[PATCH 1/1] cmd: fdt: remove CMD_FDT_MAX_DUMP
When printing the device tree we want to get an output that can be used as input for the device tree compiler. This requires that we do not write bogus lines like
pcie@10000000 { interrupt-map = * 0x4000127c [0x00000280];
For instance the QEMU virt device has a property interrupt-map with 640 bytes which exceeds CMD_FDT_MAX_DUMP=64.
So lets do away with the artificial limitation to 64 bytes.
As indicated in commit f0a29d43313c ("fdt: Limit printed hex in fdt print and list commands") if a device tree contains binary blobs, it may still be desirable to limit the output length. Provide environment variable fdt_max_dump for this purpose.
Fixes: 5d927b428622 ("Kconfig: Drop CONFIG_CMD_FDT_MAX_DUMP") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/fdt.c | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/cmd/fdt.c b/cmd/fdt.c index 99b1b5b3fc..89ab572d8d 100644 --- a/cmd/fdt.c +++ b/cmd/fdt.c @@ -21,7 +21,6 @@
#define MAX_LEVEL 32 /* how deeply nested we will go */ #define SCRATCHPAD 1024 /* bytes of scratchpad memory */ -#define CMD_FDT_MAX_DUMP 64
/* * Global data (for the gd->bd) @@ -934,11 +933,17 @@ static int is_printable_string(const void *data, int len) static void print_data(const void *data, int len) { int j; + const char *env_max_dump; + ulong max_dump = ULONG_MAX;
/* no data, don't print */ if (len == 0) return;
+ env_max_dump = env_get("fdt_max_dump"); + if (env_max_dump) + max_dump = simple_strtoul(env_max_dump, NULL, 16); + /* * It is a string, but it may have multiple strings (embedded '\0's). */ @@ -957,7 +962,7 @@ static void print_data(const void *data, int len) }
if ((len %4) == 0) { - if (len > CMD_FDT_MAX_DUMP) + if (len > max_dump) printf("* 0x%p [0x%08x]", data, len); else { const __be32 *p; @@ -969,7 +974,7 @@ static void print_data(const void *data, int len) printf(">"); } } else { /* anything else... hexdump */ - if (len > CMD_FDT_MAX_DUMP) + if (len > max_dump) printf("* 0x%p [0x%08x]", data, len); else { const u8 *s; -- 2.27.0
Applied to u-boot-dm/next, thanks!
