[PATCH 1/2] CI: Update to gcc-13.2.0
The latest kernel.org toolchains for gcc are now 13.2.0, so upgrade to that.
Signed-off-by: Tom Rini trini@konsulko.com --- .azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- tools/buildman/toolchain.py | 2 +- tools/docker/Dockerfile | 58 ++++++++++++++++++------------------- 4 files changed, 32 insertions(+), 32 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 0be317b38867..711b067c1f31 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -195,7 +195,7 @@ stages: ln -s /opt/nokia/libc6_2.5.1-1eglibc27+0m5_armel.deb nokia_rx51_tmp/ ln -s /opt/nokia/busybox_1.10.2.legal-1osso30+0m5_armel.deb nokia_rx51_tmp/ ln -s /opt/nokia/qemu-system-arm nokia_rx51_tmp/ - export PATH=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin:$PATH + export PATH=/opt/gcc-13.2.0-nolibc/arm-linux-gnueabi/bin:$PATH test/nokia_rx51_test.sh
- job: pylint diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 5750d8202332..aff6a5c2dce1 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -235,7 +235,7 @@ Run tests for Nokia RX-51 (aka N900): ln -s /opt/nokia/libc6_2.5.1-1eglibc27+0m5_armel.deb nokia_rx51_tmp/; ln -s /opt/nokia/busybox_1.10.2.legal-1osso30+0m5_armel.deb nokia_rx51_tmp/; ln -s /opt/nokia/qemu-system-arm nokia_rx51_tmp/; - export PATH=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin:$PATH; + export PATH=/opt/gcc-13.2.0-nolibc/arm-linux-gnueabi/bin:$PATH; test/nokia_rx51_test.sh
# Check for any pylint regressions diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index b05001194e42..79c7c11a1105 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -499,7 +499,7 @@ class Toolchains: if arch == 'aarch64': arch = 'arm64' base = 'https://www.kernel.org/pub/tools/crosstool/files/bin' - versions = ['13.1.0', '12.2.0'] + versions = ['13.2.0', '12.2.0'] links = [] for version in versions: url = '%s/%s/%s/' % (base, arch, version) diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 3d2b64a355f3..93fe8c613244 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -14,19 +14,19 @@ RUN apt-get update && apt-get install -y gnupg2 wget xz-utils && rm -rf /var/lib RUN wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | apt-key add - RUN echo deb http://apt.llvm.org/jammy/ llvm-toolchain-jammy-16 main | tee /etc/apt/sources.list.d/llvm.list
-# Manually install the kernel.org "Crosstool" based toolchains for gcc-13.1.0 -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ -RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.1.0/... | tar -C /opt -xJ +# Manually install the kernel.org "Crosstool" based toolchains for gcc-13.2.0 +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ
# Manually install other toolchains RUN wget -O - https://github.com/foss-xtensa/toolchain/releases/download/2020.07/x86_64-20... | tar -C /opt -xz @@ -134,11 +134,11 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ mkdir -p /opt/grub && \ ./configure --target=aarch64 --with-platform=efi \ CC=gcc \ - TARGET_CC=/opt/gcc-13.1.0-nolibc/aarch64-linux/bin/aarch64-linux-gcc \ - TARGET_OBJCOPY=/opt/gcc-13.1.0-nolibc/aarch64-linux/bin/aarch64-linux-objcopy \ - TARGET_STRIP=/opt/gcc-13.1.0-nolibc/aarch64-linux/bin/aarch64-linux-strip \ - TARGET_NM=/opt/gcc-13.1.0-nolibc/aarch64-linux/bin/aarch64-linux-nm \ - TARGET_RANLIB=/opt/gcc-13.1.0-nolibc/aarch64-linux/bin/aarch64-linux-ranlib && \ + TARGET_CC=/opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-gcc \ + TARGET_OBJCOPY=/opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-objcopy \ + TARGET_STRIP=/opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-strip \ + TARGET_NM=/opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-nm \ + TARGET_RANLIB=/opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-ranlib && \ make && \ ./grub-mkimage -O arm64-efi -o /opt/grub/grubaa64.efi --prefix= -d \ grub-core cat chain configfile echo efinet ext2 fat halt help linux \ @@ -148,11 +148,11 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ make clean && \ ./configure --target=arm --with-platform=efi \ CC=gcc \ - TARGET_CC=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-gcc \ - TARGET_OBJCOPY=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-objcopy \ - TARGET_STRIP=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-strip \ - TARGET_NM=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-nm \ - TARGET_RANLIB=/opt/gcc-13.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ranlib && \ + TARGET_CC=/opt/gcc-13.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-gcc \ + TARGET_OBJCOPY=/opt/gcc-13.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-objcopy \ + TARGET_STRIP=/opt/gcc-13.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-strip \ + TARGET_NM=/opt/gcc-13.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-nm \ + TARGET_RANLIB=/opt/gcc-13.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ranlib && \ make && \ ./grub-mkimage -O arm-efi -o /opt/grub/grubarm.efi --prefix= -d \ grub-core cat chain configfile echo efinet ext2 fat halt help linux \ @@ -162,11 +162,11 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ make clean && \ ./configure --target=riscv64 --with-platform=efi \ CC=gcc \ - TARGET_CC=/opt/gcc-13.1.0-nolibc/riscv64-linux/bin/riscv64-linux-gcc \ - TARGET_OBJCOPY=/opt/gcc-13.1.0-nolibc/riscv64-linux/bin/riscv64-linux-objcopy \ - TARGET_STRIP=/opt/gcc-13.1.0-nolibc/riscv64-linux/bin/riscv64-linux-strip \ - TARGET_NM=/opt/gcc-13.1.0-nolibc/riscv64-linux/bin/riscv64-linux-nm \ - TARGET_RANLIB=/opt/gcc-13.1.0-nolibc/riscv64-linux/bin/riscv64-linux-ranlib && \ + TARGET_CC=/opt/gcc-13.2.0-nolibc/riscv64-linux/bin/riscv64-linux-gcc \ + TARGET_OBJCOPY=/opt/gcc-13.2.0-nolibc/riscv64-linux/bin/riscv64-linux-objcopy \ + TARGET_STRIP=/opt/gcc-13.2.0-nolibc/riscv64-linux/bin/riscv64-linux-strip \ + TARGET_NM=/opt/gcc-13.2.0-nolibc/riscv64-linux/bin/riscv64-linux-nm \ + TARGET_RANLIB=/opt/gcc-13.2.0-nolibc/riscv64-linux/bin/riscv64-linux-ranlib && \ make && \ ./grub-mkimage -O riscv64-efi -o /opt/grub/grubriscv64.efi --prefix= -d \ grub-core cat chain configfile echo efinet ext2 fat halt help linux \ @@ -277,7 +277,7 @@ RUN virtualenv -p /usr/bin/python3 /tmp/venv && \
# Create the buildman config file RUN /bin/echo -e "[toolchain]\nroot = /usr" > ~/.buildman -RUN /bin/echo -e "kernelorg = /opt/gcc-13.1.0-nolibc/*" >> ~/.buildman +RUN /bin/echo -e "kernelorg = /opt/gcc-13.2.0-nolibc/*" >> ~/.buildman RUN /bin/echo -e "\n[toolchain-prefix]\nxtensa = /opt/2020.07/xtensa-dc233c-elf/bin/xtensa-dc233c-elf-" >> ~/.buildman; RUN /bin/echo -e "\n[toolchain-alias]\nsh = sh2" >> ~/.buildman RUN /bin/echo -e "\nsandbox = x86_64" >> ~/.buildman
Move to the latest "Jammy" tag from Ubuntu.
Signed-off-by: Tom Rini trini@konsulko.com --- .azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- tools/docker/Dockerfile | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 711b067c1f31..b9dce3b1cadf 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -2,7 +2,7 @@ variables: windows_vm: windows-2019 ubuntu_vm: ubuntu-22.04 macos_vm: macOS-12 - ci_runner_image: trini/u-boot-gitlab-ci-runner:jammy-20230624-20Jul2023 + ci_runner_image: trini/u-boot-gitlab-ci-runner:jammy-20230804-24Aug2023 # Add '-u 0' options for Azure pipelines, otherwise we get "permission # denied" error when it tries to "useradd -m -u 1001 vsts_azpcontainer", # since our $(ci_runner_image) user is not root. diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index aff6a5c2dce1..09b95fce41af 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -10,7 +10,7 @@ default:
# Grab our configured image. The source for this is found # in the u-boot tree at tools/docker/Dockerfile -image: ${MIRROR_DOCKER}/trini/u-boot-gitlab-ci-runner:jammy-20230624-20Jul2023 +image: ${MIRROR_DOCKER}/trini/u-boot-gitlab-ci-runner:jammy-20230804-24Aug2023
# We run some tests in different order, to catch some failures quicker. stages: diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 93fe8c613244..9670f04eb5ee 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -2,7 +2,7 @@ # This Dockerfile is used to build an image containing basic stuff to be used # to build U-Boot and run our test suites.
-FROM ubuntu:jammy-20230624 +FROM ubuntu:jammy-20230804 MAINTAINER Tom Rini trini@konsulko.com LABEL Description=" This image is for building U-Boot inside a container"
Hi Tom,
I wonder if they have a 'latest' tag? I suppose it wouldn't be safe to do this without trying it first, though.
On Fri, Aug 25, 2023 at 12:06:09PM -0600, Simon Glass wrote:
Hi Tom,
Yes, but that would break reproducibility.
Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org
