[U-Boot] [PATCH] m5373evb: Update NAND driver to new API.
Signed-off-by: Scott Wood scottwood@freescale.com --- I don't have hardware or a toolchain to test, so any help in that regard is appreciated.
Applied to u-boot-nand-flash.
board/freescale/m5373evb/nand.c | 64 +++++++++++---------------------------- 1 files changed, 18 insertions(+), 46 deletions(-)
diff --git a/board/freescale/m5373evb/nand.c b/board/freescale/m5373evb/nand.c index 344a614..404a9c3 100644 --- a/board/freescale/m5373evb/nand.c +++ b/board/freescale/m5373evb/nand.c @@ -36,64 +36,39 @@ DECLARE_GLOBAL_DATA_PTR; #include <linux/mtd/mtd.h>
#define SET_CLE 0x10 -#define CLR_CLE ~SET_CLE #define SET_ALE 0x08 -#define CLR_ALE ~SET_ALE
-static void nand_hwcontrol(struct mtd_info *mtdinfo, int cmd) +static void nand_hwcontrol(struct mtd_info *mtdinfo, int cmd, unsigned int ctrl) { struct nand_chip *this = mtdinfo->priv; volatile fbcs_t *fbcs = (fbcs_t *) MMAP_FBCS; u32 nand_baseaddr = (u32) this->IO_ADDR_W;
- switch (cmd) { - case NAND_CTL_SETNCE: - case NAND_CTL_CLRNCE: - break; - case NAND_CTL_SETCLE: - nand_baseaddr |= SET_CLE; - break; - case NAND_CTL_CLRCLE: - nand_baseaddr &= CLR_CLE; - break; - case NAND_CTL_SETALE: - nand_baseaddr |= SET_ALE; - break; - case NAND_CTL_CLRALE: - nand_baseaddr |= CLR_ALE; - break; - case NAND_CTL_SETWP: - fbcs->csmr2 |= FBCS_CSMR_WP; - break; - case NAND_CTL_CLRWP: - fbcs->csmr2 &= ~FBCS_CSMR_WP; - break; - } - this->IO_ADDR_W = (void __iomem *)(nand_baseaddr); -} + if (ctrl & NAND_CTRL_CHANGE) { + ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; + IO_ADDR_W &= ~(SET_ALE | SE_CLE);
-static void nand_write_byte(struct mtd_info *mtdinfo, u_char byte) -{ - struct nand_chip *this = mtdinfo->priv; - *((volatile u8 *)(this->IO_ADDR_W)) = byte; -} + if (ctrl & NAND_CLE) + IO_ADDR_W |= SET_CLE; + if (ctrl & NAND_ALE) + IO_ADDR_W |= SET_ALE;
-static u8 nand_read_byte(struct mtd_info *mtdinfo) -{ - struct nand_chip *this = mtdinfo->priv; - return (u8) (*((volatile u8 *)this->IO_ADDR_R)); -} + at91_set_gpio_value(AT91_PIN_PD15, !(ctrl & NAND_NCE)); + this->IO_ADDR_W = (void *)IO_ADDR_W;
-static int nand_dev_ready(struct mtd_info *mtdinfo) -{ - return 1; + } + + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); }
int board_nand_init(struct nand_chip *nand) { volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; + volatile fbcs_t *fbcs = (fbcs_t *) MMAP_FBCS;
*((volatile u16 *)CFG_LATCH_ADDR) |= 0x0004; + fbcs->csmr2 &= ~FBCS_CSMR_WP;
/* set up pin configuration */ gpio->par_timer &= ~GPIO_PAR_TIN3_TIN3; @@ -103,11 +78,8 @@ int board_nand_init(struct nand_chip *nand) gpio->podr_timer = 0;
nand->chip_delay = 50; - nand->eccmode = NAND_ECC_SOFT; - nand->hwcontrol = nand_hwcontrol; - nand->read_byte = nand_read_byte; - nand->write_byte = nand_write_byte; - nand->dev_ready = nand_dev_ready; + nand->ecc.mode = NAND_ECC_SOFT; + nand->cmd_ctrl = nand_hwcontrol;
return 0; }
Scott Wood
