-cells = <3>; +};
Add the PWM on the SAMA5D2.
Signed-off-by: Dan Sneddon dan.sneddon@microchip.com --- arch/arm/dts/sama5d2.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/sama5d2.dtsi b/arch/arm/dts/sama5d2.dtsi index 6fb2cb25f9..ba1b69e629 100644 --- a/arch/arm/dts/sama5d2.dtsi +++ b/arch/arm/dts/sama5d2.dtsi @@ -671,6 +671,14 @@ status = "disabled"; };
+ pwm0: pwm@f802c000 { + compatible = "atmel,sama5d2-pwm"; + reg = <0xf802c000 0x4000>; + clocks = <&pwm_clk>; + #pwm-cells = <3>; + status = "disabled"; + }; + rstc@f8048000 { compatible = "atmel,sama5d3-rstc"; reg = <0xf8048000 0x10>;
-- 2.17.1
Applied to u-boot-at91/master, thanks !
Dan Sneddon
Eugen.Hristev@microchip.com
