[U-Boot-Users] [PATCH 3/9] NAND update
The following modifications have been made in cpu/
Note that the patch-series is broken unless it is seen as one single patch. It is broken up to multiple emails to fit the size limit.
We have set up a git repository were you can pull the complete patch: http://git.tandberg.com/tandberg/u-boot.git
Best regards William
------------------------------------------------- William Juul, Senior Development Engineer Data Respons Norge AS Sandviksveien 26 P.O. Box 489 NO-1323 Høvik, Norway
www.datarespons.no -------------------------------------------------
diff --git a/cpu/arm926ejs/davinci/nand.c b/cpu/arm926ejs/davinci/nand.c index 127be9f..0a612de 100644 --- a/cpu/arm926ejs/davinci/nand.c +++ b/cpu/arm926ejs/davinci/nand.c @@ -42,6 +42,7 @@ */
#include <common.h> +#include <asm/io.h>
#ifdef CFG_USE_NAND #if !defined(CFG_NAND_LEGACY) @@ -52,23 +53,23 @@
extern struct nand_chip nand_dev_desc[CFG_MAX_NAND_DEVICE];
-static void nand_davinci_hwcontrol(struct mtd_info *mtd, int cmd) +static void nand_davinci_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) { struct nand_chip *this = mtd->priv; u_int32_t IO_ADDR_W = (u_int32_t)this->IO_ADDR_W;
IO_ADDR_W &= ~(MASK_ALE|MASK_CLE);
- switch (cmd) { - case NAND_CTL_SETCLE: + if (ctrl & NAND_CTRL_CHANGE) { + if ( ctrl & NAND_CLE ) IO_ADDR_W |= MASK_CLE; - break; - case NAND_CTL_SETALE: + if ( ctrl & NAND_ALE ) IO_ADDR_W |= MASK_ALE; - break; + this->IO_ADDR_W = (void __iomem *) IO_ADDR_W; }
- this->IO_ADDR_W = (void *)IO_ADDR_W; + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); }
/* Set WP on deselect, write enable on select */ @@ -145,7 +146,7 @@ static int nand_davinci_calculate_ecc(struct mtd_info *mtd, const u_char *dat, u int region, n; struct nand_chip *this = mtd->priv;
- n = (this->eccmode == NAND_ECC_HW12_2048) ? 4 : 1; + n = (this->ecc.size/512);
region = 1; while (n--) { @@ -277,7 +278,7 @@ static int nand_davinci_correct_data(struct mtd_info *mtd, u_char *dat, u_char * int block_count = 0, i, rc;
this = mtd->priv; - block_count = (this->eccmode == NAND_ECC_HW12_2048) ? 4 : 1; + block_count = (this->ecc.size/512); for (i = 0; i < block_count; i++) { if (memcmp(read_ecc, calc_ecc, 3) != 0) { rc = nand_davinci_compare_ecc(read_ecc, calc_ecc, dat); @@ -302,7 +303,7 @@ static int nand_davinci_dev_ready(struct mtd_info *mtd) return(emif_addr->NANDFSR & 0x1); }
-static int nand_davinci_waitfunc(struct mtd_info *mtd, struct nand_chip *this, int state) +static int nand_davinci_waitfunc(struct mtd_info *mtd, struct nand_chip *this) { while(!nand_davinci_dev_ready(mtd)) {;} *NAND_CE0CLE = NAND_STATUS; @@ -358,22 +359,26 @@ int board_nand_init(struct nand_chip *nand) #endif #ifdef CFG_NAND_HW_ECC #ifdef CFG_NAND_LARGEPAGE - nand->eccmode = NAND_ECC_HW12_2048; + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.size = 2048; + nand->ecc.bytes = 12; #elif defined(CFG_NAND_SMALLPAGE) - nand->eccmode = NAND_ECC_HW3_512; + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.size = 512; + nand->ecc.bytes = 3; #else #error "Either CFG_NAND_LARGEPAGE or CFG_NAND_SMALLPAGE must be defined!" #endif - nand->autooob = &davinci_nand_oobinfo; - nand->calculate_ecc = nand_davinci_calculate_ecc; - nand->correct_data = nand_davinci_correct_data; - nand->enable_hwecc = nand_davinci_enable_hwecc; +/* nand->autooob = &davinci_nand_oobinfo; */ + nand->ecc.calculate = nand_davinci_calculate_ecc; + nand->ecc.correct = nand_davinci_correct_data; + nand->ecc.hwctl = nand_davinci_enable_hwecc; #else - nand->eccmode = NAND_ECC_SOFT; + nand->ecc.mode = NAND_ECC_SOFT; #endif
/* Set address of hardware control function */ - nand->hwcontrol = nand_davinci_hwcontrol; + nand->cmd_ctrl = nand_davinci_hwcontrol;
nand->dev_ready = nand_davinci_dev_ready; nand->waitfunc = nand_davinci_waitfunc; diff --git a/cpu/ppc4xx/ndfc.c b/cpu/ppc4xx/ndfc.c index 3984577..0bc4137 100644 --- a/cpu/ppc4xx/ndfc.c +++ b/cpu/ppc4xx/ndfc.c @@ -45,38 +45,22 @@
static u8 hwctl = 0;
-static void ndfc_hwcontrol(struct mtd_info *mtdinfo, int cmd) +static void ndfc_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) { - switch (cmd) { - case NAND_CTL_SETCLE: - hwctl |= 0x1; - break; - - case NAND_CTL_CLRCLE: - hwctl &= ~0x1; - break; - - case NAND_CTL_SETALE: - hwctl |= 0x2; - break; - - case NAND_CTL_CLRALE: - hwctl &= ~0x2; - break; + struct nand_chip *this = mtd->priv; + + if (ctrl & NAND_CTRL_CHANGE) { + if ( ctrl & NAND_CLE ) + hwctl |= 0x1; + else + hwctl &= ~0x1; + if ( ctrl & NAND_ALE ) + hwctl |= 0x2; + else + hwctl &= ~0x2; } -} - -static void ndfc_write_byte(struct mtd_info *mtdinfo, u_char byte) -{ - struct nand_chip *this = mtdinfo->priv; - ulong base = (ulong) this->IO_ADDR_W & 0xfffffffc; - - if (hwctl & 0x1) - out_8((u8 *)(base + NDFC_CMD), byte); - else if (hwctl & 0x2) - out_8((u8 *)(base + NDFC_ALE), byte); - else - out_8((u8 *)(base + NDFC_DATA), byte); + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); }
static u_char ndfc_read_byte(struct mtd_info *mtdinfo) @@ -193,16 +177,17 @@ int board_nand_init(struct nand_chip *nand) int cs = (ulong)nand->IO_ADDR_W & 0x00000003; ulong base = (ulong)nand->IO_ADDR_W & 0xfffffffc;
- nand->hwcontrol = ndfc_hwcontrol; + nand->cmd_ctrl = ndfc_hwcontrol; nand->read_byte = ndfc_read_byte; nand->read_buf = ndfc_read_buf; - nand->write_byte = ndfc_write_byte; nand->dev_ready = ndfc_dev_ready;
- nand->eccmode = NAND_ECC_HW3_256; - nand->enable_hwecc = ndfc_enable_hwecc; - nand->calculate_ecc = ndfc_calculate_ecc; - nand->correct_data = nand_correct_data; + nand->ecc.correct = nand_correct_data; + nand->ecc.hwctl = ndfc_enable_hwecc; + nand->ecc.calculate = ndfc_calculate_ecc; + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.size = 256; + nand->ecc.bytes = 3;
#ifndef CONFIG_NAND_SPL nand->write_buf = ndfc_write_buf;
William Juul
