[U-Boot] [PATCH v7 08/20] sandbox: Add board info for architecture
This is required for the bdinfo command to work.
This also cleans up the #ifdef mess for ethernet and lnum a little.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v7: - Correct typo (missing backslash at end of line)
common/cmd_bdinfo.c | 34 ++++++++++++++++++++++++++++++---- 1 files changed, 30 insertions(+), 4 deletions(-)
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 6051120..9c1d7d0 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -31,11 +31,14 @@ DECLARE_GLOBAL_DATA_PTR;
static void print_num(const char *, ulong);
-#if !(defined(CONFIG_ARM) || defined(CONFIG_M68K)) || defined(CONFIG_CMD_NET) +#if !(defined(CONFIG_ARM) || defined(CONFIG_M68K) || defined(CONFIG_SANDBOX)) \ + || defined(CONFIG_CMD_NET) +#define HAVE_PRINT_ETH static void print_eth(int idx); #endif
-#if (!defined(CONFIG_ARM) && !defined(CONFIG_X86)) +#if (!defined(CONFIG_ARM) && !defined(CONFIG_X86) && !defined(CONFIG_SANDBOX)) +#define HAVE_PRINT_LNUM static void print_lnum(const char *, u64); #endif
@@ -413,6 +416,29 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
+#elif defined(CONFIG_SANDBOX) + +int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int i; + bd_t *bd = gd->bd; + + print_num("boot_params", (ulong)bd->bi_boot_params); + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { + print_num("DRAM bank", i); + print_num("-> start", bd->bi_dram[i].start); + print_num("-> size", bd->bi_dram[i].size); + } + +#if defined(CONFIG_CMD_NET) + print_eth(0); + printf("ip_addr = %pI4\n", &bd->bi_ip_addr); +#endif + print_num("FB base ", gd->fb_base); + return 0; +} + #else #error "a case for this architecture does not exist!" #endif @@ -422,7 +448,7 @@ static void print_num(const char *name, ulong value) printf("%-12s= 0x%08lX\n", name, value); }
-#if !(defined(CONFIG_ARM) || defined(CONFIG_M68K)) || defined(CONFIG_CMD_NET) +#ifdef HAVE_PRINT_ETH static void print_eth(int idx) { char name[10], *val; @@ -437,7 +463,7 @@ static void print_eth(int idx) } #endif
-#if (!defined(CONFIG_ARM) && !defined(CONFIG_X86)) +#ifdef HAVE_PRINT_LNUM static void print_lnum(const char *name, u64 value) { printf("%-12s= 0x%.8llX\n", name, value);
Dear Simon Glass,
Changes in v7:
I already found & fixed this one.
