[U-Boot] [PATCH v2] Avoid use of divides in print_size
Modification of print_size to avoid use of divides and especially long long divides. Keep the binary scale factor in terms of bit shifts instead. This should be faster, since the previous code gave the compiler no clues that the divides where always powers of two, preventing optimisation.
Signed-off-by: Nick Thompson nick.thompson@ge.com --- Since v1: Removed misplaced brackets that resulted in round-up value of 5 rather than the intended 0.5. Now passes Timur Tabi's test.
lib/display_options.c | 14 ++++++++------ 1 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/lib/display_options.c b/lib/display_options.c index 86df05d..14a2da5 100644 --- a/lib/display_options.c +++ b/lib/display_options.c @@ -46,13 +46,14 @@ int display_options (void) void print_size(unsigned long long size, const char *s) { unsigned long m = 0, n; + unsigned long long f; static const char names[] = {'E', 'P', 'T', 'G', 'M', 'K'}; - unsigned long long d = 1ULL << (10 * ARRAY_SIZE(names)); + unsigned long d = 10 * ARRAY_SIZE(names); char c = 0; unsigned int i;
- for (i = 0; i < ARRAY_SIZE(names); i++, d >>= 10) { - if (size >= d) { + for (i = 0; i < ARRAY_SIZE(names); i++, d -= 10) { + if (size >> d) { c = names[i]; break; } @@ -63,11 +64,12 @@ void print_size(unsigned long long size, const char *s) return; }
- n = size / d; + n = size >> d; + f = size & ((1ULL << d) - 1);
/* If there's a remainder, deal with it */ - if(size % d) { - m = (10 * (size - (n * d)) + (d / 2) ) / d; + if (f) { + m = (10ULL * f + (1 << (d - 1))) >> d;
if (m >= 10) { m -= 10;
Nick Thompson
