[U-Boot] [PATCH v3 00/10] spi: Add Atmel QuadSPI driver
Backport the driver from linux v5.1-rc5 and adapt it for u-boot. Tested on sama5d2_xplained Rev B with mx25l25635e spi-nor flash, and on sama5d27_som1_ek with sst26vf064b spi-nor flash.
v3: fix following config warnings reported by travis: ./tools/genboardscfg.py WARNING: no status info for 'sama5d2_xplained_qspiflash' WARNING: no maintainers for 'sama5d2_xplained_qspiflash' WARNING: no status info for 'sama5d27_som1_ek_qspiflash' WARNING: no maintainers for 'sama5d27_som1_ek_qspiflash'
v2: update/add configs and update sama5d2_xplained dts
Cyrille Pitchen (2): ARM: dts: at91: sama5d2_xplained: fix QSPI0 node ARM: at91: sama5: add common environment for QSPI
Eugen Hristev (1): configs: sama5d2_xplained: add support QSPI flash boot
Tudor Ambarus (7): dt-bindings: spi: add bindings for Atmel QSPI driver spi: Add Atmel QuadSPI driver configs: sama5d2_xplained: enable qspi controller and flashes configs: sama5d27_som1_ek: enable qspi controller and flashes configs: sama5d2_xplained: add qspiflash_defconfig configs: sama5d27_som1_ek: add qspiflash_defconfig configs: sama5d27_som1_ek: qspi: use common memory layout
arch/arm/dts/at91-sama5d2_xplained.dts | 36 +- board/atmel/sama5d27_som1_ek/MAINTAINERS | 1 + board/atmel/sama5d2_xplained/MAINTAINERS | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 2 + configs/sama5d27_som1_ek_mmc_defconfig | 2 + configs/sama5d27_som1_ek_qspiflash_defconfig | 101 +++++ configs/sama5d2_xplained_emmc_defconfig | 5 + configs/sama5d2_xplained_mmc_defconfig | 5 + configs/sama5d2_xplained_qspiflash_defconfig | 101 +++++ configs/sama5d2_xplained_spiflash_defconfig | 5 + doc/device-tree-bindings/spi/atmel-quadspi.txt | 37 ++ drivers/spi/Kconfig | 7 + drivers/spi/Makefile | 1 + drivers/spi/atmel-quadspi.c | 535 +++++++++++++++++++++++++ include/configs/at91-sama5_common.h | 8 + include/configs/sama5d27_som1_ek.h | 7 - include/configs/sama5d2_xplained.h | 11 + 17 files changed, 839 insertions(+), 26 deletions(-) create mode 100644 configs/sama5d27_som1_ek_qspiflash_defconfig create mode 100644 configs/sama5d2_xplained_qspiflash_defconfig create mode 100644 doc/device-tree-bindings/spi/atmel-quadspi.txt create mode 100644 drivers/spi/atmel-quadspi.c
Describe the DT bindings for the driver of the Atmel QSPI controller. Taken form linux v5.1-rc5.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v3: no change v2: no change
doc/device-tree-bindings/spi/atmel-quadspi.txt | 37 ++++++++++++++++++++++++++ 1 file changed, 37 insertions(+) create mode 100644 doc/device-tree-bindings/spi/atmel-quadspi.txt
diff --git a/doc/device-tree-bindings/spi/atmel-quadspi.txt b/doc/device-tree-bindings/spi/atmel-quadspi.txt new file mode 100644 index 000000000000..7c40ea694352 --- /dev/null +++ b/doc/device-tree-bindings/spi/atmel-quadspi.txt @@ -0,0 +1,37 @@ +* Atmel Quad Serial Peripheral Interface (QSPI) + +Required properties: +- compatible: Should be one of the following: + - "atmel,sama5d2-qspi" + - "microchip,sam9x60-qspi" +- reg: Should contain the locations and lengths of the base registers + and the mapped memory. +- reg-names: Should contain the resource reg names: + - qspi_base: configuration register address space + - qspi_mmap: memory mapped address space +- interrupts: Should contain the interrupt for the device. +- clocks: Should reference the peripheral clock and the QSPI system + clock if available. +- clock-names: Should contain "pclk" for the peripheral clock and "qspick" + for the system clock when available. +- #address-cells: Should be <1>. +- #size-cells: Should be <0>. + +Example: + +spi@f0020000 { + compatible = "atmel,sama5d2-qspi"; + reg = <0xf0020000 0x100>, <0xd0000000 0x8000000>; + reg-names = "qspi_base", "qspi_mmap"; + interrupts = <52 IRQ_TYPE_LEVEL_HIGH 7>; + clocks = <&pmc PMC_TYPE_PERIPHERAL 52>; + clock-names = "pclk"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spi0_default>; + + m25p80@0 { + ... + }; +};
Backport the driver from linux v5.1-rc5 and adapt it for u-boot. Tested on sama5d2_xplained Rev B with mx25l25635e spi-nor flash.
drivers/spi/Kconfig | 7 + drivers/spi/Makefile | 1 + drivers/spi/atmel-quadspi.c | 535 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 543 insertions(+) create mode 100644 drivers/spi/atmel-quadspi.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index dc3e23f353aa..69c2f92c7826 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -49,6 +49,13 @@ config ATH79_SPI uses driver model and requires a device tree binding to operate. please refer to doc/device-tree-bindings/spi/spi-ath79.txt.
+config ATMEL_QSPI + bool "Atmel QSPI driver" + depends on ARCH_AT91 + help + Enable the Ateml Quad-SPI (QSPI) driver. This driver can only be + used to access SPI NOR flashes. + config ATMEL_SPI bool "Atmel SPI driver" default y if ARCH_AT91 diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 8be9a4baa244..32b42d18b1af 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -18,6 +18,7 @@ endif
obj-$(CONFIG_ALTERA_SPI) += altera_spi.o obj-$(CONFIG_ATH79_SPI) += ath79_spi.o +obj-$(CONFIG_ATMEL_QSPI) += atmel-quadspi.o obj-$(CONFIG_ATMEL_SPI) += atmel_spi.o obj-$(CONFIG_BCM63XX_HSSPI) += bcm63xx_hsspi.o obj-$(CONFIG_BCM63XX_SPI) += bcm63xx_spi.o diff --git a/drivers/spi/atmel-quadspi.c b/drivers/spi/atmel-quadspi.c new file mode 100644 index 000000000000..c54fbe6bc6cf --- /dev/null +++ b/drivers/spi/atmel-quadspi.c @@ -0,0 +1,535 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Driver for Atmel QSPI Controller + * + * Copyright (C) 2015 Atmel Corporation + * Copyright (C) 2018 Cryptera A/S + * + * Author: Cyrille Pitchen cyrille.pitchen@atmel.com + * Author: Piotr Bugalski bugalski.piotr@gmail.com + */ + +#include <asm/io.h> +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <linux/io.h> +#include <linux/iopoll.h> +#include <linux/ioport.h> +#include <mach/clk.h> +#include <spi.h> +#include <spi-mem.h> + +/* QSPI register offsets */ +#define QSPI_CR 0x0000 /* Control Register */ +#define QSPI_MR 0x0004 /* Mode Register */ +#define QSPI_RD 0x0008 /* Receive Data Register */ +#define QSPI_TD 0x000c /* Transmit Data Register */ +#define QSPI_SR 0x0010 /* Status Register */ +#define QSPI_IER 0x0014 /* Interrupt Enable Register */ +#define QSPI_IDR 0x0018 /* Interrupt Disable Register */ +#define QSPI_IMR 0x001c /* Interrupt Mask Register */ +#define QSPI_SCR 0x0020 /* Serial Clock Register */ + +#define QSPI_IAR 0x0030 /* Instruction Address Register */ +#define QSPI_ICR 0x0034 /* Instruction Code Register */ +#define QSPI_WICR 0x0034 /* Write Instruction Code Register */ +#define QSPI_IFR 0x0038 /* Instruction Frame Register */ +#define QSPI_RICR 0x003C /* Read Instruction Code Register */ + +#define QSPI_SMR 0x0040 /* Scrambling Mode Register */ +#define QSPI_SKR 0x0044 /* Scrambling Key Register */ + +#define QSPI_WPMR 0x00E4 /* Write Protection Mode Register */ +#define QSPI_WPSR 0x00E8 /* Write Protection Status Register */ + +#define QSPI_VERSION 0x00FC /* Version Register */ + +/* Bitfields in QSPI_CR (Control Register) */ +#define QSPI_CR_QSPIEN BIT(0) +#define QSPI_CR_QSPIDIS BIT(1) +#define QSPI_CR_SWRST BIT(7) +#define QSPI_CR_LASTXFER BIT(24) + +/* Bitfields in QSPI_MR (Mode Register) */ +#define QSPI_MR_SMM BIT(0) +#define QSPI_MR_LLB BIT(1) +#define QSPI_MR_WDRBT BIT(2) +#define QSPI_MR_SMRM BIT(3) +#define QSPI_MR_CSMODE_MASK GENMASK(5, 4) +#define QSPI_MR_CSMODE_NOT_RELOADED (0 << 4) +#define QSPI_MR_CSMODE_LASTXFER (1 << 4) +#define QSPI_MR_CSMODE_SYSTEMATICALLY (2 << 4) +#define QSPI_MR_NBBITS_MASK GENMASK(11, 8) +#define QSPI_MR_NBBITS(n) ((((n) - 8) << 8) & QSPI_MR_NBBITS_MASK) +#define QSPI_MR_DLYBCT_MASK GENMASK(23, 16) +#define QSPI_MR_DLYBCT(n) (((n) << 16) & QSPI_MR_DLYBCT_MASK) +#define QSPI_MR_DLYCS_MASK GENMASK(31, 24) +#define QSPI_MR_DLYCS(n) (((n) << 24) & QSPI_MR_DLYCS_MASK) + +/* Bitfields in QSPI_SR/QSPI_IER/QSPI_IDR/QSPI_IMR */ +#define QSPI_SR_RDRF BIT(0) +#define QSPI_SR_TDRE BIT(1) +#define QSPI_SR_TXEMPTY BIT(2) +#define QSPI_SR_OVRES BIT(3) +#define QSPI_SR_CSR BIT(8) +#define QSPI_SR_CSS BIT(9) +#define QSPI_SR_INSTRE BIT(10) +#define QSPI_SR_QSPIENS BIT(24) + +#define QSPI_SR_CMD_COMPLETED (QSPI_SR_INSTRE | QSPI_SR_CSR) + +/* Bitfields in QSPI_SCR (Serial Clock Register) */ +#define QSPI_SCR_CPOL BIT(0) +#define QSPI_SCR_CPHA BIT(1) +#define QSPI_SCR_SCBR_MASK GENMASK(15, 8) +#define QSPI_SCR_SCBR(n) (((n) << 8) & QSPI_SCR_SCBR_MASK) +#define QSPI_SCR_DLYBS_MASK GENMASK(23, 16) +#define QSPI_SCR_DLYBS(n) (((n) << 16) & QSPI_SCR_DLYBS_MASK) + +/* Bitfields in QSPI_ICR (Read/Write Instruction Code Register) */ +#define QSPI_ICR_INST_MASK GENMASK(7, 0) +#define QSPI_ICR_INST(inst) (((inst) << 0) & QSPI_ICR_INST_MASK) +#define QSPI_ICR_OPT_MASK GENMASK(23, 16) +#define QSPI_ICR_OPT(opt) (((opt) << 16) & QSPI_ICR_OPT_MASK) + +/* Bitfields in QSPI_IFR (Instruction Frame Register) */ +#define QSPI_IFR_WIDTH_MASK GENMASK(2, 0) +#define QSPI_IFR_WIDTH_SINGLE_BIT_SPI (0 << 0) +#define QSPI_IFR_WIDTH_DUAL_OUTPUT (1 << 0) +#define QSPI_IFR_WIDTH_QUAD_OUTPUT (2 << 0) +#define QSPI_IFR_WIDTH_DUAL_IO (3 << 0) +#define QSPI_IFR_WIDTH_QUAD_IO (4 << 0) +#define QSPI_IFR_WIDTH_DUAL_CMD (5 << 0) +#define QSPI_IFR_WIDTH_QUAD_CMD (6 << 0) +#define QSPI_IFR_INSTEN BIT(4) +#define QSPI_IFR_ADDREN BIT(5) +#define QSPI_IFR_OPTEN BIT(6) +#define QSPI_IFR_DATAEN BIT(7) +#define QSPI_IFR_OPTL_MASK GENMASK(9, 8) +#define QSPI_IFR_OPTL_1BIT (0 << 8) +#define QSPI_IFR_OPTL_2BIT (1 << 8) +#define QSPI_IFR_OPTL_4BIT (2 << 8) +#define QSPI_IFR_OPTL_8BIT (3 << 8) +#define QSPI_IFR_ADDRL BIT(10) +#define QSPI_IFR_TFRTYP_MEM BIT(12) +#define QSPI_IFR_SAMA5D2_WRITE_TRSFR BIT(13) +#define QSPI_IFR_CRM BIT(14) +#define QSPI_IFR_NBDUM_MASK GENMASK(20, 16) +#define QSPI_IFR_NBDUM(n) (((n) << 16) & QSPI_IFR_NBDUM_MASK) +#define QSPI_IFR_APBTFRTYP_READ BIT(24) /* Defined in SAM9X60 */ + +/* Bitfields in QSPI_SMR (Scrambling Mode Register) */ +#define QSPI_SMR_SCREN BIT(0) +#define QSPI_SMR_RVDIS BIT(1) + +/* Bitfields in QSPI_WPMR (Write Protection Mode Register) */ +#define QSPI_WPMR_WPEN BIT(0) +#define QSPI_WPMR_WPKEY_MASK GENMASK(31, 8) +#define QSPI_WPMR_WPKEY(wpkey) (((wpkey) << 8) & QSPI_WPMR_WPKEY_MASK) + +/* Bitfields in QSPI_WPSR (Write Protection Status Register) */ +#define QSPI_WPSR_WPVS BIT(0) +#define QSPI_WPSR_WPVSRC_MASK GENMASK(15, 8) +#define QSPI_WPSR_WPVSRC(src) (((src) << 8) & QSPI_WPSR_WPVSRC) + +struct atmel_qspi_caps { + bool has_qspick; + bool has_ricr; +}; + +struct atmel_qspi { + void __iomem *regs; + void __iomem *mem; + struct platform_device *pdev; + const struct atmel_qspi_caps *caps; + ulong bus_clk_rate; + u32 mr; +}; + +struct atmel_qspi_mode { + u8 cmd_buswidth; + u8 addr_buswidth; + u8 data_buswidth; + u32 config; +}; + +static const struct atmel_qspi_mode atmel_qspi_modes[] = { + { 1, 1, 1, QSPI_IFR_WIDTH_SINGLE_BIT_SPI }, + { 1, 1, 2, QSPI_IFR_WIDTH_DUAL_OUTPUT }, + { 1, 1, 4, QSPI_IFR_WIDTH_QUAD_OUTPUT }, + { 1, 2, 2, QSPI_IFR_WIDTH_DUAL_IO }, + { 1, 4, 4, QSPI_IFR_WIDTH_QUAD_IO }, + { 2, 2, 2, QSPI_IFR_WIDTH_DUAL_CMD }, + { 4, 4, 4, QSPI_IFR_WIDTH_QUAD_CMD }, +}; + +static inline bool atmel_qspi_is_compatible(const struct spi_mem_op *op, + const struct atmel_qspi_mode *mode) +{ + if (op->cmd.buswidth != mode->cmd_buswidth) + return false; + + if (op->addr.nbytes && op->addr.buswidth != mode->addr_buswidth) + return false; + + if (op->data.nbytes && op->data.buswidth != mode->data_buswidth) + return false; + + return true; +} + +static int atmel_qspi_find_mode(const struct spi_mem_op *op) +{ + u32 i; + + for (i = 0; i < ARRAY_SIZE(atmel_qspi_modes); i++) + if (atmel_qspi_is_compatible(op, &atmel_qspi_modes[i])) + return i; + + return -ENOTSUPP; +} + +static bool atmel_qspi_supports_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + if (atmel_qspi_find_mode(op) < 0) + return false; + + /* special case not supported by hardware */ + if (op->addr.nbytes == 2 && op->cmd.buswidth != op->addr.buswidth && + op->dummy.nbytes == 0) + return false; + + return true; +} + +static int atmel_qspi_set_cfg(struct atmel_qspi *aq, + const struct spi_mem_op *op, u32 *offset) +{ + u32 iar, icr, ifr; + u32 dummy_cycles = 0; + int mode; + + iar = 0; + icr = QSPI_ICR_INST(op->cmd.opcode); + ifr = QSPI_IFR_INSTEN; + + mode = atmel_qspi_find_mode(op); + if (mode < 0) + return mode; + ifr |= atmel_qspi_modes[mode].config; + + if (op->dummy.buswidth && op->dummy.nbytes) + dummy_cycles = op->dummy.nbytes * 8 / op->dummy.buswidth; + + /* + * The controller allows 24 and 32-bit addressing while NAND-flash + * requires 16-bit long. Handling 8-bit long addresses is done using + * the option field. For the 16-bit addresses, the workaround depends + * of the number of requested dummy bits. If there are 8 or more dummy + * cycles, the address is shifted and sent with the first dummy byte. + * Otherwise opcode is disabled and the first byte of the address + * contains the command opcode (works only if the opcode and address + * use the same buswidth). The limitation is when the 16-bit address is + * used without enough dummy cycles and the opcode is using a different + * buswidth than the address. + */ + if (op->addr.buswidth) { + switch (op->addr.nbytes) { + case 0: + break; + case 1: + ifr |= QSPI_IFR_OPTEN | QSPI_IFR_OPTL_8BIT; + icr |= QSPI_ICR_OPT(op->addr.val & 0xff); + break; + case 2: + if (dummy_cycles < 8 / op->addr.buswidth) { + ifr &= ~QSPI_IFR_INSTEN; + ifr |= QSPI_IFR_ADDREN; + iar = (op->cmd.opcode << 16) | + (op->addr.val & 0xffff); + } else { + ifr |= QSPI_IFR_ADDREN; + iar = (op->addr.val << 8) & 0xffffff; + dummy_cycles -= 8 / op->addr.buswidth; + } + break; + case 3: + ifr |= QSPI_IFR_ADDREN; + iar = op->addr.val & 0xffffff; + break; + case 4: + ifr |= QSPI_IFR_ADDREN | QSPI_IFR_ADDRL; + iar = op->addr.val & 0x7ffffff; + break; + default: + return -ENOTSUPP; + } + } + + /* offset of the data access in the QSPI memory space */ + *offset = iar; + + /* Set number of dummy cycles */ + if (dummy_cycles) + ifr |= QSPI_IFR_NBDUM(dummy_cycles); + + /* Set data enable */ + if (op->data.nbytes) + ifr |= QSPI_IFR_DATAEN; + + /* + * If the QSPI controller is set in regular SPI mode, set it in + * Serial Memory Mode (SMM). + */ + if (aq->mr != QSPI_MR_SMM) { + writel(QSPI_MR_SMM, aq->regs + QSPI_MR); + aq->mr = QSPI_MR_SMM; + } + + /* Clear pending interrupts */ + (void)readl(aq->regs + QSPI_SR); + + if (aq->caps->has_ricr) { + if (!op->addr.nbytes && op->data.dir == SPI_MEM_DATA_IN) + ifr |= QSPI_IFR_APBTFRTYP_READ; + + /* Set QSPI Instruction Frame registers */ + writel(iar, aq->regs + QSPI_IAR); + if (op->data.dir == SPI_MEM_DATA_IN) + writel(icr, aq->regs + QSPI_RICR); + else + writel(icr, aq->regs + QSPI_WICR); + writel(ifr, aq->regs + QSPI_IFR); + } else { + if (op->data.dir == SPI_MEM_DATA_OUT) + ifr |= QSPI_IFR_SAMA5D2_WRITE_TRSFR; + + /* Set QSPI Instruction Frame registers */ + writel(iar, aq->regs + QSPI_IAR); + writel(icr, aq->regs + QSPI_ICR); + writel(ifr, aq->regs + QSPI_IFR); + } + + return 0; +} + +static int atmel_qspi_exec_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + struct atmel_qspi *aq = dev_get_priv(slave->dev->parent); + u32 sr, imr, offset; + int err; + + err = atmel_qspi_set_cfg(aq, op, &offset); + if (err) + return err; + + /* Skip to the final steps if there is no data */ + if (op->data.nbytes) { + /* Dummy read of QSPI_IFR to synchronize APB and AHB accesses */ + (void)readl(aq->regs + QSPI_IFR); + + /* Send/Receive data */ + if (op->data.dir == SPI_MEM_DATA_IN) + memcpy_fromio(op->data.buf.in, aq->mem + offset, + op->data.nbytes); + else + memcpy_toio(aq->mem + offset, op->data.buf.out, + op->data.nbytes); + + /* Release the chip-select */ + writel(QSPI_CR_LASTXFER, aq->regs + QSPI_CR); + } + + /* Poll INSTruction End and Chip Select Rise flags. */ + imr = QSPI_SR_INSTRE | QSPI_SR_CSR; + return readl_poll_timeout(aq->regs + QSPI_SR, sr, (sr & imr) == imr, + 1000000); +} + +static int atmel_qspi_set_speed(struct udevice *bus, uint hz) +{ + struct atmel_qspi *aq = dev_get_priv(bus); + u32 scr, scbr, mask, new_value; + + /* Compute the QSPI baudrate */ + scbr = DIV_ROUND_UP(aq->bus_clk_rate, hz); + if (scbr > 0) + scbr--; + + new_value = QSPI_SCR_SCBR(scbr); + mask = QSPI_SCR_SCBR_MASK; + + scr = readl(aq->regs + QSPI_SCR); + if ((scr & mask) == new_value) + return 0; + + scr = (scr & ~mask) | new_value; + writel(scr, aq->regs + QSPI_SCR); + + return 0; +} + +static int atmel_qspi_set_mode(struct udevice *bus, uint mode) +{ + struct atmel_qspi *aq = dev_get_priv(bus); + u32 scr, mask, new_value = 0; + + if (mode & SPI_CPOL) + new_value = QSPI_SCR_CPOL; + if (mode & SPI_CPHA) + new_value = QSPI_SCR_CPHA; + + mask = QSPI_SCR_CPOL | QSPI_SCR_CPHA; + + scr = readl(aq->regs + QSPI_SCR); + if ((scr & mask) == new_value) + return 0; + + scr = (scr & ~mask) | new_value; + writel(scr, aq->regs + QSPI_SCR); + + return 0; +} + +static int atmel_qspi_enable_clk(struct udevice *dev) +{ + struct atmel_qspi *aq = dev_get_priv(dev); + struct clk pclk, qspick; + int ret; + + ret = clk_get_by_name(dev, "pclk", &pclk); + if (ret) + ret = clk_get_by_index(dev, 0, &pclk); + + if (ret) { + dev_err(dev, "Missing QSPI peripheral clock\n"); + return ret; + } + + ret = clk_enable(&pclk); + if (ret) { + dev_err(dev, "Failed to enable QSPI peripheral clock\n"); + goto free_pclk; + } + + if (aq->caps->has_qspick) { + /* Get the QSPI system clock */ + ret = clk_get_by_name(dev, "qspick", &qspick); + if (ret) { + dev_err(dev, "Missing QSPI peripheral clock\n"); + goto free_pclk; + } + + ret = clk_enable(&qspick); + if (ret) + dev_err(dev, "Failed to enable QSPI system clock\n"); + clk_free(&qspick); + } + + aq->bus_clk_rate = clk_get_rate(&pclk); + if (!aq->bus_clk_rate) + ret = -EINVAL; + +free_pclk: + clk_free(&pclk); + + return ret; +} + +static void atmel_qspi_init(struct atmel_qspi *aq) +{ + /* Reset the QSPI controller */ + writel(QSPI_CR_SWRST, aq->regs + QSPI_CR); + + /* Set the QSPI controller by default in Serial Memory Mode */ + writel(QSPI_MR_SMM, aq->regs + QSPI_MR); + aq->mr = QSPI_MR_SMM; + + /* Enable the QSPI controller */ + writel(QSPI_CR_QSPIEN, aq->regs + QSPI_CR); +} + +static int atmel_qspi_probe(struct udevice *dev) +{ + struct atmel_qspi *aq = dev_get_priv(dev); + struct resource res; + int ret; + + aq->caps = (struct atmel_qspi_caps *)dev_get_driver_data(dev); + if (!aq->caps) { + dev_err(dev, "Could not retrieve QSPI caps\n"); + return -EINVAL; + }; + + /* Map the registers */ + ret = dev_read_resource_byname(dev, "qspi_base", &res); + if (ret) { + dev_err(dev, "missing registers\n"); + return ret; + } + aq->regs = devm_ioremap(dev, res.start, resource_size(&res)); + if (IS_ERR(aq->regs)) + return PTR_ERR(aq->regs); + + /* Map the AHB memory */ + ret = dev_read_resource_byname(dev, "qspi_mmap", &res); + if (ret) { + dev_err(dev, "missing AHB memory\n"); + return ret; + } + aq->mem = devm_ioremap(dev, res.start, resource_size(&res)); + if (IS_ERR(aq->mem)) + return PTR_ERR(aq->mem); + + ret = atmel_qspi_enable_clk(dev); + if (ret) + return ret; + + atmel_qspi_init(aq); + + return 0; +} + +static const struct spi_controller_mem_ops atmel_qspi_mem_ops = { + .supports_op = atmel_qspi_supports_op, + .exec_op = atmel_qspi_exec_op, +}; + +static const struct dm_spi_ops atmel_qspi_ops = { + .set_speed = atmel_qspi_set_speed, + .set_mode = atmel_qspi_set_mode, + .mem_ops = &atmel_qspi_mem_ops, +}; + +static const struct atmel_qspi_caps atmel_sama5d2_qspi_caps = {}; + +static const struct atmel_qspi_caps atmel_sam9x60_qspi_caps = { + .has_qspick = true, + .has_ricr = true, +}; + +static const struct udevice_id atmel_qspi_ids[] = { + { + .compatible = "atmel,sama5d2-qspi", + .data = (ulong)&atmel_sama5d2_qspi_caps, + }, + { + .compatible = "microchip,sam9x60-qspi", + .data = (ulong)&atmel_sam9x60_qspi_caps, + }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(atmel_qspi) = { + .name = "atmel_qspi", + .id = UCLASS_SPI, + .of_match = atmel_qspi_ids, + .ops = &atmel_qspi_ops, + .priv_auto_alloc_size = sizeof(struct atmel_qspi), + .probe = atmel_qspi_probe, +};
+config ATMEL_QSPI
- bool "Atmel QSPI driver"
"Atmel Quad SPI Controller"
- depends on ARCH_AT91
- help
The description is wrong, I'll submit a new version if everything else looks ok. This should have been:
This enables support for the Quad SPI controller in master mode. This driver does not support generic SPI. The implementation only supports spi-mem interface.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v4: update Kconfig description v3: no change v2: no change
drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/atmel-quadspi.c | 535 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 544 insertions(+) create mode 100644 drivers/spi/atmel-quadspi.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index dc3e23f353aa..0b87c155b87a 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -49,6 +49,14 @@ config ATH79_SPI uses driver model and requires a device tree binding to operate. please refer to doc/device-tree-bindings/spi/spi-ath79.txt.
+config ATMEL_QSPI + bool "Atmel Quad SPI Controller" + depends on ARCH_AT91 + help + Enable the Atmel Quad SPI controller in master mode. This driver + does not support generic SPI. The implementation supports only the + spi-mem interface. + config ATMEL_SPI bool "Atmel SPI driver" default y if ARCH_AT91 diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 8be9a4baa244..32b42d18b1af 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -18,6 +18,7 @@ endif
+config ATMEL_QSPI
help
spi-mem interface.
- Driver for Atmel QSPI Controller
- Copyright (C) 2015 Atmel Corporation
- Copyright (C) 2018 Cryptera A/S
- Author: Cyrille Pitchen cyrille.pitchen@atmel.com
- Author: Piotr Bugalski bugalski.piotr@gmail.com
bool has_qspick;
bool has_ricr;
void __iomem *regs;
void __iomem *mem;
Linux copy, please drop this.
ulong bus_clk_rate;
u32 mr;
u8 cmd_buswidth;
u8 addr_buswidth;
u8 data_buswidth;
u32 config;
return false;
return false;
return false;
return true;
u32 i;
return i;
return -ENOTSUPP;
return false;
return false;
return true;
u32 iar, icr, ifr;
int mode;
iar = 0;
if (mode < 0)
return mode;
case 0:
break;
case 1:
break;
case 2:
} else {
break;
case 3:
break;
case 4:
break;
default:
return -ENOTSUPP;
*offset = iar;
if (dummy_cycles)
else
} else {
int err;
if (err)
return err;
op->data.nbytes);
else
op->data.nbytes);
1000000);
if (scbr > 0)
scbr--;
int ret;
if (ret)
if (ret) {
return ret;
if (ret) {
goto free_pclk;
if (ret) {
goto free_pclk;
if (ret)
clk_free(&qspick);
ret = -EINVAL;
+free_pclk:
clk_free(&pclk);
return ret;
int ret;
if (!aq->caps) {
return -EINVAL;
if (ret) {
return ret;
space
if (ret) {
return ret;
space
if (ret)
return ret;
.has_qspick = true,
.has_ricr = true,
Better assign NULL
Hi, Jagan,
On 06/12/2019 11:02 AM, Jagan Teki wrote:
External E-Mail
cut
cut
void __iomem *regs;
void __iomem *mem;
will do
int ret;
if (!aq->caps) {
return -EINVAL;
if (ret) {
return ret;
space
ok
if (ret) {
return ret;
space
ok
if (ret)
return ret;
.has_qspick = true,
.has_ricr = true,
Better assign NULL
I deliberately added a zeroed caps instance to the sama5d2 entry to not allow aq->caps to be NULL. This way I avoid redundant checks like:
+ if (aq->caps && aq->caps->has_qspick) { and + if (aq->caps && aq->caps->has_ricr) {
Since this patch is just a backport from the linux driver and does not modify the code logic, can we keep it as it is, and modify it later on if you have a strong opinion on this?
Cheers, ta
We have a macronix spi-nor flash on sama5d2_xplained RevB and a sst spi-nor flash on RevC. Select the rest for testing purposes.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v3: no change v2: new patch
configs/sama5d2_xplained_emmc_defconfig | 5 +++++ configs/sama5d2_xplained_mmc_defconfig | 5 +++++ configs/sama5d2_xplained_spiflash_defconfig | 5 +++++ 3 files changed, 15 insertions(+)
diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index f643b5a62f39..f244777121b1 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -65,6 +65,10 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y @@ -76,6 +80,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index c25d67bfebb1..633f6c5ad00c 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -67,6 +67,10 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y @@ -78,6 +82,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index ac5ae5133c3d..39da86530429 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -64,6 +64,10 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y @@ -75,6 +79,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y
We use a sst spi-nor flash memory on sama5d27_som1_ek. Select the others for testing purposes.
configs/sama5d27_som1_ek_mmc1_defconfig | 2 ++ configs/sama5d27_som1_ek_mmc_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 205a4399410f..9b2b78110357 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -67,6 +67,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=66000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y @@ -80,6 +81,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index 0a0780066cd8..e5c551e205d0 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -67,6 +67,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=66000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y @@ -80,6 +81,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y
From: Cyrille Pitchen cyrille.pitchen@microchip.com
Fix the following: - use "jedec,spi-nor" binding, we use jedec compatible flashes - set bus width to 4, we use quad capable flashes - differentiate bewteen data and clk and cs pins - drop partions as we don't use them in u-boot.
Signed-off-by: Cyrille Pitchen cyrille.pitchen@microchip.com [tudor.ambarus@microchip.com: use "jedec,spi-nor", edit commit message] Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v3: no change v2: new patch
arch/arm/dts/at91-sama5d2_xplained.dts | 36 ++++++++++++++++------------------ 1 file changed, 17 insertions(+), 19 deletions(-)
diff --git a/arch/arm/dts/at91-sama5d2_xplained.dts b/arch/arm/dts/at91-sama5d2_xplained.dts index c0708feeb7b2..7f0d1696ba3e 100644 --- a/arch/arm/dts/at91-sama5d2_xplained.dts +++ b/arch/arm/dts/at91-sama5d2_xplained.dts @@ -79,26 +79,18 @@ };
qspi0: spi@f0020000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi0_sck_cs_default &pinctrl_qspi0_dat_default>; status = "okay"; + u-boot,dm-pre-reloc;
flash@0 { - compatible = "atmel,sama5d2-qspi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; - #address-cells = <1>; - #size-cells = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_qspi0_default>; spi-max-frequency = <83000000>; - - partition@00000000 { - label = "boot"; - reg = <0x00000000 0x00c00000>; - }; - - partition@00c00000 { - label = "rootfs"; - reg = <0x00c00000 0x00000000>; - }; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <4>; + u-boot,dm-pre-reloc; }; };
@@ -208,14 +200,20 @@ bias-disable; };
- pinctrl_qspi0_default: qspi0_default { + pinctrl_qspi0_sck_cs_default: qspi0_sck_cs_default { pinmux = <PIN_PA22__QSPI0_SCK>, - <PIN_PA23__QSPI0_CS>, - <PIN_PA24__QSPI0_IO0>, + <PIN_PA23__QSPI0_CS>; + bias-disable; + u-boot,dm-pre-reloc; + }; + + pinctrl_qspi0_dat_default: qspi0_dat_default { + pinmux = <PIN_PA24__QSPI0_IO0>, <PIN_PA25__QSPI0_IO1>, <PIN_PA26__QSPI0_IO2>, <PIN_PA27__QSPI0_IO3>; - bias-disable; + bias-pull-up; + u-boot,dm-pre-reloc; };
pinctrl_sdmmc0_cmd_dat_default: sdmmc0_cmd_dat_default {
Use the same memory layout as we use for the NAND boot on the other boards.
QSPI flashes are present on the following boards: sama5d2_xplained RevB: 32 Mbyte flash (mx25l3273fm2i-08g) sama5d2_xplained RevC: 8 Mbyte flash (sst26vf064b-104i/sn) sama5d27_som1_ek: 8 Mbyte flash (sst26vf064b-104i/sn) sama5d2_ptc_ek: 8 Mbyte flash (sst26vf064b-104i/sn)
The 8 Mbyte limit is enough to cope with the memory layout used in the NAND boot. rootfs exceeds the 8 Mbyte limit and will stay in eMMC in the sama5d2_xplained case. The final scope is to use a single memory layout for all boot medias.
Signed-off-by: Cyrille Pitchen cyrille.pitchen@microchip.com [tudor.ambarus@microchip.com: change memory layout, add commit message] Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v3: no change v2: new patch
include/configs/at91-sama5_common.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index 30c6cd47cac2..fc46540a10ab 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -72,6 +72,14 @@ "sf read 0x21000000 0x60000 0xc000; " \ "sf read 0x22000000 0x6c000 0x394000; " \ "bootz 0x22000000 - 0x21000000" +#elif CONFIG_QSPI_BOOT +#define CONFIG_ENV_OFFSET 0x140000 +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_SECT_SIZE 0x1000 +#define CONFIG_BOOTCOMMAND "sf probe 0; " \ + "sf read 0x21000000 0x180000 0x80000; " \ + "sf read 0x22000000 0x200000 0x600000; " \ + "bootz 0x22000000 - 0x21000000" #endif
#endif
Add the default config file of QSPI media. The config is based on sama5d2_xplained_mmc_defconfig.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v3: fix the following: ./tools/genboardscfg.py WARNING: no status info for 'sama5d2_xplained_qspiflash' WARNING: no maintainers for 'sama5d2_xplained_qspiflash'
v2: new patch
board/atmel/sama5d2_xplained/MAINTAINERS | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 101 +++++++++++++++++++++++++++ 2 files changed, 102 insertions(+) create mode 100644 configs/sama5d2_xplained_qspiflash_defconfig
diff --git a/board/atmel/sama5d2_xplained/MAINTAINERS b/board/atmel/sama5d2_xplained/MAINTAINERS index 08de5bb6a076..88e327f81cd8 100644 --- a/board/atmel/sama5d2_xplained/MAINTAINERS +++ b/board/atmel/sama5d2_xplained/MAINTAINERS @@ -6,3 +6,4 @@ F: include/configs/sama5d2_xplained.h F: configs/sama5d2_xplained_mmc_defconfig F: configs/sama5d2_xplained_spiflash_defconfig F: configs/sama5d2_xplained_emmc_defconfig +F: configs/sama5d2_xplained_qspiflash_defconfig diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig new file mode 100644 index 000000000000..1bf04936f748 --- /dev/null +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -0,0 +1,101 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_SYS_TEXT_BASE=0x26f00000 +CONFIG_TARGET_SAMA5D2_XPLAINED=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0xf8020000 +CONFIG_DEBUG_UART_CLOCK=83000000 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_DEBUG_UART=y +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_MMC" +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p1 rw rootwait" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_xplained" +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_DM_GPIO=y +CONFIG_ATMEL_PIO4=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_AT91=y +CONFIG_I2C_EEPROM=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ATMEL_USART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_DM_VIDEO=y +CONFIG_ATMEL_HLCD=y +CONFIG_W1=y +CONFIG_W1_GPIO=y +CONFIG_W1_EEPROM=y +CONFIG_W1_EEPROM_DS24XXX=y +CONFIG_FAT_WRITE=y +CONFIG_OF_LIBFDT_OVERLAY=y
Add the default config file of QSPI media. The config is based on sama5d27_som1_ek_mmc_defconfig.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v3: fix the following: ./tools/genboardscfg.py WARNING: no status info for 'sama5d27_som1_ek_qspiflash' WARNING: no maintainers for 'sama5d27_som1_ek_qspiflash'
v2: new patch
board/atmel/sama5d27_som1_ek/MAINTAINERS | 1 + configs/sama5d27_som1_ek_qspiflash_defconfig | 101 +++++++++++++++++++++++++++ 2 files changed, 102 insertions(+) create mode 100644 configs/sama5d27_som1_ek_qspiflash_defconfig
diff --git a/board/atmel/sama5d27_som1_ek/MAINTAINERS b/board/atmel/sama5d27_som1_ek/MAINTAINERS index 74434e93e952..f2d2f49db304 100644 --- a/board/atmel/sama5d27_som1_ek/MAINTAINERS +++ b/board/atmel/sama5d27_som1_ek/MAINTAINERS @@ -5,3 +5,4 @@ F: board/atmel/sama5d27_som1_ek/ F: include/configs/sama5d27_som1_ek.h F: configs/sama5d27_som1_ek_mmc_defconfig F: configs/sama5d27_som1_ek_mmc1_defconfig +F: configs/sama5d27_som1_ek_qspiflash_defconfig diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig new file mode 100644 index 000000000000..128b6645f6d9 --- /dev/null +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -0,0 +1,101 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_SYS_TEXT_BASE=0x23f00000 +CONFIG_TARGET_SAMA5D27_SOM1_EK=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0xf8020000 +CONFIG_DEBUG_UART_CLOCK=82000000 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_DEBUG_UART=y +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d27_som1_ek" +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_DM_GPIO=y +CONFIG_ATMEL_PIO4=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_AT91=y +CONFIG_I2C_EEPROM=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=66000000 +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ATMEL_USART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_DM_VIDEO=y +CONFIG_ATMEL_HLCD=y +CONFIG_W1=y +CONFIG_W1_GPIO=y +CONFIG_W1_EEPROM=y +CONFIG_W1_EEPROM_DS24XXX=y +CONFIG_FAT_WRITE=y +CONFIG_OF_LIBFDT_OVERLAY=y
Use the qspi memory layout defined in at91-sama5_common - it aligns with the 8 Mbyte flash (sst26vf064b-104i/sn) available in sama5d27_som1_ek.
include/configs/sama5d27_som1_ek.h | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/include/configs/sama5d27_som1_ek.h b/include/configs/sama5d27_som1_ek.h index 5f6979cd77a5..90846c4bfd44 100644 --- a/include/configs/sama5d27_som1_ek.h +++ b/include/configs/sama5d27_som1_ek.h @@ -43,13 +43,6 @@ #endif
#ifdef CONFIG_QSPI_BOOT -#define CONFIG_ENV_OFFSET 0xb0000 -#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_BOOTCOMMAND "sf probe 0; " \ - "sf read 0x21000000 0xc0000 0x20000; " \ - "sf read 0x22000000 0xe0000 0x400000; " \ - "bootz 0x22000000 - 0x21000000" #undef CONFIG_BOOTARGS #define CONFIG_BOOTARGS \ "console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait"
The spi-nor flash resides on spi bus 1. Update the CONFIG_ENV_SPI_CS and CONFIG_BOOTCOMMAND accordingly.
Based on original work by Wenyou Yang.
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com [tudor.ambarus@microchip.com: amend the commit message.] Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v3: no change v2: new patch
include/configs/sama5d2_xplained.h | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index e522740e0c5b..3dea3591275f 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -46,6 +46,17 @@
#endif
+#ifdef CONFIG_QSPI_BOOT +#undef CONFIG_ENV_SPI_BUS +#undef CONFIG_BOOTCOMMAND +#define CONFIG_ENV_SPI_BUS 1 +#define CONFIG_BOOTCOMMAND "sf probe 1:0; " \ + "sf read 0x21000000 0x180000 0x80000; " \ + "sf read 0x22000000 0x200000 0x600000; "\ + "bootz 0x22000000 - 0x21000000" + +#endif + /* SPL */ #define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000
Jagan Teki
