[U-Boot] tools/Makefile broken?
Not sure what is going on but my build broke. I suspect commit d984fed068b3bec8a7edaf7a3de71479abde080a makefiles: fixes for building build tools
Currently, some of the tools instead set CC to be HOSTCC in order to re-use some pattern rules -- but this fails when the user overrides CC on the make command line. Also, the HOSTCFLAGS in tools/Makefile are currently not being used because config.mk overwrites them.
This patch adds static pattern rules for files that have been requested to be built with the native compiler using $(HOSTSRCS) and $(HOSTOBJS), and converts the tools to use them.
It restores easylogo to using the host compiler, which was broken by commit 38d299c2db81bd889c601b5dfc12c4e83ef83333 (if this was an intentional change, please let me know -- but it seems to be a build tool).
It restores -pedantic and the special flags for darwin and cygwin that were requested in tools/makefile (but keeps the flags added by config.mk) -- hopefully someone can test this on those platforms. It no longer conditionalizes -pedantic on not being darwin; it wasn't clear that that was intentional, and unless there's a real problem it's just inviting people to contribute non-pedantic patches to those files (I'm not a fan of -pedantic personally, but if it's on for one platform it should be on for all).
HOST_LDFLAGS is renamed HOSTLDFLAGS for consistency with the previous HOST_CFLAGS to HOSTCFLAGS rename. A new HOSTCFLAGS_NOPED is made available for those files which currently cannot be built with -pedantic, and replaces the old FIT_CFLAGS.
imls now uses the cross compiler properly, rather than by trying to reconstruct CC using the typoed $(CROSS_COMPILER).
envcrc.c is now dependency-processed unconditionally -- previously it would be built without being on (HOST)SRCS if CONFIG_ENV_IS_EMBEDDED was not selected.
Signed-off-by: Scott Wood scottwood@freescale.com gmake -C tools all gmake[1]: Entering directory `/usr/local/src/cutu2uboot/tools' powerpc-softfloat-linux-gnu-gcc -g -Os -mrelocatable -fPIC -meabi -DCONFIG_IDENT_STRING="\nCBX-0001A:cuboot02a:p1a:99" -D__KERNEL__ -DTEXT_BASE=0xF8020000 -I/usr/local/src/cutu2uboot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/powerpc-softfloat-linux-gnu/3.4.6/include -pipe -DCONFIG_PPC -D__powerpc__ -DCONFIG_MPC83xx -DCONFIG_E300 -ffixed-r2 -msoft-float -Wall -Wstrict-prototypes -fno-stack-protector -o crc32.o crc32.c -c powerpc-softfloat-linux-gnu-gcc -g -Os -mrelocatable -fPIC -meabi -DCONFIG_IDENT_STRING="\nCBX-0001A:cuboot02a:p1a:99" -D__KERNEL__ -DTEXT_BASE=0xF8020000 -I/usr/local/src/cutu2uboot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/powerpc-softfloat-linux-gnu/3.4.6/include -pipe -DCONFIG_PPC -D__powerpc__ -DCONFIG_MPC83xx -DCONFIG_E300 -ffixed-r2 -msoft-float -Wall -Wstrict-prototypes -fno-stack-protector -o env_embedded.o env_embedded.c -c gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /usr/local/src/cutu2uboot/include -idirafter /usr/local/src/cutu2uboot/include2 -idirafter /usr/local/src/cutu2uboot/include -I /usr/local/src/cutu2uboot/libfdt -I /usr/local/src/cutu2uboot/tools -DTEXT_BASE=0xF8020000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -pedantic -o envcrc.o envcrc.c -c powerpc-softfloat-linux-gnu-gcc -g -Os -mrelocatable -fPIC -meabi -DCONFIG_IDENT_STRING="\nCBX-0001A:cuboot02a:p1a:99" -D__KERNEL__ -DTEXT_BASE=0xF8020000 -I/usr/local/src/cutu2uboot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/powerpc-softfloat-linux-gnu/3.4.6/include -pipe -DCONFIG_PPC -D__powerpc__ -DCONFIG_MPC83xx -DCONFIG_E300 -ffixed-r2 -msoft-float -Wall -Wstrict-prototypes -fno-stack-protector -o sha1.o sha1.c -c gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /usr/local/src/cutu2uboot/include -idirafter /usr/local/src/cutu2uboot/include2 -idirafter /usr/local/src/cutu2uboot/include -I /usr/local/src/cutu2uboot/libfdt -I /usr/local/src/cutu2uboot/tools -DTEXT_BASE=0xF8020000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -pedantic -o envcrc crc32.o env_embedded.o envcrc.o sha1.o /usr/lib/gcc/i686-pc-linux-gnu/4.3.4/../../../../i686-pc-linux-gnu/bin/ld: crc32.o: Relocations in generic ELF (EM: 20) /usr/lib/gcc/i686-pc-linux-gnu/4.3.4/../../../../i686-pc-linux-gnu/bin/ld: crc32.o: Relocations in generic ELF (EM: 20) /usr/lib/gcc/i686-pc-linux-gnu/4.3.4/../../../../i686-pc-linux-gnu/bin/ld: crc32.o: Relocations in generic ELF (EM: 20) /usr/lib/gcc/i686-pc-linux-gnu/4.3.4/../../../../i686-pc-linux-gnu/bin/ld: crc32.o: Relocations in generic ELF (EM: 20) /usr/lib/gcc/i686-pc-linux-gnu/4.3.4/../../../../i686-pc-linux-gnu/bin/ld: crc32.o: Relocations in generic ELF (EM: 20) /usr/lib/gcc/i686-pc-linux-gnu/4.3.4/../../../../i686-pc-linux-gnu/bin/ld: crc32.o: Relocations in generic ELF (EM: 20) /usr/lib/gcc/i686-pc-linux-gnu/4.3.4/../../../../i686-pc-linux-gnu/bin/ld: crc32.o: Relocations in generic ELF (EM: 20) crc32.o: could not read symbols: File in wrong format collect2: ld returned 1 exit status gmake[1]: *** [envcrc] Error 1 gmake[1]: Leaving directory `/usr/local/src/cutu2uboot/tools' gmake: *** [tools] Error 2
Answering myself, the symlinks under tools isn't removed, not even a by a distclean. Kinda makes sense since now they aren't created anymore. Once needs to remove these by hand or do a clean checkout.
Jocke
Dear Joakim Tjernlund,
In message OF6C585F6E.B27CCCC8-ONC12576B0.0049C760-C12576B0.004A1C7B@transmode.se you wrote:
It helps to
1) run "make mrproper" before pulling in new versions 2) run "git clean -n -x" to get a list of all files not checked in 3) get used to run out-of-tree builds which makes sure your repository remains clean
(or any combination of this)
Joakim Tjernlund
