[U-Boot] [PATCH 3/3] add mcf5307 support
Other modified files:
# modified: arch/m68k/include/asm/cache.h # modified: arch/m68k/include/asm/immap.h # modified: arch/m68k/include/asm/timer.h # modified: include/common.h
Signed-off-by: Angelo Dureghello sysamfw@gmail.com ---
diff --git a/arch/m68k/include/asm/cache.h b/arch/m68k/include/asm/cache.h index 7c84e48..e447f3c 100644 --- a/arch/m68k/include/asm/cache.h +++ b/arch/m68k/include/asm/cache.h @@ -31,7 +31,7 @@ #define CONFIG_CF_V2 #endif
-#if defined(CONFIG_MCF532x) || defined(CONFIG_MCF5301x) +#if defined(CONFIG_MCF530x) || defined(CONFIG_MCF532x) || defined(CONFIG_MCF5301x) #define CONFIG_CF_V3 #endif
diff --git a/arch/m68k/include/asm/immap.h b/arch/m68k/include/asm/immap.h index e83ce08..bc43f13 100644 --- a/arch/m68k/include/asm/immap.h +++ b/arch/m68k/include/asm/immap.h @@ -256,6 +256,28 @@ #endif #endif /* CONFIG_M5282 */
+#ifdef CONFIG_M5307 +#include <asm/immap_5307.h> +#include <asm/m5307.h> + +#define CONFIG_SYS_UART_BASE (MMAP_UART0 + (CONFIG_SYS_UART_PORT * 0x40)) + +#define CONFIG_SYS_INTR_BASE (MMAP_INTC) +#define CONFIG_SYS_NUM_IRQS (64) + +/* Timer */ +#ifdef CONFIG_MCFTMR +#define CONFIG_SYS_UDELAY_BASE (MMAP_DTMR0) +#define CONFIG_SYS_TMR_BASE (MMAP_DTMR1) +#define CONFIG_SYS_TMRPND_REG (mbar_readLong(MCFSIM_IPR)) +#define CONFIG_SYS_TMRINTR_NO (31) +#define CONFIG_SYS_TMRINTR_MASK (0x00000400) +#define CONFIG_SYS_TMRINTR_PEND (CONFIG_SYS_TMRINTR_MASK) +#define CONFIG_SYS_TMRINTR_PRI (MCFSIM_ICR_AUTOVEC | MCFSIM_ICR_LEVEL7 | MCFSIM_ICR_PRI3) +#define CONFIG_SYS_TIMER_PRESCALER (((gd->bus_clk / 1000000) - 1) << 8) +#endif +#endif /* CONFIG_M5307 */ + #if defined(CONFIG_MCF5301x) #include <asm/immap_5301x.h> #include <asm/m5301x.h> diff --git a/arch/m68k/include/asm/timer.h b/arch/m68k/include/asm/timer.h index 1a5de05..8516c8f 100644 --- a/arch/m68k/include/asm/timer.h +++ b/arch/m68k/include/asm/timer.h @@ -33,7 +33,7 @@ /****************************************************************************/ /* DMA Timer module registers */ typedef struct dtimer_ctrl { -#if defined(CONFIG_M5249) || defined(CONFIG_M5253) || defined(CONFIG_M5272) +#if defined(CONFIG_M5307) || defined(CONFIG_M5249) || defined(CONFIG_M5253) || defined(CONFIG_M5272) u16 tmr; /* 0x00 Mode register */ u16 res1; /* 0x02 */ u16 trr; /* 0x04 Reference register */ diff --git a/include/common.h b/include/common.h index 12a1074..40bfbe9 100644 --- a/include/common.h +++ b/include/common.h @@ -574,7 +574,7 @@ void get_sys_info ( sys_info_t * ); #if defined(CONFIG_8xx) || defined(CONFIG_8260) void cpu_init_f (volatile immap_t *immr); #endif -#if defined(CONFIG_4xx) || defined(CONFIG_MPC85xx) || defined(CONFIG_MCF52x2) ||defined(CONFIG_MPC86xx) +#if defined(CONFIG_4xx) || defined(CONFIG_MPC85xx) || defined(CONFIG_MCF52x2) || defined (CONFIG_MCF5307) || defined(CONFIG_MPC86xx) void cpu_init_f (void); #endif
Angelo Dureghello
