[U-Boot] [PATCH] simple-bus: enable suport for of-platdata
Just do nothing in post_bind if of-platdata enabled, for there is no dm_scan_fdt_dev().
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
drivers/core/simple-bus.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/core/simple-bus.c b/drivers/core/simple-bus.c index 5c955da..9b79825 100644 --- a/drivers/core/simple-bus.c +++ b/drivers/core/simple-bus.c @@ -27,6 +27,9 @@ fdt_addr_t simple_bus_translate(struct udevice *dev, fdt_addr_t addr)
static int simple_bus_post_bind(struct udevice *dev) { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + return 0; +#else u32 cell[3]; int ret;
@@ -41,6 +44,7 @@ static int simple_bus_post_bind(struct udevice *dev) }
return dm_scan_fdt_dev(dev); +#endif }
UCLASS_DRIVER(simple_bus) = {
Hi Simon,
Found 1 typo on the subject, 'suport' should be 'support', do I need to send a new patch or you can correct it when you apply?
Hi Kever,
On 4 February 2017 at 17:24, Kever Yang kever.yang@rock-chips.com wrote:
Hi Simon,
I can correct it when I apply, should be soon.
- Simon
Thanks,
- Kever
On 7 February 2017 at 22:09, Simon Glass sjg@chromium.org wrote:
Hi Kever,
Hi Simon,
- Simon
Thanks,
- Kever
Corrected and
Applied to u-boot-dm, thanks!
Kever Yang
