[U-Boot] [PATCH v2 09/16] [PATCH] lm75: Make the LM75 MULTI_BUS compatible.
Signed-off-by: Heiko Schocher hs@denx.de --- drivers/hwmon/lm75.c | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/drivers/hwmon/lm75.c b/drivers/hwmon/lm75.c index f544ebb..17379e5 100644 --- a/drivers/hwmon/lm75.c +++ b/drivers/hwmon/lm75.c @@ -155,6 +155,10 @@ int dtt_init (void) const char *const header = "DTT: "; int old_bus;
+ /* switch to correct I2C bus */ + old_bus = I2C_GET_BUS(); + I2C_SET_BUS(CFG_DTT_BUS_NUM); + for (i = 0; i < sizeof(sensors); i++) { if (_dtt_init(sensors[i]) != 0) printf("%s%d FAILED INIT\n", header, i+1); @@ -162,6 +166,8 @@ int dtt_init (void) printf("%s%d is %i C\n", header, i+1, dtt_get_temp(sensors[i])); } + /* switch back to original I2C bus */ + I2C_SET_BUS(old_bus);
return (0); } /* dtt_init() */
Heiko Schocher
