[PATCH 0/6] Clean up eSDHC periperhal clock code
This patch-set is to clean up eSDHC peripheral clock code. - Drop useless code in esdhc/esdhc_imx drivers and powerpc/. - Add global variable sdhc_per_clk for peripehral clock. - Drop CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK option and let driver decides which clock to use. - Some fixes for peripehral clock calcualtion.
Yangbo Lu (6): mmc: fsl_esdhc_imx: drop QorIQ eSDHC specific peripheral clock code mmc: fsl_esdhc: drop useless fdt fixup powerpc/mpc85xx: drop eSDHC periperhal clock code Add global variable sdhc_per_clk for arm/powerpc configs: ls1028a: use default SDHC clock divider value Drop CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK usage
.../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 29 +++++-------- .../arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c | 22 +++++----- arch/arm/include/asm/global_data.h | 4 ++ arch/powerpc/cpu/mpc85xx/speed.c | 49 +--------------------- arch/powerpc/include/asm/config_mpc85xx.h | 8 ---- arch/powerpc/include/asm/global_data.h | 1 + configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 1 - configs/ls1028aqds_tfa_defconfig | 1 - configs/ls1028ardb_tfa_SECURE_BOOT_defconfig | 1 - configs/ls1028ardb_tfa_defconfig | 1 - drivers/mmc/Kconfig | 9 ---- drivers/mmc/fsl_esdhc.c | 41 +++++++++--------- drivers/mmc/fsl_esdhc_imx.c | 40 ------------------ include/configs/T1040QDS.h | 1 - include/configs/T208xQDS.h | 1 - include/e500.h | 1 - scripts/config_whitelist.txt | 2 - 17 files changed, 48 insertions(+), 164 deletions(-)
Drop QorIQ eSDHC specific peripheral clock code.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- drivers/mmc/fsl_esdhc_imx.c | 40 ---------------------------------------- 1 file changed, 40 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index f1afab7..e1528e7 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -658,35 +658,6 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) priv->clock = clock; }
-#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK -static void esdhc_clock_control(struct fsl_esdhc_priv *priv, bool enable) -{ - struct fsl_esdhc *regs = priv->esdhc_regs; - u32 value; - u32 time_out; - - value = esdhc_read32(®s->sysctl); - - if (enable) - value |= SYSCTL_CKEN; - else - value &= ~SYSCTL_CKEN; - - esdhc_write32(®s->sysctl, value); - - time_out = 20; - value = PRSSTAT_SDSTB; - while (!(esdhc_read32(®s->prsstat) & value)) { - if (time_out == 0) { - printf("fsl_esdhc: Internal clock never stabilised.\n"); - break; - } - time_out--; - mdelay(1); - } -} -#endif - #ifdef MMC_SUPPORTS_TUNING static int esdhc_change_pinstate(struct udevice *dev) { @@ -958,12 +929,6 @@ static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) int ret __maybe_unused; u32 clock;
-#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK - /* Select to use peripheral clock */ - esdhc_clock_control(priv, false); - esdhc_setbits32(®s->scr, ESDHCCTL_PCS); - esdhc_clock_control(priv, true); -#endif /* Set the clock speed */ clock = mmc->clock; if (clock < mmc->cfg->f_min) @@ -1388,13 +1353,8 @@ void fdt_fixup_esdhc(void *blob, bd_t *bd) if (esdhc_status_fixup(blob, compat)) return;
-#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK - do_fixup_by_compat_u32(blob, compat, "peripheral-frequency", - gd->arch.sdhc_clk, 1); -#else do_fixup_by_compat_u32(blob, compat, "clock-frequency", gd->arch.sdhc_clk, 1); -#endif } #endif
The fdt fixup for properties "peripheral-frequency" and "adapter-type" was once for a Freescale SDK release. The properties haven't been existed in linux mainline. Drop these useless code.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- drivers/mmc/fsl_esdhc.c | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 1e7d606..8655503 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -716,17 +716,8 @@ void fdt_fixup_esdhc(void *blob, bd_t *bd) if (esdhc_status_fixup(blob, compat)) return;
-#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK - do_fixup_by_compat_u32(blob, compat, "peripheral-frequency", - gd->arch.sdhc_clk, 1); -#else do_fixup_by_compat_u32(blob, compat, "clock-frequency", gd->arch.sdhc_clk, 1); -#endif -#ifdef CONFIG_FSL_ESDHC_ADAPTER_IDENT - do_fixup_by_compat_u32(blob, compat, "adapter-type", - (u32)(gd->arch.sdhc_adapter), 1); -#endif } #endif
The below patch added eSDHC periperhal clock code initially. 2d9ca2c mmc: fsl_esdhc: Add peripheral clock support
The purpose was to fix up device tree properties "peripheral-frequency" so that linux could get the periperhal clock by it. However the implementation on both u-boot and linux was only for a Freescale SDK release. The linux part implementation had never been upstreamed. These code should not have been exist on u-boot mainline.
Let's remove the powerpc part changes but keep the changes in fsl_esdhc driver. The changes in fsl_esdhc driver could be utilized to support SD UHS and eMMC HS200/HS400 speed modes for current Layerscape ARM platforms.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- arch/powerpc/cpu/mpc85xx/speed.c | 49 +------------------------------ arch/powerpc/include/asm/config_mpc85xx.h | 8 ----- include/configs/T1040QDS.h | 1 - include/configs/T208xQDS.h | 1 - include/e500.h | 1 - scripts/config_whitelist.txt | 2 -- 6 files changed, 1 insertion(+), 61 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index 15b05fc..0c5252e 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -69,8 +69,7 @@ void get_sys_info(sys_info_t *sys_info) [14] = 4, /* CC4 PPL / 4 */ }; uint i, freq_c_pll[CONFIG_SYS_FSL_NUM_CC_PLLS]; -#if !defined(CONFIG_FM_PLAT_CLK_DIV) || !defined(CONFIG_PME_PLAT_CLK_DIV) || \ - defined(CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK) +#if !defined(CONFIG_FM_PLAT_CLK_DIV) || !defined(CONFIG_PME_PLAT_CLK_DIV) uint rcw_tmp; #endif uint ratio[CONFIG_SYS_FSL_NUM_CC_PLLS]; @@ -450,48 +449,6 @@ void get_sys_info(sys_info_t *sys_info) #endif #endif
-#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK -#if defined(CONFIG_ARCH_T2080) -#define ESDHC_CLK_SEL 0x00000007 -#define ESDHC_CLK_SHIFT 0 -#define ESDHC_CLK_RCWSR 15 -#else /* Support T1040 T1024 by now */ -#define ESDHC_CLK_SEL 0xe0000000 -#define ESDHC_CLK_SHIFT 29 -#define ESDHC_CLK_RCWSR 7 -#endif - rcw_tmp = in_be32(&gur->rcwsr[ESDHC_CLK_RCWSR]); - switch ((rcw_tmp & ESDHC_CLK_SEL) >> ESDHC_CLK_SHIFT) { - case 1: - sys_info->freq_sdhc = freq_c_pll[CONFIG_SYS_SDHC_CLK]; - break; - case 2: - sys_info->freq_sdhc = freq_c_pll[CONFIG_SYS_SDHC_CLK] / 2; - break; - case 3: - sys_info->freq_sdhc = freq_c_pll[CONFIG_SYS_SDHC_CLK] / 3; - break; -#if defined(CONFIG_SYS_SDHC_CLK_2_PLL) - case 4: - sys_info->freq_sdhc = freq_c_pll[CONFIG_SYS_SDHC_CLK] / 4; - break; -#if defined(CONFIG_ARCH_T2080) - case 5: - sys_info->freq_sdhc = freq_c_pll[1 - CONFIG_SYS_SDHC_CLK]; - break; -#endif - case 6: - sys_info->freq_sdhc = freq_c_pll[1 - CONFIG_SYS_SDHC_CLK] / 2; - break; - case 7: - sys_info->freq_sdhc = freq_c_pll[1 - CONFIG_SYS_SDHC_CLK] / 3; - break; -#endif - default: - sys_info->freq_sdhc = 0; - printf("Error: Unknown SDHC peripheral clock select!\n"); - } -#endif #else /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */
for_each_cpu(i, cpu, cpu_numcores(), cpu_mask()) { @@ -673,15 +630,11 @@ int get_clocks (void) gd->arch.i2c2_clk = gd->arch.i2c1_clk;
#if defined(CONFIG_FSL_ESDHC) -#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK - gd->arch.sdhc_clk = sys_info.freq_sdhc / 2; -#else #if defined(CONFIG_ARCH_MPC8569) || defined(CONFIG_ARCH_P1010) gd->arch.sdhc_clk = gd->bus_clk; #else gd->arch.sdhc_clk = gd->bus_clk / 2; #endif -#endif #endif /* defined(CONFIG_FSL_ESDHC) */
#if defined(CONFIG_CPM2) diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 946e74a..4ca1e2b 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -331,9 +331,6 @@ #define CONFIG_SYS_FMAN_V3 #define CONFIG_FM_PLAT_CLK_DIV 1 #define CONFIG_SYS_FM1_CLK CONFIG_FM_PLAT_CLK_DIV -#define CONFIG_SYS_SDHC_CLK 0/* Select SDHC CLK begining from PLL1 - per rcw field value */ -#define CONFIG_SYS_SDHC_CLK_2_PLL /* Select SDHC CLK from 2 PLLs */ #define CONFIG_SYS_FM_MURAM_SIZE 0x30000 #define CONFIG_SYS_FSL_SINGLE_SOURCE_CLK #define CONFIG_SYS_FSL_TBCLK_DIV 16 @@ -362,8 +359,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FM1_CLK 0 -#define CONFIG_SYS_SDHC_CLK 0/* Select SDHC CLK begining from PLL1 - per rcw field value */ #define CONFIG_QBMAN_CLK_DIV 1 #define CONFIG_SYS_FM_MURAM_SIZE 0x30000 #define CONFIG_SYS_FSL_SINGLE_SOURCE_CLK @@ -402,9 +397,6 @@ #define CONFIG_PME_PLAT_CLK_DIV 1 #define CONFIG_SYS_PME_CLK CONFIG_PME_PLAT_CLK_DIV #define CONFIG_SYS_FM1_CLK 0 -#define CONFIG_SYS_SDHC_CLK 1/* Select SDHC CLK begining from PLL2 - per rcw field value */ -#define CONFIG_SYS_SDHC_CLK_2_PLL /* Select SDHC CLK from 2 PLLs */ #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index b845698..aa2a8b0 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -481,7 +481,6 @@ unsigned long get_board_ddr_clk(void); #endif
#ifdef CONFIG_MMC -#define CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_FSL_ESDHC_ADAPTER_IDENT #endif diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 2078b9d..be5a658 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -630,7 +630,6 @@ unsigned long get_board_ddr_clk(void); * SDHC */ #ifdef CONFIG_MMC -#define CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 diff --git a/include/e500.h b/include/e500.h index 1acf778..255f46b 100644 --- a/include/e500.h +++ b/include/e500.h @@ -18,7 +18,6 @@ typedef struct unsigned long freq_ddrbus; unsigned long freq_localbus; unsigned long freq_qe; - unsigned long freq_sdhc; #ifdef CONFIG_SYS_DPAA_FMAN unsigned long freq_fman[CONFIG_SYS_NUM_FMAN]; #endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index cf1808e..7c7eba6 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3784,8 +3784,6 @@ CONFIG_SYS_SCRATCH_VA CONFIG_SYS_SCSI_MAX_DEVICE CONFIG_SYS_SCSI_MAX_LUN CONFIG_SYS_SCSI_MAX_SCSI_ID -CONFIG_SYS_SDHC_CLK -CONFIG_SYS_SDHC_CLK_2_PLL CONFIG_SYS_SDIO0 CONFIG_SYS_SDIO0_MAX_CLK CONFIG_SYS_SDIO1
The QorIQ eSDHC controller supports two reference clocks. They are platform clock and periperhal clock. The global variable sdhc_clk has already been used for platform clock. This patch is to add another global variable sdhc_per_clk for periperhal clock, which provides higher frequency and is required to be used for SD UHS and eMMC HS200/HS400 speed modes.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- arch/arm/include/asm/global_data.h | 4 ++++ arch/powerpc/include/asm/global_data.h | 1 + 2 files changed, 5 insertions(+)
diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index 1774014..f23b6bf 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -13,6 +13,10 @@ struct arch_global_data { u32 sdhc_clk; #endif
+#if defined(CONFIG_FSL_ESDHC) + u32 sdhc_per_clk; +#endif + #if defined(CONFIG_U_QE) u32 qe_clk; u32 brg_clk; diff --git a/arch/powerpc/include/asm/global_data.h b/arch/powerpc/include/asm/global_data.h index b6e4dd6..1620fba 100644 --- a/arch/powerpc/include/asm/global_data.h +++ b/arch/powerpc/include/asm/global_data.h @@ -14,6 +14,7 @@ struct arch_global_data { #if defined(CONFIG_FSL_ESDHC) u32 sdhc_clk; + u32 sdhc_per_clk; #if defined(CONFIG_FSL_ESDHC_ADAPTER_IDENT) u8 sdhc_adapter; #endif
The SDHC clock divider value for LS1028A should be default 2, not 1.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 1 - configs/ls1028aqds_tfa_defconfig | 1 - configs/ls1028ardb_tfa_SECURE_BOOT_defconfig | 1 - configs/ls1028ardb_tfa_defconfig | 1 - 4 files changed, 4 deletions(-)
diff --git a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig index a69e892..149f0b6 100644 --- a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig @@ -3,7 +3,6 @@ CONFIG_TARGET_LS1028AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_NXP_ESBC=y -CONFIG_SYS_FSL_SDHC_CLK_DIV=1 CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index 538830d..da59b9c 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1028AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x6000 -CONFIG_SYS_FSL_SDHC_CLK_DIV=1 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig index 55769c7..e287d08 100644 --- a/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig @@ -3,7 +3,6 @@ CONFIG_TARGET_LS1028ARDB=y CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_NXP_ESBC=y -CONFIG_SYS_FSL_SDHC_CLK_DIV=1 CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index 870d6b7..4ceecbc 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1028ARDB=y CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x6000 -CONFIG_SYS_FSL_SDHC_CLK_DIV=1 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2
The eSDHC reference clocks should be provided by speed.c in arch/. And we do not need CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK option to select which clock to use. Because we can make the driver to select the periperhal clock which is better (provides higher frequency) automatically if its value is provided by speed.c.
This patch is to drop this option and make driver to select clock automatically. Also fix peripheral clock calculation issue in fsl_lsch2_speed.c/fsl_lsch3_speed.c.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 29 +++++++------------- .../arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c | 22 +++++++-------- drivers/mmc/Kconfig | 9 ------ drivers/mmc/fsl_esdhc.c | 32 +++++++++++++++------- 4 files changed, 42 insertions(+), 50 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 25e9a49..fec2318 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -125,7 +125,6 @@ void get_sys_info(struct sys_info *sys_info) } #endif
-#ifdef CONFIG_FSL_ESDHC #define HWA_CGA_M2_CLK_SEL 0x00000007 #define HWA_CGA_M2_CLK_SHIFT 0 #if defined(CONFIG_TARGET_LS1046ARDB) || defined(CONFIG_TARGET_LS1043ARDB) @@ -148,11 +147,10 @@ void get_sys_info(struct sys_info *sys_info) break; #endif default: - printf("Error: Unknown peripheral clock select!\n"); + printf("Error: Unknown cluster group A mux 2 clock select!\n"); break; } #endif -#endif
#if defined(CONFIG_FSL_IFC) sys_info->freq_localbus = sys_info->freq_systembus / @@ -179,28 +177,21 @@ unsigned long get_qman_freq(void) int get_clocks(void) { struct sys_info sys_info; - +#ifdef CONFIG_FSL_ESDHC + u32 clock = 0; +#endif get_sys_info(&sys_info); gd->cpu_clk = sys_info.freq_processor[0]; gd->bus_clk = sys_info.freq_systembus / CONFIG_SYS_FSL_PCLK_DIV; gd->mem_clk = sys_info.freq_ddrbus; - #ifdef CONFIG_FSL_ESDHC -#if defined(CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK) -#if defined(CONFIG_TARGET_LS1046ARDB) - gd->arch.sdhc_clk = sys_info.freq_cga_m2 / 2; -#endif -#if defined(CONFIG_TARGET_LS1043ARDB) - gd->arch.sdhc_clk = sys_info.freq_cga_m2; -#endif -#if defined(CONFIG_TARGET_LS1012ARDB) - gd->arch.sdhc_clk = sys_info.freq_systembus; -#endif -#else - gd->arch.sdhc_clk = (sys_info.freq_systembus / - CONFIG_SYS_FSL_PCLK_DIV) / - CONFIG_SYS_FSL_SDHC_CLK_DIV; +#if defined(CONFIG_ARCH_LS1012A) + clock = sys_info.freq_systembus; +#elif defined(CONFIG_ARCH_LS1043A) || defined(CONFIG_ARCH_LS1046A) + clock = sys_info.freq_cga_m2; #endif + gd->arch.sdhc_per_clk = clock / CONFIG_SYS_FSL_SDHC_CLK_DIV; + gd->arch.sdhc_clk = gd->bus_clk / CONFIG_SYS_FSL_SDHC_CLK_DIV; #endif if (gd->cpu_clk != 0) return 0; diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c index 4b047a3..bd8b9cb 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c @@ -160,14 +160,14 @@ void get_sys_info(struct sys_info *sys_info) break; } #endif -#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LS2080A) - sys_info->freq_cga_m2 = sys_info->freq_systembus; -#endif }
int get_clocks(void) { struct sys_info sys_info; +#ifdef CONFIG_FSL_ESDHC + u32 clock = 0; +#endif get_sys_info(&sys_info); gd->cpu_clk = sys_info.freq_processor[0]; gd->bus_clk = sys_info.freq_systembus / CONFIG_SYS_FSL_PCLK_DIV; @@ -175,18 +175,16 @@ int get_clocks(void) #ifdef CONFIG_SYS_FSL_HAS_DP_DDR gd->arch.mem2_clk = sys_info.freq_ddrbus2; #endif -#if defined(CONFIG_FSL_ESDHC) -#if defined(CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK) -#if defined(CONFIG_ARCH_LS1028A) || defined(CONFIG_ARCH_LX2160A) - gd->arch.sdhc_clk = sys_info.freq_cga_m2 / 2; -#endif -#if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LS1088A) - gd->arch.sdhc_clk = sys_info.freq_cga_m2; + +#ifdef CONFIG_FSL_ESDHC +#if defined(CONFIG_ARCH_LS1028A) || defined(CONFIG_ARCH_LS1088A) + clock = sys_info.freq_cga_m2; +#elif defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LS2080A) + clock = sys_info.freq_systembus; #endif -#else + gd->arch.sdhc_per_clk = clock / CONFIG_SYS_FSL_SDHC_CLK_DIV; gd->arch.sdhc_clk = gd->bus_clk / CONFIG_SYS_FSL_SDHC_CLK_DIV; #endif -#endif /* defined(CONFIG_FSL_ESDHC) */
if (gd->cpu_clk != 0) return 0; diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 85fd190..f0d33d1 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -711,19 +711,10 @@ endif
config FSL_ESDHC bool "Freescale/NXP eSDHC controller support" - select FSL_ESDHC_USE_PERIPHERAL_CLK if MMC_HS200_SUPPORT || MMC_UHS_SUPPORT help This selects support for the eSDHC (Enhanced Secure Digital Host Controller) found on numerous Freescale/NXP SoCs.
-config FSL_ESDHC_USE_PERIPHERAL_CLK - bool "enable ESDHC peripheral clock support" - depends on FSL_ESDHC - help - eSDHC supports two reference clocks (platform clock and peripheral clock). - Peripheral clock which could provide higher clock frequency is required to - be used for tuning of SD UHS mode and eMMC HS200/HS400 modes. - config FSL_ESDHC_IMX bool "Freescale/NXP i.MX eSDHC controller support" help diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 8655503..112f115 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -81,6 +81,7 @@ struct fsl_esdhc_plat { struct fsl_esdhc_priv { struct fsl_esdhc *esdhc_regs; unsigned int sdhc_clk; + bool is_sdhc_per_clk; unsigned int clock; #if !CONFIG_IS_ENABLED(DM_MMC) struct mmc *mmc; @@ -523,7 +524,6 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); }
-#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK static void esdhc_clock_control(struct fsl_esdhc_priv *priv, bool enable) { struct fsl_esdhc *regs = priv->esdhc_regs; @@ -550,18 +550,18 @@ static void esdhc_clock_control(struct fsl_esdhc_priv *priv, bool enable) mdelay(1); } } -#endif
static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) { struct fsl_esdhc *regs = priv->esdhc_regs;
-#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK - /* Select to use peripheral clock */ - esdhc_clock_control(priv, false); - esdhc_setbits32(®s->esdhcctl, ESDHCCTL_PCS); - esdhc_clock_control(priv, true); -#endif + if (priv->is_sdhc_per_clk) { + /* Select to use peripheral clock */ + esdhc_clock_control(priv, false); + esdhc_setbits32(®s->esdhcctl, ESDHCCTL_PCS); + esdhc_clock_control(priv, true); + } + /* Set the clock speed */ if (priv->clock != mmc->clock) set_sysctl(priv, mmc, mmc->clock); @@ -779,6 +779,8 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg)
priv->esdhc_regs = (struct fsl_esdhc *)(unsigned long)(cfg->esdhc_base); priv->sdhc_clk = cfg->sdhc_clk; + if (gd->arch.sdhc_per_clk) + priv->is_sdhc_per_clk = true;
mmc_cfg = &plat->cfg;
@@ -817,7 +819,11 @@ int fsl_esdhc_mmc_init(bd_t *bis)
cfg = calloc(sizeof(struct fsl_esdhc_cfg), 1); cfg->esdhc_base = CONFIG_SYS_FSL_ESDHC_ADDR; - cfg->sdhc_clk = gd->arch.sdhc_clk; + /* Prefer peripheral clock which provides higher frequency. */ + if (gd->arch.sdhc_per_clk) + cfg->sdhc_clk = gd->arch.sdhc_per_clk; + else + cfg->sdhc_clk = gd->arch.sdhc_clk; return fsl_esdhc_initialize(bis, cfg); } #else /* DM_MMC */ @@ -839,7 +845,13 @@ static int fsl_esdhc_probe(struct udevice *dev) #endif priv->dev = dev;
- priv->sdhc_clk = gd->arch.sdhc_clk; + if (gd->arch.sdhc_per_clk) { + priv->sdhc_clk = gd->arch.sdhc_per_clk; + priv->is_sdhc_per_clk = true; + } else { + priv->sdhc_clk = gd->arch.sdhc_clk; + } + if (priv->sdhc_clk <= 0) { dev_err(dev, "Unable to get clk for %s\n", dev->name); return -EINVAL;
Here is CI build result. https://travis-ci.org/yangbolu1991/u-boot-test/builds/627093385
Thanks.
-----Original Message----- From: Yangbo Lu yangbo.lu@nxp.com Sent: Thursday, December 19, 2019 6:59 PM To: u-boot@lists.denx.de Cc: Peng Fan peng.fan@nxp.com; Priyanka Jain priyanka.jain@nxp.com; Wolfgang Denk wd@denx.de; Y.b. Lu yangbo.lu@nxp.com Subject: [PATCH 0/6] Clean up eSDHC periperhal clock code
-- 2.7.4
Hi Peng and Priyanka,
Happy new year! Could you help to review this patch-set? It's related to MMC and QorIQ PowerPC/ARM.
Thanks.
Best regards, Yangbo Lu
-----Original Message----- From: Y.b. Lu Sent: Friday, December 20, 2019 11:56 AM To: Yangbo Lu yangbo.lu@nxp.com; u-boot@lists.denx.de Cc: Peng Fan peng.fan@nxp.com; Priyanka Jain priyanka.jain@nxp.com; Wolfgang Denk wd@denx.de Subject: RE: [PATCH 0/6] Clean up eSDHC periperhal clock code
Thanks.
-- 2.7.4
Y.b. Lu
Yangbo Lu
