[U-Boot] [PATCH 0/3] efi_loader: correctly initialize system table crc32
The crc32 of the system table has to be calculated after all fields have been set.
Adjust the signature of CalculateCrc32().
Provide a unit test that checks the crc of the system table, the runtime services table, and the boot sevices table before and after ExitBootServices().
Heinrich Schuchardt (3): efi_loader: correctly initialize system table crc32 efi_loader: correct signature of CalculateCrc32() efi_selftest: unit test for CalculateCrc32()
cmd/bootefi.c | 10 +- include/efi_api.h | 4 +- lib/efi_loader/efi_boottime.c | 6 +- lib/efi_selftest/Makefile | 1 + lib/efi_selftest/efi_selftest_crc32.c | 141 ++++++++++++++++++++++++++ 5 files changed, 152 insertions(+), 10 deletions(-) create mode 100644 lib/efi_selftest/efi_selftest_crc32.c
We should calculate the crc32 after initalizing all fields of the system table.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index b60c151fb4..1bf75e2bba 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -44,11 +44,6 @@ efi_status_t efi_init_obj_list(void) if (efi_obj_list_initialized != OBJ_LIST_NOT_INITIALIZED) return efi_obj_list_initialized;
- /* Initialize system table */ - ret = efi_initialize_system_table(); - if (ret != EFI_SUCCESS) - goto out; - /* Initialize EFI driver uclass */ ret = efi_driver_init(); if (ret != EFI_SUCCESS) @@ -91,6 +86,11 @@ efi_status_t efi_init_obj_list(void) if (ret != EFI_SUCCESS) goto out;
+ /* Initialize system table */ + ret = efi_initialize_system_table(); + if (ret != EFI_SUCCESS) + goto out; + out: efi_obj_list_initialized = ret; return ret;
Use const for the buffer. We are not changing the buffer. Use efi_uintn_t where prescribed by the UEFI spec. Prefer u32 over uint32_t.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_api.h | 5 +++-- lib/efi_loader/efi_boottime.c | 6 +++--- 2 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index c98cc34908..ebf2a3bc18 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -165,8 +165,9 @@ struct efi_boot_services { void **handle, ...); efi_status_t (EFIAPI *uninstall_multiple_protocol_interfaces)( void *handle, ...); - efi_status_t (EFIAPI *calculate_crc32)(void *data, - unsigned long data_size, uint32_t *crc32); + efi_status_t (EFIAPI *calculate_crc32)(const void *data, + efi_uintn_t data_size, + u32 *crc32); void (EFIAPI *copy_mem)(void *destination, const void *source, size_t length); void (EFIAPI *set_mem)(void *buffer, size_t size, uint8_t value); diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 9ac8e18680..5a011f0b36 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2418,9 +2418,9 @@ static efi_status_t EFIAPI efi_uninstall_multiple_protocol_interfaces( * @crc32_p: cyclic redundancy code * Return Value: status code */ -static efi_status_t EFIAPI efi_calculate_crc32(void *data, - unsigned long data_size, - uint32_t *crc32_p) +static efi_status_t EFIAPI efi_calculate_crc32(const void *data, + efi_uintn_t data_size, + u32 *crc32_p) { EFI_ENTRY("%p, %ld", data, data_size); *crc32_p = crc32(0, data, data_size);
This unit test checks the CalculateCrc32 bootservice and checks the headers of the system table, the boot services tablle, and the runtime services table before and after ExitBootServices().
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/Makefile | 1 + lib/efi_selftest/efi_selftest_crc32.c | 141 ++++++++++++++++++++++++++ 2 files changed, 142 insertions(+) create mode 100644 lib/efi_selftest/efi_selftest_crc32.c
diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index d927208700..590f90b16d 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -16,6 +16,7 @@ efi_selftest_bitblt.o \ efi_selftest_config_table.o \ efi_selftest_controllers.o \ efi_selftest_console.o \ +efi_selftest_crc32.o \ efi_selftest_devicepath.o \ efi_selftest_devicepath_util.o \ efi_selftest_events.o \ diff --git a/lib/efi_selftest/efi_selftest_crc32.c b/lib/efi_selftest/efi_selftest_crc32.c new file mode 100644 index 0000000000..8555b8f114 --- /dev/null +++ b/lib/efi_selftest/efi_selftest_crc32.c @@ -0,0 +1,141 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * efi_selftest_crc32 + * + * Copyright (c) 2018 Heinrich Schuchardt xypron.glpk@gmx.de + * + * This unit test checks the CalculateCrc32 bootservice and checks the + * headers of the system table, the boot services tablle, and the runtime + * services table before and after ExitBootServices(). + */ + +#include <efi_selftest.h> + +const struct efi_system_table *st; +efi_status_t (EFIAPI *bs_crc32)(const void *data, efi_uintn_t data_size, + u32 *crc32); + +static int check_table(const void *table) +{ + efi_status_t ret; + u32 crc32, res; + /* Casting from const to not const */ + struct efi_table_hdr *hdr = (struct efi_table_hdr *)table; + + if (!hdr->signature) { + efi_st_error("Missing header signature\n"); + return EFI_ST_FAILURE; + } + if (!hdr->revision) { + efi_st_error("Missing header revision\n"); + return EFI_ST_FAILURE; + } + if (hdr->headersize <= sizeof(struct efi_table_hdr)) { + efi_st_error("Incorrect headersize value\n"); + return EFI_ST_FAILURE; + } + if (hdr->reserved) { + efi_st_error("Reserved header field is not zero\n"); + return EFI_ST_FAILURE; + } + + crc32 = hdr->crc32; + /* + * Setting the crc32 of the 'const' table to zero is easier than + * copying + */ + hdr->crc32 = 0; + ret = bs_crc32(table, hdr->headersize, &res); + /* Reset table crc32 so it stays constant */ + hdr->crc32 = crc32; + if (ret != EFI_ST_SUCCESS) { + efi_st_error("CalculateCrc32 failed\n"); + return EFI_ST_FAILURE; + } + if (res != crc32) { + efi_st_error("Incorrect CRC32\n"); + // return EFI_ST_FAILURE; + } + return EFI_ST_SUCCESS; +} + +/* + * Setup unit test. + * + * Check that CalculateCrc32 is working correctly. + * Check tables before ExitBootServices(). + * + * @handle: handle of the loaded image + * @systable: system table + * @return: EFI_ST_SUCCESS for success + */ +static int setup(const efi_handle_t handle, + const struct efi_system_table *systable) +{ + efi_status_t ret; + u32 res; + + st = systable; + bs_crc32 = systable->boottime->calculate_crc32; + + /* Check that CalculateCrc32 is working */ + ret = bs_crc32("U-Boot", 6, &res); + if (ret != EFI_ST_SUCCESS) { + efi_st_error("CalculateCrc32 failed\n"); + return EFI_ST_FAILURE; + } + if (res != 0x134b0db4) { + efi_st_error("Incorrect CRC32\n"); + return EFI_ST_FAILURE; + } + + /* Check tables before ExitBootServices() */ + if (check_table(st) != EFI_ST_SUCCESS) { + efi_st_error("Checking system table\n"); + return EFI_ST_FAILURE; + } + if (check_table(st->boottime) != EFI_ST_SUCCESS) { + efi_st_error("Checking boottime table\n"); + return EFI_ST_FAILURE; + } + if (check_table(st->runtime) != EFI_ST_SUCCESS) { + efi_st_error("Checking runtime table\n"); + return EFI_ST_FAILURE; + } + + return EFI_ST_SUCCESS; +} + +/* + * Execute unit test + * + * Check tables after ExitBootServices() + * + * @return: EFI_ST_SUCCESS for success + */ +static int execute(void) +{ + if (check_table(st) != EFI_ST_SUCCESS) { + efi_st_error("Checking system table\n"); + return EFI_ST_FAILURE; + } + if (check_table(st->runtime) != EFI_ST_SUCCESS) { + efi_st_error("Checking runtime table\n"); + return EFI_ST_FAILURE; + } + + /* + * We cannot call SetVirtualAddressMap() and recheck the runtime + * table afterwards because this would invalidate the addresses of the + * unit tests. + */ + + return EFI_ST_SUCCESS; +} + +EFI_UNIT_TEST(crc32) = { + .name = "crc32", + .phase = EFI_SETUP_BEFORE_BOOTTIME_EXIT, + .setup = setup, + .execute = execute, +};
