[PATCH v4 1/1] driver: watchdog: get platform clock from dt file
Get the watchdog platform clock from the DTS file using clk subsystem and use the same for calculating ticks in msec.
Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com Signed-off-by: Bharat Kumar Reddy Gooty bharat.gooty@broadcom.com --- Changes from v3: -Address review comments from Stefan Roese, Don't return error if clk_get_by_index() fails becasue all platform may not have clock support.
Changes from v2: -Address review comments from Stefan Roese, Use clk subsystem to get the base frequency of device instead of dt parameter "clk_mhz".
Changes from v1: -Address review comments from Stefan Roese, Remove default timeout reading in probe() as it is read in include/wdt.h. Add paranthesis on multi-line statements.
drivers/watchdog/sp805_wdt.c | 15 +++++++++++++-- 1 file changed, 13 insertions(+), 2 deletions(-)
diff --git a/drivers/watchdog/sp805_wdt.c b/drivers/watchdog/sp805_wdt.c index ca3ccbe76c..65fd2384f1 100644 --- a/drivers/watchdog/sp805_wdt.c +++ b/drivers/watchdog/sp805_wdt.c @@ -7,6 +7,7 @@
#include <asm/io.h> #include <common.h> +#include <clk.h> #include <dm/device.h> #include <dm/fdtaddr.h> #include <dm/read.h> @@ -34,6 +35,7 @@ DECLARE_GLOBAL_DATA_PTR;
struct sp805_wdt_priv { void __iomem *reg; + unsigned long clk_rate; };
static int sp805_wdt_reset(struct udevice *dev) @@ -63,8 +65,13 @@ static int sp805_wdt_start(struct udevice *dev, u64 timeout, ulong flags) * set 120s, the gd->bus_clk is less than 1145MHz, the load_value will * not overflow. */ - load_value = (gd->bus_clk) / - (2 * 1000 * SYS_FSL_WDT_CLK_DIV) * load_time; + if (gd->bus_clk) { + load_value = (gd->bus_clk) / + (2 * 1000 * SYS_FSL_WDT_CLK_DIV) * load_time; + } else { + /* platform provide clk */ + load_value = (timeout / 2) * (priv->clk_rate / 1000); + }
writel(UNLOCK, priv->reg + WDTLOCK); writel(load_value, priv->reg + WDTLOAD); @@ -105,11 +112,15 @@ static int sp805_wdt_probe(struct udevice *dev) static int sp805_wdt_ofdata_to_platdata(struct udevice *dev) { struct sp805_wdt_priv *priv = dev_get_priv(dev); + struct clk clk;
priv->reg = (void __iomem *)dev_read_addr(dev); if (IS_ERR(priv->reg)) return PTR_ERR(priv->reg);
+ if (!clk_get_by_index(dev, 0, &clk)) + priv->clk_rate = clk_get_rate(&clk); + return 0; }
But I still would like to see a comment or best "tested-by" tag from seom NXP folks, using this driver.
Thanks, Stefan
if (gd->bus_clk) {
} else {
struct clk clk;
return 0; }
Viele Grüße, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
if (gd->bus_clk) {
} else {
struct clk clk;
return 0; }
Viele Grüße, Stefan
Rayagonda Kokatanur
Stefan Roese
