[PATCH] km/arm: coding style clean up
Address most of the checkpatch issues we found in km_arm and common km code.
CC: Stefan Roese sr@denx.de CC: Valentin Longchamp valentin.longchamp@hitachi-powergrids.com Signed-off-by: Holger Brunck holger.brunck@hitachi-powergrids.com --- board/keymile/common/common.c | 44 ++++++++------- board/keymile/common/ivm.c | 84 ++++++++++++++--------------- board/keymile/km_arm/fpga_config.c | 16 +++--- board/keymile/km_arm/km_arm.c | 41 +++++++------- include/configs/km/keymile-common.h | 4 +- include/configs/km/km_arm.h | 2 +- 6 files changed, 96 insertions(+), 95 deletions(-)
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 03c7ce9da7..df507e2790 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -56,7 +56,7 @@ int set_km_env(void)
/* try to read rootfssize (ram image) from environment */ p = env_get("rootfssize"); - if (p != NULL) + if (p) strict_strtoul(p, 16, &rootfssize); pram = (rootfssize + CONFIG_KM_RESERVED_PRAM + CONFIG_KM_PHRAM + CONFIG_KM_PNVRAM) / 0x400; @@ -165,7 +165,7 @@ static int do_setboardid(struct cmd_tbl *cmdtp, int flag, int argc, char *p;
p = get_local_var("IVM_BoardId"); - if (p == NULL) { + if (!p) { printf("can't get the IVM_Boardid\n"); return 1; } @@ -174,7 +174,7 @@ static int do_setboardid(struct cmd_tbl *cmdtp, int flag, int argc, printf("set boardid=%s\n", buf);
p = get_local_var("IVM_HWKey"); - if (p == NULL) { + if (!p) { printf("can't get the IVM_HWKey\n"); return 1; } @@ -186,8 +186,8 @@ static int do_setboardid(struct cmd_tbl *cmdtp, int flag, int argc, return 0; }
-U_BOOT_CMD(km_setboardid, 1, 0, do_setboardid, "setboardid", "read out bid and " - "hwkey from IVM and set in environment"); +U_BOOT_CMD(km_setboardid, 1, 0, do_setboardid, "setboardid", + "read out bid and hwkey from IVM and set in environment");
/* * command km_checkbidhwk @@ -218,14 +218,14 @@ static int do_checkboardidhwk(struct cmd_tbl *cmdtp, int flag, int argc, * already stored in the local hush variables */ p = get_local_var("IVM_BoardId"); - if (p == NULL) { + if (!p) { printf("can't get the IVM_Boardid\n"); return 1; } rc = strict_strtoul(p, 16, &ivmbid);
p = get_local_var("IVM_HWKey"); - if (p == NULL) { + if (!p) { printf("can't get the IVM_HWKey\n"); return 1; } @@ -238,10 +238,10 @@ static int do_checkboardidhwk(struct cmd_tbl *cmdtp, int flag, int argc,
/* now try to read values from environment if available */ p = env_get("boardid"); - if (p != NULL) + if (p) rc = strict_strtoul(p, 16, &envbid); p = env_get("hwkey"); - if (p != NULL) + if (p) rc = strict_strtoul(p, 16, &envhwkey);
if (rc != 0) { @@ -263,9 +263,8 @@ static int do_checkboardidhwk(struct cmd_tbl *cmdtp, int flag, int argc,
if (verbose) { printf("IVM_BoardId: %ld, IVM_HWKey=%ld\n", - ivmbid, ivmhwkey); - printf("boardIdHwKeyList: %s\n", - bidhwklist); + ivmbid, ivmhwkey); + printf("boardIdHwKeyList: %s\n", bidhwklist); } while (!found) { /* loop over each bid/hwkey pair in the list */ @@ -291,13 +290,13 @@ static int do_checkboardidhwk(struct cmd_tbl *cmdtp, int flag, int argc, while (*rest && !isxdigit(*rest)) rest++; } - if ((!bid) || (!hwkey)) { + if (!bid || !hwkey) { /* end of list */ break; } if (verbose) { printf("trying bid=0x%lX, hwkey=%ld\n", - bid, hwkey); + bid, hwkey); } /* * Compare the values of the found entry in the @@ -305,7 +304,7 @@ static int do_checkboardidhwk(struct cmd_tbl *cmdtp, int flag, int argc, * in the inventory eeprom. If they are equal * set the values in environment variables. */ - if ((bid == ivmbid) && (hwkey == ivmhwkey)) { + if (bid == ivmbid && hwkey == ivmhwkey) { char buf[10];
found = 1; @@ -321,12 +320,12 @@ static int do_checkboardidhwk(struct cmd_tbl *cmdtp, int flag, int argc, }
/* compare now the values */ - if ((ivmbid == envbid) && (ivmhwkey == envhwkey)) { + if (ivmbid == envbid && ivmhwkey == envhwkey) { printf("boardid=0x%3lX, hwkey=%ld\n", envbid, envhwkey); rc = 0; /* match */ } else { printf("Error: env boardid=0x%3lX, hwkey=%ld\n", envbid, - envhwkey); + envhwkey); printf(" IVM bId=0x%3lX, hwKey=%ld\n", ivmbid, ivmhwkey); rc = 1; /* don't match */ } @@ -334,10 +333,8 @@ static int do_checkboardidhwk(struct cmd_tbl *cmdtp, int flag, int argc, }
U_BOOT_CMD(km_checkbidhwk, 2, 0, do_checkboardidhwk, - "check boardid and hwkey", - "[v]\n - check environment parameter "\ - ""boardIdListHex" against stored boardid and hwkey "\ - "from the IVM\n v: verbose output" + "check boardid and hwkey", + "[v]\n - check environment parameter "boardIdListHex" against stored boardid and hwkey from the IVM\n v: verbose output" );
/* @@ -356,6 +353,7 @@ static int do_checktestboot(struct cmd_tbl *cmdtp, int flag, int argc, #if defined(CONFIG_POST) testpin = post_hotkeys_pressed(); #endif + s = env_get("test_bank"); /* when test_bank is not set, act as if testpin is not asserted */ testboot = (testpin != 0) && (s); @@ -370,6 +368,6 @@ static int do_checktestboot(struct cmd_tbl *cmdtp, int flag, int argc, }
U_BOOT_CMD(km_checktestboot, 2, 0, do_checktestboot, - "check if testpin is asserted", - "[v]\n v - verbose output" + "check if testpin is asserted", + "[v]\n v - verbose output" ); diff --git a/board/keymile/common/ivm.c b/board/keymile/common/ivm.c index 60b89fe348..e989bf609f 100644 --- a/board/keymile/common/ivm.c +++ b/board/keymile/common/ivm.c @@ -46,28 +46,27 @@ static int ivm_set_value(char *name, char *value) { char tempbuf[256];
- if (value != NULL) { + if (value) { sprintf(tempbuf, "%s=%s", name, value); return set_local_var(tempbuf, 0); - } else { - unset_local_var(name); } + unset_local_var(name); return 0; }
static int ivm_get_value(unsigned char *buf, int len, char *name, int off, - int check) + int check) { unsigned short val; unsigned char valbuf[30];
- if ((buf[off + 0] != buf[off + 2]) && - (buf[off + 2] != buf[off + 4])) { + if (buf[off + 0] != buf[off + 2] && + buf[off + 2] != buf[off + 4]) { printf("%s Error corrupted %s\n", __func__, name); val = -1; } else { val = buf[off + 0] + (buf[off + 1] << 8); - if ((val == 0) && (check == 1)) + if (val == 0 && check == 1) val = -1; } sprintf((char *)valbuf, "%x", val); @@ -98,9 +97,9 @@ static char convert_char(char c) }
static int ivm_findinventorystring(int type, - unsigned char *const string, - unsigned long maxlen, - unsigned char *buf) + unsigned char *const string, + unsigned long maxlen, + unsigned char *buf) { int xcode = 0; unsigned long cr = 0; @@ -133,12 +132,12 @@ static int ivm_findinventorystring(int type, */ if (addr < INVENTORYDATASIZE) { /* Copy the IVM string in the corresponding string */ - for (; (buf[addr] != '\r') && - ((buf[addr] != ';') || (!stop)) && - (size < (maxlen - 1) && - (addr < INVENTORYDATASIZE)); addr++) { + for (; (buf[addr] != '\r') && + ((buf[addr] != ';') || (!stop)) && + (size < (maxlen - 1) && + (addr < INVENTORYDATASIZE)); addr++) { size += sprintf((char *)string + size, "%c", - convert_char (buf[addr])); + convert_char (buf[addr])); }
/* @@ -176,12 +175,12 @@ static int ivm_check_crc(unsigned char *buf, int block) unsigned long crceeprom;
crc = ivm_calc_crc(buf, CONFIG_SYS_IVM_EEPROM_PAGE_LEN - 2); - crceeprom = (buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN - 1] + \ + crceeprom = (buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN - 1] + buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN - 2] * 256); if (crc != crceeprom) { if (block == 0) - printf("Error CRC Block: %d EEprom: calculated: \ - %lx EEprom: %lx\n", block, crc, crceeprom); + printf("Error CRC Block: %d EEprom: calculated: %lx EEprom: %lx\n", + block, crc, crceeprom); return -1; } return 0; @@ -189,7 +188,7 @@ static int ivm_check_crc(unsigned char *buf, int block)
/* take care of the possible MAC address offset and the IVM content offset */ static int process_mac(unsigned char *valbuf, unsigned char *buf, - int offset, bool unique) + int offset, bool unique) { unsigned char mac[6]; unsigned long val = (buf[4] << 16) + (buf[5] << 8) + buf[6]; @@ -197,9 +196,9 @@ static int process_mac(unsigned char *valbuf, unsigned char *buf, /* use an intermediate buffer, to not change IVM content * MAC address is at offset 1 */ - memcpy(mac, buf+1, 6); + memcpy(mac, buf + 1, 6);
- /* MAC adress can be set to locally administred, this is only allowed + /* MAC address can be set to locally administred, this is only allowed * for interfaces which have now connection to the outside. For these * addresses we need to set the second bit in the first byte. */ @@ -222,7 +221,7 @@ static int ivm_analyze_block2(unsigned char *buf, int len) unsigned char valbuf[MAC_STR_SZ]; unsigned long count;
- /* IVM_MAC Adress begins at offset 1 */ + /* IVM_MAC Address begins at offset 1 */ sprintf((char *)valbuf, "%pM", buf + 1); ivm_set_value("IVM_MacAddress", (char *)valbuf); /* IVM_MacCount */ @@ -247,9 +246,9 @@ int ivm_analyze_eeprom(unsigned char *buf, int len) return -1;
ivm_get_value(buf, CONFIG_SYS_IVM_EEPROM_PAGE_LEN, - "IVM_BoardId", 0, 1); + "IVM_BoardId", 0, 1); val = ivm_get_value(buf, CONFIG_SYS_IVM_EEPROM_PAGE_LEN, - "IVM_HWKey", 6, 1); + "IVM_HWKey", 6, 1); if (val != 0xffff) { sprintf((char *)valbuf, "%x", ((val / 100) % 10)); ivm_set_value("IVM_HWVariant", (char *)valbuf); @@ -257,7 +256,7 @@ int ivm_analyze_eeprom(unsigned char *buf, int len) ivm_set_value("IVM_HWVersion", (char *)valbuf); } ivm_get_value(buf, CONFIG_SYS_IVM_EEPROM_PAGE_LEN, - "IVM_Functions", 12, 0); + "IVM_Functions", 12, 0);
GET_STRING("IVM_Symbol", IVM_POS_SYMBOL_ONLY, 8) GET_STRING("IVM_DeviceName", IVM_POS_SHORT_TEXT, 64) @@ -269,7 +268,7 @@ int ivm_analyze_eeprom(unsigned char *buf, int len) while (i < len) { if (tmp[i] == ';') { ivm_set_value("IVM_ShortText", - (char *)&tmp[i + 1]); + (char *)&tmp[i + 1]); break; } i++; @@ -292,7 +291,7 @@ int ivm_analyze_eeprom(unsigned char *buf, int len) if (ivm_check_crc(&buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN * 2], 2) != 0) return 0; ivm_analyze_block2(&buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN * 2], - CONFIG_SYS_IVM_EEPROM_PAGE_LEN); + CONFIG_SYS_IVM_EEPROM_PAGE_LEN);
return 0; } @@ -305,22 +304,23 @@ static int ivm_populate_env(unsigned char *buf, int len, int mac_address_offset) /* do we have the page 2 filled ? if not return */ if (ivm_check_crc(buf, 2)) return 0; - page2 = &buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN*2]; + page2 = &buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN * 2];
-#ifndef CONFIG_KMTEGR1 - /* if an offset is defined, add it */ - process_mac(valbuf, page2, mac_address_offset, true); - env_set((char *)"ethaddr", (char *)valbuf); -#else -/* KMTEGR1 has a special setup. eth0 has no connection to the outside and - * gets an locally administred MAC address, eth1 is the debug interface and - * gets the official MAC address from the IVM - */ - process_mac(valbuf, page2, mac_address_offset, false); - env_set((char *)"ethaddr", (char *)valbuf); - process_mac(valbuf, page2, mac_address_offset, true); - env_set((char *)"eth1addr", (char *)valbuf); -#endif + if (!IS_ENABLED(CONFIG_KMTEGR1)) { + /* if an offset is defined, add it */ + process_mac(valbuf, page2, mac_address_offset, true); + env_set((char *)"ethaddr", (char *)valbuf); + } else { + /* KMTEGR1 has a special setup. eth0 has no connection to the + * outside and gets an locally administred MAC address, eth1 is + * the debug interface and gets the official MAC address from + * the IVM + */ + process_mac(valbuf, page2, mac_address_offset, false); + env_set((char *)"ethaddr", (char *)valbuf); + process_mac(valbuf, page2, mac_address_offset, true); + env_set((char *)"eth1addr", (char *)valbuf); + }
return 0; } diff --git a/board/keymile/km_arm/fpga_config.c b/board/keymile/km_arm/fpga_config.c index abb5b7d60d..839b162eea 100644 --- a/board/keymile/km_arm/fpga_config.c +++ b/board/keymile/km_arm/fpga_config.c @@ -40,14 +40,14 @@ static int boco_clear_bits(u8 reg, u8 flags) ret = i2c_read(BOCO_ADDR, reg, 1, ®val, 1); if (ret) { printf("%s: error reading the BOCO @%#x !!\n", - __func__, reg); + __func__, reg); return ret; } regval &= ~flags; ret = i2c_write(BOCO_ADDR, reg, 1, ®val, 1); if (ret) { printf("%s: error writing the BOCO @%#x !!\n", - __func__, reg); + __func__, reg); return ret; }
@@ -63,14 +63,14 @@ static int boco_set_bits(u8 reg, u8 flags) ret = i2c_read(BOCO_ADDR, reg, 1, ®val, 1); if (ret) { printf("%s: error reading the BOCO @%#x !!\n", - __func__, reg); + __func__, reg); return ret; } regval |= flags; ret = i2c_write(BOCO_ADDR, reg, 1, ®val, 1); if (ret) { printf("%s: error writing the BOCO @%#x !!\n", - __func__, reg); + __func__, reg); return ret; }
@@ -113,7 +113,8 @@ int trigger_fpga_config(void) skip = 0; #ifndef CONFIG_KM_FPGA_FORCE_CONFIG /* if the FPGA is already configured, we do not want to - * reconfigure it */ + * reconfigure it + */ skip = 0; if (fpga_done()) { printf("PCIe FPGA config: skipped\n"); @@ -179,7 +180,7 @@ int wait_for_fpga_config(void) ret = i2c_read(BOCO_ADDR, SPI_REG, 1, &spictrl, 1); if (ret) { printf("%s: error reading the BOCO spictrl !!\n", - __func__); + __func__); return ret; } if (timeout-- == 0) { @@ -235,7 +236,8 @@ int fpga_reset(void) #endif
/* the FPGA was configured, we configure the BOCO2 so that the EEPROM - * is available from the Bobcat SPI bus */ + * is available from the Bobcat SPI bus + */ int toggle_eeprom_spi_bus(void) { int ret = 0; diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c index 7d191ab860..60187bd8d2 100644 --- a/board/keymile/km_arm/km_arm.c +++ b/board/keymile/km_arm/km_arm.c @@ -53,9 +53,9 @@ DECLARE_GLOBAL_DATA_PTR; #define PHY_MARVELL_88E1118R_LED_CTRL_REG 0x0010
#define PHY_MARVELL_88E1118R_LED_CTRL_RESERVED 0x1000 -#define PHY_MARVELL_88E1118R_LED_CTRL_LED0_1000MB (0x7<<0) -#define PHY_MARVELL_88E1118R_LED_CTRL_LED1_ACT (0x3<<4) -#define PHY_MARVELL_88E1118R_LED_CTRL_LED2_LINK (0x0<<8) +#define PHY_MARVELL_88E1118R_LED_CTRL_LED0_1000MB (0x7 << 0) +#define PHY_MARVELL_88E1118R_LED_CTRL_LED1_ACT (0x3 << 4) +#define PHY_MARVELL_88E1118R_LED_CTRL_LED2_LINK (0x0 << 8)
/* I/O pin to erase flash RGPP09 = MPP43 */ #define KM_FLASH_ERASE_ENABLE 43 @@ -169,6 +169,7 @@ static void set_bootcount_addr(void) { uchar buf[32]; unsigned int bootcountaddr; + bootcountaddr = gd->ram_size - BOOTCOUNT_ADDR; sprintf((char *)buf, "0x%x", bootcountaddr); env_set("bootcountaddr", (char *)buf); @@ -192,7 +193,7 @@ int board_early_init_f(void)
/* set the 2 bitbang i2c pins as output gpios */ tmp = readl(MVEBU_GPIO0_BASE + 4); - writel(tmp & (~KM_KIRKWOOD_SOFT_I2C_GPIOS) , MVEBU_GPIO0_BASE + 4); + writel(tmp & (~KM_KIRKWOOD_SOFT_I2C_GPIOS), MVEBU_GPIO0_BASE + 4); #endif /* adjust SDRAM size for bank 0 */ mvebu_sdram_size_adjust(0); @@ -292,11 +293,11 @@ int mvebu_board_spi_release_bus(struct udevice *dev)
#define PHY_LED_SEL_REG 0x18 #define PHY_LED0_LINK (0x5) -#define PHY_LED1_ACT (0x8<<4) -#define PHY_LED2_INT (0xe<<8) +#define PHY_LED1_ACT (0x8 << 4) +#define PHY_LED2_INT (0xe << 8) #define PHY_SPEC_CTRL_REG 0x1c -#define PHY_RGMII_CLK_STABLE (0x1<<10) -#define PHY_CLSA (0x1<<1) +#define PHY_RGMII_CLK_STABLE (0x1 << 10) +#define PHY_CLSA (0x1 << 1)
/* Configure and enable MV88E3018 PHY */ void reset_phy(void) @@ -407,8 +408,8 @@ void reset_phy(void) return;
/* check for Marvell 88E1118R Gigabit PHY (PIGGY3) */ - if ((oui == PHY_MARVELL_OUI) && - (model == PHY_MARVELL_88E1118R_MODEL)) { + if (oui == PHY_MARVELL_OUI && + model == PHY_MARVELL_88E1118R_MODEL) { /* set page register to 3 */ if (miiphy_write(name, CONFIG_PHY_BASE_ADR, PHY_MARVELL_PAGE_REG, @@ -438,7 +439,6 @@ void reset_phy(void) } #endif
- #if defined(CONFIG_HUSH_INIT_VAR) int hush_init_var(void) { @@ -478,22 +478,23 @@ int get_scl(void)
int post_hotkeys_pressed(void) { -#if defined(CONFIG_KM_COGE5UN) - return kw_gpio_get_value(KM_POST_EN_L); -#else - return !kw_gpio_get_value(KM_POST_EN_L); -#endif + if (IS_ENABLED(CONFIG_KM_COGE5UN)) + return kw_gpio_get_value(KM_POST_EN_L); + else + return !kw_gpio_get_value(KM_POST_EN_L); }
ulong post_word_load(void) { - void* addr = (void *) (gd->ram_size - BOOTCOUNT_ADDR + POST_WORD_OFF); + void *addr = (void *)(gd->ram_size - BOOTCOUNT_ADDR + POST_WORD_OFF); + return in_le32(addr);
} void post_word_store(ulong value) { - void* addr = (void *) (gd->ram_size - BOOTCOUNT_ADDR + POST_WORD_OFF); + void *addr = (void *)(gd->ram_size - BOOTCOUNT_ADDR + POST_WORD_OFF); + out_le32(addr, value); }
@@ -502,14 +503,14 @@ int arch_memory_test_prepare(u32 *vstart, u32 *size, phys_addr_t *phys_offset) *vstart = CONFIG_SYS_SDRAM_BASE;
/* we go up to relocation plus a 1 MB margin */ - *size = CONFIG_SYS_TEXT_BASE - (1<<20); + *size = CONFIG_SYS_TEXT_BASE - (1 << 20);
return 0; } #endif
#if defined(CONFIG_SYS_EEPROM_WREN) -int eeprom_write_enable(unsigned dev_addr, int state) +int eeprom_write_enable(unsigned int dev_addr, int state) { kw_gpio_set_value(KM_KIRKWOOD_ENV_WP, !state);
diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index c1968048a7..7ea5ebd8b5 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -184,9 +184,9 @@ "cramfsloadfdt=" \ "cramfsload ${fdt_addr_r} " \ "fdt_0x${IVM_BoardId}_0x${IVM_HWKey}.dtb\0" \ - "fdt_addr_r="__stringify(CONFIG_KM_FDT_ADDR) "\0" \ + "fdt_addr_r=" __stringify(CONFIG_KM_FDT_ADDR) "\0" \ "init=/sbin/init-overlay.sh\0" \ - "load_addr_r="__stringify(CONFIG_KM_KERNEL_ADDR) "\0" \ + "load_addr_r=" __stringify(CONFIG_KM_KERNEL_ADDR) "\0" \ "load=tftpboot ${load_addr_r} ${u-boot}\0" \ "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 98e0ce1c24..29060fa96b 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -48,7 +48,7 @@ " boardid=0x${IVM_BoardId} hwkey=0x${IVM_HWKey}"
#define CONFIG_KM_DEF_ENV_CPU \ - "u-boot="CONFIG_HOSTNAME "/u-boot.kwb\0" \ + "u-boot=" CONFIG_HOSTNAME "/u-boot.kwb\0" \ CONFIG_KM_UPDATE_UBOOT \ "set_fdthigh=setenv fdt_high ${kernelmem}\0" \ "checkfdt=" \
Thanks, Stefan
- if (p != NULL)
- if (p) strict_strtoul(p, 16, &rootfssize); pram = (rootfssize + CONFIG_KM_RESERVED_PRAM + CONFIG_KM_PHRAM + CONFIG_KM_PNVRAM) / 0x400;
- if (p == NULL) {
- if (!p) { printf("can't get the IVM_Boardid\n"); return 1; }
- if (p == NULL) {
- if (!p) { printf("can't get the IVM_HWKey\n"); return 1; }
- command km_checkbidhwk
- if (p == NULL) {
- if (p == NULL) {
- if (p != NULL)
- if (p) rc = strict_strtoul(p, 16, &envbid); p = env_get("hwkey");
- if (p != NULL)
if (rc != 0) {
ivmbid, ivmhwkey);
bidhwklist);
ivmbid, ivmhwkey);
bid, hwkey);
if (bid == ivmbid && hwkey == ivmhwkey) { char buf[10]; found = 1;
- if (ivmbid == envbid && ivmhwkey == envhwkey) { printf("boardid=0x%3lX, hwkey=%ld\n", envbid, envhwkey); rc = 0; /* match */ } else { printf("Error: env boardid=0x%3lX, hwkey=%ld\n", envbid,
envhwkey);
printf(" IVM bId=0x%3lX, hwKey=%ld\n", ivmbid, ivmhwkey); rc = 1; /* don't match */ }envhwkey);
"\"boardIdListHex\" against stored boardid and hwkey "\
"[v]\n - check environment parameter \"boardIdListHex\" against stored boardid and hwkey from the IVM\n v: verbose output"
- s = env_get("test_bank"); /* when test_bank is not set, act as if testpin is not asserted */ testboot = (testpin != 0) && (s);
);"[v]\n v - verbose output"
- if (value) { sprintf(tempbuf, "%s=%s", name, value); return set_local_var(tempbuf, 0);
- } else {
}unset_local_var(name);
int check)
{ unsigned short val; unsigned char valbuf[30];int check)
- if (buf[off + 0] != buf[off + 2] &&
printf("%s Error corrupted %s\n", __func__, name); val = -1; } else { val = buf[off + 0] + (buf[off + 1] << 8);buf[off + 2] != buf[off + 4]) {
} sprintf((char *)valbuf, "%x", val);if (val == 0 && check == 1) val = -1;
unsigned char *buf)
{ int xcode = 0; unsigned long cr = 0;unsigned char *buf)
- crceeprom = (buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN - 1] + buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN - 2] * 256); if (crc != crceeprom) { if (block == 0)
return -1; } return 0;block, crc, crceeprom);
{ unsigned char mac[6]; unsigned long val = (buf[4] << 16) + (buf[5] << 8) + buf[6];int offset, bool unique)
- memcpy(mac, buf + 1, 6);
- /* MAC address can be set to locally administred, this is only allowed
- for interfaces which have now connection to the outside. For these
- addresses we need to set the second bit in the first byte.
- /* IVM_MAC Address begins at offset 1 */ sprintf((char *)valbuf, "%pM", buf + 1); ivm_set_value("IVM_MacAddress", (char *)valbuf); /* IVM_MacCount */
val = ivm_get_value(buf, CONFIG_SYS_IVM_EEPROM_PAGE_LEN,"IVM_BoardId", 0, 1);
"IVM_HWKey", 6, 1);
if (val != 0xffff) { sprintf((char *)valbuf, "%x", ((val / 100) % 10)); ivm_set_value("IVM_HWVariant", (char *)valbuf);"IVM_HWKey", 6, 1);
return 0; }
- page2 = &buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN * 2];
- gets an locally administred MAC address, eth1 is the debug interface and
- gets the official MAC address from the IVM
-#endif
} else {
* the IVM
return 0; }
__func__, reg);
return ret; } regval &= ~flags; ret = i2c_write(BOCO_ADDR, reg, 1, ®val, 1); if (ret) { printf("%s: error writing the BOCO @%#x !!\n",__func__, reg);
__func__, reg);
return ret; }__func__, reg);
__func__, reg);
return ret; } regval |= flags; ret = i2c_write(BOCO_ADDR, reg, 1, ®val, 1); if (ret) { printf("%s: error writing the BOCO @%#x !!\n",__func__, reg);
__func__, reg);
* reconfigure it */
* reconfigure it
skip = 0; if (fpga_done()) { printf("PCIe FPGA config: skipped\n");*/
__func__);
} if (timeout-- == 0) {__func__); return ret;
- is available from the Bobcat SPI bus */
- */ int toggle_eeprom_spi_bus(void) { int ret = 0;
- bootcountaddr = gd->ram_size - BOOTCOUNT_ADDR; sprintf((char *)buf, "0x%x", bootcountaddr); env_set("bootcountaddr", (char *)buf);
- writel(tmp & (~KM_KIRKWOOD_SOFT_I2C_GPIOS), MVEBU_GPIO0_BASE + 4); #endif /* adjust SDRAM size for bank 0 */ mvebu_sdram_size_adjust(0);
- if (oui == PHY_MARVELL_OUI &&
/* set page register to 3 */ if (miiphy_write(name, CONFIG_PHY_BASE_ADR, PHY_MARVELL_PAGE_REG,model == PHY_MARVELL_88E1118R_MODEL) {
-#else
-#endif
else
- void *addr = (void *)(gd->ram_size - BOOTCOUNT_ADDR + POST_WORD_OFF);
- out_le32(addr, value); }
return 0; } #endif
- "fdt_addr_r=" __stringify(CONFIG_KM_FDT_ADDR) "\0" \ "init=/sbin/init-overlay.sh\0" \
- "load_addr_r=" __stringify(CONFIG_KM_KERNEL_ADDR) "\0" \ "load=tftpboot ${load_addr_r} ${u-boot}\0" \ "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \
- "u-boot=" CONFIG_HOSTNAME "/u-boot.kwb\0" \ CONFIG_KM_UPDATE_UBOOT \ "set_fdthigh=setenv fdt_high ${kernelmem}\0" \ "checkfdt=" \
Viele Grüße, Stefan
CC: Stefan Roese sr@denx.de CC: Valentin Longchamp valentin.longchamp@hitachi-powergrids.com Signed-off-by: Holger Brunck holger.brunck@hitachi-powergrids.com Reviewed-by: Stefan Roese sr@denx.de
Holger Brunck
Stefan Roese
