(overlapping) lmb allocations during boot
I sometimes see a corrupted initrd during kernel boot on my board (kontron_sl28). Debugging showed that in this case the spin table for the secondary CPUs overlaps with the lmb initrd allocations (initrd_high is set).
I had a look at how the fdt and initrd are relocated (if enabled). In summary, they use lmb_alloc() which will first add all available memory and then carve out reserved regions. There are calls for arch (arch_lmb_reserve()) and board (board_lmb_reserve()) callbacks. The interesting thing is that, there is also code to carve out any reserved regions which were added to the fdt earlier (boot_fdt_add_mem_rsv_regions()). The problem here is, that the DT fixups, which might add the reserved regions are called just before jumping to linux. Thus both the allocation for the fdt (if fdt_high is set) and the ramdisk (if initrd_high is set) will ignore any reserved memory regions.
Unfortunately, I don't see any good way to fix this. You'd need all the DT fixups before we can initialize the lmb. Also, I don't know if this will affect any other areas; probably I'm the only one, who reserves an area which is outside of the u-boot code and data segment.
A hackish way would be to carve out the spin_table code in board_lmb_reserve(). But meh..
-michael
Date: Sun, 31 Oct 2021 11:43:38 +0100 From: Michael Walle michael@walle.cc
The spin table is embedded in the u-boot binary itself isn't it? But the memory occupied by the u-boot should already be reserved...
Unless CONFIG_EFI_LOADER is defined. Then it relocates the spin table to memory allocated using efi_allocate_pages(). But that function only looks at the EFI memory map to figure out what memory is available. So I suspect that it might hand out the same memory as lmb_alloc(). It all looks a bit broken to me...
Does your target end up with CONFIG_EFI_LOADER defined?
Am 2021-10-31 12:44, schrieb Mark Kettenis:
Yes it is. As long as it doen't overlap with the 64k EFI code page. See below.
Yes, that is actually my code ;) The kontron_sl28 is the only board which uses spin tables as far as I know. It doesn't support PSCI; at least if you don't load a bl31 TF-A. Therefore, for SMP it uses spin tables. The relocation code work arounds a problem with the reserved EFI code, see [1].
And yes, it actually is broken. But so might be every code which is using the efi_allocate_pages(), no? LMB isn't global, but is just initialized at different places. Like before a linux kernel is booted or when you load a file (?). And everytime the whole memory is added, and then different regions are carved out (see above).
Yes ;)
-michael
[1] https://lore.kernel.org/u-boot/20200601195336.3237-1-michael@walle.cc/
Date: Sun, 31 Oct 2021 13:04:40 +0100 From: Michael Walle michael@walle.cc
Yes, I saw the comment. Which confuses me. The overlap itself shouldn't be a problem since both the spin table and the EFI runtime code page should be preserved. But I guess that the overlap causes problems later on because attempting to reserve overlapping areas fails?
Right. So it mostly works because U-Boot either ends up using a code path where it uses LMB or a path where it ends up using the EFI memory map, but never both. Except if it hits your layerscape code.
I think the right way to solve this is to allocate the memory for the spin table through some other means and use efi_add_memory_map() to reserve that memory like what is done in board/raspberrypi/rpi/rpi.c.
Or don't relocate the spin table and fix the issue with overlapping reserves.
Cheers,
Mark
Am 2021-10-31 13:51, schrieb Mark Kettenis:
TBH I don't remember the specifics anymore, my first try to fix this problem was here [1]. But the conclusion was that reserving 64k for the EFI alone would increase the binary size a lot. Thus Heinrich suggested to relocate the spin table code.
Mh. I don't think this will work, just because lmb is quite stupid and has just the three steps to carve out memory: (1) arch_lmb_reserve() (2) board_lmb_reserve() (3) boot_fdt_add_mem_rsv_regions()
(1) will carve out u-boot code and data (2) is usually not used and (3) doesn't really work IMHO, because the reserved regions are added much later in the bootm flow.
So what would "other means" be? I could allocate the memory somehow, but how can I communicate that to lmb, so it would be excluded there.
Which hadn't much appeal ;) And doesn't fix (fundamental) lmb problem.
-michael
[1] https://lore.kernel.org/u-boot/20200514123831.30157-2-michael@walle.cc/
Date: Sun, 31 Oct 2021 16:19:56 +0100 From: Michael Walle michael@walle.cc
Ah right, the overlap is somewhat problematic since the EFI memory types don't match. Now that in itself isn't an issue as long as the memory page attributes are the same. As far as I can tell, both the spin table and the EFI runtime services code would use EFI_MEMORY_WB, so that would be fine.
It could be a simple:
memalign(PAGE_SIZE, PAGE_SIZE);
This would allocate memory from the heap which should be excluded from what lmb hands out.
Am 2021-10-31 18:36, schrieb Mark Kettenis:
Thanks, that was easy ;) Turns out the heap is between the stack and the uboot code which is reserved by lmb (arch_lmb_reserve()).
-michael
Mark Kettenis
Michael Walle
