[PATCH 1/3] ARM: imx: novena: Move defconfig bits to arch Kconfig
Just move the defconfig entries which are required into the Novena entry in arch Kconfig, no functional change.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Vagrant Cascadian vagrant@debian.org --- arch/arm/mach-imx/mx6/Kconfig | 8 ++++++++ configs/novena_defconfig | 8 -------- 2 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 9d91f9ab44..811c41d906 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -259,7 +259,15 @@ config TARGET_GW_VENTANA config TARGET_KOSAGI_NOVENA bool "Kosagi Novena" select BOARD_LATE_INIT + select DM_GPIO + select DM_MMC + select DM_PCI + select DM_SCSI + select DM_USB + select DM_VIDEO + select OF_CONTROL select SUPPORT_SPL + imply CMD_DM
config TARGET_MCCMON6 bool "mccmon6" diff --git a/configs/novena_defconfig b/configs/novena_defconfig index f14f82b9a6..2fd89b2939 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -8,7 +8,6 @@ CONFIG_MX6_DDRCAL=y CONFIG_TARGET_KOSAGI_NOVENA=y CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DM_GPIO=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 @@ -33,7 +32,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y -CONFIG_CMD_DM=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y @@ -44,7 +42,6 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_PARTITION_UUIDS is not set -CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-novena" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y @@ -52,19 +49,15 @@ CONFIG_ENV_OFFSET_REDUND=0x84000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_DWC_AHSATA=y -CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_MII=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y -CONFIG_DM_SCSI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y @@ -74,7 +67,6 @@ CONFIG_USB_ETH_CDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y -CONFIG_DM_VIDEO=y CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y
Convert to DM ethernet to prevent board removal.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Vagrant Cascadian vagrant@debian.org --- arch/arm/mach-imx/mx6/Kconfig | 1 + configs/novena_defconfig | 2 ++ include/configs/novena.h | 9 ++------- 3 files changed, 5 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 811c41d906..f9f576d403 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -259,6 +259,7 @@ config TARGET_GW_VENTANA config TARGET_KOSAGI_NOVENA bool "Kosagi Novena" select BOARD_LATE_INIT + select DM_ETH select DM_GPIO select DM_MMC select DM_PCI diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 2fd89b2939..b20bbab454 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -53,6 +53,8 @@ CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y CONFIG_PCI=y CONFIG_PINCTRL=y diff --git a/include/configs/novena.h b/include/configs/novena.h index c03b8db2ba..2b8419563c 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -53,13 +53,8 @@ #include "imx6_spl.h" /* common IMX6 SPL configuration */
/* Ethernet Configuration */ -#ifdef CONFIG_CMD_NET -#define CONFIG_FEC_MXC -#define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_XCV_TYPE RGMII -#define CONFIG_ETHPRIME "FEC" -#define CONFIG_FEC_MXC_PHYADDR 0x7 -#define CONFIG_ARP_TIMEOUT 200UL +#ifdef CONFIG_SPL_BUILD +#undef CONFIG_DM_ETH #endif
/* I2C */
Convert to DM ethernet to prevent board removal. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Vagrant Cascadian vagrant@debian.org
Best regards, Stefano Babic
Enable DM thermal driver and iMX thermal driver to get accurate CPU frequency reporting in the boot log.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Vagrant Cascadian vagrant@debian.org --- configs/novena_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/novena_defconfig b/configs/novena_defconfig index b20bbab454..0967d2d284 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -59,6 +59,8 @@ CONFIG_MII=y CONFIG_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y
Enable DM thermal driver and iMX thermal driver to get accurate CPU frequency reporting in the boot log. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Vagrant Cascadian vagrant@debian.org
Just move the defconfig entries which are required into the Novena entry in arch Kconfig, no functional change. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Vagrant Cascadian vagrant@debian.org
sbabic@denx.de
