[U-Boot] [PATCH v2 00/10] Update STM32 QSPI driver
This series : _ removes useless CONFIG_CLK flag _ fixes checkpatch warnings _ sorts include files in alphabetical order _ align DT bindings with kernel in DT and in driver code _ add chip select management _ uses dev_read_xxx API _ add reset support
Changes in v2: _ remove "update mode management" patch, will be reworked and submitted separately
Christophe Kerello (3): spi: stm32_qspi: Align reg-names with kernel 4.12 RC1 spi: stm32_qspi: Add st,stm32f469-qspi compatible string spi: stm32_qspi: Add chip select management
Patrice Chotard (6): spi: stm32_qspi: Remove CONFIG_CLK flag spi: stm32_qspi: Sort include files alphabetically spi: stm32_qspi: Use dev_read_xxx API spi: stm32_qspi: Add reset support ARM: dts: stm32: Add quadspi reset for stm32f746 ARM: dts: stm32: Update qspi bindings for stm32f746
Patrick Delaunay (1): spi: stm32_qspi: Solve issue detected by checkpatch
arch/arm/dts/stm32f746.dtsi | 3 +- drivers/spi/stm32_qspi.c | 91 ++++++++++++++++++++++++++++++--------------- 2 files changed, 62 insertions(+), 32 deletions(-)
As all platforms which uses this driver have CONFIG_CLK flag enable in their defconfig, we can remove it from driver code.
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
Changes in v2: None
drivers/spi/stm32_qspi.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 7d1801280773..41a488097c19 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -448,6 +448,8 @@ static int stm32_qspi_probe(struct udevice *bus) struct stm32_qspi_platdata *plat = dev_get_platdata(bus); struct stm32_qspi_priv *priv = dev_get_priv(bus); struct dm_spi_bus *dm_spi_bus; + struct clk clk; + int ret;
dm_spi_bus = bus->uclass_priv;
@@ -457,9 +459,6 @@ static int stm32_qspi_probe(struct udevice *bus)
priv->max_hz = plat->max_hz;
-#ifdef CONFIG_CLK - int ret; - struct clk clk; ret = clk_get_by_index(bus, 0, &clk); if (ret < 0) return ret; @@ -477,7 +476,6 @@ static int stm32_qspi_probe(struct udevice *bus) return priv->clock_rate; }
-#endif
setbits_le32(&priv->regs->cr, STM32_QSPI_CR_SSHIFT);
Fix parameters function alingemnt Fix variable declaration
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
Changes in v2: None
drivers/spi/stm32_qspi.c | 31 ++++++++++++++++++------------- 1 file changed, 18 insertions(+), 13 deletions(-)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 41a488097c19..a82c180089e0 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -206,6 +206,7 @@ static void _stm32_qspi_wait_for_ftf(struct stm32_qspi_priv *priv) static void _stm32_qspi_set_flash_size(struct stm32_qspi_priv *priv, u32 size) { u32 fsize = fls(size) - 1; + clrsetbits_le32(&priv->regs->dcr, STM32_QSPI_DCR_FSIZE_MASK << STM32_QSPI_DCR_FSIZE_SHIFT, fsize << STM32_QSPI_DCR_FSIZE_SHIFT); @@ -255,13 +256,15 @@ static unsigned int _stm32_qspi_gen_ccr(struct stm32_qspi_priv *priv) }
static void _stm32_qspi_enable_mmap(struct stm32_qspi_priv *priv, - struct spi_flash *flash) + struct spi_flash *flash) { + unsigned int ccr_reg; + priv->command = flash->read_cmd | CMD_HAS_ADR | CMD_HAS_DATA | CMD_HAS_DUMMY; priv->dummycycles = flash->dummy_byte * 8;
- unsigned int ccr_reg = _stm32_qspi_gen_ccr(priv); + ccr_reg = _stm32_qspi_gen_ccr(priv); ccr_reg |= (STM32_QSPI_CCR_MEM_MAP << STM32_QSPI_CCR_FMODE_SHIFT);
_stm32_qspi_wait_for_not_busy(priv); @@ -291,10 +294,12 @@ static void _stm32_qspi_start_xfer(struct stm32_qspi_priv *priv, u32 cr_reg) }
static int _stm32_qspi_xfer(struct stm32_qspi_priv *priv, - struct spi_flash *flash, unsigned int bitlen, - const u8 *dout, u8 *din, unsigned long flags) + struct spi_flash *flash, unsigned int bitlen, + const u8 *dout, u8 *din, unsigned long flags) { unsigned int words = bitlen / 8; + u32 ccr_reg; + int i;
if (flags & SPI_XFER_MMAP) { _stm32_qspi_enable_mmap(priv, flash); @@ -346,7 +351,7 @@ static int _stm32_qspi_xfer(struct stm32_qspi_priv *priv, }
if (flags & SPI_XFER_END) { - u32 ccr_reg = _stm32_qspi_gen_ccr(priv); + ccr_reg = _stm32_qspi_gen_ccr(priv); ccr_reg |= STM32_QSPI_CCR_IND_WRITE << STM32_QSPI_CCR_FMODE_SHIFT;
@@ -365,7 +370,7 @@ static int _stm32_qspi_xfer(struct stm32_qspi_priv *priv,
debug("%s: words:%d data:", __func__, words);
- int i = 0; + i = 0; while (words > i) { writeb(dout[i], &priv->regs->dr); debug("%02x ", dout[i]); @@ -379,7 +384,7 @@ static int _stm32_qspi_xfer(struct stm32_qspi_priv *priv, } } } else if (din) { - u32 ccr_reg = _stm32_qspi_gen_ccr(priv); + ccr_reg = _stm32_qspi_gen_ccr(priv); ccr_reg |= STM32_QSPI_CCR_IND_READ << STM32_QSPI_CCR_FMODE_SHIFT;
@@ -394,7 +399,7 @@ static int _stm32_qspi_xfer(struct stm32_qspi_priv *priv,
debug("%s: data:", __func__);
- int i = 0; + i = 0; while (words > i) { din[i] = readb(&priv->regs->dr); debug("%02x ", din[i]); @@ -518,7 +523,7 @@ static int stm32_qspi_release_bus(struct udevice *dev) }
static int stm32_qspi_xfer(struct udevice *dev, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) + const void *dout, void *din, unsigned long flags) { struct stm32_qspi_priv *priv; struct udevice *bus; @@ -536,12 +541,13 @@ static int stm32_qspi_set_speed(struct udevice *bus, uint speed) { struct stm32_qspi_platdata *plat = bus->platdata; struct stm32_qspi_priv *priv = dev_get_priv(bus); + u32 qspi_clk = priv->clock_rate; + u32 prescaler = 255; + u32 csht;
if (speed > plat->max_hz) speed = plat->max_hz;
- u32 qspi_clk = priv->clock_rate; - u32 prescaler = 255; if (speed > 0) { prescaler = DIV_ROUND_UP(qspi_clk, speed) - 1; if (prescaler > 255) @@ -550,7 +556,7 @@ static int stm32_qspi_set_speed(struct udevice *bus, uint speed) prescaler = 0; }
- u32 csht = DIV_ROUND_UP((5 * qspi_clk) / (prescaler + 1), 100000000); + csht = DIV_ROUND_UP((5 * qspi_clk) / (prescaler + 1), 100000000); csht = (csht - 1) & STM32_QSPI_DCR_CSHT_MASK;
_stm32_qspi_wait_for_not_busy(priv); @@ -560,7 +566,6 @@ static int stm32_qspi_set_speed(struct udevice *bus, uint speed) STM32_QSPI_CR_PRESCALER_SHIFT, prescaler << STM32_QSPI_CR_PRESCALER_SHIFT);
- clrsetbits_le32(&priv->regs->dcr, STM32_QSPI_DCR_CSHT_MASK << STM32_QSPI_DCR_CSHT_SHIFT, csht << STM32_QSPI_DCR_CSHT_SHIFT);
Sort include files by alphabetical order
Changes in v2: None
drivers/spi/stm32_qspi.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index a82c180089e0..4bc4455d2ef9 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -8,14 +8,14 @@ */
#include <common.h> +#include <clk.h> +#include <dm.h> +#include <errno.h> #include <malloc.h> #include <spi.h> #include <spi_flash.h> #include <asm/io.h> -#include <dm.h> -#include <errno.h> #include <asm/arch/stm32.h> -#include <clk.h>
DECLARE_GLOBAL_DATA_PTR;
Align qspi bindings following kernel dt-bindings Documentation/devicetree/bindings/mtd/stm32-quadspi.txt from kernel v4.12-rc1.
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
Changes in v2: None
drivers/spi/stm32_qspi.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 4bc4455d2ef9..fc1a34ea442c 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -420,13 +420,13 @@ static int stm32_qspi_ofdata_to_platdata(struct udevice *bus) int ret;
ret = fdt_get_named_resource(blob, node, "reg", "reg-names", - "QuadSPI", &res_regs); + "qspi", &res_regs); if (ret) { debug("Error: can't get regs base addresses(ret = %d)!\n", ret); return -ENOMEM; } ret = fdt_get_named_resource(blob, node, "reg", "reg-names", - "QuadSPI-memory", &res_mem); + "qspi_mm", &res_mem); if (ret) { debug("Error: can't get mmap base address(ret = %d)!\n", ret); return -ENOMEM;
Add "st,stm32f469-qspi" compatible which is used on kernel side. This will be necessary when DT will be synchronised from kernel.
Changes in v2: None
drivers/spi/stm32_qspi.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index fc1a34ea442c..9fe8b297a458 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -635,6 +635,7 @@ static const struct dm_spi_ops stm32_qspi_ops = {
static const struct udevice_id stm32_qspi_ids[] = { { .compatible = "st,stm32-qspi" }, + { .compatible = "st,stm32f469-qspi" }, { } };
Quad-SPI interface is able to manage 2 spi nor devices. FSEL bit selects the flash memory to be addressed in single flash mode.
Changes in v2: None
drivers/spi/stm32_qspi.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 9fe8b297a458..56ea5911239a 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -155,6 +155,8 @@ enum STM32_QSPI_CCR_FMODE { /* default SCK frequency, unit: HZ */ #define STM32_QSPI_DEFAULT_SCK_FREQ 108000000
+#define STM32_MAX_NORCHIP 2 + struct stm32_qspi_platdata { u32 base; u32 memory_map; @@ -212,6 +214,12 @@ static void _stm32_qspi_set_flash_size(struct stm32_qspi_priv *priv, u32 size) fsize << STM32_QSPI_DCR_FSIZE_SHIFT); }
+static void _stm32_qspi_set_cs(struct stm32_qspi_priv *priv, unsigned int cs) +{ + clrsetbits_le32(&priv->regs->cr, STM32_QSPI_CR_FSEL, + cs ? STM32_QSPI_CR_FSEL : 0); +} + static unsigned int _stm32_qspi_gen_ccr(struct stm32_qspi_priv *priv) { unsigned int ccr_reg = 0; @@ -497,10 +505,17 @@ static int stm32_qspi_claim_bus(struct udevice *dev) struct stm32_qspi_priv *priv; struct udevice *bus; struct spi_flash *flash; + struct dm_spi_slave_platdata *slave_plat;
bus = dev->parent; priv = dev_get_priv(bus); flash = dev_get_uclass_priv(dev); + slave_plat = dev_get_parent_platdata(dev); + + if (slave_plat->cs >= STM32_MAX_NORCHIP) + return -ENODEV; + + _stm32_qspi_set_cs(priv, slave_plat->cs);
_stm32_qspi_set_flash_size(priv, flash->size);
Use dev_read_xxx() instead of old manner fdt_xxx() API
Changes in v2: None
drivers/spi/stm32_qspi.c | 17 ++++++----------- 1 file changed, 6 insertions(+), 11 deletions(-)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 56ea5911239a..62875e2e4c89 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -16,8 +16,7 @@ #include <spi_flash.h> #include <asm/io.h> #include <asm/arch/stm32.h> - -DECLARE_GLOBAL_DATA_PTR; +#include <linux/ioport.h>
struct stm32_qspi_regs { u32 cr; /* 0x00 */ @@ -421,27 +420,23 @@ static int _stm32_qspi_xfer(struct stm32_qspi_priv *priv,
static int stm32_qspi_ofdata_to_platdata(struct udevice *bus) { - struct fdt_resource res_regs, res_mem; + struct resource res_regs, res_mem; struct stm32_qspi_platdata *plat = bus->platdata; - const void *blob = gd->fdt_blob; - int node = dev_of_offset(bus); int ret;
- ret = fdt_get_named_resource(blob, node, "reg", "reg-names", - "qspi", &res_regs); + ret = dev_read_resource_byname(bus, "qspi", &res_regs); if (ret) { debug("Error: can't get regs base addresses(ret = %d)!\n", ret); return -ENOMEM; } - ret = fdt_get_named_resource(blob, node, "reg", "reg-names", - "qspi_mm", &res_mem); + ret = dev_read_resource_byname(bus, "qspi_mm", &res_mem); if (ret) { debug("Error: can't get mmap base address(ret = %d)!\n", ret); return -ENOMEM; }
- plat->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", - STM32_QSPI_DEFAULT_SCK_FREQ); + plat->max_hz = dev_read_u32_default(bus, "spi-max-frequency", + STM32_QSPI_DEFAULT_SCK_FREQ);
plat->base = res_regs.start; plat->memory_map = res_mem.start;
In some situation, QSPI controller is already configured by an early boot stage, adding reset support will insure that QSPI controller is started from a pristine state.
Changes in v2: None
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 62875e2e4c89..f6cc35336320 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -12,6 +12,7 @@ #include <dm.h> #include <errno.h> #include <malloc.h> +#include <reset.h> #include <spi.h> #include <spi_flash.h> #include <asm/io.h> @@ -457,6 +458,7 @@ static int stm32_qspi_probe(struct udevice *bus) struct stm32_qspi_priv *priv = dev_get_priv(bus); struct dm_spi_bus *dm_spi_bus; struct clk clk; + struct reset_ctl reset_ctl; int ret;
dm_spi_bus = bus->uclass_priv; @@ -484,6 +486,19 @@ static int stm32_qspi_probe(struct udevice *bus) return priv->clock_rate; }
+ ret = reset_get_by_index(bus, 0, &reset_ctl); + if (ret) { + if (ret != -ENOENT) { + dev_err(bus, "failed to get reset\n"); + clk_disable(&clk); + return ret; + } + } else { + /* Reset QSPI controller */ + reset_assert(&reset_ctl); + udelay(2); + reset_deassert(&reset_ctl); + }
Add missing reset property in quadspi node.
Changes in v2: None
arch/arm/dts/stm32f746.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/stm32f746.dtsi b/arch/arm/dts/stm32f746.dtsi index 8581df9a2778..4845279ccfca 100644 --- a/arch/arm/dts/stm32f746.dtsi +++ b/arch/arm/dts/stm32f746.dtsi @@ -92,6 +92,7 @@ interrupts = <92>; spi-max-frequency = <108000000>; clocks = <&rcc 0 STM32F7_AHB3_CLOCK(QSPI)>; + resets = <&rcc STM32F7_AHB3_RESET(QSPI)>; status = "disabled"; }; usart1: serial@40011000 {
Align qspi bindings following kernel dt-bindings Documentation/devicetree/bindings/mtd/stm32-quadspi.txt from kernel v4.17-rc1.
arch/arm/dts/stm32f746.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/stm32f746.dtsi b/arch/arm/dts/stm32f746.dtsi index 4845279ccfca..afa7832f8936 100644 --- a/arch/arm/dts/stm32f746.dtsi +++ b/arch/arm/dts/stm32f746.dtsi @@ -88,7 +88,7 @@ #address-cells = <1>; #size-cells = <0>; reg = <0xA0001000 0x1000>, <0x90000000 0x10000000>; - reg-names = "QuadSPI", "QuadSPI-memory"; + reg-names = "qspi", "qspi_mm"; interrupts = <92>; spi-max-frequency = <108000000>; clocks = <&rcc 0 STM32F7_AHB3_CLOCK(QSPI)>;
On Mon, May 14, 2018 at 7:12 PM, Patrice Chotard patrice.chotard@st.com wrote:
Reviewed-by: Jagan Teki jagan@openedev.com
Applied to u-boot-spi/master
Jagan Teki
Patrice Chotard
