[U-Boot] [PATCH 0/4] No GOT in IRQ and use r12 as GOT ptr
This series removes the needs to access the GOT in IRQ handlers, then switches GOT PTR in start.S asm to use r12 instead of r14. This leads up to the removal of -ffixed-r14 gcc option for ppc
This is a resend since the it seems like the series was lost
Joakim Tjernlund (3): ppc: Loose GOT access in IRQ ppc: Use r12 instead of r14 as GOT pointer. ppc: remove -ffixed-r14 gcc option. ppc: Update README about the new GOT ptr.
cpu/74xx_7xx/config.mk | 2 +- cpu/74xx_7xx/start.S | 47 +++++++--------------------------------- cpu/mpc512x/config.mk | 2 +- cpu/mpc512x/start.S | 46 +++++++-------------------------------- cpu/mpc5xx/config.mk | 2 +- cpu/mpc5xx/start.S | 48 +++++++---------------------------------- cpu/mpc5xxx/config.mk | 2 +- cpu/mpc5xxx/start.S | 46 +++++++-------------------------------- cpu/mpc8220/config.mk | 2 +- cpu/mpc8220/start.S | 46 +++++++-------------------------------- cpu/mpc824x/config.mk | 2 +- cpu/mpc824x/start.S | 44 +++++++------------------------------ cpu/mpc8260/config.mk | 2 +- cpu/mpc8260/start.S | 50 ++++++++++--------------------------------- cpu/mpc83xx/config.mk | 2 +- cpu/mpc83xx/start.S | 45 +++++++------------------------------- cpu/mpc85xx/config.mk | 2 +- cpu/mpc85xx/start.S | 44 +++++++------------------------------ cpu/mpc86xx/config.mk | 2 +- cpu/mpc86xx/start.S | 47 +++++++--------------------------------- cpu/mpc8xx/config.mk | 2 +- cpu/mpc8xx/start.S | 47 +++++++--------------------------------- cpu/ppc4xx/config.mk | 2 +- cpu/ppc4xx/start.S | 44 +++++++------------------------------ include/ppc_asm.tmpl | 55 ++++++++++++++++++++++------------------------- lib_ppc/Makefile | 1 + lib_ppc/reloc.S | 49 ++++++++++++++++++++++++++++++++++++++++++ README | 4 +++- 28 files changed, 202 insertions(+), 485 deletions(-) create mode 100644 lib_ppc/reloc.S
Using the GOT in IRQ handlers requires r14 to be -ffixed-r14. Avoid this by relocatate transfer_to_handler too. This will allow to free up r14 later on. --- cpu/74xx_7xx/start.S | 36 +++--------------------------------- cpu/mpc512x/start.S | 35 +++-------------------------------- cpu/mpc5xx/start.S | 37 +++---------------------------------- cpu/mpc5xxx/start.S | 35 +++-------------------------------- cpu/mpc8220/start.S | 35 +++-------------------------------- cpu/mpc824x/start.S | 33 +++------------------------------ cpu/mpc8260/start.S | 35 +++-------------------------------- cpu/mpc83xx/start.S | 34 +++------------------------------- cpu/mpc85xx/start.S | 33 +++------------------------------ cpu/mpc86xx/start.S | 36 +++--------------------------------- cpu/mpc8xx/start.S | 36 +++--------------------------------- cpu/ppc4xx/start.S | 33 +++------------------------------ include/ppc_asm.tmpl | 47 ++++++++++++++++++++++------------------------- lib_ppc/Makefile | 1 + lib_ppc/reloc.S | 49 +++++++++++++++++++++++++++++++++++++++++++++++++ 15 files changed, 108 insertions(+), 407 deletions(-) create mode 100644 lib_ppc/reloc.S
diff --git a/cpu/74xx_7xx/start.S b/cpu/74xx_7xx/start.S index 23381a3..efcd95f 100644 --- a/cpu/74xx_7xx/start.S +++ b/cpu/74xx_7xx/start.S @@ -132,28 +132,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
/* Program check exception */ . = 0x700 ProgramCheck: EXCEPTION_PROLOG(SRR0, SRR1) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_ProgramCheck: - .long ProgramCheckException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(ProgramCheck, ProgramCheckException, + MSR_KERNEL, COPY_EE)
/* No FPU on MPC8xx. This exception is not supposed to happen. */ @@ -837,23 +824,6 @@ trap_init: mtlr r4 /* restore link register */ blr
- /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - sync - isync - - blr - #ifdef CONFIG_SYS_INIT_RAM_LOCK lock_ram_in_cache: /* Allocate Initial RAM in data cache. diff --git a/cpu/mpc512x/start.S b/cpu/mpc512x/start.S index 4edc8e9..46c5efa 100644 --- a/cpu/mpc512x/start.S +++ b/cpu/mpc512x/start.S @@ -127,30 +127,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - rlwimi r20,r23,0,25,25 /* copy IP bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
/* Program check exception */ . = 0x700 ProgramCheck: EXCEPTION_PROLOG(SRR0, SRR1) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - rlwimi r20,r23,0,25,25 /* copy IP bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_ProgramCheck: - .long ProgramCheckException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(ProgramCheck, ProgramCheckException, + MSR_KERNEL, COPY_EE)
/* Floating Point Unit unavailable exception */ STD_EXCEPTION(0x800, FPUnavailable, UnknownException) @@ -723,17 +708,3 @@ trap_init:
mtlr r4 /* restore link register */ blr - - /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - blr diff --git a/cpu/mpc5xx/start.S b/cpu/mpc5xx/start.S index 85ea7a8..be980a1 100644 --- a/cpu/mpc5xx/start.S +++ b/cpu/mpc5xx/start.S @@ -217,28 +217,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
/* FPU on MPC5xx available. We will use it later. */ @@ -563,24 +550,6 @@ trap_init: mtlr r4 /* restore link register */ blr
- /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - sync - isync - - blr - - #if defined(CONFIG_PATI) /* Program the PLL */ pll_prog_code_start: diff --git a/cpu/mpc5xxx/start.S b/cpu/mpc5xxx/start.S index eb42939..075a7dd 100644 --- a/cpu/mpc5xxx/start.S +++ b/cpu/mpc5xxx/start.S @@ -215,30 +215,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - rlwimi r20,r23,0,25,25 /* copy IP bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
@@ -797,17 +782,3 @@ trap_init:
mtlr r4 /* restore link register */ blr - - /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - blr diff --git a/cpu/mpc8220/start.S b/cpu/mpc8220/start.S index af9472d..5218c85 100644 --- a/cpu/mpc8220/start.S +++ b/cpu/mpc8220/start.S @@ -176,30 +176,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - rlwimi r20,r23,0,25,25 /* copy IP bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
@@ -762,17 +747,3 @@ trap_init:
mtlr r4 /* restore link register */ blr - - /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - blr diff --git a/cpu/mpc824x/start.S b/cpu/mpc824x/start.S index 750457b..7f40648 100644 --- a/cpu/mpc824x/start.S +++ b/cpu/mpc824x/start.S @@ -227,28 +227,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
/* Program check exception */ . = EXC_OFF_PROGRAM ProgramCheck: EXCEPTION_PROLOG(SRR0, SRR1) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_ProgramCheck: - .long ProgramCheckException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(ProgramCheck, ProgramCheckException, + MSR_KERNEL, COPY_EE)
/* No FPU on MPC8xx. This exception is not supposed to happen. */ @@ -695,20 +682,6 @@ trap_init: mtlr r4 /* restore link register */ blr
- /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - blr - /* Setup the BAT registers. */ setup_bats: diff --git a/cpu/mpc8260/start.S b/cpu/mpc8260/start.S index edb95e6..7d80af5 100644 --- a/cpu/mpc8260/start.S +++ b/cpu/mpc8260/start.S @@ -286,30 +286,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - rlwimi r20,r23,0,25,25 /* copy IP bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
@@ -1033,17 +1018,3 @@ trap_init:
mtlr r4 /* restore link register */ blr - - /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - blr diff --git a/cpu/mpc83xx/start.S b/cpu/mpc83xx/start.S index ee4b862..5a50b09 100644 --- a/cpu/mpc83xx/start.S +++ b/cpu/mpc83xx/start.S @@ -338,30 +338,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - rlwimi r20,r23,0,25,25 /* copy IP bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
@@ -1086,19 +1071,6 @@ trap_init: mtlr r4 /* restore link register */ blr
- /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - blr #endif /* !CONFIG_NAND_SPL */
#ifdef CONFIG_SYS_INIT_RAM_LOCK diff --git a/cpu/mpc85xx/start.S b/cpu/mpc85xx/start.S index 6a86528..6fafbb7 100644 --- a/cpu/mpc85xx/start.S +++ b/cpu/mpc85xx/start.S @@ -409,28 +409,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + _START_OFFSET - .long int_return - _start + _START_OFFSET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
/* Program check exception */ . = 0x0700 ProgramCheck: EXCEPTION_PROLOG(SRR0, SRR1) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_ProgramCheck: - .long ProgramCheckException - _start + _START_OFFSET - .long int_return - _start + _START_OFFSET + EXC_XFER_TEMPLATE(ProgramCheck, ProgramCheckException, + MSR_KERNEL, COPY_EE)
/* No FPU on MPC85xx. This exception is not supposed to happen. */ @@ -1083,20 +1070,6 @@ trap_init: mtlr r4 /* restore link register */ blr
- /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0,0(r7) /* hdlr ... */ - add r0,r0,r3 /* ... += dest_addr */ - stw r0,0(r7) - - lwz r0,4(r7) /* int_return ... */ - add r0,r0,r3 /* ... += dest_addr */ - stw r0,4(r7) - - blr - .globl unlock_ram_in_cache unlock_ram_in_cache: /* invalidate the INIT_RAM section */ diff --git a/cpu/mpc86xx/start.S b/cpu/mpc86xx/start.S index e65f1c0..eaa2657 100644 --- a/cpu/mpc86xx/start.S +++ b/cpu/mpc86xx/start.S @@ -121,28 +121,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
@@ -848,23 +835,6 @@ trap_init: mtlr r4 /* restore link register */ blr
- /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - sync - isync - - blr - .globl enable_ext_addr enable_ext_addr: mfspr r0, HID0 diff --git a/cpu/mpc8xx/start.S b/cpu/mpc8xx/start.S index e84326e..24e9053 100644 --- a/cpu/mpc8xx/start.S +++ b/cpu/mpc8xx/start.S @@ -231,28 +231,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + EXC_OFF_SYS_RESET - .long int_return - _start + EXC_OFF_SYS_RESET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
/* No FPU on MPC8xx. This exception is not supposed to happen. */ @@ -694,20 +681,3 @@ trap_init:
mtlr r4 /* restore link register */ blr - - /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - sync - isync - - blr diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index 46f65aa..2eb21fa 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -574,28 +574,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + _START_OFFSET - .long int_return - _start + _START_OFFSET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
/* Program check exception */ . = 0x700 ProgramCheck: EXCEPTION_PROLOG(SRR0, SRR1) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_ProgramCheck: - .long ProgramCheckException - _start + _START_OFFSET - .long int_return - _start + _START_OFFSET + EXC_XFER_TEMPLATE(ProgramCheck, ProgramCheckException, + MSR_KERNEL, COPY_EE)
#ifdef CONFIG_440 STD_EXCEPTION(0x800, FPUnavailable, UnknownException) @@ -1742,20 +1729,6 @@ __440_msr_continue: mtlr r4 /* restore link register */ blr
- /* - * Function: relocate entries for one exception vector - */ -trap_reloc: - lwz r0, 0(r7) /* hdlr ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 0(r7) - - lwz r0, 4(r7) /* int_return ... */ - add r0, r0, r3 /* ... += dest_addr */ - stw r0, 4(r7) - - blr - #if defined(CONFIG_440) /*----------------------------------------------------------------------------+ | dcbz_area. diff --git a/include/ppc_asm.tmpl b/include/ppc_asm.tmpl index 0019d46..fa5c5f6 100644 --- a/include/ppc_asm.tmpl +++ b/include/ppc_asm.tmpl @@ -257,46 +257,43 @@ * OFFSET values only; they must be relocated first before they can * be used! */ -#define STD_EXCEPTION(n, label, hdlr) \ - . = n; \ -label: \ - EXCEPTION_PROLOG(SRR0, SRR1); \ - lwz r3,GOT(transfer_to_handler); \ - mtlr r3; \ - addi r3,r1,STACK_FRAME_OVERHEAD; \ - li r20,MSR_KERNEL; \ +#define COPY_EE(d, s) rlwimi d,s,0,16,16 +#define NOCOPY(d, s) +#define EXC_XFER_TEMPLATE(label, hdlr, msr, copyee) \ + bl 1f; \ +1: mflr r20; \ + lwz r20,(.L_ ## label)-1b+8(r20); \ + mtlr r20; \ + li r20,msr; \ + copyee(r20,r23); \ rlwimi r20,r23,0,25,25; \ blrl; \ .L_ ## label : \ .long hdlr - _start + _START_OFFSET; \ - .long int_return - _start + _START_OFFSET + .long int_return - _start + _START_OFFSET; \ + .long transfer_to_handler - _start + _START_OFFSET + +#define STD_EXCEPTION(n, label, hdlr) \ + . = n; \ +label: \ + EXCEPTION_PROLOG(SRR0, SRR1); \ + addi r3,r1,STACK_FRAME_OVERHEAD; \ + EXC_XFER_TEMPLATE(label, hdlr, MSR_KERNEL, NOCOPY) \
#define CRIT_EXCEPTION(n, label, hdlr) \ . = n; \ label: \ EXCEPTION_PROLOG(CSRR0, CSRR1); \ - lwz r3,GOT(transfer_to_handler); \ - mtlr r3; \ addi r3,r1,STACK_FRAME_OVERHEAD; \ - li r20,(MSR_KERNEL & ~(MSR_ME|MSR_DE|MSR_CE)); \ - rlwimi r20,r23,0,25,25; \ - blrl; \ -.L_ ## label : \ - .long hdlr - _start + _START_OFFSET; \ - .long crit_return - _start + _START_OFFSET + EXC_XFER_TEMPLATE(label, hdlr, \ + MSR_KERNEL & ~(MSR_ME|MSR_DE|MSR_CE), NOCOPY) \
#define MCK_EXCEPTION(n, label, hdlr) \ . = n; \ label: \ EXCEPTION_PROLOG(MCSRR0, MCSRR1); \ - lwz r3,GOT(transfer_to_handler); \ - mtlr r3; \ addi r3,r1,STACK_FRAME_OVERHEAD; \ - li r20,(MSR_KERNEL & ~(MSR_ME|MSR_DE|MSR_CE)); \ - rlwimi r20,r23,0,25,25; \ - blrl; \ -.L_ ## label : \ - .long hdlr - _start + _START_OFFSET; \ - .long mck_return - _start + _START_OFFSET + EXC_XFER_TEMPLATE(label, hdlr, \ + MSR_KERNEL & ~(MSR_ME|MSR_DE|MSR_CE), NOCOPY) \
#endif /* __PPC_ASM_TMPL__ */ diff --git a/lib_ppc/Makefile b/lib_ppc/Makefile index 399b41e..3e209d0 100644 --- a/lib_ppc/Makefile +++ b/lib_ppc/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)lib$(ARCH).a SOBJS-y += ppccache.o SOBJS-y += ppcstring.o SOBJS-y += ticks.o +SOBJS-y += reloc.o
COBJS-y += bat_rw.o COBJS-y += board.o diff --git a/lib_ppc/reloc.S b/lib_ppc/reloc.S new file mode 100644 index 0000000..50f9a83 --- /dev/null +++ b/lib_ppc/reloc.S @@ -0,0 +1,49 @@ +/* + * Copyright (C) 2009 Wolfgang Denk wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <ppc_asm.tmpl> + + .file "reloc.S" + + .text +#ifndef CONFIG_NAND_SPL + /* + * Function: relocate entries for one exception vector + */ + .globl trap_reloc + .type trap_reloc, @function +trap_reloc: + lwz r0, 0(r7) /* hdlr ... */ + add r0, r0, r3 /* ... += dest_addr */ + stw r0, 0(r7) + + lwz r0, 4(r7) /* int_return ... */ + add r0, r0, r3 /* ... += dest_addr */ + stw r0, 4(r7) + + lwz r0, 8(r7) /* transfer_to_handler ...*/ + add r0, r0, r3 /* ... += dest_addr */ + stw r0, 8(r7) + + blr + .size trap_reloc, .-trap_reloc +#endif
r14 is not supposed to be clobbered by functions. Switch to r12 and call GET_GOT when needed. This will allow u-boot to loose the -ffixed-r14 gcc option. --- cpu/74xx_7xx/start.S | 11 ++++++----- cpu/mpc512x/start.S | 11 ++++++----- cpu/mpc5xx/start.S | 11 ++++++----- cpu/mpc5xxx/start.S | 11 ++++++----- cpu/mpc8220/start.S | 11 ++++++----- cpu/mpc824x/start.S | 11 ++++++----- cpu/mpc8260/start.S | 15 +++++++++------ cpu/mpc83xx/start.S | 11 ++++++----- cpu/mpc85xx/start.S | 11 ++++++----- cpu/mpc86xx/start.S | 11 ++++++----- cpu/mpc8xx/start.S | 11 ++++++----- cpu/ppc4xx/start.S | 11 ++++++----- include/ppc_asm.tmpl | 8 ++++---- 13 files changed, 79 insertions(+), 65 deletions(-)
diff --git a/cpu/74xx_7xx/start.S b/cpu/74xx_7xx/start.S index efcd95f..88fdf88 100644 --- a/cpu/74xx_7xx/start.S +++ b/cpu/74xx_7xx/start.S @@ -63,7 +63,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -599,6 +599,7 @@ relocate_code: mr r9, r4 /* Save copy of Global Data pointer */ mr r10, r5 /* Save copy of Destination Address */
+ GET_GOT mr r3, r5 /* Destination Address */ lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4, r4, CONFIG_SYS_MONITOR_BASE@l @@ -616,7 +617,7 @@ relocate_code: sub r15, r10, r4
/* First our own GOT */ - add r14, r14, r15 + add r12, r12, r15 /* then the one used by the C code */ add r30, r30, r15
@@ -691,7 +692,7 @@ in_ram: bl board_init_ecc #endif /* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -765,6 +766,8 @@ in_ram: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7, GOT(_start) lwz r8, GOT(_end_of_vectors)
@@ -772,8 +775,6 @@ trap_init:
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/mpc512x/start.S b/cpu/mpc512x/start.S index 46c5efa..d26b617 100644 --- a/cpu/mpc512x/start.S +++ b/cpu/mpc512x/start.S @@ -65,7 +65,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -486,6 +486,7 @@ relocate_code: mr r9, r4 /* Save copy of Global Data pointer */ mr r10, r5 /* Save copy of Destination Address */
+ GET_GOT mr r3, r5 /* Destination Address */ lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4, r4, CONFIG_SYS_MONITOR_BASE@l @@ -504,7 +505,7 @@ relocate_code: sub r15, r10, r4
@@ -584,7 +585,7 @@ relocate_code:
in_ram: /* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -648,6 +649,8 @@ clear_bss: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7, GOT(_start) lwz r8, GOT(_end_of_vectors)
@@ -655,8 +658,6 @@ trap_init:
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/mpc5xx/start.S b/cpu/mpc5xx/start.S index be980a1..0af879e 100644 --- a/cpu/mpc5xx/start.S +++ b/cpu/mpc5xx/start.S @@ -56,7 +56,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -372,6 +372,7 @@ relocate_code: mr r9, r4 /* Save copy of global data pointer in SRAM */ mr r10, r5 /* Save copy of monitor destination Address in SRAM */
+ GET_GOT mr r3, r5 /* Destination Address */ lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4, r4, CONFIG_SYS_MONITOR_BASE@l @@ -388,7 +389,7 @@ relocate_code: sub r15, r10, r4
/* First our own GOT */ - add r14, r14, r15 + add r12, r12, r15 /* the the one used by the C code */ add r30, r30, r15
@@ -433,7 +434,7 @@ relocate_code: in_ram:
/* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -497,6 +498,8 @@ clear_bss: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7, GOT(_start) lwz r8, GOT(_end_of_vectors)
@@ -504,8 +507,6 @@ trap_init:
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/mpc5xxx/start.S b/cpu/mpc5xxx/start.S index 075a7dd..d499da5 100644 --- a/cpu/mpc5xxx/start.S +++ b/cpu/mpc5xxx/start.S @@ -56,7 +56,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -567,6 +567,7 @@ relocate_code: mr r9, r4 /* Save copy of Global Data pointer */ mr r10, r5 /* Save copy of Destination Address */
+ GET_GOT mr r3, r5 /* Destination Address */ lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4, r4, CONFIG_SYS_MONITOR_BASE@l @@ -584,7 +585,7 @@ relocate_code: sub r15, r10, r4
@@ -657,7 +658,7 @@ relocate_code: in_ram:
/* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -722,6 +723,8 @@ clear_bss: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7, GOT(_start) lwz r8, GOT(_end_of_vectors)
@@ -729,8 +732,6 @@ trap_init:
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/mpc8220/start.S b/cpu/mpc8220/start.S index 5218c85..e28999d 100644 --- a/cpu/mpc8220/start.S +++ b/cpu/mpc8220/start.S @@ -55,7 +55,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -532,6 +532,7 @@ relocate_code: mr r9, r4 /* Save copy of Global Data pointer */ mr r10, r5 /* Save copy of Destination Address */
+ GET_GOT mr r3, r5 /* Destination Address */ lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4, r4, CONFIG_SYS_MONITOR_BASE@l @@ -549,7 +550,7 @@ relocate_code: sub r15, r10, r4
@@ -622,7 +623,7 @@ relocate_code: in_ram:
/* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -687,6 +688,8 @@ clear_bss: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7, GOT(_start) lwz r8, GOT(_end_of_vectors)
@@ -694,8 +697,6 @@ trap_init:
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/mpc824x/start.S b/cpu/mpc824x/start.S index 7f40648..f3f595a 100644 --- a/cpu/mpc824x/start.S +++ b/cpu/mpc824x/start.S @@ -63,7 +63,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -462,6 +462,7 @@ relocate_code: mr r9, r4 /* Save copy of Global Data pointer */ mr r10, r5 /* Save copy of Destination Address */
+ GET_GOT mr r3, r5 /* Destination Address */ #ifdef CONFIG_SYS_RAMBOOT lis r4, CONFIG_SYS_SDRAM_BASE@h /* Source Address */ @@ -484,7 +485,7 @@ relocate_code: sub r15, r10, r4
@@ -564,7 +565,7 @@ relocate_code: in_ram:
/* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -629,6 +630,8 @@ clear_bss: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7, GOT(_start) lwz r8, GOT(_end_of_vectors)
@@ -636,8 +639,6 @@ trap_init:
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/mpc8260/start.S b/cpu/mpc8260/start.S index 7d80af5..1fc70bc 100644 --- a/cpu/mpc8260/start.S +++ b/cpu/mpc8260/start.S @@ -56,7 +56,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -650,7 +650,9 @@ init_debug: /* RAM should now be operational */
#define VEC_WRD_CNT ((_end_of_vectors - _start + EXC_OFF_SYS_RESET) / 4) - + mflr r3 + GET_GOT + mtlr r3 lwz r3, GOT(_end_of_vectors) rlwinm r4, r3, 0, 18, 31 /* _end_of_vectors & 0x3FFF */ lis r5, VEC_WRD_CNT@h @@ -792,6 +794,7 @@ relocate_code: mr r9, r4 /* Save copy of Global Data pointer */ mr r10, r5 /* Save copy of Destination Address */
+ GET_GOT mr r3, r5 /* Destination Address */ lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4, r4, CONFIG_SYS_MONITOR_BASE@l @@ -809,7 +812,7 @@ relocate_code: sub r15, r10, r4
@@ -882,7 +885,7 @@ relocate_code: in_ram:
/* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -958,6 +961,8 @@ clear_bss: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7, GOT(_start) lwz r8, GOT(_end_of_vectors)
@@ -965,8 +970,6 @@ trap_init:
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/mpc83xx/start.S b/cpu/mpc83xx/start.S index 5a50b09..68bb620 100644 --- a/cpu/mpc83xx/start.S +++ b/cpu/mpc83xx/start.S @@ -65,7 +65,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -830,6 +830,7 @@ relocate_code: mr r9, r4 /* Save copy of Global Data pointer */ mr r10, r5 /* Save copy of Destination Address */
+ GET_GOT mr r3, r5 /* Destination Address */ lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4, r4, CONFIG_SYS_MONITOR_BASE@l @@ -848,7 +849,7 @@ relocate_code: sub r15, r10, r4
@@ -930,7 +931,7 @@ relocate_code: in_ram:
/* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -1010,6 +1011,8 @@ clear_bss: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7, GOT(_start) lwz r8, GOT(_end_of_vectors)
@@ -1017,8 +1020,6 @@ trap_init:
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/mpc85xx/start.S b/cpu/mpc85xx/start.S index 6fafbb7..79306e2 100644 --- a/cpu/mpc85xx/start.S +++ b/cpu/mpc85xx/start.S @@ -51,7 +51,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -865,6 +865,7 @@ relocate_code: mr r9,r4 /* Save copy of Init Data pointer */ mr r10,r5 /* Save copy of Destination Address */
+ GET_GOT mr r3,r5 /* Destination Address */ lis r4,CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4,r4,CONFIG_SYS_MONITOR_BASE@l @@ -882,7 +883,7 @@ relocate_code: sub r15,r10,r4
/* First our own GOT */ - add r14,r14,r15 + add r12,r12,r15 /* the the one used by the C code */ add r30,r30,r15
@@ -952,7 +953,7 @@ relocate_code: in_ram:
/* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -1018,6 +1019,8 @@ clear_bss: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7,GOT(_start_of_vectors) lwz r8,GOT(_end_of_vectors)
@@ -1025,8 +1028,6 @@ trap_init:
cmplw 0,r7,r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0,0(r7) stw r0,0(r9) diff --git a/cpu/mpc86xx/start.S b/cpu/mpc86xx/start.S index eaa2657..ed1e4ca 100644 --- a/cpu/mpc86xx/start.S +++ b/cpu/mpc86xx/start.S @@ -52,7 +52,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -630,6 +630,7 @@ relocate_code: mr r9, r4 /* Save copy of Global Data pointer */ mr r10, r5 /* Save copy of Destination Address */
+ GET_GOT mr r3, r5 /* Destination Address */ lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4, r4, CONFIG_SYS_MONITOR_BASE@l @@ -647,7 +648,7 @@ relocate_code: sub r15, r10, r4
@@ -708,7 +709,7 @@ relocate_code:
in_ram: /* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -775,6 +776,8 @@ in_ram: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7, GOT(_start) lwz r8, GOT(_end_of_vectors)
@@ -782,8 +785,6 @@ trap_init:
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/mpc8xx/start.S b/cpu/mpc8xx/start.S index 24e9053..7cf602f 100644 --- a/cpu/mpc8xx/start.S +++ b/cpu/mpc8xx/start.S @@ -63,7 +63,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -482,6 +482,7 @@ relocate_code: mr r9, r4 /* Save copy of Global Data pointer */ mr r10, r5 /* Save copy of Destination Address */
+ GET_GOT mr r3, r5 /* Destination Address */ lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4, r4, CONFIG_SYS_MONITOR_BASE@l @@ -499,7 +500,7 @@ relocate_code: sub r15, r10, r4
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index 2eb21fa..927c88c 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -228,7 +228,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ #if !defined(CONFIG_NAND_SPL) START_GOT @@ -1489,6 +1489,7 @@ relocate_code: mr r9, r4 /* Save copy of Init Data pointer */ mr r10, r5 /* Save copy of Destination Address */
+ GET_GOT mr r3, r5 /* Destination Address */ lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4, r4, CONFIG_SYS_MONITOR_BASE@l @@ -1506,7 +1507,7 @@ relocate_code: sub r15, r10, r4
@@ -1571,7 +1572,7 @@ relocate_code: in_ram:
/* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -1645,6 +1646,8 @@ clear_bss: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7, GOT(_start_of_vectors) lwz r8, GOT(_end_of_vectors)
@@ -1652,8 +1655,6 @@ trap_init:
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/include/ppc_asm.tmpl b/include/ppc_asm.tmpl index fa5c5f6..84de146 100644 --- a/include/ppc_asm.tmpl +++ b/include/ppc_asm.tmpl @@ -50,13 +50,13 @@ .text 2 ; \ 0: .long .LCTOC1-1f ; \ .text ; \ -1: mflr r14 ; \ - lwz r0,0b-1b(r14) ; \ - add r14,r0,r14 ; +1: mflr r12 ; \ + lwz r0,0b-1b(r12) ; \ + add r12,r0,r12 ;
#define GOT_ENTRY(NAME) .L_ ## NAME = . - .LCTOC1 ; .long NAME
-#define GOT(NAME) .L_ ## NAME (r14) +#define GOT(NAME) .L_ ## NAME (r12)
This is no loger needed, free up r14 for general usage. --- cpu/74xx_7xx/config.mk | 2 +- cpu/mpc512x/config.mk | 2 +- cpu/mpc5xx/config.mk | 2 +- cpu/mpc5xxx/config.mk | 2 +- cpu/mpc8220/config.mk | 2 +- cpu/mpc824x/config.mk | 2 +- cpu/mpc8260/config.mk | 2 +- cpu/mpc83xx/config.mk | 2 +- cpu/mpc85xx/config.mk | 2 +- cpu/mpc86xx/config.mk | 2 +- cpu/mpc8xx/config.mk | 2 +- cpu/ppc4xx/config.mk | 2 +- 12 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/cpu/74xx_7xx/config.mk b/cpu/74xx_7xx/config.mk index d589210..df1f6ac 100644 --- a/cpu/74xx_7xx/config.mk +++ b/cpu/74xx_7xx/config.mk @@ -21,6 +21,6 @@ # MA 02111-1307 USA #
-PLATFORM_RELFLAGS += -fPIC -ffixed-r14 -meabi +PLATFORM_RELFLAGS += -fPIC -meabi
PLATFORM_CPPFLAGS += -DCONFIG_74xx_7xx -ffixed-r2 -mstring diff --git a/cpu/mpc512x/config.mk b/cpu/mpc512x/config.mk index 6ab34b1..fb0a563 100644 --- a/cpu/mpc512x/config.mk +++ b/cpu/mpc512x/config.mk @@ -19,7 +19,7 @@ # Foundation, Inc., 59 Temple Place, Suite 330, Boston, # MA 02111-1307 USA # -PLATFORM_RELFLAGS += -fPIC -ffixed-r14 -meabi +PLATFORM_RELFLAGS += -fPIC -meabi
PLATFORM_CPPFLAGS += -DCONFIG_MPC512X -DCONFIG_E300 \ -ffixed-r2 -msoft-float -mcpu=603e diff --git a/cpu/mpc5xx/config.mk b/cpu/mpc5xx/config.mk index 157ddc5..7854924 100644 --- a/cpu/mpc5xx/config.mk +++ b/cpu/mpc5xx/config.mk @@ -28,7 +28,7 @@ #
PLATFORM_CPPFLAGS += -DCONFIG_5xx -ffixed-r2 -mpowerpc -msoft-float
diff --git a/cpu/mpc5xxx/config.mk b/cpu/mpc5xxx/config.mk index b0ce2ee..5e82f67 100644 --- a/cpu/mpc5xxx/config.mk +++ b/cpu/mpc5xxx/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
PLATFORM_CPPFLAGS += -DCONFIG_MPC5xxx -ffixed-r2 \ -mstring -mcpu=603e -mmultiple diff --git a/cpu/mpc8220/config.mk b/cpu/mpc8220/config.mk index 5819048..3ce40c0 100644 --- a/cpu/mpc8220/config.mk +++ b/cpu/mpc8220/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
PLATFORM_CPPFLAGS += -DCONFIG_MPC8220 -ffixed-r2 \ -mstring -mcpu=603e -mmultiple diff --git a/cpu/mpc824x/config.mk b/cpu/mpc824x/config.mk index b607fee..940474b 100644 --- a/cpu/mpc824x/config.mk +++ b/cpu/mpc824x/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
PLATFORM_CPPFLAGS += -DCONFIG_MPC824X -ffixed-r2 -mstring -mcpu=603e -msoft-float
diff --git a/cpu/mpc8260/config.mk b/cpu/mpc8260/config.mk index 2cb0270..39d81ee 100644 --- a/cpu/mpc8260/config.mk +++ b/cpu/mpc8260/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
PLATFORM_CPPFLAGS += -DCONFIG_8260 -DCONFIG_CPM2 -ffixed-r2 \ -mstring -mcpu=603e -mmultiple diff --git a/cpu/mpc83xx/config.mk b/cpu/mpc83xx/config.mk index d619426..e80919b 100644 --- a/cpu/mpc83xx/config.mk +++ b/cpu/mpc83xx/config.mk @@ -20,7 +20,7 @@ # MA 02111-1307 USA #
PLATFORM_CPPFLAGS += -DCONFIG_MPC83xx -DCONFIG_E300 \ -ffixed-r2 -msoft-float diff --git a/cpu/mpc85xx/config.mk b/cpu/mpc85xx/config.mk index beb3514..aa2c2f1 100644 --- a/cpu/mpc85xx/config.mk +++ b/cpu/mpc85xx/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
PLATFORM_CPPFLAGS += -ffixed-r2 -Wa,-me500 -msoft-float -mno-string PLATFORM_CPPFLAGS +=$(call cc-option,-mno-spe) diff --git a/cpu/mpc86xx/config.mk b/cpu/mpc86xx/config.mk index 13da2cf..ca2f837 100644 --- a/cpu/mpc86xx/config.mk +++ b/cpu/mpc86xx/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
PLATFORM_CPPFLAGS += -ffixed-r2 -mstring PLATFORM_CPPFLAGS += -maltivec -mabi=altivec -msoft-float diff --git a/cpu/mpc8xx/config.mk b/cpu/mpc8xx/config.mk index 2b3d545..5540d65 100644 --- a/cpu/mpc8xx/config.mk +++ b/cpu/mpc8xx/config.mk @@ -21,6 +21,6 @@ # MA 02111-1307 USA #
PLATFORM_CPPFLAGS += -DCONFIG_8xx -ffixed-r2 -mstring -mcpu=860 -msoft-float diff --git a/cpu/ppc4xx/config.mk b/cpu/ppc4xx/config.mk index 00ad39b..958e855 100644 --- a/cpu/ppc4xx/config.mk +++ b/cpu/ppc4xx/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
-PLATFORM_RELFLAGS += -fPIC -ffixed-r14 -meabi +PLATFORM_RELFLAGS += -fPIC -meabi PLATFORM_CPPFLAGS += -DCONFIG_4xx -ffixed-r2 -mstring -msoft-float
cfg=$(shell grep configs $(OBJTREE)/include/config.h | sed 's/.*<(configs.*)>/\1/')
r14 is no longer used as non volatile GOT ptr. Instead the volatile r12 is used so be sure to do GET_GOT in asm code when you need to access global data.
Signed-off-by: Joakim Tjernlund Joakim.Tjernlund@transmode.se --- README | 4 +++- 1 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/README b/README index 744f6bf..bfd9498 100644 --- a/README +++ b/README @@ -3916,7 +3916,9 @@ For PowerPC, the following registers have specific use: R30: GOT pointer R31: frame pointer
- (U-Boot also uses R14 as internal GOT pointer.) + (U-Boot also uses R12 as internal GOT pointer. r12 + is a volatile register so r12 needs to be reset when + going back and forth between asm and C)
==> U-Boot will use R2 to hold a pointer to the global data
Has this been forgotten(again)?
Jocke
Dear Joakim Tjernlund,
In message OFDE68EA42.2E6B3C0A-ONC12576A3.0050D905-C12576A3.00510037@transmode.se you wrote:
Jocke
Not really forgotten. Actually I was waiting for a resend - I thought these patches were still RFC.
I can't apply them as is, as the Signed-off-by: line is missing in patches 1, 2, and 3.
Wolfgang Denk wd@denx.de wrote on 17/01/2010 20:12:31:
In message <OFDE68EA42.2E6B3C0A-ONC12576A3.0050D905-C12576A3. 00510037@transmode.se> you wrote:
Jocke
Ouch, I will regenerate them next week then. Are you happy with them other the the missing SOB?
In message OF40260F27.B5C57B54-ONC12576AE.00740CD3-C12576AE.0074294E@transmode.se you wrote:
I have to admit that I didn't find the time for any real testing. I thought that I'll just throw them in so any problems will show up pretty quickly ;-)
Signed-off-by: Joakim Tjernlund Joakim.Tjernlund@transmode.se --- cpu/74xx_7xx/start.S | 36 +++--------------------------------- cpu/mpc512x/start.S | 35 +++-------------------------------- cpu/mpc5xx/start.S | 37 +++---------------------------------- cpu/mpc5xxx/start.S | 35 +++-------------------------------- cpu/mpc8220/start.S | 35 +++-------------------------------- cpu/mpc824x/start.S | 33 +++------------------------------ cpu/mpc8260/start.S | 35 +++-------------------------------- cpu/mpc83xx/start.S | 34 +++------------------------------- cpu/mpc85xx/start.S | 33 +++------------------------------ cpu/mpc86xx/start.S | 36 +++--------------------------------- cpu/mpc8xx/start.S | 36 +++--------------------------------- cpu/ppc4xx/start.S | 33 +++------------------------------ include/ppc_asm.tmpl | 47 ++++++++++++++++++++++------------------------- lib_ppc/Makefile | 1 + lib_ppc/reloc.S | 49 +++++++++++++++++++++++++++++++++++++++++++++++++ 15 files changed, 108 insertions(+), 407 deletions(-) create mode 100644 lib_ppc/reloc.S
#ifdef CONFIG_SYS_INIT_RAM_LOCK diff --git a/cpu/mpc85xx/start.S b/cpu/mpc85xx/start.S index 7e60e67..d73c5c2 100644 --- a/cpu/mpc85xx/start.S +++ b/cpu/mpc85xx/start.S @@ -415,28 +415,15 @@ Alignment: mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD - li r20,MSR_KERNEL - rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ - lwz r6,GOT(transfer_to_handler) - mtlr r6 - blrl -.L_Alignment: - .long AlignmentException - _start + _START_OFFSET - .long int_return - _start + _START_OFFSET + EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE)
/* No FPU on MPC85xx. This exception is not supposed to happen. */ @@ -1089,20 +1076,6 @@ trap_init: mtlr r4 /* restore link register */ blr
#endif /* __PPC_ASM_TMPL__ */ diff --git a/lib_ppc/Makefile b/lib_ppc/Makefile index 60a7625..334e457 100644 --- a/lib_ppc/Makefile +++ b/lib_ppc/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)lib$(ARCH).a SOBJS-y += ppccache.o SOBJS-y += ppcstring.o SOBJS-y += ticks.o +SOBJS-y += reloc.o
Signed-off-by: Joakim Tjernlund Joakim.Tjernlund@transmode.se --- cpu/74xx_7xx/start.S | 11 ++++++----- cpu/mpc512x/start.S | 11 ++++++----- cpu/mpc5xx/start.S | 11 ++++++----- cpu/mpc5xxx/start.S | 11 ++++++----- cpu/mpc8220/start.S | 11 ++++++----- cpu/mpc824x/start.S | 11 ++++++----- cpu/mpc8260/start.S | 15 +++++++++------ cpu/mpc83xx/start.S | 11 ++++++----- cpu/mpc85xx/start.S | 11 ++++++----- cpu/mpc86xx/start.S | 11 ++++++----- cpu/mpc8xx/start.S | 11 ++++++----- cpu/ppc4xx/start.S | 11 ++++++----- include/ppc_asm.tmpl | 8 ++++---- 13 files changed, 79 insertions(+), 65 deletions(-)
cmplw 0, r7, r8 bgelr /* return if r7>=r8 - just in case */ - - mflr r4 /* save link register */ 1: lwz r0, 0(r7) stw r0, 0(r9) diff --git a/cpu/mpc85xx/start.S b/cpu/mpc85xx/start.S index d73c5c2..386fa81 100644 --- a/cpu/mpc85xx/start.S +++ b/cpu/mpc85xx/start.S @@ -51,7 +51,7 @@ /* * Set up GOT: Global Offset Table * - * Use r14 to access the GOT + * Use r12 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) @@ -871,6 +871,7 @@ relocate_code: mr r9,r4 /* Save copy of Init Data pointer */ mr r10,r5 /* Save copy of Destination Address */
+ GET_GOT mr r3,r5 /* Destination Address */ lis r4,CONFIG_SYS_MONITOR_BASE@h /* Source Address */ ori r4,r4,CONFIG_SYS_MONITOR_BASE@l @@ -888,7 +889,7 @@ relocate_code: sub r15,r10,r4
@@ -958,7 +959,7 @@ relocate_code: in_ram:
/* - * Relocation Function, r14 point to got2+0x8000 + * Relocation Function, r12 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. @@ -1024,6 +1025,8 @@ clear_bss: */ .globl trap_init trap_init: + mflr r4 /* save link register */ + GET_GOT lwz r7,GOT(_start_of_vectors) lwz r8,GOT(_end_of_vectors)
@@ -1031,8 +1034,6 @@ trap_init:
Signed-off-by: Joakim Tjernlund Joakim.Tjernlund@transmode.se --- cpu/74xx_7xx/config.mk | 2 +- cpu/mpc512x/config.mk | 2 +- cpu/mpc5xx/config.mk | 2 +- cpu/mpc5xxx/config.mk | 2 +- cpu/mpc8220/config.mk | 2 +- cpu/mpc824x/config.mk | 2 +- cpu/mpc8260/config.mk | 2 +- cpu/mpc83xx/config.mk | 2 +- cpu/mpc85xx/config.mk | 2 +- cpu/mpc86xx/config.mk | 2 +- cpu/mpc8xx/config.mk | 2 +- cpu/ppc4xx/config.mk | 2 +- 12 files changed, 12 insertions(+), 12 deletions(-)
PLATFORM_CPPFLAGS += -DCONFIG_MPC83xx -DCONFIG_E300 \ -ffixed-r2 -msoft-float diff --git a/cpu/mpc85xx/config.mk b/cpu/mpc85xx/config.mk index 84651b8..408184a 100644 --- a/cpu/mpc85xx/config.mk +++ b/cpu/mpc85xx/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
PLATFORM_CPPFLAGS += -DCONFIG_8xx -ffixed-r2 -mstring -mcpu=860 -msoft-float diff --git a/cpu/ppc4xx/config.mk b/cpu/ppc4xx/config.mk index 979004b..c1de1e9 100644 --- a/cpu/ppc4xx/config.mk +++ b/cpu/ppc4xx/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
diff --git a/README b/README index 7affe10..263bb05 100644 --- a/README +++ b/README @@ -3922,7 +3922,9 @@ For PowerPC, the following registers have specific use: R30: GOT pointer R31: frame pointer
In message 1263908518-31835-4-git-send-email-Joakim.Tjernlund@transmode.se you wrote:
Applied, thanks!
In message 1263908518-31835-3-git-send-email-Joakim.Tjernlund@transmode.se you wrote:
Applied, thanks.
In message 1263908518-31835-1-git-send-email-Joakim.Tjernlund@transmode.se you wrote:
Applied, thanks.
Joakim Tjernlund
Joakim Tjernlund
