[PATCH 0/6] rockchip: rk3568: Fix use of PCIe bifurcation
This series add support for use of PCIe bifurcation on RK3568, and as a bonus support for the RK3588 PHY is also included. With PCIe bifurcation supported it is possible to enable PCIe on more RK3568 boards, e.g. on NanoPi R5C and NanoPi R5S. This series only include fixing the mini PCIe slot on Radxa E25.
Most parts of this series was imported almost 1:1 from mainline linux.
Patch 1 fixes configuration of number of lanes in pcie_dw_rockchip. Patch 2-3 refactor the snps-pcie3 phy driver. Patch 4 add bifurcation support for RK3568. Patch 5 add support for RK3588. Patch 6 enables the mini PCIe slot on Radxa E25.
The RK3588 PHY part was tested on a ROCK 5B together with device tree files picked from Sebastian Reichel's rk3588 branch at [1].
Patches in this series is also aviliable at [2].
[1] https://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-misc.git/tree/?h=r... [2] https://github.com/Kwiboo/u-boot-rockchip/commits/rk35xx-pcie-bifurcation-v1
Jonas Karlman (6): pci: pcie_dw_rockchip: Configure number of lanes and link width speed phy: rockchip: snps-pcie3: Refactor to use clk_bulk API phy: rockchip: snps-pcie3: Refactor to use a phy_init ops phy: rockchip: snps-pcie3: Add bifurcation support for RK3568 phy: rockchip: snps-pcie3: Add support for RK3588 rockchip: rk3568-radxa-e25: Enable pcie3x1 node
arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi | 11 +- configs/radxa-e25-rk3568_defconfig | 1 - drivers/pci/pcie_dw_rockchip.c | 58 ++++- .../phy/rockchip/phy-rockchip-snps-pcie3.c | 230 ++++++++++++++---- 4 files changed, 235 insertions(+), 65 deletions(-)
Set number of lanes and link width speed control register based on the num-lanes property.
Code imported almost 1:1 from dw_pcie_setup in mainline linux.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- drivers/pci/pcie_dw_rockchip.c | 58 +++++++++++++++++++++++++++++----- 1 file changed, 50 insertions(+), 8 deletions(-)
diff --git a/drivers/pci/pcie_dw_rockchip.c b/drivers/pci/pcie_dw_rockchip.c index 1a35fae5c3a8..bc4635f67136 100644 --- a/drivers/pci/pcie_dw_rockchip.c +++ b/drivers/pci/pcie_dw_rockchip.c @@ -18,6 +18,7 @@ #include <asm/io.h> #include <asm-generic/gpio.h> #include <dm/device_compat.h> +#include <linux/bitfield.h> #include <linux/iopoll.h> #include <linux/delay.h> #include <power/regulator.h> @@ -43,6 +44,7 @@ struct rk_pcie { struct reset_ctl_bulk rsts; struct gpio_desc rst_gpio; u32 gen; + u32 num_lanes; };
/* Parameters for the waiting for iATU enabled routine */ @@ -152,12 +154,13 @@ static inline void rk_pcie_writel_apb(struct rk_pcie *rk_pcie, u32 reg, * rk_pcie_configure() - Configure link capabilities and speed * * @rk_pcie: Pointer to the PCI controller state - * @cap_speed: The capabilities and speed to configure * * Configure the link capabilities and speed in the PCIe root complex. */ -static void rk_pcie_configure(struct rk_pcie *pci, u32 cap_speed) +static void rk_pcie_configure(struct rk_pcie *pci) { + u32 val; + dw_pcie_dbi_write_enable(&pci->dw, true);
/* Disable BAR 0 and BAR 1 */ @@ -167,11 +170,49 @@ static void rk_pcie_configure(struct rk_pcie *pci, u32 cap_speed) PCI_BASE_ADDRESS_1);
clrsetbits_le32(pci->dw.dbi_base + PCIE_LINK_CAPABILITY, - TARGET_LINK_SPEED_MASK, cap_speed); + TARGET_LINK_SPEED_MASK, pci->gen);
clrsetbits_le32(pci->dw.dbi_base + PCIE_LINK_CTL_2, - TARGET_LINK_SPEED_MASK, cap_speed); + TARGET_LINK_SPEED_MASK, pci->gen); + + /* Set the number of lanes */ + val = readl(pci->dw.dbi_base + PCIE_PORT_LINK_CONTROL); + val &= ~PORT_LINK_FAST_LINK_MODE; + val |= PORT_LINK_DLL_LINK_EN; + val &= ~PORT_LINK_MODE_MASK; + switch (pci->num_lanes) { + case 1: + val |= PORT_LINK_MODE_1_LANES; + break; + case 2: + val |= PORT_LINK_MODE_2_LANES; + break; + case 4: + val |= PORT_LINK_MODE_4_LANES; + break; + default: + dev_err(pci->dw.dev, "num-lanes %u: invalid value\n", pci->num_lanes); + goto out; + } + writel(val, pci->dw.dbi_base + PCIE_PORT_LINK_CONTROL); + + /* Set link width speed control register */ + val = readl(pci->dw.dbi_base + PCIE_LINK_WIDTH_SPEED_CONTROL); + val &= ~PORT_LOGIC_LINK_WIDTH_MASK; + switch (pci->num_lanes) { + case 1: + val |= PORT_LOGIC_LINK_WIDTH_1_LANES; + break; + case 2: + val |= PORT_LOGIC_LINK_WIDTH_2_LANES; + break; + case 4: + val |= PORT_LOGIC_LINK_WIDTH_4_LANES; + break; + } + writel(val, pci->dw.dbi_base + PCIE_LINK_WIDTH_SPEED_CONTROL);
+out: dw_pcie_dbi_write_enable(&pci->dw, false); }
@@ -231,11 +272,10 @@ static int is_link_up(struct rk_pcie *priv) * rk_pcie_link_up() - Wait for the link to come up * * @rk_pcie: Pointer to the PCI controller state - * @cap_speed: Desired link speed * * Return: 1 (true) for active line and negetive (false) for no link (timeout) */ -static int rk_pcie_link_up(struct rk_pcie *priv, u32 cap_speed) +static int rk_pcie_link_up(struct rk_pcie *priv) { int retries;
@@ -245,7 +285,7 @@ static int rk_pcie_link_up(struct rk_pcie *priv, u32 cap_speed) }
/* DW pre link configurations */ - rk_pcie_configure(priv, cap_speed); + rk_pcie_configure(priv);
rk_pcie_disable_ltssm(priv); rk_pcie_link_status_clear(priv); @@ -341,7 +381,7 @@ static int rockchip_pcie_init_port(struct udevice *dev) rk_pcie_writel_apb(priv, 0x0, 0xf00040); pcie_dw_setup_host(&priv->dw);
- ret = rk_pcie_link_up(priv, priv->gen); + ret = rk_pcie_link_up(priv); if (ret < 0) goto err_link_up;
@@ -419,6 +459,8 @@ static int rockchip_pcie_parse_dt(struct udevice *dev) priv->gen = dev_read_u32_default(dev, "max-link-speed", LINK_SPEED_GEN_3);
+ priv->num_lanes = dev_read_u32_default(dev, "num-lanes", 1); + return 0;
rockchip_pcie_parse_dt_err_phy_get_by_index:
Add support for the RK3588 variant to the driver.
Code imported almost 1:1 from mainline linux driver.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- .../phy/rockchip/phy-rockchip-snps-pcie3.c | 85 +++++++++++++++++++ 1 file changed, 85 insertions(+)
diff --git a/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c b/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c index 642819b1f672..a4392daf4c92 100644 --- a/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c +++ b/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c @@ -27,6 +27,17 @@
#define RK3568_BIFURCATION_LANE_0_1 BIT(0)
+/* Register for RK3588 */ +#define PHP_GRF_PCIESEL_CON 0x100 +#define RK3588_PCIE3PHY_GRF_CMN_CON0 0x0 +#define RK3588_PCIE3PHY_GRF_PHY0_STATUS1 0x904 +#define RK3588_PCIE3PHY_GRF_PHY1_STATUS1 0xa04 +#define RK3588_SRAM_INIT_DONE(reg) (reg & BIT(0)) + +#define RK3588_BIFURCATION_LANE_0_1 BIT(0) +#define RK3588_BIFURCATION_LANE_2_3 BIT(1) +#define RK3588_LANE_AGGREGATION BIT(2) + /** * struct rockchip_p3phy_priv - RK DW PCIe PHY state * @@ -40,6 +51,7 @@ struct rockchip_p3phy_priv { void __iomem *mmio; struct regmap *phy_grf; + struct regmap *pipe_grf; struct reset_ctl p30phy; struct clk_bulk clks; int num_lanes; @@ -93,6 +105,66 @@ static const struct rockchip_p3phy_ops rk3568_ops = { .phy_init = rockchip_p3phy_rk3568_init, };
+static int rockchip_p3phy_rk3588_init(struct phy *phy) +{ + struct rockchip_p3phy_priv *priv = dev_get_priv(phy->dev); + u32 reg = 0; + u8 mode = 0; + int ret; + + /* Deassert PCIe PMA output clamp mode */ + regmap_write(priv->phy_grf, RK3588_PCIE3PHY_GRF_CMN_CON0, + BIT(8) | BIT(24)); + + /* Set bifurcation if needed */ + for (int i = 0; i < priv->num_lanes; i++) { + if (!priv->lanes[i]) + mode |= (BIT(i) << 3); + + if (priv->lanes[i] > 1) + mode |= (BIT(i) >> 1); + } + + if (!mode) { + reg = RK3588_LANE_AGGREGATION; + } else { + if (mode & (BIT(0) | BIT(1))) + reg |= RK3588_BIFURCATION_LANE_0_1; + + if (mode & (BIT(2) | BIT(3))) + reg |= RK3588_BIFURCATION_LANE_2_3; + } + + regmap_write(priv->phy_grf, RK3588_PCIE3PHY_GRF_CMN_CON0, + (0x7 << 16) | reg); + + /* Set pcie1ln_sel in PHP_GRF_PCIESEL_CON */ + reg = (mode & (BIT(6) | BIT(7))) >> 6; + if (reg) + regmap_write(priv->pipe_grf, PHP_GRF_PCIESEL_CON, + (reg << 16) | reg); + + reset_deassert(&priv->p30phy); + udelay(1); + + ret = regmap_read_poll_timeout(priv->phy_grf, + RK3588_PCIE3PHY_GRF_PHY0_STATUS1, + reg, RK3588_SRAM_INIT_DONE(reg), + 0, 500); + ret |= regmap_read_poll_timeout(priv->phy_grf, + RK3588_PCIE3PHY_GRF_PHY1_STATUS1, + reg, RK3588_SRAM_INIT_DONE(reg), + 0, 500); + if (ret) + dev_err(phy->dev, "lock failed 0x%x\n", reg); + + return ret; +} + +static const struct rockchip_p3phy_ops rk3588_ops = { + .phy_init = rockchip_p3phy_rk3588_init, +}; + static int rochchip_p3phy_init(struct phy *phy) { struct rockchip_p3phy_ops *ops = @@ -139,6 +211,15 @@ static int rockchip_p3phy_probe(struct udevice *dev) return PTR_ERR(priv->phy_grf); }
+ if (device_is_compatible(dev, "rockchip,rk3588-pcie3-phy")) { + priv->pipe_grf = + syscon_regmap_lookup_by_phandle(dev, "rockchip,pipe-grf"); + if (IS_ERR(priv->pipe_grf)) { + dev_err(dev, "failed to find rockchip,pipe_grf regmap\n"); + return PTR_ERR(priv->pipe_grf); + } + } + ret = dev_read_size(dev, "data-lanes"); if (ret > 0) { priv->num_lanes = ret / sizeof(u32); @@ -181,6 +262,10 @@ static const struct udevice_id rockchip_p3phy_of_match[] = { .compatible = "rockchip,rk3568-pcie3-phy", .data = (ulong)&rk3568_ops, }, + { + .compatible = "rockchip,rk3588-pcie3-phy", + .data = (ulong)&rk3588_ops, + }, { }, };
Enable mini PCIe slot, pcie3x1 node, now that the PCIe PHY driver support bifurcation.
A pinctrl is assigned for reset-gpios or the device may freeze running pci enum and nothing is connected to the mini PCIe slot.
Also drop the AHCI_PCI Kconfig option as this option is not required for a functional M.2 SATA drive slot.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi | 11 +++++++++-- configs/radxa-e25-rk3568_defconfig | 1 - 2 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi b/arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi index 572bdc5665b1..1136f0bb3b81 100644 --- a/arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi +++ b/arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi @@ -8,9 +8,16 @@ }; };
-/* PCIe PHY driver in U-Boot does not support bifurcation */ &pcie3x1 { - status = "disabled"; + pinctrl-0 = <&pcie30x1_reset_h>; +}; + +&pinctrl { + pcie { + pcie30x1_reset_h: pcie30x1-reset-h { + rockchip,pins = <0 RK_PC3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; };
&sdhci { diff --git a/configs/radxa-e25-rk3568_defconfig b/configs/radxa-e25-rk3568_defconfig index a905100a794d..2dfff6af3bd1 100644 --- a/configs/radxa-e25-rk3568_defconfig +++ b/configs/radxa-e25-rk3568_defconfig @@ -54,7 +54,6 @@ CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigne CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y -CONFIG_AHCI_PCI=y CONFIG_DWC_AHCI=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y
Jonas Karlman
