[U-Boot] [PATCH v3] usb: do explicit unaligned accesses
usb_hub_descriptor has to be packed as it's used for communication with the device. Member wHubCharacteristics violates the natural alignment rules.
Use explicit unaligned access functions for this member. Fixes ARMv7 traping while using USB.
v2: fix typo found by Thomas Langer
v3: rebased on top of u-boot-usb/master
Signed-off-by: Lucas Stach dev@lynxeye.de --- common/usb_hub.c | 14 +++++++++----- drivers/usb/host/ehci-hcd.c | 7 +++++-- 2 Dateien geändert, 14 Zeilen hinzugefügt(+), 7 Zeilen entfernt(-)
diff --git a/common/usb_hub.c b/common/usb_hub.c index 53d939c..e4a1201 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -43,6 +43,7 @@ #include <common.h> #include <command.h> #include <asm/processor.h> +#include <asm/unaligned.h> #include <linux/ctype.h> #include <asm/byteorder.h> #include <asm/unaligned.h> @@ -269,6 +270,7 @@ static int usb_hub_configure(struct usb_device *dev) int i; ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buffer, USB_BUFSIZ); unsigned char *bitmap; + short hubCharacteristics; struct usb_hub_descriptor *descriptor; struct usb_hub_device *hub; #ifdef USB_HUB_DEBUG @@ -304,8 +306,9 @@ static int usb_hub_configure(struct usb_device *dev) } memcpy((unsigned char *)&hub->desc, buffer, descriptor->bLength); /* adjust 16bit values */ - hub->desc.wHubCharacteristics = - le16_to_cpu(descriptor->wHubCharacteristics); + put_unaligned(le16_to_cpu(get_unaligned( + &descriptor->wHubCharacteristics)), + &hub->desc.wHubCharacteristics); /* set the bitmap */ bitmap = (unsigned char *)&hub->desc.DeviceRemovable[0]; /* devices not removable by default */ @@ -322,7 +325,8 @@ static int usb_hub_configure(struct usb_device *dev) dev->maxchild = descriptor->bNbrPorts; USB_HUB_PRINTF("%d ports detected\n", dev->maxchild);
- switch (hub->desc.wHubCharacteristics & HUB_CHAR_LPSM) { + hubCharacteristics = get_unaligned(&hub->desc.wHubCharacteristics); + switch (hubCharacteristics & HUB_CHAR_LPSM) { case 0x00: USB_HUB_PRINTF("ganged power switching\n"); break; @@ -335,12 +339,12 @@ static int usb_hub_configure(struct usb_device *dev) break; }
- if (hub->desc.wHubCharacteristics & HUB_CHAR_COMPOUND) + if (hubCharacteristics & HUB_CHAR_COMPOUND) USB_HUB_PRINTF("part of a compound device\n"); else USB_HUB_PRINTF("standalone hub\n");
- switch (hub->desc.wHubCharacteristics & HUB_CHAR_OCPM) { + switch (hubCharacteristics & HUB_CHAR_OCPM) { case 0x00: USB_HUB_PRINTF("global over-current protection\n"); break; diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index 0fb7c46..8537201 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -22,6 +22,7 @@ */ #include <common.h> #include <asm/byteorder.h> +#include <asm/unaligned.h> #include <usb.h> #include <asm/io.h> #include <malloc.h> @@ -876,10 +877,12 @@ int usb_lowlevel_init(int index, void **controller) printf("Register %x NbrPorts %d\n", reg, descriptor.hub.bNbrPorts); /* Port Indicators */ if (HCS_INDICATOR(reg)) - descriptor.hub.wHubCharacteristics |= 0x80; + put_unaligned(get_unaligned(&descriptor.hub.wHubCharacteristics) + | 0x80, &descriptor.hub.wHubCharacteristics); /* Port Power Control */ if (HCS_PPC(reg)) - descriptor.hub.wHubCharacteristics |= 0x01; + put_unaligned(get_unaligned(&descriptor.hub.wHubCharacteristics) + | 0x01, &descriptor.hub.wHubCharacteristics);
/* Start the host controller. */ cmd = ehci_readl(&ehcic[index].hcor->or_usbcmd);
Dear Lucas Stach,
Applied and pushed
- short hubCharacteristics; struct usb_hub_descriptor *descriptor; struct usb_hub_device *hub;
- put_unaligned(le16_to_cpu(get_unaligned(
/* set the bitmap */ bitmap = (unsigned char *)&hub->desc.DeviceRemovable[0]; /* devices not removable by default */&hub->desc.wHubCharacteristics);
- hubCharacteristics = get_unaligned(&hub->desc.wHubCharacteristics);
- switch (hubCharacteristics & HUB_CHAR_LPSM) { case 0x00: USB_HUB_PRINTF("ganged power switching\n"); break;
- if (hubCharacteristics & HUB_CHAR_COMPOUND) USB_HUB_PRINTF("part of a compound device\n"); else USB_HUB_PRINTF("standalone hub\n");
- switch (hubCharacteristics & HUB_CHAR_OCPM) { case 0x00: USB_HUB_PRINTF("global over-current protection\n"); break;
/* Port Power Control */ if (HCS_PPC(reg))| 0x80, &descriptor.hub.wHubCharacteristics);
Lucas Stach
