[U-Boot] usage of i2c command in hush script
20 Jan
2012
20 Jan
'12
5:36 a.m.
Hello, Is it possible to use i2c output in a u-boot script something like
if test "i2c md.0 68 f = 0x80";then; echo "Watchdog Triggered";else; echo "Power Cycle"; fi
the only problem is that i2c command outputs something like=> i2c md 68 f 000f: 00 .
and comparing the entire string is not working. Any inputs would help.
I can try this in the main_loop, but if i can do it in shell then i would want to avoid that.
Thanks Sridhar
4855
Sridhar Addagada
