[U-Boot] [PATCH 8/8] APM82xxx: Add top level common file changes
Add bluestone board name to the board.cfg. Change Makefile to include bluestone board support. Modified MAINTAINERS file to include board maintainers name. Modified to include blouestone entry in the MAKEALL file.
Signed-off-by: Tirumala R Marri tmarri@apm.com --- MAINTAINERS | 3 +++ MAKEALL | 1 + Makefile | 7 +++++++ boards.cfg | 1 + 4 files changed, 12 insertions(+), 0 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 4b91b0f..263c00b 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -253,6 +253,9 @@ Feng Kan fkan@amcc.com
redwood PPC4xx
+Tirumala Marritmarri@apm.com + bluestone APM82XXX + Brad Kemp Brad.Kemp@seranoa.com
ppmc8260 MPC8260 diff --git a/MAKEALL b/MAKEALL index b34ae33..02d5c17 100755 --- a/MAKEALL +++ b/MAKEALL @@ -191,6 +191,7 @@ LIST_4xx=" \ ASH405 \ bamboo \ bamboo_nand \ + bluestone \ bubinga \ CANBT \ canyonlands \ diff --git a/Makefile b/Makefile index 4f1cb1b..8cd5bd3 100644 --- a/Makefile +++ b/Makefile @@ -926,6 +926,13 @@ bamboo_nand_config: unconfig @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk @$(MKCONFIG) -n $@ -a bamboo powerpc ppc4xx bamboo amcc
+# Maui Bluestone board images +bluestone_config: unconfig + @mkdir -p $(obj)include + @echo "#define CONFIG_$$(echo $(subst ,,$(@:_config=)) | \ + tr '[:lower:]' '[:upper:]')" >$(obj)include/config.h + @$(MKCONFIG) -n $@ -a bluestone powerpc ppc4xx bluestone amcc + # Arches, Canyonlands & Glacier use different U-Boot images arches_config \ canyonlands_config \ diff --git a/boards.cfg b/boards.cfg index 69c6897..48001d3 100644 --- a/boards.cfg +++ b/boards.cfg @@ -196,6 +196,7 @@ redwood powerpc ppc4xx - amcc taihu powerpc ppc4xx - amcc taishan powerpc ppc4xx - amcc yucca powerpc ppc4xx - amcc +bluestone powerpc ppc4xx - amcc AP1000 powerpc ppc4xx ap1000 amirix CRAYL1 powerpc ppc4xx L1 cray ADCIOP powerpc ppc4xx adciop esd
Hi Marri,
Not needed with board.cfg now. Please remove your changes to Makefile.
Compiling bluestone results in this warning:
[stefan@stefan-desktop u-boot (apm82xxx)]$ ./MAKEALL bluestone Configuring for bluestone board... cpu_init.c: In function 'cpu_init_f': cpu_init.c:226: warning: unused variable 'val'
Please fix and resubmit. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
[Marri] Sure will fix it.
Cheers, Stefan
Regards, Marri
Hi Stefan,
[Marri] You mean we only need board.cfg change and we don't need Makefile entry ?
Regards, Marri
Hi Marri,
Yes.
Cheers, Stefan
On 2010/09/01 12:35 AM, Tirumala Marri wrote:
Hi Stefan,
Yes, exactly.
Rogan
Dear tmarri@apm.com,
NAK. This must not ne a separate commit.
NAK. This is not needed and not allowed any more.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Sunday, August 29, 2010 1:57 AM To: tmarri@apm.com Cc: u-boot@lists.denx.de; open-source-review@apm.com Subject: Re: [U-Boot] [PATCH 8/8] APM82xxx: Add top level common file changes
Mr Wolfgang, Sure I will fix it. Regards, Marri
participants (5)
Rogan Dawes
Stefan Roese
Tirumala Marri
tmarriļ¼ apm.com
