[U-Boot] [RFC PATCH] arm, m68k: fix out-of-range jump
fix the following build error for m68k boards: Building current source for 48 boards (2 threads, 1 job per thread) m68k: + M54455EVB_i66 +arch/m68k/cpu/mcf5445x/start.o: In function `_start': +arch/m68k/cpu/mcf5445x/start.S:668:(.text+0x45a): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o +make[1]: *** [u-boot] Error 1 +make: *** [sub-make] Error 2
Signed-off-by: Heiko Schocher hs@denx.de --- This commit fixes build error: https://travis-ci.org/hsdenx/u-boot/jobs/123254183
fixed log see: https://travis-ci.org/hsdenx/u-boot/jobs/123281032
Any ideas why the changes did not work for: arch/m68k/cpu/mcf523x/start.S arch/m68k/cpu/mcf52x2/start.S arch/m68k/cpu/mcf532x/start.S
but work for arch/m68k/cpu/mcf5445x/start.S
I have no real m68k experiences, so help is appreciated!
arch/m68k/cpu/mcf523x/start.S | 4 ++-- arch/m68k/cpu/mcf52x2/start.S | 4 ++-- arch/m68k/cpu/mcf532x/start.S | 4 ++-- arch/m68k/cpu/mcf5445x/start.S | 4 ++-- 4 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/m68k/cpu/mcf523x/start.S b/arch/m68k/cpu/mcf523x/start.S index 8a23e72..ad7bde4 100644 --- a/arch/m68k/cpu/mcf523x/start.S +++ b/arch/m68k/cpu/mcf523x/start.S @@ -141,8 +141,8 @@ _start:
move.l #__got_start, %a5 /* put relocation table address to a5 */
- bsr cpu_init_f /* run low-level CPU init code (from flash) */ - bsr board_init_f /* run low-level board init code (from flash) */ + jbsr cpu_init_f /* run low-level CPU init code (from flash) */ + jbsr board_init_f /* run low-level board init code (from flash) */
/* board_init_f() does not return */
diff --git a/arch/m68k/cpu/mcf52x2/start.S b/arch/m68k/cpu/mcf52x2/start.S index 8a59496..a16b589 100644 --- a/arch/m68k/cpu/mcf52x2/start.S +++ b/arch/m68k/cpu/mcf52x2/start.S @@ -198,8 +198,8 @@ _after_flashbar_copy:
diff --git a/arch/m68k/cpu/mcf532x/start.S b/arch/m68k/cpu/mcf532x/start.S index 3b9ede0..50d301c 100644 --- a/arch/m68k/cpu/mcf532x/start.S +++ b/arch/m68k/cpu/mcf532x/start.S @@ -155,8 +155,8 @@ _start:
diff --git a/arch/m68k/cpu/mcf5445x/start.S b/arch/m68k/cpu/mcf5445x/start.S index ae261b1..ff8d627 100644 --- a/arch/m68k/cpu/mcf5445x/start.S +++ b/arch/m68k/cpu/mcf5445x/start.S @@ -664,8 +664,8 @@ _start:
Hi Heiko,
I just sent a very similar patch some days ago.
https://patchwork.ozlabs.org/patch/609150/
Issue should be fixed.
Regards, Angelo
Hello Angelo,
Am 15.04.2016 um 16:39 schrieb Angelo Dureghello:
Hi Heiko,
Oh, sorry for overlooking this!
Thanks for fixing!
bye, Heiko
Hi Heiko,
sorry, i realized later you was asking the reason why jbsr is not working with
jbsr is an alias for bsr.l that is supported only from ISA_B. In ISA_A it is likely translated to 16bit relative jump.
I prepared some notes, you can check ISA Revisions here: http://www.denx.de/wiki/U-Boot/ColdFireNotes
Best regards, Angelo Dureghello
Angelo Dureghello
Heiko Schocher
